Ernst Posted July 18 Posted July 18 I Installed this image and it works fine. Sadly the build in WiFi module is not working. I now use an external wifi dongle. What could be the problem here? Ernst-Jan 0 Quote
Werner Posted July 18 Posted July 18 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Ernst Posted July 18 Author Posted July 18 Wow... OK, this is far beyond what I understand. I see a mediatek wifi dongle in USB 2-1 I think the plugged in dongle. But have no idea were the internal WiFi adapter is and how to activate it. It worked in a previous version of armbian ubuntu but not the latest I just found out... Ernst-Jan 0 Quote
Igor Posted July 18 Posted July 18 If you can experiment with the board, then try few other kernels: https://docs.armbian.com/User-Guide_Armbian-Config/System/#alternative-kernels and report where wifi will be up. 0 Quote
Solution Ernst Posted July 20 Author Solution Posted July 20 Hi Igor, This worked! Falling back to 6.1.115 and a working internal WiFi... Ernst-Jan 0 Quote
Ernst Posted July 20 Author Posted July 20 Maybe not the right place but the same happened on my OP5Ultra. The latest kernel stopped the internal WiFi module. Falling back to again 6.1.115 did the trick. So both Radxa 5B plus and OP5 ultra suffer the same problem when installing the latest Armbian Ubuntu. I assume other boards have similar problems... Ernst-Jan 0 Quote
armbuilder Posted July 21 Posted July 21 wifi works fine on our rock 5B+ board with the 6.18 Gnome build... 0 Quote
Ernst Posted July 22 Author Posted July 22 Hi Armbuilder, I tried them all but only 6.1.115 made the internal WiFi work. Are there different versions of the board maybe? Ernst 0 Quote
Ernst Posted July 22 Author Posted July 22 6.18.10 or 6.18.35? Gnome build? I look for kernels in armbianconfig... Ernst 0 Quote
armbuilder Posted July 22 Posted July 22 Actually spoke to soon, seeing this issue on the 6.18 kernel but happens randomly, its a known upstream issue that has been fixed in 7.1, but you guys should back port this fix here: Upstream fixed this exact Radxa/RTL8852BE problem by retrying the eFuse operation five times. The fix is https://chatgpt.com/g/g-p-69619e56d4d48191866d830f3ebddfc0/c/6a5ee909-da2c-83ea-981e-de8591585c8c, with the Wi‑Fi/BT contention confirmed by the Realtek maintainer in the patch discussion https://patchew.org/linux/20260301042422.195491-1-christianshewitt%40gmail.com/?utm_source=chatgpt.com. The fix: Is absent from 6.18.28 kernel. Is still absent from vanilla 6.18.39. First shipped upstream in Linux 7.1. A matching ROCK 5B+ Armbian trace shows the PCIe device and firmware loading successfully, followed by the eFuse failure and error -16. Matching Armbian report. 0 Quote
Werner Posted July 23 Posted July 23 Feel free to test and send a pr with a patch backporting this to 6.18 0 Quote
Ernst Posted July 23 Author Posted July 23 Well, I will wait until it works, no worry's. I wil not go back to the 115 kernel because the sbc is getting 10 degrees warmer than the latest gnome version, 47 degrees in the 6.1.115 and 36 in 6.18.28. Both with Firefox in YouTube with the same content... Te dongle works fine... Ernst 0 Quote
eselarm Posted July 23 Posted July 23 (edited) 26 minutes ago, Ernst said: 47 degrees in the 6.1.115 and 36 in 6.18.28 That is interesting, I would expect the other way around. I use 'btop' to watch clocks and load. On some systems, it also show GPU load and power consumption. Anyway, there is also the edge kernel (7.1.0-edge-rockchip64😞 linux-image-edge-rockchip64/trixie,now 26.5.1 arm64 [installed] Edited July 23 by eselarm 0 Quote
