Ernst Posted Saturday at 09:40 AM Posted Saturday at 09:40 AM I Installed this image and it works fine. Sadly the build in WiFi module is not working. I now use an external wifi dongle. What could be the problem here? Ernst-Jan 0 Quote
Werner Posted Saturday at 10:05 AM Posted Saturday at 10:05 AM Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Ernst Posted Saturday at 07:30 PM Author Posted Saturday at 07:30 PM https://paste.armbian.com/emoyipejug 0 Quote
Ernst Posted Saturday at 07:48 PM Author Posted Saturday at 07:48 PM Wow... OK, this is far beyond what I understand. I see a mediatek wifi dongle in USB 2-1 I think the plugged in dongle. But have no idea were the internal WiFi adapter is and how to activate it. It worked in a previous version of armbian ubuntu but not the latest I just found out... Ernst-Jan 0 Quote
Igor Posted Saturday at 08:22 PM Posted Saturday at 08:22 PM If you can experiment with the board, then try few other kernels: https://docs.armbian.com/User-Guide_Armbian-Config/System/#alternative-kernels and report where wifi will be up. 0 Quote
Solution Ernst Posted yesterday at 11:55 AM Author Solution Posted yesterday at 11:55 AM Hi Igor, This worked! Falling back to 6.1.115 and a working internal WiFi... Ernst-Jan 0 Quote
Ernst Posted 22 hours ago Author Posted 22 hours ago Maybe not the right place but the same happened on my OP5Ultra. The latest kernel stopped the internal WiFi module. Falling back to again 6.1.115 did the trick. So both Radxa 5B plus and OP5 ultra suffer the same problem when installing the latest Armbian Ubuntu. I assume other boards have similar problems... Ernst-Jan 0 Quote
armbuilder Posted 12 hours ago Posted 12 hours ago wifi works fine on our rock 5B+ board with the 6.18 Gnome build... 0 Quote
