No wifi Rock 5B plus 26.04 Gnome 6.18.28
Go to solution Solved by Ernst,
I Installed this image and it works fine. Sadly the build in WiFi module is not working. I now use an external wifi dongle.
What could be the problem here?
Ernst-Jan
Wow...
OK, this is far beyond what I understand.
I see a mediatek wifi dongle in USB 2-1 I think the plugged in dongle. But have no idea were the internal WiFi adapter is and how to activate it.
It worked in a previous version of armbian ubuntu but not the latest I just found out...
Ernst-Jan
Maybe not the right place but the same happened on my OP5Ultra. The latest kernel stopped the internal WiFi module. Falling back to again 6.1.115 did the trick.
So both Radxa 5B plus and OP5 ultra suffer the same problem when installing the latest Armbian Ubuntu. I assume other boards have similar problems...
Ernst-Jan
Hi Armbuilder,
I tried them all but only 6.1.115 made the internal WiFi work. Are there different versions of the board maybe?
Ernst
