aitek Posted October 25, 2018 Posted October 25, 2018 I use the FriendlyElec's img file working good. but Armbian_5.59 can't boot. at the end is always same: random: crng init done
Igor Posted October 25, 2018 Posted October 25, 2018 17 hours ago, aitek said: I use the FriendlyElec's img file working good. but Armbian_5.59 can't boot. at the end is always same: random: crng init done FriendlyARM uses very different setup. They have their own u-boot and kernel. My board works perfectly fine: http://ix.io/1q1R with this image: https://dl.armbian.com/nanopct3plus/Debian_stretch_next.7z Running low on ideas. It can be some different board revision. Have you tried to boot without anything attached? Power and serial console only. Do you have plus model - with 2G of memory? PSU = 5A SD card = Samsung EVO32GB
aitek Posted November 1, 2018 Posted November 1, 2018 i have change one SD card,but still have same problem. at the end is show: crng init done. then freeze. but new 5.65 the screen can show the log. not like before always black.
aitek Posted November 1, 2018 Posted November 1, 2018 this is my boot log: http://47.52.204.202/boot.log
Igor Posted November 1, 2018 Posted November 1, 2018 On 10/25/2018 at 10:09 PM, Igor said: Have you tried to boot without anything attached? I see you have keyboard at USB.
aitek Posted November 1, 2018 Posted November 1, 2018 still cannot, this is log: http://47.52.204.202/boot-without-usb.log
NicoD Posted November 1, 2018 Posted November 1, 2018 I`ve installed Bionic and Stretch 2 days ago on my T3+, both worked fine. I see there`s a segmentation fault. Is this a clue? RAM problem? 59 minutes ago, aitek said:
aitek Posted November 1, 2018 Posted November 1, 2018 i don't know. feel strange。 i use FriendlyElec ‘s img work good. but armbian cannot work. maybe my board have some problem?
NicoD Posted November 2, 2018 Posted November 2, 2018 13 hours ago, aitek said: i use FriendlyElec ‘s img work good. but armbian cannot work. maybe my board have some problem?  Maybe try ramtester in friendlyElec their img. I doubt this is your problem. But I don`t know anything else either. Boot with nothing attached, try another psu, another sd-card, re-download the image, try an older image. But I think all this is done. And you don`t seem alone with the problem. For me it all seemed to work fine. I`ve done a lot of benchmarks on it.
aitek Posted November 5, 2018 Posted November 5, 2018 i have buy another nanopc t3 plus and new sd card. without pluging anything. still same error. can not boot
aitek Posted November 5, 2018 Posted November 5, 2018 new boot error log is: http://47.52.204.202/boot-2.txt
aitek Posted November 5, 2018 Posted November 5, 2018 it is have possible have two version nanopc t3 plus?
Igor Posted November 5, 2018 Posted November 5, 2018 4 hours ago, aitek said: it is have possible have two version nanopc t3 plus? Yes, we have seen this in the past. They change memory modules for example which need adjustments in u-boot. We use different one ... which is adjusted to support booting modern kernel. To be able to start solving this problem a few components are needed: know-how, time and hardware sample. Another strange thing is that my T3+ has the same revision numbers as yours - at least in mine there is: 1709, check memory chips. Sometimes they don't change revision number and change components. Haven't seen this at FA but elsewhere.
aitek Posted November 6, 2018 Posted November 6, 2018 Yes, you are right. i use M3's img run on my board, it's can work... but my board is T3 Plus...
aitek Posted November 6, 2018 Posted November 6, 2018 but M3 img cannot write the img to the eMMC. if do it, the board will cannot boot...
Igor Posted November 6, 2018 Posted November 6, 2018 If M3 image works on your board, you don't have T3+ but T3 ... or some other memory configuration. That is the only difference beside eMMC support.
Vlado Posted November 18, 2018 Author Posted November 18, 2018 I look not only I have one this problem.
sfalcon Posted January 17, 2019 Posted January 17, 2019 I'm having the same problem on my T3+. All the versions of Armbian for the T3+ I've tried give me segfaults on boot. I've notice the mem chips on my board are slightly different to the picture posted.
AmirHG Posted February 2, 2019 Posted February 2, 2019 (edited) On 1/17/2019 at 7:43 AM, sfalcon said: I'm having the same problem on my T3+. All the versions of Armbian for the T3+ I've tried give me segfaults on boot. I've notice the mem chips on my board are slightly different to the picture posted. I have this revision of nanoPC t3+ too, and I cannot boot either the log cat is the same as above @NicroD and @aitek mentioned please let me know if there is any solution to boot Edited February 2, 2019 by AmirHG
NoXQS Posted February 26, 2019 Posted February 26, 2019 Hi fellow T3+ owners. I have the same situation; Armbian Bionic for T3+ panics right after boot, probably the memory config has changed. However... if you use the T3 (non plus) armbian image I can not only boot but can flash it to eMMC (I am not saying this is a perm solution). WiFi works, haven't tried camera but looks stable enough for development. The only issue I have is the usable memory is 1Gb instead of 2Gb. Where does armbian get the available memory from, is it auto detect or is there something like a boot.txt ? Regards, Morgan
Igor Posted February 26, 2019 Posted February 26, 2019 2 hours ago, NoXQS said: The only issue I have is the usable memory is 1Gb instead of 2Gb. Where does armbian get the available memory from, is it auto detect or is there something like a boot.txt ? It is defined in BL1. The one for + model is different. https://github.com/armbian/build/blob/master/config/sources/s5p6818.conf#L44-L48
NoXQS Posted February 27, 2019 Posted February 27, 2019 Excuse my lack of knowledge regarding the armbian build pipeline but is it possible to replace boot.bin on the SD card ? Does the boot.img end up as the vmLinux-4.14.98-sp56818 in the /boot folder ? Could I potentially replace that file with 2g-bl1-nanopi.bin ?
constantius Posted April 26, 2019 Posted April 26, 2019 Please add something that the images for t3 + do not work or that the board is not supported or has no support. I wasted some time playing around with the broken images. It was only after a while that I looked at the forum ... I even built an image 4.14.113 armbian 5.85 .... all for nothing ...
constantius Posted April 27, 2019 Posted April 27, 2019 hi Is there a way or a chance to enable 2GB RAM in Nano pi T3+? I mean build img myself. Thanks for reply in advance.
Igor Posted April 27, 2019 Posted April 27, 2019 18 hours ago, constantius said: Please add something When someone will take responsibility: BTW. I have 4 different boards and all works fine. 2 minutes ago, constantius said: Is there a way or a chance to enable 2GB RAM in Nano pi T3+? I mean build img myself. Thanks for reply in advance. If you use/build image for T3+ you will have 2GB memory support. If not, than is is possible you have one of those boards with unknown/not supported memory. This is most probably cause of crashing.
constantius Posted April 27, 2019 Posted April 27, 2019 I have build img for nano pi t3+ 5.85 armbian kernel 4.14.113 and it does not work either. I have the same memory number SEC 710. Only img from t3 without "+" is working but only with 1GB ram. I can take care about Pine64 first realese Bananapi M2U / Berry Firefly RK3399 and Nanopi T3 plus I have these boards. Conclusion for Nano Pi T3 + with memory number begin SEC710 K4B4G16 is that.... no images from dl.armbian work. If you try to build image with kernel 4.14 it also wont work. Issue kernel panic segmentation fault and more stupid things on your monitor.
