I tried to compile and install this module https://github.com/pvaret/rtl8192cu-fixes
but when I run: "sudo dkms install 8192cu/1.10" the result is
Building module:
cleaning build area.....
make KERNELRELEASE=3.4.110-sun8i -C /lib/modules/3.4.110-sun8i/build M=/var/lib/dkms/8192cu/1.10/build......(bad exit status: 2)
Error! Bad return status for module build on kernel: 3.4.110-sun8i (armv7l)
Consult /var/lib/dkms/8192cu/1.10/build/make.log for more information.
make.log content:
DKMS make.log for 8192cu-1.10 for kernel 3.4.110-sun8i (armv7l)
Sun Feb 28 00:13:37 CET 2016
make: Entering directory '/usr/src/linux-headers-3.4.110-sun8i'
  LD      /var/lib/dkms/8192cu/1.10/build/built-in.o
  CC [M]  /var/lib/dkms/8192cu/1.10/build/core/rtw_cmd.o
/bin/sh: 1: /usr/src/linux-headers-3.4.110-sun8i/scripts/recordmcount: not found
scripts/Makefile.build:307: recipe for target '/var/lib/dkms/8192cu/1.10/build/core/rtw_cmd.o' failed
make[1]: *** [/var/lib/dkms/8192cu/1.10/build/core/rtw_cmd.o] Error 127
Makefile:1367: recipe for target '_module_/var/lib/dkms/8192cu/1.10/build' failed
make: *** [_module_/var/lib/dkms/8192cu/1.10/build] Error 2
make: Leaving directory '/usr/src/linux-headers-3.4.110-sun8i'
Note: the package linux-headers-generic is not found also.
Any help please?
Thanks in Advance.
Headers are present on the system, don't download anything especially not some generic.
cd /usr/src/linux-headers-3.4.110-sun8i/
make scripts # this you will skip in the future when we fix the building process
cd
git clone https://github.com/pvaret/rtl8192cu-fixes
cd rtl8192cu-fixes
make ARCH=arm
# when done
insmod 8192cu.ko
# dmesg
usbcore: registered new interface driver rtl8192cu
The armbian-5.05 builds for OrangePiOne ( simple/xfce - versions ) both fail with 8192cu wifi-dongle EW-7811Un.
Armbian seems to try to register the module twice and causes fatal crashes when using the installed driver(s).
dmesg
[ 6641.758850] rtl8192cu: Chip version 0x10
[ 6641.843455] rtl8192cu: MAC address: 80:1f:02:84:da:34
[ 6641.843475] rtl8192cu: Board Type 0
[ 6641.843697] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 6641.843819] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
[ 6641.844488] usbcore: registered new interface driver rtl8192cu
[ 6641.872716] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 6641.874212] rtlwifi: wireless switch is on
[ 6641.901717] rtl8192cu driver version=v4.0.2_9000.20130911
[ 6641.901746] Error: Driver 'rtl8192cu' is already registered, aborting...
[ 6642.110495] systemd-udevd[1176]: renamed network interface wlan0 to wlan1
lsmod
Module                  Size  Used by
rtlwifi                46169  0
rtl8192c_common        33409  0
mac80211              366795  2 rtlwifi,rtl8192c_common
8192cu                520853  0
8189es                896688  0
lsusb
Bus 002 Device 012: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
/etc/udev/rules.d/70-persistent-net.rules
# USB device 0x:0x (rtl8192cu)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:e0:4c:81:92:de", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="80:1f:02:84:da:34", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan1"
The same dongle works flawlessly in the latest Openelec-build from orangepi.org.
It would be very helpful to have working wifi with proven reliable USB-dongles. Ethernet works fine in armbian5.05 with speeds of 94Mbs.
Will wifi be available in legacy or will we have to wait for 4.x ?
Thanks for the good work, OrangePiOne is starting to look like a real contender !
Images for H3 Oranges are in pre-release state and poorly working wireless is a known issue. We haven't touch it yet. There are a lot of open issues - welcome to step in.
@igor
Thanks for the info and keep up the good work. I'll try to contribute in areas I'm knowledgeable about, mainly testing, documenting and high level use cases.
cd
cd rtl8192cu-fixes
make ARCH=arm
# when done
insmod 8192cu.ko
# dmesg
Common Edimax dongle EW-7811UN is now fully working by following Igor's procedure for Armbian-5.05.. Thanks !  After configuring wlan0 and testing the connection I disabled old / enabled new WIFI driver
/etc/modules-load.d/modules.conf
#----------disable standard Armbian driver
# 8189es
#----------enable fixed WIFI driver for EDIMAX EW-7811UN
8192cu
The board now reliably starts up and connects to configured wireless network. Performance is adequate in a noisy busy environment, iperf reaches 87 mbps.
Problem SOLVED !
Hello!
I am quite new in linux and may be my question is very simple :)
after I did all procedures for Armbian-5.05 above wi-fi seems working (not stable) but if I boot the Orange PI PC without ethernet cable connected wi-fi interface not connecting to router automaticly
wi-fi is working if only eth0 is up. I dont understand how interfaces connected. pls help me
Hello!
With default Debian simple networking config it's not possible to achieve this. Probably the simplest way is to use some other network manager which is also more user friendly, but we don't use it because it has some other limitations and bugs.
However, to achieve only wlan0 connectivity you simply comment out eth0 in your /etc/network/interfaces and reboot into wireless only connection. I assume you already set it up properly - so you have a working wlan0 configuration ...
Edit: Check this topic.
An additional step improves performance of module 8192cu ( Proven Edimax EW-7811UN as well as  $1.60 China-crapdongles from Aliexpress )
nano /etc/modprobe.d/8192cu.conf
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
This stops erroneous power management ( dmesg flooded with attempted power switches ). After network reload/restart you get about up to 90mbps from EW-7811UN and gain much stability with the ChinaWifi-crapdongle at up to 60-70mbps, performances measured with iperf ( 4m open space from access point ). Before correction, values were at 12mbps for ChinaWifi. Edimax performs way better than the cheap dongles, but with the options set they are quite useful too . AP mode is not solved yet, might have to wait for saner drivers in mainline.
i try but fail .
so in order to connect wifi router on air , i used  repeater , this was simple and saved usb port .
so ifconfig -> eth0 only  , namely no wlan .
i managed to understand what rodolfo said at Posted 31 March 2016 - 10:10 PM .
 two more steps  is needed .
1) at terminal , wpa_passphrase MyPlace  7082446
this gives next info .
network={
    ssid="MyPlace"
    #psk="7082446"
    psk=06d6f60771f44b0369f226c0ed4757cdc8939a2f3db
2)by using this info , rewrite /etc/network/interfaces
auto wlan0
    iface wlan0 inet dhcp
    wpa-ssid MyPlace
    wpa-psk 06d6f60771f44b0369fb1ed4757cdc8939a2f3db
auto lo
    iface lo inet loopback
then
ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr 00:22:cf:ec:c8:05
          inet addr:192.168.10.220  Bcast:192.168.10.255  Mask:255.255.255.0
          inet6 addr: fe80::222:cfff:feec:c805/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:340 errors:0 dropped:0 overruns:0 frame:0
          TX packets:281 errors:0 dropped:1 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:42290 (41.2 KiB)  TX bytes:45931 (44.8 KiB)
splendid!   orange pi PC can fly in the sky .
i heartly thanks for rodolfo .
@igor
After fresh install of Armbian_5.10 (jessie legacy server) on OPI ONE wireless dongles 8192cu crash kernel. The proven procedure (see previous posts) for Armbian_5.05 does NOT work for Armbian_5.10.
Log from failed installation :
root@orangepione:~# cd /usr/src/linux-headers-3.4.112-sun8i/
root@orangepione:/usr/src/linux-headers-3.4.112-sun8i# make scripts
scripts/kconfig/conf --silentoldconfig Kconfig
fs/Kconfig:287: can't open file "fs/fs_compat.kconfig"
/usr/src/linux-headers-3.4.112-sun8i/scripts/kconfig/Makefile:33: recipe for target 'silentoldconfig' failed
make[2]: *** [silentoldconfig] Error 1
/usr/src/linux-headers-3.4.112-sun8i/Makefile:493: recipe for target 'silentoldconfig' failed
make[1]: *** [silentoldconfig] Error 2
make: *** No rule to make target 'include/config/auto.conf', needed by 'scripts'.  Stop.
root@orangepione:/usr/src/linux-headers-3.4.112-sun8i# cd
root@orangepione:~# git clone https://github.com/pvaret/rtl8192cu-fixes
Cloning into 'rtl8192cu-fixes'...
remote: Counting objects: 438, done.
remote: Total 438 (delta 0), reused 0 (delta 0), pack-reused 438
Receiving objects: 100% (438/438), 1.80 MiB | 994.00 KiB/s, done.
Resolving deltas: 100% (223/223), done.
Checking connectivity... done.
root@orangepione:~# cd rtl8192cu-fixes
root@orangepione:~/rtl8192cu-fixes# make ARCH=arm
make ARCH=arm CROSS_COMPILE= -C /lib/modules/3.4.112-sun8i/build M=/root/rtl8192cu-fixes  modules
make[1]: Entering directory '/usr/src/linux-headers-3.4.112-sun8i'
  CC [M]  /root/rtl8192cu-fixes/core/rtw_cmd.o
/bin/sh: 1: /usr/src/linux-headers-3.4.112-sun8i/scripts/recordmcount: not found
scripts/Makefile.build:307: recipe for target '/root/rtl8192cu-fixes/core/rtw_cmd.o' failed
make[2]: *** [/root/rtl8192cu-fixes/core/rtw_cmd.o] Error 127
Makefile:1368: recipe for target '_module_/root/rtl8192cu-fixes' failed
make[1]: *** [_module_/root/rtl8192cu-fixes] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-3.4.112-sun8i'
Makefile:584: recipe for target 'modules' failed
make: *** [modules] Error 2
Please advise as to how to proceed in Armbian_5.10 to make 8192cu dongles work again . Thanks.
try
make m=scripts
We changed to other kernel source in last build. It should be better / more recent.
@igor
Sorry for the noise - I had not realized that 8192cu module is fixed in the meantime. So all that is needed is enabling the module 8192cu . I will test available modes and performance.
Thanks for the good job !
Tested working wifi-dongles with OPI ONE and Armbian_5.10
(Load proper module at startup)
nano /etc/modules-load.d/modules.conf
#8189es
8192cu
1. RTL8188CUS cheap no-name dongle from Aliexpress ( < $2 )
Bus 002 Device 003: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
identified as (rtl8192cu)
performance :    86.8 Mbits/sec
2. RTL8188EU cheap no-name dongle from Aliexpress ( < $2 )
Bus 001 Device 009: ID 0bda:0179 Realtek Semiconductor Corp. ( noname identified as 8188EU )
identified as (rtl8188eu)
performance :    86.1 Mbits/sec
3. RTL8188CUS Edimax EW-7811Un high quality dongle ( $10 )
Bus 001 Device 008: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
performance :    82.9 Mbits/sec
Remarkably all three dongles perform well in a not too noisy environment. The Edimax dongle is far superior when there is interference ( yes - we all sit in a giant microwave oven )
AP mode could not be tested yet. iw list does not return any result with the driver.
@igor
Hey rodolfo,
can you please tell me what steps are needed to get those wifi dongles to work? I was able to get them to work on 5.05 but not on 5.10.
Thanks in advance!
@ Igor & the armbian team
Thank you for this great OS! You made a great job!
@Chillman
For Armbian_5.05 you had to compile a patched version of module 8192cu. This is no longer needed, the module 8192cu is already compiled and ready to use. In order to load it at startup :
(change)
#8189es
8192cu
configure your network as you did with Armbian_5.05 and you are set to go.
Enjoy !
try
make m=scripts
These instructions do not work. when I enter this command I get the following error
make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/kernel.release'.  Stop.
I removed
source "fs/fs_compat.kconfig"
 from /usr/src/linux-headers-3.4.112-sun8i/fs/Kconfig  and then I was able to run make scripts on Armbian 5.10
aka
sed -i '287d;' /usr/src/linux-headers-3.4.112-sun8i/fs/Kconfig
make scripts
i was able to get the module built afterwards.. whether or not i get it to work with my wifi adapter is another story
update:
wifi seems to be alive now...  i went back to /usr/src and did
sudo cp ./rtl8192cu-fixes/blacklist-native-rtl8192.conf /etc/modprobe.d/
sudo cp ./rtl8192cu-fixes/8192cu-disable-power-management.conf /etc/modprobe.d/
rebooted then re-inserted the wifi
Hello everyone
I am a proud new owner of an orange pi pc. I am new here and very grateful for your work
on armbian which makes the board usable. So I sent a small bitcoin donation yesterday.
Now, I am undertaking the first steps with armbian, using the new 5.1 version,
trying to use wifi with 8189cu driver using one of those dongles:
Dongle 1: china , lsusb:
Bus 004 Device 003: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter B
or alternatively dongle 2, a well known Edimax 7811un, lsusb:
Bus 004 Device 002: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
both dongles worki well in raspi 2. When one of them is inserted in third boot,
armbian will automatically load rtl8192 module, which does not produce a wlan interface.
So according to rodolphos post #18 in this thread I have changed /etc/modules commenting out
#8189es and inserting 8192cu at the top. I reckon this is not the same as rtl8192.
now a wlan0 device shows up when entering "ifconfig".
iwlist wlan0 then shows visible networks, like in this extract:
          Cell 03 - Address: 26:65:11:FA:EB:10
                    ESSID:"Gast"
                    Protocol:IEEE 802.11bgn
                    Mode:Master
                    Frequency:2.462 GHz (Channel 11)
                    Encryption key:on
                    Bit Rates:300 Mb/s
                    Extra:wpa_ie=dd160050f20101000050f20201000050f20201000050f202
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : TKIP
                        Authentication Suites (1) : PSK
                    Extra:rsn_ie=30140100000fac020100000fac040100000fac020000
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: DD6F0050F204104A0001101044000102103B00010310470010BAE2343E91CE490C1609EB8F5005378E1021000341564D1023000446426F78102400043030303010420004303030301054000800060050F20400011011000446426F78100800022388103C0001031049000600372A000120
                    Quality=96/100  Signal level=51/100
innocent networks removed for protection.
Using wpa_passphrase I have created this gast.conf for wpa_supplicant.
network={
	ssid="Gast"
	psk=1a97bf36071e3e957e4c68cd530c56d2e328a4fcde5540c18a103477c7cc23e5
when now entering wpa_supplicant -B -iwlan0 -c gast.conf -d
the driver cannot be opened and the response is like this:
wpa_supplicant v2.3
random: Trying to read entropy from /dev/random
Successfully initialized wpa_supplicant
Initializing interface 'wlan0' conf 'gast.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file 'gast.conf' -> '/root/gast.conf'
Reading configuration file '/root/gast.conf'
Priority group 0
   id=0 ssid='Gast'
nl80211: Could not add multicast membership for vendor events: -2 (No such file or directory)
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=4 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211: Failed to set interface 4 to mode 2: -19 (No such device)
wlan0: Failed to initialize driver interface
Failed to add interface wlan0
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
So this is it. Of course I also tried "desktop" image with wicd automatic configuration which fails the same, but does not show any debug info.
I would be thankful for any tips!
best,
gnasch
@gnasch
Obviously your network dongles are recognized. Try the following steps :
nano /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
        ssid="Gast"
        key_mgmt=WPA-PSK
nano /etc/network/interfaces
allow-hotplug wlan0
        wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
>>>>>There may be hotplugging junk left from previous attempts
nano /etc/udev/rules.d/70-persistent-net.rules
(clear out all wlan entries)
restart and enjoy !
@Chillman
(change)
#8189es
8192cu
Enjoy !
@rodolfo:
My biggest thanks to you! I had read this in the thread before but adding the right and commenting out the wrong module in this file was not enough to configure the network via wicd in my case (wicd's error notification: bad password).
Thanks to your comment #22 I did the configuration myself and it worked immediately!
I've written a short tutorial in the German Orange Pi Forum, I hope that's ok for you (credits to this thread are in there, of course!).
Have a nice weekend!
I can confirm that wicd does not work. I disabled it on my device and stayed with rodolphos config.
Thanks, gnasch
I'm at the end of my rope trying to get this to work with 5.1
Original wifi module that worked with 5.05
lsusb:
Tried
#8189es
8192cu
I get this in my dmesg
and lsmod gives:
Module                  Size  Used by
rtlwifi                46157  0
rtl8192c_common        33398  0
mac80211              363732  2 rtlwifi,rtl8192c_common
8192cu                627893  0
iwconfig shows the device just fine.  After 2 days, I thought it was the cheap dongle, so I went and purchased the recommended one and still it doesn't work
lsusb:
ID 20f4:648b TRENDnet TEW-648UBM 802.11n 150Mbps Micro Wireless N Adapter [Realtek RTL8188CUS]
I've tried blacklisting the driver, which causes nothing to work (as expected).  I've tried everything in Post #22 and still nothing.
HELP!!
Some additional information:
started over with a fresh image, enabled 8192cu in modules.conf (disabled 8189es) and made no other changes to any files.  lsmod shows 8192cu as the only driver loaded.  Insert TRENDnet device and here is the dmesg output
[    4.938536] rtl8192cu driver version=v4.0.2_9000.20130911
[    4.938692] usbcore: registered new interface driver rtl8192cu
... (Insert dongle)
[  247.013492] ehci_irq: highspeed device connect
[  247.434416] USB_SPEED_HIGH
[  247.434489] CHIP TYPE: RTL8188C_8192C
[  247.434567] register rtw_netdev_ops to netdev_ops
[  247.434807] Chip Version ID: VERSION_NORMAL_TSMC_CHIP_88C.
[  247.434840] RF_Type is 3!!
[  247.435279] EEPROM type is E-FUSE
[  247.435306] ====> ReadAdapterInfo8192C
[  247.435534] Boot from EFUSE, Autoload OK !
[  247.588284] EEPROMVID = 0x20f4
[  247.588308] EEPROMPID = 0x648b
[  247.588323] EEPROMCustomerID : 0x00
[  247.588339] EEPROMSubCustomerID: 0x00
[  247.588354] RT_CustomerID: 0x00
[  247.588379] _ReadMACAddress MAC Address from EFUSE = xx:xx:xx:x:xx:xx
[  247.588405] EEPROMRegulatory = 0x0
[  247.588421] _ReadBoardType(0)
[  247.588437] BT Coexistance = disable
[  247.588455] mlmepriv.ChannelPlan = 0x00
[  247.588476] _ReadPSSetting...bHWPwrPindetect(0)-bHWPowerdown(0) ,bSupportRemoteWakeup(0)
[  247.588502] ### PS params=>  power_mgnt(1),usbss_enable(0) ###
[  247.588522] ### AntDivCfg(0)
[  247.588538] readAdapterInfo_8192CU(): REPLACEMENT = 1
[  247.588560] <==== ReadAdapterInfo8192C in 150 ms
[  247.589898] rtw_macaddr_cfg MAC Address  = d8:eb:97:30:df:a3
[  247.589931] bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
[  247.592351] _rtw_drv_register_netdev, MAC Address (if1) = xx:xx:xx:xx:xx:xx
[  247.719356] Error: Driver 'rtl8192cu' is already registered, aborting...
If I blacklist rtl8192cu, lsmod shows
Module                  Size  Used by
8192cu                627893  0
and dmesg has
root@orangepipc:~# dmesg | grep rtl
[    4.698692] rtl8192cu driver version=v4.0.2_9000.20130911
[    4.836033] usbcore: registered new interface driver rtl8192cu
@Pride: no need to blacklist, what does iwlist wlan0 show?
gnasch
This is frustrating.  I just woke up, turned it on, and now it is working correctly with the TRENDnet dongle.  No changes from last night.  arghhh
iwlist wlan0 scanning showed the router on both dongles.  I'm not sure what changed, but I will cycle this through some shutdowns and reboots to see if it sticks.
Have similar trouble.
lsusb
Bus 001 Device 002: ID 0bda:8179 Realtek Semiconductor Corp.
root@orangepione:~# lsmod
Module                  Size  Used by
8188eu                911607  0
8192cu                627893  0
Build module 8192cu by manual from #20 post http://forum.armbian.com/index.php/topic/749-orange-pi-pc-wireless-module-8192cu/#entry8860
nano /etc/modules-load.d/modules.conf (change)
#8189es
8192cu
dmesg show error:
[   64.785939] ehci_irq: highspeed device connect
[   65.020127] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[   65.277512] RTL871X: module init start
[   65.277531] RTL871X: rtl8188eu v4.3.0.6_12167.20140828
[   65.277541] RTL871X: build time: Apr 30 2016 19:47:19
[   65.277559] sw_usb_enable_hcd: usbc_num = 5
[   65.277567] [rf_pm]: regulator on.
[   65.287586] WRN:L148(drivers/usb/sunxi_usb/manager/usb_hcd_servers.c):ERR: unkown usbc_no(5)
[   65.292669] bFWReady == _FALSE call reset 8051...
[   65.327362] RTL871X: MAC Address from Efuse is 40:a5:ef:0f:fa:75
[   65.337542] RTL871X: rtw_ndev_init(wlan0)
[   65.338976] RTL871X: rtw_ndev_init(wlan1)
[   65.340305] usbcore: registered new interface driver rtl8188eu
[   65.340321] RTL871X: module init ret=0
And i have two not working  wlan in list
root@orangepione:~# iwconfig
lo        no wireless extensions.
tunl0     no wireless extensions.
wlan1     unassociated  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
wlan0     unassociated  Nickname:"<WIFI@REALTEK>"
          Sensitivity:0/0
          Encryption key:off
Need any help from community
