tkaiser Posted June 17, 2018 Posted June 17, 2018 This is something hopefully suitable to become a 'Board Bring up' thread. The NanoPC T4 was the smallest RK3399 board around featuring full set of interfaces (Rock960 was smaller but there you can't use GbE without a proprietary expander) but in the meantime he got two smaller siblings: NanoPi M4 and the cute NEO4. Pros: Another RK3399 board so software support is already pretty mature Rich set of interfaces (2 x USB2 without shared bandwidth, 2 x USB3, triple display output and so on) No powering hassles due to 12V (2A) PSU requirement 16GB superfast eMMC 5.1 Usable and performant Wi-Fi (dual band and dual antenna so MIMO can be used, for numbers see here) All 4 PCIe lanes exposed (M.2 M key connector on the bottom, suitable for NVMe SSDs, or to attach a 4 port SATA controller or a PCIe riser card) Cons: A bit pricey (but if you compare with RockPro64 for example and order all Add-Ons you end up with a similar price) High idle consumption (4W PSU included in idle), maybe this is just bad settings we can improve over time heatsink too small for continous loads I started relying on @hjc's work since he's currently using different kernels than we use on RockPro64 or ODROID-N1 (though all the 4.4 kernels are more or less just RK's 4.4 LTS branch with some modifications, with mainline I didn't had a look what's different in Heiko's tree and 'true' mainline). Tinymembench numbers with RK 4.4 vs. mainline kernel (the latter both showing lower latency and higher bandwidth). Internal 16 GB eMMC performance: eMMC / ext4 / iozone random random kB reclen write rewrite read reread read write 102400 4 23400 28554 26356 26143 27061 29546 102400 16 48364 48810 85421 85847 84017 47607 102400 512 48789 49075 273380 275699 258495 47858 102400 1024 48939 49053 290198 291462 270699 48099 102400 16384 48673 49050 295690 295705 294706 48966 1024000 16384 49243 49238 298010 298443 299018 49255 That's what's to be expected with 16 GB and exactly same numbers as I generated on ODROID-N1 with 16 GB size. When checking SD card performance it maxed out at 23.5 MB/s which is an indication that no higher speed modes are enabled (and according to schematics not possible since not able to switch to 1.8V here -- I didn't try to adjust DT like with ODROID-N1 where SDR104 mode is possible which led to some nice speed improvements when using a fast card -- see here and there) Quick USB3 performance test via the USB-3A port: Rockchip 4.4.132 random random kB reclen write rewrite read reread read write 102400 4 24818 29815 33896 34016 24308 28656 102400 16 79104 90640 107607 108892 80643 89896 102400 512 286583 288045 285021 293431 285016 298604 102400 1024 315033 322207 320545 330923 320888 327650 102400 16384 358314 353818 371869 384292 383404 354743 1024000 16384 378748 381709 383865 384704 384113 381574 mmind 4.17.0-rc6-firefly random random kB reclen write rewrite read reread read write 102400 4 37532 42871 22224 21533 21483 39841 102400 16 86016 104508 87895 87253 84424 102194 102400 512 274257 294262 287394 296589 287757 304003 102400 1024 294051 312527 317703 323938 323353 325371 102400 16384 296354 340272 336480 352221 339591 340985 1024000 16384 367949 189404 328094 330342 328136 139675 This was with an ASM1153 enclosure which shows slightly lower numbers than my usual JMS567 (all currently busy with other stuff). Performance with RK 4.4 kernel as expected, with mainline lower for whatever reasons. I also tried to test with my VIA VL716 enclosure directly attached to the USB-C port but ran into similar issues as with RockPro64 but since my enclosure and the cable also show problems when using at a MacBook Pro I suspect I should blame the hardware here and not USB-C PHY problems with RK3399. This is NanoPC T4 with vendor's heatsink, lying flat on a surface that allows for some airflow below, running cpuburn-a53 on all 6 cores after half an hour: 13:57:31: 1008/1416MHz 8.44 100% 0% 99% 0% 0% 0% 91.1°C 0/5 13:57:40: 1008/1416MHz 8.52 100% 0% 99% 0% 0% 0% 91.1°C 0/5 13:57:48: 1008/1416MHz 8.51 100% 0% 99% 0% 0% 0% 91.1°C 0/5 13:57:57: 1200/1416MHz 8.47 100% 0% 99% 0% 0% 0% 90.6°C 0/5 13:58:05: 1200/1416MHz 8.47 100% 0% 99% 0% 0% 0% 91.1°C 0/5 So with heavy workloads you most probably need a fan to prevent throttling. Development related questions: IMO we should try to rely on single sources for all the various RK3399 boards that are now available or will be soon. And I would prefer ayufan's since he's somewhat in contact with RK guys and there's a lot of great information/feeback provided by TL Lim. What do others think? Also an issue is IRQ affinity since on boards where PCIe is in use those interrupts should clearly end up on one of the big cores while on other boards USB3 and network IRQs are better candidates. I already talked about this with @Xalius ages ago and most probably the best idea is to switch from static IRQ affinity set at boot by armbian-hardware-optimization to a daemon that analyzes IRQ situation every minute and adopts then dynamically the best strategy. Wrt information for endusers. All RK3399 boards basically behave the same since the relevant stuff is inside the SoC. There's only different DRAM (matters with regard to consumption and performance), different interfaces exposed and different power circuitry (and obviously different settings like e.g. cpufreq behaviour but I think we should consolidate those for all RK3399 boards). So you already find a lot of information in my ODROID-N1 'review', my SBC storage performance overview and most probably also a lot around RockPro64. No idea where to inform about RK3399 GPU/VPU stuff since not interested in these areas at all (hope others add references or direct information). 3 Quote
chwe Posted June 17, 2018 Posted June 17, 2018 On 6/17/2018 at 2:26 PM, tkaiser said: Usable and performant Wi-Fi (dual band and dual antenna so MIMO can be used, for numbers see here) Expand there's a link missing.. On 6/17/2018 at 2:26 PM, tkaiser said: Development related questions: IMO we should try to rely on single sources for all the various RK3399 boards that are now available or will be soon. And I would prefer ayufan's since he's somewhat in contact with RK guys and there's a lot of great information/feeback provided by TL Lim. What do others think? Expand Question here, does a dev has all those RK3399 boards at hand to test them with a single kernelsource? I would prefer a 'not boardmaker related' kernelsource, therefore ayufan's or RKs own kernelsource might be the best way to go (hope that the missing bits can be added properly by patching the kernel). But I think it's time to discuss/decide it now, before all those boards get added into the buildsystem. On 6/17/2018 at 2:26 PM, tkaiser said: No idea where to inform about RK3399 GPU/VPU stuff since not interested in these areas at all (hope others add references or direct information). Expand Your turn @JMCC.. For whatever reason RockChip decided to remove all closed issues (and disabled it on github) on all their GPU/VPU userspace stuff. I really don't understand why they decided to act this way but it makes it harder to get a clue what problems are common for people who played with this stuff. 0 Quote
zador.blood.stained Posted June 17, 2018 Posted June 17, 2018 My 2 cents (thx to FriendlyArm and Igor for the sample) Subjective pros: Lots of fast interfaces (PCIe, USB3 and Type C) with a pretty fast CPU Good software support (for the SoC), both BSP and mainline, we'll have to see if the audio chip and PMIC have good support too Subjective cons / nitpicks: Type C can't be used for powering the board Finding an appropriate connector for the fan may be tricky, though it is understandable given the component density on the PCB Serial console baud rate (1500000) may not work with some USB-UART adapters (applies to all Rockchip SoCs and devices AFAIK), it was a bit disappointing that the default kit does not include a USB-UART adapter M.2 connector has a standoff for only one card form factor, though again it is understandable given the component density on the PCB Details to keep in mind: Some I/O interfaces are 1.8V only according to specifications On 6/17/2018 at 2:26 PM, tkaiser said: Development related questions: IMO we should try to rely on single sources for all the various RK3399 boards that are now available or will be soon. And I would prefer ayufan's since he's somewhat in contact with RK guys and there's a lot of great information/feeback provided by TL Lim. What do others think? Expand I'm in favor of having a single kernel source(s) too (default - 4.4 BSP, next - kernel.org mainline, dev - maybe ayufan's mainline?) I think (and hope) that the mainline kernel should be suitable for server and lightweight desktop usage scenarios, and hope that this device along with Odroid N1 and RockPro64 will get upstream DTs soon enough On 6/17/2018 at 2:26 PM, tkaiser said: heatsink too small for continous loads Expand ... without active cooling, which is IMO a not a bad idea for this board, especially if you install a M.2 SSD on it. 0 Quote
hjc Posted June 17, 2018 Posted June 17, 2018 On 6/17/2018 at 3:28 PM, zador.blood.stained said: I'm in favor of having a single kernel source(s) too (default - 4.4 BSP, next - kernel.org mainline, dev - maybe ayufan's mainline?) I think (and hope) that the mainline kernel should be suitable for server and lightweight desktop usage scenarios, and hope that this device along with Odroid N1 and RockPro64 will get upstream DTs soon enough Expand It's too early to use the mainline kernel as "next". In fact, RK3399's situation is more or less similar to RK3328's 4.17 kernel right now, so a single mainline branch should be used as "dev". On 6/17/2018 at 2:57 PM, chwe said: On 6/17/2018 at 2:26 PM, tkaiser said: Development related questions: IMO we should try to rely on single sources for all the various RK3399 boards that are now available or will be soon. And I would prefer ayufan's since he's somewhat in contact with RK guys and there's a lot of great information/feeback provided by TL Lim. What do others think? Expand Question here, does a dev has all those RK3399 boards at hand to test them with a single kernelsource? I would prefer a 'not boardmaker related' kernelsource, therefore ayufan's or RKs own kernelsource might be the best way to go (hope that the missing bits can be added properly by patching the kernel). But I think it's time to discuss/decide it now, before all those boards get added into the buildsystem. Expand I'd prefer ayufan's kernel, too. Rockchip's kernel development seems to be focusing on their newer low-end SoCs right now, and they usually break things (and maybe fix them in a few weeks after they found older SoCs are broken). Actually I don't understand why they're doing all active development in a branch called release-4.4. What Armbian needs right now is a solid branch optimized specifically for RK3328/3399. 0 Quote
zador.blood.stained Posted June 17, 2018 Posted June 17, 2018 On 6/17/2018 at 4:39 PM, hjc said: It's too early to use the mainline kernel as "next". Expand Is it? RK3399 .dtsi and the status matrix show a lot of supported HW features. But I didn't pay much attention to Rockchip development, so can you please name some roadblocks for getting at least server images with the mainline stack working? I'm not saying that we should immediately release mainline based images, I just indicated my opinion on next and dev kernel branch mapping. 0 Quote
hjc Posted June 17, 2018 Posted June 17, 2018 On 6/17/2018 at 4:47 PM, zador.blood.stained said: Is it? RK3399 .dtsi and the status matrix show a lot of supported HW features. But I didn't pay much attention to Rockchip development, so can you please name some roadblocks for getting at least server images with the mainline stack working? I'm not saying that we should immediately release mainline based images, I just indicated my opinion on next and dev kernel branch mapping. Expand Headless images already works, except big.LITTLE scheduling. AFAIK, there isn't a good solution for this in vanilla kernel. For lightweight desktop, HDMI is a major problem (incomplete in status matrix, at least my monitor is not working well with RK3399 mainline). 0 Quote
zador.blood.stained Posted June 17, 2018 Posted June 17, 2018 On 6/17/2018 at 5:02 PM, hjc said: For lightweight desktop, HDMI is a major problem (incomplete in status matrix, at least my monitor is not working well with RK3399 mainline). Expand And what about the Quote DP on Type-C: DisplayPort 1.2 Alt Mode on USB Type-C Expand Do you know if it needs additional software support on top of the base USB-C and whether it should be working already? 0 Quote
JMCC Posted June 17, 2018 Posted June 17, 2018 On 6/17/2018 at 2:57 PM, chwe said: For whatever reason RockChip decided to remove all closed issues (and disabled it on github) on all their GPU/VPU userspace stuff. I really don't understand why they decided to act this way but it makes it harder to get a clue what problems are common for people who played with this stuff. Expand Yes, It is a long and sad story, but boils down to RK not seeming to be very receptive to community comments/bug reports. I vote too for unifying Rockchip kernels, and I think that, since all kernels are so similar, we should consider as an important factor the communication with the upstream maintainers. About RK, as I said, I'm a bit disappointed. About Ayufan, I really admire his work, though being a single person I don't know how available he is to read and respond to issues, PR's, etc., but at least it seems like he has good communication with RK. And about Hardkernel, my experience has always been good in this regard (as in almost any other aspect too). When I say unifying RK kernels, I vote for including RK3288 too (I'm talking about sorces, of course not patches and configs). That would save us lots of resources in dealing with upstream changes. For example, most of the enormous work that our maintainers are putting now into bringing the rockchip default kernel "back to life" consists in dealing with an upstream mess. So I think it would be positive if all the devs and contributors are fighting in the same front, instead of spreading our limited resources into two or three different source trees. But, of course, that depends on how comfortable is @TonyMac32 with switching to a slightly different kernel source for 3288. If we decide to go the way of unifying, HK will focus on 3399, but Ayufan covers also 3328, so probably the latter is a better option. On 6/17/2018 at 2:26 PM, tkaiser said: No idea where to inform about RK3399 GPU/VPU stuff since not interested in these areas at all (hope others add references or direct information). Expand I've had a surgery last week, and only had some time today to deal with an old RK3328 bug, but I'll try to give a good look to the board multimedia-wise in the next days, and report. 0 Quote
hjc Posted June 18, 2018 Posted June 18, 2018 On 6/17/2018 at 6:12 PM, zador.blood.stained said: Do you know if it needs additional software support on top of the base USB-C and whether it should be working already? Expand Haven't got that working even on legacy kernel. Maybe it's a kernel configuration issue. 0 Quote
TonyMac32 Posted June 19, 2018 Posted June 19, 2018 On 6/17/2018 at 3:28 PM, zador.blood.stained said: (applies to all Rockchip SoCs and devices AFAIK) Expand Seems to be an RK33xx issue, the RK3288 is 115200 like any sane serial terminal. On 6/17/2018 at 4:39 PM, hjc said: and they usually break things Expand tell me about it. On 6/17/2018 at 4:39 PM, hjc said: What Armbian needs right now is a solid branch optimized specifically for RK3328/3399 Expand Agreed. On 6/17/2018 at 8:30 PM, JMCC said: I think it would be positive if all the devs and contributors are fighting in the same front, instead of spreading our limited resources into two or three different source trees Expand I agree. I'm not against "slightly different", I just need to see stable. I don't want a "commit bomb" destroying my kernel config and making it impossible to repair without major issues. 0 Quote
hjc Posted June 19, 2018 Posted June 19, 2018 On 6/19/2018 at 3:11 AM, TonyMac32 said: On 6/17/2018 at 4:39 PM, hjc said: and they usually break things Expand tell me about it. Expand See this and this, they just silently broke all RK3399 boards, and then silently fixed it. This change even stops the UART from working so one cannot diagnose what's wrong. This is all done in the release-4.4 branch, and they seldom use tags, so I doubt they're not testing their code on various boards. Besides, they put both Mali Android and (old, not updated) Linux drivers in the kernel, and their modifications to rk3399.dtsi broke the Linux one, since they switched to the new power model. If you use an old kernel config, it will cause a kernel panic after you update the kernel. They finally completely removed the old Mali Linux drivers recently, and their CONFIG_MALI_MIDGARD_FOR_LINUX/CONFIG_MALI_MIDGARD_FOR_ANDROID disappeared. 0 Quote
tkaiser Posted June 19, 2018 Author Posted June 19, 2018 On 6/19/2018 at 6:03 AM, hjc said: See this and this, they just silently broke all RK3399 boards, and then silently fixed it. This change even stops the UART from working so one cannot diagnose what's wrong. This is all done in the release-4.4 branch, and they seldom use tags, so I doubt they're not testing their code on various boards. Expand I don't think this group of Rockchip engineers working in these github repos is aware what's happening outside (various open source communities using their kernel sources for a bunch of RK devices). Yesterday I dropped a quick note to Kever Yang (AFAIK he's in charge of some of RK's open source activitities) but got no answer yet. Edit: got an answer almost immediately, just found it in another inbox now. Let's wait and see 0 Quote
TonyMac32 Posted June 19, 2018 Posted June 19, 2018 On 6/19/2018 at 6:03 AM, hjc said: Besides, they put both Mali Android and (old, not updated) Linux drivers in the kernel, and their modifications to rk3399.dtsi broke the Linux one, since they switched to the new power model. Expand Same for RK3288, that's why so many issues around Tinker board have popped up, woke up one morning and the kernel config no longer worked, Mali was trashed, etc. 0 Quote
chwe Posted June 19, 2018 Posted June 19, 2018 On 6/19/2018 at 6:40 AM, tkaiser said: I don't think this group of Rockchip engineers working in these github repos is aware what's happening outside (various open source communities using their kernel sources for a bunch of RK devices). Expand https://github.com/rockchip-linux/kernel/issues/98 It's not that they don't get some feedback for their action.. But when you've to pray to god after every module that it still works.. It's not that much fun.. If you go down the whole rabbit hole on weekends and on monday your config from saturday has one or two config issues again it starts to piss you.. I do like the idea of having one branch for all their SoCs. but then this needs extensive testing. Who ever found this here (https://github.com/rockchip-linux/kernel/blob/40e877458b0dd3fedc39afc8c2a8e428adafc858/arch/arm/boot/dts/rk3288-linux.dtsi#L10-L12 btw @TonyMac32 we may need it partly due to dmc nodes are now here.... ) a good idea obviously doesn't think about that there are others may get fooled by this (why not set it as kernel bootarg with the 'overrule by u-boot bootargs - flag'? wouldn't hurt any other project). The first time I played with the ISP-driver I was quite surprised how fast they react on github, now this is more an AA-group model... Btw, let me know if I should split it to a 'which RK kernel should we use?'-thread. IMO this affects all or at least also other RK based boards. 0 Quote
TonyMac32 Posted June 19, 2018 Posted June 19, 2018 On 6/19/2018 at 10:44 AM, chwe said: we may need it partly due to dmc nodes are now here.... Expand My old patch simply eliminated it, now I'll just have to kill off that section of it. 0 Quote
tkaiser Posted June 19, 2018 Author Posted June 19, 2018 On 6/19/2018 at 10:44 AM, chwe said: https://github.com/rockchip-linux/kernel/issues/98 Expand Well... by looking at the (closed) pull request it becomes even more obvious that the RK people owning this github repo don't have an idea how to deal with the world outside. They don't care about the state of this kernel tree breaking stuff most probably since their internal work style is totally different from ours. I would continue to discuss this stuff here since i sent Kever Yang only a link to this thread right now... 0 Quote
TonyMac32 Posted June 19, 2018 Posted June 19, 2018 Good idea. I should be able to start working on this again once my vehicle repair is finished, the weather has worked against me so far. 0 Quote
kevery Posted June 21, 2018 Posted June 21, 2018 I'm Kever Yang from Rockchip BSP team, and I'm in charge of open source for Rockchip SoCs, you should able to see my patches to upstream U-Boot and kernel. Thanks very much to @tkaiser for share this thread to me, and I hope I can do some explanation here so that help developers understand what we are doing. The github(https://github.com/rockchip-linux/) is owned by Rockchip, and repos on github consider to be a 'Linux SDK' of some of Rockchip SoCs(mainly for RK3328, RK3288, RK3399 now), we have a wiki to provide basic document for it(http://opensource.rock-chips.com/), the github is now maintained by one of our product team. We hope this github can be a good reference to developers who interested in Rockchip platform. I have to declare that Rockchip never try to stop community developers to report issue to Rockchip by github or by mail, but it's not correct to close issues without any comments, I'm sorry about what we have done and I promise it would never happen again. For some issues, we may not able to fix it, but people should get a saying if we have to close it. Rockchip always open to community, and, yes, we hope to get advice about github maintain. Here is the information about Rockchip source code: - Rockchip have only one common BSP maintained by BSP team, including U-Boot, kernel, rkbin(ddr, miniloader, trust), this is used in all Rockchip products and for many SoCs, so it including 4.4 base/LTS patches, upstream backport for some modules, vendor/rockchip solution for some modules because the requirement for production; - Rockchip product team will test for product SDK release, but usually only for one SoC per SDK, and it will fix at that point before next version SDK. - Rockchip kernel is now 4.4, and will update to next LTS; We try to use upstream source code as much as possible for all the modules, you can find this out by compare to our last version kernel 3.10, but still way to go. - Rockchip kernel is used for Android and Linux OS; - Github source code is a special 'Linux SDK', not like other 'fixed after release for one SoC' SDK, it keeps update and used for more than one SoCs, you can consider it to be a mirror of Rockchip internal BSP * that's why we not able to merge the pull request, we have to review all the source code internally; * the github release branch is not maintained directly by BSP team, so it may not have maintained good enough now, I will sync with the maintainer, we will have better test, and better release flow; - Rockchip don't have official community version BSP which only have everything from upstream, and won't going to have one in near future; - Issue report(feature defeat, performance and etc) are always welcome, we want provide a better common kernel. We will fix issues really need to fix, people don't want to get a kernel always have the same issue. - We focus on evb first for new SoCs, and some popular board will add later; this may be one of the conflict with the what community wants. About the common kernel for community, here is my suggestion: - Community can chose one kernel version fork from Rockchip as common kernel, now the kernel4.4 already has good support for RK3288/RK3399/RK3328; - Developing, apply patches for new board support, switch some of module to upstream driver, and so on; - Upstream the new board support or feature support as much as you can, then rockchip kernel can support it when update to new kernel; - If some feature/performance issue need to fix recently, community people can contact Rockchip/me, we will try to fix it if we can; - maybe a mailing list is needed for better communication? 6 Quote
TonyMac32 Posted June 21, 2018 Posted June 21, 2018 Thank you for the reply. My only real issue so far has been the large changes with no documented, it's caused a huge disruption to my use of the BSP, specifically the Mali changes. Another example was getting rkwifi drivers working, the documentation on how to configure the kernel seemed to only be available in the commit message for the adjustments. With some documentation these large changes wouldn't cause as many issues. As far as specific board support, I understand not supporting everything, this is the sort of decisions we are all familiar with. I can easily maintain a patchset as long as the underlying BSP stays stable. For hardware like the miniarm, as an example, there are some workarounds that should not be part of the BSP. 0 Quote
kevery Posted June 22, 2018 Posted June 22, 2018 @TonyMac32So I think you want a change log for kernel? We have no experience for it now, is there good reference from other vendor's BSP, and I will try what I can do. 0 Quote
TonyMac32 Posted June 22, 2018 Posted June 22, 2018 Well, it doesn't necessarily have to be a change log, simply keeping the kernel documentation and the kconfig notes current and accurate would be a huge help, like I said sometimes the only way to figure out a kconfig issue is to dig into the commit history for the feature that is changing, and even then sometimes it is simply luck (building Mali as a module seems to be mandatory, at least at my last check. This was not the case before and it still allowed other options ). As far as other vendors go, I believe Rockchip has the most open development as far as that goes, others keep it more secretive and release snapshots. For Amlogic the BSP / buildroot is released periodically with a report detailing the results of a group of tests they perform on the kernel like reboot cycling, drivers, etc, that's the only one I can directly comment on. 0 Quote
tkaiser Posted June 24, 2018 Author Posted June 24, 2018 On 6/21/2018 at 7:42 AM, kevery said: Github source code is a special 'Linux SDK', Expand Thanks a bunch for this explanation, Kever. I think it pretty much explains a lot of the annoyances developers ran into. Also thank you for your other explanation and suggestions. Though I'm a bit disappointed about lack of other developer responses. Anyway, to get back on (our) topic. We have the following 'BSP' branches for RK3399 boards right now: RK's own: https://github.com/rockchip-linux/kernel/tree/release-4.4 Firefly's repo for their RK boards: https://gitlab.com/TeeFirefly/linux-kernel/ (If I understood @hjc correctly also based on an older RK 4.4 kernel?) Hardkernel's for their canceled ODROID N1: https://github.com/hardkernel/linux/tree/odroidn1-4.4.y (AFAIK a fork of RK's 4.4 but rebased on 4.4 kernel.org version) ayufan's: https://github.com/ayufan-rock64/linux-kernel/tree/release-4.4 (forked and rebased from RK's 4.4 recently) FriendlyELEC's for NanoPC T4/NaniPi M4: https://github.com/friendlyarm/kernel-rockchip/tree/nanopi4-linux-v4.4.y (older fork from RK's 4.4 with some device specific additions for now) What else? With mainline we have: true mainline Heiko's branch: https://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip.git Heinrich Schuchardt's Firefly RK3399 repo: https://github.com/xypron/kernel-firefly-rk3399 Ayufan said he would be happy to open up his repo for other contributors: http://irc.pine64.uk/?date=2018-06-21 08:03:47 (change the channel to #Rock64 via the menu). TL Lim also added he is for unifying development efforts (stopping developers from wasting their time reinventing the wheel over and over again). Is this addressing your concerns @JMCC? So how to proceed? To me it seems possible to use one single BSP kernel for all three RK 'open source SoCs' but I'm not into any details at all. 0 Quote
JMCC Posted June 24, 2018 Posted June 24, 2018 Well, let's take a break from important decision-making, and post some benchmarks about VPU/GPU. I have used the official FriendlyELEC's Ubuntu Xenial image, kernel 4.4.126, 32-bit architecture. That allowed me to easily create a media configuration script, based on the existing RK3288 one. All tests were done with "performance" governor, both in CPU and GPU. The 32-bit script can be downloaded here. It is not yet a release version, so there may be some rough edges. If the community demands it, I might create a 64-bit version in the future. 1. VPU 4K Video Decoding capabilities I'll make a chart comparing NanoPC-T4 (RK3399) with ASUS TinkerBoard (RK3328) and Khadas VIM2 (Amlogic S912). Rockchips acceleration was tested with our well-known MPV, while for Amlogic we used @balbes150's LibreElec: BOARD H.264 HEVC VP9 HEVC-10 VP9-10 ------------------------------------------------------ TB (RK3288) ✓ ✓ x x x T4 (RK3399) ✓ ✓ ✓ ✓ x VIM2 (S912) ✓ ✓ ✓ ✓ ✓ The first thing to comment here is that VP9 10-bit HDR video playback is not supported by the board, which on the other hand is in accordance with Rockchip's official specs. HDR is only supported for H.264 and H.265 (we didn't test the former, though, but we can assume it works if the latter does). It should not be a software issue, since we tested also in Android with the Rockchip Media Player App, and we only got a messagebox saying "10-bit video is not supported". So, in this aspect, RK3399 is inferior to the competitor's S912, which can play VP9-HDR10 videos. Besides that, all supported videos played with perfect smoothness and vivid colors. 2. GPU OpenGL-ES & WebGL Time for 3D capabilities of the Mali-T860 with 4 cores @800 Mhz. As references for the comparison, we chose this time the TinkerBoard (Mali-T760, 4 cores@600), and the Odroid XU4 (Mali-T628, 6 cores@600). All three malis share the Midgard architecture, though they represent the first, second and third generation. We didn't use this time the S912, because it has no Linux Mali support, plus performance would be much lower with only 3 cores. Kernel for TB is Armbian's 4.4.131-rockchip, while for XU4 is 4.14.30. For the Rockchips we used their custom X server with Glamor enabled, while for XU4 we used Crashoverride's armsoc X driver: Results are in frames per second: BOARD Glmark2-X Glmark2-offscreen WebGL Aquarium (Chromium) ----------------------------------------------------------------------------------------- TB (RK3288) 57 547 30-34 T4 (RK3399) 52 340 33-36 XU4 (S5422) 428 747 39-44 In the first place, Rockchip's X server seems to be better tuned for the RK3288, where we see that FPS almost match the Vsync (60 FPS). In the case of RK3399, we see it is significantly lower, while we also see tearing that does not happen with the other Rockchip SoC. XU4's driver works in a different way, and so it is not limited by Vsync, but nevertheless it doesn't show any tearing. Offscreen performance is strangely low in RK3399 (probably a matter of a not-so-well tuned Mali binary?). WebGL performs better in 3399 than 3288, but the difference is not as big as one should expect considering the superiority of both CPU and GPU. XU4 clearly sticks from the others. 3. GPU OpenCL performance Now OpenCL performance with GPU miners. That can give us a better idea of the raw processing power of the GPU since there are no X drivers getting in the way. We used cgminer for the skein algo, and sgminer for lyra2rev2. Results are averages from running the miner for two hours, with an intensity as high as possible monitoring that no hardware errors happened. BOARD Skein (Mh/s) Lyra2rev2 (Kh/s) ------------------------------------------------ TB (RK3288) 1.150 42 T4 (RK3399) 1.150 60 XU4 (S5422) 1.440 72 It is shocking that performance in Skein algo is about the same for RK3288 and RK3399, but using CPU miners for the same algorithm the TinkerBoard also gives surprisingly high numbers (higher than XU4). For that reason, I think there must be something in the TB that makes it specially suited for Skein (maybe the dual-channel RAM?), so results must be taken carefully. On the other hand, Lyra2 numbers are more or less as expected. Remember that all these tests are made in a armhf system. Maybe arm64 can give us some surprise in the future. Or maybe Rockchip can make improvements to their binaries/libraries giving better performance. 1 Quote
JMCC Posted June 24, 2018 Posted June 24, 2018 On 6/24/2018 at 1:52 PM, tkaiser said: So how to proceed? Expand Sorry @tkaiser, you posted while I was typing my benchmark results and I didn't notice it. I didn't mean to "bury" your post 0 Quote
TonyMac32 Posted June 24, 2018 Posted June 24, 2018 @JMCC Nice review, I still need to get my system running... :'( @tkaiser, there is very little "special" with the rk3288 boards we support, the Tinker patches have been carefully (well, as carefully as I can manage) tailored to not harm the operation of other boards (the Tinker Reboot is a nasty one, it's hackish code that I wrapped with a device tree check conditional execution). The MiQi is basically just a Rockchip development board, nothing strange to get in the way. I would support a common BSP kernel for all the devices, for Mainline though I would recommend using straight official mainline and grab patches for the important things from the "almost mainline" or "will wind up in mainline" repos (easy for me to say when the RK3288 is almost perfectly supported at this point). 1 Quote
JMCC Posted June 24, 2018 Posted June 24, 2018 On 6/24/2018 at 1:52 PM, tkaiser said: Is this addressing your concerns @JMCC? Expand Definitely. After your remarks, I think Ayufan's is the best option, for the following reasons: After @kevery's clarifications, it seems like RK upstream aims at a purpose that does not fit Armbian's needs. Hardkernel's is dead ATM, and we have no clue what N2 will be like (maybe not even Rockchip). Firefly's and FriendlyELEC's can end up being similar to ASUS, where they choose to stay with an older version of the kernel/drivers and patch them. Not what Armbian does normally. Ayufan's main difficulty is that, being driven by a single person, the project could die if for any reason he cannot take care of it any more. But being open to external contributions somehow prevents that situation, since there would be more people closely familiar with the source tree who could be able to continue the work. And also, since his work and Armbian's is so close (we are already using his kernel for RK3328), transition would be relatively easy. The only drawback could be that @TonyMac32 would need to check all his patches against that kernel (it currently does not support RK3288), but I think that would be a piece of cake compared to what he is doing now trying to put order in RK's upstream kernel. 1 Quote
TonyMac32 Posted June 24, 2018 Posted June 24, 2018 On 6/24/2018 at 2:32 PM, JMCC said: would need to check all his patches against that kernel (it currently does not support RK3288) Expand Well, thanks to the current state of the Rockchip kernel I need to check all of my patches anyway, so it's not a huge obstacle. ;-) 0 Quote
Myy Posted June 28, 2018 Posted June 28, 2018 Do you need to flash another U-boot to be able to input something during initialization, when starting from the Android Nougat image ? (´・ω・ `) I'm able to read the input but not send anything and quite frankly the boot phase is FAST. Less than 1 second to react. Also is minicom the best tool for the job ? It seems recommended on FriendlyArm Wiki but... Even though I've used it a lot with the Tinkerboard and MiQi, it still feels clunky. 0 Quote
Myy Posted June 28, 2018 Posted June 28, 2018 It seems that Picocom did a better job for transmitting input. Still, that seems to require an awful lot of tinkering to get it working with a Linux system... I guess I'm missing something. 0 Quote
