I am trying to apply the following configuration to my nanoPi Duo Core:
* Boot from eMMC
* System on SATA/USB (disk)
When i try to find the eMMC device using the command "fdisk", I can only see the SD card and the disk that I added.
My NanoPi duo core contains the eMMC memory but I am unable to find it.
In addition to that, If I try to execute the script "nand-sata-install", only one option is available boot from SD, system on SATA / USB.
The other two options : "boot from eMMC / NAND, system on eMMC/NAND" and "
boot from eMMC / NAND, system on SATA / USB" are not mentionned.
Can someone help me with this issue?
Thanks in advance.
Regards,
Antony
Hi Antony,
I didnt know any model like your "nanoPi Duo core with eMMC"
I know the
- NanoPi Neo2 Core with eMMC
or
- NanoPi Duo with Mini Shield - where you could put a Halfsize mSATA SSD
The eMMC on the NanoPi Neo2 Core is bootable and the halfsize mSATA-SSD on the NanoPi Duo with Mini-Shield isnt bootable
(as I know)
Did you try to install to NAND/eMMC via armbian-config (system) - or didnt you use armbian?
NanoPi Duo with MiniShield:
http://www.friendlyarm.com/index.php?route=product/product&product_id=198
NanoPi Neo2 Core:
http://www.friendlyarm.com/index.php?route=product/product&product_id=211
This means you have the wrong image (without eMMC support) for your board. We actually don't know which board you have ... make a picture of it, both sides to make sure.
Thanks for your replies.
I am using nanoPi Neo Core with mini shield nanoPi NEO CORE/CORE2. You can find it attached to this message.
As u can see, there is the eMMC memory on the board.
I am using armbian stretch with the nanoPi NEO CORE.
Thanks in advance for your help.
Regards,
Antony
That is something different. We might have some troubles here. Can you provide a link to the download page. I am not sure which image you are using. If you run the board, type armbianmonitor -u
without eMMC support - because when you are using a image for the Duo, the Duo hasnt an eMMC option. Only mSATA - non-bootable.
But I guess it's better to merge it with Neo (now eMMC support is enabled by default and this should not affect normal Neo functionality), as I did it now since it also has ethernet while Air doesn't. At least on this shield.
@guidol Check download https://www.armbian.com/nanopi-neo/ ... if nightly images are exposed and named properly?
OK - if eMMC is enabled at the normal Neo image this would be the better selection.... but the I would suggest to move the "Core" description from the NanoPi Neo Air to the NanoPi Neo.
At the normal exposed Neo download-page isnt a nightly image - only xenial and stretch mainline as stable :)
It is enabled since u-boot2018/05, kernel 4.17.y ... and I can't double check atm.
Edit: switched + added text that you need to use nightly images for Core.
CTRL R? :)
I just tried the image that you mentionned @guidol but I got also the same problem.
eMMC is not support and If I try to execute the script "nand-sata-install", only one option is available : boot from SD, system on SATA / USB.
Any suggestions?
Regards,
Antony
44 minutes ago, Antony Abi Rached said:
What does mean nightly image ? @guidol @Igor
nightly does mean, that (mostly) every night there will be a actual updated image generated - and if you wish you could update daily your system without reinstalling.
It also mean  that this will be a very fresh - and sometimes a image with problems, but the NanoPi Neo Core is also a NEW (around 7 months) device.
So there wil be - at this time - no other stable image which support all the features of this device.
NanPo Neo Core as new in 12/2017:
https://www.cnx-software.com/2017/12/13/nanopi-neo-core-and-neo-core2-allwinner-h3-h5-systems-on-module-launched-for-7-99-and-up/
6 minutes ago, Antony Abi Rached said:
So the eMMC storage is not supported for now ?
Sorry - my fault , @Igor did wrote
and https://dl.armbian.com/nanopineo/Debian_stretch_next_nightly.7z
is "only" Kernel 4.14
So you have to try
https://dl.armbian.com/nanopineo/nightly/Armbian_5.54.180727_Nanopineo_Debian_stretch_next_4.17.10.7z
(here you could see all nightly images: https://dl.armbian.com/nanopineo/nightly/ )
For bionic/kernel 4.18 we have to wait for the end-release of 4.18 later this year.
I tried this image. I typed the command : "uname -a" to know the version of the Kernel and I got the following result
Linux nanopineo 4.17.10-sunxi #40 SMP Thu Jul 26 10:21:51 UTC 2018 armv7l GNU/Linux
So i am using Kernel 4.17 but the eMMC is not supported.
Did you boot via MicroSD-Card and then use
armbian-config
as command.
Inside armbian-config select system and then you should see the option to install to eMMC like on the picture (or why is it not supported? Error-Message?)
It is possible that there are no bits in the device tree ... so we need another patch for the kernel.
Edit:
I can prepare another image later on.
Any suggestions?
Wait until tomorrows update. Do apt-update & upgrade - make sure new kernel version is installed, reboot and try again.
I have a NanoPi Neo Core with eMMC..I have installed armbian os from "https://www.armbian.com/nanopi-neo/" to sd card and tried the "Armbian configuration utility" and "nand-sata-install" to install os to eMMC. But it is showing "there are no targets..please check your drives."..If we give "fdisk -l" command it is not detecting the eMMC.
How to solve this issue??
8 hours ago, edu said:
I have the same problem @Antony Abi Rached
I am trying to install armbian in the emmc of my nanopi neo core, but nand-sata install does not recognize the emmc.
Any solution?
Exactly which image are you trying to use?
I am using this image    https://www.armbian.com/nanopi-neo/    (Armbian_5.59_Nanopineo_Debian_stretch_next_4.14.65)
