balbes150 Posted April 7, 2019 Author Posted April 7, 2019 On 4/7/2019 at 6:16 AM, Xavier31 said: I am available to test and to help to improve Armbian support of NanoPi K2 board. Expand This topic discusses images for TV boxes. But it would be interesting to test them on K2. Are you ready to try this option ?
Xavier31 Posted April 7, 2019 Posted April 7, 2019 Yes! My K2 is ready to test images: I have several SD card so no problem to rewrite them from scratch... Waiting for your images...
dsh Posted April 7, 2019 Posted April 7, 2019 Hello @balbes150, I have tried your latest 5.76 with Mali support. H264 video streams are decoded by HW, however, H265 streams are decoded by SW. I have used following command without any parameter. mpv [Video-URL]. In case of H265, do I need to explicitly state HW decoder? Also I have tried building one myself using your script but I can't find where select Mali driver options. Thanks in advance.
balbes150 Posted April 7, 2019 Author Posted April 7, 2019 On 4/7/2019 at 7:46 AM, Xavier31 said: Yes! My K2 is ready to test images: I have several SD card so no problem to rewrite them from scratch... Waiting for your images... Expand 1. Copy of the standard u-boot from the working SD card. dd if=/dev/mmcblkXXX of=u-boot_k2.img bs=1M count=4 2. Burn the image Armbian for TV Boxing on the SD card. 3. Replace u-boot on the recorded SD card dd if=u-boot_k2.img of=/dev/mmcblk0 conv=fsync bs=1 count=442 dd if=u-boot_k2.img of=/dev/mmcblk0 conv=fsync bs=512 skip=1 seek=1 Configure the correct DTB for K2. If you have u-boot-2018\19 , then in the file "/extlinux/extlinux.conf". If u-boot is different, show its version.
balbes150 Posted April 7, 2019 Author Posted April 7, 2019 On 4/7/2019 at 8:38 AM, dsh said: I have tried your latest 5.76 with Mali support. H264 video streams are decoded by HW, however, H265 streams are decoded by SW. I have used following command without any parameter. mpv [Video-URL]. In case of H265, do I need to explicitly state HW decoder? Also there is no audio. Expand This is a test case, I'm not sure h265 is supported. Look at the list of decoders and try them.
dsh Posted April 7, 2019 Posted April 7, 2019 On 4/7/2019 at 10:07 AM, balbes150 said: This is a test case, I'm not sure h265 is supported. Look at the list of decoders and try them. Expand Will do that. Aside from that, Are we eventually be able to flash directly to emmc by Amlogic burning tool?
balbes150 Posted April 7, 2019 Author Posted April 7, 2019 A new set of images 5.77_20190407 , used by the kernel 5.1.0-rc1. Pay attention, this is a generic image for the entire line of S9xxx (including for S912 and S905x2). Enabled by default DTB for Khadas VIM1 (S905X). To run on other models, you need to configure DTB.
Xavier31 Posted April 7, 2019 Posted April 7, 2019 I planned to use Armbian_5.75_Nanopik2-s905_Ubuntu_bionic_next_4.19.20_desktop.img to prepare a working SD card and then to grab u-boot from. But I noticed this image contains only one partition. Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.1.0-rc1_desktop_20190407.img image contains two partitions. Is your procedure always applicable in such situation?
balbes150 Posted April 7, 2019 Author Posted April 7, 2019 On 4/7/2019 at 3:50 PM, Xavier31 said: I planned to use Armbian_5.75_Nanopik2-s905_Ubuntu_bionic_next_4.19.20_desktop.img to prepare a working SD card and then to grab u-boot from. But I noticed this image contains only one partition. Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.1.0-rc1_desktop_20190407.img image contains two partitions. Is your procedure always applicable in such situation? Expand Yes, follow the description. The recovery option is specially made to save the current partition table.
amirul Posted April 7, 2019 Posted April 7, 2019 On 4/7/2019 at 11:05 AM, balbes150 said: A new set of images 5.77_20190407 , used by the kernel 5.1.0-rc1. Pay attention, this is a generic image for the entire line of S9xxx (including for S912 and S905x2). Enabled by default DTB for Khadas VIM1 (S905X). To run on other models, you need to configure DTB. Expand BM8 s912 2Gb meson-gxm-q200.dtb root@aml-bm8:~# uname -a Linux aml-bm8 5.1.0-rc1-aml-s905 #5.77 SMP PREEMPT Sun Apr 7 12:55:48 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux update: T95Z Plus - s912 octacore 3gb ram 1
Xavier31 Posted April 7, 2019 Posted April 7, 2019 I performed following steps: root@desktop:~# cat Armbian_5.75_Nanopik2-s905_Ubuntu_bionic_next_4.19.20_desktop.img > /dev/sdf root@desktop:~# dd if=/dev/sdf of=u-boot_k2.img bs=1M count=4 root@desktop:~# cat Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.1.0-rc1_desktop_20190407.img > /dev/sdf root@desktop:~# dd if=u-boot_k2.img of=/dev/sdf conv=fsync bs=1 count=442 root@desktop:~# dd if=u-boot_k2.img of=/dev/sdf conv=fsync bs=512 skip=1 seek=1 root@desktop:~# vi extlinux/extlinux.conf add line: FDT /dtb/meson-gxbb-nanopi-k2.dtb SD card boots perfectly. Below, output of uname -a Linux aml 5.1.0-rc1-aml-s905 #5.77 SMP PREEMPT Sun Apr 7 12:55:48 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux I noticed this image doesn't contain mali drivers so I don't expect a smooth Kodi GUI... I will play with it anyway and achieve some tests. If you think about some tests you would like I perform, feel free to ask...
balbes150 Posted April 8, 2019 Author Posted April 8, 2019 On 4/7/2019 at 6:09 PM, Xavier31 said: I noticed this image doesn't contain mali drivers so I don't expect a smooth Kodi GUI... Expand A test image with Mali support and a media script for it are at this link. https://yadi.sk/d/WxYNiTDLz8ILsQ
Xavier31 Posted April 8, 2019 Posted April 8, 2019 On 4/8/2019 at 6:29 AM, balbes150 said: A test image with Mali support and a media script for it are at this link. https://yadi.sk/d/WxYNiTDLz8ILsQ Expand Thank you I will test that...
Leon F Posted April 8, 2019 Posted April 8, 2019 On 4/7/2019 at 11:05 AM, balbes150 said: A new set of images 5.77_20190407 , used by the kernel 5.1.0-rc1. Pay attention, this is a generic image for the entire line of S9xxx (including for S912 and S905x2). Enabled by default DTB for Khadas VIM1 (S905X). To run on other models, you need to configure DTB. Expand test images 5.77_20190407 with Beelink GT1 mini , mouse keyboard vidoe, all is good except : HDMI no sound no wifi, any suggest?
balbes150 Posted April 8, 2019 Author Posted April 8, 2019 On 4/8/2019 at 11:52 AM, Leon F said: except : HDMI no sound no wifi, any suggest? Expand Please note, this is the first test version, it does not work yet sound from HDMI, WiFi and video acceleration HW. Works wired network, USB sound card and USB WiFi. Video in SW mode surprisingly works in up to 1080p inclusive. https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/606133-linux-images-for-s802-s805-s812-s905-s905x-s912-sd-usb-emmc?p=768370#post768370 New image 20190408 only changes add support BT and eMMC for x96 max (s905x2).
balbes150 Posted April 8, 2019 Author Posted April 8, 2019 Checked work with eMMC of the last variant of an image 20190408 on x96max. eMMC can see, the ddbr utility creates a full copy. I also checked the installation of the latest version of LibreELEC in eMMC, the system was installed in eMMC without problems and works from eMMC.
balbes150 Posted April 8, 2019 Author Posted April 8, 2019 Now checked on Odroid C2 an image 5.76 with MALI and a media script, by a technique with replacement of u-boot, as for K2. Everything works fine. After installing the script, the standard browser began to play video 1080 full screen without brakes. MPV is just as easy to handle any full-screen video. Bonus has an in-house sound via HDMI. There is one caveat when configuring - it is necessary to specify the correct DTB option in the file for Odroid C2 "/extlinux/extlinux conf". For those who don't know. The browser has a special additional link for a quick test of full-screen video. 2
teridotoji Posted April 9, 2019 Posted April 9, 2019 On 4/8/2019 at 1:18 PM, balbes150 said: Checked work with eMMC of the last variant of an image 20190408 on x96max. eMMC can see, the ddbr utility creates a full copy. I also checked the installation of the latest version of LibreELEC in eMMC, the system was installed in eMMC without problems and works from eMMC. Expand I modified the ethernet dtb for x96max 2GB version, it could boot but there is no driver for ethernet device from dmesg. Could you release the new image for the x96max 2GB version? Thanks ethernet@ff3f0000 { compatible = "amlogic, g12a-eth-dwmac", "snps,dwmac"; reg = <0x0 0xff3f0000 0x0 0x10000 0x0 0xff634540 0x0 0x8 0x0 0xff64c000 0x0 0xa0>; reg-names = "eth_base", "eth_cfg", "eth_pll"; interrupts = <0x0 0x8 0x1>; interrupt-names = "macirq"; status = "okay"; clocks = <0x2 0x38>; clock-names = "ethclk81"; pll_val = <0x9c0040a 0x927e0000 0xac5f49e5>; analog_val = <0x20200000 0xc000 0x23>; pinctrl-names = "external_eth_pins"; pinctrl-0 = <0x11>; mc_val = <0x1621>; cali_val = <0x30000>; internal_phy = <0x0>; }; external_eth_pins { linux,phandle = <0x11>; phandle = <0x11>; mux { groups = "eth_mdio", "eth_mdc", "eth_rgmii_rx_clk", "eth_rx_dv", "eth_rxd0", "eth_rxd1", "eth_rxd2_rgmii", "eth_rxd3_rgmii", "eth_rgmii_tx_clk", "eth_txen", "eth_txd0", "eth_txd1", "eth_txd2_rgmii", "eth_txd3_rgmii"; function = "eth"; drive-strength = <0x3>; }; };
balbes150 Posted April 9, 2019 Author Posted April 9, 2019 On 4/9/2019 at 10:15 AM, teridotoji said: I modified the ethernet dtb for x96max 2GB version, it could boot but there is no driver for ethernet device from dmesg. Could you release the new image for the x96max 2GB version? Thanks Expand I will try to add it in the next versions.
Leon F Posted April 9, 2019 Posted April 9, 2019 On 4/8/2019 at 12:45 PM, balbes150 said: Please note, this is the first test version, it does not work yet sound from HDMI, WiFi and video acceleration HW. Works wired network, USB sound card and USB WiFi. Video in SW mode surprisingly works in up to 1080p inclusive. https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/606133-linux-images-for-s802-s805-s812-s905-s905x-s912-sd-usb-emmc?p=768370#post768370 New image 20190408 only changes add support BT and eMMC for x96 max (s905x2). Expand I will test the new image on emmc, if it works, i will reply. thanks for your hard work.
balbes150 Posted April 9, 2019 Author Posted April 9, 2019 On 4/9/2019 at 10:15 AM, teridotoji said: Could you release the new image for the x96max 2GB version? Expand try https://yadi.sk/d/QHmrwhbZ8wRvOA
Peyton Posted April 11, 2019 Posted April 11, 2019 Hi there, i have a question regarding the stability of my tv box. I actually use a km8p as a pihole box and every week it crashed and i have to hard reboot it to make it works again. Can someone give me a hint to see where logs can help knows where could be the problem? I was on 5.1 kernel when i got the prob so i reinstall the box from scratch with previous build in 4.20.5 and both got the problem. Last kern.log is just : Apr 11 04:01:29 localhost kernel: [ 92.903423] random: 7 urandom warning(s) missed due to ratelimiting Thanks.
balbes150 Posted April 11, 2019 Author Posted April 11, 2019 Uploaded to the website alpha versions of images (Armbian and LibreELEC) with kernel 5.1.0-rc1 for Odroid N2.
AndrewDB Posted April 11, 2019 Posted April 11, 2019 On 4/11/2019 at 9:48 AM, Peyton said: Hi there, i have a question regarding the stability of my tv box. I actually use a km8p as a pihole box and every week it crashed and i have to hard reboot it to make it works again. Can someone give me a hint to see where logs can help knows where could be the problem? I was on 5.1 kernel when i got the prob so i reinstall the box from scratch with previous build in 4.20.5 and both got the problem. Last kern.log is just : Apr 11 04:01:29 localhost kernel: [ 92.903423] random: 7 urandom warning(s) missed due to ratelimiting Thanks. Expand Are you using the WiFi or ethernet to connect to the net? Also try a different power brick if you have one, you could have received a bad one. andrew@km8p1:~$ uptime 22:12:51 up 23 days andrew@km8p2:~$ uptime 22:13:38 up 47 days andrew@km8p3:~/Development/Armbian-NG$ uptime 22:14:01 up 47 days
Seasalt Posted April 12, 2019 Posted April 12, 2019 On 4/11/2019 at 2:55 PM, balbes150 said: Uploaded to the website alpha versions of images (Armbian and LibreELEC) with kernel 5.1.0-rc1 for Odroid N2. Expand You have uploaded Armbian s912 5.78. What are the benefits / improvements over Armbian 5.77? It appears the Kernel has gone from 5.0 to 5.1? Does that mean better Video driver performance? P.S. 5.77 s912 runs great on my Mecool s912 TV box. I use it as my main TV / projector player now utilizing VLC. Thanks for the great work.
balbes150 Posted April 12, 2019 Author Posted April 12, 2019 On 4/12/2019 at 1:22 AM, Seasalt said: It appears the Kernel has gone from 5.0 to 5.1? Expand Yes, it goes to the core 5.1 adding support for s905x2 and s922
teridotoji Posted April 12, 2019 Posted April 12, 2019 On 4/9/2019 at 2:19 PM, balbes150 said: try https://yadi.sk/d/QHmrwhbZ8wRvOA Expand Now, It works with x96max 2GB, Thanks for your effort
balbes150 Posted April 12, 2019 Author Posted April 12, 2019 On 4/12/2019 at 6:40 AM, teridotoji said: It works with x96max 2GB with USB. Thanks for your effort Expand This file is now part of the image.
Peyton Posted April 12, 2019 Posted April 12, 2019 On 4/11/2019 at 8:15 PM, AndrewDB said: Are you using the WiFi or ethernet to connect to the net? Also try a different power brick if you have one, you could have received a bad one. andrew@km8p1:~$ uptime 22:12:51 up 23 days andrew@km8p2:~$ uptime 22:13:38 up 47 days andrew@km8p3:~/Development/Armbian-NG$ uptime 22:14:01 up 47 days Expand I don't use WiFi nor BT at all. Only ethernet. Will try with a different power supply. Thanks.
