Tarzanus Posted January 15, 2020 Posted January 15, 2020 A95X Z2 4GB/64GB, RK3318 Armbian_19.11.4_Arm-64_bionic_dev_5.5.0-rc2_desktop_20191228 Doesn't work: Wifi, Bluetooth Does work: everything else It is stable and relatively fast, considering low price. It is based on RK3318 chip so it's not really desktop replacement material. Video playback in chromium works very slow and VLC has issues playing higher resolution videos. Desktop environment seems to be GPU accelerated and browsing seems quite smooth. Kodi - LibreElec, plays videos smoothly, even in a bit higher resolution (fullHD). I haven't tried 4k, but I very much doubt it can. If I install Kodi in Armbian it can't play even video resolutions such as 720p. Armbian_19.11.5_Aml-g12_bionic_dev_5.5.0-rc5-next-20200110_desktop is newer, but USB3 stopped working. 1
amirul Posted February 14, 2020 Posted February 14, 2020 Magicsee N6 Max Armbian_20.05.0-trunk_Arm-64_bionic_current_5.5.1_desktop_20200218 rk3399-rock-pi-4-2.dtb (tweaked to run 1.7 and 2GHz) rk3399-rock-pi-4-2.dtbFetching info... rk3399-rock-pi-4-2.dtsFetching info... Armbian_20.05.0-trunk_Arm-64_bionic_current_5.5.1_desktop_20200227 wifi works Armbian_20.05.0_Arm-64_bionic_current_5.6.0-rc4_desktop_20200304 xorg colors seem overbright, losing details Armbian_20.05.0_Arm-64_bionic_legacy_5.6.0-rc7_desktop_20200324 colors back to normal, wifi works for a while Armbian_20.05.0_Arm-64_bionic_current_5.6.0-rc6_desktop_20200403 xorg overbright color is back Armbian_20.05.1_Arm-64_bionic_current_5.6.0-rc7_desktop_20200404 color problem. Fixed by replacing uInitrd & zImage from 20200324 Armbian_20.05.2_Arm-64_bionic_current_5.7.0-rc1_desktop_20200416 Armbian_20.05.2_Arm-64_bionic_current_5.7.0-rc1_desktop_20200417 https://github.com/150balbes/Build-Armbian/blob/master/patch/kernel/rockchip64-current/rk3399-adjust-txpbl-for-mtu-1500.patch rk3399-rock-pi-4-2-adjust-txpbl-for-mtu-1500.dtsFetching info... All sorts of things changed in the current dtb, so I added the new cpu speeds rk3399-rock-pi-4-2-5.7.dtsFetching info... On idle, cpu % by some kworker - tracked down to module brcmfmac (wlan) so modprobe -r brcmfmac for now Armbian_20.05.2_Arm-64_bionic_current_5.7.0-rc1_desktop_20200423 OK Armbian_20.05.3_Arm-64_bionic_current_5.7.0-rc2_desktop_20200425 OK, seems better with memory management Armbian_20.05.3_Arm-64_bionic_current_5.7.0-rc3_desktop_20200502 OK Armbian_20.05.4_Arm-64_bionic_current_5.7.0-rc3_desktop_20200508 Armbian_20.05.4_Arm-64_bionic_current_5.7.0-rc4_desktop_20200510 Armbian_20.05.4_Arm-64_bionic_current_5.7.0-rc5_desktop_20200514 Armbian_20.05.4_Arm-64_bionic_current_5.7.0-rc5_desktop_20200516 glamor: video clicks & pops no more Armbian_20.05.5_Arm-64_bionic_current_5.7.0-rc6_desktop_20200522 Armbian_20.05.5_Arm-64_bionic_current_5.7.0-rc6_desktop_20200525 Armbian_20.05.5_Arm-64_focal_current_5.7.0-rc7_desktop_20200527 remove /etc/apt/sources.list.d/snwh-ubuntu-ppa-focal.list to update Armbian_20.05.5_Arm-64_focal_current_5.7.0-rc7_desktop_20200529 ✔ Armbian_20.08.0_Arm-64_focal_current_5.7.0-rc7_desktop_20200531 ✔ Armbian_20.05.6_Arm-64_focal_current_5.7.2_desktop_20200612 ✔ desktop feels snappier...? Armbian_20.05.6_Arm-64_focal_dev_5.8.0-rc1_desktop_20200616 ✔ wifi does not disappear, nope didn't last Armbian_20.06.0_Arm-64_focal_current_5.7.2_desktop_20200619 ✔ Armbian_20.06.0_Arm-64_focal_dev_5.8.0-rc2_desktop_20200623 ✔ Armbian_20.06.0_Arm-64_focal_dev_5.8.0-rc3_desktop_20200629 ✔ 13hr uptime wifi still on rk3399-rock-pi-4-5.7-1.dtbFetching info... rk3399-rock-pi-4-5.7-1.dtsFetching info... Armbian_20.05.6_Arm-64_focal_current_5.7.0-rc7_desktop_20200605 OK with rk3399-rock-pi-4-2-5.7.dtb, with rk3399-rock-pi-4-5.7-1 mpv locks up 20.09 20200904 5.8.5-arm-64 su -c 'echo 5 > /proc/irq/230/smp_affinity_list' # irq230 is USB3 port (xhci-hcd:usb7) su -c 'echo 4 > /proc/irq/27/smp_affinity_list' # irq27 is eth0 sudo taskset -cp 4,5 $(pgrep Xorg) # pin Xorg to cpu 4&5 ==> chromium Octane score 10k+
jimbob Posted March 7, 2020 Posted March 7, 2020 H96 Max X3 - Amlogic S905X3 SoC - Gigabit ethernet (RTL8211F)! - boots with meson-g12a-x96-max.dtb and standard aml color fix - decent radiator (compiling for hours on all 4 cores doesn't overheat at all) - installs on eMMC no problem - warn - comes with unrooted Android - like other aml S905X's no wifi/bt/sound by default
l33chy Posted April 8, 2020 Posted April 8, 2020 MX pro 4K Amlogic S905 Mali-450 DRAM 1GB DDR3 Flash 8GB Currently running Armbian_20.02.0-rc1.037_Aml-s9xxx_buster_current_5.5.0-rc6_20200205 with meson-gxbb-p201.dtb Ethernet and USB is working Haven't tried eMMC install (it might not work from what I've seen), so only running it from SD. WiFi chipset is RTL8189etv - not working (it did work on OpenELEC with gxbb_p200_1G_100M_RealtekWiFi.dtb if someone is interested in that)
root-stas Posted May 3, 2020 Posted May 3, 2020 For additions to previous post: On 3/7/2020 at 10:31 PM, jimbob said: H96 Max X3 - Amlogic S905X3 SoC - Gigabit ethernet (RTL8211F)! - boots with meson-g12a-x96-max.dtb and standard aml color fix - decent radiator (compiling for hours on all 4 cores doesn't overheat at all) - installs on eMMC no problem - warn - comes with unrooted Android - like other aml S905X's no wifi/bt/sound by default Expand After use DTB file from post: With kernel 5.6 and 5.7 Wi-Fi working out-of-the-box, but recognizing as BCM4339/2 (proper name is BCM4335), on 2.4 and 5 (AC) mode. To get Bluetooth working we need add firmware for BCM4335, get it from: https://github.com/kszaq/brcmfmac_sdio-firmware-aml/blob/master/firmware/brcm/bcm4335c0.hcd and put in folder "/lib/firmware/brcm" with name "BCM4335C0.hcd" and reboot. Don't get working yet 3D acceleration and video encoding.
orange Posted May 29, 2020 Posted May 29, 2020 Tanix TX8 Max Amlogic S912 3 GB RAM DDR4 16 GB eMMC Armbian_20.02.0-rc1.037_Aml-s9xxx with meson-gxm-q200.dtb Installed on the emmc without problems. Don't get working yet 3D acceleration in game. Encoding video up to 1080p. Work all right. Fanless the temperature rises to 70. With fan 30 degrees.
mradalbert Posted May 29, 2020 Posted May 29, 2020 Vontar x3 (Amlogic S905X3 SoC) Most probably same circuit as H96 Max X3 see: Confirmed to work with h96max-x2-test-bus80-gpu-volt.dtb from root-stas: -HDMI w/ sound -WiFi 802.11a/b/g/n/ac -Bluetooth 4.0 after adding missing files Not working yet GPU/VPU accel
ThatUnknownGuy Posted June 3, 2020 Posted June 3, 2020 (edited) I'm running some X96 Air 2/16 variants on Armbian with no issue. They're quad-core S905X3 based and come with DDR3. They're also very compact which is great for my use. Using the meson-sm610.dtb, ethernet works and HDMI works as well. I have no clue about audio or wifi as I do not use a desktop environment They also have 16GB of eMMC which can be flashed to host armbian Edited June 3, 2020 by ThatUnknownGuy 1
balbes150 Posted January 25, 2021 Author Posted January 25, 2021 Firefly Station M1 (rk3328) https://www.thanassis.space/stationm1.html
