rino Posted December 12, 2018 Posted December 12, 2018 On debian stretch: Linux lepotato 4.19.8-meson64 #5.67.181210 SMP PREEMPT Tue Dec 11 00:22:25 CET 2018 aarch64 GNU/Linux and on my PA248Q ASUS 1920x1200 monitor: HDMI to HDMI ok (even hotplugged) HDMI to DVI ok but 'lazy' (required several plug/unplug reboot attempts) hotplug USB mouse ok hottplug USB keyboard NOT OK Recap of desktop usability problems I can see: -slow windows resizing in XFCE (waiting for HW OpenGL acceleration by Lima project) -chromium windows not integrated in XFCE destop environment (top right buttons missing) -no video acceleration in Chromium or mpv media player (waiting for that as LibreComputers's plan)
Tommy21 Posted December 12, 2018 Posted December 12, 2018 [mention=3841]Tommy21[/mention]You won't have OpenGL acceleration, but yes should be able with the actual images. With a Bionic ubuntu desktop image, you should be able to select wayland gnome at the login prompt.Yeah, i do know it will be without OpenGL, and it will stay that way until Lima driver starts supporting it?About Gnome, synaptic has 3.2.x version, i've read that 3.30 versions are Arm supported, and there is no way to add 3.30 gnome repo, maybe only way is to compile it from source?
Neil Armstrong Posted December 13, 2018 Posted December 13, 2018 @TonyMac32 With witch screen do you still have an issue you didn't had with the previous kernel releases ?
TonyMac32 Posted December 13, 2018 Author Posted December 13, 2018 All of them unfortunately. They (almost*) all work on boot now after the last few patches you recommended)posted, but switching resolution is a problem on all, and hot plugging can result in only part of the screen showing output. Switch from higher to lower res results in a garbled display. * The 4k display boots in 1080p with a strange interlacing pattern making only some of the desktop accessible. A plug cycle and it is fine, as long as the whole screen displays the desktop (black bar at the bottom possible seemingly at random). [Edit] I will dump xrandr data from a different board arch (or maybe just older kernel) for these, the resolutions/frequencies look different than I'm used to seeing with the current Meson64. Sent from my Pixel using Tapatalk
Neil Armstrong Posted December 14, 2018 Posted December 14, 2018 And this behavior in only since 4.19 ?
rino Posted December 16, 2018 Posted December 16, 2018 with Bionic: Linux lepotato 4.19.9-meson64 #5.67.181213 SMP PREEMPT Thu Dec 13 23:45:38 CET 2018 aarch64 aarch64 aarch64 GNU/Linux I also installed desktop env via armbian-config and on my PA248Q ASUS 1920x1200 monitor: HDMI to HDMI ok (even hotplugged) HDMI to DVI ok -hotplug USB mouse ok -hottplug USB keyboard OK, better than in debian Stretch -no CPU temp in htop -slow windows resizing in XFCE (waiting for HW OpenGL acceleration by Lima project) -chromium windows IS integrated in XFCE destop environment, better than in debian -no video acceleration in Chromium or mpv media player (waiting for that as LibreComputers's plan) -better low res youtube video than in debian So desktop usability in bionic appears to be better than in debian Stretch.
rino Posted December 16, 2018 Posted December 16, 2018 How to test audio? Audio is on HDMI, I suppose. Is possibile to get audio out from 3.5mm jack? How to configure that?
TonyMac32 Posted December 16, 2018 Author Posted December 16, 2018 @rino Thanks for the test! Could you test changing resolutions?Sent from my Pixel using Tapatalk
Neil Armstrong Posted December 17, 2018 Posted December 17, 2018 @rinoAudio is only supported out of HDMI now, we need funding (and time) to finish audio properly and have the 3,5mm Jack output and S/PDIF with data passthrough
rino Posted December 18, 2018 Posted December 18, 2018 @TonyMac32 trying to do what you asked for I chose: 1600*1200 but it doesn't work and that resolution put the monitor output in an inconsistent state (mirrored stripes) Now I need to reset a working resolution via CLI in order to continue the testing. Trying to recover I had no success: I opened a virtual terminal and: $ xrandr -q Can't open display Please, give me guidance.
rino Posted December 18, 2018 Posted December 18, 2018 On: Linux lepotato 4.19.10-meson64 #5.67.181217 SMP PREEMPT Mon Dec 17 14:21:39 CET 2018 aarch64 aarch64 aarch64 GNU/Linux ARMBIAN 5.67.181217 nightly Ubuntu 18.04.1 LTS 4.19.10-meson64 and on my PA248Q ASUS 1920x1200 monitor: HDMI to HDMI ok HDMI to DVI NOT ok So I can see a regression here.
TonyMac32 Posted December 18, 2018 Author Posted December 18, 2018 Yes, this is what I've been talking about in this thread for the last week or so.Sent from my Pixel using Tapatalk
Neil Armstrong Posted December 19, 2018 Posted December 19, 2018 @rino so you connect the same screen via HDMI and "HDMI to DVI" and only the "HDMI to DVI" fails ? What is the resolution selected via HDMI and "HDMI to DVI" ? is that 1920x1200, 1920x1080 or 1600*1200 ? On 4.19 I added a "generic" support for all monitors, but I waited for feedback to know if it failed on some monitors. Let me check
rino Posted December 19, 2018 Posted December 19, 2018 @Neil Armstrong > so you connect the same screen via HDMI and "HDMI to DVI" and only the "HDMI to DVI" fails ? That's correct I just tested it again: HDMI to HDMI works but HDMI to DVI does not. I got a blank screen and after several minutes I only obtained an unusable flashing armbian/penguin desktop background with a lot of green tone instead of the usual black one. That's with the last bionic: ARMBIAN 5.67.181217 nightly Ubuntu 18.04.1 LTS 4.19.10-meson64. Before, with bionic "Linux lepotato 4.19.9-meson64 #5.67.181213 SMP PREEMPT Thu Dec 13 23:45:38 CET 2018 aarch64 aarch64 aarch64 GNU/Linux", HDMI to DVI worked. It's a regression. > What is the resolution selected via HDMI and "HDMI to DVI" ? is that 1920x1200, 1920x1080 or 1600*1200 ? 1920x1200, that's the default for my Asus PA248Q monitor. Please explain here how to change resolution via CLI (i.e. UART console).
Neil Armstrong Posted December 19, 2018 Posted December 19, 2018 @TonyMac32 What did you change between the 4.19.9-meson64 and 4.19.10-meson64 kernel ? the only upstream change is about adding the HDMI 1080p25 mode
rino Posted December 19, 2018 Posted December 19, 2018 > What did you change between the 4.19.9-meson64 and 4.19.10-meson64 kernel I think nothing. In both case I started from the fresh beta bionic image and added the full desktop via armbian-config (beta bionic image has not the desktop, instead the stretch one has it). I should suggest to add the desktop part to the bionic beta image because so the desktop user experience is not bad. For example I can see music videos in lowres from youtube with a fair user experience.
rino Posted December 19, 2018 Posted December 19, 2018 During the shutdown on the uart console: [ 4460.137855] meson-i2s-dai meson-i2s-dai.4.auto: Unable set to set i2s description [ 4460.227077] meson-i2s-dai meson-i2s-dai.4.auto: ASoC: can't set meson-i2s-dai.4.auto hw params: -22
TonyMac32 Posted December 19, 2018 Author Posted December 19, 2018 2 hours ago, Neil Armstrong said: 4.19.9-meson64 and 4.19.10-meson64 kernel ? Nothing, I'm not sure the mention of "regression" was discussing the minor revision number, but more likely the 4.19 kernel itself. @rino can you confirm?
rino Posted December 19, 2018 Posted December 19, 2018 @TonyMac32 4 hours ago, TonyMac32 said: Nothing, I'm not sure the mention of "regression" was discussing the minor revision number, but more likely the 4.19 kernel itself. @rino can you confirm? Yes the 4.19 kernel itself. HDMI to DVI was working when I just moved from debian to ubuntu beta images. Is this irrelevant? Are the two beta 4.19 meson kernels, at same moment, always the same and no other element in the distro can influence HDMI to DVI functionality?
TonyMac32 Posted December 19, 2018 Author Posted December 19, 2018 Now that I need to look at.Sent from my Pixel using Tapatalk
rino Posted December 23, 2018 Posted December 23, 2018 Other test performed. I am starting to understand better the "HDMI to DVI" working/not working laziness problem: HDMI to DVI works BUT, just after the boot, I have to move the mouse to wake up the monitor and get the desktop (I usually interact with the SBC via the uart console). That's with the last: ARMBIAN 5.67.181221 nightly Ubuntu 18.04.1 LTS 4.19.11-meson64 1
rino Posted December 26, 2018 Posted December 26, 2018 On 12/16/2018 at 3:36 PM, TonyMac32 said: @rino Thanks for the test! Could you test changing resolutions? Sent from my Pixel using Tapatalk On bionic 4.19.12-meson64 #5.67.181226: $ xrandr -d :0 -q Screen 0: minimum 320 x 200, current 1920 x 1200, maximum 16384 x 8192 Composite-1 connected (normal left inverted right x axis y axis) 720x576i 50.00 720x480i 59.94 HDMI-1 connected 1920x1200+0+0 (normal left inverted right x axis y axis) 546mm x 352mm 1920x1200 59.95*+ (yes) 1920x1080 60.00 (yes) 1600x1200 60.00 1680x1050 59.88 (yes) 1280x1024 75.02 60.02 (HDMI only) 1440x900 59.90 (yes) 1280x960 60.00 1152x864 75.00 1024x768 75.03 70.07 60.00 832x624 74.55 800x600 72.19 75.00 60.32 56.25 640x480 75.00 72.81 66.67 Legenda of test result: (yes) means that HDMI to HDMI and HDMI to DVI both work (HDMI only) means HDMI to HDMI works no () means that HDMI to HDMI and HDMI to DVI both don't work. PS To change resolution from UART console I used for example: $ xrandr -d :0 --output HDMI-1 --mode 1920x1080 2
rino Posted December 28, 2018 Posted December 28, 2018 Accelerated 4K full-screen video in vlc on Armbian Bionic 4.19 beta image of Le Potato is working. How to get it: -install beta image: Armbian Bionic nightly mainline kernel 4.19.y -add desktop via armbian-config -install vlc: $ sudo apt-get install vlc -configure VLC: Tools > Preferences > Input / Codecs > Codecs > Hardware-accelerated decoding > VA-API video decoder Tools > Preferences > Video > Display > Output > X11 video output (XCB) -open a 4k .mp4 video and double click on it in order to get full-screen and enjoy the baylibre work on the open source graphic driver in the mainline 4.19 kernel
rino Posted January 7, 2019 Posted January 7, 2019 Year needs to be changed in the nightly build name. For example: https://dl.armbian.com/lepotato/nightly/Armbian_5.68.180101_Lepotato_Ubuntu_bionic_dev_4.19.13.7z should be: ... 190101 ...
Neil Armstrong Posted January 8, 2019 Posted January 8, 2019 @TonyMac32I found a regression, can you test this fix ? https://github.com/superna9999/linux/commit/b9edb9c9eec654ba57f8da7966e4b1b81a6d7c7b 1
TonyMac32 Posted January 9, 2019 Author Posted January 9, 2019 @Neil Armstrong everything looks good now, changing modes, changing monitors, no problems. Tested on Le Potato. [edit] Just tossed it into the dev branch, anyone else wanting to test, go forth.
Neil Armstrong Posted January 15, 2019 Posted January 15, 2019 @TonyMac32 the fixup was not right (it worked, but was not the right way), can you check if https://patchwork.freedesktop.org/patch/277316/ does the same effect ? I'm also checking on my side
Neil Armstrong Posted January 15, 2019 Posted January 15, 2019 (edited) @TonyMac32 I'm getting a failure in u-boot with the latest 4.19 bionic desktop LePotato image I get from armbian.com : Spoiler Quote GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:0;RCY:0;USB:0;SPI:0;CHK:A7;EMMC:400;NAND:81;SD:0;READ:0;0.0;CHK:0; no sdio debug board detected TE: 1888362 BL2 Built : 11:58:42, May 27 2017. gxl gc3c9a84 - xiaobo.gu@droid05 set vcck to 1120 mv set vddee to 1000 mv Board ID = 6 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - PASS Rank0: 1024MB(auto)-2T-13 Rank1: 1024MB(auto)-2T-13 DataBus test pass! AddrBus test pass! Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from SD, src: 0x00020200, des: 0x05100000, size: 0x00018400 Load bl33 from SD, src: 0x0003c200, des: 0x01000000, size: 0x00081200 NOTICE: BL3-1: v1.0(release):3348978 NOTICE: BL3-1: Built : 15:44:01, May 12 2017 [BL31]: GXL CPU setup! mpu_config_enable:ok [Image: gxl_v1.1.3221-2cfba69 2017-05-27 16:03:58 qiufang.dai@droid07] OPS=0x84 48 38 b be a2 f0 dc eb 16 d9 1e b2 [2.241797 Inits done] secure task start! high task start! low task start! ERROR: Error initializing runtime service opteed_fast U-Boot 2018.11-armbian (Jan 11 2019 - 19:16:55 +0100) libretech-cc DRAM: 2 GiB MMC: mmc@72000: 0, mmc@74000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@4c0 Out: serial@4c0 Err: serial@4c0 [BL31]: tee size: 0 [BL31]: tee size: 0 Net: Warning: ethernet@c9410000 (eth0) using random MAC address - 2a:ef:31:d6:85:db eth0: ethernet@c9410000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3048 bytes read in 1 ms (2.9 MiB/s) ## Executing script at 1f000000 154 bytes read in 1 ms (150.4 KiB/s) ** File not found /boot/uInitrd ** ** File not found /boot/Image ** ** File not found /boot/dtb/amlogic/meson-gxl-s905x-libretech-cc.dtb ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! ** File not found /boot/dtb/amlogic/overlay/meson-fixup.scr ** Bad Linux ARM64 Image magic! SCRIPT FAILED: continuing... MMC Device 2 not found no mmc device at slot 2 starting USB... USB0: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 3 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device Speed: 100, full duplex BOOTP broadcast 1 Abort missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-00-50-43-84-fb-2f Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-meson Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default Speed: 100, full duplex *** ERROR: `serverip' not set Config file not found => <INTERRUPT> => <INTERRUPT> => Edited January 15, 2019 by Tido added spoiler
Igor Posted January 15, 2019 Posted January 15, 2019 54 minutes ago, Neil Armstrong said: I'm getting a failure in u-boot with the latest 4.19 bionic desktop LePotato image I get from armbian.com : Mine boots fine http://ix.io/1ynZ - must be some SD card related problem?
