TheLinuxBug Posted April 27, 2019 Share Posted April 27, 2019 Yeah, having a serial UART is pretty important for working with this board unless you have one of the VGA breakouts or something where you can see whats going on. Cause I don't think these images are setup in any way to otherwise be default accessible. I doubt you will get any feedback on the USB port with the image, however, it may bring up ethernet... can't recall though and if it does, it is likely with a predefined static IP. You can probably mount the image using a loop device on your local Linux machine and take a look at things inside to get a better idea. Maybe a little later today I can pull it out and play with it and see if I can come up with something better for you. If you really want to motivate me to test it, you are best to come to IRC and bug me about it, lol. Otherwise I do have a huge list of 'other things' I will probably start working on first. Cheers! 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 27, 2019 Share Posted April 27, 2019 1 hour ago, TheLinuxBug said: You can probably mount the image using a loop device on your local Linux machine and take a look at things inside to get a better idea. Maybe a little later today I can pull it out and play with it and see if I can come up with something better for you. If you really want to motivate me to test it, you are best to come to IRC and bug me about it, lol. Otherwise I do have a huge list of 'other things' I will probably start working on first. I already did mount the two partitons and did take a look at /etc/network/interfaces and /etc/rc.local, but ethernet doenst came up like I configured. Something better would be nice. This week I havent a free head for much more, because since monday I got the flu/grip and tissue's are my best friends these days....butI like small boards and when its not so easy (like on the supported armbian-boards) 0 Quote Link to comment Share on other sites More sharing options...
TheLinuxBug Posted April 28, 2019 Share Posted April 28, 2019 @guidol Good news and medium good news. Here is u-boot, kernel and dtb needed to enable eth0 and have it work: https://licheepizero.us/licheepizero.linux-4.12.with.vga.and.eth0.tar.gz http://prntscr.com/nhuq6f http://prntscr.com/nhupqd http://prntscr.com/nhupv3 The uboot has vga and eth0 enabled, however, the current versions of the WiFi module that are around do not work with this kernel and while VGA is in the uboot, it isn't active in the kernel in this. If your goal is to boot up and have eth0 up and access, this should work for you. I am going to test building 4.14.y and 4.13.y branch to see if the WiFi driver is incorporated at any point, the github repos are not very specific about whats been updated and my attempts to build the driver seperately have so far failed for the 4.12.y repo I used to generate this. This should at least be enough to get you started. Once i test a bit more I will upload my .config and provide a link as well. Cheers! 1 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 28, 2019 Share Posted April 28, 2019 10 hours ago, TheLinuxBug said: @guidol Good news and medium good news. Here is u-boot, kernel and dtb needed to enable eth0 and have it work: https://licheepizero.us/licheepizero.linux-4.12.with.vga.and.eth0.tar.gz The uboot has vga and eth0 enabled, however, the current versions of the WiFi module that are around do not work with this kernel and while VGA is in the uboot, it isn't active in the kernel in this. If your goal is to boot up and have eth0 up and access, this should work for you. This should at least be enough to get you started. Once i test a bit more I will upload my .config and provide a link as well. Woohoo YES - its working! BootUp and Ethernet is working and also the TrippleLED (Green/Red/Blue) Static IP wouldnt work in the first place, so I did go back to DHCP and did tell my Router to give a Static-DHCP-IP to the LicheePi-MAC. I did expand the filesystem with a with the following link (which I didnt found in your link-list):https://github.com/Squonk42/buildroot-licheepi-zero-old/wiki/Fresh-image-–-Expand-the-root-partition-and-filesystem and then I "installed" the 128MB swap with a mix of the instructions you listed under http://bbs.ilichee.cc/t/tutorial-setup-swap-file-for-zero/56 and the link I did found also in the same (LicheePi builtroot) wiki : https://github.com/Squonk42/buildroot-licheepi-zero-old/wiki/Fresh-image-–-Expand-the-virtual-memory Some impressions: Spoiler login as: root root@192.168.6.130's password: _ ____ _ _____ ____ _ | | | _ \(_) |__ /___ _ __ ___ | _ \ ___ ___| | __ | | | |_) | | / // _ \ '__/ _ \ | | | |/ _ \ / __| |/ / | |___| __/| | / /| __/ | | (_) | | |_| | (_) | (__| < |_____|_| |_| /____\___|_| \___/ |____/ \___/ \___|_|\_\ ============================================================ V3s Single-Cortex-A7-System 64MB Ram ------------------------------------------------------------ Last login: Mon Apr 29 03:02:33 2019 from 192.168.6.17 root@LicheePi(addr:192.168.6.130):/# uname -a Linux LicheePi 4.12.0-rc1-00088-gbe3a3cd-dirty #1 SMP Sun Apr 28 10:21:26 CEST 2019 armv7l GNU/Linux root@LicheePi(addr:192.168.6.130):/# top top - 02:00:38 up 16 min, 1 user, load average: 0.02, 0.03, 0.00 Tasks: 61 total, 1 running, 60 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.3 us, 0.6 sy, 0.0 ni, 95.8 id, 3.4 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem: 55956 total, 44916 used, 11040 free, 3652 buffers KiB Swap: 131068 total, 0 used, 131068 free. 20408 cached Mem root@LicheePi(addr:192.168.6.130):/# ls -l /sys/class/leds total 0 lrwxrwxrwx 1 root root 0 Apr 29 01:43 licheepi:blue:usr -> ../../devices/platform/leds/leds/licheepi:blue:usr lrwxrwxrwx 1 root root 0 Apr 29 01:43 licheepi:green:usr -> ../../devices/platform/leds/leds/licheepi:green:usr lrwxrwxrwx 1 root root 0 Apr 29 01:43 licheepi:red:usr -> ../../devices/platform/leds/leds/licheepi:red:usr root@LicheePi(addr:192.168.6.130):/# more /proc/cpuinfo processor : 0 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 48.00 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : Allwinner sun8i Family Revision : 0000 Serial : 12c000022eec95b1 I did see that /etc/apt/sources.list does point to debian jessie - so we have to adjust the entrys to get them work, because they did change them - I think - a month ago: https://lists.debian.org/debian-devel-announce/2019/03/msg00006.html dmesg: Spoiler [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.12.0-rc1-00088-gbe3a3cd-dirty (root@shell10.phix-it.com) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Sun Apr 28 10:21:26 CEST 2019 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Lichee Pi Zero [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 16384 [ 0.000000] free_area_init_node: node 0, pgdat c0a603c0, node_mem_map c3f7a000 [ 0.000000] Normal zone: 128 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 16384 pages, LIFO batch:3 [ 0.000000] percpu: Embedded 16 pages/cpu @c3f62000 s33548 r8192 d23796 u65536 [ 0.000000] pcpu-alloc: s33548 r8192 d23796 u65536 alloc=16*4096 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 [ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=tty0 rootwait root=/dev/mmcblk0p2 earlyprintk rw [ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes) [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Memory: 54932K/65536K available (6144K kernel code, 387K rwdata, 1432K rodata, 1024K init, 265K bss, 10604K reserved, 0K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xc4800000 - 0xff800000 ( 944 MB) lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc0700000 (7136 kB) .init : 0xc0900000 - 0xc0a00000 (1024 kB) .data : 0xc0a00000 - 0xc0a60cc0 ( 388 kB) .bss : 0xc0a674d8 - 0xc0aa9a94 ( 266 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000019] Switching to timer-based delay loop, resolution 41ns [ 0.000153] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000378] Console: colour dummy device 80x30 [ 0.000794] console [tty0] enabled [ 0.000836] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.000875] pid_max: default: 32768 minimum: 301 [ 0.001014] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001041] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001679] CPU: Testing write buffer coherency: ok [ 0.002077] /cpus/cpu@0 missing clock-frequency property [ 0.002122] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002594] Setting up static identity map for 0x40100000 - 0x40100060 [ 0.003263] smp: Bringing up secondary CPUs ... [ 0.003303] smp: Brought up 1 node, 1 CPU [ 0.003325] SMP: Total of 1 processors activated (48.00 BogoMIPS). [ 0.003344] CPU: All CPU(s) started in SVC mode. [ 0.004091] devtmpfs: initialized [ 0.006569] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.006867] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.006924] futex hash table entries: 256 (order: 2, 16384 bytes) [ 0.007091] pinctrl core: initialized pinctrl subsystem [ 0.008158] NET: Registered protocol family 16 [ 0.008665] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.009798] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.009845] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.021615] SCSI subsystem initialized [ 0.021979] libata version 3.00 loaded. [ 0.022289] usbcore: registered new interface driver usbfs [ 0.022381] usbcore: registered new interface driver hub [ 0.022494] usbcore: registered new device driver usb [ 0.022753] pps_core: LinuxPPS API ver. 1 registered [ 0.022777] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.022827] PTP clock support registered [ 0.023055] Advanced Linux Sound Architecture Driver Initialized. [ 0.023746] Bluetooth: Core ver 2.22 [ 0.023848] NET: Registered protocol family 31 [ 0.023870] Bluetooth: HCI device and connection manager initialized [ 0.023900] Bluetooth: HCI socket layer initialized [ 0.023921] Bluetooth: L2CAP socket layer initialized [ 0.023966] Bluetooth: SCO socket layer initialized [ 0.024508] clocksource: Switched to clocksource arch_sys_counter [ 0.035532] NET: Registered protocol family 2 [ 0.036178] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.036236] TCP bind hash table entries: 1024 (order: 1, 8192 bytes) [ 0.036274] TCP: Hash tables configured (established 1024 bind 1024) [ 0.036411] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.036475] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.036694] NET: Registered protocol family 1 [ 0.037411] RPC: Registered named UNIX socket transport module. [ 0.037457] RPC: Registered udp transport module. [ 0.037477] RPC: Registered tcp transport module. [ 0.037494] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.039555] workingset: timestamp_bits=30 max_order=14 bucket_order=0 [ 0.049085] NFS: Registering the id_resolver key type [ 0.049167] Key type id_resolver registered [ 0.049187] Key type id_legacy registered [ 0.049246] fuse init (API version 7.26) [ 0.051422] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 0.051481] io scheduler noop registered [ 0.051501] io scheduler deadline registered [ 0.051555] io scheduler cfq registered (default) [ 0.051573] io scheduler mq-deadline registered [ 0.051591] io scheduler kyber registered [ 0.056482] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 0.124223] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.127708] console [ttyS0] disabled [ 0.148001] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 30, base_baud = 1500000) is a U6_16550A [ 0.740861] console [ttyS0] enabled [ 0.758155] loop: module loaded [ 0.762256] libphy: Fixed MDIO Bus: probed [ 0.766494] CAN device driver interface [ 0.771785] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 0.779400] usbcore: registered new interface driver pegasus [ 0.785160] usbcore: registered new interface driver rtl8150 [ 0.790913] usbcore: registered new interface driver r8152 [ 0.797738] aoe: AoE v85 initialised. [ 0.801473] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.808106] ehci-platform: EHCI generic platform driver [ 0.813520] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.819791] ohci-platform: OHCI generic platform driver [ 0.825220] usbcore: registered new interface driver uas [ 0.830615] usbcore: registered new interface driver usb-storage [ 0.837944] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0 [ 0.844864] sun6i-rtc 1c20400.rtc: RTC enabled [ 0.849527] i2c /dev entries driver [ 0.853262] IR NEC protocol handler initialized [ 0.857873] IR RC5(x/sz) protocol handler initialized [ 0.862935] IR RC6 protocol handler initialized [ 0.867494] IR JVC protocol handler initialized [ 0.872029] IR Sony protocol handler initialized [ 0.876662] IR SANYO protocol handler initialized [ 0.881370] IR Sharp protocol handler initialized [ 0.886091] IR MCE Keyboard/mouse protocol handler initialized [ 0.891927] IR XMP protocol handler initialized [ 0.897246] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 0.905277] Bluetooth: HCI UART driver ver 2.3 [ 0.909738] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 0.974560] sunxi-mmc 1c0f000.mmc: base:0xc485d000 irq:22 [ 0.981522] usbcore: registered new interface driver usbhid [ 0.987208] usbhid: USB HID core driver [ 0.992593] ipip: IPv4 and MPLS over IPv4 tunneling driver [ 0.998978] gre: GRE over IPv4 demultiplexor driver [ 1.003887] ip_gre: GRE over IPv4 tunneling driver [ 1.010061] NET: Registered protocol family 17 [ 1.014647] can: controller area network core (rev 20170425 abi 9) [ 1.020955] NET: Registered protocol family 29 [ 1.025464] can: raw protocol (rev 20170425) [ 1.029744] can: broadcast manager protocol (rev 20170425 t) [ 1.035440] can: netlink gateway (rev 20170425) max_hops=1 [ 1.041197] Key type dns_resolver registered [ 1.045683] Registering SWP/SWPB emulation handler [ 1.056817] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 1.068291] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 1.074085] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1 [ 1.085434] hub 1-0:1.0: USB hub found [ 1.089333] hub 1-0:1.0: 1 port detected [ 1.094141] sun6i-rtc 1c20400.rtc: setting system clock to 2019-04-28 18:11:53 UTC (1556475113) [ 1.103167] vcc3v0: disabling [ 1.106222] vcc5v0: disabling [ 1.109204] ALSA device list: [ 1.112176] No soundcards found. [ 1.116237] Waiting for root device /dev/mmcblk0p2... [ 1.161773] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.172042] mmc0: new high speed SDHC card at address aaaa [ 1.178295] mmcblk0: mmc0:aaaa SU16G 14.8 GiB [ 1.184340] mmcblk0: p1 p2 [ 1.205860] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities [ 1.215064] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities [ 1.237270] random: fast init done [ 1.243556] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.251867] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.265964] devtmpfs: mounted [ 1.270147] Freeing unused kernel memory: 1024K [ 1.469611] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 1.483682] systemd[1]: Detected architecture 'arm'. [ 1.512454] systemd[1]: Failed to insert module 'autofs4' [ 1.518368] systemd[1]: Failed to insert module 'ipv6' [ 1.525429] systemd[1]: Set hostname to <LicheePi>. [ 1.929072] systemd[1]: Cannot add dependency job for unit dbus.socket, ignoring: Unit dbus.socket failed to load: No such file or directory. [ 1.942157] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 1.959723] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 1.968299] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 1.976234] systemd[1]: Expecting device dev-ttyS0.device... [ 2.182638] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 2.591149] systemd-udevd[91]: starting version 215 [ 2.778800] Adding 131068k swap on /swap. Priority:-1 extents:4 across:172032k SS [ 3.512443] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 4.044479] systemd-journald[78]: Received request to flush runtime journal from PID 1 [ 6.225240] libphy: 1c30000.ethernet: probed [ 6.241598] Generic PHY 1c30000.ethernet-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1c30000.ethernet-0:01, irq=-1) [ 6.253430] sun8i-emac 1c30000.ethernet: device MAC address slot 0 02:02:2e:ec:95:b1 [ 6.261680] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01 [ 8.325108] sun8i-emac 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 11.273289] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01 [ 16.505200] sun8i-emac 1c30000.ethernet: device MAC address slot 1 01:00:5e:00:00:01 PS: My OrangePi PC is running your(?) H3Droid as Text2Speech-Server, because the good german Voice was much cheaper than for a PC: 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 28, 2019 Share Posted April 28, 2019 the old jessie-souces.list does give the updates-error: Spoiler deb http://ftp.cn.debian.org/debian/ jessie main contrib non-free deb-src http://ftp.cn.debian.org/debian/ jessie main contrib non-free deb http://ftp.cn.debian.org/debian/ jessie-updates main contrib non-free deb-src http://ftp.cn.debian.org/debian/ jessie-updates main contrib non-free W: Failed to fetch http://ftp.cn.debian.org/debian/dists/jessie-updates/InRelease Unable to find expected entry 'main/source/Sources' in Release file (Wrong sources.list entry or malformed file) My newer one does work Spoiler deb http://archive.debian.org/debian/ jessie main contrib non-free deb-src http://archive.debian.org/debian/ jessie main contrib non-free deb http://security.debian.org jessie/updates main contrib non-free deb-src http://security.debian.org jessie/updates main contrib non-free Fetched 20.2 MB in 1min 52s (179 kB/s) Reading package lists... Done Building dependency tree... Done 93 packages can be upgraded. Run 'apt list --upgradable' to see them. 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 28, 2019 Share Posted April 28, 2019 9 hours ago, TheLinuxBug said: Here is u-boot, kernel and dtb needed to enable eth0 and have it work: https://licheepizero.us/licheepizero.linux-4.12.with.vga.and.eth0.tar.gz it seems that I missed to "flash" the new u-boot I did copy it only to /boot, but I did read it has to be flaseh with a 8K offset to the microsd like: dd if=u-boot-sunxi-with-spl.bin of=/dev/ sdX bs=1024 seek=8 Spoiler root@LicheePi(addr:192.168.6.130):/boot# ls -l total 4320 drwxr-xr-x 2 root root 2048 Apr 27 19:13 System Volume Information drwxr-xr-x 2 root root 2048 Apr 28 23:14 backup -rwxr-xr-x 1 root root 287 Apr 27 22:29 boot.scr -rwxr-xr-x 1 root root 8238 Apr 28 19:20 sun8i-v3s-licheepi-zero.dtb -rwxr-xr-x 1 root root 409391 Apr 28 20:44 u-boot-sunxi-with-spl-vga.bin -rwxr-xr-x 1 root root 3997192 Apr 28 19:21 zImage inside you archive was a 400K file named u-boot-sunxi-with-spl-vga.bin but ethernet did work with the old u-boot from mindb which I flashed initially to my microsd. Is it a safe way to flash it from another linux sbc with dd if=u-boot-sunxi-with-spl-vga.bin of=/dev/sdb bs=1024 seek=8 or should I leave the old u-boot because Iam not using vga at this time? 0 Quote Link to comment Share on other sites More sharing options...
TheLinuxBug Posted April 29, 2019 Share Posted April 29, 2019 10 hours ago, guidol said: it seems that I missed to "flash" the new u-boot I did copy it only to /boot, but I did read it has to be flaseh with a 8K offset to the microsd like: dd if=u-boot-sunxi-with-spl.bin of=/dev/ sdX bs=1024 seek=8 Reveal hidden contents root@LicheePi(addr:192.168.6.130):/boot# ls -l total 4320 drwxr-xr-x 2 root root 2048 Apr 27 19:13 System Volume Information drwxr-xr-x 2 root root 2048 Apr 28 23:14 backup -rwxr-xr-x 1 root root 287 Apr 27 22:29 boot.scr -rwxr-xr-x 1 root root 8238 Apr 28 19:20 sun8i-v3s-licheepi-zero.dtb -rwxr-xr-x 1 root root 409391 Apr 28 20:44 u-boot-sunxi-with-spl-vga.bin -rwxr-xr-x 1 root root 3997192 Apr 28 19:21 zImage inside you archive was a 400K file named u-boot-sunxi-with-spl-vga.bin but ethernet did work with the old u-boot from mindb which I flashed initially to my microsd. Is it a safe way to flash it from another linux sbc with dd if=u-boot-sunxi-with-spl-vga.bin of=/dev/sdb bs=1024 seek=8 or should I leave the old u-boot because Iam not using vga at this time? Yes, most of the devices are controlled by the DTB file, in fact, I compiled the 'staging' wifi driver and played around with enabling WIFi in the new DTB. I actually added the wrong DTB to that tar.gz after all was said and done, like you noticed, sorry about that. I was kinda rushed when I put that up. I did compile a few more kernels and was talking to some devs about trying to get some help with getting devices enabled correctly in the DTB. I actually have a DTB that works for enabling vga framebuffer, ethernet and wifi however ends up breaking USB (assuming your powering through pins, you can actually connect a USB device) and the staging driver in 4.12.y is trash and the kernel panics when you inset the WiFi driver. Glad to hear you found a working dtb for your needs, supposedly there were a few in the packages as you noticed with different things enabled. As I get time I will probably compile a few more kernels and work on the DTB and will post back here if I come up with something better. Though glad to hear what I provided gave you a good start! Cheers! 1 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 30, 2019 Share Posted April 30, 2019 On 4/29/2019 at 9:01 AM, TheLinuxBug said: As I get time I will probably compile a few more kernels and work on the DTB and will post back here if I come up with something better. Though glad to hear what I provided gave you a good start! Hi @TheLinuxBug today I did try to add the soundcard "analog-codec" to the .dtb you gave me for the ethernet-port. Ethernet-port code is: Spoiler ethernet@1c30000 { compatible = "allwinner,sun8i-h3-emac"; syscon = <0xb>; reg = <0x1c30000 0x104>; interrupts = <0x0 0x52 0x4>; interrupt-names = "macirq"; resets = <0x2 0xc>; reset-names = "stmmaceth"; clocks = <0x2 0x1a>; clock-names = "stmmaceth"; #address-cells = <0x1>; #size-cells = <0x0>; status = "okay"; phy-handle = <0xc>; phy-mode = "mii"; allwinner,leds-active-low; mdio { #address-cells = <0x1>; #size-cells = <0x0>; ethernet-phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x1>; clocks = <0x2 0x2b>; resets = <0x2 0x27>; linux,phandle = <0xc>; phandle = <0xc>; }; }; }; and the soundcard (codec-analog) is: Spoiler codec@01c22c00 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-v3s-codec"; reg = <0x1c22c00 0x400>; interrupts = <0x0 0x1d 0x4>; clocks = <0x2 0x24 0x2 0x46>; clock-names = "apb", "codec"; resets = <0x2 0x28>; dmas = <0xb 0xf 0xb 0xf>; dma-names = "rx", "tx"; allwinner,codec-analog-controls = <0xc>; status = "okay"; allwinner,audio-routing = "Headphone", "HP", "Headphone", "HPCOM", "MIC1$ }; codec-analog@01c23000 { compatible = "allwinner,sun8i-v3s-codec-analog"; reg = <0x1c23000 0x4>; linux,phandle = <0xc>; phandle = <0xc>; }; I did insert the soundcard data to the ethernet-.dtb , but it doenst could be compiled (also when i try to use another phandle for the soundcard). So 0xc seems to be used for ethernet and soundcard I do get the following "syntax-error" (error? I did copy & paste the parts): root@LicheePi(addr:192.168.6.130):/home/guido# dtc -I dts -O dtb ./sun8i-v3s-licheepi-zero_eth0_analog.dts -o ./sun8i-v3s-licheepi-zero_eth0_analog.dtb Error: ./sun8i-v3s-licheepi-zero_eth0_analog.dts:255.39-40 syntax error FATAL ERROR: Unable to parse input tree and Line 255 points to : compatible = "allwinner,sun8i-v3s-codec-analog"; from the part codec-analog@01c23000 { Iam not firm in decode this error in the .dts - but I couldnt find any wrong written word (=syntax-error) nor a double name, handle or address. Maybe you got an idea when do will compile new dtbs or kernel.@Igor short question: when I try to edit a entry in the forum I couldnt use spoiler/code-tags after the first save. on the second edit these tags are gone in the editor. Is this as you wish or is there a problem for my user or for all? Got this problem spotted for 1-2 weeks.. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted April 30, 2019 Share Posted April 30, 2019 4 minutes ago, guidol said: short question: when I try to edit a entry in the forum I couldnt use spoiler/code-tags after the first save. on the second edit these tags are gone in the editor. Is this as you wish or is there a problem for my user or for all? Got this problem spotted for 1-2 weeks.. There is a major forum upgrade + 2 bug fix upgrade waiting. I hope some of those troubles will be gone after that. I already started with theme adjustments and testing, but due to family duties I am grounded for few days Switch to updated version perhaps in upcoming weekend. 1 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted April 30, 2019 Share Posted April 30, 2019 54 minutes ago, guidol said: So 0xc seems to be used for ethernet and soundcard phandles are kind of slot number for the node, it can't be used twice, if slot is already occupied. When adding a new node manually to a decompiled DT, you need to assign a phandle which doesn't already exist, looking at the highest phandle and choosing something higher, not necessarly consecutive, maybe something like 0x99 ... 0 Quote Link to comment Share on other sites More sharing options...
TheLinuxBug Posted April 30, 2019 Share Posted April 30, 2019 57 minutes ago, guidol said: Hi @TheLinuxBug today I did try to add the soundcard "analog-codec" to the .dtb you gave me for the ethernet-port. Ethernet-port code is: Reveal hidden contents ethernet@1c30000 { compatible = "allwinner,sun8i-h3-emac"; syscon = <0xb>; reg = <0x1c30000 0x104>; interrupts = <0x0 0x52 0x4>; interrupt-names = "macirq"; resets = <0x2 0xc>; reset-names = "stmmaceth"; clocks = <0x2 0x1a>; clock-names = "stmmaceth"; #address-cells = <0x1>; #size-cells = <0x0>; status = "okay"; phy-handle = <0xc>; phy-mode = "mii"; allwinner,leds-active-low; mdio { #address-cells = <0x1>; #size-cells = <0x0>; ethernet-phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x1>; clocks = <0x2 0x2b>; resets = <0x2 0x27>; linux,phandle = <0xc>; phandle = <0xc>; }; }; }; and the soundcard (codec-analog) is: Reveal hidden contents codec@01c22c00 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-v3s-codec"; reg = <0x1c22c00 0x400>; interrupts = <0x0 0x1d 0x4>; clocks = <0x2 0x24 0x2 0x46>; clock-names = "apb", "codec"; resets = <0x2 0x28>; dmas = <0xb 0xf 0xb 0xf>; dma-names = "rx", "tx"; allwinner,codec-analog-controls = <0xc>; status = "okay"; allwinner,audio-routing = "Headphone", "HP", "Headphone", "HPCOM", "MIC1$ }; codec-analog@01c23000 { compatible = "allwinner,sun8i-v3s-codec-analog"; reg = <0x1c23000 0x4>; linux,phandle = <0xc>; phandle = <0xc>; }; I did insert the soundcard data to the ethernet-.dtb , but it doenst could be compiled (also when i try to use another phandle for the soundcard). So 0xc seems to be used for ethernet and soundcard I do get the following "syntax-error" (error? I did copy & paste the parts): root@LicheePi(addr:192.168.6.130):/home/guido# dtc -I dts -O dtb ./sun8i-v3s-licheepi-zero_eth0_analog.dts -o ./sun8i-v3s-licheepi-zero_eth0_analog.dtb Error: ./sun8i-v3s-licheepi-zero_eth0_analog.dts:255.39-40 syntax error FATAL ERROR: Unable to parse input tree and Line 255 points to : compatible = "allwinner,sun8i-v3s-codec-analog"; from the part codec-analog@01c23000 { Iam not firm in decode this error in the .dts - but I couldnt find any wrong written word (=syntax-error) nor a double name, handle or address. Maybe you got an idea when do will compile new dtbs or kernel. Before I got a headache and quit the other night I was dealing with a similar issue. It looks like in the DTBs I was reviewing that the analog codec seems to want to use similar pins as the ethernet adapter. I am not well versed enough in how the DTB is to be formatted and how to map this differently as needed. I had one DTB hacked together which seemed to provide most things except USB and analog audio, but not confident enough in it to really give it out till I know its right. My hope is next time I get a chance to bug a few devs I know and get it working as expected. When I get there, I will share that with you as well. RE: @martinayotte this is actually the info I was looking for, thanks for that! At least got me pointed in the right direction of what to look at. @guidol if you want to mess with it your self, what @martinayotte said should get you started. Cheers! 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 30, 2019 Share Posted April 30, 2019 8 minutes ago, TheLinuxBug said: RE: @martinayotte this is actually the info I was looking for, thanks for that! At least got me pointed in the right direction of what to look at. @guidol if you want to mess with it your self, what @martinayotte said should get you started. I did already test to replace 0xc with something like 0xa1 - but this does not solve the "sytax error) As @TheLinuxBug did wrote there seem to be some other setting double. I didnt found any editor or guide for me at this time 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted April 30, 2019 Share Posted April 30, 2019 16 minutes ago, TheLinuxBug said: allwinner,audio-routing = "Headphone", "HP", "Headphone", "HPCOM", "MIC1$ The compile error is probably because the missing quote and semicolon at the end of this line ... 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 30, 2019 Share Posted April 30, 2019 16 hours ago, martinayotte said: The compile error is probably because the missing quote and semicolon at the end of this line ... You got a "Eagle-Eye" - but its even more worse.... the $ at the end of the line is from the nano-editor and the line is even longer: not only allwinner,audio-routing = "Headphone", "HP", "Headphone", "HPCOM", "MIC1" BUT allwinner,audio-routing = "Headphone", "HP", "Headphone", "HPCOM", "MIC1", "Mic", "Mic", "HBIAS"; Mind the ; OK - the sun8i-v3s-licheepi-zero_eth0_analog.dts is now compiled as .dtb.. (named in / boot as sun8i-v3s-licheepi-zero.dtb) Ethernet is working like before but it seems now Iam missing the audio-driver/module @TheLinuxBug maybe this link would help us more? Add support for the audio codec on Allwinner V3s:https://lwn.net/Articles/723647/ root@LicheePi(addr:192.168.6.130):~# aplay -l aplay: device_list:268: no soundcards found... [EDIT] I also did try to add the DMA-controller, but I doent know if I had to insert the new phandle 0xa8 to the DMA-lines of the codec-analog, because there is also 2x 0xb whcih is the old phandle. [EDIT 2nd] I deleted here the non-working .DTS/.DTBs 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted April 30, 2019 Share Posted April 30, 2019 54 minutes ago, guidol said: but I doent know if I had to insert the new phandle 0xa8 to the DMA-lines of the codec-analog, because there is also 2x 0xb whcih is the old phandle. Right, they must be changed to 0xa8 ... BTW, since the patch you mentioned is coming from Icenowy, you can dig her github, she got several v3s branches : https://github.com/Icenowy/linux/tree/v3s-codec-v1 https://github.com/Icenowy/linux/commit/716da86219368781107a5c4fcf205b7973d3dba5 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 30, 2019 Share Posted April 30, 2019 I did a test-compile on my Virtual-Box Lichee 4.13 build-system. The LicheePi does boot the zImage but I havent here also no sound, but the Ethernet [EDIT] after getting the .dtb in the right shape sound & ethernet does work Backup of zImage/Kernel 4.13 for you & me saved on my GoogleDrive:https://drive.google.com/open?id=1X7y0XIC8TAj3R7Ag4iUu1f4rT77RdzPL 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 30, 2019 Share Posted April 30, 2019 4 minutes ago, martinayotte said: Right, they must be changed to 0xa8 ... from dmas = <0xb 0xf 0xb 0xf>; to dmas = <0xa8 0xf 0xa8 0xf>; ? or has the 0xf also be changed to something else? 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted April 30, 2019 Share Posted April 30, 2019 3 minutes ago, guidol said: or has the 0xf also be changed to something else? No ! 0xf is the interrupt number 15. I've edit my above post which shows the original sources from icenowy's github : the line "dmas = <&dma 15>, <&dma 15>;" would then be translated into "dmas = <0xa8 0xf 0xa8 0xf>;" BTW, why not trying to take icenowy's patches and place them in Armbian build, you will end up with a working lichee kernel 5.0.y ... 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 30, 2019 Share Posted April 30, 2019 15 hours ago, martinayotte said: No ! 0xf is the interrupt number 15. BTW, why not trying to take icenowy's patches and place them in Armbian build, you will end up with a working lichee kernel 5.0.y ... Sorry I got no idea which is a phandle there and which is ther an interrupt. AND Iam a VERY VERY beginner in self-compiling. Using the armbian-build-system menue is - for me - not really compiling As now I dont use any patches or know how to place them.... [EDIT] BUT YES! after editing the DMA-lines also to 0xa8 see what I do get: root@LicheePi(addr:192.168.6.130):~# aplay -l **** List of PLAYBACK Hardware Devices ****card 0: Codec [V3s Audio Codec], device 0: CDC PCM Codec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 lsmod (for soundcard): sun8i_codec_analog 28672 1 snd_soc_simple_card 20480 0 sun8i_adda_pr_regmap 16384 1 sun8i_codec_analog snd_soc_simple_card_utils 16384 1 snd_soc_simple_card sun4i_codec 49152 3 snd_soc_core 126976 5 sun4i_i2s,sun8i_codec_analog,sun4i_codec,snd_soc_simple_card_utils,snd_soc_simple_card snd_pcm_dmaengine 16384 1 snd_soc_core snd_pcm 94208 4 sun4i_i2s,sun4i_codec,snd_soc_core,snd_pcm_dmaengine snd_timer 32768 1 snd_pcm snd 57344 3 snd_timer,snd_soc_core,snd_pcm soundcore 16384 1 snd @TheLinuxBug Also NEW DMA-version .dts and .dtb here for all other Backup of the .dts/.dtb with working Ethernet/Audio/LEDs also on GoogleDrive:https://drive.google.com/open?id=1X7y0XIC8TAj3R7Ag4iUu1f4rT77RdzPL sun8i-v3s-licheepi-zero_eth0_analog_dma.dtb sun8i-v3s-licheepi-zero_eth0_analog_dma.dts 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted April 30, 2019 Share Posted April 30, 2019 2 minutes ago, guidol said: Sorry I got no idea which is a phandle there and which is ther an interrupt. No problem, as I said the resulting "dmas = <0xa8 0xf 0xa8 0xf>;" is good ! 5 minutes ago, guidol said: As now I dont use any patches or know how to place them.... No worries ! But that would be a good opportunity and challenge ... 1 Quote Link to comment Share on other sites More sharing options...
guidol Posted April 30, 2019 Share Posted April 30, 2019 16 hours ago, martinayotte said: No problem, as I said the resulting "dmas = <0xa8 0xf 0xa8 0xf>;" is good ! No worries ! But that would be a good opportunity and challenge ... Hmmm.... I edited a /etc/asound.conf and can use alsamixer but I couldnt get sound on the connected headphone or a amplified speaker !WAIT! all back - I hadnt said/wrote that I was in the wrong terminal window.... (my NanoPi Neo2 NAS) Its alive!! and do play Internetradio via mpg123 mpg123 -@ /home/guido/hr1_2.m3u hr1_2.m3u 0 Quote Link to comment Share on other sites More sharing options...
chwe Posted April 30, 2019 Share Posted April 30, 2019 45 minutes ago, guidol said: Using the armbian-build-system menue is - for me - not really compiling As now I dont use any patches or know how to place them.... it is, the difference is.. You don't have to think about outdated compilers on your base system.. There was a time when I compiled a few u-boot/ kernels without the buildscript for the BPi R2 (during the time.. this thing actually produced more headache than output) wasn't 5.0 back then.. but well.. it's been a while since.. 53 minutes ago, guidol said: know how to place them.... that's a starter for the manual patching (and a few follow up posts): otherwise for those being lazy.. you can download patches from github (in fact every commit).. Just add '.patch' to the commit in the link... e.g.: https://github.com/Icenowy/linux/commit/716da86219368781107a5c4fcf205b7973d3dba5.patch then keep in mind that our kernel/u-boot sources are git repositories as well so you can just git apply blablabla.patch (sometimes force - doing this during build with create patch = yes) and then fix the rejections and armbian will take care that a new patch is created after its which is hopefully without any rejections at all. In case it doesn't have any rejections from the beginning, just place it in the right patchfolder and you don't even have to care... 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted May 5, 2019 Share Posted May 5, 2019 On 4/28/2019 at 12:52 PM, TheLinuxBug said: I am going to test building 4.14.y and 4.13.y branch to see if the WiFi driver is incorporated at any point, the github repos are not very specific about whats been updated and my attempts to build the driver seperately have so far failed for the 4.12.y repo I used to generate this. Today I did clone and compile kernel 4.14 from:https://github.com/Lichee-Pi/linux/tree/zero-4.14.y with their standard setttings (.config) The resulting zImage ( 4.14.14-licheepi-zero+ ) does also work with Ethernet / Audio-Codec and the Tripple-Status-LED I did put the 4.14.y zImage as zImage_Kernel_414.zip on my GoogleDrive (see above for the link) I do like the small 23MB footprint of this small Linux (would like to see such Linux on a Router which normally do use OpenWRT - many of them have 128MB RAM, but less Mhz) 1 Quote Link to comment Share on other sites More sharing options...
markbirss Posted May 5, 2019 Share Posted May 5, 2019 @guidol are there any modules in /lib/modules/'uname -r' folder ? 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted May 5, 2019 Share Posted May 5, 2019 13 hours ago, markbirss said: @guidol are there any modules in /lib/modules/'uname -r' folder ? I - personally - see the following modules: root@LicheePi(192.168.6.130):/# find / -name *.ko /root/ns2009.ko /root/r8723bs.ko /lib/modules/4.10.2-licheepi-zero+/kernel/crypto/echainiv.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/input/touchscreen/ns2009.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/staging/rtl8188eu/r8188eu.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/video/backlight/lcd.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/net/wireless/esp8089.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/net/wireless/realtek/rtlwifi/rtl_usb.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/net/wireless/realtek/rtlwifi/rtl8192c/rtl8192c-common.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/net/wireless/realtek/rtlwifi/rtlwifi.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/net/wireless/realtek/rtlwifi/rtl8192cu/rtl8192cu.ko /lib/modules/4.10.2-licheepi-zero+/kernel/drivers/net/wireless/mediatek/mt7601u/mt7601u.ko I did compile with these instructions ( the cloning was a 2GB Download ): Kernel 4.14.y git clone https://github.com/Lichee-Pi/linux.git -b zero-4.14.y zero414 cd zero414 make ARCH=arm licheepi_zero_defconfig make ARCH=arm menuconfig #add bluethooth, etc. make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j16 make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j16 INSTALL_MOD_PATH=out modules make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j16 INSTALL_MOD_PATH=out modules_install Output of the modules-install-command: root@licheebuild:/home/guido/zero414# make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j16 INSTALL_MOD_PATH=out modules_install INSTALL crypto/echainiv.ko INSTALL drivers/video/backlight/lcd.ko INSTALL drivers/staging/rtl8723bs/r8723bs.ko DEPMOD 4.14.14-licheepi-zero+ 0 Quote Link to comment Share on other sites More sharing options...
markbirss Posted May 5, 2019 Share Posted May 5, 2019 @guidol check in your 'out' folder if any modules were built, you also need to copy them to your Lichee Pi INSTALL crypto/echainiv.ko INSTALL drivers/video/backlight/lcd.ko INSTALL drivers/staging/rtl8723bs/r8723bs.ko 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted May 9, 2019 Share Posted May 9, 2019 It took me some time today, but I updated the jessie image (mindb_dd.tar.gz + kernel 4.14 + new .dtb ) to stretch the normal way Editing the /etc/sources.list (in the process of updateing) was more a replacement from deb http://archive.debian.org/debian/ jessie main contrib non-free deb-src http://archive.debian.org/debian/ jessie main contrib non-free deb http://security.debian.org jessie/updates main contrib non-free deb-src http://security.debian.org jessie/updates main contrib non-free to deb http://ftp.de.debian.org/debian/ stretch main contrib non-free deb-src http://ftp.de.debian.org/debian/ stretch main contrib non-free deb http://security.debian.org/ stretch/updates main contrib non-free deb-src http://security.debian.org/ stretch/updates main contrib non-free but I do had a problem with apt at the second time Reading package lists... is in speed OK BUT Building dependency tree take serveral Minutes and is really SLOW I did try apt-get autoclean apt-get autoremove AND apt-get clean to speedup the process.....but it doesnt get really better [EDIT] I did found a old jessie-multi-list in the directory /etc/apt/sources.list.d ! because I did wonder why I do see jessie-entrys in my apt-get update when the sources.list only contains stretch entries. After removing the jessie-multi-list in the additional directory I give again a apt-get clean and then apt-get install debian-keyring apt-get install debian-archive-keyring apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8B48AD6246925553 apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9D6D8F6BC857C906 apt-get update and now its MUCH faster (like before with only jessie entries for jessie) AND only around 19MB memory-footprint with stretch 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted May 10, 2019 Share Posted May 10, 2019 @TheLinuxBug at your page for compiling the u-boot you have at the end of the page https://licheepizero.us/build--uboot-for-licheepi-zero the text: After success compilation, u-boot-sunxi-with-spl.bin will be generated, you can write it with 8K offset to boot. for reference I do found the follwing page/command for doing this http://linux-sunxi.org/Bootable_SD_card#Bootloader dd if=u-boot-sunxi-with-spl.bin of=${card} bs=1024 seek=8 at the SD-Card layout part you could also see the 8k offset for the spl/u-boot:http://linux-sunxi.org/Bootable_SD_card#SD_Card_Layout Quote A default U-Boot build for an Allwinner based board uses the following layout on (micro-)SD cards or eMMC storage (from v2018.05 or newer) 0 Quote Link to comment Share on other sites More sharing options...
Meisam Posted May 18, 2019 Share Posted May 18, 2019 With much thanks to the above references , i have 2 major problem with the 4.14 version , first I can not enable SPI bus through dts file and the second one is when i add simple panel to the dts file to have LCD , the boot operation hungs up do you have any idea to solve these problems ? 0 Quote Link to comment Share on other sites More sharing options...
sfx2000 Posted May 29, 2019 Share Posted May 29, 2019 On 5/9/2019 at 9:30 AM, guidol said: only around 19MB memory-footprint with stretch Nice 0 Quote Link to comment Share on other sites More sharing options...
