I am using friendlycore bionic on a NanoPiM4 and trying to play some videos but they are not playing smoothly. And there are some warnings, please take a look:
X.Org X Server 1.19.3
Release Date: 2017-03-15
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.162-rk3399 aarch64 Ubuntu
Current Operating System: Linux NanoPi-M4 4.4.154 #1 SMP Thu Mar 7 18:30:53 CST 2019 aarch64
Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 rw root=PARTUUID=614e0000-0000 rootfstype=ext4 rootwait root=/dev/mmcblk1p7 rw rootfstype=ext4 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00006000@0x00008000(resource),0x00010000@0x0000e000(kernel),0x00010000@0x0001e000(boot),-@0x00030000(rootfs) consoleblank=0 storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-08-01_14:55:50 SecureBootCheckOk=0 androidboot.mode=emmc
Build Date: 17 December 2018  12:58:34PM
xorg-server 2:1.19.3-1 (https://www.debian.org/support)
Current version of pixman: 0.34.0
    Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.11.log", Time: Thu Mar 28 11:31:25 2019
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
XmbTextListToTextProperty result code -2
Empty filename passed to function
mpi: mpp version: 0b701fe author: Lawrence-Tang DEBIAN: prepare for release_20171218-3
mpp_rt: NOT found ion allocator
mpp_rt: found drm allocator
QWidget::paintEngine: Should no longer be called
mpp_buffer: mpp_buffer_group_set_listener found NULL pointer
mpp: command 310002 param (nil) ret -3
Warning: "A lot of buffers are being dropped."
If you have any idea about all errors/warnings (buffer being dropped mainly), please let me know.
1 hour ago, cassiov said:
Sorry, I can only help you if you use Armbian, I don't have enough knowledge about the other OS's.
@JMCC : I finally managed to get KODI GBM working on my ROCK960C (bionic ARM64) with HDMI CEC and HDMI audio passthrough features... experience is close to LibreELEC one BUT whenever i want to switch to an X11 session from it, i can... that is what i wanted.
Thanks for your help ! :thumbup:
Use FriendlyDesktop instead. That has everything installed for playing videos default. Friendlycore is not for desktop use.
18.2 2018-12-19
FriendlyDesktop is updated as follows:
1) Added OV13850 and wide dynamic OV4689 camera support
2) Add Chrome-browser browser, support web page 1080P hardware decoding, support WebGL
3) Added ffmpeg support, provides static libraries and header files, supports 4K hardware decoding (does not support hardware encoding)
So at the moment I have Armbian_5.75_Nanopim4_Ubuntu_bionic_default_4.4.174_desktop installed on my NanoPiM4.  and here you can find the logs:
Playing  4K 10bits H265 with qt player:
tarting /home/cassiovolcan/qt5_cassio_examples/build-player-Desktop-Debug/player...
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Stream with high frequencies VQ coding
H265D_PARSER: mpp_hevc_decode_nal_sei error ret = -1006
H265_PARSER_REF: Could not find ref with POC -41
H265_PARSER_REF: Could not find ref with POC -43
H265_PARSER_REF: Could not find ref with POC -46
H265_PARSER_REF: Could not find ref with POC -48
H265_PARSER_REF: Could not find ref with POC -52
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
** (player:9533): CRITICAL **: 14:11:01.788: gst_x_image_sink_xwindow_clear: assertion 'xwindow != NULL' failed
Starting /home/cassiovolcan/qt5_cassio_examples/build-player-Desktop-Debug/player...
QXcbConnection: XCB error: 3 (BadWindow), sequence: 1426, resource id: 10554719, major code: 40 (TranslateCoords), minor code: 0
By executing a qt browser:
In addiction, chromium browser log playing 4k videos (really slow and crash the system)
cassiovolcan@nanopim4:~$ chromium-browser
[11856:11856:0329/150154.201175:ERROR:sandbox_linux.cc(364)] InitializeSandbox() called with multiple threads in process gpu-process.
[11815:11848:0329/150154.208135:ERROR:database.cc(1808)] Passwords sqlite error 14, errno -2: unable to open database file, sql: -- sqlite3_open()
[11815:11848:0329/150154.208382:ERROR:login_database.cc(601)] Unable to open the password store database.
[11815:11848:0329/150154.208431:ERROR:password_store_default.cc(42)] Could not create/open login database.
[11856:11856:0329/150154.611025:ERROR:gles2_cmd_decoder.cc(2774)] [GroupMarkerNotSet(crbug.com/242999)!:E82CF3A855000000]GL ERROR :GL_INVALID_FRAMEBUFFER_OPE$
[11815:11981:0329/150202.283912:ERROR:object_proxy.cc(621)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower:$
[11815:11981:0329/150202.284441:ERROR:object_proxy.cc(621)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPo$
[11815:11981:0329/150202.285023:ERROR:object_proxy.cc(621)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPo$
[11815:11870:0329/150204.699759:ERROR:object_proxy.cc(621)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedes$
[11815:11870:0329/150204.700163:ERROR:power_save_blocker_x11.cc(330)] No response to Inhibit() request!
[11815:11870:0329/150204.722484:ERROR:object_proxy.cc(621)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenS$
[11815:11870:0329/150204.722775:ERROR:power_save_blocker_x11.cc(330)] No response to Inhibit() request!
In advance, very thanks.
With this setup, Chromium will play up to 1080p, probably some 1440p, but definitely not 4k (2160p).
What is the command line you are using to launch the player? I assume you are using command line and not the desktop launcher, since I see logs.
Have you tried to play that same video with MPV-GBM or Kodi?
any idea how to make it?
/usr/lib/aarch64-linux-gnu/qt5/examples/multimediawidgets/player/player --geometry 960x640+0+0
yes, mpv seems that is not using hardware accel.  since the video simply goes really slow and consumes a lot of cpu.
In the other hand, kobi plays very, very well... even better than in my pc over VLC.
Probably with Wayland, but I am not aware of anyone who has made that work yet. You have another option: use a Kodi YouTube addon, or use MPV-GBM like this:
sudo apt install youtube-dl
mpv-gbm "http://youtube.com/etc..."
Of course, you only need to install youtube-dl the first time.
Are you sure you are using MPV-GBM, and not the regular MPV? You must right-click on the video file and select "MPV (GBM)", or type "mpv-gbm <filename>" from the command line.
That is not using HW acceleration. You need to use the "Rockchip Gst Player" launcher, or type the same command line used in the "Rockchip Gst Player" desktop launcher (I can't remember it now, just open the .desktop file and copy it).
Hello, I'm testing with a fresh armbian bionic install on rockpi4b  (flashing bionic , then running `sudo apt upgrade`)
During install script I select only 'System', 'Devel', and 'GL4ES'.  Installation succeeds and I reboot. I then try running both `glxinfo` and `glxgears` from mesa-utils.  glxgears reports "libGL error: failed to load driver: rockchip" and falls back to llvmpipe renderer.
Attempting to run LD_LIBRARY_PATH set yields and error":
$ LD_LIBRARY_PATH=/opt/gl4es/ glxgears
LIBGL: Initialising gl4es
ERROR: The DDK is not compatible with any of the Mali GPUs on the system.
The DDK was build for 0x860 r2p0 status range [0..15], but none of the GPUs matched:
Any suggestions on working around this?
Edited by tumbleweed2019
better link to image
@tumbleweed2019 did you try the included "glrun" wrapper, as described in the documentation?
On 1/10/2019 at 2:38 PM, JMCC said:
- GL4ES: An Opengl-ES wrapper library that will allow you to use OpenGL 1.5-2.0 compatible programs with hardware acceleration. More info: https://github.com/ptitSeb/gl4es. · In order to make it easier to use the library, we have included a script called "glrun", that will set the proper environment variables. Launch your OpenGL program like this:
"glrun <command>"
Is there any chance of an update for this kit? An additional kit for Buster would also be most welcome, if possible.
I'd like to, and I started working on a script that would compile the latest versions of the software for a specific distro. Let's see if I can find some time to finish it.
I was just filming a video about (your) @JMCC's RK3399 Media Script.
I`m using the RockPi4B for it, but chromium GPU acc doesn't seem to be working. The Rockchip video player does work.
Here's the gpu info of chromium
Graphics Feature Status
Canvas: Software only, hardware acceleration unavailable
Flash: Software only. Hardware acceleration disabled
Flash Stage3D: Software only. Hardware acceleration disabled
Flash Stage3D Baseline profile: Software only. Hardware acceleration disabled
Compositing: Software only. Hardware acceleration disabled
Multiple Raster Threads: Force enabled
Out-of-process Rasterization: Disabled
Hardware Protected Video Decode: Disabled
Rasterization: Software only. Hardware acceleration disabled
Skia Renderer: Disabled
Video Decode: Software only. Hardware acceleration disabled
Viz Display Compositor: Enabled
Viz Hit-test Surface Layer: Disabled
WebGL: Software only, hardware acceleration unavailable
WebGL2: Software only, hardware acceleration unavailable
Version Information
Data exported2019-10-29T13:59:04.975Z
Chrome versionChrome/77.0.3865.90
Operating systemLinux 4.4.192-rockchip64
Software rendering list URLhttps://chromium.googlesource.com/chromium/src/+/58c425ba843df2918d9d4b409331972646c393dd/gpu/config/software_rendering_list.json
Driver bug list URLhttps://chromium.googlesource.com/chromium/src/+/58c425ba843df2918d9d4b409331972646c393dd/gpu/config/gpu_driver_bug_list.json
ANGLE commit idunknown hash
2D graphics backendSkia/77 a10014304cba4f24b7af17191f59490faa8aee77
Command Line/usr/lib/chromium-browser/chromium-browser --disable-low-res-tiling --num-raster-threads=6 --profiler-timing=0 --disable-composited-antialiasing --disk-cache-dir=/tmp/nicod-cache --disk-cache-size=609701069 --no-sandbox --test-type --show-component-extension-options --ignore-gpu-blacklist --use-gl=egl --enable-pinch --flag-switches-begin --flag-switches-end
Driver Information
Initialization time143
In-process GPUfalse
Passthrough Command Decoderfalse
Sandboxedfalse
GPU0VENDOR = 0x0000 [Google Inc.], DEVICE= 0x0000 [Google SwiftShader] *ACTIVE*
Optimusfalse
AMD switchablefalse
Driver vendor
Driver version4.1.0.7
Driver date
GPU CUDA compute capability major version0
Pixel shader version3.00
Vertex shader version3.00
Max. MSAA samples4
Machine model name
Machine model version
GL_VENDORGoogle Inc.
GL_RENDERERGoogle SwiftShader
GL_VERSIONOpenGL ES 3.0 SwiftShader 4.1.0.7
GL_EXTENSIONSGL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_framebuffer_object GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_texture_3D GL_OES_vertex_array_object GL_OES_vertex_half_float GL_EXT_blend_minmax GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_draw_buffers GL_EXT_float_blend GL_EXT_instanced_arrays GL_EXT_occlusion_query_boolean GL_EXT_read_format_bgra GL_EXT_texture_compression_dxt1 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_rg GL_ARB_texture_rectangle GL_ANGLE_framebuffer_blit GL_ANGLE_framebuffer_multisample GL_ANGLE_instanced_arrays GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_texture_format_BGRA8888 GL_CHROMIUM_color_buffer_float_rgba GL_CHROMIUM_texture_filtering_hint GL_NV_depth_buffer_float2 GL_NV_fence GL_NV_framebuffer_blit GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil
Disabled Extensions
Disabled WebGL Extensions
Window system binding vendorGoogle Inc.
Window system binding version1.4 SwiftShader 4.1.0.7
Window system binding extensionsEGL_KHR_create_context EGL_KHR_get_all_proc_addresses EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_KHR_image_base EGL_KHR_surfaceless_context EGL_ANGLE_iosurface_client_buffer EGL_ANDROID_framebuffer_target EGL_ANDROID_recordable
Window managerXfwm4
XDG_CURRENT_DESKTOPXFCE
GDMSESSIONxfce
Compositing managerNo
Direct rendering versionunknown
Reset notification strategy0x0000
GPU process crash count1
System visual ID0
RGBA visual ID0
gfx::BufferFormats supported for allocation and texturingR_8: not supported, R_16: not supported, RG_88: not supported, BGR_565: not supported, RGBA_4444: not supported, RGBX_8888: not supported, RGBA_8888: not supported, BGRX_8888: not supported, BGRX_1010102: not supported, RGBX_1010102: not supported, BGRA_8888: not supported, RGBA_F16: not supported, YVU_420: not supported, YUV_420_BIPLANAR: not supported, UYVY_422: not supported, P010: not supported
Compositor Information
Tile Update ModeOne-copy
Partial RasterEnabled
GpuMemoryBuffers Status
R_8Software only
R_16Software only
RG_88Software only
BGR_565Software only
RGBA_4444Software only
RGBX_8888Software only
RGBA_8888Software only
BGRX_8888Software only
BGRX_1010102Software only
RGBX_1010102Software only
BGRA_8888Software only
RGBA_F16Software only
YVU_420Software only
YUV_420_BIPLANARSoftware only
UYVY_422Software only
P010Software only
Display(s) Information
InfoDisplay[22697502238517315] bounds=[0,0 1920x1080], workarea=[0,31 1920x1008], scale=1, external.
Color space information{primaries:INVALID, transfer:INVALID, matrix:INVALID, range:INVALID}
SDR white level in nits80
Bits per color component8
Bits per pixel24
Refresh Rate in Hz60
Video Acceleration Information
Driver Information for Hardware GPU
In-process GPUfalse
Sandboxedfalse
Optimusfalse
AMD switchablefalse
Driver vendor
Driver date
Max. MSAA samples4
Machine model name
Disabled Extensions
Window managerXfwm4
GDMSESSIONxfce
System visual ID0
RGBA visual ID0
Graphics Feature Status for Hardware GPU
Log Messages
[2863:2863:1029/135850.891612:ERROR:gl_surface_egl.cc(1057)] : eglInitialize Default failed with error EGL_NOT_INITIALIZED
[2863:2863:1029/135850.892408:ERROR:gl_initializer_x11.cc(156)] : GLSurfaceEGL::InitializeOneOff failed.
GpuProcessHost: The GPU process exited with code 1024.
[2890:2890:1029/135851.665461:WARNING:ipc_message_attachment_set.cc(49)] : MessageAttachmentSet destroyed with unconsumed attachments: 0/1
Using Armbian Bionic 5.98 default.
I should have tested it first before filming the video. :)
I'll wait to do it in the M4V2 review video then. I wanted to make the video for RK3399 in general...
It works great on the M4. I woulnd't want to live without it anymore.
Any news on an update for it?
Cheers.
Edit. : Install Log
Hit:1 http://ports.ubuntu.com bionic InRelease
Hit:2 http://ports.ubuntu.com bionic-security InRelease
Hit:3 http://ports.ubuntu.com bionic-updates InRelease
Hit:4 http://ports.ubuntu.com bionic-backports InRelease
Hit:5 https://apt.armbian.com bionic InRelease
Reading package lists...
* Installing base packages and configuring system *
Installing base libs...
(Reading database ... 82058 files and directories currently installed.)
Preparing to unpack .../libmali-rk-midgard-t86x-gbm-r14p0-r0p0_1.6-1_arm64.deb ...
Unpacking libmali-rk-midgard-t86x-gbm-r14p0-r0p0:arm64 (1.6-1) over (1.6-1) ...
Preparing to unpack .../libmali-rk-midgard-t86x-r14p0-r0p0_1.6-1-0armbian1_arm64.deb ...
Unpacking libmali-rk-midgard-t86x-r14p0-r0p0:arm64 (1.6-1-0armbian1) over (1.6-1-0armbian1) ...
Preparing to unpack .../librockchip-mpp1_20171218-3_arm64.deb ...
Unpacking librockchip-mpp1 (20171218-3) over (20171218-3) ...
Preparing to unpack .../librockchip-vpu0_20171218-3_arm64.deb ...
Unpacking librockchip-vpu0 (20171218-3) over (20171218-3) ...
Preparing to unpack .../rockchip-mpp-demos_20171218-3_arm64.deb ...
Unpacking rockchip-mpp-demos (20171218-3) over (20171218-3) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Building dependency tree...
Reading state information...
The following packages were automatically installed and are no longer required:
  libavdevice57 libavfilter6 libavformat57 libavresample3 libmysofa0 libnorm1
  libpgm-5.2-0 libpostproc54 libsodium23 libssh-gcrypt-4 libswscale4
  libva-wayland2 libzmq5
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
5 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up librockchip-mpp1 (20171218-3) ...
Setting up libmali-rk-midgard-t86x-gbm-r14p0-r0p0:arm64 (1.6-1) ...
Setting up librockchip-vpu0 (20171218-3) ...
Setting up libmali-rk-midgard-t86x-r14p0-r0p0:arm64 (1.6-1-0armbian1) ...
Setting up rockchip-mpp-demos (20171218-3) ...
Configuring X server...
Preparing to unpack .../xserver-common-rockchip_1.19.3-2armbian1_all.deb ...
Unpacking xserver-common-rockchip (3:1.19.3-2armbian1) over (3:1.19.3-2armbian1) ...
Preparing to unpack .../xserver-xorg-core-rockchip_1.19.3-2armbian1_arm64.deb ...
Unpacking xserver-xorg-core-rockchip (3:1.19.3-2armbian1) over (3:1.19.3-2armbian1) ...
Preparing to unpack .../xserver-xorg-video-armsoc_1.4.1-1_arm64.deb ...
Unpacking xserver-xorg-video-armsoc (1.4.1-1) over (1.4.1-1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
3 not fully installed or removed.
Setting up xserver-common-rockchip (3:1.19.3-2armbian1) ...
Setting up xserver-xorg-core-rockchip (3:1.19.3-2armbian1) ...
Setting up xserver-xorg-video-armsoc (1.4.1-1) ...
Configuring Chromium acceleration...
*     Installing accelerated MPV media player     *
Preparing to unpack .../mpv-rockchip_2_2018.12.12.d6d6da4711-0bionic1_arm64.deb ...
Unpacking mpv-rockchip (2:2018.12.12.d6d6da4711-0bionic1) over (2:2018.12.12.d6d6da4711-0bionic1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
1 not fully installed or removed.
Setting up mpv-rockchip (2:2018.12.12.d6d6da4711-0bionic1) ...
*Installing Gstreamer backport, plugins and player*
libqt5multimedia5 is already the newest version (5.9.5-0ubuntu1).
libqt5multimedia5-plugins is already the newest version (5.9.5-0ubuntu1).
libqt5multimediaquick-p5 is already the newest version (5.9.5-0ubuntu1).
qtgstreamer-plugins-qt5 is already the newest version (1.2.0-5).
qtmultimedia5-doc-html is already the newest version (5.9.5-0ubuntu1).
qtmultimedia5-examples is already the newest version (5.9.5-0ubuntu1).
gstreamer1.0-plugins-base is already the newest version (1.14.5-0ubuntu1~18.04.1).
gstreamer1.0-plugins-base-apps is already the newest version (1.14.5-0ubuntu1~18.04.1).
gstreamer1.0-plugins-good is already the newest version (1.14.5-0ubuntu1~18.04.1).
libqt5core5a is already the newest version (5.9.5+dfsg-0ubuntu2.3).
libqt5gui5 is already the newest version (5.9.5+dfsg-0ubuntu2.3).
libqt5opengl5 is already the newest version (5.9.5+dfsg-0ubuntu2.3).
libqt5widgets5 is already the newest version (5.9.5+dfsg-0ubuntu2.3).
gstreamer1.0-plugins-bad is already the newest version (1.14.5-0ubuntu1~18.04.1).
gstreamer1.0-plugins-ugly is already the newest version (1.14.5-0ubuntu1~18.04.1).
libqt5qml5 is already the newest version (5.9.5-0ubuntu1.1).
libqt5quick5 is already the newest version (5.9.5-0ubuntu1.1).
qml-module-qtquick2 is already the newest version (5.9.5-0ubuntu1.1).
Preparing to unpack .../gstreamer1.0-rockchip1-extra_20181227-0armbian1_arm64.deb ...
Unpacking gstreamer1.0-rockchip1-extra (20181227-0armbian1) over (20181227-0armbian1) ...
Preparing to unpack .../gstreamer1.0-rockchip1_20181227-0armbian1_arm64.deb ...
Unpacking gstreamer1.0-rockchip1 (20181227-0armbian1) over (20181227-0armbian1) ...
2 not fully installed or removed.
Setting up gstreamer1.0-rockchip1-extra (20181227-0armbian1) ...
Setting up gstreamer1.0-rockchip1 (20181227-0armbian1) ...
*   Installing Chromium armhf with web streaming support    *
Installing Docker...
The following additional packages will be installed:
  containerd runc
Suggested packages:
  aufs-tools debootstrap docker-doc rinse zfs-fuse | zfsutils
Recommended packages:
  cgroupfs-mount | cgroup-lite pigz ubuntu-fan apparmor
The following NEW packages will be installed:
  containerd docker.io runc
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
Need to get 35.0 MB of archives.
After this operation, 201 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com bionic-security/universe arm64 runc arm64 1.0.0~rc7+git20190403.029124da-0ubuntu1~18.04.2 [1694 kB]
Get:2 http://ports.ubuntu.com bionic-security/universe arm64 containerd arm64 1.2.6-0ubuntu1~18.04.2 [13.6 MB]
Get:3 http://ports.ubuntu.com bionic-security/universe arm64 docker.io arm64 18.09.7-0ubuntu1~18.04.4 [19.7 MB]
Preconfiguring packages ...
Fetched 35.0 MB in 35s (995 kB/s)
Selecting previously unselected package runc.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 82058 files and directories currently installed.)
Preparing to unpack .../runc_1.0.0~rc7+git20190403.029124da-0ubuntu1~18.04.2_arm64.deb ...
Unpacking runc (1.0.0~rc7+git20190403.029124da-0ubuntu1~18.04.2) ...
Selecting previously unselected package containerd.
Preparing to unpack .../containerd_1.2.6-0ubuntu1~18.04.2_arm64.deb ...
Unpacking containerd (1.2.6-0ubuntu1~18.04.2) ...
Selecting previously unselected package docker.io.
Preparing to unpack .../docker.io_18.09.7-0ubuntu1~18.04.4_arm64.deb ...
Unpacking docker.io (18.09.7-0ubuntu1~18.04.4) ...
Setting up runc (1.0.0~rc7+git20190403.029124da-0ubuntu1~18.04.2) ...
Setting up containerd (1.2.6-0ubuntu1~18.04.2) ...
Created symlink /etc/systemd/system/multi-user.target.wants/containerd.service -> /lib/systemd/system/containerd.service.
Setting up docker.io (18.09.7-0ubuntu1~18.04.4) ...
Adding group `docker' (GID 122) ...
Done.
Created symlink /etc/systemd/system/sockets.target.wants/docker.socket -> /lib/systemd/system/docker.socket.
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
invoke-rc.d: initscript docker, action "start" failed.
* docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; disabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Tue 2019-10-29 13:50:50 UTC; 30ms ago
     Docs: https://docs.docker.com
  Process: 4521 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock [0;1;31m(code=exited, status=1/FAILURE)[0m
 Main PID: 4521 (code=exited, status=1/FAILURE)
Oct 29 13:50:50 rockpi systemd[1]: [0;1;39m[0;1;31m[0;1;39mdocker.service: Main process exited, code=exited, status=1/FAILURE[0m
Oct 29 13:50:50 rockpi systemd[1]: [0;1;39m[0;1;31m[0;1;39mdocker.service: Failed with result 'exit-code'.[0m
Oct 29 13:50:50 rockpi systemd[1]: [0;1;31m[0;1;39m[0;1;31mFailed to start Docker Application Container Engine.[0m
Processing triggers for systemd (237-3ubuntu10.31) ...
Creating container...
Sending build context to Docker daemon  22.68MB
Step 1/17 : FROM arm32v7/ubuntu
latest: Pulling from arm32v7/ubuntu
b3915b87c11a: Pulling fs layer
91c70bf447bd: Pulling fs layer
b0fb82918427: Pulling fs layer
272b3e2bb977: Pulling fs layer
272b3e2bb977: Waiting
91c70bf447bd: Verifying Checksum
91c70bf447bd: Download complete
b0fb82918427: Verifying Checksum
b0fb82918427: Download complete
272b3e2bb977: Download complete
b3915b87c11a: Retrying in 5 seconds
b3915b87c11a: Retrying in 4 seconds
b3915b87c11a: Retrying in 3 seconds
b3915b87c11a: Retrying in 2 seconds
b3915b87c11a: Retrying in 1 second
b3915b87c11a: Verifying Checksum
b3915b87c11a: Download complete
b3915b87c11a: Pull complete
91c70bf447bd: Pull complete
b0fb82918427: Pull complete
272b3e2bb977: Pull complete
Digest: sha256:d8893280cd15ee1e2e395f042273a823cd8ee95bad3d6f42eacb5b012ea1c66c
Status: Downloaded newer image for arm32v7/ubuntu:latest
 ---> 0db8e9f01d2d
Step 2/17 : MAINTAINER JMCC <JMCC@locahost>
 ---> Running in 984bc4d3d2a1
Removing intermediate container 984bc4d3d2a1
 ---> a6f30d88ce1b
Step 3/17 : ENV DEBIAN_FRONTEND noninteractive
 ---> Running in 32129da3fed9
Removing intermediate container 32129da3fed9
 ---> 9cf5d065df72
Step 4/17 : RUN apt-get update && apt-get install -y --no-install-recommends   fontconfig fontconfig-config fonts-dejavu-core gconf-service gconf-service-backend gconf2-common   libasn1-8-heimdal libasound2 libasound2-data libatk1.0-0 libatk1.0-data libavahi-client3 libavahi-common-data   libavahi-common3 libcairo2 libcups2 libdatrie1 libdbus-1-3 libdbus-glib-1-2 libexpat1 libfontconfig1   libfreetype6 libgconf-2-4 libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgmp10 libgnome-keyring-common   libgnome-keyring0 libgnutls30 libgraphite2-3 libgssapi-krb5-2 libgssapi3-heimdal libgtk2.0-0   libgtk2.0-common libharfbuzz0b libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhogweed4   libhx509-5-heimdal libicu60 libjbig0 libjpeg-turbo8 libjpeg8 libk5crypto3 libkeyutils1   libkrb5-26-heimdal libkrb5-3 libkrb5support0 libldap-2.4-2 libnettle6 libnspr4 libnss3   libp11-kit0 libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpixman-1-0 libpng16-16 libroken18-heimdal   libsasl2-2 libsasl2-modules-db libsqlite3-0 libtasn1-6 libthai-data libthai0 libtiff5 libwind0-heimdal libx11-6   libx11-data libxau6 libxcb-render0 libxcb-shm0 libxcb1 libxcomposite1 libxcursor1 libxdamage1 libxdmcp6   libxext6 libxfixes3 libxi6 libxinerama1 libxml2 libxrandr2 libxrender1 libxss1 libxtst6 shared-mime-info ucf   x11-common xdg-utils chromium-browser libpulse0 pulseaudio-utils && apt-get clean
 ---> Running in 81f02b1f1731
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic InRelease [242 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [74.6 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf Packages [11.0 MB]
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic/multiverse armhf Packages [157 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf Packages [1277 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic/restricted armhf Packages [12.5 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe armhf Packages [1089 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf Packages [711 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-updates/restricted armhf Packages [10.4 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse armhf Packages [3995 B]
Get:13 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe armhf Packages [4224 B]
Get:14 http://ports.ubuntu.com/ubuntu-ports bionic-backports/main armhf Packages [2490 B]
Get:15 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe armhf Packages [630 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports bionic-security/multiverse armhf Packages [2077 B]
Get:17 http://ports.ubuntu.com/ubuntu-ports bionic-security/restricted armhf Packages [5013 B]
Get:18 http://ports.ubuntu.com/ubuntu-ports bionic-security/main armhf Packages [437 kB]
Fetched 15.8 MB in 14s (1168 kB/s)
libgmp10 is already the newest version (2:6.1.2+dfsg-2).
libhogweed4 is already the newest version (3.4-1).
libnettle6 is already the newest version (3.4-1).
libp11-kit0 is already the newest version (0.23.9-2).
libtasn1-6 is already the newest version (4.13-2).
libgnutls30 is already the newest version (3.5.18-1ubuntu1.1).
  adwaita-icon-theme chromium-codecs-ffmpeg-extra dconf-gsettings-backend
  dconf-service glib-networking glib-networking-common
  glib-networking-services gsettings-desktop-schemas gtk-update-icon-cache
  hicolor-icon-theme humanity-icon-theme libasyncns0 libatk-bridge2.0-0
  libatspi2.0-0 libbsd0 libcairo-gobject2 libcap2 libcolord2 libcroco3
  libdconf1 libepoxy0 libflac8 libglib2.0-0 libgtk-3-0 libgtk-3-common libice6
  libjson-glib-1.0-0 libjson-glib-1.0-common liblcms2-2 libldap-common libogg0
  libproxy1v5 libpulsedsp librest-0.7-0 librsvg2-2 librsvg2-common libsm6
  libsndfile1 libsoup-gnome2.4-1 libsoup2.4-1 libvorbis0a libvorbisenc2
  libwayland-client0 libwayland-cursor0 libwayland-egl1 libwrap0 libx11-xcb1
  libxkbcommon0 multiarch-support ubuntu-mono xkb-data
Suggested packages:
  webaccounts-chromium-extension unity-chromium-extension adobe-flashplugin
  libasound2-plugins alsa-utils colord cups-common gnome-keyring krb5-doc
  krb5-user gvfs liblcms2-utils pulseaudio librsvg2-bin avahi-daemon
  chromium-browser-l10n at-spi2-core dbus libgdk-pixbuf2.0-bin libglib2.0-data
  xdg-user-dirs libgtk-3-bin libgail-common libgtk2.0-bin krb5-locales
  libsasl2-modules libfile-mimeinfo-perl libnet-dbus-perl libx11-protocol-perl
  x11-utils x11-xserver-utils
  adwaita-icon-theme chromium-browser chromium-codecs-ffmpeg-extra
  dconf-gsettings-backend dconf-service fontconfig fontconfig-config
  glib-networking glib-networking-common glib-networking-services
  gsettings-desktop-schemas gtk-update-icon-cache hicolor-icon-theme
  humanity-icon-theme libasn1-8-heimdal libasound2 libasound2-data libasyncns0
  libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data libatspi2.0-0 libavahi-client3
  libavahi-common-data libavahi-common3 libbsd0 libcairo-gobject2 libcairo2
  libcap2 libcolord2 libcroco3 libcups2 libdatrie1 libdbus-1-3
  libdbus-glib-1-2 libdconf1 libepoxy0 libexpat1 libflac8 libfontconfig1
  libglib2.0-0 libgnome-keyring-common libgnome-keyring0 libgraphite2-3
  libgssapi-krb5-2 libgssapi3-heimdal libgtk-3-0 libgtk-3-common libgtk2.0-0
  libheimntlm0-heimdal libhx509-5-heimdal libice6 libicu60 libjbig0
  libjpeg-turbo8 libjpeg8 libjson-glib-1.0-0 libjson-glib-1.0-common
  liblcms2-2 libldap-2.4-2 libldap-common libnspr4 libnss3 libogg0
  libpng16-16 libproxy1v5 libpulse0 libpulsedsp librest-0.7-0
  libroken18-heimdal librsvg2-2 librsvg2-common libsasl2-2 libsasl2-modules-db
  libsm6 libsndfile1 libsoup-gnome2.4-1 libsoup2.4-1 libsqlite3-0 libthai-data
  libthai0 libtiff5 libvorbis0a libvorbisenc2 libwayland-client0
  libwayland-cursor0 libwayland-egl1 libwind0-heimdal libwrap0 libx11-6
  libx11-data libx11-xcb1 libxau6 libxcb-render0 libxcb-shm0 libxcb1
  libxinerama1 libxkbcommon0 libxml2 libxrandr2 libxrender1 libxss1 libxtst6
  multiarch-support pulseaudio-utils shared-mime-info ubuntu-mono ucf
  x11-common xdg-utils xkb-data
0 upgraded, 139 newly installed, 0 to remove and 1 not upgraded.
Need to get 86.2 MB of archives.
After this operation, 280 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf multiarch-support armhf 2.27-3ubuntu1 [6912 B]
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxau6 armhf 1:1.0.8-1 [7324 B]
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libbsd0 armhf 0.8.7-1 [40.4 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxdmcp6 armhf 1:1.1.2-3 [9316 B]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb1 armhf 1.13-2~ubuntu18.04 [41.2 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libx11-data all 2:1.6.4-3ubuntu0.2 [113 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libx11-6 armhf 2:1.6.4-3ubuntu0.2 [514 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxext6 armhf 2:1.3.3-1 [25.1 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libasound2-data all 1.1.3-5ubuntu0.2 [36.5 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libasound2 armhf 1.1.3-5ubuntu0.2 [306 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libglib2.0-0 armhf 2.56.4-0ubuntu0.18.04.4 [1017 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libatk1.0-data all 2.28.1-1 [2992 B]
Get:13 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libatk1.0-0 armhf 2.28.1-1 [36.9 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdbus-1-3 armhf 1.12.2-1ubuntu1.1 [153 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libatspi2.0-0 armhf 2.28.0-1 [49.9 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libatk-bridge2.0-0 armhf 2.26.2-1 [48.9 kB]
Get:17 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libexpat1 armhf 2.2.5-3ubuntu0.2 [59.6 kB]
Get:18 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpng16-16 armhf 1.6.34-1ubuntu0.18.04.2 [159 kB]
Get:19 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libfreetype6 armhf 2.8.1-2ubuntu2 [280 kB]
Get:20 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf ucf all 3.0038 [50.5 kB]
Get:21 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf fonts-dejavu-core all 2.37-1 [1041 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf fontconfig-config all 2.12.6-0ubuntu2 [55.8 kB]
Get:23 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libfontconfig1 armhf 2.12.6-0ubuntu2 [120 kB]
Get:24 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libpixman-1-0 armhf 0.34.0-2 [157 kB]
Get:25 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-render0 armhf 1.13-2~ubuntu18.04 [13.9 kB]
Get:26 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-shm0 armhf 1.13-2~ubuntu18.04 [5416 B]
Get:27 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxrender1 armhf 1:0.9.10-1 [15.6 kB]
Get:28 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libcairo2 armhf 1.15.10-2ubuntu0.1 [506 kB]
Get:29 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libavahi-common-data armhf 0.7-3.1ubuntu1.2 [22.1 kB]
Get:30 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libavahi-common3 armhf 0.7-3.1ubuntu1.2 [18.4 kB]
Get:31 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libavahi-client3 armhf 0.7-3.1ubuntu1.2 [21.7 kB]
Get:32 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libkrb5support0 armhf 1.16-2ubuntu0.1 [27.3 kB]
Get:33 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libk5crypto3 armhf 1.16-2ubuntu0.1 [83.2 kB]
Get:34 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libkeyutils1 armhf 1.5.9-9.2ubuntu2 [7796 B]
Get:35 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libkrb5-3 armhf 1.16-2ubuntu0.1 [234 kB]
Get:36 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgssapi-krb5-2 armhf 1.16-2ubuntu0.1 [101 kB]
Get:37 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libcups2 armhf 2.2.7-1ubuntu2.7 [179 kB]
Get:38 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libjpeg-turbo8 armhf 1.5.2-0ubuntu5.18.04.1 [87.4 kB]
Get:39 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libjpeg8 armhf 8c-2ubuntu8 [2202 B]
Get:40 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libjbig0 armhf 2.1-3.1build1 [23.9 kB]
Get:41 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libtiff5 armhf 4.0.9-5ubuntu0.3 [135 kB]
Get:42 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libicu60 armhf 60.2-3ubuntu3 [7797 kB]
Get:43 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxml2 armhf 2.9.4+dfsg1-6.1ubuntu1.2 [567 kB]
Get:44 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf shared-mime-info armhf 1.9-2 [424 kB]
Get:45 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgdk-pixbuf2.0-common all 2.36.11-2 [4536 B]
Get:46 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgdk-pixbuf2.0-0 armhf 2.36.11-2 [149 kB]
Get:47 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libdconf1 armhf 0.26.0-2ubuntu3 [29.3 kB]
Get:48 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf dconf-service armhf 0.26.0-2ubuntu3 [24.5 kB]
Get:49 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf dconf-gsettings-backend armhf 0.26.0-2ubuntu3 [16.3 kB]
Get:50 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgtk-3-common all 3.22.30-1ubuntu4 [229 kB]
Get:51 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libcairo-gobject2 armhf 1.15.10-2ubuntu0.1 [16.1 kB]
Get:52 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf liblcms2-2 armhf 2.9-1ubuntu0.1 [114 kB]
Get:53 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libcolord2 armhf 1.3.3-2build1 [95.3 kB]
Get:54 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libepoxy0 armhf 1.4.3-1 [161 kB]
Get:55 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libjson-glib-1.0-common all 1.4.2-3 [3464 B]
Get:56 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libjson-glib-1.0-0 armhf 1.4.2-3 [51.2 kB]
Get:57 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf fontconfig armhf 2.12.6-0ubuntu2 [167 kB]
Get:58 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libthai-data all 0.1.27-2 [133 kB]
Get:59 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libdatrie1 armhf 0.2.10-7 [14.5 kB]
Get:60 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libthai0 armhf 0.1.27-2 [14.7 kB]
Get:61 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpango-1.0-0 armhf 1.40.14-1ubuntu0.1 [137 kB]
Get:62 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgraphite2-3 armhf 1.3.11-2 [67.5 kB]
Get:63 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libharfbuzz0b armhf 1.7.2-1ubuntu1 [205 kB]
Get:64 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpangoft2-1.0-0 armhf 1.40.14-1ubuntu0.1 [28.5 kB]
Get:65 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpangocairo-1.0-0 armhf 1.40.14-1ubuntu0.1 [17.5 kB]
Get:66 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsqlite3-0 armhf 3.22.0-1ubuntu0.1 [422 kB]
Get:67 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libproxy1v5 armhf 0.4.15-1 [42.7 kB]
Get:68 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf glib-networking-common all 2.56.0-1 [3324 B]
Get:69 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf glib-networking-services armhf 2.56.0-1 [7860 B]
Get:70 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf gsettings-desktop-schemas all 3.28.0-1ubuntu1 [27.8 kB]
Get:71 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf glib-networking armhf 2.56.0-1 [49.3 kB]
Get:72 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsoup2.4-1 armhf 2.62.1-1ubuntu0.4 [249 kB]
Get:73 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsoup-gnome2.4-1 armhf 2.62.1-1ubuntu0.4 [4728 B]
Get:74 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf librest-0.7-0 armhf 0.8.0-2 [26.9 kB]
Get:75 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libwayland-client0 armhf 1.16.0-1ubuntu1.1~18.04.1 [18.8 kB]
Get:76 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libwayland-cursor0 armhf 1.16.0-1ubuntu1.1~18.04.1 [9000 B]
Get:77 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libwayland-egl1 armhf 1.16.0-1ubuntu1.1~18.04.1 [5508 B]
Get:78 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxcomposite1 armhf 1:0.4.4-2 [7684 B]
Get:79 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxfixes3 armhf 1:5.0.3-1 [9390 B]
Get:80 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxcursor1 armhf 1:1.1.15-1 [16.9 kB]
Get:81 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxdamage1 armhf 1:1.1.4-3 [6488 B]
Get:82 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxi6 armhf 2:1.7.9-1 [26.1 kB]
Get:83 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxinerama1 armhf 2:1.1.3-1 [7278 B]
Get:84 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf xkb-data all 2.23.1-1ubuntu1.18.04.1 [325 kB]
Get:85 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxkbcommon0 armhf 0.8.2-1~ubuntu18.04.1 [86.3 kB]
Get:86 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxrandr2 armhf 2:1.5.1-1 [15.5 kB]
Get:87 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf hicolor-icon-theme all 0.17-2 [9976 B]
Get:88 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf gtk-update-icon-cache armhf 3.22.30-1ubuntu4 [27.1 kB]
Get:89 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libcroco3 armhf 0.6.12-2 [69.4 kB]
Get:90 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf librsvg2-2 armhf 2.40.20-2 [83.8 kB]
Get:91 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf librsvg2-common armhf 2.40.20-2 [4720 B]
Get:92 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf humanity-icon-theme all 0.6.15 [1250 kB]
Get:93 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf ubuntu-mono all 16.10+18.04.20181005-0ubuntu1 [149 kB]
Get:94 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf adwaita-icon-theme all 3.28.0-1ubuntu1 [3306 kB]
Get:95 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libgtk-3-0 armhf 3.22.30-1ubuntu4 [2135 kB]
Get:96 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libnspr4 armhf 2:4.18-1ubuntu1 [89.8 kB]
Get:97 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libnss3 armhf 2:3.35-2ubuntu2.3 [947 kB]
Get:98 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libx11-xcb1 armhf 2:1.6.4-3ubuntu0.2 [9312 B]
Get:99 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf x11-common all 1:7.7+19ubuntu7.1 [22.5 kB]
Get:100 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxss1 armhf 1:1.2.2-1 [7652 B]
Get:101 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libxtst6 armhf 2:1.2.3-1 [11.4 kB]
Get:102 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf xdg-utils all 1.1.2-1ubuntu2.3 [60.7 kB]
Get:103 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe armhf chromium-codecs-ffmpeg-extra armhf 77.0.3865.90-0ubuntu0.18.04.1 [959 kB]
Get:104 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe armhf chromium-browser armhf 77.0.3865.90-0ubuntu0.18.04.1 [55.0 MB]
Get:105 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf libgnome-keyring-common all 3.12.0-1build1 [5792 B]
Get:106 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf libgnome-keyring0 armhf 3.12.0-1build1 [49.5 kB]
Get:107 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libogg0 armhf 1.3.2-1 [14.6 kB]
Get:108 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libice6 armhf 2:1.0.9-2 [33.5 kB]
Get:109 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libsm6 armhf 2:1.2.2-1 [13.9 kB]
Get:110 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libcap2 armhf 1:2.25-1.2 [11.7 kB]
Get:111 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libdbus-glib-1-2 armhf 0.110-2 [48.2 kB]
Get:112 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf gconf2-common all 3.2.6-4ubuntu1 [700 kB]
Get:113 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf libgconf-2-4 armhf 3.2.6-4ubuntu1 [74.9 kB]
Get:114 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libroken18-heimdal armhf 7.5.0+dfsg-1 [34.1 kB]
Get:115 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libasn1-8-heimdal armhf 7.5.0+dfsg-1 [136 kB]
Get:116 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libheimbase1-heimdal armhf 7.5.0+dfsg-1 [24.1 kB]
Get:117 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libhcrypto4-heimdal armhf 7.5.0+dfsg-1 [76.5 kB]
Get:118 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libwind0-heimdal armhf 7.5.0+dfsg-1 [47.2 kB]
Get:119 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libhx509-5-heimdal armhf 7.5.0+dfsg-1 [87.9 kB]
Get:120 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libkrb5-26-heimdal armhf 7.5.0+dfsg-1 [168 kB]
Get:121 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libheimntlm0-heimdal armhf 7.5.0+dfsg-1 [13.1 kB]
Get:122 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgssapi3-heimdal armhf 7.5.0+dfsg-1 [78.8 kB]
Get:123 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libsasl2-modules-db armhf 2.1.27~101-g0780600+dfsg-3ubuntu2 [13.0 kB]
Get:124 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libsasl2-2 armhf 2.1.27~101-g0780600+dfsg-3ubuntu2 [42.0 kB]
Get:125 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libldap-common all 2.4.45+dfsg-1ubuntu1.4 [16.9 kB]
Get:126 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libldap-2.4-2 armhf 2.4.45+dfsg-1ubuntu1.4 [132 kB]
Get:127 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf gconf-service-backend armhf 3.2.6-4ubuntu1 [50.0 kB]
Get:128 http://ports.ubuntu.com/ubuntu-ports bionic/universe armhf gconf-service armhf 3.2.6-4ubuntu1 [2036 B]
Get:129 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libasyncns0 armhf 0.8-6 [11.0 kB]
Get:130 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libflac8 armhf 1.3.2-1 [142 kB]
Get:131 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgtk2.0-common all 2.24.32-1ubuntu1 [125 kB]
Get:132 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libgtk2.0-0 armhf 2.24.32-1ubuntu1 [1509 kB]
Get:133 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libvorbis0a armhf 1.3.5-4.2 [75.6 kB]
Get:134 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libvorbisenc2 armhf 1.3.5-4.2 [64.5 kB]
Get:135 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libsndfile1 armhf 1.0.28-4ubuntu0.18.04.1 [159 kB]
Get:136 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libwrap0 armhf 7.6.q-27 [43.5 kB]
Get:137 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpulse0 armhf 1:11.1-1ubuntu7.2 [236 kB]
Get:138 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libpulsedsp armhf 1:11.1-1ubuntu7.2 [30.1 kB]
Get:139 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf pulseaudio-utils armhf 1:11.1-1ubuntu7.2 [63.2 kB]
[91mdebconf: delaying package configuration, since apt-utils is not installed
[0mFetched 86.2 MB in 35s (2464 kB/s)
Selecting previously unselected package multiarch-support.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 4040 files and directories currently installed.)
Preparing to unpack .../multiarch-support_2.27-3ubuntu1_armhf.deb ...
Unpacking multiarch-support (2.27-3ubuntu1) ...
Setting up multiarch-support (2.27-3ubuntu1) ...
Selecting previously unselected package libxau6:armhf.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 4043 files and directories currently installed.)
Preparing to unpack .../000-libxau6_1%3a1.0.8-1_armhf.deb ...
Unpacking libxau6:armhf (1:1.0.8-1) ...
Selecting previously unselected package libbsd0:armhf.
Preparing to unpack .../001-libbsd0_0.8.7-1_armhf.deb ...
Unpacking libbsd0:armhf (0.8.7-1) ...
Selecting previously unselected package libxdmcp6:armhf.
Preparing to unpack .../002-libxdmcp6_1%3a1.1.2-3_armhf.deb ...
Unpacking libxdmcp6:armhf (1:1.1.2-3) ...
Selecting previously unselected package libxcb1:armhf.
Preparing to unpack .../003-libxcb1_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb1:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libx11-data.
Preparing to unpack .../004-libx11-data_2%3a1.6.4-3ubuntu0.2_all.deb ...
Unpacking libx11-data (2:1.6.4-3ubuntu0.2) ...
Selecting previously unselected package libx11-6:armhf.
Preparing to unpack .../005-libx11-6_2%3a1.6.4-3ubuntu0.2_armhf.deb ...
Unpacking libx11-6:armhf (2:1.6.4-3ubuntu0.2) ...
Selecting previously unselected package libxext6:armhf.
Preparing to unpack .../006-libxext6_2%3a1.3.3-1_armhf.deb ...
Unpacking libxext6:armhf (2:1.3.3-1) ...
Selecting previously unselected package libasound2-data.
Preparing to unpack .../007-libasound2-data_1.1.3-5ubuntu0.2_all.deb ...
Unpacking libasound2-data (1.1.3-5ubuntu0.2) ...
Selecting previously unselected package libasound2:armhf.
Preparing to unpack .../008-libasound2_1.1.3-5ubuntu0.2_armhf.deb ...
Unpacking libasound2:armhf (1.1.3-5ubuntu0.2) ...
Selecting previously unselected package libglib2.0-0:armhf.
Preparing to unpack .../009-libglib2.0-0_2.56.4-0ubuntu0.18.04.4_armhf.deb ...
Unpacking libglib2.0-0:armhf (2.56.4-0ubuntu0.18.04.4) ...
Selecting previously unselected package libatk1.0-data.
Preparing to unpack .../010-libatk1.0-data_2.28.1-1_all.deb ...
Unpacking libatk1.0-data (2.28.1-1) ...
Selecting previously unselected package libatk1.0-0:armhf.
Preparing to unpack .../011-libatk1.0-0_2.28.1-1_armhf.deb ...
Unpacking libatk1.0-0:armhf (2.28.1-1) ...
Selecting previously unselected package libdbus-1-3:armhf.
Preparing to unpack .../012-libdbus-1-3_1.12.2-1ubuntu1.1_armhf.deb ...
Unpacking libdbus-1-3:armhf (1.12.2-1ubuntu1.1) ...
Selecting previously unselected package libatspi2.0-0:armhf.
Preparing to unpack .../013-libatspi2.0-0_2.28.0-1_armhf.deb ...
Unpacking libatspi2.0-0:armhf (2.28.0-1) ...
Selecting previously unselected package libatk-bridge2.0-0:armhf.
Preparing to unpack .../014-libatk-bridge2.0-0_2.26.2-1_armhf.deb ...
Unpacking libatk-bridge2.0-0:armhf (2.26.2-1) ...
Selecting previously unselected package libexpat1:armhf.
Preparing to unpack .../015-libexpat1_2.2.5-3ubuntu0.2_armhf.deb ...
Unpacking libexpat1:armhf (2.2.5-3ubuntu0.2) ...
Selecting previously unselected package libpng16-16:armhf.
Preparing to unpack .../016-libpng16-16_1.6.34-1ubuntu0.18.04.2_armhf.deb ...
Unpacking libpng16-16:armhf (1.6.34-1ubuntu0.18.04.2) ...
Selecting previously unselected package libfreetype6:armhf.
Preparing to unpack .../017-libfreetype6_2.8.1-2ubuntu2_armhf.deb ...
Unpacking libfreetype6:armhf (2.8.1-2ubuntu2) ...
Selecting previously unselected package ucf.
Preparing to unpack .../018-ucf_3.0038_all.deb ...
Moving old data out of the way
Unpacking ucf (3.0038) ...
Selecting previously unselected package fonts-dejavu-core.
Preparing to unpack .../019-fonts-dejavu-core_2.37-1_all.deb ...
Unpacking fonts-dejavu-core (2.37-1) ...
Selecting previously unselected package fontconfig-config.
Preparing to unpack .../020-fontconfig-config_2.12.6-0ubuntu2_all.deb ...
Unpacking fontconfig-config (2.12.6-0ubuntu2) ...
Selecting previously unselected package libfontconfig1:armhf.
Preparing to unpack .../021-libfontconfig1_2.12.6-0ubuntu2_armhf.deb ...
Unpacking libfontconfig1:armhf (2.12.6-0ubuntu2) ...
Selecting previously unselected package libpixman-1-0:armhf.
Preparing to unpack .../022-libpixman-1-0_0.34.0-2_armhf.deb ...
Unpacking libpixman-1-0:armhf (0.34.0-2) ...
Selecting previously unselected package libxcb-render0:armhf.
Preparing to unpack .../023-libxcb-render0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-render0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxcb-shm0:armhf.
Preparing to unpack .../024-libxcb-shm0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-shm0:armhf (1.13-2~ubuntu18.04) ...
Selecting previously unselected package libxrender1:armhf.
Preparing to unpack .../025-libxrender1_1%3a0.9.10-1_armhf.deb ...
Unpacking libxrender1:armhf (1:0.9.10-1) ...
Selecting previously unselected package libcairo2:armhf.
Preparing to unpack .../026-libcairo2_1.15.10-2ubuntu0.1_armhf.deb ...
Unpacking libcairo2:armhf (1.15.10-2ubuntu0.1) ...
Selecting previously unselected package libavahi-common-data:armhf.
Preparing to unpack .../027-libavahi-common-data_0.7-3.1ubuntu1.2_armhf.deb ...
Unpacking libavahi-common-data:armhf (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libavahi-common3:armhf.
Preparing to unpack .../028-libavahi-common3_0.7-3.1ubuntu1.2_armhf.deb ...
Unpacking libavahi-common3:armhf (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libavahi-client3:armhf.
Preparing to unpack .../029-libavahi-client3_0.7-3.1ubuntu1.2_armhf.deb ...
Unpacking libavahi-client3:armhf (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libkrb5support0:armhf.
Preparing to unpack .../030-libkrb5support0_1.16-2ubuntu0.1_armhf.deb ...
Unpacking libkrb5support0:armhf (1.16-2ubuntu0.1) ...
Selecting previously unselected package libk5crypto3:armhf.
Preparing to unpack .../031-libk5crypto3_1.16-2ubuntu0.1_armhf.deb ...
Unpacking libk5crypto3:armhf (1.16-2ubuntu0.1) ...
Selecting previously unselected package libkeyutils1:armhf.
Preparing to unpack .../032-libkeyutils1_1.5.9-9.2ubuntu2_armhf.deb ...
Unpacking libkeyutils1:armhf (1.5.9-9.2ubuntu2) ...
Selecting previously unselected package libkrb5-3:armhf.
Preparing to unpack .../033-libkrb5-3_1.16-2ubuntu0.1_armhf.deb ...
Unpacking libkrb5-3:armhf (1.16-2ubuntu0.1) ...
Selecting previously unselected package libgssapi-krb5-2:armhf.
Preparing to unpack .../034-libgssapi-krb5-2_1.16-2ubuntu0.1_armhf.deb ...
Unpacking libgssapi-krb5-2:armhf (1.16-2ubuntu0.1) ...
Selecting previously unselected package libcups2:armhf.
Preparing to unpack .../035-libcups2_2.2.7-1ubuntu2.7_armhf.deb ...
Unpacking libcups2:armhf (2.2.7-1ubuntu2.7) ...
Selecting previously unselected package libjpeg-turbo8:armhf.
Preparing to unpack .../036-libjpeg-turbo8_1.5.2-0ubuntu5.18.04.1_armhf.deb ...
Unpacking libjpeg-turbo8:armhf (1.5.2-0ubuntu5.18.04.1) ...
Selecting previously unselected package libjpeg8:armhf.
Preparing to unpack .../037-libjpeg8_8c-2ubuntu8_armhf.deb ...
Unpacking libjpeg8:armhf (8c-2ubuntu8) ...
Selecting previously unselected package libjbig0:armhf.
Preparing to unpack .../038-libjbig0_2.1-3.1build1_armhf.deb ...
Unpacking libjbig0:armhf (2.1-3.1build1) ...
Selecting previously unselected package libtiff5:armhf.
Preparing to unpack .../039-libtiff5_4.0.9-5ubuntu0.3_armhf.deb ...
Unpacking libtiff5:armhf (4.0.9-5ubuntu0.3) ...
Selecting previously unselected package libicu60:armhf.
Preparing to unpack .../040-libicu60_60.2-3ubuntu3_armhf.deb ...
Unpacking libicu60:armhf (60.2-3ubuntu3) ...
Selecting previously unselected package libxml2:armhf.
Preparing to unpack .../041-libxml2_2.9.4+dfsg1-6.1ubuntu1.2_armhf.deb ...
Unpacking libxml2:armhf (2.9.4+dfsg1-6.1ubuntu1.2) ...
Selecting previously unselected package shared-mime-info.
Preparing to unpack .../042-shared-mime-info_1.9-2_armhf.deb ...
Unpacking shared-mime-info (1.9-2) ...
Selecting previously unselected package libgdk-pixbuf2.0-common.
Preparing to unpack .../043-libgdk-pixbuf2.0-common_2.36.11-2_all.deb ...
Unpacking libgdk-pixbuf2.0-common (2.36.11-2) ...
Selecting previously unselected package libgdk-pixbuf2.0-0:armhf.
Preparing to unpack .../044-libgdk-pixbuf2.0-0_2.36.11-2_armhf.deb ...
Unpacking libgdk-pixbuf2.0-0:armhf (2.36.11-2) ...
Selecting previously unselected package libdconf1:armhf.
Preparing to unpack .../045-libdconf1_0.26.0-2ubuntu3_armhf.deb ...
Unpacking libdconf1:armhf (0.26.0-2ubuntu3) ...
Selecting previously unselected package dconf-service.
Preparing to unpack .../046-dconf-service_0.26.0-2ubuntu3_armhf.deb ...
Unpacking dconf-service (0.26.0-2ubuntu3) ...
Selecting previously unselected package dconf-gsettings-backend:armhf.
Preparing to unpack .../047-dconf-gsettings-backend_0.26.0-2ubuntu3_armhf.deb ...
Unpacking dconf-gsettings-backend:armhf (0.26.0-2ubuntu3) ...
Selecting previously unselected package libgtk-3-common.
Preparing to unpack .../048-libgtk-3-common_3.22.30-1ubuntu4_all.deb ...
Unpacking libgtk-3-common (3.22.30-1ubuntu4) ...
Selecting previously unselected package libcairo-gobject2:armhf.
Preparing to unpack .../049-libcairo-gobject2_1.15.10-2ubuntu0.1_armhf.deb ...
Unpacking libcairo-gobject2:armhf (1.15.10-2ubuntu0.1) ...
Selecting previously unselected package liblcms2-2:armhf.
Preparing to unpack .../050-liblcms2-2_2.9-1ubuntu0.1_armhf.deb ...
Unpacking liblcms2-2:armhf (2.9-1ubuntu0.1) ...
Selecting previously unselected package libcolord2:armhf.
Preparing to unpack .../051-libcolord2_1.3.3-2build1_armhf.deb ...
Unpacking libcolord2:armhf (1.3.3-2build1) ...
Selecting previously unselected package libepoxy0:armhf.
Preparing to unpack .../052-libepoxy0_1.4.3-1_armhf.deb ...
Unpacking libepoxy0:armhf (1.4.3-1) ...
Selecting previously unselected package libjson-glib-1.0-common.
Preparing to unpack .../053-libjson-glib-1.0-common_1.4.2-3_all.deb ...
Unpacking libjson-glib-1.0-common (1.4.2-3) ...
Selecting previously unselected package libjson-glib-1.0-0:armhf.
Preparing to unpack .../054-libjson-glib-1.0-0_1.4.2-3_armhf.deb ...
Unpacking libjson-glib-1.0-0:armhf (1.4.2-3) ...
Selecting previously unselected package fontconfig.
Preparing to unpack .../055-fontconfig_2.12.6-0ubuntu2_armhf.deb ...
Unpacking fontconfig (2.12.6-0ubuntu2) ...
Selecting previously unselected package libthai-data.
Preparing to unpack .../056-libthai-data_0.1.27-2_all.deb ...
Unpacking libthai-data (0.1.27-2) ...
Selecting previously unselected package libdatrie1:armhf.
Preparing to unpack .../057-libdatrie1_0.2.10-7_armhf.deb ...
Unpacking libdatrie1:armhf (0.2.10-7) ...
Selecting previously unselected package libthai0:armhf.
Preparing to unpack .../058-libthai0_0.1.27-2_armhf.deb ...
Unpacking libthai0:armhf (0.1.27-2) ...
Selecting previously unselected package libpango-1.0-0:armhf.
Preparing to unpack .../059-libpango-1.0-0_1.40.14-1ubuntu0.1_armhf.deb ...
Unpacking libpango-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Selecting previously unselected package libgraphite2-3:armhf.
Preparing to unpack .../060-libgraphite2-3_1.3.11-2_armhf.deb ...
Unpacking libgraphite2-3:armhf (1.3.11-2) ...
Selecting previously unselected package libharfbuzz0b:armhf.
Preparing to unpack .../061-libharfbuzz0b_1.7.2-1ubuntu1_armhf.deb ...
Unpacking libharfbuzz0b:armhf (1.7.2-1ubuntu1) ...
Selecting previously unselected package libpangoft2-1.0-0:armhf.
Preparing to unpack .../062-libpangoft2-1.0-0_1.40.14-1ubuntu0.1_armhf.deb ...
Unpacking libpangoft2-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Selecting previously unselected package libpangocairo-1.0-0:armhf.
Preparing to unpack .../063-libpangocairo-1.0-0_1.40.14-1ubuntu0.1_armhf.deb ...
Unpacking libpangocairo-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Selecting previously unselected package libsqlite3-0:armhf.
Preparing to unpack .../064-libsqlite3-0_3.22.0-1ubuntu0.1_armhf.deb ...
Unpacking libsqlite3-0:armhf (3.22.0-1ubuntu0.1) ...
Selecting previously unselected package libproxy1v5:armhf.
Preparing to unpack .../065-libproxy1v5_0.4.15-1_armhf.deb ...
Unpacking libproxy1v5:armhf (0.4.15-1) ...
Selecting previously unselected package glib-networking-common.
Preparing to unpack .../066-glib-networking-common_2.56.0-1_all.deb ...
Unpacking glib-networking-common (2.56.0-1) ...
Selecting previously unselected package glib-networking-services.
Preparing to unpack .../067-glib-networking-services_2.56.0-1_armhf.deb ...
Unpacking glib-networking-services (2.56.0-1) ...
Selecting previously unselected package gsettings-desktop-schemas.
Preparing to unpack .../068-gsettings-desktop-schemas_3.28.0-1ubuntu1_all.deb ...
Unpacking gsettings-desktop-schemas (3.28.0-1ubuntu1) ...
Selecting previously unselected package glib-networking:armhf.
Preparing to unpack .../069-glib-networking_2.56.0-1_armhf.deb ...
Unpacking glib-networking:armhf (2.56.0-1) ...
Selecting previously unselected package libsoup2.4-1:armhf.
Preparing to unpack .../070-libsoup2.4-1_2.62.1-1ubuntu0.4_armhf.deb ...
Unpacking libsoup2.4-1:armhf (2.62.1-1ubuntu0.4) ...
Selecting previously unselected package libsoup-gnome2.4-1:armhf.
Preparing to unpack .../071-libsoup-gnome2.4-1_2.62.1-1ubuntu0.4_armhf.deb ...
Unpacking libsoup-gnome2.4-1:armhf (2.62.1-1ubuntu0.4) ...
Selecting previously unselected package librest-0.7-0:armhf.
Preparing to unpack .../072-librest-0.7-0_0.8.0-2_armhf.deb ...
Unpacking librest-0.7-0:armhf (0.8.0-2) ...
Selecting previously unselected package libwayland-client0:armhf.
Preparing to unpack .../073-libwayland-client0_1.16.0-1ubuntu1.1~18.04.1_armhf.deb ...
Unpacking libwayland-client0:armhf (1.16.0-1ubuntu1.1~18.04.1) ...
Selecting previously unselected package libwayland-cursor0:armhf.
Preparing to unpack .../074-libwayland-cursor0_1.16.0-1ubuntu1.1~18.04.1_armhf.deb ...
Unpacking libwayland-cursor0:armhf (1.16.0-1ubuntu1.1~18.04.1) ...
Selecting previously unselected package libwayland-egl1:armhf.
Preparing to unpack .../075-libwayland-egl1_1.16.0-1ubuntu1.1~18.04.1_armhf.deb ...
Unpacking libwayland-egl1:armhf (1.16.0-1ubuntu1.1~18.04.1) ...
Selecting previously unselected package libxcomposite1:armhf.
Preparing to unpack .../076-libxcomposite1_1%3a0.4.4-2_armhf.deb ...
Unpacking libxcomposite1:armhf (1:0.4.4-2) ...
Selecting previously unselected package libxfixes3:armhf.
Preparing to unpack .../077-libxfixes3_1%3a5.0.3-1_armhf.deb ...
Unpacking libxfixes3:armhf (1:5.0.3-1) ...
Selecting previously unselected package libxcursor1:armhf.
Preparing to unpack .../078-libxcursor1_1%3a1.1.15-1_armhf.deb ...
Unpacking libxcursor1:armhf (1:1.1.15-1) ...
Selecting previously unselected package libxdamage1:armhf.
Preparing to unpack .../079-libxdamage1_1%3a1.1.4-3_armhf.deb ...
Unpacking libxdamage1:armhf (1:1.1.4-3) ...
Selecting previously unselected package libxi6:armhf.
Preparing to unpack .../080-libxi6_2%3a1.7.9-1_armhf.deb ...
Unpacking libxi6:armhf (2:1.7.9-1) ...
Selecting previously unselected package libxinerama1:armhf.
Preparing to unpack .../081-libxinerama1_2%3a1.1.3-1_armhf.deb ...
Unpacking libxinerama1:armhf (2:1.1.3-1) ...
Selecting previously unselected package xkb-data.
Preparing to unpack .../082-xkb-data_2.23.1-1ubuntu1.18.04.1_all.deb ...
Unpacking xkb-data (2.23.1-1ubuntu1.18.04.1) ...
Selecting previously unselected package libxkbcommon0:armhf.
Preparing to unpack .../083-libxkbcommon0_0.8.2-1~ubuntu18.04.1_armhf.deb ...
Unpacking libxkbcommon0:armhf (0.8.2-1~ubuntu18.04.1) ...
Selecting previously unselected package libxrandr2:armhf.
Preparing to unpack .../084-libxrandr2_2%3a1.5.1-1_armhf.deb ...
Unpacking libxrandr2:armhf (2:1.5.1-1) ...
Selecting previously unselected package hicolor-icon-theme.
Preparing to unpack .../085-hicolor-icon-theme_0.17-2_all.deb ...
Unpacking hicolor-icon-theme (0.17-2) ...
Selecting previously unselected package gtk-update-icon-cache.
Preparing to unpack .../086-gtk-update-icon-cache_3.22.30-1ubuntu4_armhf.deb ...
No diversion 'diversion of /usr/sbin/update-icon-caches to /usr/sbin/update-icon-caches.gtk2 by libgtk-3-bin', none removed.
No diversion 'diversion of /usr/share/man/man8/update-icon-caches.8.gz to /usr/share/man/man8/update-icon-caches.gtk2.8.gz by libgtk-3-bin', none removed.
Unpacking gtk-update-icon-cache (3.22.30-1ubuntu4) ...
Selecting previously unselected package libcroco3:armhf.
Preparing to unpack .../087-libcroco3_0.6.12-2_armhf.deb ...
Unpacking libcroco3:armhf (0.6.12-2) ...
Selecting previously unselected package librsvg2-2:armhf.
Preparing to unpack .../088-librsvg2-2_2.40.20-2_armhf.deb ...
Unpacking librsvg2-2:armhf (2.40.20-2) ...
Selecting previously unselected package librsvg2-common:armhf.
Preparing to unpack .../089-librsvg2-common_2.40.20-2_armhf.deb ...
Unpacking librsvg2-common:armhf (2.40.20-2) ...
Selecting previously unselected package humanity-icon-theme.
Preparing to unpack .../090-humanity-icon-theme_0.6.15_all.deb ...
Unpacking humanity-icon-theme (0.6.15) ...
Selecting previously unselected package ubuntu-mono.
Preparing to unpack .../091-ubuntu-mono_16.10+18.04.20181005-0ubuntu1_all.deb ...
Unpacking ubuntu-mono (16.10+18.04.20181005-0ubuntu1) ...
Selecting previously unselected package adwaita-icon-theme.
Preparing to unpack .../092-adwaita-icon-theme_3.28.0-1ubuntu1_all.deb ...
Unpacking adwaita-icon-theme (3.28.0-1ubuntu1) ...
Selecting previously unselected package libgtk-3-0:armhf.
Preparing to unpack .../093-libgtk-3-0_3.22.30-1ubuntu4_armhf.deb ...
Unpacking libgtk-3-0:armhf (3.22.30-1ubuntu4) ...
Selecting previously unselected package libnspr4:armhf.
Preparing to unpack .../094-libnspr4_2%3a4.18-1ubuntu1_armhf.deb ...
Unpacking libnspr4:armhf (2:4.18-1ubuntu1) ...
Selecting previously unselected package libnss3:armhf.
Preparing to unpack .../095-libnss3_2%3a3.35-2ubuntu2.3_armhf.deb ...
Unpacking libnss3:armhf (2:3.35-2ubuntu2.3) ...
Selecting previously unselected package libx11-xcb1:armhf.
Preparing to unpack .../096-libx11-xcb1_2%3a1.6.4-3ubuntu0.2_armhf.deb ...
Unpacking libx11-xcb1:armhf (2:1.6.4-3ubuntu0.2) ...
Selecting previously unselected package x11-common.
Preparing to unpack .../097-x11-common_1%3a7.7+19ubuntu7.1_all.deb ...
dpkg-query: no packages found matching nux-tools
Unpacking x11-common (1:7.7+19ubuntu7.1) ...
Selecting previously unselected package libxss1:armhf.
Preparing to unpack .../098-libxss1_1%3a1.2.2-1_armhf.deb ...
Unpacking libxss1:armhf (1:1.2.2-1) ...
Selecting previously unselected package libxtst6:armhf.
Preparing to unpack .../099-libxtst6_2%3a1.2.3-1_armhf.deb ...
Unpacking libxtst6:armhf (2:1.2.3-1) ...
Selecting previously unselected package xdg-utils.
Preparing to unpack .../100-xdg-utils_1.1.2-1ubuntu2.3_all.deb ...
Unpacking xdg-utils (1.1.2-1ubuntu2.3) ...
Selecting previously unselected package chromium-codecs-ffmpeg-extra.
Preparing to unpack .../101-chromium-codecs-ffmpeg-extra_77.0.3865.90-0ubuntu0.18.04.1_armhf.deb ...
Unpacking chromium-codecs-ffmpeg-extra (77.0.3865.90-0ubuntu0.18.04.1) ...
Selecting previously unselected package chromium-browser.
Preparing to unpack .../102-chromium-browser_77.0.3865.90-0ubuntu0.18.04.1_armhf.deb ...
Unpacking chromium-browser (77.0.3865.90-0ubuntu0.18.04.1) ...
Selecting previously unselected package libgnome-keyring-common.
Preparing to unpack .../103-libgnome-keyring-common_3.12.0-1build1_all.deb ...
Unpacking libgnome-keyring-common (3.12.0-1build1) ...
Selecting previously unselected package libgnome-keyring0:armhf.
Preparing to unpack .../104-libgnome-keyring0_3.12.0-1build1_armhf.deb ...
Unpacking libgnome-keyring0:armhf (3.12.0-1build1) ...
Selecting previously unselected package libogg0:armhf.
Preparing to unpack .../105-libogg0_1.3.2-1_armhf.deb ...
Unpacking libogg0:armhf (1.3.2-1) ...
Selecting previously unselected package libice6:armhf.
Preparing to unpack .../106-libice6_2%3a1.0.9-2_armhf.deb ...
Unpacking libice6:armhf (2:1.0.9-2) ...
Selecting previously unselected package libsm6:armhf.
Preparing to unpack .../107-libsm6_2%3a1.2.2-1_armhf.deb ...
Unpacking libsm6:armhf (2:1.2.2-1) ...
Selecting previously unselected package libcap2:armhf.
Preparing to unpack .../108-libcap2_1%3a2.25-1.2_armhf.deb ...
Unpacking libcap2:armhf (1:2.25-1.2) ...
Selecting previously unselected package libdbus-glib-1-2:armhf.
Preparing to unpack .../109-libdbus-glib-1-2_0.110-2_armhf.deb ...
Unpacking libdbus-glib-1-2:armhf (0.110-2) ...
Selecting previously unselected package gconf2-common.
Preparing to unpack .../110-gconf2-common_3.2.6-4ubuntu1_all.deb ...
Unpacking gconf2-common (3.2.6-4ubuntu1) ...
Selecting previously unselected package libgconf-2-4:armhf.
Preparing to unpack .../111-libgconf-2-4_3.2.6-4ubuntu1_armhf.deb ...
Unpacking libgconf-2-4:armhf (3.2.6-4ubuntu1) ...
Selecting previously unselected package libroken18-heimdal:armhf.
Preparing to unpack .../112-libroken18-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libroken18-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libasn1-8-heimdal:armhf.
Preparing to unpack .../113-libasn1-8-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libasn1-8-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libheimbase1-heimdal:armhf.
Preparing to unpack .../114-libheimbase1-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libheimbase1-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libhcrypto4-heimdal:armhf.
Preparing to unpack .../115-libhcrypto4-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libhcrypto4-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libwind0-heimdal:armhf.
Preparing to unpack .../116-libwind0-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libwind0-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libhx509-5-heimdal:armhf.
Preparing to unpack .../117-libhx509-5-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libhx509-5-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libkrb5-26-heimdal:armhf.
Preparing to unpack .../118-libkrb5-26-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libkrb5-26-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libheimntlm0-heimdal:armhf.
Preparing to unpack .../119-libheimntlm0-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libheimntlm0-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libgssapi3-heimdal:armhf.
Preparing to unpack .../120-libgssapi3-heimdal_7.5.0+dfsg-1_armhf.deb ...
Unpacking libgssapi3-heimdal:armhf (7.5.0+dfsg-1) ...
Selecting previously unselected package libsasl2-modules-db:armhf.
Preparing to unpack .../121-libsasl2-modules-db_2.1.27~101-g0780600+dfsg-3ubuntu2_armhf.deb ...
Unpacking libsasl2-modules-db:armhf (2.1.27~101-g0780600+dfsg-3ubuntu2) ...
Selecting previously unselected package libsasl2-2:armhf.
Preparing to unpack .../122-libsasl2-2_2.1.27~101-g0780600+dfsg-3ubuntu2_armhf.deb ...
Unpacking libsasl2-2:armhf (2.1.27~101-g0780600+dfsg-3ubuntu2) ...
Selecting previously unselected package libldap-common.
Preparing to unpack .../123-libldap-common_2.4.45+dfsg-1ubuntu1.4_all.deb ...
Unpacking libldap-common (2.4.45+dfsg-1ubuntu1.4) ...
Selecting previously unselected package libldap-2.4-2:armhf.
Preparing to unpack .../124-libldap-2.4-2_2.4.45+dfsg-1ubuntu1.4_armhf.deb ...
Unpacking libldap-2.4-2:armhf (2.4.45+dfsg-1ubuntu1.4) ...
Selecting previously unselected package gconf-service-backend.
Preparing to unpack .../125-gconf-service-backend_3.2.6-4ubuntu1_armhf.deb ...
Unpacking gconf-service-backend (3.2.6-4ubuntu1) ...
Selecting previously unselected package gconf-service.
Preparing to unpack .../126-gconf-service_3.2.6-4ubuntu1_armhf.deb ...
Unpacking gconf-service (3.2.6-4ubuntu1) ...
Selecting previously unselected package libasyncns0:armhf.
Preparing to unpack .../127-libasyncns0_0.8-6_armhf.deb ...
Unpacking libasyncns0:armhf (0.8-6) ...
Selecting previously unselected package libflac8:armhf.
Preparing to unpack .../128-libflac8_1.3.2-1_armhf.deb ...
Unpacking libflac8:armhf (1.3.2-1) ...
Selecting previously unselected package libgtk2.0-common.
Preparing to unpack .../129-libgtk2.0-common_2.24.32-1ubuntu1_all.deb ...
Unpacking libgtk2.0-common (2.24.32-1ubuntu1) ...
Selecting previously unselected package libgtk2.0-0:armhf.
Preparing to unpack .../130-libgtk2.0-0_2.24.32-1ubuntu1_armhf.deb ...
Unpacking libgtk2.0-0:armhf (2.24.32-1ubuntu1) ...
Selecting previously unselected package libvorbis0a:armhf.
Preparing to unpack .../131-libvorbis0a_1.3.5-4.2_armhf.deb ...
Unpacking libvorbis0a:armhf (1.3.5-4.2) ...
Selecting previously unselected package libvorbisenc2:armhf.
Preparing to unpack .../132-libvorbisenc2_1.3.5-4.2_armhf.deb ...
Unpacking libvorbisenc2:armhf (1.3.5-4.2) ...
Selecting previously unselected package libsndfile1:armhf.
Preparing to unpack .../133-libsndfile1_1.0.28-4ubuntu0.18.04.1_armhf.deb ...
Unpacking libsndfile1:armhf (1.0.28-4ubuntu0.18.04.1) ...
Selecting previously unselected package libwrap0:armhf.
Preparing to unpack .../134-libwrap0_7.6.q-27_armhf.deb ...
Unpacking libwrap0:armhf (7.6.q-27) ...
Selecting previously unselected package libpulse0:armhf.
Preparing to unpack .../135-libpulse0_1%3a11.1-1ubuntu7.2_armhf.deb ...
Unpacking libpulse0:armhf (1:11.1-1ubuntu7.2) ...
Selecting previously unselected package libpulsedsp:armhf.
Preparing to unpack .../136-libpulsedsp_1%3a11.1-1ubuntu7.2_armhf.deb ...
Unpacking libpulsedsp:armhf (1:11.1-1ubuntu7.2) ...
Selecting previously unselected package pulseaudio-utils.
Preparing to unpack .../137-pulseaudio-utils_1%3a11.1-1ubuntu7.2_armhf.deb ...
Unpacking pulseaudio-utils (1:11.1-1ubuntu7.2) ...
Setting up libexpat1:armhf (2.2.5-3ubuntu0.2) ...
Setting up libicu60:armhf (60.2-3ubuntu3) ...
Setting up libjson-glib-1.0-common (1.4.2-3) ...
Setting up libgtk2.0-common (2.24.32-1ubuntu1) ...
Setting up libgnome-keyring-common (3.12.0-1build1) ...
Setting up libasyncns0:armhf (0.8-6) ...
Setting up glib-networking-common (2.56.0-1) ...
Setting up libpng16-16:armhf (1.6.34-1ubuntu0.18.04.2) ...
Setting up liblcms2-2:armhf (2.9-1ubuntu0.1) ...
Setting up libjbig0:armhf (2.1-3.1build1) ...
Setting up libldap-common (2.4.45+dfsg-1ubuntu1.4) ...
Setting up fonts-dejavu-core (2.37-1) ...
Setting up libglib2.0-0:armhf (2.56.4-0ubuntu0.18.04.4) ...
Setting up libasound2-data (1.1.3-5ubuntu0.2) ...
Setting up libcap2:armhf (1:2.25-1.2) ...
Setting up libwayland-client0:armhf (1.16.0-1ubuntu1.1~18.04.1) ...
Setting up xkb-data (2.23.1-1ubuntu1.18.04.1) ...
Setting up libsasl2-modules-db:armhf (2.1.27~101-g0780600+dfsg-3ubuntu2) ...
Setting up libproxy1v5:armhf (0.4.15-1) ...
Setting up libsasl2-2:armhf (2.1.27~101-g0780600+dfsg-3ubuntu2) ...
Setting up libgdk-pixbuf2.0-common (2.36.11-2) ...
Setting up glib-networking-services (2.56.0-1) ...
Setting up libdatrie1:armhf (0.2.10-7) ...
Setting up libjpeg-turbo8:armhf (1.5.2-0ubuntu5.18.04.1) ...
Setting up libroken18-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libbsd0:armhf (0.8.7-1) ...
Setting up libkrb5support0:armhf (1.16-2ubuntu0.1) ...
Setting up libnspr4:armhf (2:4.18-1ubuntu1) ...
Setting up ucf (3.0038) ...
Setting up libxml2:armhf (2.9.4+dfsg1-6.1ubuntu1.2) ...
Setting up libfreetype6:armhf (2.8.1-2ubuntu2) ...
Setting up libasound2:armhf (1.1.3-5ubuntu0.2) ...
Setting up libjson-glib-1.0-0:armhf (1.4.2-3) ...
Setting up libgraphite2-3:armhf (1.3.11-2) ...
Setting up libcroco3:armhf (0.6.12-2) ...
Setting up libogg0:armhf (1.3.2-1) ...
Setting up libatk1.0-data (2.28.1-1) ...
Setting up libx11-xcb1:armhf (2:1.6.4-3ubuntu0.2) ...
Setting up libpixman-1-0:armhf (0.34.0-2) ...
Setting up libepoxy0:armhf (1.4.3-1) ...
Setting up chromium-codecs-ffmpeg-extra (77.0.3865.90-0ubuntu0.18.04.1) ...
Setting up libatk1.0-0:armhf (2.28.1-1) ...
Setting up libheimbase1-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libsqlite3-0:armhf (3.22.0-1ubuntu0.1) ...
Setting up libdconf1:armhf (0.26.0-2ubuntu3) ...
Setting up shared-mime-info (1.9-2) ...
Setting up libxkbcommon0:armhf (0.8.2-1~ubuntu18.04.1) ...
Setting up libcolord2:armhf (1.3.3-2build1) ...
Setting up libthai-data (0.1.27-2) ...
Setting up libxdmcp6:armhf (1:1.1.2-3) ...
Setting up libkeyutils1:armhf (1.5.9-9.2ubuntu2) ...
Setting up libvorbis0a:armhf (1.3.5-4.2) ...
Setting up x11-common (1:7.7+19ubuntu7.1) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Setting up xdg-utils (1.1.2-1ubuntu2.3) ...
Setting up hicolor-icon-theme (0.17-2) ...
Setting up libwayland-cursor0:armhf (1.16.0-1ubuntu1.1~18.04.1) ...
Setting up libwayland-egl1:armhf (1.16.0-1ubuntu1.1~18.04.1) ...
Setting up libx11-data (2:1.6.4-3ubuntu0.2) ...
Setting up libxau6:armhf (1:1.0.8-1) ...
Setting up libdbus-1-3:armhf (1.12.2-1ubuntu1.1) ...
Setting up libwrap0:armhf (7.6.q-27) ...
Setting up libavahi-common-data:armhf (0.7-3.1ubuntu1.2) ...
Setting up libjpeg8:armhf (8c-2ubuntu8) ...
Setting up gconf2-common (3.2.6-4ubuntu1) ...
Creating config file /etc/gconf/2/path with new version
Setting up libk5crypto3:armhf (1.16-2ubuntu0.1) ...
Setting up fontconfig-config (2.12.6-0ubuntu2) ...
Setting up libwind0-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up dconf-service (0.26.0-2ubuntu3) ...
Setting up libdbus-glib-1-2:armhf (0.110-2) ...
Setting up libasn1-8-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libgconf-2-4:armhf (3.2.6-4ubuntu1) ...
Setting up libhcrypto4-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libflac8:armhf (1.3.2-1) ...
Setting up libnss3:armhf (2:3.35-2ubuntu2.3) ...
Setting up libharfbuzz0b:armhf (1.7.2-1ubuntu1) ...
Setting up libtiff5:armhf (4.0.9-5ubuntu0.3) ...
Setting up libthai0:armhf (0.1.27-2) ...
Setting up libhx509-5-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libgnome-keyring0:armhf (3.12.0-1build1) ...
Setting up libice6:armhf (2:1.0.9-2) ...
Setting up libkrb5-3:armhf (1.16-2ubuntu0.1) ...
Setting up libavahi-common3:armhf (0.7-3.1ubuntu1.2) ...
Setting up libkrb5-26-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libvorbisenc2:armhf (1.3.5-4.2) ...
Setting up dconf-gsettings-backend:armhf (0.26.0-2ubuntu3) ...
Setting up libxcb1:armhf (1.13-2~ubuntu18.04) ...
Setting up libheimntlm0-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up libfontconfig1:armhf (2.12.6-0ubuntu2) ...
Setting up libsm6:armhf (2:1.2.2-1) ...
Setting up libxcb-render0:armhf (1.13-2~ubuntu18.04) ...
Setting up gsettings-desktop-schemas (3.28.0-1ubuntu1) ...
Setting up libgtk-3-common (3.22.30-1ubuntu4) ...
Setting up libx11-6:armhf (2:1.6.4-3ubuntu0.2) ...
Setting up libgssapi-krb5-2:armhf (1.16-2ubuntu0.1) ...
Setting up libsndfile1:armhf (1.0.28-4ubuntu0.18.04.1) ...
Setting up glib-networking:armhf (2.56.0-1) ...
Setting up libxcomposite1:armhf (1:0.4.4-2) ...
Setting up libxcb-shm0:armhf (1.13-2~ubuntu18.04) ...
Setting up libxrender1:armhf (1:0.9.10-1) ...
Setting up libavahi-client3:armhf (0.7-3.1ubuntu1.2) ...
Setting up libgssapi3-heimdal:armhf (7.5.0+dfsg-1) ...
Setting up fontconfig (2.12.6-0ubuntu2) ...
Regenerating fonts cache... done.
Setting up libcups2:armhf (2.2.7-1ubuntu2.7) ...
Setting up libxdamage1:armhf (1:1.1.4-3) ...
Setting up libxext6:armhf (2:1.3.3-1) ...
Setting up libxfixes3:armhf (1:5.0.3-1) ...
Setting up libatspi2.0-0:armhf (2.28.0-1) ...
Setting up libxss1:armhf (1:1.2.2-1) ...
Setting up libgdk-pixbuf2.0-0:armhf (2.36.11-2) ...
Setting up libsoup2.4-1:armhf (2.62.1-1ubuntu0.4) ...
Setting up libsoup-gnome2.4-1:armhf (2.62.1-1ubuntu0.4) ...
Setting up libpulse0:armhf (1:11.1-1ubuntu7.2) ...
Setting up libxtst6:armhf (2:1.2.3-1) ...
Setting up gtk-update-icon-cache (3.22.30-1ubuntu4) ...
Setting up libxcursor1:armhf (1:1.1.15-1) ...
Setting up libldap-2.4-2:armhf (2.4.45+dfsg-1ubuntu1.4) ...
Setting up libpango-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Setting up libatk-bridge2.0-0:armhf (2.26.2-1) ...
Setting up librest-0.7-0:armhf (0.8.0-2) ...
Setting up libxrandr2:armhf (2:1.5.1-1) ...
Setting up libxi6:armhf (2:1.7.9-1) ...
Setting up libcairo2:armhf (1.15.10-2ubuntu0.1) ...
Setting up libxinerama1:armhf (2:1.1.3-1) ...
Setting up libpulsedsp:armhf (1:11.1-1ubuntu7.2) ...
Setting up pulseaudio-utils (1:11.1-1ubuntu7.2) ...
Setting up libcairo-gobject2:armhf (1.15.10-2ubuntu0.1) ...
Setting up libpangoft2-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Setting up libpangocairo-1.0-0:armhf (1.40.14-1ubuntu0.1) ...
Setting up librsvg2-2:armhf (2.40.20-2) ...
Setting up librsvg2-common:armhf (2.40.20-2) ...
Setting up gconf-service-backend (3.2.6-4ubuntu1) ...
Setting up adwaita-icon-theme (3.28.0-1ubuntu1) ...
update-alternatives: using /usr/share/icons/Adwaita/cursor.theme to provide /usr/share/icons/default/index.theme (x-cursor-theme) in auto mode
Setting up libgtk2.0-0:armhf (2.24.32-1ubuntu1) ...
Setting up humanity-icon-theme (0.6.15) ...
Setting up libgtk-3-0:armhf (3.22.30-1ubuntu4) ...
Setting up gconf-service (3.2.6-4ubuntu1) ...
Setting up chromium-browser (77.0.3865.90-0ubuntu0.18.04.1) ...
update-alternatives: using /usr/bin/chromium-browser to provide /usr/bin/x-www-browser (x-www-browser) in auto mode
update-alternatives: using /usr/bin/chromium-browser to provide /usr/bin/gnome-www-browser (gnome-www-browser) in auto mode
Setting up ubuntu-mono (16.10+18.04.20181005-0ubuntu1) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for libgdk-pixbuf2.0-0:armhf (2.36.11-2) ...
Removing intermediate container 81f02b1f1731
 ---> eb387f8202a8
Step 5/17 : ADD chromium-settings /etc/chromium-browser/default
 ---> 3637c115d2c8
Step 6/17 : ADD packages/ /tmp/custompkgs
 ---> dcce6ebaeda8
Step 7/17 : RUN dpkg --unpack /tmp/custompkgs/*.deb
 ---> Running in 22ded5c68ff7
Selecting previously unselected package chromium-streaming.
(Reading database ... 19211 files and directories currently installed.)
Preparing to unpack .../chromium-streaming_2.0-armbian_armhf.deb ...
Unpacking chromium-streaming (2.0-armbian) ...
Selecting previously unselected package libmali-rk-midgard-t86x-r14p0-r0p0:armhf.
Preparing to unpack .../libmali-rk-midgard-t86x-r14p0-r0p0_1.6-1-0armbian1_armhf.deb ...
Unpacking libmali-rk-midgard-t86x-r14p0-r0p0:armhf (1.6-1-0armbian1) ...
Removing intermediate container 22ded5c68ff7
 ---> cdee543f47ea
Step 8/17 : RUN apt-get -f -y install
 ---> Running in 90b2465ea83f
Reading package lists...
Building dependency tree...
Reading state information...
Correcting dependencies... Done
The following additional packages will be installed:
  libdrm-common libdrm2 libxcb-dri2-0
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
2 not fully installed or removed.
Need to get 39.2 kB of archives.
After this operation, 167 kB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdrm-common all 2.4.97-1ubuntu1~18.04.1 [5216 B]
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libdrm2 armhf 2.4.97-1ubuntu1~18.04.1 [27.3 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libxcb-dri2-0 armhf 1.13-2~ubuntu18.04 [6716 B]
[0mFetched 39.2 kB in 0s (215 kB/s)
Selecting previously unselected package libdrm-common.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 19246 files and directories currently installed.)
Preparing to unpack .../libdrm-common_2.4.97-1ubuntu1~18.04.1_all.deb ...
Unpacking libdrm-common (2.4.97-1ubuntu1~18.04.1) ...
Selecting previously unselected package libdrm2:armhf.
Preparing to unpack .../libdrm2_2.4.97-1ubuntu1~18.04.1_armhf.deb ...
Unpacking libdrm2:armhf (2.4.97-1ubuntu1~18.04.1) ...
Selecting previously unselected package libxcb-dri2-0:armhf.
Preparing to unpack .../libxcb-dri2-0_1.13-2~ubuntu18.04_armhf.deb ...
Unpacking libxcb-dri2-0:armhf (1.13-2~ubuntu18.04) ...
Setting up libxcb-dri2-0:armhf (1.13-2~ubuntu18.04) ...
Setting up libdrm-common (2.4.97-1ubuntu1~18.04.1) ...
Setting up chromium-streaming (2.0-armbian) ...
Setting up libdrm2:armhf (2.4.97-1ubuntu1~18.04.1) ...
Setting up libmali-rk-midgard-t86x-r14p0-r0p0:armhf (1.6-1-0armbian1) ...
Removing intermediate container 90b2465ea83f
 ---> 0cca778dc12c
Step 9/17 : RUN rm -rf /tmp/custompkgs
 ---> Running in 37ccbb59b790
Removing intermediate container 37ccbb59b790
 ---> 84722f17699f
Step 10/17 : ADD chromium-streaming /usr/bin/chromium-streaming
 ---> 59a48e8757eb
Step 11/17 : RUN chmod +x /usr/bin/chromium-streaming
 ---> Running in c6e1e4f82c34
Removing intermediate container c6e1e4f82c34
 ---> 54f56829f20b
Step 12/17 : COPY pulse-client.conf /etc/pulse/client.conf
 ---> 74e2aac3bd4c
Step 13/17 : ENV UNAME mediaguy
 ---> Running in 4f9c77a08351
Removing intermediate container 4f9c77a08351
 ---> bc5562588f88
Step 14/17 : RUN export UNAME=$UNAME UID=1000 GID=1000 &&     mkdir -p "/home/${UNAME}" &&     echo "${UNAME}:x:${UID}:${GID}:${UNAME} User,,,:/home/${UNAME}:/bin/bash" >> /etc/passwd &&     echo "${UNAME}:x:${UID}:" >> /etc/group &&     mkdir -p /etc/sudoers.d &&     echo "${UNAME} ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/${UNAME} &&     chmod 0440 /etc/sudoers.d/${UNAME} &&     chown ${UID}:${GID} -R /home/${UNAME} &&     gpasswd -a ${UNAME} audio
 ---> Running in a5ef6745120b
Adding user mediaguy to group audio
Removing intermediate container a5ef6745120b
 ---> 574dd0ad9e2f
Step 15/17 : USER $UNAME
 ---> Running in c39a9312906b
Removing intermediate container c39a9312906b
 ---> 188e81c0bff8
Step 16/17 : ENV HOME /home/${UNAME}
 ---> Running in 8467865ccab7
Removing intermediate container 8467865ccab7
 ---> dafbe4546f0b
Step 17/17 : CMD [ "chromium-streaming" ]
 ---> Running in eeaa44109a07
Removing intermediate container eeaa44109a07
 ---> f2e29cd008a1
Successfully built f2e29cd008a1
Successfully tagged teacupx/chromium-armhf:latest
chromium_home
*             Installing GL4ES wrapper            *
opt/
opt/gl4es/
opt/gl4es/libGL.so
opt/gl4es/libGL.so.1
usr/
usr/bin/
usr/bin/glrun
*       Installing Pulseaudio GTK Equalizer       *
Selecting previously unselected package pulseaudio-equalizer.
(Reading database ... 82306 files and directories currently installed.)
Preparing to unpack .../pulseaudio-equalizer_2.7.0.2-6_all.deb ...
Unpacking pulseaudio-equalizer (2:2.7.0.2-6) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for mime-support (3.60ubuntu1) ...
The following packages were automatically installed and are no longer required:
  libavdevice57 libavfilter6 libavformat57 libavresample3 libmysofa0 libnorm1
  libpgm-5.2-0 libpostproc54 libsodium23 libssh-gcrypt-4 libswscale4
  libva-wayland2 libzmq5
Use 'sudo apt autoremove' to remove them.
  ladspa-sdk libidl-2-0 liborbit2 python-gconf python-gi python-glade2
  python-gnome2 python-gobject python-pyorbit swh-plugins
Suggested packages:
  python-gnome2-doc python-gi-cairo python-gtk2-doc
0 upgraded, 10 newly installed, 0 to remove and 1 not upgraded.
1 not fully installed or removed.
Need to get 877 kB of archives.
After this operation, 4178 kB of additional disk space will be used.
Get:1 http://ports.ubuntu.com bionic/universe arm64 swh-plugins arm64 0.4.17-2 [392 kB]
Get:2 http://ports.ubuntu.com bionic/universe arm64 ladspa-sdk arm64 1.13-3ubuntu2 [33.8 kB]
Get:3 http://ports.ubuntu.com bionic/universe arm64 python-glade2 arm64 2.24.0-5.1ubuntu2 [8072 B]
Get:4 http://ports.ubuntu.com bionic-updates/main arm64 python-gi arm64 3.26.1-2ubuntu1 [182 kB]
Get:5 http://ports.ubuntu.com bionic-updates/universe arm64 python-gobject all 3.26.1-2ubuntu1 [2624 B]
Get:6 http://ports.ubuntu.com bionic/universe arm64 python-gconf arm64 2.28.1+dfsg-1.2 [18.6 kB]
Get:7 http://ports.ubuntu.com bionic/universe arm64 libidl-2-0 arm64 0.8.14-4 [60.4 kB]
Get:8 http://ports.ubuntu.com bionic/universe arm64 liborbit2 arm64 1:2.14.19-4 [12.9 kB]
Get:9 http://ports.ubuntu.com bionic/universe arm64 python-pyorbit arm64 2.24.0-7.2 [53.0 kB]
Get:10 http://ports.ubuntu.com bionic/universe arm64 python-gnome2 arm64 2.28.1+dfsg-1.2 [114 kB]
Fetched 877 kB in 2s (498 kB/s)
Selecting previously unselected package swh-plugins.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 82339 files and directories currently installed.)
Preparing to unpack .../0-swh-plugins_0.4.17-2_arm64.deb ...
Unpacking swh-plugins (0.4.17-2) ...
Selecting previously unselected package ladspa-sdk.
Preparing to unpack .../1-ladspa-sdk_1.13-3ubuntu2_arm64.deb ...
Unpacking ladspa-sdk (1.13-3ubuntu2) ...
Selecting previously unselected package python-glade2.
Preparing to unpack .../2-python-glade2_2.24.0-5.1ubuntu2_arm64.deb ...
Unpacking python-glade2 (2.24.0-5.1ubuntu2) ...
Selecting previously unselected package python-gi.
Preparing to unpack .../3-python-gi_3.26.1-2ubuntu1_arm64.deb ...
Unpacking python-gi (3.26.1-2ubuntu1) ...
Selecting previously unselected package python-gobject.
Preparing to unpack .../4-python-gobject_3.26.1-2ubuntu1_all.deb ...
Unpacking python-gobject (3.26.1-2ubuntu1) ...
Selecting previously unselected package python-gconf.
Preparing to unpack .../5-python-gconf_2.28.1+dfsg-1.2_arm64.deb ...
Unpacking python-gconf (2.28.1+dfsg-1.2) ...
Selecting previously unselected package libidl-2-0:arm64.
Preparing to unpack .../6-libidl-2-0_0.8.14-4_arm64.deb ...
Unpacking libidl-2-0:arm64 (0.8.14-4) ...
Selecting previously unselected package liborbit2:arm64.
Preparing to unpack .../7-liborbit2_1%3a2.14.19-4_arm64.deb ...
Unpacking liborbit2:arm64 (1:2.14.19-4) ...
Selecting previously unselected package python-pyorbit.
Preparing to unpack .../8-python-pyorbit_2.24.0-7.2_arm64.deb ...
Unpacking python-pyorbit (2.24.0-7.2) ...
Selecting previously unselected package python-gnome2.
Preparing to unpack .../9-python-gnome2_2.28.1+dfsg-1.2_arm64.deb ...
Unpacking python-gnome2 (2.28.1+dfsg-1.2) ...
Setting up python-gconf (2.28.1+dfsg-1.2) ...
Setting up swh-plugins (0.4.17-2) ...
Setting up libidl-2-0:arm64 (0.8.14-4) ...
Setting up ladspa-sdk (1.13-3ubuntu2) ...
Setting up liborbit2:arm64 (1:2.14.19-4) ...
Setting up python-gi (3.26.1-2ubuntu1) ...
Setting up python-glade2 (2.24.0-5.1ubuntu2) ...
Setting up python-pyorbit (2.24.0-7.2) ...
Setting up python-gnome2 (2.28.1+dfsg-1.2) ...
Setting up python-gobject (3.26.1-2ubuntu1) ...
Setting up pulseaudio-equalizer (2:2.7.0.2-6) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
*      Installing accelerated Kodi 18.0-rc4       *
Package 'libkodiplatform16v4' is not installed, so not removed
Package 'kodiplatform' is not installed, so not removed
Package 'kodi' is not installed, so not removed
Package 'kodi-addons-dev' is not installed, so not removed
Package 'kodi-bin' is not installed, so not removed
Package 'kodi-data' is not installed, so not removed
Package 'kodi-eventclients-common' is not installed, so not removed
Package 'kodi-eventclients-dev' is not installed, so not removed
Package 'kodi-eventclients-kodi-send' is not installed, so not removed
Package 'kodi-eventclients-ps3' is not installed, so not removed
Package 'kodi-eventclients-wiiremote' is not installed, so not removed
Package 'kodi-pvr-argustv' is not installed, so not removed
Package 'kodi-pvr-dvbviewer' is not installed, so not removed
Package 'kodi-pvr-hdhomerun' is not installed, so not removed
Package 'kodi-pvr-hts' is not installed, so not removed
Package 'kodi-pvr-iptvsimple' is not installed, so not removed
Package 'kodi-pvr-mediaportal-tvserver' is not installed, so not removed
Package 'kodi-pvr-mythtv' is not installed, so not removed
Package 'kodi-pvr-nextpvr' is not installed, so not removed
Package 'kodi-pvr-njoy' is not installed, so not removed
Package 'kodi-pvr-vdr-vnsi' is not installed, so not removed
Package 'kodi-pvr-vuplus' is not installed, so not removed
Package 'kodi-pvr-wmc' is not installed, so not removed
Package 'kodi-repository-kodi' is not installed, so not removed
Package 'kodi-visualization-spectrum' is not installed, so not removed
Package 'libkodiplatform-dev' is not installed, so not removed
Package 'libkodiplatform16' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
  libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd-dev
  libavahi-compat-libdnssd1 libdbus-1-dev pkg-config
Recommended packages:
  libnss-mdns
  flatbuffers libavahi-client-dev libavahi-common-dev
  libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-dev
  libshairplay0 libwayland-client++ libwayland-client-extra++
  libwayland-cursor++ libwayland-egl++ pkg-config shairplay wayland-scanner++
0 upgraded, 14 newly installed, 0 to remove and 1 not upgraded.
Need to get 302 kB/897 kB of archives.
After this operation, 3962 kB of additional disk space will be used.
Get:1 /home/nicod/media-script/packages/kodi/deps/flatbuffers_1.9.0-2~bionic_arm64.deb flatbuffers arm64 1.9.0-2~bionic [358 kB]
Get:2 /home/nicod/media-script/packages/kodi/deps/libwayland-client++_0.2.3-1~bionic_arm64.deb libwayland-client++ arm64 0.2.3-1~bionic [59.8 kB]
Get:3 /home/nicod/media-script/packages/kodi/deps/libwayland-client-extra++_0.2.3-1~bionic_arm64.deb libwayland-client-extra++ arm64 0.2.3-1~bionic [26.1 kB]
Get:4 /home/nicod/media-script/packages/kodi/deps/libwayland-cursor++_0.2.3-1~bionic_arm64.deb libwayland-cursor++ arm64 0.2.3-1~bionic [7084 B]
Get:5 /home/nicod/media-script/packages/kodi/deps/libwayland-egl++_0.2.3-1~bionic_arm64.deb libwayland-egl++ arm64 0.2.3-1~bionic [5484 B]
Get:6 /home/nicod/media-script/packages/kodi/deps/wayland-scanner++_0.2.3-1~bionic_arm64.deb wayland-scanner++ arm64 0.2.3-1~bionic [88.4 kB]
Get:7 /home/nicod/media-script/packages/kodi/deps/libshairplay0_0.9.0.1-2~bionic_arm64.deb libshairplay0 arm64 0.9.0.1-2~bionic [40.2 kB]
Get:8 /home/nicod/media-script/packages/kodi/deps/shairplay_0.9.0.1-2~bionic_arm64.deb shairplay arm64 0.9.0.1-2~bionic [9984 B]
Get:9 http://ports.ubuntu.com bionic-security/main arm64 libavahi-common-dev arm64 0.7-3.1ubuntu1.2 [35.0 kB]
Get:10 http://ports.ubuntu.com bionic/main arm64 pkg-config arm64 0.29.1-0ubuntu2 [42.8 kB]
Get:11 http://ports.ubuntu.com bionic-security/main arm64 libdbus-1-dev arm64 1.12.2-1ubuntu1.1 [150 kB]
Get:12 http://ports.ubuntu.com bionic-security/main arm64 libavahi-client-dev arm64 0.7-3.1ubuntu1.2 [29.6 kB]
Get:13 http://ports.ubuntu.com bionic-security/main arm64 libavahi-compat-libdnssd1 arm64 0.7-3.1ubuntu1.2 [14.1 kB]
Get:14 http://ports.ubuntu.com bionic-security/main arm64 libavahi-compat-libdnssd-dev arm64 0.7-3.1ubuntu1.2 [30.3 kB]
Fetched 302 kB in 0s (610 kB/s)
Selecting previously unselected package flatbuffers:arm64.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 82586 files and directories currently installed.)
Preparing to unpack .../00-flatbuffers_1.9.0-2~bionic_arm64.deb ...
Unpacking flatbuffers:arm64 (1.9.0-2~bionic) ...
Selecting previously unselected package libavahi-common-dev:arm64.
Preparing to unpack .../01-libavahi-common-dev_0.7-3.1ubuntu1.2_arm64.deb ...
Unpacking libavahi-common-dev:arm64 (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package pkg-config.
Preparing to unpack .../02-pkg-config_0.29.1-0ubuntu2_arm64.deb ...
Unpacking pkg-config (0.29.1-0ubuntu2) ...
Selecting previously unselected package libdbus-1-dev:arm64.
Preparing to unpack .../03-libdbus-1-dev_1.12.2-1ubuntu1.1_arm64.deb ...
Unpacking libdbus-1-dev:arm64 (1.12.2-1ubuntu1.1) ...
Selecting previously unselected package libavahi-client-dev:arm64.
Preparing to unpack .../04-libavahi-client-dev_0.7-3.1ubuntu1.2_arm64.deb ...
Unpacking libavahi-client-dev:arm64 (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libavahi-compat-libdnssd1:arm64.
Preparing to unpack .../05-libavahi-compat-libdnssd1_0.7-3.1ubuntu1.2_arm64.deb ...
Unpacking libavahi-compat-libdnssd1:arm64 (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev:arm64.
Preparing to unpack .../06-libavahi-compat-libdnssd-dev_0.7-3.1ubuntu1.2_arm64.deb ...
Unpacking libavahi-compat-libdnssd-dev:arm64 (0.7-3.1ubuntu1.2) ...
Selecting previously unselected package libwayland-client++:arm64.
Preparing to unpack .../07-libwayland-client++_0.2.3-1~bionic_arm64.deb ...
Unpacking libwayland-client++:arm64 (0.2.3-1~bionic) ...
Selecting previously unselected package libwayland-client-extra++:arm64.
Preparing to unpack .../08-libwayland-client-extra++_0.2.3-1~bionic_arm64.deb ...
Unpacking libwayland-client-extra++:arm64 (0.2.3-1~bionic) ...
Selecting previously unselected package libwayland-cursor++:arm64.
Preparing to unpack .../09-libwayland-cursor++_0.2.3-1~bionic_arm64.deb ...
Unpacking libwayland-cursor++:arm64 (0.2.3-1~bionic) ...
Selecting previously unselected package libwayland-egl++:arm64.
Preparing to unpack .../10-libwayland-egl++_0.2.3-1~bionic_arm64.deb ...
Unpacking libwayland-egl++:arm64 (0.2.3-1~bionic) ...
Selecting previously unselected package wayland-scanner++:arm64.
Preparing to unpack .../11-wayland-scanner++_0.2.3-1~bionic_arm64.deb ...
Unpacking wayland-scanner++:arm64 (0.2.3-1~bionic) ...
Selecting previously unselected package libshairplay0:arm64.
Preparing to unpack .../12-libshairplay0_0.9.0.1-2~bionic_arm64.deb ...
Unpacking libshairplay0:arm64 (0.9.0.1-2~bionic) ...
Selecting previously unselected package shairplay.
Preparing to unpack .../13-shairplay_0.9.0.1-2~bionic_arm64.deb ...
Unpacking shairplay (0.9.0.1-2~bionic) ...
Setting up libwayland-client++:arm64 (0.2.3-1~bionic) ...
Setting up wayland-scanner++:arm64 (0.2.3-1~bionic) ...
Setting up libshairplay0:arm64 (0.9.0.1-2~bionic) ...
Setting up libwayland-egl++:arm64 (0.2.3-1~bionic) ...
Setting up libwayland-cursor++:arm64 (0.2.3-1~bionic) ...
Setting up libavahi-common-dev:arm64 (0.7-3.1ubuntu1.2) ...
Setting up libavahi-compat-libdnssd1:arm64 (0.7-3.1ubuntu1.2) ...
Setting up flatbuffers:arm64 (1.9.0-2~bionic) ...
Setting up pkg-config (0.29.1-0ubuntu2) ...
Setting up libwayland-client-extra++:arm64 (0.2.3-1~bionic) ...
Setting up libdbus-1-dev:arm64 (1.12.2-1ubuntu1.1) ...
Setting up libavahi-client-dev:arm64 (0.7-3.1ubuntu1.2) ...
Setting up libavahi-compat-libdnssd-dev:arm64 (0.7-3.1ubuntu1.2) ...
Setting up shairplay (0.9.0.1-2~bionic) ...
  fonts-liberation libaacs0 libcec4 libfstrcmp0 liblirc-client0
  libmicrohttpd12 libmysqlclient20 libnfs11 libp8-platform2 libpcrecpp0v5
  libtinyxml2.6.2v5 mesa-utils mysql-common python-bluez python-pil
  python-simplejson
Suggested packages:
  kodi-pvr-mythtv kodi-pvr-vuplus kodi-pvr-vdr-vnsi kodi-pvr-njoy
  kodi-pvr-nextpvr kodi-pvr-mediaportal-tvserver kodi-pvr-tvheadend-hts
  kodi-pvr-dvbviewer kodi-pvr-argustv kodi-pvr-iptvsimple
  kodi-audioencoder-vorbis kodi-audioencoder-flac kodi-audioencoder-lame lirc
  python-pil-doc python-pil-dbg
  libva-intel-vaapi-driver libva1 libbdplus0 python-olefile
  fonts-liberation kodi kodi-bin libaacs0 libcec4 libfstrcmp0 liblirc-client0
  python-simplejson
0 upgraded, 18 newly installed, 0 to remove and 1 not upgraded.
Need to get 2468 kB/35.5 MB of archives.
After this operation, 93.9 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com bionic-updates/main arm64 fonts-liberation all 1:1.07.4-7~18.04.1 [822 kB]
Get:2 /home/nicod/media-script/packages/kodi/kodi-bin_18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1_arm64.deb kodi-bin arm64 2:18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1 [13.4 MB]
Get:3 http://ports.ubuntu.com bionic/universe arm64 libp8-platform2 arm64 2.1.0.1+dfsg1-1 [19.8 kB]
Get:4 http://ports.ubuntu.com bionic-updates/universe arm64 libcec4 arm64 4.0.2+dfsg1-2ubuntu1.1 [183 kB]
Get:5 http://ports.ubuntu.com bionic/universe arm64 libfstrcmp0 arm64 0.7.D001-1.1build1 [7176 B]
Get:6 http://ports.ubuntu.com bionic/main arm64 liblirc-client0 arm64 0.10.0-2 [20.0 kB]
Get:7 http://ports.ubuntu.com bionic/universe arm64 libmicrohttpd12 arm64 0.9.59-1 [45.1 kB]
Get:8 http://ports.ubuntu.com bionic/main arm64 mysql-common all 5.8+1.0.4 [7308 B]
Get:9 http://ports.ubuntu.com bionic-security/main arm64 libmysqlclient20 arm64 5.7.27-0ubuntu0.18.04.1 [779 kB]
Get:10 /home/nicod/media-script/packages/kodi/kodi_18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1_all.deb kodi all 2:18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1 [19.7 MB]
Get:11 http://ports.ubuntu.com bionic/universe arm64 libnfs11 arm64 2.0.0-1~exp1 [64.1 kB]
Get:12 http://ports.ubuntu.com bionic/main arm64 libpcrecpp0v5 arm64 2:8.39-9 [15.1 kB]
Get:13 http://ports.ubuntu.com bionic/universe arm64 libtinyxml2.6.2v5 arm64 2.6.2-4 [28.3 kB]
Get:14 http://ports.ubuntu.com bionic/universe arm64 mesa-utils arm64 8.4.0-1 [31.0 kB]
Get:15 http://ports.ubuntu.com bionic/universe arm64 python-bluez arm64 0.22-1 [44.4 kB]
Get:16 http://ports.ubuntu.com bionic/main arm64 python-pil arm64 5.1.0-1 [300 kB]
Get:17 http://ports.ubuntu.com bionic/main arm64 python-simplejson arm64 3.13.2-1 [58.7 kB]
Get:18 http://ports.ubuntu.com bionic/universe arm64 libaacs0 arm64 0.9.0-1 [42.9 kB]
Fetched 2468 kB in 1s (2368 kB/s)
Selecting previously unselected package fonts-liberation.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 82731 files and directories currently installed.)
Preparing to unpack .../00-fonts-liberation_1%3a1.07.4-7~18.04.1_all.deb ...
Unpacking fonts-liberation (1:1.07.4-7~18.04.1) ...
Selecting previously unselected package libp8-platform2:arm64.
Preparing to unpack .../01-libp8-platform2_2.1.0.1+dfsg1-1_arm64.deb ...
Unpacking libp8-platform2:arm64 (2.1.0.1+dfsg1-1) ...
Selecting previously unselected package libcec4:arm64.
Preparing to unpack .../02-libcec4_4.0.2+dfsg1-2ubuntu1.1_arm64.deb ...
Unpacking libcec4:arm64 (4.0.2+dfsg1-2ubuntu1.1) ...
Selecting previously unselected package libfstrcmp0.
Preparing to unpack .../03-libfstrcmp0_0.7.D001-1.1build1_arm64.deb ...
Unpacking libfstrcmp0 (0.7.D001-1.1build1) ...
Selecting previously unselected package liblirc-client0:arm64.
Preparing to unpack .../04-liblirc-client0_0.10.0-2_arm64.deb ...
Unpacking liblirc-client0:arm64 (0.10.0-2) ...
Selecting previously unselected package libmicrohttpd12.
Preparing to unpack .../05-libmicrohttpd12_0.9.59-1_arm64.deb ...
Unpacking libmicrohttpd12 (0.9.59-1) ...
Selecting previously unselected package mysql-common.
Preparing to unpack .../06-mysql-common_5.8+1.0.4_all.deb ...
Unpacking mysql-common (5.8+1.0.4) ...
Selecting previously unselected package libmysqlclient20:arm64.
Preparing to unpack .../07-libmysqlclient20_5.7.27-0ubuntu0.18.04.1_arm64.deb ...
Unpacking libmysqlclient20:arm64 (5.7.27-0ubuntu0.18.04.1) ...
Selecting previously unselected package libnfs11:arm64.
Preparing to unpack .../08-libnfs11_2.0.0-1~exp1_arm64.deb ...
Unpacking libnfs11:arm64 (2.0.0-1~exp1) ...
Selecting previously unselected package libpcrecpp0v5:arm64.
Preparing to unpack .../09-libpcrecpp0v5_2%3a8.39-9_arm64.deb ...
Unpacking libpcrecpp0v5:arm64 (2:8.39-9) ...
Selecting previously unselected package libtinyxml2.6.2v5:arm64.
Preparing to unpack .../10-libtinyxml2.6.2v5_2.6.2-4_arm64.deb ...
Unpacking libtinyxml2.6.2v5:arm64 (2.6.2-4) ...
Selecting previously unselected package kodi-bin.
Preparing to unpack .../11-kodi-bin_18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1_arm64.deb ...
Unpacking kodi-bin (2:18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1) ...
Selecting previously unselected package mesa-utils.
Preparing to unpack .../12-mesa-utils_8.4.0-1_arm64.deb ...
Unpacking mesa-utils (8.4.0-1) ...
Selecting previously unselected package python-bluez.
Preparing to unpack .../13-python-bluez_0.22-1_arm64.deb ...
Unpacking python-bluez (0.22-1) ...
Selecting previously unselected package python-pil:arm64.
Preparing to unpack .../14-python-pil_5.1.0-1_arm64.deb ...
Unpacking python-pil:arm64 (5.1.0-1) ...
Selecting previously unselected package python-simplejson.
Preparing to unpack .../15-python-simplejson_3.13.2-1_arm64.deb ...
Unpacking python-simplejson (3.13.2-1) ...
Selecting previously unselected package libaacs0:arm64.
Preparing to unpack .../16-libaacs0_0.9.0-1_arm64.deb ...
Unpacking libaacs0:arm64 (0.9.0-1) ...
Selecting previously unselected package kodi.
Preparing to unpack .../17-kodi_18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1_all.deb ...
Unpacking kodi (2:18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1) ...
Setting up python-simplejson (3.13.2-1) ...
Setting up python-bluez (0.22-1) ...
Setting up libtinyxml2.6.2v5:arm64 (2.6.2-4) ...
Setting up libaacs0:arm64 (0.9.0-1) ...
Setting up mysql-common (5.8+1.0.4) ...
update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Setting up liblirc-client0:arm64 (0.10.0-2) ...
Setting up fonts-liberation (1:1.07.4-7~18.04.1) ...
Setting up libnfs11:arm64 (2.0.0-1~exp1) ...
Setting up libp8-platform2:arm64 (2.1.0.1+dfsg1-1) ...
Setting up libpcrecpp0v5:arm64 (2:8.39-9) ...
Setting up libmysqlclient20:arm64 (5.7.27-0ubuntu0.18.04.1) ...
Setting up libmicrohttpd12 (0.9.59-1) ...
Setting up python-pil:arm64 (5.1.0-1) ...
Setting up libfstrcmp0 (0.7.D001-1.1build1) ...
Setting up mesa-utils (8.4.0-1) ...
Setting up libcec4:arm64 (4.0.2+dfsg1-2ubuntu1.1) ...
Setting up kodi-bin (2:18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1) ...
Setting up kodi (2:18.0~git20190107.1219-14086a7bd3-dirty-18.0rc4bionic0bionic-rockchip1) ...
Processing triggers for fontconfig (2.12.6-0ubuntu2) ...
Finished.
On 9/20/2019 at 4:13 AM, JMCC said:
I'd like to, and I started working on a script that would compile the latest versions of the software for a specific distro. Let's see if I can find some time to finish it.
That would be really cool. Seems as with latest buster, it doesn't work all that well now and appears ( at least in chromium ) to be just using CPU and no GPU.    So its back to friendly arm's distro for now. But would rather be using Armbian.  ( which does work fine if you dont need video.  Using it on a 2nd T4  ( + a 1TB M.2 ) i have as a mini server.
You can always use Armbian Bionic default. In my experience it's a lot better than FriendlyDesktop. There Chromium also doesn't seem to work ok while it should be gpu acc. I had to use Firefox for ok video playback.
Maybe it's time to try creating a set with HW acceleration of full screen video playback based on the new kernel 5 ?
All necessary components are already working (tested using LE images with kernel 5 for rk33xx and HW). :)
Ill give it a shot, tho its still a version behind.  That FD isn't the best is one reason i was hoping for this to work on the buster release.   Of course these baords are not really 'made' for desktop, use, an RK3399 can be.. ( as proven by my pinebook pro )
Let's see if I get a chance to look at it. Thanks!
If necessary, I can share links to source and working images where HW runs on RK33xx (LIMA and Panfrost) with kernel 5. :)
LIMA and Panfrost for GPU, but what interface does it use for VPU? Does it support full HW acceleration, up to 4k? And encoding?
V4l2 is used for decoding, not all formats are still supported, but some already work. With 4K while there is a problem with green interference. I didn't check the coding. You can check for yourself which formats work in the latest version of LE (it is universal and works on all rk33xx).
https://forum.libreelec.tv/thread/20823-not-official-le-version-for-rk3328-rk3399/
I can't wait to see the result. Only in mainline I can use the M4 at 2Ghz. But only in default I can use the media script. I'd love to be able to switch. to mainline And I hope the bugs can be worked out of panfrost so gaming will be good. It performs well, if you ignore the messed up textures.
Now working on the Jetson Nano. It's great to have good drivers for it. But the RK3399 is so much more in every way.
I'll keep a look out for the progress. If it's ready I'll for sure make a video about it. Thanks for all the great work.
I've tested it on m4, and I found it very useful but with a lot of defects:
Kodi won't start, it throw me out of x11, and it can't create a gui after that (which is expected).
The chromium on docker doesn't launch at all.
The mpv (gbm) it's unresponsive on the playback manipulation with keyboard. I  could quit but nothing more than that.
Ok, everything is as expected. Kodi and docker-chromium are experimental features, it is normal that they fail. But the main ones seem to be still working. Let's see when can we integrate them into the main build script.
Wouldn't it be better to integrate it in armbian-config?
Then people can still choose to install it or not. It does break some functionality of some programs. For example Kdenlive doesn't work with the script installed(no video playback).  I'll again try to find a fix for it.  But I've put a lot of time into it in the past and couldn't find a solution.
Do you know how it is possible to make VPU acc work in mainline? With that we'd have a perfect image with panfrost + VPU. I'm looking into it, but my knowledge is very limited about this.
Hi everyone,
I'm using Armbian 19.11.7 Rockpi-4b Ubuntu bionic legacy. Kernel: 4.4.208
While starting plaing files I get errors:
$ mpv-gbm ~/Downloads/jellyfish_250_mbps_4k_uhd_hevc_10bit.mkv
Playing: /home/user/Downloads/jellyfish_250_mbps_4k_uhd_hevc_10bit.mkv
 (+) Video --vid=1 (*) (hevc 3840x2160 29.970fps)
[vo/gpu/opengl] Failed to initialize EGL.
[vo/gpu] Failed to setup EGL.
[vo/gpu] Failed initializing any suitable GPU context!
Error opening/initializing the selected video_out (--vo) device.
Video: no video
No video or audio streams selected.
Exiting... (Errors when loading file
# ls /dev/mali*
ls: cannot access '/dev/mali*': No such file or directory
How is it easiest way to switch on HW acceleration plaing files?
media-script install.log
/home/user/media-script/install.log        6335/6335              100%
After this operation, 0 B of additional disk space will be used.
Setting up mpv-rockchip (2:2018.12.12.d6d6da4711-0bionic1) ...
*Installing Gstreamer backport, plugins and player*
libqt5multimedia5 is already the newest version (5.9.5-0ubuntu1).
libqt5multimedia5-plugins is already the newest version (5.9.5-0ubuntu1).
libqt5multimediaquick-p5 is already the newest version (5.9.5-0ubuntu1).
qtgstreamer-plugins-qt5 is already the newest version (1.2.0-5).
qtmultimedia5-doc-html is already the newest version (5.9.5-0ubuntu1).
qtmultimedia5-examples is already the newest version (5.9.5-0ubuntu1).
gstreamer1.0-plugins-base is already the newest version (1.14.5-0ubuntu1~18.04.1).
gstreamer1.0-plugins-base-apps is already the newest version (1.14.5-0ubuntu1~18.04.1).
gstreamer1.0-plugins-good is already the newest version (1.14.5-0ubuntu1~18.04.1).
libqt5core5a is already the newest version (5.9.5+dfsg-0ubuntu2.4).
libqt5gui5 is already the newest version (5.9.5+dfsg-0ubuntu2.4).
libqt5opengl5 is already the newest version (5.9.5+dfsg-0ubuntu2.4).
libqt5widgets5 is already the newest version (5.9.5+dfsg-0ubuntu2.4).
gstreamer1.0-plugins-bad is already the newest version (1.14.5-0ubuntu1~18.04.1).
gstreamer1.0-plugins-ugly is already the newest version (1.14.5-0ubuntu1~18.04.1).
libqt5qml5 is already the newest version (5.9.5-0ubuntu1.1).
libqt5quick5 is already the newest version (5.9.5-0ubuntu1.1).
qml-module-qtquick2 is already the newest version (5.9.5-0ubuntu1.1).
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
(Reading database ... 80031 files and directories currently installed.)
Preparing to unpack .../gstreamer1.0-rockchip1_20181227-0armbian1_arm64.deb ...
Unpacking gstreamer1.0-rockchip1 (20181227-0armbian1) over (20181227-0armbian1) ...
Preparing to unpack .../gstreamer1.0-rockchip1-extra_20181227-0armbian1_arm64.deb ...
Unpacking gstreamer1.0-rockchip1-extra (20181227-0armbian1) over (20181227-0armbian1) ...
Setting up gstreamer1.0-rockchip1-extra (20181227-0armbian1) ...
Setting up gstreamer1.0-rockchip1 (20181227-0armbian1) ...
Finished.
5 hours ago, Gleb_ said:
Hi everyone,
Video: no video
# ls /dev/mali*
  Reveal hidden contents
Finished.
Currently RockPi 4b is not supporting media acceleration. It is a kernel issue, we are working on it. Stay tuned...
Noted
Отправлено с моего PRO 6 Plus через Tapatalk
