New Orange Pi Prime fried? Unable to boot.
seagullstar
Hi,
My Orange Pi Prime stopped working within an hour of use.
Setup:
Orange Pi Prime v1.0 (201811)
Official PSU, rated 5V 3A
Official plastic case (without heatsinks)
Display attached using HDMI
Network attached
100mA keyboard attached
SD Card: Sandisk 64G Ultra
SD Card tested "The real thing"
SD Card formatted to factory defaults
Images (Armbian Stretch next for Orange Pi Prime) checked for authenticity and integrity
SD flashed using Etcher
First boot succesful
Installed tmux
Set up SSH using armbian-config and used it to connect
Installed docker using armbian-config successfully
When trying to install ISPConfig:
the SSH connection timed out,
and when I switched my screen back to HDMI I could see the display was corrupted (colored streaks),
armbian-config's did give a generic error message (something like "Error during installation").
The Pi Prime did not respond,
the case was quite warm.
After that I could not get it to boot again. I've tried both Armbian images,
and one of the Debian server Orange Pi Prime images.
Measured supply voltage (at the barrel connector's pins): 5.25V
On further inspection I saw some discoloration on the CPU and on one of the memory chips:
The ambient room temperature is around 21 degrees celcius
I don't have a USB to TTL converter yet.
I also measured some of the resistors and found that R3 (KEYADC to AVCC and KEYLADC) was only 39K instead of 100K as it should be according to the schematics.
This could be a problem - since last update to 4.19.y, cpu speed can go to maximum, but with this, heatsink become more or less mandatory. Especially if you are running the board inside the case.
Have you tried to boot after board cooled down?
Thanks for the blazingly fast reply Igor.
I've tried booting after the board cooled down; I left it alone for an entire night, but to no avail.
Perhaps it's a good idea to add a warning that a heatsink is required on the hardware page. I'll have a look around if I can do that myself.
On 1/26/2019 at 3:33 PM, martinayotte said:
I think that will give you real answers when you will be able to see boot log ...
Finally got the converter. Here is the result:
HELLO! BOOT0 is starting!
boot0 commit : 82a2e49cc2a78c99a14cb67b3cb4284805382f0c
boot0 version : 4.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM BOOT DRIVE INFO: V0.6
the chip id is 0x00000001
axp not exist
DRAM CLK =624 MHZ
DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM zq value: 0x003b3bf9
DRAM SIZE =2048 M
DRAM simple test OK.
dram size =2048
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2016-03-15 20:40
[mmc]: sdc0 spd mode error, 2
[BUDDY] CARD_TYPE 0
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 0***
[mmc]: HSSDR52/SDR25 4 bit
[mmc]: 50000000 Hz
[mmc]: 30436 MB
[mmc]: ***SD/MMC 0 init OK!!!***
[MMC] BLCOK ARG:cmd.cmdidx 18
[MMC] BLCOK ARG:cmd.resp_type 21
[MMC] BLCOK ARG:cmd.flags 0
[MMC] BLCOK ARG:data.block 64
[MMC] BLCOK ARG:data.blocksize 512
[MMC] BLCOK ARG:data.flags 1
[MMC] BLCOK ARG:cmd.cmdarg 32800
[BUDDY2] nectblck net
[MMC2] BLCOK ARG:cmd.cmdidx 12
[MMC2] BLCOK ARG:cmd.resp_type 29
[MMC2] BLCOK ARG:cmd.flags 0
[MMC2] BLCOK ARG:data.block 64
[MMC2] BLCOK ARG:data.blocksize 512
[MMC2] BLCOK ARG:data.flags 1
[MMC2] BLCOK ARG:cmd.cmdarg 0
[MMC] BLCOK ARG:data.block 2176
[MMC] BLCOK ARG:cmd.cmdarg 32864
[MMC2] BLCOK ARG:data.block 2176
sum=9286958d
src_sum=e28ddf42
Fail in checking uboot.
[MMC] BLCOK ARG:cmd.cmdarg 24576
PANIC : sunxi_flash_init() error --2--,toc1 magic error
PANIC : sunxi_flash_init() error --0--
Ready to disable icache.
Duckduckgoing didn't fetch me anything useful fo "Fail in checking uboot" nor "toc1 magic error". It looks like it's seeing the SD card properly, but then hits kernel panic. I'm guessing toc1 has something to do with the CPU.
Simple Question (because I dont see any "big" error before the toc1 magic):
Did you try another (smaller/fresh) card than your Sandisk 64G Ultra with an
actual image ( https://dl.armbian.com/orangepiprime/Debian_stretch_next.7z ) ?
The term "toc" I know as TableOfContent.
For me it looks like a bad content inside the flash or wrong read of the flash, because the "magic" normally should be a CRC-checksum
In a source-code of flash.c (OK, for another board) at
https://github.com/BPI-SINOVOIP/BPI-M3-bsp/blob/master/u-boot-sunxi/sunxi_spl/sbrom/flash/flash.c
there is the code:
		toc1_head = (struct sbrom_toc1_head_info *)tmp_buff;
		if(toc1_head->magic != TOC_MAIN_INFO_MAGIC)
			printf("PANIC : sunxi_flash_init() error --2--,toc1 magic error\n");
			return -1;
Thanks guidol. The previous output was with the producer's instructions and their original Pi Prime image.
I've tried it with armbian (the image you linked to) and two different SD cards. The other one is a Sandisk Ultra 32GB (class 10). Both cards give the same output (with the armbian image):
U-Boot SPL 2018.11-armbian (Feb 08 2019 - 11:30:47 +0100)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.0(debug):30490b1
NOTICE:  BL31: Built : 19:11:09, Feb  6 2019
NOTICE:  BL31: Detected Allwinner H5 SoC (1718)
NOTICE:  BL31: No DTB found.
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
NOTICE:  BL31: PMIC: Defaulting to PortL GPIO according to H5 reference design.
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
While this looks promising (to me), I'm not getting output on HDMI or LAN. I don't know if I can log in using the TTL connection, but pressing enter yielded no results.
