I have a Clusterboard and the latest images (Stretch and Bionic) do not work with my SOPINE modules.  Legacy 3.10 (Xenial) works.  I've been told this is a problem that has been resolved before but somehow the fix has been left out of the latest images.  What is the process for getting it back in?
armbianator didn't generate a URL so I'm manually pasting it here:
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Wed Jan  9 22:34:25 UTC 2019 | SoPine A64 | 5.69 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@nightly) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #76 SMP PREEMPT Wed Jan 9 22:15:14 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s18880 r8192 d22080 u49152
[    0.000000] pcpu-alloc: s18880 r8192 d22080 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1965428k/1965428k available, 115340k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000ab2000 - 0xffffffc000b329c0   (   515 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000ab1e84   ( 10440 kB)
                     .data : 0xffffffc000b33000 - 0xffffffc000c8d318   (  1385 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.019214] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.019223] pid_max: default: 32768 minimum: 301
[   10.019318] Security Framework initialized
[   10.019367] AppArmor: AppArmor initialized
[   10.019402] Mount-cache hash table entries: 256
[   10.029764] Initializing cgroup subsys memory
[   10.029812] Initializing cgroup subsys devices
[   10.029819] Initializing cgroup subsys freezer
[   10.029824] Initializing cgroup subsys blkio
[   10.029830] Initializing cgroup subsys perf_event
[   10.029840] Initializing cgroup subsys hugetlb
[   10.029898] ftrace: allocating 27493 entries in 108 pages
[   10.061930] CPU0: update cpu_power 1968128
[   10.061951] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.062946] virtual base = 0xffffff800000a000.
[   10.062959] gicd_base = 0xffffff800000c000.
[   10.062964] gicc_base = 0xffffff800000e000.
[   10.063602] CPU1: Booted secondary processor
[   10.063629] CPU1: update cpu_power 1968128
[   10.066227] CPU2: Booted secondary processor
[   10.066240] CPU2: update cpu_power 1968128
[   10.070346] CPU3: Booted secondary processor
[   10.070357] CPU3: update cpu_power 1968128
[   10.070431] Brought up 4 CPUs
[   10.070452] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.070955] devtmpfs: initialized
[   10.075704] pinctrl core: initialized pinctrl subsystem
[   10.078134] NET: Registered protocol family 16
[   10.078387] script_sysfs_init success
[   10.078626] dump_class_init,806, success
[   10.078867] vdso: 2 pages (1 code, 1 data) at base ffffffc000b39000
[   10.078888] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.080146] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.081203] DMA: preallocated 256 KiB pool for atomic allocations
[   10.081319] Serial: AMBA PL011 UART driver
[   10.081424] axp81x_board_init: axp regl_devs num = 23
[   10.081566] pll_audio-set_default_rate=24576000 success!
[   10.081584] pll_video0-set_default_rate=297000000 success!
[   10.081656] pll_video1-set_default_rate=297000000 success!
[   10.081715] pll_de-set_default_rate=297000000 success!
[   10.082422] de-set_default_source=pll_de success!
[   10.082428] de-set_default_rate=297000000 success!
[   10.082470] tcon0-set_default_source=pll_mipi success!
[   10.082501] tcon1-set_default_source=pll_video0 success!
[   10.082719] hdmi-set_default_source=pll_video0 success!
[   10.084908] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.085065] [sun50iw1p1_pinctrl_probe][838]
[   10.086498] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.087112] sunxi hwspinlock vbase:0xffffff800005c000
[   10.097171] bio: create slab <bio-0> at 0
[   10.097515] pwm module init!
[   10.098725] SCSI subsystem initialized
[   10.098846] usbcore: registered new interface driver usbfs
[   10.098880] usbcore: registered new interface driver hub
[   10.098947] usbcore: registered new device driver usb
[   10.099642] Linux video capture interface: v2.00
[   10.100109] [ARISC] :sunxi-arisc driver v1.10
[   10.107032] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.107279] Advanced Linux Sound Architecture Driver Initialized.
[   10.107623] NetLabel: Initializing
[   10.107628] NetLabel:  domain hash size = 128
[   10.107631] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.107670] NetLabel:  unlabeled traffic allowed by default
[   10.107827] [pm]aw_pm_init!
[   10.107896] rtc physical base = 0x0000000001f00000 .
[   10.107931] np name = /soc@01c00000/rtc@01f00000.
[   10.107937] base = ffffff800006e100, len = 4.
[   10.107942] pmu name: pmu0 .
[   10.107977] pmu0_enable = 0x1.
[   10.107983] pmux_id = 0x6.
[   10.107989] pmux_twi_id = 0x1.
[   10.107995] pmux_twi_addr = 0x34.
[   10.107999] pmu name: pmu1 .
[   10.108050] Warning: can not find np for pmu1.
[   10.108282] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.108442] after inited: sys_mask config = 0x4a55.
[   10.108464] Warning: can not find np for dynamic_standby_para.
[   10.108592] [pm]valid
[   10.108596] [pm]valid
[   10.108600] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.108804] Switching to clocksource arch_sys_counter_ool
[   10.119398] AppArmor: AppArmor Filesystem Enabled
[   10.125894] NET: Registered protocol family 2
[   10.126582] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.126823] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.127134] TCP: Hash tables configured (established 16384 bind 16384)
[   10.127219] TCP: reno registered
[   10.127230] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.127281] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.127533] NET: Registered protocol family 1
[   10.127852] RPC: Registered named UNIX socket transport module.
[   10.127858] RPC: Registered udp transport module.
[   10.127862] RPC: Registered tcp transport module.
[   10.127866] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.128039] Trying to unpack rootfs image as initramfs...
[   10.332501] Freeing initrd memory: 4292K (ffffffc075a85000 - ffffffc075eb6000)
[   10.333093] kvm [1]: Using HYP init bounce page @b787c000
[   10.333619] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.334041] kvm [1]: timer IRQ27
[   10.334057] kvm [1]: Hyp mode initialized successfully
[   10.335822] lock super standby defaultly!
[   10.335838] lookup_scene_lock_name: new scene lock super_standby
[   10.335843] scene_lock_init name=super_standby
[   10.335850] scene_lock: super_standby, type 5, count 1
[   10.336274] audit: initializing netlink socket (disabled)
[   10.336333] type=2000 audit(0.310:1): initialized
[   10.337005] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.337460] VFS: Disk quotas dquot_6.5.2
[   10.337563] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.338489] NFS: Registering the id_resolver key type
[   10.338537] Key type id_resolver registered
[   10.338541] Key type id_legacy registered
[   10.338553] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.338695] NTFS driver 2.1.30 [Flags: R/W].
[   10.338858] fuse init (API version 7.22)
[   10.339036] msgmni has been set to 3975
[   10.339996] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.340082] io scheduler noop registered
[   10.340088] io scheduler deadline registered
[   10.340118] io scheduler cfq registered (default)
[   10.340693] [DISP]disp_module_init
[   10.341128] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.341137] [DISP] boot_disp:0x0
[   10.341717] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.341849] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.341979] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.343095] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.343100] [DISP] fb_base:0x0
[   10.360813] Console: switching to colour frame buffer device 160x45
[   10.375375] [DISP]disp_module_init finish
[   10.375787] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.375810] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.376166] console [ttyS0] enabled
[   10.376547] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.376775] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.377082] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.377368] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.377701] misc dump reg init
[   10.377846] [drm] Initialized drm 1.1.0 20060810
[   10.379987] brd: module loaded
[   10.382101] loop: module loaded
[   10.382360] sunxi-bt bt.27: Missing bt_power.
[   10.382367] sunxi-bt bt.27: bt_power_name ((null))
[   10.382375] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.382409] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.382453] sunxi-bt bt.27: clk not config
[   10.382524] sunxi-bt bt.27: block state already is 1
[   10.382701] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.382708] sunxi-wlan wlan.26: Missing wlan_power.
[   10.382715] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.382722] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.382740] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.382759] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.382776] sunxi-wlan wlan.26: clk not config
[   10.383476] WARNING: Get ephy clock is failed
[   10.384099] chipid-sunxi serial 140050374620201507cf
[   10.384191] PPP generic driver version 2.4.2
[   10.384348] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.384521] get ehci0-controller drv_vbus_gpio is fail
[   10.384528] get ehci0-controller, regulator_io is no nocare
[   10.384568] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   10.384621] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.384639] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.384984] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000584c7c
[   10.404057] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.404140] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.404148] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.404154] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.404161] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.404167] usb usb1: SerialNumber: sunxi-ehci
[   10.404503] hub 1-0:1.0: USB hub found
[   10.404520] hub 1-0:1.0: 1 port detected
[   10.404654] scene_lock_init name=ehci_standby
[   10.404728] get ehci1-controller drv_vbus_gpio is fail
[   10.404734] get ehci1-controller, regulator_io is no nocare
[   10.404772] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000d16dd0, 0x:ffffff80000b2000, irq_no:6a
[   10.404821] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.404840] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.405108] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000584c7c
[   10.423892] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.423940] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.423947] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.423954] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.423960] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.423966] usb usb2: SerialNumber: sunxi-ehci
[   10.424260] hub 2-0:1.0: USB hub found
[   10.424274] hub 2-0:1.0: 1 port detected
[   10.424398] scene_lock_init name=ehci_standby
[   10.424591] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.424748] get ohci0-controller drv_vbus_gpio is fail
[   10.424754] get ohci0-controller, regulator_io is no nocare
[   10.424794] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   10.424844] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.424860] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.424891] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.486747] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.486755] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.486762] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.486768] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.486774] usb usb3: SerialNumber: sunxi-ohci
[   10.487044] hub 3-0:1.0: USB hub found
[   10.487058] hub 3-0:1.0: 1 port detected
[   10.487176] scene_lock_init name=ohci_standby
[   10.487238] get ohci1-controller drv_vbus_gpio is fail
[   10.487243] get ohci1-controller, regulator_io is no nocare
[   10.487276] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000d16930
[   10.487315] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.487332] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.487359] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.545823] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.545831] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.545838] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.545844] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.545851] usb usb4: SerialNumber: sunxi-ohci
[   10.546125] hub 4-0:1.0: USB hub found
[   10.546138] hub 4-0:1.0: 1 port detected
[   10.546253] scene_lock_init name=ohci_standby
[   10.546559] usbcore: registered new interface driver usb-storage
[   10.546589] usbcore: registered new interface driver ums-alauda
[   10.546616] usbcore: registered new interface driver ums-cypress
[   10.546642] usbcore: registered new interface driver ums-datafab
[   10.546664] usbcore: registered new interface driver ums_eneub6250
[   10.546688] usbcore: registered new interface driver ums-freecom
[   10.546711] usbcore: registered new interface driver ums-isd200
[   10.546734] usbcore: registered new interface driver ums-jumpshot
[   10.546758] usbcore: registered new interface driver ums-karma
[   10.546781] usbcore: registered new interface driver ums-onetouch
[   10.546815] usbcore: registered new interface driver ums-realtek
[   10.546840] usbcore: registered new interface driver ums-sddr09
[   10.546863] usbcore: registered new interface driver ums-sddr55
[   10.546891] usbcore: registered new interface driver ums-usbat
[   10.546974] usbcore: registered new interface driver usbserial
[   10.547000] usbcore: registered new interface driver usbserial_generic
[   10.547024] usbserial: USB Serial support registered for generic
[   10.547216] mousedev: PS/2 mouse device common for all mice
[   10.547673] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.548522] get ctp_para failed, -1
[   10.548543] get node gsensor failed
[   10.548547] get sysconfig para erro!
[   10.548557] get node lightsensor failed
[   10.548560] get sysconfig para erro!
[   10.548569] get node gyroscopesensor failed
[   10.548572] get sysconfig para erro!
[   10.548582] get node compasssensor failed
[   10.548585] get sysconfig para erro!
[   10.548874] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.548894] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.549056] i2c /dev entries driver
[   10.591595] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.595041] sunxi budget cooling probe start !
[   10.595068] CPU freq cooling register Success
[   10.595087] CPU hotplug cooling register Success
[   10.595173] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.595181] CPU budget cooling register Success
[   10.595393] sunxi gpu cooling probe start !
[   10.595403] CPU gpu cooling register Success
[   10.596053] cpuidle: using governor ladder
[   10.596060] cpuidle: using governor menu
[   10.596797] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.596825] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.596833] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.596842] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.596892] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.596899] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.597489] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.597513] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.548610] wakeup gpio set err!get node ctp failed
[   10.600915] get sysconfig para erro!
[   10.610694] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.630384] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.630760] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.630786] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.630793] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.630800] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.630804] get() with no identifier
[   10.630807] get() with no identifier
[   10.630811] get() with no identifier
[   10.630817] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.630822] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.630828] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.631206] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.631218] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.631236] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.632027] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.632046] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.634430] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.636570] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.637384] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.638196] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.639008] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.639635] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.639678] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.642052] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.650053] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.669739] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.670430] ledtrig-cpu: registered to indicate activity on CPUs
[   10.670494] hidraw: raw HID events driver (C) Jiri Kosina
[   10.670644] usbcore: registered new interface driver usbhid
[   10.670649] usbhid: USB HID core driver
[   10.671511] usbcore: registered new interface driver snd-usb-audio
[   10.673553] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.674350] TCP: cubic registered
[   10.674358] Initializing XFRM netlink socket
[   10.674441] NET: Registered protocol family 10
[   10.675235] mip6: Mobile IPv6
[   10.675243] sit: IPv6 over IPv4 tunneling driver
[   10.675610] NET: Registered protocol family 17
[   10.675634] NET: Registered protocol family 15
[   10.675683] 8021q: 802.1Q VLAN Support v1.8
[   10.675730] Key type dns_resolver registered
[   10.675935] Registering SWP/SWPB emulation handler
[   10.676223] registered taskstats version 1
[   10.688206] Key type encrypted registered
[   10.688227] AppArmor: AppArmor sha1 policy hashing enabled
[   10.688669] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.688677] [DISP] boot_disp:0x0
[   10.688723] HDMI base address: ffffff8000b40000
[   10.689524] [HDMI] power vcc-hdmi-33
[   10.690048] [HDMI] cec support = 0
[   10.709054] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.711552] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.711626] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.711729] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.711755] mmc0: new high speed SDHC card at address aaaa
[   10.712184] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.714210]  mmcblk0: p1
[   10.715321] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.716131] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.716150] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.718545] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.720363] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.721172] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.721979] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.722785] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.723590] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.724397] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.725204] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.726011] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.726818] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.726835] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.727667] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.727684] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.800501] input: sunxi-ths as /devices/virtual/input/input2
[   10.800659] thermal thermal_zone0: failed to read out thermal zone 0
[   10.801056] ALSA device list:
[   10.801062]   #0: sndhdmi
[   10.801480] Freeing unused kernel memory: 512K (ffffffc000ab2000 - ffffffc000b32000)
[   11.397911] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.074378] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.074392] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80
[   14.074414] scene_lock_destroy name=ehci_standby
[   14.074427] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.074449] usb usb1: USB disconnect, device number 1
[   14.074996] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.075028] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.075036] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.075042] scene_lock_destroy name=ohci_standby
[   14.075049] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.075065] usb usb3: USB disconnect, device number 1
[   14.075438] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.075473] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.075481] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   14.075524] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.075549] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.078749] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b86d0
[   14.094074] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.094174] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.094182] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.094188] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.094195] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.094201] usb usb1: SerialNumber: sunxi-ehci
[   14.094665] hub 1-0:1.0: USB hub found
[   14.094684] hub 1-0:1.0: 1 port detected
[   14.094836] scene_lock_init name=ehci_standby
[   14.094844] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.094852] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.094902] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.094921] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.094962] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b86d0
[   14.157118] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.157133] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.157139] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.157146] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.157152] usb usb3: SerialNumber: sunxi-ohci
[   14.157610] hub 3-0:1.0: USB hub found
[   14.157629] hub 3-0:1.0: 1 port detected
[   14.157818] scene_lock_init name=ohci_standby
[   16.409233] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.765514] systemd[1]: System time before build time, advancing clock.
[   16.802776] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.803083] systemd[1]: Detected architecture arm64.
[   16.832429] systemd[1]: Set hostname to <pine64so>.
[   17.110247] systemd[1]: Reached target Swap.
[   17.125059] systemd[1]: Listening on udev Kernel Socket.
[   17.144708] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.164603] systemd[1]: Created slice System Slice.
[   17.183919] systemd[1]: Reached target Remote File Systems (Pre).
[   17.203725] systemd[1]: Listening on udev Control Socket.
[   17.223781] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.243506] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.262820] systemd[1]: Created slice User and Session Slice.
[   17.282287] systemd[1]: Reached target Slices.
[   17.301955] systemd[1]: Reached target Remote File Systems.
[   17.321643] systemd[1]: Reached target Encrypted Volumes.
[   17.341581] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.361067] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.380826] systemd[1]: Listening on Journal Socket.
[   17.406348] systemd[1]: Starting Load Kernel Modules...
[   17.422091] systemd[1]: Mounting POSIX Message Queue File System...
[   17.442655] systemd[1]: Mounting Huge Pages File System...
[   17.462155] systemd[1]: Mounting Debug File System...
[   17.482343] systemd[1]: Starting Set console keymap...
[   17.501020] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.520868] systemd[1]: Starting Nameserver information manager...
[   17.524454] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.540562] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.566590] systemd[1]: Listening on Syslog Socket.
[   17.587823] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.612159] systemd[1]: Starting Restore / save the current clock...
[   17.627089] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.630101] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.630374] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.630505] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.630645] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.631793] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.646639] systemd[1]: Reached target Paths.
[   17.670684] systemd[1]: Mounted Debug File System.
[   17.686139] systemd[1]: Mounted POSIX Message Queue File System.
[   17.690780] cfg80211: Calling CRDA to update world regulatory domain
[   17.705688] systemd[1]: Mounted Huge Pages File System.
[   17.727226] systemd[1]: Started Set console keymap.
[   17.746479] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.768315] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.804692] systemd[1]: Started Restore / save the current clock.
[   17.810775] RTL871X: module init start
[   17.810790] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.810795] RTL871X: build time: Jan  9 2019 22:15:04
[   17.810799] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.810814] sunxi-wlan wlan.26: bus_index: 1
[   17.810987] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.825892] systemd[1]: Started Nameserver information manager.
[   17.846214] systemd[1]: Time has been changed
[   17.930225] systemd[1]: Reached target Network (Pre).
[   17.931858] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.931970] RTL871X: module init ret=0
[   17.931982] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   17.951394] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.954059] systemd[1]: Starting Create Static Device Nodes in /dev...
[   17.971921] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.972763] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.972806] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.973728] systemd[1]: Starting Load/Save Random Seed...
[   17.975288] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.977190] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   17.978022] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.978839] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.979655] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.980469] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.981292] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.982104] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.982937] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.983755] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.983783] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.984675] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   17.984697] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.005051] systemd[1]: Starting udev Coldplug all Devices...
[   18.021201] systemd[1]: Started Load Kernel Modules.
[   18.041795] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.060778] systemd[1]: Started Load/Save Random Seed.
[   18.124344] systemd[1]: Starting udev Kernel Device Manager...
[   18.138635] systemd[1]: Reached target Local File Systems (Pre).
[   18.161782] systemd[1]: Mounting /tmp...
[   18.180244] systemd[1]: Mounting FUSE Control File System...
[   18.199964] systemd[1]: Starting Apply Kernel Variables...
[   18.220655] systemd[1]: Mounting Configuration File System...
[   18.241401] systemd[1]: Mounted FUSE Control File System.
[   18.256972] systemd[1]: Mounted Configuration File System.
[   18.276413] systemd[1]: Mounted /tmp.
[   18.296648] systemd[1]: Started udev Kernel Device Manager.
[   18.316646] systemd[1]: Started udev Coldplug all Devices.
[   18.337395] systemd[1]: Started Apply Kernel Variables.
[   18.407804] cfg80211: World regulatory domain updated:
[   18.407824] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.407831] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.407836] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.407842] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.407847] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.407852] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.407857] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.407862] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.407868] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.416600] systemd[1]: Reached target Sound Card.
[   18.433994] systemd[1]: Reached target Local File Systems.
[   18.442479] systemd[1]: Starting Armbian ZRAM config...
[   18.458875] sunxi cedar version 0.1
[   18.459117] [cedar]: install start!!!
[   18.459253] ycy the get irq is 90
[   18.459704] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.459718] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.459723] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.459728] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.459733] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.459736] [cedar]: install end!!!
[   18.460502] systemd[1]: Starting Raise network interfaces...
[   18.474255] systemd[1]: Starting Set console font and keymap...
[   18.527121] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.545485] Registered IR keymap rc_map_sunxi
[   18.546020] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.547226] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.555428] systemd[1]: Starting Journal Service...
[   18.563904] Driver for 1-wire Dallas network protocol.
[   18.622767] systemd[1]: Found device /dev/ttyS0.
[   18.635678] IR JVC protocol handler initialized
[   18.636596] [VFE]cci probe end cci_sel = 0!
[   18.636906] [VFE]cci_init end
[   18.637140] IR NEC protocol handler initialized
[   18.638303] IR RC5(x) protocol handler initialized
[   18.639343] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.639727] IR MCE Keyboard/mouse protocol handler initialized
[   18.648309] IR Sony protocol handler initialized
[   18.648478] lirc_dev: IR Remote Control driver registered, major 248
[   18.649466] IR RC6 protocol handler initialized
[   18.649468] IR SANYO protocol handler initialized
[   18.653010] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.653028] IR LIRC bridge handler initialized
[   18.834997] [VFE]Welcome to Video Front End driver
[   18.835356] [VFE]csi probe end csi_sel = 0!
[   18.837905] [VFE]csi_init end
[   18.838412] [VFE]isp probe start isp_sel = 0!
[   18.840907] [ISP] isp platform_id = 3!
[   18.840935] [VFE]isp probe end isp_sel = 0!
[   18.841040] [VFE]sunxi_isp_platform_register end
[   18.841604] [VFE]mipi probe start mipi_sel = 0!
[   18.841644] [VFE]mipi probe end mipi_sel = 0!
[   18.842843] [VFE]mipi_init end
[   18.842867] [VFE]flash_init end
[   18.843791] [VFE]vfe_init end
[   18.944598] systemd[1]: Started Journal Service.
[   19.043033] systemd-journald[349]: Received request to flush runtime journal from PID 1
[   19.078695] sunxi-bt bt.27: block state already is 1
[   19.122028] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.131406] zram: Created 6 device(s) ...
[   19.294097] Adding 254468k swap on /dev/zram1.  Priority:5 extents:1 across:254468k SS
[   19.316715] Adding 254468k swap on /dev/zram2.  Priority:5 extents:1 across:254468k SS
[   19.340953] Adding 254468k swap on /dev/zram3.  Priority:5 extents:1 across:254468k SS
[   19.372040] Adding 254468k swap on /dev/zram4.  Priority:5 extents:1 across:254468k SS
[   19.571906] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.571928] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.69
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035768 kB
MemFree:         1902596 kB
Buffers:            7036 kB
Cached:            52276 kB
SwapCached:            0 kB
Active:            26364 kB
Inactive:          46144 kB
Active(anon):      13520 kB
Inactive(anon):     2856 kB
Active(file):      12844 kB
Inactive(file):    43288 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017872 kB
SwapFree:        1017872 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         13164 kB
Mapped:            14672 kB
Shmem:              3040 kB
Slab:              22024 kB
SReclaimable:       8772 kB
SUnreclaim:        13252 kB
KernelStack:        1936 kB
PageTables:          652 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035756 kB
Committed_AS:     104888 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633444 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5607
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 62561
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254472 zram1
 253        2     254472 zram2
 253        3     254472 zram3
 253        4     254472 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
/dev/mmcblk0p1   15G  795M   14G   6% /
tmpfs           995M     0  995M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           995M     0  995M   0% /sys/fs/cgroup
tmpfs           995M  4.0K  995M   1% /tmp
/dev/zram0       49M  948K   44M   3% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M  884K 204.1K  892K         /var/log
/dev/zram1             248.5M    4K    78B    4K         [SWAP]
/dev/zram2             248.5M    4K    78B    4K         [SWAP]
/dev/zram3             248.5M    4K    78B    4K         [SWAP]
/dev/zram4             248.5M    4K    78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
22:34:28: 1152MHz  0.48  33%  12%  15%   0%   5%   0%   37°C   23°C  0/7
22:34:28:  480MHz  0.48   7%   4%   1%   1%   0%   0%   35°C   23°C  0/7
22:34:29:  480MHz  0.48   6%   5%   0%   1%   0%   0%   34°C   23°C  0/7
22:34:29:  480MHz  0.48  12%   6%   4%   1%   0%   0%   33°C   23°C  0/7
22:34:29:  480MHz  0.48   6%   3%   0%   3%   0%   0%   32°C   23°C  0/7
Wed Jan  9 23:16:05 UTC 2019 | SoPine A64 | 5.69 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.023075] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.023084] pid_max: default: 32768 minimum: 301
[   10.023178] Security Framework initialized
[   10.023227] AppArmor: AppArmor initialized
[   10.023261] Mount-cache hash table entries: 256
[   10.033590] Initializing cgroup subsys memory
[   10.033635] Initializing cgroup subsys devices
[   10.033642] Initializing cgroup subsys freezer
[   10.033647] Initializing cgroup subsys blkio
[   10.033653] Initializing cgroup subsys perf_event
[   10.033663] Initializing cgroup subsys hugetlb
[   10.033722] ftrace: allocating 27493 entries in 108 pages
[   10.065737] CPU0: update cpu_power 1968128
[   10.065757] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.066756] virtual base = 0xffffff800000a000.
[   10.066769] gicd_base = 0xffffff800000c000.
[   10.066774] gicc_base = 0xffffff800000e000.
[   10.067410] CPU1: Booted secondary processor
[   10.067437] CPU1: update cpu_power 1968128
[   10.070034] CPU2: Booted secondary processor
[   10.070047] CPU2: update cpu_power 1968128
[   10.074153] CPU3: Booted secondary processor
[   10.074164] CPU3: update cpu_power 1968128
[   10.074233] Brought up 4 CPUs
[   10.074254] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.074768] devtmpfs: initialized
[   10.079492] pinctrl core: initialized pinctrl subsystem
[   10.081962] NET: Registered protocol family 16
[   10.082218] script_sysfs_init success
[   10.082454] dump_class_init,806, success
[   10.082694] vdso: 2 pages (1 code, 1 data) at base ffffffc000b39000
[   10.082715] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.083973] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.085020] DMA: preallocated 256 KiB pool for atomic allocations
[   10.085137] Serial: AMBA PL011 UART driver
[   10.085242] axp81x_board_init: axp regl_devs num = 23
[   10.085383] pll_audio-set_default_rate=24576000 success!
[   10.085401] pll_video0-set_default_rate=297000000 success!
[   10.085475] pll_video1-set_default_rate=297000000 success!
[   10.085533] pll_de-set_default_rate=297000000 success!
[   10.086239] de-set_default_source=pll_de success!
[   10.086245] de-set_default_rate=297000000 success!
[   10.086287] tcon0-set_default_source=pll_mipi success!
[   10.086317] tcon1-set_default_source=pll_video0 success!
[   10.086529] hdmi-set_default_source=pll_video0 success!
[   10.088730] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.088886] [sun50iw1p1_pinctrl_probe][838]
[   10.090313] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.090929] sunxi hwspinlock vbase:0xffffff800005c000
[   10.101013] bio: create slab <bio-0> at 0
[   10.101359] pwm module init!
[   10.102566] SCSI subsystem initialized
[   10.102688] usbcore: registered new interface driver usbfs
[   10.102722] usbcore: registered new interface driver hub
[   10.102786] usbcore: registered new device driver usb
[   10.103480] Linux video capture interface: v2.00
[   10.103927] [ARISC] :sunxi-arisc driver v1.10
[   10.110838] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.111088] Advanced Linux Sound Architecture Driver Initialized.
[   10.111432] NetLabel: Initializing
[   10.111437] NetLabel:  domain hash size = 128
[   10.111441] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.111479] NetLabel:  unlabeled traffic allowed by default
[   10.111639] [pm]aw_pm_init!
[   10.111707] rtc physical base = 0x0000000001f00000 .
[   10.111739] np name = /soc@01c00000/rtc@01f00000.
[   10.111745] base = ffffff800006e100, len = 4.
[   10.111750] pmu name: pmu0 .
[   10.111784] pmu0_enable = 0x1.
[   10.111789] pmux_id = 0x6.
[   10.111795] pmux_twi_id = 0x1.
[   10.111801] pmux_twi_addr = 0x34.
[   10.111805] pmu name: pmu1 .
[   10.111854] Warning: can not find np for pmu1.
[   10.112082] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.112242] after inited: sys_mask config = 0x4a55.
[   10.112264] Warning: can not find np for dynamic_standby_para.
[   10.112388] [pm]valid
[   10.112391] [pm]valid
[   10.112395] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.112601] Switching to clocksource arch_sys_counter_ool
[   10.123183] AppArmor: AppArmor Filesystem Enabled
[   10.129664] NET: Registered protocol family 2
[   10.130352] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.130596] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.130912] TCP: Hash tables configured (established 16384 bind 16384)
[   10.130995] TCP: reno registered
[   10.131005] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.131057] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.131306] NET: Registered protocol family 1
[   10.131629] RPC: Registered named UNIX socket transport module.
[   10.131634] RPC: Registered udp transport module.
[   10.131638] RPC: Registered tcp transport module.
[   10.131643] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.131817] Trying to unpack rootfs image as initramfs...
[   10.336341] Freeing initrd memory: 4292K (ffffffc075a85000 - ffffffc075eb6000)
[   10.336935] kvm [1]: Using HYP init bounce page @b787a000
[   10.337450] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.337870] kvm [1]: timer IRQ27
[   10.337886] kvm [1]: Hyp mode initialized successfully
[   10.339645] lock super standby defaultly!
[   10.339662] lookup_scene_lock_name: new scene lock super_standby
[   10.339667] scene_lock_init name=super_standby
[   10.339673] scene_lock: super_standby, type 5, count 1
[   10.340082] audit: initializing netlink socket (disabled)
[   10.340140] type=2000 audit(0.310:1): initialized
[   10.340811] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.341269] VFS: Disk quotas dquot_6.5.2
[   10.341370] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.342296] NFS: Registering the id_resolver key type
[   10.342349] Key type id_resolver registered
[   10.342353] Key type id_legacy registered
[   10.342365] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.342509] NTFS driver 2.1.30 [Flags: R/W].
[   10.342671] fuse init (API version 7.22)
[   10.342847] msgmni has been set to 3975
[   10.343805] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.343892] io scheduler noop registered
[   10.343898] io scheduler deadline registered
[   10.343926] io scheduler cfq registered (default)
[   10.344498] [DISP]disp_module_init
[   10.344943] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.344951] [DISP] boot_disp:0x0
[   10.345551] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.345684] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.345816] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.346933] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.346939] [DISP] fb_base:0x0
[   10.364658] Console: switching to colour frame buffer device 160x45
[   10.379228] [DISP]disp_module_init finish
[   10.379649] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.379671] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.380026] console [ttyS0] enabled
[   10.380406] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.380636] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.380944] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.381228] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.381563] misc dump reg init
[   10.381709] [drm] Initialized drm 1.1.0 20060810
[   10.383856] brd: module loaded
[   10.385961] loop: module loaded
[   10.386224] sunxi-bt bt.27: Missing bt_power.
[   10.386232] sunxi-bt bt.27: bt_power_name ((null))
[   10.386240] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.386272] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.386315] sunxi-bt bt.27: clk not config
[   10.386387] sunxi-bt bt.27: block state already is 1
[   10.386566] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.386573] sunxi-wlan wlan.26: Missing wlan_power.
[   10.386579] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.386586] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.386603] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.386621] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.386639] sunxi-wlan wlan.26: clk not config
[   10.387335] WARNING: Get ephy clock is failed
[   10.387944] chipid-sunxi serial 140050374620201507cf
[   10.388037] PPP generic driver version 2.4.2
[   10.388249] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.388362] get ehci0-controller drv_vbus_gpio is fail
[   10.388368] get ehci0-controller, regulator_io is no nocare
[   10.388408] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   10.388463] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.388481] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.388840] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000584c7c
[   10.407855] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.407937] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.407945] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.407951] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.407958] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.407964] usb usb1: SerialNumber: sunxi-ehci
[   10.408295] hub 1-0:1.0: USB hub found
[   10.408311] hub 1-0:1.0: 1 port detected
[   10.408444] scene_lock_init name=ehci_standby
[   10.408516] get ehci1-controller drv_vbus_gpio is fail
[   10.408522] get ehci1-controller, regulator_io is no nocare
[   10.408561] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000d16dd0, 0x:ffffff80000b2000, irq_no:6a
[   10.408609] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.408629] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.408893] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000584c7c
[   10.427689] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.427734] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.427742] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.427749] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.427755] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.427761] usb usb2: SerialNumber: sunxi-ehci
[   10.428060] hub 2-0:1.0: USB hub found
[   10.428073] hub 2-0:1.0: 1 port detected
[   10.428200] scene_lock_init name=ehci_standby
[   10.428392] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.428547] get ohci0-controller drv_vbus_gpio is fail
[   10.428552] get ohci0-controller, regulator_io is no nocare
[   10.428594] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   10.428644] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.428660] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.428691] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.490547] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.490555] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.490562] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.490568] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.490574] usb usb3: SerialNumber: sunxi-ohci
[   10.490842] hub 3-0:1.0: USB hub found
[   10.490856] hub 3-0:1.0: 1 port detected
[   10.490973] scene_lock_init name=ohci_standby
[   10.491035] get ohci1-controller drv_vbus_gpio is fail
[   10.491039] get ohci1-controller, regulator_io is no nocare
[   10.491071] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000d16930
[   10.491110] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.491128] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.491153] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.549621] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.549629] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.549636] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.549642] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.549649] usb usb4: SerialNumber: sunxi-ohci
[   10.549917] hub 4-0:1.0: USB hub found
[   10.549930] hub 4-0:1.0: 1 port detected
[   10.550044] scene_lock_init name=ohci_standby
[   10.550348] usbcore: registered new interface driver usb-storage
[   10.550379] usbcore: registered new interface driver ums-alauda
[   10.550406] usbcore: registered new interface driver ums-cypress
[   10.550431] usbcore: registered new interface driver ums-datafab
[   10.550454] usbcore: registered new interface driver ums_eneub6250
[   10.550477] usbcore: registered new interface driver ums-freecom
[   10.550501] usbcore: registered new interface driver ums-isd200
[   10.550524] usbcore: registered new interface driver ums-jumpshot
[   10.550547] usbcore: registered new interface driver ums-karma
[   10.550570] usbcore: registered new interface driver ums-onetouch
[   10.550604] usbcore: registered new interface driver ums-realtek
[   10.550629] usbcore: registered new interface driver ums-sddr09
[   10.550653] usbcore: registered new interface driver ums-sddr55
[   10.550680] usbcore: registered new interface driver ums-usbat
[   10.550763] usbcore: registered new interface driver usbserial
[   10.550789] usbcore: registered new interface driver usbserial_generic
[   10.550813] usbserial: USB Serial support registered for generic
[   10.551010] mousedev: PS/2 mouse device common for all mice
[   10.551461] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.552306] get ctp_para failed, -1
[   10.552327] get node gsensor failed
[   10.552330] get sysconfig para erro!
[   10.552340] get node lightsensor failed
[   10.552343] get sysconfig para erro!
[   10.552352] get node gyroscopesensor failed
[   10.552356] get sysconfig para erro!
[   10.552364] get node compasssensor failed
[   10.552368] get sysconfig para erro!
[   10.552657] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.552676] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.552835] i2c /dev entries driver
[   10.595390] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.598830] sunxi budget cooling probe start !
[   10.598856] CPU freq cooling register Success
[   10.598875] CPU hotplug cooling register Success
[   10.598961] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.598969] CPU budget cooling register Success
[   10.599184] sunxi gpu cooling probe start !
[   10.599194] CPU gpu cooling register Success
[   10.599841] cpuidle: using governor ladder
[   10.599848] cpuidle: using governor menu
[   10.600589] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.600616] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.600624] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.600633] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.600685] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.600691] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.601286] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.601310] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.552393] wakeup gpio set err!get node ctp failed
[   10.604714] get sysconfig para erro!
[   10.614494] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.634182] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.634562] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.634587] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.634594] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.634601] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.634605] get() with no identifier
[   10.634608] get() with no identifier
[   10.634612] get() with no identifier
[   10.634618] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.634624] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.634630] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.635006] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.635031] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.635049] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.635829] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.635849] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.638229] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.640367] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.641181] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.641993] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.642805] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.643429] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.643472] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.645847] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.653852] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.673538] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.674223] ledtrig-cpu: registered to indicate activity on CPUs
[   10.674289] hidraw: raw HID events driver (C) Jiri Kosina
[   10.674438] usbcore: registered new interface driver usbhid
[   10.674443] usbhid: USB HID core driver
[   10.675306] usbcore: registered new interface driver snd-usb-audio
[   10.677358] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.678152] TCP: cubic registered
[   10.678161] Initializing XFRM netlink socket
[   10.678246] NET: Registered protocol family 10
[   10.679047] mip6: Mobile IPv6
[   10.679054] sit: IPv6 over IPv4 tunneling driver
[   10.679420] NET: Registered protocol family 17
[   10.679444] NET: Registered protocol family 15
[   10.679493] 8021q: 802.1Q VLAN Support v1.8
[   10.679547] Key type dns_resolver registered
[   10.679750] Registering SWP/SWPB emulation handler
[   10.680034] registered taskstats version 1
[   10.692048] Key type encrypted registered
[   10.692069] AppArmor: AppArmor sha1 policy hashing enabled
[   10.692511] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.692520] [DISP] boot_disp:0x0
[   10.692566] HDMI base address: ffffff8000b40000
[   10.693384] [HDMI] power vcc-hdmi-33
[   10.693908] [HDMI] cec support = 0
[   10.712851] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.715347] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.715423] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.715524] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.715548] mmc0: new high speed SDHC card at address aaaa
[   10.715974] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.718000]  mmcblk0: p1
[   10.719116] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.719925] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.719946] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.722338] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.724155] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.724964] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.725771] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.726578] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.727382] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.728189] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.728996] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.729803] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.730610] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.730627] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.731460] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.731477] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.804364] input: sunxi-ths as /devices/virtual/input/input2
[   10.804533] thermal thermal_zone0: failed to read out thermal zone 0
[   10.804950] ALSA device list:
[   10.804956]   #0: sndhdmi
[   10.805364] Freeing unused kernel memory: 512K (ffffffc000ab2000 - ffffffc000b32000)
[   11.401757] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.078182] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.078203] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80
[   14.078224] scene_lock_destroy name=ehci_standby
[   14.078238] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.078260] usb usb1: USB disconnect, device number 1
[   14.078814] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.078847] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.078856] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.078861] scene_lock_destroy name=ohci_standby
[   14.078869] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.078885] usb usb3: USB disconnect, device number 1
[   14.079259] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.079292] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.079299] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   14.079344] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.079368] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.080361] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b86d0
[   14.097882] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.097977] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.097985] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.097992] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.097999] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.098005] usb usb1: SerialNumber: sunxi-ehci
[   14.098482] hub 1-0:1.0: USB hub found
[   14.098500] hub 1-0:1.0: 1 port detected
[   14.098647] scene_lock_init name=ehci_standby
[   14.098654] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.098663] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.098714] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.098732] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.098775] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b86d0
[   14.160920] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.160936] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.160943] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.160949] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.160956] usb usb3: SerialNumber: sunxi-ohci
[   14.161414] hub 3-0:1.0: USB hub found
[   14.161432] hub 3-0:1.0: 1 port detected
[   14.161615] scene_lock_init name=ohci_standby
[   16.454319] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.811261] systemd[1]: System time before build time, advancing clock.
[   16.848608] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.848916] systemd[1]: Detected architecture arm64.
[   16.875521] systemd[1]: Set hostname to <cluster0>.
[   17.158483] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.178069] systemd[1]: Listening on udev Kernel Socket.
[   17.197654] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.217280] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.237079] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.256686] systemd[1]: Listening on udev Control Socket.
[   17.276313] systemd[1]: Listening on Syslog Socket.
[   17.295930] systemd[1]: Reached target Swap.
[   17.315791] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.335418] systemd[1]: Listening on Journal Socket.
[   17.355451] systemd[1]: Created slice User and Session Slice.
[   17.374818] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.394325] systemd[1]: Reached target Paths.
[   17.414215] systemd[1]: Reached target Encrypted Volumes.
[   17.433688] systemd[1]: Reached target Remote File Systems (Pre).
[   17.453361] systemd[1]: Reached target Remote File Systems.
[   17.473322] systemd[1]: Created slice System Slice.
[   17.494517] systemd[1]: Mounting Huge Pages File System...
[   17.514469] systemd[1]: Starting Set console keymap...
[   17.534105] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.556256] systemd[1]: Mounting POSIX Message Queue File System...
[   17.573540] systemd[1]: Starting Nameserver information manager...
[   17.581435] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.591991] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.613136] systemd[1]: Mounting Debug File System...
[   17.630669] systemd[1]: Reached target Slices.
[   17.655053] systemd[1]: Starting Restore / save the current clock...
[   17.672145] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.695621] systemd[1]: Starting Load Kernel Modules...
[   17.723692] systemd[1]: Mounted Debug File System.
[   17.739040] systemd[1]: Mounted POSIX Message Queue File System.
[   17.758535] systemd[1]: Mounted Huge Pages File System.
[   17.779514] systemd[1]: Started Set console keymap.
[   17.801390] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.801738] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.801919] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.802098] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.803393] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.804970] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.832782] systemd[1]: Started Restore / save the current clock.
[   17.853233] cfg80211: Calling CRDA to update world regulatory domain
[   17.858137] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.879005] systemd[1]: Started Nameserver information manager.
[   17.899563] systemd[1]: Time has been changed
[   17.984710] RTL871X: module init start
[   17.984736] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.984741] RTL871X: build time: Jan  9 2019 22:15:04
[   17.984745] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.984768] sunxi-wlan wlan.26: bus_index: 1
[   17.984961] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.986478] systemd[1]: Reached target Network (Pre).
[   18.006682] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.026239] systemd[1]: Starting Load/Save Random Seed...
[   18.054364] systemd[1]: Starting udev Coldplug all Devices...
[   18.074293] systemd[1]: Started Load/Save Random Seed.
[   18.093394] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.093495] RTL871X: module init ret=0
[   18.093520] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.099424] systemd[1]: Started Load Kernel Modules.
[   18.112660] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.128795] systemd[1]: Mounting FUSE Control File System...
[   18.133189] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.134030] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.134066] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.136517] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.138386] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.139234] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.140065] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.140893] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.142191] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.143055] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.143900] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.144762] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.146133] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.146198] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.147107] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.147138] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.154391] systemd[1]: Starting Apply Kernel Variables...
[   18.174427] systemd[1]: Mounting Configuration File System...
[   18.194884] systemd[1]: Mounted FUSE Control File System.
[   18.211212] systemd[1]: Mounted Configuration File System.
[   18.232074] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.253708] systemd[1]: Started Apply Kernel Variables.
[   18.320884] systemd[1]: Starting udev Kernel Device Manager...
[   18.339149] systemd[1]: Reached target Local File Systems (Pre).
[   18.361945] systemd[1]: Mounting /tmp...
[   18.381586] systemd[1]: Mounted /tmp.
[   18.398865] systemd[1]: Started udev Kernel Device Manager.
[   18.436638] systemd[1]: Started udev Coldplug all Devices.
[   18.471124] systemd[1]: Reached target Sound Card.
[   18.533568] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.558132] systemd[1]: Starting Journal Service...
[   18.575616] systemd[1]: Reached target Local File Systems.
[   18.605973] systemd[1]: Starting Raise network interfaces...
[   18.627066] systemd[1]: Starting Armbian ZRAM config...
[   18.634510] cfg80211: World regulatory domain updated:
[   18.634528] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.634534] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.634539] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.634545] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.634550] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.634555] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.634560] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.634565] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.634570] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.647671] systemd[1]: Starting Set console font and keymap...
[   18.770983] sunxi cedar version 0.1
[   18.771186] [cedar]: install start!!!
[   18.771335] ycy the get irq is 90
[   18.772461] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.772465] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.772468] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.772470] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.772472] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.772474] [cedar]: install end!!!
[   18.775449] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.788448] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   18.851723] sunxi-bt bt.27: block state already is 1
[   18.852467] systemd[1]: Started Load/Save RF Kill Switch Status.
[   18.874137] systemd[1]: Found device /dev/ttyS0.
[   18.919929] systemd[1]: Started Journal Service.
[   18.922164] [VFE]cci probe end cci_sel = 0!
[   18.922643] [VFE]cci_init end
[   18.951911] Registered IR keymap rc_map_sunxi
[   18.952479] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.952785] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.972434] Driver for 1-wire Dallas network protocol.
[   19.003486] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   19.003832] IR MCE Keyboard/mouse protocol handler initialized
[   19.005637] IR RC6 protocol handler initialized
[   19.006076] IR Sony protocol handler initialized
[   19.006552] IR SANYO protocol handler initialized
[   19.028536] IR NEC protocol handler initialized
[   19.029709] IR JVC protocol handler initialized
[   19.031101] systemd-journald[296]: Received request to flush runtime journal from PID 1
[   19.031943] IR RC5(x) protocol handler initialized
[   19.033674] lirc_dev: IR Remote Control driver registered, major 248
[   19.042849] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   19.042869] IR LIRC bridge handler initialized
[   19.066229] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.075071] zram: Created 6 device(s) ...
[   19.082695] [VFE]Welcome to Video Front End driver
[   19.083112] [VFE]csi probe end csi_sel = 0!
[   19.085476] [VFE]csi_init end
[   19.086005] [VFE]isp probe start isp_sel = 0!
[   19.091618] [ISP] isp platform_id = 3!
[   19.091654] [VFE]isp probe end isp_sel = 0!
[   19.100595] [VFE]sunxi_isp_platform_register end
[   19.101258] [VFE]mipi probe start mipi_sel = 0!
[   19.101299] [VFE]mipi probe end mipi_sel = 0!
[   19.101401] [VFE]mipi_init end
[   19.101407] [VFE]flash_init end
[   19.101882] [VFE]vfe_init end
[   19.212766] Adding 254468k swap on /dev/zram1.  Priority:5 extents:1 across:254468k SS
[   19.264570] Adding 254468k swap on /dev/zram2.  Priority:5 extents:1 across:254468k SS
[   19.293321] Adding 254468k swap on /dev/zram3.  Priority:5 extents:1 across:254468k SS
[   19.318659] Adding 254468k swap on /dev/zram4.  Priority:5 extents:1 across:254468k SS
[   19.549063] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.549085] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.69
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1896480 kB
Buffers:            7388 kB
Cached:            53056 kB
SwapCached:            0 kB
Active:            30068 kB
Inactive:          48232 kB
Active(anon):      17924 kB
Inactive(anon):     2868 kB
Active(file):      12144 kB
Inactive(file):    45364 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         17648 kB
Mapped:            14648 kB
Shmem:              3036 kB
Slab:              22228 kB
SReclaimable:       9036 kB
SUnreclaim:        13192 kB
KernelStack:        1984 kB
PageTables:          592 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:     112300 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62562
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254472 zram1
 253        2     254472 zram2
 253        3     254472 zram3
 253        4     254472 zram4
### df:
/dev/mmcblk0p1   15G  796M   14G   6% /
/dev/zram0       49M  1.5M   44M   4% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  1.1M  292K  1.1M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
23:16:08: 1152MHz  0.00  36%  11%  17%   0%   7%   0%   43°C   27°C  0/7
23:16:09: 1152MHz  0.00  44%   6%   9%   1%  27%   0%   41°C   27°C  0/7
23:16:09: 1152MHz  0.00  29%   6%   3%   2%  17%   0%   41°C   27°C  0/7
23:16:09: 1152MHz  0.00  28%   8%   7%   0%  12%   0%   40°C   27°C  0/7
23:16:10: 1152MHz  0.00  30%   4%  24%   1%   0%   0%   40°C   27°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Wed Jan  9 23:18:10 UTC 2019 | SoPine A64 | 5.69 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@nightly) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #76 SMP PREEMPT Wed Jan 9 22:15:14 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s18880 r8192 d22080 u49152
[    0.000000] pcpu-alloc: s18880 r8192 d22080 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1965428k/1965428k available, 115340k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000ab2000 - 0xffffffc000b329c0   (   515 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000ab1e84   ( 10440 kB)
                     .data : 0xffffffc000b33000 - 0xffffffc000c8d318   (  1385 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.019823] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.019832] pid_max: default: 32768 minimum: 301
[   10.019926] Security Framework initialized
[   10.019974] AppArmor: AppArmor initialized
[   10.020008] Mount-cache hash table entries: 256
[   10.030316] Initializing cgroup subsys memory
[   10.030365] Initializing cgroup subsys devices
[   10.030372] Initializing cgroup subsys freezer
[   10.030378] Initializing cgroup subsys blkio
[   10.030384] Initializing cgroup subsys perf_event
[   10.030394] Initializing cgroup subsys hugetlb
[   10.030456] ftrace: allocating 27493 entries in 108 pages
[   10.062518] CPU0: update cpu_power 1968128
[   10.062538] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.063536] virtual base = 0xffffff800000a000.
[   10.063550] gicd_base = 0xffffff800000c000.
[   10.063555] gicc_base = 0xffffff800000e000.
[   10.064193] CPU1: Booted secondary processor
[   10.064219] CPU1: update cpu_power 1968128
[   10.066818] CPU2: Booted secondary processor
[   10.066831] CPU2: update cpu_power 1968128
[   10.070936] CPU3: Booted secondary processor
[   10.070947] CPU3: update cpu_power 1968128
[   10.071017] Brought up 4 CPUs
[   10.071039] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.071542] devtmpfs: initialized
[   10.076270] pinctrl core: initialized pinctrl subsystem
[   10.078684] NET: Registered protocol family 16
[   10.078938] script_sysfs_init success
[   10.079174] dump_class_init,806, success
[   10.079414] vdso: 2 pages (1 code, 1 data) at base ffffffc000b39000
[   10.079435] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.080695] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.081758] DMA: preallocated 256 KiB pool for atomic allocations
[   10.081874] Serial: AMBA PL011 UART driver
[   10.081978] axp81x_board_init: axp regl_devs num = 23
[   10.082117] pll_audio-set_default_rate=24576000 success!
[   10.082136] pll_video0-set_default_rate=297000000 success!
[   10.082206] pll_video1-set_default_rate=297000000 success!
[   10.082266] pll_de-set_default_rate=297000000 success!
[   10.082973] de-set_default_source=pll_de success!
[   10.082979] de-set_default_rate=297000000 success!
[   10.083020] tcon0-set_default_source=pll_mipi success!
[   10.083051] tcon1-set_default_source=pll_video0 success!
[   10.083265] hdmi-set_default_source=pll_video0 success!
[   10.085479] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.085635] [sun50iw1p1_pinctrl_probe][838]
[   10.087064] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.087679] sunxi hwspinlock vbase:0xffffff800005c000
[   10.097770] bio: create slab <bio-0> at 0
[   10.098111] pwm module init!
[   10.099329] SCSI subsystem initialized
[   10.099452] usbcore: registered new interface driver usbfs
[   10.099486] usbcore: registered new interface driver hub
[   10.099551] usbcore: registered new device driver usb
[   10.100240] Linux video capture interface: v2.00
[   10.100687] [ARISC] :sunxi-arisc driver v1.10
[   10.107604] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.107851] Advanced Linux Sound Architecture Driver Initialized.
[   10.108195] NetLabel: Initializing
[   10.108200] NetLabel:  domain hash size = 128
[   10.108204] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.108243] NetLabel:  unlabeled traffic allowed by default
[   10.108403] [pm]aw_pm_init!
[   10.108472] rtc physical base = 0x0000000001f00000 .
[   10.108506] np name = /soc@01c00000/rtc@01f00000.
[   10.108513] base = ffffff800006e100, len = 4.
[   10.108518] pmu name: pmu0 .
[   10.108551] pmu0_enable = 0x1.
[   10.108556] pmux_id = 0x6.
[   10.108563] pmux_twi_id = 0x1.
[   10.108568] pmux_twi_addr = 0x34.
[   10.108572] pmu name: pmu1 .
[   10.108623] Warning: can not find np for pmu1.
[   10.108852] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.109012] after inited: sys_mask config = 0x4a55.
[   10.109034] Warning: can not find np for dynamic_standby_para.
[   10.109167] [pm]valid
[   10.109171] [pm]valid
[   10.109175] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.109379] Switching to clocksource arch_sys_counter_ool
[   10.119967] AppArmor: AppArmor Filesystem Enabled
[   10.126454] NET: Registered protocol family 2
[   10.127144] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.127386] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.127699] TCP: Hash tables configured (established 16384 bind 16384)
[   10.127784] TCP: reno registered
[   10.127794] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.127846] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.128100] NET: Registered protocol family 1
[   10.128424] RPC: Registered named UNIX socket transport module.
[   10.128430] RPC: Registered udp transport module.
[   10.128434] RPC: Registered tcp transport module.
[   10.128439] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.128611] Trying to unpack rootfs image as initramfs...
[   10.333081] Freeing initrd memory: 4292K (ffffffc075a85000 - ffffffc075eb6000)
[   10.333675] kvm [1]: Using HYP init bounce page @b787c000
[   10.334178] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.334609] kvm [1]: timer IRQ27
[   10.334626] kvm [1]: Hyp mode initialized successfully
[   10.336394] lock super standby defaultly!
[   10.336410] lookup_scene_lock_name: new scene lock super_standby
[   10.336415] scene_lock_init name=super_standby
[   10.336422] scene_lock: super_standby, type 5, count 1
[   10.336845] audit: initializing netlink socket (disabled)
[   10.336903] type=2000 audit(0.310:1): initialized
[   10.337572] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.338028] VFS: Disk quotas dquot_6.5.2
[   10.338129] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.339053] NFS: Registering the id_resolver key type
[   10.339098] Key type id_resolver registered
[   10.339103] Key type id_legacy registered
[   10.339115] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.339258] NTFS driver 2.1.30 [Flags: R/W].
[   10.339423] fuse init (API version 7.22)
[   10.339597] msgmni has been set to 3975
[   10.340559] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.340644] io scheduler noop registered
[   10.340650] io scheduler deadline registered
[   10.340679] io scheduler cfq registered (default)
[   10.341261] [DISP]disp_module_init
[   10.341700] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.341707] [DISP] boot_disp:0x0
[   10.342308] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.342440] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.342572] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.343691] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.343696] [DISP] fb_base:0x0
[   10.361414] Console: switching to colour frame buffer device 160x45
[   10.375993] [DISP]disp_module_init finish
[   10.376414] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.376437] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.376792] console [ttyS0] enabled
[   10.377170] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.377399] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.377705] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.377990] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.378322] misc dump reg init
[   10.378466] [drm] Initialized drm 1.1.0 20060810
[   10.380599] brd: module loaded
[   10.382712] loop: module loaded
[   10.382970] sunxi-bt bt.27: Missing bt_power.
[   10.382978] sunxi-bt bt.27: bt_power_name ((null))
[   10.382986] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.383018] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.383062] sunxi-bt bt.27: clk not config
[   10.383133] sunxi-bt bt.27: block state already is 1
[   10.383312] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.383319] sunxi-wlan wlan.26: Missing wlan_power.
[   10.383325] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.383332] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.383348] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.383367] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.383384] sunxi-wlan wlan.26: clk not config
[   10.384080] WARNING: Get ephy clock is failed
[   10.384683] chipid-sunxi serial 140050374620201507cf
[   10.384776] PPP generic driver version 2.4.2
[   10.384929] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.385096] get ehci0-controller drv_vbus_gpio is fail
[   10.385102] get ehci0-controller, regulator_io is no nocare
[   10.385142] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   10.385194] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.385214] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.385555] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000584c7c
[   10.404631] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.404713] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.404721] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.404727] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.404734] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.404740] usb usb1: SerialNumber: sunxi-ehci
[   10.405073] hub 1-0:1.0: USB hub found
[   10.405090] hub 1-0:1.0: 1 port detected
[   10.405224] scene_lock_init name=ehci_standby
[   10.405298] get ehci1-controller drv_vbus_gpio is fail
[   10.405304] get ehci1-controller, regulator_io is no nocare
[   10.405341] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000d16dd0, 0x:ffffff80000b2000, irq_no:6a
[   10.405389] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.405409] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.405674] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000584c7c
[   10.424463] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.424510] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.424518] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.424525] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.424532] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.424538] usb usb2: SerialNumber: sunxi-ehci
[   10.424837] hub 2-0:1.0: USB hub found
[   10.424851] hub 2-0:1.0: 1 port detected
[   10.424974] scene_lock_init name=ehci_standby
[   10.425165] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.425321] get ohci0-controller drv_vbus_gpio is fail
[   10.425327] get ohci0-controller, regulator_io is no nocare
[   10.425367] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   10.425416] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.425431] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.425462] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.487322] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.487330] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.487337] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.487344] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.487350] usb usb3: SerialNumber: sunxi-ohci
[   10.487615] hub 3-0:1.0: USB hub found
[   10.487628] hub 3-0:1.0: 1 port detected
[   10.487744] scene_lock_init name=ohci_standby
[   10.487803] get ohci1-controller drv_vbus_gpio is fail
[   10.487808] get ohci1-controller, regulator_io is no nocare
[   10.487840] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000d16930
[   10.487879] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.487897] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.487923] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.546398] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.546407] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.546413] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.546420] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.546426] usb usb4: SerialNumber: sunxi-ohci
[   10.546698] hub 4-0:1.0: USB hub found
[   10.546712] hub 4-0:1.0: 1 port detected
[   10.546826] scene_lock_init name=ohci_standby
[   10.547128] usbcore: registered new interface driver usb-storage
[   10.547159] usbcore: registered new interface driver ums-alauda
[   10.547186] usbcore: registered new interface driver ums-cypress
[   10.547212] usbcore: registered new interface driver ums-datafab
[   10.547234] usbcore: registered new interface driver ums_eneub6250
[   10.547257] usbcore: registered new interface driver ums-freecom
[   10.547282] usbcore: registered new interface driver ums-isd200
[   10.547306] usbcore: registered new interface driver ums-jumpshot
[   10.547329] usbcore: registered new interface driver ums-karma
[   10.547352] usbcore: registered new interface driver ums-onetouch
[   10.547387] usbcore: registered new interface driver ums-realtek
[   10.547412] usbcore: registered new interface driver ums-sddr09
[   10.547435] usbcore: registered new interface driver ums-sddr55
[   10.547463] usbcore: registered new interface driver ums-usbat
[   10.547548] usbcore: registered new interface driver usbserial
[   10.547574] usbcore: registered new interface driver usbserial_generic
[   10.547598] usbserial: USB Serial support registered for generic
[   10.547788] mousedev: PS/2 mouse device common for all mice
[   10.548239] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.549086] get ctp_para failed, -1
[   10.549109] get node gsensor failed
[   10.549113] get sysconfig para erro!
[   10.549122] get node lightsensor failed
[   10.549126] get sysconfig para erro!
[   10.549135] get node gyroscopesensor failed
[   10.549138] get sysconfig para erro!
[   10.549147] get node compasssensor failed
[   10.549150] get sysconfig para erro!
[   10.549440] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.549460] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.549622] i2c /dev entries driver
[   10.592167] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.595610] sunxi budget cooling probe start !
[   10.595636] CPU freq cooling register Success
[   10.595654] CPU hotplug cooling register Success
[   10.595742] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.595750] CPU budget cooling register Success
[   10.595963] sunxi gpu cooling probe start !
[   10.595972] CPU gpu cooling register Success
[   10.596618] cpuidle: using governor ladder
[   10.596624] cpuidle: using governor menu
[   10.597365] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.597392] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.597401] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.597409] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.597460] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.597466] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.598056] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.598081] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.549176] wakeup gpio set err!get node ctp failed
[   10.601488] get sysconfig para erro!
[   10.611270] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.630958] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.631334] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.631357] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.631364] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.631371] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.631375] get() with no identifier
[   10.631379] get() with no identifier
[   10.631382] get() with no identifier
[   10.631388] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.631394] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.631400] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.631780] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.631797] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.631816] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.632601] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.632621] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.635001] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.637129] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.637943] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.638755] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.639567] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.640194] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.640237] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.642612] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.650628] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.670314] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.670998] ledtrig-cpu: registered to indicate activity on CPUs
[   10.671064] hidraw: raw HID events driver (C) Jiri Kosina
[   10.671212] usbcore: registered new interface driver usbhid
[   10.671216] usbhid: USB HID core driver
[   10.672076] usbcore: registered new interface driver snd-usb-audio
[   10.674107] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.674900] TCP: cubic registered
[   10.674908] Initializing XFRM netlink socket
[   10.674992] NET: Registered protocol family 10
[   10.675792] mip6: Mobile IPv6
[   10.675800] sit: IPv6 over IPv4 tunneling driver
[   10.676165] NET: Registered protocol family 17
[   10.676190] NET: Registered protocol family 15
[   10.676238] 8021q: 802.1Q VLAN Support v1.8
[   10.676293] Key type dns_resolver registered
[   10.676502] Registering SWP/SWPB emulation handler
[   10.676791] registered taskstats version 1
[   10.688776] Key type encrypted registered
[   10.688798] AppArmor: AppArmor sha1 policy hashing enabled
[   10.689238] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.689247] [DISP] boot_disp:0x0
[   10.689292] HDMI base address: ffffff8000b40000
[   10.690081] [HDMI] power vcc-hdmi-33
[   10.690607] [HDMI] cec support = 0
[   10.709630] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.712127] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.712199] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.712301] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.712326] mmc0: new high speed SDHC card at address aaaa
[   10.712754] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.714783]  mmcblk0: p1
[   10.715899] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.716708] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.716727] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.719119] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.720939] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.721748] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.722555] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.723361] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.724168] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.724975] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.725782] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.726589] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727396] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727413] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.728246] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.728263] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.801054] input: sunxi-ths as /devices/virtual/input/input2
[   10.801211] thermal thermal_zone0: failed to read out thermal zone 0
[   10.801612] ALSA device list:
[   10.801618]   #0: sndhdmi
[   10.802048] Freeing unused kernel memory: 512K (ffffffc000ab2000 - ffffffc000b32000)
[   11.398551] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.074955] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.074973] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80
[   14.074992] scene_lock_destroy name=ehci_standby
[   14.075006] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.075028] usb usb1: USB disconnect, device number 1
[   14.075580] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.075613] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.075621] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.075626] scene_lock_destroy name=ohci_standby
[   14.075634] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.075651] usb usb3: USB disconnect, device number 1
[   14.076016] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.076049] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.076057] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   14.076101] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.076124] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.079483] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b86d0
[   14.094648] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.094747] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.094755] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.094762] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.094768] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.094774] usb usb1: SerialNumber: sunxi-ehci
[   14.095258] hub 1-0:1.0: USB hub found
[   14.095277] hub 1-0:1.0: 1 port detected
[   14.095427] scene_lock_init name=ehci_standby
[   14.095434] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.095441] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.095491] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.095510] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.095551] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b86d0
[   14.157689] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.157704] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.157711] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.157718] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.157724] usb usb3: SerialNumber: sunxi-ohci
[   14.158177] hub 3-0:1.0: USB hub found
[   14.158197] hub 3-0:1.0: 1 port detected
[   14.158375] scene_lock_init name=ohci_standby
[   16.460115] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.817647] systemd[1]: System time before build time, advancing clock.
[   16.854711] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.855017] systemd[1]: Detected architecture arm64.
[   16.882168] systemd[1]: Set hostname to <cluster0>.
[   17.164951] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.184715] systemd[1]: Listening on Syslog Socket.
[   17.204277] systemd[1]: Listening on Journal Socket.
[   17.223842] systemd[1]: Reached target Remote File Systems (Pre).
[   17.243897] systemd[1]: Created slice System Slice.
[   17.265078] systemd[1]: Starting Set console keymap...
[   17.293440] systemd[1]: Starting Load Kernel Modules...
[   17.321497] systemd[1]: Starting Restore / save the current clock...
[   17.345294] systemd[1]: Mounting Debug File System...
[   17.362564] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.381690] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.401417] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.421075] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.445513] systemd[1]: Mounting Huge Pages File System...
[   17.460761] systemd[1]: Listening on udev Control Socket.
[   17.481705] systemd[1]: Starting Nameserver information manager...
[   17.502500] systemd[1]: Reached target Paths.
[   17.512602] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.512901] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.513061] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.513239] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.514386] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.519341] systemd[1]: Listening on udev Kernel Socket.
[   17.538924] systemd[1]: Reached target Swap.
[   17.559321] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.572012] cfg80211: Calling CRDA to update world regulatory domain
[   17.580572] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.599865] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.619910] systemd[1]: Mounting POSIX Message Queue File System...
[   17.637439] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.650786] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.657470] systemd[1]: Created slice User and Session Slice.
[   17.676716] systemd[1]: Reached target Slices.
[   17.694438] RTL871X: module init start
[   17.694452] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.694457] RTL871X: build time: Jan  9 2019 22:15:04
[   17.694461] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.694477] sunxi-wlan wlan.26: bus_index: 1
[   17.694646] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.696494] systemd[1]: Reached target Remote File Systems.
[   17.724681] systemd[1]: Reached target Encrypted Volumes.
[   17.749517] systemd[1]: Mounted Debug File System.
[   17.765186] systemd[1]: Mounted POSIX Message Queue File System.
[   17.784732] systemd[1]: Mounted Huge Pages File System.
[   17.803006] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.803089] RTL871X: module init ret=0
[   17.803118] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   17.805512] systemd[1]: Started Set console keymap.
[   17.814193] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.825365] systemd[1]: Started Load Kernel Modules.
[   17.834650] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.835462] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.835482] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.837884] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.839702] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   17.840508] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.841315] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.842122] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.842926] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.843737] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.844548] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.844644] systemd[1]: Started Restore / save the current clock.
[   17.845361] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.846169] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.846188] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.847040] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   17.847057] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   17.867401] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.893988] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.915578] systemd[1]: Started Nameserver information manager.
[   17.940891] systemd[1]: Time has been changed
[   18.026198] systemd[1]: Reached target Network (Pre).
[   18.045237] systemd[1]: Starting udev Coldplug all Devices...
[   18.062574] systemd[1]: Starting Load/Save Random Seed...
[   18.069891] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.092442] systemd[1]: Mounting Configuration File System...
[   18.101451] systemd[1]: Mounting FUSE Control File System...
[   18.110199] systemd[1]: Starting Apply Kernel Variables...
[   18.131539] systemd[1]: Mounted FUSE Control File System.
[   18.137254] systemd[1]: Mounted Configuration File System.
[   18.161992] systemd[1]: Started Load/Save Random Seed.
[   18.179511] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.199977] systemd[1]: Started Apply Kernel Variables.
[   18.274108] systemd[1]: Starting udev Kernel Device Manager...
[   18.296583] systemd[1]: Reached target Local File Systems (Pre).
[   18.319395] systemd[1]: Mounting /tmp...
[   18.339537] systemd[1]: Mounted /tmp.
[   18.356262] systemd[1]: Started udev Kernel Device Manager.
[   18.376364] systemd[1]: Started udev Coldplug all Devices.
[   18.413695] systemd[1]: Reached target Local File Systems.
[   18.437428] systemd[1]: Starting Armbian ZRAM config...
[   18.471338] systemd[1]: Starting Raise network interfaces...
[   18.496090] systemd[1]: Starting Set console font and keymap...
[   18.523587] sunxi cedar version 0.1
[   18.523775] [cedar]: install start!!!
[   18.523900] ycy the get irq is 90
[   18.524221] ycy clk_bass_vir 0x18  is ffffff8000b6e018, the value:3006207
[   18.524229] ycy clk_bass_vir 0x13c  is ffffff8000b6e13c, the value:0
[   18.524234] ycy clk_bass_vir 0x64  is ffffff8000b6e064, the value:601810
[   18.524238] ycy clk_bass_vir 0x2c4  is ffffff8000b6e2c4, the value:601c10
[   18.524243] ycy clk_bass_vir 0x100  is ffffff8000b6e100, the value:0
[   18.524247] [cedar]: install end!!!
[   18.542048] cfg80211: World regulatory domain updated:
[   18.542077] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.542084] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.542089] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.542095] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.542100] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.542106] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.542111] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.542116] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.542122] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.543519] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.565856] systemd[1]: Starting Journal Service...
[   18.580325] [VFE]cci probe end cci_sel = 0!
[   18.580609] [VFE]cci_init end
[   18.590993] Driver for 1-wire Dallas network protocol.
[   18.592763] Registered IR keymap rc_map_sunxi
[   18.593292] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.593544] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.626109] systemd[1]: Found device /dev/ttyS0.
[   18.738759] IR NEC protocol handler initialized
[   18.739353] IR RC5(x) protocol handler initialized
[   18.740357] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.740606] IR MCE Keyboard/mouse protocol handler initialized
[   18.742478] IR Sony protocol handler initialized
[   18.742480] IR RC6 protocol handler initialized
[   18.742773] lirc_dev: IR Remote Control driver registered, major 248
[   18.743266] IR SANYO protocol handler initialized
[   18.743539] IR JVC protocol handler initialized
[   18.744961] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.744970] IR LIRC bridge handler initialized
[   18.841953] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.917974] systemd[1]: Reached target Sound Card.
[   18.939460] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   18.996246] [VFE]Welcome to Video Front End driver
[   18.997660] [VFE]csi probe end csi_sel = 0!
[   18.998099] [VFE]csi_init end
[   18.999437] [VFE]isp probe start isp_sel = 0!
[   19.000464] [ISP] isp platform_id = 3!
[   19.000491] [VFE]isp probe end isp_sel = 0!
[   19.000605] [VFE]sunxi_isp_platform_register end
[   19.002107] [VFE]mipi probe start mipi_sel = 0!
[   19.002174] [VFE]mipi probe end mipi_sel = 0!
[   19.002288] [VFE]mipi_init end
[   19.002296] [VFE]flash_init end
[   19.003788] [VFE]vfe_init end
[   19.058346] systemd[1]: Started Journal Service.
[   19.070218] sunxi-bt bt.27: block state already is 1
[   19.188893] systemd-journald[327]: Received request to flush runtime journal from PID 1
[   19.246248] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.260184] zram: Created 6 device(s) ...
[   19.394287] Adding 254468k swap on /dev/zram1.  Priority:5 extents:1 across:254468k SS
[   19.419509] Adding 254468k swap on /dev/zram2.  Priority:5 extents:1 across:254468k SS
[   19.446831] Adding 254468k swap on /dev/zram3.  Priority:5 extents:1 across:254468k SS
[   19.474708] Adding 254468k swap on /dev/zram4.  Priority:5 extents:1 across:254468k SS
[   19.661666] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.661689] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.69
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035768 kB
MemFree:         1895572 kB
Buffers:            7424 kB
Cached:            54012 kB
SwapCached:            0 kB
Active:            29808 kB
Inactive:          48260 kB
Active(anon):      16804 kB
Inactive(anon):     2884 kB
Active(file):      13004 kB
Inactive(file):    45376 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017872 kB
SwapFree:        1017872 kB
Dirty:               176 kB
Writeback:             0 kB
AnonPages:         16748 kB
Mapped:            14792 kB
Shmem:              3044 kB
Slab:              22708 kB
SReclaimable:       9112 kB
SUnreclaim:        13596 kB
KernelStack:        2000 kB
PageTables:          656 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035756 kB
Committed_AS:     111588 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633508 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5607
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 62561
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254472 zram1
 253        2     254472 zram2
 253        3     254472 zram3
 253        4     254472 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
/dev/mmcblk0p1   15G  881M   14G   7% /
tmpfs           995M     0  995M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           995M     0  995M   0% /sys/fs/cgroup
tmpfs           995M  4.0K  995M   1% /tmp
/dev/zram0       49M  1.7M   44M   4% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M  1.3M 374.5K  1.2M         /var/log
/dev/zram1             248.5M    4K    78B    4K         [SWAP]
/dev/zram2             248.5M    4K    78B    4K         [SWAP]
/dev/zram3             248.5M    4K    78B    4K         [SWAP]
/dev/zram4             248.5M    4K    78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
23:18:14: 1152MHz  0.40  36%  12%  16%   0%   8%   0%   37°C   23°C  0/7
23:18:14: 1152MHz  0.40  44%   8%   3%   0%  31%   0%   37°C   23°C  0/7
23:18:14: 1152MHz  0.40  28%   4%   0%   0%  22%   0%   35°C   23°C  0/7
23:18:15: 1152MHz  0.40  27%   4%   0%   0%  21%   0%   34°C   23°C  0/7
23:18:15: 1152MHz  0.40  30%   6%  15%   0%   8%   0%   34°C   23°C  0/7
Wed Jan  9 23:20:29 UTC 2019 | SoPine A64 | 5.69 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.021258] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.021267] pid_max: default: 32768 minimum: 301
[   10.021363] Security Framework initialized
[   10.021412] AppArmor: AppArmor initialized
[   10.021446] Mount-cache hash table entries: 256
[   10.031772] Initializing cgroup subsys memory
[   10.031818] Initializing cgroup subsys devices
[   10.031825] Initializing cgroup subsys freezer
[   10.031830] Initializing cgroup subsys blkio
[   10.031836] Initializing cgroup subsys perf_event
[   10.031846] Initializing cgroup subsys hugetlb
[   10.031905] ftrace: allocating 27493 entries in 108 pages
[   10.063926] CPU0: update cpu_power 1968128
[   10.063947] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.064939] virtual base = 0xffffff800000a000.
[   10.064953] gicd_base = 0xffffff800000c000.
[   10.064958] gicc_base = 0xffffff800000e000.
[   10.065593] CPU1: Booted secondary processor
[   10.065620] CPU1: update cpu_power 1968128
[   10.068216] CPU2: Booted secondary processor
[   10.068229] CPU2: update cpu_power 1968128
[   10.072337] CPU3: Booted secondary processor
[   10.072347] CPU3: update cpu_power 1968128
[   10.072422] Brought up 4 CPUs
[   10.072443] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.072948] devtmpfs: initialized
[   10.077679] pinctrl core: initialized pinctrl subsystem
[   10.080115] NET: Registered protocol family 16
[   10.080370] script_sysfs_init success
[   10.080609] dump_class_init,806, success
[   10.080850] vdso: 2 pages (1 code, 1 data) at base ffffffc000b39000
[   10.080871] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.082131] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.083184] DMA: preallocated 256 KiB pool for atomic allocations
[   10.083301] Serial: AMBA PL011 UART driver
[   10.083406] axp81x_board_init: axp regl_devs num = 23
[   10.083547] pll_audio-set_default_rate=24576000 success!
[   10.083565] pll_video0-set_default_rate=297000000 success!
[   10.083636] pll_video1-set_default_rate=297000000 success!
[   10.083694] pll_de-set_default_rate=297000000 success!
[   10.084402] de-set_default_source=pll_de success!
[   10.084407] de-set_default_rate=297000000 success!
[   10.084449] tcon0-set_default_source=pll_mipi success!
[   10.084478] tcon1-set_default_source=pll_video0 success!
[   10.084692] hdmi-set_default_source=pll_video0 success!
[   10.086906] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.087062] [sun50iw1p1_pinctrl_probe][838]
[   10.088491] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.089107] sunxi hwspinlock vbase:0xffffff800005c000
[   10.099190] bio: create slab <bio-0> at 0
[   10.099537] pwm module init!
[   10.100753] SCSI subsystem initialized
[   10.100875] usbcore: registered new interface driver usbfs
[   10.100909] usbcore: registered new interface driver hub
[   10.100974] usbcore: registered new device driver usb
[   10.101664] Linux video capture interface: v2.00
[   10.102109] [ARISC] :sunxi-arisc driver v1.10
[   10.109005] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.109253] Advanced Linux Sound Architecture Driver Initialized.
[   10.109597] NetLabel: Initializing
[   10.109603] NetLabel:  domain hash size = 128
[   10.109607] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.109645] NetLabel:  unlabeled traffic allowed by default
[   10.109800] [pm]aw_pm_init!
[   10.109867] rtc physical base = 0x0000000001f00000 .
[   10.109899] np name = /soc@01c00000/rtc@01f00000.
[   10.109905] base = ffffff800006e100, len = 4.
[   10.109910] pmu name: pmu0 .
[   10.109944] pmu0_enable = 0x1.
[   10.109950] pmux_id = 0x6.
[   10.109956] pmux_twi_id = 0x1.
[   10.109961] pmux_twi_addr = 0x34.
[   10.109965] pmu name: pmu1 .
[   10.110013] Warning: can not find np for pmu1.
[   10.110242] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.110402] after inited: sys_mask config = 0x4a55.
[   10.110424] Warning: can not find np for dynamic_standby_para.
[   10.110550] [pm]valid
[   10.110554] [pm]valid
[   10.110558] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.110762] Switching to clocksource arch_sys_counter_ool
[   10.121335] AppArmor: AppArmor Filesystem Enabled
[   10.127805] NET: Registered protocol family 2
[   10.128495] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.128736] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.129038] TCP: Hash tables configured (established 16384 bind 16384)
[   10.129121] TCP: reno registered
[   10.129131] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.129182] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.129433] NET: Registered protocol family 1
[   10.129755] RPC: Registered named UNIX socket transport module.
[   10.129760] RPC: Registered udp transport module.
[   10.129765] RPC: Registered tcp transport module.
[   10.129769] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.129943] Trying to unpack rootfs image as initramfs...
[   10.334427] Freeing initrd memory: 4292K (ffffffc075a85000 - ffffffc075eb6000)
[   10.335021] kvm [1]: Using HYP init bounce page @b787a000
[   10.335535] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.335958] kvm [1]: timer IRQ27
[   10.335973] kvm [1]: Hyp mode initialized successfully
[   10.337736] lock super standby defaultly!
[   10.337752] lookup_scene_lock_name: new scene lock super_standby
[   10.337757] scene_lock_init name=super_standby
[   10.337764] scene_lock: super_standby, type 5, count 1
[   10.338176] audit: initializing netlink socket (disabled)
[   10.338233] type=2000 audit(0.310:1): initialized
[   10.338900] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.339357] VFS: Disk quotas dquot_6.5.2
[   10.339459] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.340391] NFS: Registering the id_resolver key type
[   10.340437] Key type id_resolver registered
[   10.340442] Key type id_legacy registered
[   10.340454] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.340597] NTFS driver 2.1.30 [Flags: R/W].
[   10.340758] fuse init (API version 7.22)
[   10.340934] msgmni has been set to 3975
[   10.341888] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.341972] io scheduler noop registered
[   10.341978] io scheduler deadline registered
[   10.342007] io scheduler cfq registered (default)
[   10.342584] [DISP]disp_module_init
[   10.343021] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.343029] [DISP] boot_disp:0x0
[   10.343617] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.343749] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.343880] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.344993] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.344999] [DISP] fb_base:0x0
[   10.362711] Console: switching to colour frame buffer device 160x45
[   10.377273] [DISP]disp_module_init finish
[   10.377691] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.377714] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.378070] console [ttyS0] enabled
[   10.378452] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.378681] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.378987] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.379273] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.379605] misc dump reg init
[   10.379751] [drm] Initialized drm 1.1.0 20060810
[   10.381890] brd: module loaded
[   10.384000] loop: module loaded
[   10.384258] sunxi-bt bt.27: Missing bt_power.
[   10.384266] sunxi-bt bt.27: bt_power_name ((null))
[   10.384274] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.384307] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.384351] sunxi-bt bt.27: clk not config
[   10.384424] sunxi-bt bt.27: block state already is 1
[   10.384604] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.384611] sunxi-wlan wlan.26: Missing wlan_power.
[   10.384617] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.384624] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.384640] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.384659] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.384676] sunxi-wlan wlan.26: clk not config
[   10.385380] WARNING: Get ephy clock is failed
[   10.386001] chipid-sunxi serial 140050374620201507cf
[   10.386094] PPP generic driver version 2.4.2
[   10.386248] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.386414] get ehci0-controller drv_vbus_gpio is fail
[   10.386420] get ehci0-controller, regulator_io is no nocare
[   10.386460] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   10.386514] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.386533] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.386882] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000584c7c
[   10.406017] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.406098] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.406106] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.406113] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.406119] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.406125] usb usb1: SerialNumber: sunxi-ehci
[   10.406461] hub 1-0:1.0: USB hub found
[   10.406478] hub 1-0:1.0: 1 port detected
[   10.406610] scene_lock_init name=ehci_standby
[   10.406683] get ehci1-controller drv_vbus_gpio is fail
[   10.406689] get ehci1-controller, regulator_io is no nocare
[   10.406726] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000d16dd0, 0x:ffffff80000b2000, irq_no:6a
[   10.406773] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.406791] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.407042] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000584c7c
[   10.425847] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.425893] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.425901] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.425907] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.425914] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.425920] usb usb2: SerialNumber: sunxi-ehci
[   10.426209] hub 2-0:1.0: USB hub found
[   10.426222] hub 2-0:1.0: 1 port detected
[   10.426346] scene_lock_init name=ehci_standby
[   10.426539] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.426692] get ohci0-controller drv_vbus_gpio is fail
[   10.426698] get ohci0-controller, regulator_io is no nocare
[   10.426737] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   10.426786] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.426801] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.426832] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.488706] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.488714] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.488721] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.488727] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.488733] usb usb3: SerialNumber: sunxi-ohci
[   10.488999] hub 3-0:1.0: USB hub found
[   10.489013] hub 3-0:1.0: 1 port detected
[   10.489128] scene_lock_init name=ohci_standby
[   10.489190] get ohci1-controller drv_vbus_gpio is fail
[   10.489195] get ohci1-controller, regulator_io is no nocare
[   10.489229] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000d16930
[   10.489269] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.489287] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.489313] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.547783] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.547791] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.547798] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.547804] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.547811] usb usb4: SerialNumber: sunxi-ohci
[   10.548080] hub 4-0:1.0: USB hub found
[   10.548094] hub 4-0:1.0: 1 port detected
[   10.548205] scene_lock_init name=ohci_standby
[   10.548506] usbcore: registered new interface driver usb-storage
[   10.548537] usbcore: registered new interface driver ums-alauda
[   10.548564] usbcore: registered new interface driver ums-cypress
[   10.548589] usbcore: registered new interface driver ums-datafab
[   10.548612] usbcore: registered new interface driver ums_eneub6250
[   10.548635] usbcore: registered new interface driver ums-freecom
[   10.548659] usbcore: registered new interface driver ums-isd200
[   10.548682] usbcore: registered new interface driver ums-jumpshot
[   10.548705] usbcore: registered new interface driver ums-karma
[   10.548728] usbcore: registered new interface driver ums-onetouch
[   10.548763] usbcore: registered new interface driver ums-realtek
[   10.548788] usbcore: registered new interface driver ums-sddr09
[   10.548812] usbcore: registered new interface driver ums-sddr55
[   10.548840] usbcore: registered new interface driver ums-usbat
[   10.548922] usbcore: registered new interface driver usbserial
[   10.548948] usbcore: registered new interface driver usbserial_generic
[   10.548972] usbserial: USB Serial support registered for generic
[   10.549166] mousedev: PS/2 mouse device common for all mice
[   10.549617] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.550470] get ctp_para failed, -1
[   10.550491] get node gsensor failed
[   10.550495] get sysconfig para erro!
[   10.550504] get node lightsensor failed
[   10.550508] get sysconfig para erro!
[   10.550517] get node gyroscopesensor failed
[   10.550520] get sysconfig para erro!
[   10.550529] get node compasssensor failed
[   10.550532] get sysconfig para erro!
[   10.550820] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.550839] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.551000] i2c /dev entries driver
[   10.593548] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.596997] sunxi budget cooling probe start !
[   10.597026] CPU freq cooling register Success
[   10.597044] CPU hotplug cooling register Success
[   10.597131] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.597139] CPU budget cooling register Success
[   10.597352] sunxi gpu cooling probe start !
[   10.597361] CPU gpu cooling register Success
[   10.598012] cpuidle: using governor ladder
[   10.598020] cpuidle: using governor menu
[   10.598761] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.598789] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.598797] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.598805] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.598856] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.598863] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.599457] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.599481] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.550558] wakeup gpio set err!get node ctp failed
[   10.602873] get sysconfig para erro!
[   10.612654] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.632344] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.632720] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.632744] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.632751] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.632758] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.632762] get() with no identifier
[   10.632765] get() with no identifier
[   10.632769] get() with no identifier
[   10.632775] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.632781] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.632787] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.633166] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.633180] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.633200] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.633987] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.634007] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.636391] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.638522] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.639336] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.640147] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.640959] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.641584] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.641626] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.644001] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.652013] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.671700] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.672374] ledtrig-cpu: registered to indicate activity on CPUs
[   10.672439] hidraw: raw HID events driver (C) Jiri Kosina
[   10.672589] usbcore: registered new interface driver usbhid
[   10.672593] usbhid: USB HID core driver
[   10.673445] usbcore: registered new interface driver snd-usb-audio
[   10.675474] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.676268] TCP: cubic registered
[   10.676277] Initializing XFRM netlink socket
[   10.676361] NET: Registered protocol family 10
[   10.677156] mip6: Mobile IPv6
[   10.677163] sit: IPv6 over IPv4 tunneling driver
[   10.677530] NET: Registered protocol family 17
[   10.677555] NET: Registered protocol family 15
[   10.677603] 8021q: 802.1Q VLAN Support v1.8
[   10.677673] Key type dns_resolver registered
[   10.677876] Registering SWP/SWPB emulation handler
[   10.678160] registered taskstats version 1
[   10.690171] Key type encrypted registered
[   10.690192] AppArmor: AppArmor sha1 policy hashing enabled
[   10.690632] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.690642] [DISP] boot_disp:0x0
[   10.690689] HDMI base address: ffffff8000b40000
[   10.691519] [HDMI] power vcc-hdmi-33
[   10.692044] [HDMI] cec support = 0
[   10.711009] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.713506] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.713582] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.713687] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.713712] mmc0: new high speed SDHC card at address aaaa
[   10.714141] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.716162]  mmcblk0: p1
[   10.717276] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.718086] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.718105] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.720501] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.722319] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.723128] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.723935] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.724741] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.725546] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.726353] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727160] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727967] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.728774] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.728790] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.729623] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.729640] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.802497] input: sunxi-ths as /devices/virtual/input/input2
[   10.802657] thermal thermal_zone0: failed to read out thermal zone 0
[   10.803076] ALSA device list:
[   10.803082]   #0: sndhdmi
[   10.803504] Freeing unused kernel memory: 512K (ffffffc000ab2000 - ffffffc000b32000)
[   11.399874] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.076338] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.076352] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80
[   14.076372] scene_lock_destroy name=ehci_standby
[   14.076385] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.076408] usb usb1: USB disconnect, device number 1
[   14.076959] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.076991] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.076998] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.077003] scene_lock_destroy name=ohci_standby
[   14.077011] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.077027] usb usb3: USB disconnect, device number 1
[   14.077398] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.077432] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.077440] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   14.077484] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.077508] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.080762] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b86d0
[   14.096050] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.096148] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.096156] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.096162] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.096169] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.096175] usb usb1: SerialNumber: sunxi-ehci
[   14.096640] hub 1-0:1.0: USB hub found
[   14.096659] hub 1-0:1.0: 1 port detected
[   14.096810] scene_lock_init name=ehci_standby
[   14.096817] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.096825] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.096876] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.096894] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.096935] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b86d0
[   14.159075] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.159091] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.159097] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.159104] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.159110] usb usb3: SerialNumber: sunxi-ohci
[   14.159567] hub 3-0:1.0: USB hub found
[   14.159587] hub 3-0:1.0: 1 port detected
[   14.159774] scene_lock_init name=ohci_standby
[   16.404473] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.759472] systemd[1]: System time before build time, advancing clock.
[   16.796347] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.796659] systemd[1]: Detected architecture arm64.
[   16.824461] systemd[1]: Set hostname to <cluster0>.
[   17.107220] systemd[1]: Listening on udev Kernel Socket.
[   17.126995] systemd[1]: Listening on Syslog Socket.
[   17.146564] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.166392] systemd[1]: Listening on Journal Socket.
[   17.185868] systemd[1]: Reached target Remote File Systems (Pre).
[   17.205525] systemd[1]: Reached target Encrypted Volumes.
[   17.225355] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.245477] systemd[1]: Created slice User and Session Slice.
[   17.264724] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.284251] systemd[1]: Reached target Paths.
[   17.303929] systemd[1]: Reached target Remote File Systems.
[   17.323873] systemd[1]: Created slice System Slice.
[   17.345065] systemd[1]: Mounting Debug File System...
[   17.365027] systemd[1]: Starting Set console keymap...
[   17.393405] systemd[1]: Starting Load Kernel Modules...
[   17.414515] systemd[1]: Mounting Huge Pages File System...
[   17.432825] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.455578] systemd[1]: Reached target Slices.
[   17.471456] systemd[1]: Reached target Swap.
[   17.496219] systemd[1]: Starting Restore / save the current clock...
[   17.512968] systemd[1]: Starting Nameserver information manager...
[   17.530669] systemd[1]: Listening on udev Control Socket.
[   17.552325] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.558000] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.558365] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.558556] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.558740] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.563497] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.571885] systemd[1]: Mounting POSIX Message Queue File System...
[   17.589639] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.611595] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.614190] cfg80211: Calling CRDA to update world regulatory domain
[   17.629331] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.648807] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.652565] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.672624] systemd[1]: Mounted Debug File System.
[   17.688142] systemd[1]: Mounted POSIX Message Queue File System.
[   17.707700] systemd[1]: Mounted Huge Pages File System.
[   17.728784] systemd[1]: Started Set console keymap.
[   17.749306] systemd[1]: Started Restore / save the current clock.
[   17.753170] RTL871X: module init start
[   17.753180] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.753185] RTL871X: build time: Jan  9 2019 22:15:04
[   17.753189] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.753203] sunxi-wlan wlan.26: bus_index: 1
[   17.753373] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.770081] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.797363] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.817808] systemd[1]: Started Nameserver information manager.
[   17.833542] systemd[1]: Time has been changed
[   17.861741] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.861856] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   17.861986] RTL871X: module init ret=0
[   17.867046] systemd[1]: Started Load Kernel Modules.
[   17.874637] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.895119] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.895946] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.895973] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.898436] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.900305] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   17.901115] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.901922] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.902728] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.903541] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.904374] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.905229] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.906039] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.906850] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.906873] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.907756] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   17.907776] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   17.944514] systemd[1]: Starting Apply Kernel Variables...
[   17.965788] systemd[1]: Mounting Configuration File System...
[   17.985159] systemd[1]: Mounting FUSE Control File System...
[   18.002738] systemd[1]: Reached target Network (Pre).
[   18.028312] systemd[1]: Starting udev Coldplug all Devices...
[   18.044172] systemd[1]: Starting Load/Save Random Seed...
[   18.063906] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.084266] systemd[1]: Mounted FUSE Control File System.
[   18.101306] systemd[1]: Mounted Configuration File System.
[   18.122022] systemd[1]: Started Apply Kernel Variables.
[   18.143732] systemd[1]: Started Load/Save Random Seed.
[   18.161225] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.235857] systemd[1]: Reached target Local File Systems (Pre).
[   18.263323] systemd[1]: Mounting /tmp...
[   18.280255] systemd[1]: Starting udev Kernel Device Manager...
[   18.301494] systemd[1]: Mounted /tmp.
[   18.318553] systemd[1]: Started udev Coldplug all Devices.
[   18.350695] systemd[1]: Started udev Kernel Device Manager.
[   18.394807] systemd[1]: Reached target Sound Card.
[   18.416146] systemd[1]: Reached target Local File Systems.
[   18.438639] systemd[1]: Starting Armbian ZRAM config...
[   18.462514] systemd[1]: Starting Raise network interfaces...
[   18.470150] systemd[1]: Starting Set console font and keymap...
[   18.519231] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.536595] systemd[1]: Starting Journal Service...
[   18.648692] cfg80211: World regulatory domain updated:
[   18.648722] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.648729] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.648735] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.648741] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.648746] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.648751] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.648756] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.648762] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.648768] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.667987] sunxi cedar version 0.1
[   18.668287] [cedar]: install start!!!
[   18.668480] ycy the get irq is 90
[   18.669048] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.669060] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.669066] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.669071] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.669076] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.669080] [cedar]: install end!!!
[   18.740424] systemd[1]: Found device /dev/ttyS0.
[   18.784870] Registered IR keymap rc_map_sunxi
[   18.785387] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.786162] systemd[1]: Started Journal Service.
[   18.787275] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.843089] [VFE]cci probe end cci_sel = 0!
[   18.843349] [VFE]cci_init end
[   18.844310] IR JVC protocol handler initialized
[   18.845631] IR NEC protocol handler initialized
[   18.846324] IR RC5(x) protocol handler initialized
[   18.847351] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.847634] IR MCE Keyboard/mouse protocol handler initialized
[   18.849425] IR RC6 protocol handler initialized
[   18.849427] IR SANYO protocol handler initialized
[   18.850401] IR Sony protocol handler initialized
[   18.855914] lirc_dev: IR Remote Control driver registered, major 248
[   18.874657] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.874680] IR LIRC bridge handler initialized
[   18.951171] [VFE]Welcome to Video Front End driver
[   18.951739] [VFE]csi probe end csi_sel = 0!
[   18.952089] [VFE]csi_init end
[   18.952672] [VFE]isp probe start isp_sel = 0!
[   18.956836] [ISP] isp platform_id = 3!
[   18.956848] [VFE]isp probe end isp_sel = 0!
[   18.956943] [VFE]sunxi_isp_platform_register end
[   18.957621] [VFE]mipi probe start mipi_sel = 0!
[   18.957647] [VFE]mipi probe end mipi_sel = 0!
[   18.957698] [VFE]mipi_init end
[   18.957701] [VFE]flash_init end
[   18.958163] [VFE]vfe_init end
[   18.991742] sunxi-bt bt.27: block state already is 1
[   19.012321] Driver for 1-wire Dallas network protocol.
[   19.054135] systemd-journald[294]: Received request to flush runtime journal from PID 1
[   19.272897] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.292147] zram: Created 6 device(s) ...
[   19.403431] Adding 254468k swap on /dev/zram1.  Priority:5 extents:1 across:254468k SS
[   19.436525] Adding 254468k swap on /dev/zram2.  Priority:5 extents:1 across:254468k SS
[   19.459805] Adding 254468k swap on /dev/zram3.  Priority:5 extents:1 across:254468k SS
[   19.483396] Adding 254468k swap on /dev/zram4.  Priority:5 extents:1 across:254468k SS
[   19.690373] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.690395] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.69
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1891132 kB
Buffers:            7308 kB
Cached:            55392 kB
SwapCached:            0 kB
Active:            33932 kB
Inactive:          50288 kB
Active(anon):      21792 kB
Inactive(anon):     2864 kB
Active(file):      12140 kB
Inactive(file):    47424 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:               176 kB
Writeback:             0 kB
AnonPages:         21944 kB
Mapped:            15944 kB
Shmem:              3044 kB
Slab:              22232 kB
SReclaimable:       9120 kB
SUnreclaim:        13112 kB
KernelStack:        1888 kB
PageTables:          672 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:     130080 kB
VmallocChunk:   251633444 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62562
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254472 zram1
 253        2     254472 zram2
 253        3     254472 zram3
 253        4     254472 zram4
### df:
/dev/mmcblk0p1   15G  882M   14G   7% /
/dev/zram0       49M  1.9M   44M   5% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  1.5M 453.7K  1.3M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
23:20:33: 1152MHz  0.00  36%  12%  16%   0%   7%   0%   41°C   27°C  0/7
23:20:33: 1152MHz  0.00  44%   9%   3%   1%  29%   0%   41°C   27°C  0/7
23:20:33: 1152MHz  0.00  28%   3%   1%   1%  21%   0%   39°C   27°C  0/7
23:20:34: 1152MHz  0.00  29%   6%   3%   1%  18%   0%   38°C   27°C  0/7
23:20:34: 1152MHz  0.08  30%   4%  26%   0%   0%   0%   38°C   27°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Wed Jan  9 23:25:33 UTC 2019 | SoPine A64 | 5.69 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@nightly) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #76 SMP PREEMPT Wed Jan 9 22:15:14 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s18880 r8192 d22080 u49152
[    0.000000] pcpu-alloc: s18880 r8192 d22080 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1965428k/1965428k available, 115340k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000ab2000 - 0xffffffc000b329c0   (   515 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000ab1e84   ( 10440 kB)
                     .data : 0xffffffc000b33000 - 0xffffffc000c8d318   (  1385 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.021193] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.021201] pid_max: default: 32768 minimum: 301
[   10.021296] Security Framework initialized
[   10.021345] AppArmor: AppArmor initialized
[   10.021380] Mount-cache hash table entries: 256
[   10.031700] Initializing cgroup subsys memory
[   10.031746] Initializing cgroup subsys devices
[   10.031753] Initializing cgroup subsys freezer
[   10.031759] Initializing cgroup subsys blkio
[   10.031764] Initializing cgroup subsys perf_event
[   10.031775] Initializing cgroup subsys hugetlb
[   10.031837] ftrace: allocating 27493 entries in 108 pages
[   10.063873] CPU0: update cpu_power 1968128
[   10.063894] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.064890] virtual base = 0xffffff800000a000.
[   10.064903] gicd_base = 0xffffff800000c000.
[   10.064907] gicc_base = 0xffffff800000e000.
[   10.065544] CPU1: Booted secondary processor
[   10.065572] CPU1: update cpu_power 1968128
[   10.068169] CPU2: Booted secondary processor
[   10.068183] CPU2: update cpu_power 1968128
[   10.072287] CPU3: Booted secondary processor
[   10.072298] CPU3: update cpu_power 1968128
[   10.072372] Brought up 4 CPUs
[   10.072394] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.072904] devtmpfs: initialized
[   10.077629] pinctrl core: initialized pinctrl subsystem
[   10.080086] NET: Registered protocol family 16
[   10.080339] script_sysfs_init success
[   10.080577] dump_class_init,806, success
[   10.080816] vdso: 2 pages (1 code, 1 data) at base ffffffc000b39000
[   10.080837] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.082094] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.083152] DMA: preallocated 256 KiB pool for atomic allocations
[   10.083267] Serial: AMBA PL011 UART driver
[   10.083371] axp81x_board_init: axp regl_devs num = 23
[   10.083511] pll_audio-set_default_rate=24576000 success!
[   10.083529] pll_video0-set_default_rate=297000000 success!
[   10.083601] pll_video1-set_default_rate=297000000 success!
[   10.083662] pll_de-set_default_rate=297000000 success!
[   10.084369] de-set_default_source=pll_de success!
[   10.084374] de-set_default_rate=297000000 success!
[   10.084416] tcon0-set_default_source=pll_mipi success!
[   10.084447] tcon1-set_default_source=pll_video0 success!
[   10.084661] hdmi-set_default_source=pll_video0 success!
[   10.086855] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.087009] [sun50iw1p1_pinctrl_probe][838]
[   10.088437] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.089055] sunxi hwspinlock vbase:0xffffff800005c000
[   10.099147] bio: create slab <bio-0> at 0
[   10.099493] pwm module init!
[   10.100705] SCSI subsystem initialized
[   10.100828] usbcore: registered new interface driver usbfs
[   10.100862] usbcore: registered new interface driver hub
[   10.100927] usbcore: registered new device driver usb
[   10.101621] Linux video capture interface: v2.00
[   10.102063] [ARISC] :sunxi-arisc driver v1.10
[   10.108963] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.109214] Advanced Linux Sound Architecture Driver Initialized.
[   10.109559] NetLabel: Initializing
[   10.109565] NetLabel:  domain hash size = 128
[   10.109569] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.109606] NetLabel:  unlabeled traffic allowed by default
[   10.109766] [pm]aw_pm_init!
[   10.109833] rtc physical base = 0x0000000001f00000 .
[   10.109867] np name = /soc@01c00000/rtc@01f00000.
[   10.109873] base = ffffff800006e100, len = 4.
[   10.109879] pmu name: pmu0 .
[   10.109913] pmu0_enable = 0x1.
[   10.109919] pmux_id = 0x6.
[   10.109925] pmux_twi_id = 0x1.
[   10.109930] pmux_twi_addr = 0x34.
[   10.109934] pmu name: pmu1 .
[   10.109985] Warning: can not find np for pmu1.
[   10.110213] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.110373] after inited: sys_mask config = 0x4a55.
[   10.110394] Warning: can not find np for dynamic_standby_para.
[   10.110517] [pm]valid
[   10.110521] [pm]valid
[   10.110525] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.110728] Switching to clocksource arch_sys_counter_ool
[   10.121326] AppArmor: AppArmor Filesystem Enabled
[   10.127814] NET: Registered protocol family 2
[   10.128506] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.128748] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.129057] TCP: Hash tables configured (established 16384 bind 16384)
[   10.129141] TCP: reno registered
[   10.129152] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.129204] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.129455] NET: Registered protocol family 1
[   10.129773] RPC: Registered named UNIX socket transport module.
[   10.129779] RPC: Registered udp transport module.
[   10.129783] RPC: Registered tcp transport module.
[   10.129788] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.129960] Trying to unpack rootfs image as initramfs...
[   10.334450] Freeing initrd memory: 4292K (ffffffc075a85000 - ffffffc075eb6000)
[   10.335040] kvm [1]: Using HYP init bounce page @b787a000
[   10.335573] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.335998] kvm [1]: timer IRQ27
[   10.336014] kvm [1]: Hyp mode initialized successfully
[   10.337771] lock super standby defaultly!
[   10.337786] lookup_scene_lock_name: new scene lock super_standby
[   10.337792] scene_lock_init name=super_standby
[   10.337798] scene_lock: super_standby, type 5, count 1
[   10.338209] audit: initializing netlink socket (disabled)
[   10.338268] type=2000 audit(0.310:1): initialized
[   10.338935] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.339393] VFS: Disk quotas dquot_6.5.2
[   10.339495] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.340422] NFS: Registering the id_resolver key type
[   10.340471] Key type id_resolver registered
[   10.340476] Key type id_legacy registered
[   10.340488] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.340632] NTFS driver 2.1.30 [Flags: R/W].
[   10.340797] fuse init (API version 7.22)
[   10.340973] msgmni has been set to 3975
[   10.341927] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.342014] io scheduler noop registered
[   10.342020] io scheduler deadline registered
[   10.342049] io scheduler cfq registered (default)
[   10.342619] [DISP]disp_module_init
[   10.343060] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.343067] [DISP] boot_disp:0x0
[   10.343667] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.343801] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.343931] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.345050] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.345056] [DISP] fb_base:0x0
[   10.362778] Console: switching to colour frame buffer device 160x45
[   10.377368] [DISP]disp_module_init finish
[   10.377789] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.377812] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.378166] console [ttyS0] enabled
[   10.378549] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.378783] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.379086] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.379369] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.379716] misc dump reg init
[   10.379875] [drm] Initialized drm 1.1.0 20060810
[   10.382051] brd: module loaded
[   10.384207] loop: module loaded
[   10.384476] sunxi-bt bt.27: Missing bt_power.
[   10.384483] sunxi-bt bt.27: bt_power_name ((null))
[   10.384491] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.384525] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.384568] sunxi-bt bt.27: clk not config
[   10.384639] sunxi-bt bt.27: block state already is 1
[   10.384822] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.384829] sunxi-wlan wlan.26: Missing wlan_power.
[   10.384835] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.384842] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.384860] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.384879] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.384897] sunxi-wlan wlan.26: clk not config
[   10.385594] WARNING: Get ephy clock is failed
[   10.386207] chipid-sunxi serial 140050374620201507cf
[   10.386364] PPP generic driver version 2.4.2
[   10.386506] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.386619] get ehci0-controller drv_vbus_gpio is fail
[   10.386625] get ehci0-controller, regulator_io is no nocare
[   10.386665] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   10.386718] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.386737] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.387116] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000584c7c
[   10.405981] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.406063] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.406070] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.406077] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.406083] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.406089] usb usb1: SerialNumber: sunxi-ehci
[   10.406429] hub 1-0:1.0: USB hub found
[   10.406445] hub 1-0:1.0: 1 port detected
[   10.406578] scene_lock_init name=ehci_standby
[   10.406649] get ehci1-controller drv_vbus_gpio is fail
[   10.406654] get ehci1-controller, regulator_io is no nocare
[   10.406692] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000d16dd0, 0x:ffffff80000b2000, irq_no:6a
[   10.406739] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.406759] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.407016] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000584c7c
[   10.425813] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.425860] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.425868] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.425874] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.425881] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.425887] usb usb2: SerialNumber: sunxi-ehci
[   10.426193] hub 2-0:1.0: USB hub found
[   10.426206] hub 2-0:1.0: 1 port detected
[   10.426329] scene_lock_init name=ehci_standby
[   10.426524] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.426680] get ohci0-controller drv_vbus_gpio is fail
[   10.426685] get ohci0-controller, regulator_io is no nocare
[   10.426726] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   10.426774] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.426790] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.426822] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.488670] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.488678] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.488685] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.488691] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.488697] usb usb3: SerialNumber: sunxi-ohci
[   10.488972] hub 3-0:1.0: USB hub found
[   10.488986] hub 3-0:1.0: 1 port detected
[   10.489103] scene_lock_init name=ohci_standby
[   10.489164] get ohci1-controller drv_vbus_gpio is fail
[   10.489169] get ohci1-controller, regulator_io is no nocare
[   10.489201] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000d16930
[   10.489239] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.489257] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.489283] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.547737] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.547746] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.547753] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.547759] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.547765] usb usb4: SerialNumber: sunxi-ohci
[   10.548037] hub 4-0:1.0: USB hub found
[   10.548050] hub 4-0:1.0: 1 port detected
[   10.548164] scene_lock_init name=ohci_standby
[   10.548463] usbcore: registered new interface driver usb-storage
[   10.548493] usbcore: registered new interface driver ums-alauda
[   10.548520] usbcore: registered new interface driver ums-cypress
[   10.548546] usbcore: registered new interface driver ums-datafab
[   10.548568] usbcore: registered new interface driver ums_eneub6250
[   10.548591] usbcore: registered new interface driver ums-freecom
[   10.548615] usbcore: registered new interface driver ums-isd200
[   10.548638] usbcore: registered new interface driver ums-jumpshot
[   10.548661] usbcore: registered new interface driver ums-karma
[   10.548685] usbcore: registered new interface driver ums-onetouch
[   10.548720] usbcore: registered new interface driver ums-realtek
[   10.548744] usbcore: registered new interface driver ums-sddr09
[   10.548772] usbcore: registered new interface driver ums-sddr55
[   10.548796] usbcore: registered new interface driver ums-usbat
[   10.548880] usbcore: registered new interface driver usbserial
[   10.548907] usbcore: registered new interface driver usbserial_generic
[   10.548928] usbserial: USB Serial support registered for generic
[   10.549139] mousedev: PS/2 mouse device common for all mice
[   10.549586] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.550423] get ctp_para failed, -1
[   10.550445] get node gsensor failed
[   10.550448] get sysconfig para erro!
[   10.550458] get node lightsensor failed
[   10.550461] get sysconfig para erro!
[   10.550470] get node gyroscopesensor failed
[   10.550473] get sysconfig para erro!
[   10.550482] get node compasssensor failed
[   10.550485] get sysconfig para erro!
[   10.550788] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.550808] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.550969] i2c /dev entries driver
[   10.593432] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.596899] sunxi budget cooling probe start !
[   10.596926] CPU freq cooling register Success
[   10.596944] CPU hotplug cooling register Success
[   10.597025] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.597033] CPU budget cooling register Success
[   10.597245] sunxi gpu cooling probe start !
[   10.597254] CPU gpu cooling register Success
[   10.597899] cpuidle: using governor ladder
[   10.597906] cpuidle: using governor menu
[   10.598655] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.598683] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.598692] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.598701] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.598764] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.598771] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.599354] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.599378] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.550510] wakeup gpio set err!get node ctp failed
[   10.602818] get sysconfig para erro!
[   10.612619] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.632309] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.632696] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.632721] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.632728] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.632735] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.632739] get() with no identifier
[   10.632742] get() with no identifier
[   10.632746] get() with no identifier
[   10.632752] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.632758] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.632764] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.633132] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.633170] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.633190] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.633955] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.633974] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.636357] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.638501] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.639315] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.640127] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.640938] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.641563] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.641605] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.643980] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.651979] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.671665] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.672333] ledtrig-cpu: registered to indicate activity on CPUs
[   10.672403] hidraw: raw HID events driver (C) Jiri Kosina
[   10.672529] usbcore: registered new interface driver usbhid
[   10.672533] usbhid: USB HID core driver
[   10.673428] usbcore: registered new interface driver snd-usb-audio
[   10.675471] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.676271] TCP: cubic registered
[   10.676280] Initializing XFRM netlink socket
[   10.676363] NET: Registered protocol family 10
[   10.677163] mip6: Mobile IPv6
[   10.677171] sit: IPv6 over IPv4 tunneling driver
[   10.677540] NET: Registered protocol family 17
[   10.677563] NET: Registered protocol family 15
[   10.677608] 8021q: 802.1Q VLAN Support v1.8
[   10.677653] Key type dns_resolver registered
[   10.677867] Registering SWP/SWPB emulation handler
[   10.678157] registered taskstats version 1
[   10.690122] Key type encrypted registered
[   10.690144] AppArmor: AppArmor sha1 policy hashing enabled
[   10.690597] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.690606] [DISP] boot_disp:0x0
[   10.690650] HDMI base address: ffffff8000b40000
[   10.691420] [HDMI] power vcc-hdmi-33
[   10.691952] [HDMI] cec support = 0
[   10.710977] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.713473] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.713548] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.713654] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.713679] mmc0: new high speed SDHC card at address aaaa
[   10.714101] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.716117]  mmcblk0: p1
[   10.717232] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.718041] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.718060] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.720452] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.722270] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.723078] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.723885] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.724692] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.725496] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.726303] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727110] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727917] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.728724] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.728741] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.729576] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.729593] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.802397] input: sunxi-ths as /devices/virtual/input/input2
[   10.802570] thermal thermal_zone0: failed to read out thermal zone 0
[   10.802981] ALSA device list:
[   10.802987]   #0: sndhdmi
[   10.803396] Freeing unused kernel memory: 512K (ffffffc000ab2000 - ffffffc000b32000)
[   11.399873] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.076305] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.076321] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80
[   14.076343] scene_lock_destroy name=ehci_standby
[   14.076357] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.076379] usb usb1: USB disconnect, device number 1
[   14.076933] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.076966] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.076974] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.076979] scene_lock_destroy name=ohci_standby
[   14.076987] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.077002] usb usb3: USB disconnect, device number 1
[   14.077362] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.077392] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.077399] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   14.077442] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.077465] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.078317] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b86d0
[   14.095997] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.096097] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.096106] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.096113] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.096119] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.096125] usb usb1: SerialNumber: sunxi-ehci
[   14.096612] hub 1-0:1.0: USB hub found
[   14.096631] hub 1-0:1.0: 1 port detected
[   14.096782] scene_lock_init name=ehci_standby
[   14.096789] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.096797] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.096847] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.096865] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.096905] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b86d0
[   14.159051] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.159065] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.159072] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.159078] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.159085] usb usb3: SerialNumber: sunxi-ohci
[   14.159533] hub 3-0:1.0: USB hub found
[   14.159556] hub 3-0:1.0: 1 port detected
[   14.159730] scene_lock_init name=ohci_standby
[   16.422059] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.778442] systemd[1]: System time before build time, advancing clock.
[   16.815348] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.815653] systemd[1]: Detected architecture arm64.
[   16.844149] systemd[1]: Set hostname to <cluster0>.
[   17.122414] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.146522] systemd[1]: Reached target Encrypted Volumes.
[   17.166538] systemd[1]: Created slice System Slice.
[   17.185968] systemd[1]: Listening on udev Kernel Socket.
[   17.205751] systemd[1]: Created slice User and Session Slice.
[   17.225173] systemd[1]: Reached target Swap.
[   17.245037] systemd[1]: Listening on Journal Socket.
[   17.266355] systemd[1]: Mounting Debug File System...
[   17.286272] systemd[1]: Starting Nameserver information manager...
[   17.306206] systemd[1]: Mounting Huge Pages File System...
[   17.324129] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.344020] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.368758] systemd[1]: Mounting POSIX Message Queue File System...
[   17.382760] systemd[1]: Reached target Slices.
[   17.407171] systemd[1]: Starting Restore / save the current clock...
[   17.426011] systemd[1]: Starting Set console keymap...
[   17.442017] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.463750] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.481455] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.502571] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.518899] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.520854] systemd[1]: Listening on udev Control Socket.
[   17.540582] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.560080] systemd[1]: Listening on Syslog Socket.
[   17.579579] systemd[1]: Reached target Remote File Systems (Pre).
[   17.599105] systemd[1]: Reached target Remote File Systems.
[   17.618979] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.638446] systemd[1]: Reached target Paths.
[   17.663855] systemd[1]: Starting Load Kernel Modules...
[   17.682475] systemd[1]: Mounted Debug File System.
[   17.697904] systemd[1]: Mounted POSIX Message Queue File System.
[   17.717301] systemd[1]: Mounted Huge Pages File System.
[   17.741669] systemd[1]: Started Restore / save the current clock.
[   17.758547] systemd[1]: Started Set console keymap.
[   17.777208] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.797056] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.818180] systemd[1]: Started Nameserver information manager.
[   17.843007] systemd[1]: Time has been changed
[   17.903076] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.903381] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.903531] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.903665] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.904912] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.930376] systemd[1]: Reached target Network (Pre).
[   17.956224] systemd[1]: Starting Load/Save Random Seed...
[   17.979519] cfg80211: Calling CRDA to update world regulatory domain
[   17.982989] systemd[1]: Starting udev Coldplug all Devices...
[   18.004933] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.121687] RTL871X: module init start
[   18.121705] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.121710] RTL871X: build time: Jan  9 2019 22:15:04
[   18.121715] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.121730] sunxi-wlan wlan.26: bus_index: 1
[   18.121910] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.130826] systemd[1]: Started Load/Save Random Seed.
[   18.188773] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.232414] systemd[1]: Reached target Local File Systems (Pre).
[   18.241179] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.241270] RTL871X: module init ret=0
[   18.241302] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.253565] systemd[1]: Mounting /tmp...
[   18.258399] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.270518] systemd[1]: Starting udev Kernel Device Manager...
[   18.278906] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.279746] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.279781] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.282252] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.284127] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.284940] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.285747] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.286557] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.287461] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.288292] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.289119] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.289939] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.290524] systemd[1]: Mounted /tmp.
[   18.290760] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.290786] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.291677] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.291699] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.308681] systemd[1]: Started Load Kernel Modules.
[   18.347815] systemd[1]: Mounting Configuration File System...
[   18.369401] systemd[1]: Starting Apply Kernel Variables...
[   18.389021] systemd[1]: Mounting FUSE Control File System...
[   18.430775] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.448195] systemd[1]: Starting Journal Service...
[   18.465701] systemd[1]: Reached target Local File Systems.
[   18.487493] systemd[1]: Starting Set console font and keymap...
[   18.495349] systemd[1]: Starting Armbian ZRAM config...
[   18.520048] systemd[1]: Mounted FUSE Control File System.
[   18.544061] systemd[1]: Mounted Configuration File System.
[   18.564327] systemd[1]: Started udev Kernel Device Manager.
[   18.585483] systemd[1]: Started udev Coldplug all Devices.
[   18.615363] systemd[1]: Started Apply Kernel Variables.
[   18.630115] sunxi cedar version 0.1
[   18.630413] [cedar]: install start!!!
[   18.630621] ycy the get irq is 90
[   18.631223] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.631234] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.631239] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.631245] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.631250] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.631254] [cedar]: install end!!!
[   18.693232] cfg80211: World regulatory domain updated:
[   18.693251] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.693258] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.693263] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.693268] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.693274] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.693279] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.693284] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.693290] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.693295] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.737596] systemd[1]: Found device /dev/ttyS0.
[   18.749865] Registered IR keymap rc_map_sunxi
[   18.750428] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.750915] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.752716] systemd[1]: Reached target Sound Card.
[   18.800710] Driver for 1-wire Dallas network protocol.
[   18.817933] IR NEC protocol handler initialized
[   18.818514] IR RC5(x) protocol handler initialized
[   18.833206] systemd[1]: Starting Raise network interfaces...
[   18.833244] [VFE]cci probe end cci_sel = 0!
[   18.833510] [VFE]cci_init end
[   18.866052] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.866442] IR MCE Keyboard/mouse protocol handler initialized
[   18.878629] IR JVC protocol handler initialized
[   18.910273] IR SANYO protocol handler initialized
[   18.910275] IR RC6 protocol handler initialized
[   18.911536] IR Sony protocol handler initialized
[   18.911785] lirc_dev: IR Remote Control driver registered, major 248
[   18.915092] [VFE]Welcome to Video Front End driver
[   18.915465] [VFE]csi probe end csi_sel = 0!
[   18.915851] [VFE]csi_init end
[   18.918087] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.918108] IR LIRC bridge handler initialized
[   18.918144] [VFE]isp probe start isp_sel = 0!
[   18.926600] [ISP] isp platform_id = 3!
[   18.926630] [VFE]isp probe end isp_sel = 0!
[   18.926741] [VFE]sunxi_isp_platform_register end
[   18.927341] [VFE]mipi probe start mipi_sel = 0!
[   18.927372] [VFE]mipi probe end mipi_sel = 0!
[   18.927552] [VFE]mipi_init end
[   18.927564] [VFE]flash_init end
[   18.928046] [VFE]vfe_init end
[   18.971596] systemd[1]: Started Journal Service.
[   18.975914] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   18.982166] zram: Created 6 device(s) ...
[   19.139347] sunxi-bt bt.27: block state already is 1
[   19.156133] Adding 254468k swap on /dev/zram1.  Priority:5 extents:1 across:254468k SS
[   19.187364] systemd-journald[290]: Received request to flush runtime journal from PID 1
[   19.209740] Adding 254468k swap on /dev/zram2.  Priority:5 extents:1 across:254468k SS
[   19.248248] Adding 254468k swap on /dev/zram3.  Priority:5 extents:1 across:254468k SS
[   19.297010] Adding 254468k swap on /dev/zram4.  Priority:5 extents:1 across:254468k SS
[   19.575750] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.575769] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.69
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035768 kB
MemFree:         1891124 kB
Buffers:            7452 kB
Cached:            57124 kB
SwapCached:            0 kB
Active:            31972 kB
Inactive:          50968 kB
Active(anon):      18688 kB
Inactive(anon):     2876 kB
Active(file):      13284 kB
Inactive(file):    48092 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017872 kB
SwapFree:        1017872 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         18388 kB
Mapped:            16892 kB
Shmem:              3048 kB
Slab:              22812 kB
SReclaimable:       9208 kB
SUnreclaim:        13604 kB
KernelStack:        1984 kB
PageTables:          512 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035756 kB
Committed_AS:     112076 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633452 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5607
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254472 zram1
 253        2     254472 zram2
 253        3     254472 zram3
 253        4     254472 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
tmpfs           995M     0  995M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           995M     0  995M   0% /sys/fs/cgroup
tmpfs           995M  4.0K  995M   1% /tmp
/dev/zram0       49M  2.1M   43M   5% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M  1.7M 534.7K  1.3M         /var/log
/dev/zram1             248.5M    4K    78B    4K         [SWAP]
/dev/zram2             248.5M    4K    78B    4K         [SWAP]
/dev/zram3             248.5M    4K    78B    4K         [SWAP]
/dev/zram4             248.5M    4K    78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
23:25:37: 1152MHz  0.00  37%  12%  16%   0%   8%   0%   36°C   22°C  0/7
23:25:37: 1152MHz  0.00  40%   5%   5%   1%  28%   0%   35°C   22°C  0/7
23:25:37: 1152MHz  0.00  28%   4%   1%   0%  21%   0%   33°C   22°C  0/7
23:25:38: 1152MHz  0.00  27%   2%   1%   1%  22%   0%   32°C   22°C  0/7
23:25:38: 1152MHz  0.00  31%   5%  15%   1%   8%   0%   33°C   22°C  0/7
Thu Jan 10 01:47:35 UTC 2019 | SoPine A64 | 5.69 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.025615] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.025625] pid_max: default: 32768 minimum: 301
[   10.025718] Security Framework initialized
[   10.025767] AppArmor: AppArmor initialized
[   10.025802] Mount-cache hash table entries: 256
[   10.036120] Initializing cgroup subsys memory
[   10.036169] Initializing cgroup subsys devices
[   10.036176] Initializing cgroup subsys freezer
[   10.036182] Initializing cgroup subsys blkio
[   10.036187] Initializing cgroup subsys perf_event
[   10.036197] Initializing cgroup subsys hugetlb
[   10.036257] ftrace: allocating 27493 entries in 108 pages
[   10.068317] CPU0: update cpu_power 1968128
[   10.068339] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.069326] virtual base = 0xffffff800000a000.
[   10.069338] gicd_base = 0xffffff800000c000.
[   10.069343] gicc_base = 0xffffff800000e000.
[   10.069974] CPU1: Booted secondary processor
[   10.070001] CPU1: update cpu_power 1968128
[   10.072597] CPU2: Booted secondary processor
[   10.072610] CPU2: update cpu_power 1968128
[   10.076716] CPU3: Booted secondary processor
[   10.076727] CPU3: update cpu_power 1968128
[   10.076800] Brought up 4 CPUs
[   10.076822] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.077327] devtmpfs: initialized
[   10.082068] pinctrl core: initialized pinctrl subsystem
[   10.084504] NET: Registered protocol family 16
[   10.084758] script_sysfs_init success
[   10.084998] dump_class_init,806, success
[   10.085238] vdso: 2 pages (1 code, 1 data) at base ffffffc000b39000
[   10.085258] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.086517] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.087570] DMA: preallocated 256 KiB pool for atomic allocations
[   10.087686] Serial: AMBA PL011 UART driver
[   10.087789] axp81x_board_init: axp regl_devs num = 23
[   10.087931] pll_audio-set_default_rate=24576000 success!
[   10.087949] pll_video0-set_default_rate=297000000 success!
[   10.088022] pll_video1-set_default_rate=297000000 success!
[   10.088082] pll_de-set_default_rate=297000000 success!
[   10.088786] de-set_default_source=pll_de success!
[   10.088792] de-set_default_rate=297000000 success!
[   10.088834] tcon0-set_default_source=pll_mipi success!
[   10.088865] tcon1-set_default_source=pll_video0 success!
[   10.089079] hdmi-set_default_source=pll_video0 success!
[   10.091293] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.091451] [sun50iw1p1_pinctrl_probe][838]
[   10.092883] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.093499] sunxi hwspinlock vbase:0xffffff800005c000
[   10.103577] bio: create slab <bio-0> at 0
[   10.103921] pwm module init!
[   10.105137] SCSI subsystem initialized
[   10.105258] usbcore: registered new interface driver usbfs
[   10.105291] usbcore: registered new interface driver hub
[   10.105357] usbcore: registered new device driver usb
[   10.106043] Linux video capture interface: v2.00
[   10.106484] [ARISC] :sunxi-arisc driver v1.10
[   10.113407] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.113654] Advanced Linux Sound Architecture Driver Initialized.
[   10.114002] NetLabel: Initializing
[   10.114007] NetLabel:  domain hash size = 128
[   10.114011] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.114049] NetLabel:  unlabeled traffic allowed by default
[   10.114207] [pm]aw_pm_init!
[   10.114277] rtc physical base = 0x0000000001f00000 .
[   10.114310] np name = /soc@01c00000/rtc@01f00000.
[   10.114316] base = ffffff800006e100, len = 4.
[   10.114321] pmu name: pmu0 .
[   10.114356] pmu0_enable = 0x1.
[   10.114361] pmux_id = 0x6.
[   10.114368] pmux_twi_id = 0x1.
[   10.114373] pmux_twi_addr = 0x34.
[   10.114377] pmu name: pmu1 .
[   10.114429] Warning: can not find np for pmu1.
[   10.114656] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.114817] after inited: sys_mask config = 0x4a55.
[   10.114839] Warning: can not find np for dynamic_standby_para.
[   10.114967] [pm]valid
[   10.114971] [pm]valid
[   10.114975] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.115178] Switching to clocksource arch_sys_counter_ool
[   10.125793] AppArmor: AppArmor Filesystem Enabled
[   10.132276] NET: Registered protocol family 2
[   10.132970] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.133211] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.133519] TCP: Hash tables configured (established 16384 bind 16384)
[   10.133601] TCP: reno registered
[   10.133612] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.133664] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.133914] NET: Registered protocol family 1
[   10.134235] RPC: Registered named UNIX socket transport module.
[   10.134241] RPC: Registered udp transport module.
[   10.134245] RPC: Registered tcp transport module.
[   10.134250] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.134423] Trying to unpack rootfs image as initramfs...
[   10.338997] Freeing initrd memory: 4292K (ffffffc075a85000 - ffffffc075eb6000)
[   10.339592] kvm [1]: Using HYP init bounce page @b787a000
[   10.340108] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.340533] kvm [1]: timer IRQ27
[   10.340547] kvm [1]: Hyp mode initialized successfully
[   10.342310] lock super standby defaultly!
[   10.342326] lookup_scene_lock_name: new scene lock super_standby
[   10.342332] scene_lock_init name=super_standby
[   10.342338] scene_lock: super_standby, type 5, count 1
[   10.342749] audit: initializing netlink socket (disabled)
[   10.342807] type=2000 audit(0.310:1): initialized
[   10.343477] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.343934] VFS: Disk quotas dquot_6.5.2
[   10.344035] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.344961] NFS: Registering the id_resolver key type
[   10.345020] Key type id_resolver registered
[   10.345024] Key type id_legacy registered
[   10.345036] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.345179] NTFS driver 2.1.30 [Flags: R/W].
[   10.345340] fuse init (API version 7.22)
[   10.345515] msgmni has been set to 3975
[   10.346469] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.346553] io scheduler noop registered
[   10.346559] io scheduler deadline registered
[   10.346588] io scheduler cfq registered (default)
[   10.347157] [DISP]disp_module_init
[   10.347595] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.347602] [DISP] boot_disp:0x0
[   10.348192] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.348326] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.348458] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.349571] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.349576] [DISP] fb_base:0x0
[   10.367291] Console: switching to colour frame buffer device 160x45
[   10.381855] [DISP]disp_module_init finish
[   10.382272] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.382296] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.382651] console [ttyS0] enabled
[   10.383031] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.383261] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.383568] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.383853] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.384186] misc dump reg init
[   10.384327] [drm] Initialized drm 1.1.0 20060810
[   10.386467] brd: module loaded
[   10.388575] loop: module loaded
[   10.388836] sunxi-bt bt.27: Missing bt_power.
[   10.388843] sunxi-bt bt.27: bt_power_name ((null))
[   10.388851] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.388883] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.388928] sunxi-bt bt.27: clk not config
[   10.389001] sunxi-bt bt.27: block state already is 1
[   10.389183] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.389191] sunxi-wlan wlan.26: Missing wlan_power.
[   10.389197] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.389204] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.389220] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.389239] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.389255] sunxi-wlan wlan.26: clk not config
[   10.389959] WARNING: Get ephy clock is failed
[   10.390561] chipid-sunxi serial 140050374620201507cf
[   10.390654] PPP generic driver version 2.4.2
[   10.390878] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.390989] get ehci0-controller drv_vbus_gpio is fail
[   10.390995] get ehci0-controller, regulator_io is no nocare
[   10.391036] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   10.391089] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.391107] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.391453] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000584c7c
[   10.410431] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.410515] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.410523] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.410529] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.410536] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.410542] usb usb1: SerialNumber: sunxi-ehci
[   10.410867] hub 1-0:1.0: USB hub found
[   10.410884] hub 1-0:1.0: 1 port detected
[   10.411015] scene_lock_init name=ehci_standby
[   10.411086] get ehci1-controller drv_vbus_gpio is fail
[   10.411091] get ehci1-controller, regulator_io is no nocare
[   10.411128] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000d16dd0, 0x:ffffff80000b2000, irq_no:6a
[   10.411174] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.411194] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.411460] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000584c7c
[   10.430279] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.430327] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.430335] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.430341] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.430348] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.430354] usb usb2: SerialNumber: sunxi-ehci
[   10.430650] hub 2-0:1.0: USB hub found
[   10.430663] hub 2-0:1.0: 1 port detected
[   10.430788] scene_lock_init name=ehci_standby
[   10.430980] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.431134] get ohci0-controller drv_vbus_gpio is fail
[   10.431140] get ohci0-controller, regulator_io is no nocare
[   10.431182] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   10.431233] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.431248] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.431279] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.493120] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.493128] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.493135] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.493141] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.493147] usb usb3: SerialNumber: sunxi-ohci
[   10.493417] hub 3-0:1.0: USB hub found
[   10.493431] hub 3-0:1.0: 1 port detected
[   10.493546] scene_lock_init name=ohci_standby
[   10.493607] get ohci1-controller drv_vbus_gpio is fail
[   10.493612] get ohci1-controller, regulator_io is no nocare
[   10.493645] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000d16930
[   10.493684] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.493702] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.493728] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.552198] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.552207] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.552214] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.552220] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.552226] usb usb4: SerialNumber: sunxi-ohci
[   10.552500] hub 4-0:1.0: USB hub found
[   10.552513] hub 4-0:1.0: 1 port detected
[   10.552628] scene_lock_init name=ohci_standby
[   10.552930] usbcore: registered new interface driver usb-storage
[   10.552961] usbcore: registered new interface driver ums-alauda
[   10.552988] usbcore: registered new interface driver ums-cypress
[   10.553014] usbcore: registered new interface driver ums-datafab
[   10.553036] usbcore: registered new interface driver ums_eneub6250
[   10.553060] usbcore: registered new interface driver ums-freecom
[   10.553084] usbcore: registered new interface driver ums-isd200
[   10.553108] usbcore: registered new interface driver ums-jumpshot
[   10.553131] usbcore: registered new interface driver ums-karma
[   10.553154] usbcore: registered new interface driver ums-onetouch
[   10.553189] usbcore: registered new interface driver ums-realtek
[   10.553214] usbcore: registered new interface driver ums-sddr09
[   10.553237] usbcore: registered new interface driver ums-sddr55
[   10.553265] usbcore: registered new interface driver ums-usbat
[   10.553347] usbcore: registered new interface driver usbserial
[   10.553372] usbcore: registered new interface driver usbserial_generic
[   10.553396] usbserial: USB Serial support registered for generic
[   10.553588] mousedev: PS/2 mouse device common for all mice
[   10.554039] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.554888] get ctp_para failed, -1
[   10.554909] get node gsensor failed
[   10.554913] get sysconfig para erro!
[   10.554923] get node lightsensor failed
[   10.554926] get sysconfig para erro!
[   10.554935] get node gyroscopesensor failed
[   10.554938] get sysconfig para erro!
[   10.554947] get node compasssensor failed
[   10.554950] get sysconfig para erro!
[   10.555238] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.555258] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.555423] i2c /dev entries driver
[   10.597965] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.601414] sunxi budget cooling probe start !
[   10.601441] CPU freq cooling register Success
[   10.601459] CPU hotplug cooling register Success
[   10.601547] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.601554] CPU budget cooling register Success
[   10.601766] sunxi gpu cooling probe start !
[   10.601776] CPU gpu cooling register Success
[   10.602425] cpuidle: using governor ladder
[   10.602431] cpuidle: using governor menu
[   10.603168] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.603195] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.603203] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.603212] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.603261] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.603268] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.603855] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.603879] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.554976] wakeup gpio set err!get node ctp failed
[   10.607287] get sysconfig para erro!
[   10.617070] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.636759] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.637136] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.637160] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.637168] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.637175] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.637179] get() with no identifier
[   10.637182] get() with no identifier
[   10.637186] get() with no identifier
[   10.637192] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.637198] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.637203] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.637580] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.637601] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.637619] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.638401] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.638420] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.640803] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.642931] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.643745] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.644556] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.645368] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.645993] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.646035] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.648409] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.656428] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.676116] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.676791] ledtrig-cpu: registered to indicate activity on CPUs
[   10.676856] hidraw: raw HID events driver (C) Jiri Kosina
[   10.677006] usbcore: registered new interface driver usbhid
[   10.677010] usbhid: USB HID core driver
[   10.677867] usbcore: registered new interface driver snd-usb-audio
[   10.679908] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.680709] TCP: cubic registered
[   10.680718] Initializing XFRM netlink socket
[   10.680802] NET: Registered protocol family 10
[   10.681599] mip6: Mobile IPv6
[   10.681607] sit: IPv6 over IPv4 tunneling driver
[   10.681976] NET: Registered protocol family 17
[   10.682003] NET: Registered protocol family 15
[   10.682051] 8021q: 802.1Q VLAN Support v1.8
[   10.682097] Key type dns_resolver registered
[   10.682301] Registering SWP/SWPB emulation handler
[   10.682584] registered taskstats version 1
[   10.694627] Key type encrypted registered
[   10.694648] AppArmor: AppArmor sha1 policy hashing enabled
[   10.695093] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.695102] [DISP] boot_disp:0x0
[   10.695147] HDMI base address: ffffff8000b40000
[   10.695946] [HDMI] power vcc-hdmi-33
[   10.696474] [HDMI] cec support = 0
[   10.715424] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.717921] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.717996] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.718097] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.718122] mmc0: new high speed SDHC card at address aaaa
[   10.718551] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.720574]  mmcblk0: p1
[   10.721689] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.722498] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.722517] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.724908] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.726726] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.727534] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.728341] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.729148] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.729952] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.730760] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.731567] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.732373] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.733180] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.733197] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.734030] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.734047] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.806920] input: sunxi-ths as /devices/virtual/input/input2
[   10.807078] thermal thermal_zone0: failed to read out thermal zone 0
[   10.807493] ALSA device list:
[   10.807500]   #0: sndhdmi
[   10.807916] Freeing unused kernel memory: 512K (ffffffc000ab2000 - ffffffc000b32000)
[   11.404287] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.080753] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.080767] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80
[   14.080788] scene_lock_destroy name=ehci_standby
[   14.080802] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.080824] usb usb1: USB disconnect, device number 1
[   14.081379] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.081412] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.081419] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.081424] scene_lock_destroy name=ohci_standby
[   14.081432] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.081448] usb usb3: USB disconnect, device number 1
[   14.081809] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.081842] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.081850] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   14.081892] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.081916] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.085343] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b86d0
[   14.100454] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.100553] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.100561] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.100568] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.100574] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.100580] usb usb1: SerialNumber: sunxi-ehci
[   14.101032] hub 1-0:1.0: USB hub found
[   14.101049] hub 1-0:1.0: 1 port detected
[   14.101196] scene_lock_init name=ehci_standby
[   14.101204] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.101212] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.101264] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.101284] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.101331] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b86d0
[   14.163494] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.163509] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.163516] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.163522] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.163528] usb usb3: SerialNumber: sunxi-ohci
[   14.164000] hub 3-0:1.0: USB hub found
[   14.164019] hub 3-0:1.0: 1 port detected
[   14.164172] scene_lock_init name=ohci_standby
[   16.369364] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.723694] systemd[1]: System time before build time, advancing clock.
[   16.760542] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.760842] systemd[1]: Detected architecture arm64.
[   16.789492] systemd[1]: Set hostname to <cluster0>.
[   17.072696] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.092597] systemd[1]: Created slice System Slice.
[   17.111882] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.131418] systemd[1]: Listening on udev Control Socket.
[   17.151016] systemd[1]: Listening on Syslog Socket.
[   17.170640] systemd[1]: Listening on udev Kernel Socket.
[   17.190271] systemd[1]: Reached target Swap.
[   17.209935] systemd[1]: Reached target Encrypted Volumes.
[   17.229765] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.249398] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.269180] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.288713] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.308338] systemd[1]: Reached target Remote File Systems (Pre).
[   17.328015] systemd[1]: Reached target Remote File Systems.
[   17.348250] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.367692] systemd[1]: Created slice User and Session Slice.
[   17.387065] systemd[1]: Reached target Slices.
[   17.406733] systemd[1]: Reached target Paths.
[   17.426597] systemd[1]: Listening on Journal Socket.
[   17.447922] systemd[1]: Starting Nameserver information manager...
[   17.477486] systemd[1]: Starting Load Kernel Modules...
[   17.504854] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.527205] systemd[1]: Mounting Huge Pages File System...
[   17.547383] systemd[1]: Mounting Debug File System...
[   17.566609] systemd[1]: Starting Set console keymap...
[   17.586756] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.605799] systemd[1]: Mounting POSIX Message Queue File System...
[   17.614002] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.614313] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.614466] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.614605] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.616139] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.639445] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.668930] systemd[1]: Starting Restore / save the current clock...
[   17.678490] cfg80211: Calling CRDA to update world regulatory domain
[   17.687125] systemd[1]: Mounted Debug File System.
[   17.702323] systemd[1]: Mounted POSIX Message Queue File System.
[   17.721926] systemd[1]: Mounted Huge Pages File System.
[   17.745265] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.773783] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.794629] systemd[1]: Started Set console keymap.
[   17.807714] RTL871X: module init start
[   17.807731] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.807736] RTL871X: build time: Jan  9 2019 22:15:04
[   17.807741] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.807757] sunxi-wlan wlan.26: bus_index: 1
[   17.807918] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.811528] systemd[1]: Started Restore / save the current clock.
[   17.831829] systemd[1]: Started Nameserver information manager.
[   17.858302] systemd[1]: Time has been changed
[   17.916271] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.916378] RTL871X: module init ret=0
[   17.916396] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   17.921269] systemd[1]: Started Load Kernel Modules.
[   17.928237] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.948761] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.949587] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.949611] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.952046] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.953920] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   17.954751] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.955569] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.956384] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.957193] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.958022] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.958940] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.959757] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.960575] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.960602] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.961494] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   17.961516] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   17.969359] systemd[1]: Mounting FUSE Control File System...
[   17.989349] systemd[1]: Starting Apply Kernel Variables...
[   18.010020] systemd[1]: Mounting Configuration File System...
[   18.026940] systemd[1]: Reached target Network (Pre).
[   18.048357] systemd[1]: Starting Load/Save Random Seed...
[   18.071195] systemd[1]: Starting udev Coldplug all Devices...
[   18.087956] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.108418] systemd[1]: Mounted FUSE Control File System.
[   18.125362] systemd[1]: Mounted Configuration File System.
[   18.146534] systemd[1]: Started Apply Kernel Variables.
[   18.165514] systemd[1]: Started Load/Save Random Seed.
[   18.186981] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.260523] systemd[1]: Reached target Local File Systems (Pre).
[   18.287257] systemd[1]: Mounting /tmp...
[   18.304365] systemd[1]: Starting udev Kernel Device Manager...
[   18.324703] systemd[1]: Mounted /tmp.
[   18.348729] systemd[1]: Started udev Coldplug all Devices.
[   18.378789] systemd[1]: Started udev Kernel Device Manager.
[   18.422473] systemd[1]: Reached target Sound Card.
[   18.483789] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.512071] systemd[1]: Starting Journal Service...
[   18.529415] systemd[1]: Reached target Local File Systems.
[   18.556187] systemd[1]: Starting Raise network interfaces...
[   18.581154] systemd[1]: Starting Set console font and keymap...
[   18.600702] systemd[1]: Starting Armbian ZRAM config...
[   18.671614] cfg80211: World regulatory domain updated:
[   18.671638] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.671645] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.671651] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.671656] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.671661] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.671666] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.671671] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.671677] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.671682] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.708358] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.725973] sunxi cedar version 0.1
[   18.726387] [cedar]: install start!!!
[   18.726600] ycy the get irq is 90
[   18.727234] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.727245] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.727251] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.727256] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.727261] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.727264] [cedar]: install end!!!
[   18.738984] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   18.812640] sunxi-bt bt.27: block state already is 1
[   18.816148] systemd[1]: Started Load/Save RF Kill Switch Status.
[   18.838371] systemd[1]: Found device /dev/ttyS0.
[   18.855604] systemd[1]: Started Journal Service.
[   18.868352] [VFE]cci probe end cci_sel = 0!
[   18.868648] [VFE]cci_init end
[   18.911924] Registered IR keymap rc_map_sunxi
[   18.913594] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.913912] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.956704] Driver for 1-wire Dallas network protocol.
[   18.973810] IR Sony protocol handler initialized
[   18.973832] lirc_dev: IR Remote Control driver registered, major 248
[   18.974566] IR RC5(x) protocol handler initialized
[   18.975231] IR RC6 protocol handler initialized
[   18.978424] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.978450] IR LIRC bridge handler initialized
[   18.978466] IR JVC protocol handler initialized
[   18.980986] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.983732] IR MCE Keyboard/mouse protocol handler initialized
[   18.985469] IR SANYO protocol handler initialized
[   19.035801] systemd-journald[294]: Received request to flush runtime journal from PID 1
[   19.131169] IR NEC protocol handler initialized
[   19.134041] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.143466] zram: Created 6 device(s) ...
[   19.155135] [VFE]Welcome to Video Front End driver
[   19.155518] [VFE]csi probe end csi_sel = 0!
[   19.158912] [VFE]csi_init end
[   19.159365] [VFE]isp probe start isp_sel = 0!
[   19.160356] [ISP] isp platform_id = 3!
[   19.160369] [VFE]isp probe end isp_sel = 0!
[   19.160467] [VFE]sunxi_isp_platform_register end
[   19.160978] [VFE]mipi probe start mipi_sel = 0!
[   19.161001] [VFE]mipi probe end mipi_sel = 0!
[   19.168224] [VFE]mipi_init end
[   19.168249] [VFE]flash_init end
[   19.168738] [VFE]vfe_init end
[   19.293084] Adding 254468k swap on /dev/zram1.  Priority:5 extents:1 across:254468k SS
[   19.322919] Adding 254468k swap on /dev/zram2.  Priority:5 extents:1 across:254468k SS
[   19.352052] Adding 254468k swap on /dev/zram3.  Priority:5 extents:1 across:254468k SS
[   19.377514] Adding 254468k swap on /dev/zram4.  Priority:5 extents:1 across:254468k SS
[   19.594696] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.594717] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.69
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1892572 kB
Buffers:            7332 kB
Cached:            56152 kB
SwapCached:            0 kB
Active:            31780 kB
Inactive:          49848 kB
Active(anon):      18648 kB
Inactive(anon):     2856 kB
Active(file):      13132 kB
Inactive(file):    46992 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:                 0 kB
Writeback:             4 kB
AnonPages:         18392 kB
Mapped:            16156 kB
Shmem:              3044 kB
Slab:              22592 kB
SReclaimable:       9224 kB
SUnreclaim:        13368 kB
KernelStack:        2032 kB
PageTables:          672 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:     111808 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62562
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254472 zram1
 253        2     254472 zram2
 253        3     254472 zram3
 253        4     254472 zram4
### df:
/dev/mmcblk0p1   15G  882M   14G   7% /
/dev/zram0       49M  2.4M   43M   6% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M   2M 647.3K  1.4M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
01:47:38: 1152MHz  0.00  36%  12%  16%   0%   7%   0%   38°C   24°C  0/7
01:47:39: 1152MHz  0.00  46%   8%   4%   1%  32%   0%   37°C   24°C  0/7
01:47:39: 1152MHz  0.00  28%   2%   1%   2%  22%   0%   35°C   24°C  0/7
01:47:39: 1152MHz  0.00  28%   3%   0%   0%  23%   0%   35°C   24°C  0/7
01:47:40: 1152MHz  0.00  28%   7%   8%   0%  12%   0%   35°C   24°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Thu Jan 10 02:57:18 UTC 2019 | SoPine A64 | 5.69 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@nightly) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #76 SMP PREEMPT Wed Jan 9 22:15:14 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s18880 r8192 d22080 u49152
[    0.000000] pcpu-alloc: s18880 r8192 d22080 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1965428k/1965428k available, 115340k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000ab2000 - 0xffffffc000b329c0   (   515 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000ab1e84   ( 10440 kB)
                     .data : 0xffffffc000b33000 - 0xffffffc000c8d318   (  1385 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.020315] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.020324] pid_max: default: 32768 minimum: 301
[   10.020419] Security Framework initialized
[   10.020467] AppArmor: AppArmor initialized
[   10.020502] Mount-cache hash table entries: 256
[   10.030834] Initializing cgroup subsys memory
[   10.030880] Initializing cgroup subsys devices
[   10.030887] Initializing cgroup subsys freezer
[   10.030893] Initializing cgroup subsys blkio
[   10.030899] Initializing cgroup subsys perf_event
[   10.030908] Initializing cgroup subsys hugetlb
[   10.030968] ftrace: allocating 27493 entries in 108 pages
[   10.063013] CPU0: update cpu_power 1968128
[   10.063034] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.064025] virtual base = 0xffffff800000a000.
[   10.064038] gicd_base = 0xffffff800000c000.
[   10.064043] gicc_base = 0xffffff800000e000.
[   10.064676] CPU1: Booted secondary processor
[   10.064703] CPU1: update cpu_power 1968128
[   10.067299] CPU2: Booted secondary processor
[   10.067311] CPU2: update cpu_power 1968128
[   10.071416] CPU3: Booted secondary processor
[   10.071427] CPU3: update cpu_power 1968128
[   10.071500] Brought up 4 CPUs
[   10.071520] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.072028] devtmpfs: initialized
[   10.076773] pinctrl core: initialized pinctrl subsystem
[   10.079208] NET: Registered protocol family 16
[   10.079463] script_sysfs_init success
[   10.079701] dump_class_init,806, success
[   10.079941] vdso: 2 pages (1 code, 1 data) at base ffffffc000b39000
[   10.079963] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.081223] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.082287] DMA: preallocated 256 KiB pool for atomic allocations
[   10.082402] Serial: AMBA PL011 UART driver
[   10.082508] axp81x_board_init: axp regl_devs num = 23
[   10.082650] pll_audio-set_default_rate=24576000 success!
[   10.082668] pll_video0-set_default_rate=297000000 success!
[   10.082740] pll_video1-set_default_rate=297000000 success!
[   10.082801] pll_de-set_default_rate=297000000 success!
[   10.083510] de-set_default_source=pll_de success!
[   10.083516] de-set_default_rate=297000000 success!
[   10.083558] tcon0-set_default_source=pll_mipi success!
[   10.083588] tcon1-set_default_source=pll_video0 success!
[   10.083805] hdmi-set_default_source=pll_video0 success!
[   10.086001] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.086157] [sun50iw1p1_pinctrl_probe][838]
[   10.087586] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.088204] sunxi hwspinlock vbase:0xffffff800005c000
[   10.098285] bio: create slab <bio-0> at 0
[   10.098632] pwm module init!
[   10.099844] SCSI subsystem initialized
[   10.099966] usbcore: registered new interface driver usbfs
[   10.100000] usbcore: registered new interface driver hub
[   10.100069] usbcore: registered new device driver usb
[   10.100759] Linux video capture interface: v2.00
[   10.101207] [ARISC] :sunxi-arisc driver v1.10
[   10.108109] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.108354] Advanced Linux Sound Architecture Driver Initialized.
[   10.108700] NetLabel: Initializing
[   10.108705] NetLabel:  domain hash size = 128
[   10.108709] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.108747] NetLabel:  unlabeled traffic allowed by default
[   10.108906] [pm]aw_pm_init!
[   10.108974] rtc physical base = 0x0000000001f00000 .
[   10.109007] np name = /soc@01c00000/rtc@01f00000.
[   10.109013] base = ffffff800006e100, len = 4.
[   10.109018] pmu name: pmu0 .
[   10.109053] pmu0_enable = 0x1.
[   10.109059] pmux_id = 0x6.
[   10.109065] pmux_twi_id = 0x1.
[   10.109070] pmux_twi_addr = 0x34.
[   10.109074] pmu name: pmu1 .
[   10.109127] Warning: can not find np for pmu1.
[   10.109355] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.109517] after inited: sys_mask config = 0x4a55.
[   10.109539] Warning: can not find np for dynamic_standby_para.
[   10.109675] [pm]valid
[   10.109679] [pm]valid
[   10.109683] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.109886] Switching to clocksource arch_sys_counter_ool
[   10.120493] AppArmor: AppArmor Filesystem Enabled
[   10.126985] NET: Registered protocol family 2
[   10.127675] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.127916] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.128229] TCP: Hash tables configured (established 16384 bind 16384)
[   10.128311] TCP: reno registered
[   10.128322] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.128374] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.128628] NET: Registered protocol family 1
[   10.128951] RPC: Registered named UNIX socket transport module.
[   10.128957] RPC: Registered udp transport module.
[   10.128961] RPC: Registered tcp transport module.
[   10.128965] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.129140] Trying to unpack rootfs image as initramfs...
[   10.333630] Freeing initrd memory: 4292K (ffffffc075a85000 - ffffffc075eb6000)
[   10.334225] kvm [1]: Using HYP init bounce page @b787c000
[   10.334731] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.335154] kvm [1]: timer IRQ27
[   10.335169] kvm [1]: Hyp mode initialized successfully
[   10.336929] lock super standby defaultly!
[   10.336946] lookup_scene_lock_name: new scene lock super_standby
[   10.336951] scene_lock_init name=super_standby
[   10.336958] scene_lock: super_standby, type 5, count 1
[   10.337378] audit: initializing netlink socket (disabled)
[   10.337435] type=2000 audit(0.310:1): initialized
[   10.338101] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.338557] VFS: Disk quotas dquot_6.5.2
[   10.338660] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.339587] NFS: Registering the id_resolver key type
[   10.339635] Key type id_resolver registered
[   10.339640] Key type id_legacy registered
[   10.339651] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.339794] NTFS driver 2.1.30 [Flags: R/W].
[   10.339959] fuse init (API version 7.22)
[   10.340133] msgmni has been set to 3975
[   10.341087] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.341171] io scheduler noop registered
[   10.341177] io scheduler deadline registered
[   10.341206] io scheduler cfq registered (default)
[   10.341782] [DISP]disp_module_init
[   10.342219] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.342226] [DISP] boot_disp:0x0
[   10.342818] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.342949] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.343082] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.344198] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.344204] [DISP] fb_base:0x0
[   10.361918] Console: switching to colour frame buffer device 160x45
[   10.376489] [DISP]disp_module_init finish
[   10.376905] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.376927] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.377283] console [ttyS0] enabled
[   10.377659] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.377891] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.378196] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.378481] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.378813] misc dump reg init
[   10.378958] [drm] Initialized drm 1.1.0 20060810
[   10.381090] brd: module loaded
[   10.383199] loop: module loaded
[   10.383458] sunxi-bt bt.27: Missing bt_power.
[   10.383466] sunxi-bt bt.27: bt_power_name ((null))
[   10.383473] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.383505] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.383549] sunxi-bt bt.27: clk not config
[   10.383621] sunxi-bt bt.27: block state already is 1
[   10.383800] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.383807] sunxi-wlan wlan.26: Missing wlan_power.
[   10.383813] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.383820] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.383838] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.383857] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.383873] sunxi-wlan wlan.26: clk not config
[   10.384572] WARNING: Get ephy clock is failed
[   10.385185] chipid-sunxi serial 140050374620201507cf
[   10.385277] PPP generic driver version 2.4.2
[   10.385432] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.385605] get ehci0-controller drv_vbus_gpio is fail
[   10.385611] get ehci0-controller, regulator_io is no nocare
[   10.385651] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   10.385705] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.385724] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.386065] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000584c7c
[   10.405148] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.405229] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.405237] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.405243] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.405250] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.405256] usb usb1: SerialNumber: sunxi-ehci
[   10.405585] hub 1-0:1.0: USB hub found
[   10.405601] hub 1-0:1.0: 1 port detected
[   10.405732] scene_lock_init name=ehci_standby
[   10.405805] get ehci1-controller drv_vbus_gpio is fail
[   10.405811] get ehci1-controller, regulator_io is no nocare
[   10.405850] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000d16dd0, 0x:ffffff80000b2000, irq_no:6a
[   10.405898] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.405917] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.406178] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000584c7c
[   10.424976] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.425022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.425030] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.425036] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.425043] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.425049] usb usb2: SerialNumber: sunxi-ehci
[   10.425347] hub 2-0:1.0: USB hub found
[   10.425361] hub 2-0:1.0: 1 port detected
[   10.425485] scene_lock_init name=ehci_standby
[   10.425678] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.425835] get ohci0-controller drv_vbus_gpio is fail
[   10.425841] get ohci0-controller, regulator_io is no nocare
[   10.425880] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   10.425930] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.425945] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.425975] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.487829] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.487837] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.487844] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.487850] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.487856] usb usb3: SerialNumber: sunxi-ohci
[   10.488123] hub 3-0:1.0: USB hub found
[   10.488137] hub 3-0:1.0: 1 port detected
[   10.488250] scene_lock_init name=ohci_standby
[   10.488309] get ohci1-controller drv_vbus_gpio is fail
[   10.488314] get ohci1-controller, regulator_io is no nocare
[   10.488349] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000d16930
[   10.488388] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.488406] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.488432] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.546904] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.546912] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.546919] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.546925] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.546931] usb usb4: SerialNumber: sunxi-ohci
[   10.547204] hub 4-0:1.0: USB hub found
[   10.547217] hub 4-0:1.0: 1 port detected
[   10.547329] scene_lock_init name=ohci_standby
[   10.547633] usbcore: registered new interface driver usb-storage
[   10.547663] usbcore: registered new interface driver ums-alauda
[   10.547691] usbcore: registered new interface driver ums-cypress
[   10.547716] usbcore: registered new interface driver ums-datafab
[   10.547739] usbcore: registered new interface driver ums_eneub6250
[   10.547762] usbcore: registered new interface driver ums-freecom
[   10.547786] usbcore: registered new interface driver ums-isd200
[   10.547810] usbcore: registered new interface driver ums-jumpshot
[   10.547833] usbcore: registered new interface driver ums-karma
[   10.547856] usbcore: registered new interface driver ums-onetouch
[   10.547890] usbcore: registered new interface driver ums-realtek
[   10.547915] usbcore: registered new interface driver ums-sddr09
[   10.547939] usbcore: registered new interface driver ums-sddr55
[   10.547966] usbcore: registered new interface driver ums-usbat
[   10.548048] usbcore: registered new interface driver usbserial
[   10.548074] usbcore: registered new interface driver usbserial_generic
[   10.548098] usbserial: USB Serial support registered for generic
[   10.548291] mousedev: PS/2 mouse device common for all mice
[   10.548744] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.549599] get ctp_para failed, -1
[   10.549622] get node gsensor failed
[   10.549626] get sysconfig para erro!
[   10.549636] get node lightsensor failed
[   10.549639] get sysconfig para erro!
[   10.549648] get node gyroscopesensor failed
[   10.549651] get sysconfig para erro!
[   10.549660] get node compasssensor failed
[   10.549664] get sysconfig para erro!
[   10.549950] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.549970] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.550130] i2c /dev entries driver
[   10.592671] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.596117] sunxi budget cooling probe start !
[   10.596144] CPU freq cooling register Success
[   10.596162] CPU hotplug cooling register Success
[   10.596250] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.596258] CPU budget cooling register Success
[   10.596469] sunxi gpu cooling probe start !
[   10.596479] CPU gpu cooling register Success
[   10.597128] cpuidle: using governor ladder
[   10.597134] cpuidle: using governor menu
[   10.597867] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.597894] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.597903] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.597911] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.597962] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.597969] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.598554] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.598578] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.549689] wakeup gpio set err!get node ctp failed
[   10.601997] get sysconfig para erro!
[   10.611777] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.631466] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.631840] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.631864] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.631871] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.631878] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.631883] get() with no identifier
[   10.631886] get() with no identifier
[   10.631889] get() with no identifier
[   10.631895] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.631901] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.631907] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.632287] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.632301] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.632320] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.633108] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.633128] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.635512] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.637643] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.638457] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.639271] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.640082] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.640707] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.640749] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.643124] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.651136] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.670822] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.671504] ledtrig-cpu: registered to indicate activity on CPUs
[   10.671569] hidraw: raw HID events driver (C) Jiri Kosina
[   10.671720] usbcore: registered new interface driver usbhid
[   10.671724] usbhid: USB HID core driver
[   10.672580] usbcore: registered new interface driver snd-usb-audio
[   10.674608] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.675396] TCP: cubic registered
[   10.675404] Initializing XFRM netlink socket
[   10.675488] NET: Registered protocol family 10
[   10.676285] mip6: Mobile IPv6
[   10.676293] sit: IPv6 over IPv4 tunneling driver
[   10.676659] NET: Registered protocol family 17
[   10.676684] NET: Registered protocol family 15
[   10.676732] 8021q: 802.1Q VLAN Support v1.8
[   10.676778] Key type dns_resolver registered
[   10.676981] Registering SWP/SWPB emulation handler
[   10.677268] registered taskstats version 1
[   10.689229] Key type encrypted registered
[   10.689251] AppArmor: AppArmor sha1 policy hashing enabled
[   10.689694] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.689703] [DISP] boot_disp:0x0
[   10.689748] HDMI base address: ffffff8000b40000
[   10.690526] [HDMI] power vcc-hdmi-33
[   10.691052] [HDMI] cec support = 0
[   10.710129] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.712625] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.712698] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.712802] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.712828] mmc0: new high speed SDHC card at address aaaa
[   10.713255] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.715280]  mmcblk0: p1
[   10.716395] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.717203] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.717223] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.719615] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.721433] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.722242] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.723049] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.723853] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.724658] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.725465] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.726272] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727079] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727886] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.727902] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.728735] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.728752] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.801494] input: sunxi-ths as /devices/virtual/input/input2
[   10.801653] thermal thermal_zone0: failed to read out thermal zone 0
[   10.802069] ALSA device list:
[   10.802074]   #0: sndhdmi
[   10.802502] Freeing unused kernel memory: 512K (ffffffc000ab2000 - ffffffc000b32000)
[   11.399023] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.075461] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.075479] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80
[   14.075500] scene_lock_destroy name=ehci_standby
[   14.075514] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.075536] usb usb1: USB disconnect, device number 1
[   14.076087] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.076119] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.076127] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.076132] scene_lock_destroy name=ohci_standby
[   14.076140] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.076156] usb usb3: USB disconnect, device number 1
[   14.076535] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.076569] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.076576] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   14.076619] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.076643] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.079914] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b86d0
[   14.095167] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.095264] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.095272] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.095279] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.095285] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.095292] usb usb1: SerialNumber: sunxi-ehci
[   14.095758] hub 1-0:1.0: USB hub found
[   14.095776] hub 1-0:1.0: 1 port detected
[   14.095927] scene_lock_init name=ehci_standby
[   14.095935] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.095943] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.095993] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.096011] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.096053] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b86d0
[   14.158196] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.158211] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.158218] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.158224] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.158231] usb usb3: SerialNumber: sunxi-ohci
[   14.158683] hub 3-0:1.0: USB hub found
[   14.158702] hub 3-0:1.0: 1 port detected
[   14.158891] scene_lock_init name=ohci_standby
[   16.431208] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.785769] systemd[1]: System time before build time, advancing clock.
[   16.822646] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.822961] systemd[1]: Detected architecture arm64.
[   16.853082] systemd[1]: Set hostname to <cluster0>.
[   17.136783] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.155694] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.175404] systemd[1]: Reached target Encrypted Volumes.
[   17.194948] systemd[1]: Listening on udev Control Socket.
[   17.214618] systemd[1]: Listening on udev Kernel Socket.
[   17.234216] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.253918] systemd[1]: Reached target Remote File Systems (Pre).
[   17.273525] systemd[1]: Reached target Remote File Systems.
[   17.293767] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.313011] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.332683] systemd[1]: Listening on Syslog Socket.
[   17.352630] systemd[1]: Created slice User and Session Slice.
[   17.371926] systemd[1]: Reached target Swap.
[   17.391808] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.411285] systemd[1]: Reached target Paths.
[   17.431121] systemd[1]: Listening on Journal Socket.
[   17.451021] systemd[1]: Created slice System Slice.
[   17.472144] systemd[1]: Mounting Huge Pages File System...
[   17.499935] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.521934] systemd[1]: Starting Set console keymap...
[   17.541601] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.561188] systemd[1]: Mounting POSIX Message Queue File System...
[   17.564160] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.582646] systemd[1]: Starting Load Kernel Modules...
[   17.600673] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.620069] systemd[1]: Starting Nameserver information manager...
[   17.639695] systemd[1]: Mounting Debug File System...
[   17.657544] systemd[1]: Reached target Slices.
[   17.688842] systemd[1]: Starting Restore / save the current clock...
[   17.711218] systemd[1]: Mounted Debug File System.
[   17.726457] systemd[1]: Mounted POSIX Message Queue File System.
[   17.745951] systemd[1]: Mounted Huge Pages File System.
[   17.766747] systemd[1]: Started Set console keymap.
[   17.769792] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.770071] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.770215] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.770352] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.771484] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.786655] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.806473] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.822773] cfg80211: Calling CRDA to update world regulatory domain
[   17.828839] systemd[1]: Started Restore / save the current clock.
[   17.846850] systemd[1]: Started Nameserver information manager.
[   17.871975] systemd[1]: Time has been changed
[   17.955500] systemd[1]: Reached target Network (Pre).
[   17.957390] RTL871X: module init start
[   17.957402] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.957407] RTL871X: build time: Jan  9 2019 22:15:04
[   17.957411] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.957427] sunxi-wlan wlan.26: bus_index: 1
[   17.957579] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.974436] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.023272] systemd[1]: Starting udev Coldplug all Devices...
[   18.043226] systemd[1]: Starting Load/Save Random Seed...
[   18.065956] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.066044] RTL871X: module init ret=0
[   18.066075] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.068126] systemd[1]: Started Load Kernel Modules.
[   18.080433] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.088281] systemd[1]: Mounting FUSE Control File System...
[   18.100925] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.101749] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.101773] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.104204] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.106035] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.106852] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.107671] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.108499] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.109339] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.110178] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.111016] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.111863] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.112431] systemd[1]: Mounting Configuration File System...
[   18.112734] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.112775] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.113691] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.113728] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.132146] systemd[1]: Starting Apply Kernel Variables...
[   18.153773] systemd[1]: Mounted FUSE Control File System.
[   18.169659] systemd[1]: Mounted Configuration File System.
[   18.190795] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.211311] systemd[1]: Started Load/Save Random Seed.
[   18.230032] systemd[1]: Started Apply Kernel Variables.
[   18.308183] systemd[1]: Reached target Local File Systems (Pre).
[   18.331164] systemd[1]: Mounting /tmp...
[   18.348322] systemd[1]: Starting udev Kernel Device Manager...
[   18.369526] systemd[1]: Mounted /tmp.
[   18.386625] systemd[1]: Started udev Coldplug all Devices.
[   18.418348] systemd[1]: Started udev Kernel Device Manager.
[   18.462448] systemd[1]: Reached target Sound Card.
[   18.484112] systemd[1]: Reached target Local File Systems.
[   18.506541] systemd[1]: Starting Armbian ZRAM config...
[   18.530111] systemd[1]: Starting Raise network interfaces...
[   18.555258] systemd[1]: Starting Set console font and keymap...
[   18.603773] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.624395] systemd[1]: Starting Journal Service...
[   18.716803] sunxi cedar version 0.1
[   18.717064] [cedar]: install start!!!
[   18.717222] ycy the get irq is 90
[   18.717672] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.717684] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.717689] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.717694] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.717699] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.717703] [cedar]: install end!!!
[   18.726687] cfg80211: World regulatory domain updated:
[   18.726705] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.726712] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.726718] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.726723] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.726728] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.726733] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.726738] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.726744] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.726749] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.786926] systemd[1]: Found device /dev/ttyS0.
[   18.840727] Registered IR keymap rc_map_sunxi
[   18.841241] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.841452] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.898342] Driver for 1-wire Dallas network protocol.
[   18.909604] systemd[1]: Started Journal Service.
[   18.930525] IR NEC protocol handler initialized
[   18.931736] IR RC5(x) protocol handler initialized
[   18.933009] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.934156] IR MCE Keyboard/mouse protocol handler initialized
[   18.934169] IR RC6 protocol handler initialized
[   18.935454] IR Sony protocol handler initialized
[   18.938979] IR SANYO protocol handler initialized
[   18.939031] IR JVC protocol handler initialized
[   18.940759] lirc_dev: IR Remote Control driver registered, major 248
[   18.944700] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.944707] IR LIRC bridge handler initialized
[   19.000794] [VFE]cci probe end cci_sel = 0!
[   19.001068] [VFE]cci_init end
[   19.112121] systemd-journald[299]: Received request to flush runtime journal from PID 1
[   19.155388] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.170546] [VFE]Welcome to Video Front End driver
[   19.170987] [VFE]csi probe end csi_sel = 0!
[   19.171930] [VFE]csi_init end
[   19.173194] [VFE]isp probe start isp_sel = 0!
[   19.186822] zram: Created 6 device(s) ...
[   19.193097] [ISP] isp platform_id = 3!
[   19.193130] [VFE]isp probe end isp_sel = 0!
[   19.193287] [VFE]sunxi_isp_platform_register end
[   19.193897] [VFE]mipi probe start mipi_sel = 0!
[   19.193935] [VFE]mipi probe end mipi_sel = 0!
[   19.194009] [VFE]mipi_init end
[   19.194016] [VFE]flash_init end
[   19.195518] [VFE]vfe_init end
[   19.277782] sunxi-bt bt.27: block state already is 1
[   19.373869] Adding 254468k swap on /dev/zram1.  Priority:5 extents:1 across:254468k SS
[   19.413559] Adding 254468k swap on /dev/zram2.  Priority:5 extents:1 across:254468k SS
[   19.442658] Adding 254468k swap on /dev/zram3.  Priority:5 extents:1 across:254468k SS
[   19.473951] Adding 254468k swap on /dev/zram4.  Priority:5 extents:1 across:254468k SS
[   19.692841] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.692863] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.69
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035768 kB
MemFree:         1886796 kB
Buffers:            7452 kB
Cached:            58192 kB
SwapCached:            0 kB
Active:            34784 kB
Inactive:          52648 kB
Active(anon):      21980 kB
Inactive(anon):     2860 kB
Active(file):      12804 kB
Inactive(file):    49788 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017872 kB
SwapFree:        1017872 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         21736 kB
Mapped:            17092 kB
Shmem:              3044 kB
Slab:              22716 kB
SReclaimable:       9152 kB
SUnreclaim:        13564 kB
KernelStack:        1936 kB
PageTables:          488 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035756 kB
Committed_AS:     115696 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633468 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5607
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 62561
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254472 zram1
 253        2     254472 zram2
 253        3     254472 zram3
 253        4     254472 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
tmpfs           995M     0  995M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           995M     0  995M   0% /sys/fs/cgroup
tmpfs           995M  4.0K  995M   1% /tmp
/dev/zram0       49M  2.7M   43M   6% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M  2.3M 759.2K  1.5M         /var/log
/dev/zram1             248.5M    4K    78B    4K         [SWAP]
/dev/zram2             248.5M    4K    78B    4K         [SWAP]
/dev/zram3             248.5M    4K    78B    4K         [SWAP]
/dev/zram4             248.5M    4K    78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
02:57:21: 1152MHz  0.00  36%  12%  16%   0%   7%   0%   41°C   25°C  0/7
02:57:22: 1152MHz  0.00  50%   7%   2%   2%  37%   0%   39°C   25°C  0/7
02:57:22: 1152MHz  0.00  27%   4%   1%   0%  21%   0%   37°C   25°C  0/7
02:57:22: 1152MHz  0.00  29%   5%   0%   1%  21%   0%   37°C   25°C  0/7
02:57:23: 1152MHz  0.00  28%   4%  22%   0%   2%   0%   37°C   25°C  0/7
Thu Jan 10 03:21:20 UTC 2019 | SoPine A64 | 5.69 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.032634] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.032643] pid_max: default: 32768 minimum: 301
[   10.032736] Security Framework initialized
[   10.032784] AppArmor: AppArmor initialized
[   10.032819] Mount-cache hash table entries: 256
[   10.043131] Initializing cgroup subsys memory
[   10.043179] Initializing cgroup subsys devices
[   10.043187] Initializing cgroup subsys freezer
[   10.043193] Initializing cgroup subsys blkio
[   10.043199] Initializing cgroup subsys perf_event
[   10.043209] Initializing cgroup subsys hugetlb
[   10.043266] ftrace: allocating 27493 entries in 108 pages
[   10.075251] CPU0: update cpu_power 1968128
[   10.075271] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.076252] virtual base = 0xffffff800000a000.
[   10.076265] gicd_base = 0xffffff800000c000.
[   10.076270] gicc_base = 0xffffff800000e000.
[   10.076905] CPU1: Booted secondary processor
[   10.076932] CPU1: update cpu_power 1968128
[   10.079529] CPU2: Booted secondary processor
[   10.079542] CPU2: update cpu_power 1968128
[   10.083648] CPU3: Booted secondary processor
[   10.083659] CPU3: update cpu_power 1968128
[   10.083734] Brought up 4 CPUs
[   10.083755] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.084260] devtmpfs: initialized
[   10.088982] pinctrl core: initialized pinctrl subsystem
[   10.091453] NET: Registered protocol family 16
[   10.091708] script_sysfs_init success
[   10.091945] dump_class_init,806, success
[   10.092185] vdso: 2 pages (1 code, 1 data) at base ffffffc000b39000
[   10.092206] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.093467] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.094527] DMA: preallocated 256 KiB pool for atomic allocations
[   10.094643] Serial: AMBA PL011 UART driver
[   10.094746] axp81x_board_init: axp regl_devs num = 23
[   10.094887] pll_audio-set_default_rate=24576000 success!
[   10.094905] pll_video0-set_default_rate=297000000 success!
[   10.094977] pll_video1-set_default_rate=297000000 success!
[   10.095034] pll_de-set_default_rate=297000000 success!
[   10.095740] de-set_default_source=pll_de success!
[   10.095746] de-set_default_rate=297000000 success!
[   10.095788] tcon0-set_default_source=pll_mipi success!
[   10.095818] tcon1-set_default_source=pll_video0 success!
[   10.096030] hdmi-set_default_source=pll_video0 success!
[   10.098246] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.098404] [sun50iw1p1_pinctrl_probe][838]
[   10.099836] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.100451] sunxi hwspinlock vbase:0xffffff800005c000
[   10.110516] bio: create slab <bio-0> at 0
[   10.110863] pwm module init!
[   10.112079] SCSI subsystem initialized
[   10.112200] usbcore: registered new interface driver usbfs
[   10.112233] usbcore: registered new interface driver hub
[   10.112296] usbcore: registered new device driver usb
[   10.112986] Linux video capture interface: v2.00
[   10.113445] [ARISC] :sunxi-arisc driver v1.10
[   10.120368] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.120616] Advanced Linux Sound Architecture Driver Initialized.
[   10.120960] NetLabel: Initializing
[   10.120965] NetLabel:  domain hash size = 128
[   10.120968] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.121007] NetLabel:  unlabeled traffic allowed by default
[   10.121164] [pm]aw_pm_init!
[   10.121231] rtc physical base = 0x0000000001f00000 .
[   10.121263] np name = /soc@01c00000/rtc@01f00000.
[   10.121269] base = ffffff800006e100, len = 4.
[   10.121274] pmu name: pmu0 .
[   10.121309] pmu0_enable = 0x1.
[   10.121314] pmux_id = 0x6.
[   10.121320] pmux_twi_id = 0x1.
[   10.121326] pmux_twi_addr = 0x34.
[   10.121330] pmu name: pmu1 .
[   10.121380] Warning: can not find np for pmu1.
[   10.121606] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.121766] after inited: sys_mask config = 0x4a55.
[   10.121787] Warning: can not find np for dynamic_standby_para.
[   10.121905] [pm]valid
[   10.121909] [pm]valid
[   10.121913] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.122115] Switching to clocksource arch_sys_counter_ool
[   10.132693] AppArmor: AppArmor Filesystem Enabled
[   10.139171] NET: Registered protocol family 2
[   10.139862] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.140103] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.140411] TCP: Hash tables configured (established 16384 bind 16384)
[   10.140494] TCP: reno registered
[   10.140504] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.140555] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.140808] NET: Registered protocol family 1
[   10.141127] RPC: Registered named UNIX socket transport module.
[   10.141132] RPC: Registered udp transport module.
[   10.141136] RPC: Registered tcp transport module.
[   10.141141] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.141318] Trying to unpack rootfs image as initramfs...
[   10.345711] Freeing initrd memory: 4292K (ffffffc075a85000 - ffffffc075eb6000)
[   10.346300] kvm [1]: Using HYP init bounce page @b787a000
[   10.346817] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.347243] kvm [1]: timer IRQ27
[   10.347257] kvm [1]: Hyp mode initialized successfully
[   10.349026] lock super standby defaultly!
[   10.349042] lookup_scene_lock_name: new scene lock super_standby
[   10.349047] scene_lock_init name=super_standby
[   10.349054] scene_lock: super_standby, type 5, count 1
[   10.349464] audit: initializing netlink socket (disabled)
[   10.349523] type=2000 audit(0.310:1): initialized
[   10.350190] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.350647] VFS: Disk quotas dquot_6.5.2
[   10.350748] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.351671] NFS: Registering the id_resolver key type
[   10.351733] Key type id_resolver registered
[   10.351738] Key type id_legacy registered
[   10.351749] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.351891] NTFS driver 2.1.30 [Flags: R/W].
[   10.352055] fuse init (API version 7.22)
[   10.352233] msgmni has been set to 3975
[   10.353187] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.353272] io scheduler noop registered
[   10.353278] io scheduler deadline registered
[   10.353306] io scheduler cfq registered (default)
[   10.353876] [DISP]disp_module_init
[   10.354316] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.354324] [DISP] boot_disp:0x0
[   10.354917] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.355048] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.355179] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.356298] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.356303] [DISP] fb_base:0x0
[   10.374013] Console: switching to colour frame buffer device 160x45
[   10.388585] [DISP]disp_module_init finish
[   10.389003] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.389025] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.389379] console [ttyS0] enabled
[   10.389759] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.389991] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.390298] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.390583] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.390918] misc dump reg init
[   10.391065] [drm] Initialized drm 1.1.0 20060810
[   10.393205] brd: module loaded
[   10.395326] loop: module loaded
[   10.395588] sunxi-bt bt.27: Missing bt_power.
[   10.395596] sunxi-bt bt.27: bt_power_name ((null))
[   10.395604] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.395638] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.395681] sunxi-bt bt.27: clk not config
[   10.395754] sunxi-bt bt.27: block state already is 1
[   10.395934] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.395941] sunxi-wlan wlan.26: Missing wlan_power.
[   10.395947] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.395954] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.395970] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.395988] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.396005] sunxi-wlan wlan.26: clk not config
[   10.396703] WARNING: Get ephy clock is failed
[   10.397309] chipid-sunxi serial 140050374620201507cf
[   10.397403] PPP generic driver version 2.4.2
[   10.397555] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.397660] get ehci0-controller drv_vbus_gpio is fail
[   10.397666] get ehci0-controller, regulator_io is no nocare
[   10.397763] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   10.397817] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.397836] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.398181] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc000584c7c
[   10.417366] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.417447] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.417455] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.417462] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.417468] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.417474] usb usb1: SerialNumber: sunxi-ehci
[   10.417813] hub 1-0:1.0: USB hub found
[   10.417829] hub 1-0:1.0: 1 port detected
[   10.417963] scene_lock_init name=ehci_standby
[   10.418035] get ehci1-controller drv_vbus_gpio is fail
[   10.418040] get ehci1-controller, regulator_io is no nocare
[   10.418079] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000d16dd0, 0x:ffffff80000b2000, irq_no:6a
[   10.418128] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.418147] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.418401] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc000584c7c
[   10.437189] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.437234] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.437242] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.437248] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.437255] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.437261] usb usb2: SerialNumber: sunxi-ehci
[   10.437559] hub 2-0:1.0: USB hub found
[   10.437572] hub 2-0:1.0: 1 port detected
[   10.437696] scene_lock_init name=ehci_standby
[   10.437887] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.438040] get ohci0-controller drv_vbus_gpio is fail
[   10.438046] get ohci0-controller, regulator_io is no nocare
[   10.438085] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   10.438136] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.438151] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.438182] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.500058] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.500066] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.500073] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.500079] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.500085] usb usb3: SerialNumber: sunxi-ohci
[   10.500356] hub 3-0:1.0: USB hub found
[   10.500370] hub 3-0:1.0: 1 port detected
[   10.500487] scene_lock_init name=ohci_standby
[   10.500547] get ohci1-controller drv_vbus_gpio is fail
[   10.500552] get ohci1-controller, regulator_io is no nocare
[   10.500585] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000d16930
[   10.500625] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.500642] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.500667] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.559136] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.559144] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.559151] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.559158] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.559164] usb usb4: SerialNumber: sunxi-ohci
[   10.559439] hub 4-0:1.0: USB hub found
[   10.559453] hub 4-0:1.0: 1 port detected
[   10.559567] scene_lock_init name=ohci_standby
[   10.559867] usbcore: registered new interface driver usb-storage
[   10.559897] usbcore: registered new interface driver ums-alauda
[   10.559925] usbcore: registered new interface driver ums-cypress
[   10.559951] usbcore: registered new interface driver ums-datafab
[   10.559973] usbcore: registered new interface driver ums_eneub6250
[   10.559996] usbcore: registered new interface driver ums-freecom
[   10.560021] usbcore: registered new interface driver ums-isd200
[   10.560043] usbcore: registered new interface driver ums-jumpshot
[   10.560066] usbcore: registered new interface driver ums-karma
[   10.560090] usbcore: registered new interface driver ums-onetouch
[   10.560124] usbcore: registered new interface driver ums-realtek
[   10.560149] usbcore: registered new interface driver ums-sddr09
[   10.560173] usbcore: registered new interface driver ums-sddr55
[   10.560200] usbcore: registered new interface driver ums-usbat
[   10.560284] usbcore: registered new interface driver usbserial
[   10.560310] usbcore: registered new interface driver usbserial_generic
[   10.560335] usbserial: USB Serial support registered for generic
[   10.560528] mousedev: PS/2 mouse device common for all mice
[   10.560976] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.561826] get ctp_para failed, -1
[   10.561847] get node gsensor failed
[   10.561851] get sysconfig para erro!
[   10.561860] get node lightsensor failed
[   10.561864] get sysconfig para erro!
[   10.561873] get node gyroscopesensor failed
[   10.561876] get sysconfig para erro!
[   10.561885] get node compasssensor failed
[   10.561888] get sysconfig para erro!
[   10.562176] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.562196] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.562357] i2c /dev entries driver
[   10.604900] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.608348] sunxi budget cooling probe start !
[   10.608375] CPU freq cooling register Success
[   10.608393] CPU hotplug cooling register Success
[   10.608478] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.608486] CPU budget cooling register Success
[   10.608697] sunxi gpu cooling probe start !
[   10.608706] CPU gpu cooling register Success
[   10.609363] cpuidle: using governor ladder
[   10.609370] cpuidle: using governor menu
[   10.610108] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.610136] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.610144] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.610152] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.610206] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.610213] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.610807] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.610830] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.561915] wakeup gpio set err!get node ctp failed
[   10.614228] get sysconfig para erro!
[   10.624007] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.643696] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.644070] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  9 2019 at 22:15:00
[   10.644094] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.644101] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.644107] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.644111] get() with no identifier
[   10.644115] get() with no identifier
[   10.644118] get() with no identifier
[   10.644124] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.644130] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.644136] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.644518] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.644533] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.644553] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.645341] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.645360] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.647744] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.649880] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.650693] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.651505] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.652317] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.652944] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.652986] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.655359] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.663365] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.683051] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.683719] ledtrig-cpu: registered to indicate activity on CPUs
[   10.683784] hidraw: raw HID events driver (C) Jiri Kosina
[   10.683931] usbcore: registered new interface driver usbhid
[   10.683935] usbhid: USB HID core driver
[   10.684793] usbcore: registered new interface driver snd-usb-audio
[   10.686818] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.687616] TCP: cubic registered
[   10.687624] Initializing XFRM netlink socket
[   10.687707] NET: Registered protocol family 10
[   10.688502] mip6: Mobile IPv6
[   10.688510] sit: IPv6 over IPv4 tunneling driver
[   10.688877] NET: Registered protocol family 17
[   10.688903] NET: Registered protocol family 15
[   10.688951] 8021q: 802.1Q VLAN Support v1.8
[   10.688997] Key type dns_resolver registered
[   10.689202] Registering SWP/SWPB emulation handler
[   10.689489] registered taskstats version 1
[   10.701505] Key type encrypted registered
[   10.701526] AppArmor: AppArmor sha1 policy hashing enabled
[   10.701969] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.701979] [DISP] boot_disp:0x0
[   10.702024] HDMI base address: ffffff8000b40000
[   10.702820] [HDMI] power vcc-hdmi-33
[   10.703344] [HDMI] cec support = 0
[   10.722361] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.724860] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.724932] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.725034] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.725059] mmc0: new high speed SDHC card at address aaaa
[   10.725487] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.727513]  mmcblk0: p1
[   10.728629] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.729438] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.729458] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.731849] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.733666] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.734475] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.735282] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.736089] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.736895] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.737702] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.738510] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.739316] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.740123] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.740140] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.740973] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.740990] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.813799] input: sunxi-ths as /devices/virtual/input/input2
[   10.813960] thermal thermal_zone0: failed to read out thermal zone 0
[   10.814374] ALSA device list:
[   10.814380]   #0: sndhdmi
[   10.814798] Freeing unused kernel memory: 512K (ffffffc000ab2000 - ffffffc000b32000)
[   11.411226] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.087690] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.087704] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80
[   14.087726] scene_lock_destroy name=ehci_standby
[   14.087740] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.087762] usb usb1: USB disconnect, device number 1
[   14.088316] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.088349] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.088356] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.088361] scene_lock_destroy name=ohci_standby
[   14.088368] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.088385] usb usb3: USB disconnect, device number 1
[   14.088750] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.088784] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.088791] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000d16b80, 0x:ffffff80000aa000, irq_no:68
[   14.088835] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.088857] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.092400] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b86d0
[   14.107386] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.107483] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.107491] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.107498] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.107504] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.107510] usb usb1: SerialNumber: sunxi-ehci
[   14.107999] hub 1-0:1.0: USB hub found
[   14.108019] hub 1-0:1.0: 1 port detected
[   14.108167] scene_lock_init name=ehci_standby
[   14.108174] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.108182] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000d166e0
[   14.108230] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.108249] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.108291] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b86d0
[   14.170424] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.170439] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.170445] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.170452] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.170458] usb usb3: SerialNumber: sunxi-ohci
[   14.170910] hub 3-0:1.0: USB hub found
[   14.170930] hub 3-0:1.0: 1 port detected
[   14.171108] scene_lock_init name=ohci_standby
[   16.435603] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.793130] systemd[1]: System time before build time, advancing clock.
[   16.830222] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.830529] systemd[1]: Detected architecture arm64.
[   16.855563] systemd[1]: Set hostname to <cluster0>.
[   17.137720] systemd[1]: Listening on Journal Socket.
[   17.157918] systemd[1]: Reached target Encrypted Volumes.
[   17.177672] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.197196] systemd[1]: Reached target Remote File Systems (Pre).
[   17.216865] systemd[1]: Reached target Remote File Systems.
[   17.245633] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.266514] systemd[1]: Created slice User and Session Slice.
[   17.285880] systemd[1]: Listening on udev Kernel Socket.
[   17.305580] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.325407] systemd[1]: Created slice System Slice.
[   17.344834] systemd[1]: Reached target Slices.
[   17.369281] systemd[1]: Starting Restore / save the current clock...
[   17.388547] systemd[1]: Mounting POSIX Message Queue File System...
[   17.406489] systemd[1]: Mounting Huge Pages File System...
[   17.427603] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.455080] systemd[1]: Starting Nameserver information manager...
[   17.473202] systemd[1]: Listening on Syslog Socket.
[   17.494306] systemd[1]: Starting Set console keymap...
[   17.512228] systemd[1]: Reached target Swap.
[   17.532246] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.551817] systemd[1]: Listening on udev Control Socket.
[   17.573117] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.590279] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.591771] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.614280] systemd[1]: Reached target Paths.
[   17.630537] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.650427] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.675250] systemd[1]: Starting Load Kernel Modules...
[   17.691294] systemd[1]: Mounting Debug File System...
[   17.719277] systemd[1]: Mounted Debug File System.
[   17.738593] systemd[1]: Mounted POSIX Message Queue File System.
[   17.758218] systemd[1]: Mounted Huge Pages File System.
[   17.778724] systemd[1]: Started Restore / save the current clock.
[   17.799529] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.830767] systemd[1]: Started Set console keymap.
[   17.848114] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.869859] systemd[1]: Started Nameserver information manager.
[   17.874654] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.874958] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.875128] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.875263] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.876534] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.889033] systemd[1]: Time has been changed
[   17.929615] cfg80211: Calling CRDA to update world regulatory domain
[   17.979870] systemd[1]: Reached target Network (Pre).
[   17.996549] systemd[1]: Starting Load/Save Random Seed...
[   18.036213] systemd[1]: Starting udev Coldplug all Devices...
[   18.056159] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.064639] RTL871X: module init start
[   18.064656] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.064660] RTL871X: build time: Jan  9 2019 22:15:04
[   18.064665] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.064682] sunxi-wlan wlan.26: bus_index: 1
[   18.064842] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.110070] systemd[1]: Started Load/Save Random Seed.
[   18.183363] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.183491] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.183693] RTL871X: module init ret=0
[   18.186076] systemd[1]: Started Load Kernel Modules.
[   18.200946] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.202253] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.221369] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.231288] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.231357] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.233836] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.235739] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.236601] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.237444] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.237575] systemd[1]: Reached target Local File Systems (Pre).
[   18.238291] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.239122] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.239957] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.240802] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.241640] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.242456] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.242479] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.243367] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.243386] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.264685] systemd[1]: Mounting /tmp...
[   18.281738] systemd[1]: Starting udev Kernel Device Manager...
[   18.301582] systemd[1]: Starting Apply Kernel Variables...
[   18.321419] systemd[1]: Mounting FUSE Control File System...
[   18.340813] systemd[1]: Mounting Configuration File System...
[   18.361768] systemd[1]: Mounted FUSE Control File System.
[   18.378476] systemd[1]: Mounted Configuration File System.
[   18.397965] systemd[1]: Mounted /tmp.
[   18.418168] systemd[1]: Started udev Kernel Device Manager.
[   18.439237] systemd[1]: Started udev Coldplug all Devices.
[   18.447580] systemd[1]: Started Apply Kernel Variables.
[   18.535227] systemd[1]: Reached target Sound Card.
[   18.563220] cfg80211: World regulatory domain updated:
[   18.563240] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.563248] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.563253] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.563258] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.563263] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.563268] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.563274] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.563279] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.563285] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.576774] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.599093] systemd[1]: Starting Journal Service...
[   18.599166] sunxi cedar version 0.1
[   18.599457] [cedar]: install start!!!
[   18.599629] ycy the get irq is 90
[   18.600100] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.600111] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.600117] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.600122] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.600127] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.600131] [cedar]: install end!!!
[   18.614663] systemd[1]: Reached target Local File Systems.
[   18.636923] systemd[1]: Starting Set console font and keymap...
[   18.656655] systemd[1]: Starting Armbian ZRAM config...
[   18.670692] systemd[1]: Starting Raise network interfaces...
[   18.675112] [VFE]cci probe end cci_sel = 0!
[   18.675415] [VFE]cci_init end
[   18.713411] systemd[1]: Found device /dev/ttyS0.
[   18.733166] Registered IR keymap rc_map_sunxi
[   18.733725] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.734503] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.742504] Driver for 1-wire Dallas network protocol.
[   18.750453] IR NEC protocol handler initialized
[   18.787316] IR JVC protocol handler initialized
[   18.788620] IR RC5(x) protocol handler initialized
[   18.789291] IR RC6 protocol handler initialized
[   18.793142] [VFE]Welcome to Video Front End driver
[   18.813748] IR Sony protocol handler initialized
[   18.815177] [VFE]csi probe end csi_sel = 0!
[   18.815297] [VFE]csi_init end
[   18.815773] [VFE]isp probe start isp_sel = 0!
[   18.820826] [ISP] isp platform_id = 3!
[   18.820845] [VFE]isp probe end isp_sel = 0!
[   18.820945] [VFE]sunxi_isp_platform_register end
[   18.821459] [VFE]mipi probe start mipi_sel = 0!
[   18.821491] [VFE]mipi probe end mipi_sel = 0!
[   18.821567] [VFE]mipi_init end
[   18.821573] [VFE]flash_init end
[   18.822105] [VFE]vfe_init end
[   18.828413] IR SANYO protocol handler initialized
[   18.832839] lirc_dev: IR Remote Control driver registered, major 248
[   18.839457] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.839484] IR LIRC bridge handler initialized
[   18.839694] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.839965] IR MCE Keyboard/mouse protocol handler initialized
[   18.888373] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.995793] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   19.016114] systemd[1]: Started Journal Service.
[   19.053900] sunxi-bt bt.27: block state already is 1
[   19.099066] systemd-journald[295]: Received request to flush runtime journal from PID 1
[   19.135412] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.164581] zram: Created 6 device(s) ...
[   19.285347] Adding 254468k swap on /dev/zram1.  Priority:5 extents:1 across:254468k SS
[   19.320482] Adding 254468k swap on /dev/zram2.  Priority:5 extents:1 across:254468k SS
[   19.348505] Adding 254468k swap on /dev/zram3.  Priority:5 extents:1 across:254468k SS
[   19.376827] Adding 254468k swap on /dev/zram4.  Priority:5 extents:1 across:254468k SS
[   19.560030] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.560052] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.69
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1890816 kB
Buffers:            7396 kB
Cached:            56612 kB
SwapCached:            0 kB
Active:            33316 kB
Inactive:          51032 kB
Active(anon):      20552 kB
Inactive(anon):     2884 kB
Active(file):      12764 kB
Inactive(file):    48148 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:                 8 kB
Writeback:             0 kB
AnonPages:         20368 kB
Mapped:            15568 kB
Shmem:              3040 kB
Slab:              22196 kB
SReclaimable:       9224 kB
SUnreclaim:        12972 kB
KernelStack:        2080 kB
PageTables:          608 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:      81968 kB
VmallocChunk:   251633444 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62562
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254472 zram1
 253        2     254472 zram2
 253        3     254472 zram3
 253        4     254472 zram4
### df:
/dev/mmcblk0p1   15G  883M   14G   7% /
/dev/zram0       49M  3.0M   42M   7% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  2.6M 858.3K  1.6M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
03:21:23: 1152MHz  0.00  36%  12%  16%   0%   7%   0%   46°C   31°C  0/7
03:21:23: 1152MHz  0.00  41%   9%   5%   0%  26%   0%   46°C   31°C  0/7
03:21:23: 1152MHz  0.00  29%   0%   2%   3%  22%   0%   44°C   31°C  0/7
03:21:24: 1152MHz  0.00  27%   2%   5%   2%  17%   0%   43°C   31°C  0/7
03:21:24: 1152MHz  0.00  30%   4%  25%   1%   0%   0%   44°C   31°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Tue Mar  5 22:39:16 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@armbian.com) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #2 SMP PREEMPT Fri Feb 8 10:23:10 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s19520 r8192 d21440 u49152
[    0.000000] pcpu-alloc: s19520 r8192 d21440 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1964644k/1964644k available, 116124k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000b59000 - 0xffffffc000be0c40   (   544 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000b58164   ( 11105 kB)
                     .data : 0xffffffc000be1000 - 0xffffffc000d50e48   (  1472 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.065097] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.065105] pid_max: default: 32768 minimum: 301
[   10.065198] Security Framework initialized
[   10.065246] AppArmor: AppArmor initialized
[   10.065281] Mount-cache hash table entries: 256
[   10.075601] Initializing cgroup subsys memory
[   10.075649] Initializing cgroup subsys devices
[   10.075656] Initializing cgroup subsys freezer
[   10.075662] Initializing cgroup subsys blkio
[   10.075667] Initializing cgroup subsys perf_event
[   10.075678] Initializing cgroup subsys hugetlb
[   10.075740] ftrace: allocating 28898 entries in 113 pages
[   10.109482] CPU0: update cpu_power 1968128
[   10.109503] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.110477] virtual base = 0xffffff800000a000.
[   10.110490] gicd_base = 0xffffff800000c000.
[   10.110494] gicc_base = 0xffffff800000e000.
[   10.111126] CPU1: Booted secondary processor
[   10.111152] CPU1: update cpu_power 1968128
[   10.113749] CPU2: Booted secondary processor
[   10.113761] CPU2: update cpu_power 1968128
[   10.117868] CPU3: Booted secondary processor
[   10.117879] CPU3: update cpu_power 1968128
[   10.117952] Brought up 4 CPUs
[   10.117973] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.118476] devtmpfs: initialized
[   10.123489] pinctrl core: initialized pinctrl subsystem
[   10.125922] NET: Registered protocol family 16
[   10.126167] script_sysfs_init success
[   10.126399] dump_class_init,806, success
[   10.126633] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.126654] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.127932] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.128922] DMA: preallocated 256 KiB pool for atomic allocations
[   10.129037] Serial: AMBA PL011 UART driver
[   10.129130] axp81x_board_init: axp regl_devs num = 23
[   10.129287] pll_audio-set_default_rate=24576000 success!
[   10.129307] pll_video0-set_default_rate=297000000 success!
[   10.129374] pll_video1-set_default_rate=297000000 success!
[   10.129435] pll_de-set_default_rate=297000000 success!
[   10.130149] de-set_default_source=pll_de success!
[   10.130155] de-set_default_rate=297000000 success!
[   10.130200] tcon0-set_default_source=pll_mipi success!
[   10.130231] tcon1-set_default_source=pll_video0 success!
[   10.130446] hdmi-set_default_source=pll_video0 success!
[   10.132688] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.132849] [sun50iw1p1_pinctrl_probe][838]
[   10.134283] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.134898] sunxi hwspinlock vbase:0xffffff800005c000
[   10.145086] bio: create slab <bio-0> at 0
[   10.145470] pwm module init!
[   10.146702] SCSI subsystem initialized
[   10.146819] usbcore: registered new interface driver usbfs
[   10.146855] usbcore: registered new interface driver hub
[   10.146924] usbcore: registered new device driver usb
[   10.147631] Linux video capture interface: v2.00
[   10.148091] [ARISC] :sunxi-arisc driver v1.10
[   10.154987] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.155231] Advanced Linux Sound Architecture Driver Initialized.
[   10.155590] NetLabel: Initializing
[   10.155595] NetLabel:  domain hash size = 128
[   10.155599] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.155640] NetLabel:  unlabeled traffic allowed by default
[   10.155800] [pm]aw_pm_init!
[   10.155865] rtc physical base = 0x0000000001f00000 .
[   10.155898] np name = /soc@01c00000/rtc@01f00000.
[   10.155904] base = ffffff800006e100, len = 4.
[   10.155909] pmu name: pmu0 .
[   10.155945] pmu0_enable = 0x1.
[   10.155951] pmux_id = 0x6.
[   10.155958] pmux_twi_id = 0x1.
[   10.155963] pmux_twi_addr = 0x34.
[   10.155967] pmu name: pmu1 .
[   10.156014] Warning: can not find np for pmu1.
[   10.156243] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.156403] after inited: sys_mask config = 0x4a55.
[   10.156425] Warning: can not find np for dynamic_standby_para.
[   10.156556] [pm]valid
[   10.156560] [pm]valid
[   10.156563] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.156759] Switching to clocksource arch_sys_counter_ool
[   10.174703] AppArmor: AppArmor Filesystem Enabled
[   10.180811] NET: Registered protocol family 2
[   10.181490] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.181730] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.182045] TCP: Hash tables configured (established 16384 bind 16384)
[   10.182127] TCP: reno registered
[   10.182138] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.182190] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.182458] NET: Registered protocol family 1
[   10.182782] RPC: Registered named UNIX socket transport module.
[   10.182788] RPC: Registered udp transport module.
[   10.182792] RPC: Registered tcp transport module.
[   10.182797] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.182972] Trying to unpack rootfs image as initramfs...
[   10.387522] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.388103] kvm [1]: Using HYP init bounce page @b789c000
[   10.388639] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.389051] kvm [1]: timer IRQ27
[   10.389063] kvm [1]: Hyp mode initialized successfully
[   10.390717] lock super standby defaultly!
[   10.390732] lookup_scene_lock_name: new scene lock super_standby
[   10.390737] scene_lock_init name=super_standby
[   10.390743] scene_lock: super_standby, type 5, count 1
[   10.391148] audit: initializing netlink socket (disabled)
[   10.391199] type=2000 audit(0.310:1): initialized
[   10.391881] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.392356] VFS: Disk quotas dquot_6.5.2
[   10.392458] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.393462] NFS: Registering the id_resolver key type
[   10.393507] Key type id_resolver registered
[   10.393512] Key type id_legacy registered
[   10.393523] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.393661] NTFS driver 2.1.30 [Flags: R/W].
[   10.393836] fuse init (API version 7.22)
[   10.394014] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.394444] msgmni has been set to 3973
[   10.395440] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.395520] io scheduler noop registered
[   10.395526] io scheduler deadline registered
[   10.395559] io scheduler cfq registered (default)
[   10.396136] [DISP]disp_module_init
[   10.396592] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.396601] [DISP] boot_disp:0x0
[   10.397191] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.397325] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.397454] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.398563] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.398570] [DISP] fb_base:0x0
[   10.416282] Console: switching to colour frame buffer device 160x45
[   10.430739] [DISP]disp_module_init finish
[   10.431159] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.431182] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.431540] console [ttyS0] enabled
[   10.431918] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.432145] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.432606] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.432900] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.433252] misc dump reg init
[   10.433403] [drm] Initialized drm 1.1.0 20060810
[   10.435511] brd: module loaded
[   10.437644] loop: module loaded
[   10.437915] sunxi-bt bt.27: Missing bt_power.
[   10.437922] sunxi-bt bt.27: bt_power_name ((null))
[   10.437930] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.437963] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.438004] sunxi-bt bt.27: clk not config
[   10.438075] sunxi-bt bt.27: block state already is 1
[   10.438252] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.438260] sunxi-wlan wlan.26: Missing wlan_power.
[   10.438266] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.438274] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.438289] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.438309] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.438326] sunxi-wlan wlan.26: clk not config
[   10.439029] WARNING: Get ephy clock is failed
[   10.439664] chipid-sunxi serial 140050374620201507cf
[   10.439758] PPP generic driver version 2.4.2
[   10.439915] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.440023] get ehci0-controller drv_vbus_gpio is fail
[   10.440029] get ehci0-controller, regulator_io is no nocare
[   10.440068] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.440124] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.440143] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.440525] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.452023] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.452103] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.452111] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.452118] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.452125] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.452131] usb usb1: SerialNumber: sunxi-ehci
[   10.452464] hub 1-0:1.0: USB hub found
[   10.452480] hub 1-0:1.0: 1 port detected
[   10.452619] scene_lock_init name=ehci_standby
[   10.452692] get ehci1-controller drv_vbus_gpio is fail
[   10.452697] get ehci1-controller, regulator_io is no nocare
[   10.452739] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.452787] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.452803] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.453048] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.471705] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.471747] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.471754] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.471761] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.471768] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.471774] usb usb2: SerialNumber: sunxi-ehci
[   10.472045] hub 2-0:1.0: USB hub found
[   10.472058] hub 2-0:1.0: 1 port detected
[   10.472173] scene_lock_init name=ehci_standby
[   10.472360] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.472505] get ohci0-controller drv_vbus_gpio is fail
[   10.472510] get ohci0-controller, regulator_io is no nocare
[   10.472549] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.472595] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.472610] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.472638] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.534715] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.534723] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.534730] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.534736] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.534743] usb usb3: SerialNumber: sunxi-ohci
[   10.535026] hub 3-0:1.0: USB hub found
[   10.535040] hub 3-0:1.0: 1 port detected
[   10.535158] scene_lock_init name=ohci_standby
[   10.535223] get ohci1-controller drv_vbus_gpio is fail
[   10.535228] get ohci1-controller, regulator_io is no nocare
[   10.535265] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.535306] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.535321] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.535347] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.593771] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.593779] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.593786] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.593793] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.593799] usb usb4: SerialNumber: sunxi-ohci
[   10.594082] hub 4-0:1.0: USB hub found
[   10.594095] hub 4-0:1.0: 1 port detected
[   10.594208] scene_lock_init name=ohci_standby
[   10.594504] usbcore: registered new interface driver usb-storage
[   10.594535] usbcore: registered new interface driver ums-alauda
[   10.594559] usbcore: registered new interface driver ums-cypress
[   10.594584] usbcore: registered new interface driver ums-datafab
[   10.594610] usbcore: registered new interface driver ums_eneub6250
[   10.594634] usbcore: registered new interface driver ums-freecom
[   10.594658] usbcore: registered new interface driver ums-isd200
[   10.594681] usbcore: registered new interface driver ums-jumpshot
[   10.594708] usbcore: registered new interface driver ums-karma
[   10.594732] usbcore: registered new interface driver ums-onetouch
[   10.594763] usbcore: registered new interface driver ums-realtek
[   10.594788] usbcore: registered new interface driver ums-sddr09
[   10.594815] usbcore: registered new interface driver ums-sddr55
[   10.594839] usbcore: registered new interface driver ums-usbat
[   10.594925] usbcore: registered new interface driver usbserial
[   10.594952] usbcore: registered new interface driver usbserial_generic
[   10.594973] usbserial: USB Serial support registered for generic
[   10.595170] mousedev: PS/2 mouse device common for all mice
[   10.595630] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.596460] get ctp_para failed, -1
[   10.596480] get node gsensor failed
[   10.596484] get sysconfig para erro!
[   10.596494] get node lightsensor failed
[   10.596497] get sysconfig para erro!
[   10.596506] get node gyroscopesensor failed
[   10.596509] get sysconfig para erro!
[   10.596518] get node compasssensor failed
[   10.596522] get sysconfig para erro!
[   10.596819] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.596840] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.597001] i2c /dev entries driver
[   10.639553] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.642993] sunxi budget cooling probe start !
[   10.643024] CPU freq cooling register Success
[   10.643043] CPU hotplug cooling register Success
[   10.643133] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.643141] CPU budget cooling register Success
[   10.643352] sunxi gpu cooling probe start !
[   10.643363] CPU gpu cooling register Success
[   10.644017] cpuidle: using governor ladder
[   10.644023] cpuidle: using governor menu
[   10.644769] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.644798] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.644807] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.644815] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.644865] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.644872] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.645456] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.645480] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.596548] wakeup gpio set err!get node ctp failed
[   10.648871] get sysconfig para erro!
[   10.658654] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.678343] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.678726] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.678752] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.678759] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.678766] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.678771] get() with no identifier
[   10.678775] get() with no identifier
[   10.678778] get() with no identifier
[   10.678784] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.678790] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.678795] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.679150] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.679163] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.679169] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.679987] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.680006] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.682388] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.684531] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.685345] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.686157] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.686968] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687592] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.687636] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.690010] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.698012] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.717699] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.718396] ledtrig-cpu: registered to indicate activity on CPUs
[   10.718467] hidraw: raw HID events driver (C) Jiri Kosina
[   10.718593] usbcore: registered new interface driver usbhid
[   10.718597] usbhid: USB HID core driver
[   10.719487] usbcore: registered new interface driver snd-usb-audio
[   10.721547] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.722364] TCP: cubic registered
[   10.722374] Initializing XFRM netlink socket
[   10.722456] NET: Registered protocol family 10
[   10.723265] mip6: Mobile IPv6
[   10.723273] sit: IPv6 over IPv4 tunneling driver
[   10.723653] NET: Registered protocol family 17
[   10.723675] NET: Registered protocol family 15
[   10.723720] 8021q: 802.1Q VLAN Support v1.8
[   10.723765] Key type dns_resolver registered
[   10.723973] Registering SWP/SWPB emulation handler
[   10.724261] registered taskstats version 1
[   10.736259] Key type encrypted registered
[   10.736282] AppArmor: AppArmor sha1 policy hashing enabled
[   10.736730] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.736740] [DISP] boot_disp:0x0
[   10.736786] HDMI base address: ffffff8000b40000
[   10.737583] [HDMI] power vcc-hdmi-33
[   10.738107] [HDMI] cec support = 0
[   10.757008] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.759503] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.759577] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.759681] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.759706] mmc0: new high speed SDHC card at address aaaa
[   10.760123] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.762148]  mmcblk0: p1
[   10.763258] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.764066] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.764084] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.766476] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.768294] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.769103] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.769909] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.770716] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771521] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772328] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.773134] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.773941] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774748] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774765] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.775598] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.775615] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.848553] input: sunxi-ths as /devices/virtual/input/input2
[   10.848710] thermal thermal_zone0: failed to read out thermal zone 0
[   10.849115] ALSA device list:
[   10.849121]   #0: sndhdmi
[   10.849567] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.445869] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.132181] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.132198] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.132218] scene_lock_destroy name=ehci_standby
[   14.132231] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.132254] usb usb1: USB disconnect, device number 1
[   14.132822] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.132856] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.132864] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.132869] scene_lock_destroy name=ohci_standby
[   14.132877] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.132894] usb usb3: USB disconnect, device number 1
[   14.133262] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.133297] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.133304] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.133352] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.133379] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.134312] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.151888] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.151985] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.151994] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.152001] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.152007] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.152013] usb usb1: SerialNumber: sunxi-ehci
[   14.152499] hub 1-0:1.0: USB hub found
[   14.152519] hub 1-0:1.0: 1 port detected
[   14.152671] scene_lock_init name=ehci_standby
[   14.152678] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.152686] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.152736] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.152753] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.152797] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.214908] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.214922] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.214929] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.214936] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.214942] usb usb3: SerialNumber: sunxi-ohci
[   14.215397] hub 3-0:1.0: USB hub found
[   14.215416] hub 3-0:1.0: 1 port detected
[   14.215592] scene_lock_init name=ohci_standby
[   16.439452] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.823203] systemd[1]: System time before build time, advancing clock.
[   16.860432] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.860744] systemd[1]: Detected architecture arm64.
[   16.890123] systemd[1]: Set hostname to <cluster0>.
[   17.246641] systemd[1]: Listening on udev Kernel Socket.
[   17.261582] systemd[1]: Listening on Journal Socket.
[   17.281219] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.300828] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.320516] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.340221] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.359819] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.379984] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.399147] systemd[1]: Reached target Swap.
[   17.418898] systemd[1]: Listening on Syslog Socket.
[   17.438877] systemd[1]: Created slice System Slice.
[   17.459969] systemd[1]: Mounting POSIX Message Queue File System...
[   17.486987] systemd[1]: Starting Nameserver information manager...
[   17.509871] systemd[1]: Mounting Debug File System...
[   17.529057] systemd[1]: Starting Set console keymap...
[   17.551898] systemd[1]: Starting Restore / save the current clock...
[   17.566832] systemd[1]: Listening on udev Control Socket.
[   17.588640] systemd[1]: Mounting Huge Pages File System...
[   17.606273] systemd[1]: Created slice User and Session Slice.
[   17.625837] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.650942] systemd[1]: Starting Load Kernel Modules...
[   17.664958] systemd[1]: Reached target Remote File Systems (Pre).
[   17.685047] systemd[1]: Reached target Encrypted Volumes.
[   17.704324] systemd[1]: Reached target Remote File Systems.
[   17.724007] systemd[1]: Reached target Slices.
[   17.743546] systemd[1]: Reached target Paths.
[   17.765164] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.785948] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.791670] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.806881] systemd[1]: Mounted Debug File System.
[   17.822438] systemd[1]: Mounted POSIX Message Queue File System.
[   17.842045] systemd[1]: Mounted Huge Pages File System.
[   17.866374] systemd[1]: Started Set console keymap.
[   17.867289] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.867630] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.867810] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.867962] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.869193] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.883152] systemd[1]: Started Restore / save the current clock.
[   17.902767] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.922098] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.931744] cfg80211: Calling CRDA to update world regulatory domain
[   17.942923] systemd[1]: Started Nameserver information manager.
[   17.963760] systemd[1]: Time has been changed
[   18.052370] RTL871X: module init start
[   18.052386] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.052391] RTL871X: build time: Feb  8 2019 10:22:36
[   18.052396] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.052411] sunxi-wlan wlan.26: bus_index: 1
[   18.052568] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.066700] systemd[1]: Reached target Network (Pre).
[   18.090196] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.109859] systemd[1]: Starting Load/Save Random Seed...
[   18.134042] systemd[1]: Starting udev Coldplug all Devices...
[   18.161044] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.161193] RTL871X: module init ret=0
[   18.161196] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.161590] systemd[1]: Started Load/Save Random Seed.
[   18.176499] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.177745] systemd[1]: Started Load Kernel Modules.
[   18.196967] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.197811] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.197853] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.200347] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.202234] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.203083] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.203938] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.204779] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.205609] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.206439] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.207283] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.208131] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.208977] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.209023] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.209941] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.210586] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.213470] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.270070] systemd[1]: Starting udev Kernel Device Manager...
[   18.285063] systemd[1]: Reached target Local File Systems (Pre).
[   18.307205] systemd[1]: Mounting /tmp...
[   18.326282] systemd[1]: Mounting Configuration File System...
[   18.345909] systemd[1]: Starting Apply Kernel Variables...
[   18.365958] systemd[1]: Mounting FUSE Control File System...
[   18.385972] systemd[1]: Mounted FUSE Control File System.
[   18.403265] systemd[1]: Mounted Configuration File System.
[   18.422838] systemd[1]: Mounted /tmp.
[   18.443071] systemd[1]: Started udev Kernel Device Manager.
[   18.462900] systemd[1]: Started udev Coldplug all Devices.
[   18.484062] systemd[1]: Started Apply Kernel Variables.
[   18.565444] systemd[1]: Reached target Sound Card.
[   18.580687] cfg80211: World regulatory domain updated:
[   18.580709] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.580717] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.580722] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.580727] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.580732] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.580737] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.580742] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.580748] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.580753] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.601491] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.617418] sunxi cedar version 0.1
[   18.617672] [cedar]: install start!!!
[   18.617813] ycy the get irq is 90
[   18.618261] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.618273] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.618278] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.618283] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.618288] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.618292] [cedar]: install end!!!
[   18.624366] systemd[1]: Starting Journal Service...
[   18.639397] systemd[1]: Reached target Local File Systems.
[   18.661865] systemd[1]: Starting Set console font and keymap...
[   18.681827] systemd[1]: Starting Armbian ZRAM config...
[   18.720818] Registered IR keymap rc_map_sunxi
[   18.721354] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.722997] systemd[1]: Starting Raise network interfaces...
[   18.723630] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.743982] systemd[1]: Found device /dev/ttyS0.
[   18.755836] IR JVC protocol handler initialized
[   18.763404] [VFE]cci probe end cci_sel = 0!
[   18.763712] [VFE]cci_init end
[   18.767302] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.767576] IR MCE Keyboard/mouse protocol handler initialized
[   18.780614] lirc_dev: IR Remote Control driver registered, major 248
[   18.784504] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.784523] IR LIRC bridge handler initialized
[   18.789249] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.794915] Driver for 1-wire Dallas network protocol.
[   18.800214] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   18.808901] IR NEC protocol handler initialized
[   18.809872] IR RC5(x) protocol handler initialized
[   18.811034] IR RC6 protocol handler initialized
[   18.812085] IR SANYO protocol handler initialized
[   18.813055] IR Sony protocol handler initialized
[   18.914873] [VFE]Welcome to Video Front End driver
[   18.915313] [VFE]csi probe end csi_sel = 0!
[   18.915589] [VFE]csi_init end
[   18.916100] [VFE]isp probe start isp_sel = 0!
[   18.918287] [ISP] isp platform_id = 3!
[   18.918318] [VFE]isp probe end isp_sel = 0!
[   18.918452] [VFE]sunxi_isp_platform_register end
[   18.919047] [VFE]mipi probe start mipi_sel = 0!
[   18.919097] [VFE]mipi probe end mipi_sel = 0!
[   18.919211] [VFE]mipi_init end
[   18.919218] [VFE]flash_init end
[   18.919654] [VFE]vfe_init end
[   18.939769] sunxi-bt bt.27: block state already is 1
[   18.940627] systemd[1]: Started Load/Save RF Kill Switch Status.
[   18.964723] systemd[1]: Started Journal Service.
[   19.081482] systemd-journald[300]: Received request to flush runtime journal from PID 1
[   19.227369] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.232742] zram: Created 6 device(s) ...
[   19.379502] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.406276] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.434998] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.460088] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.686004] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.686026] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035016 kB
MemFree:         1885632 kB
Buffers:            9344 kB
Cached:            57304 kB
SwapCached:            0 kB
Active:            32524 kB
Inactive:          53208 kB
Active(anon):      19564 kB
Inactive(anon):     2844 kB
Active(file):      12960 kB
Inactive(file):    50364 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017504 kB
SwapFree:        1017504 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         19372 kB
Mapped:            15908 kB
Shmem:              3032 kB
Slab:              24148 kB
SReclaimable:      10456 kB
SUnreclaim:        13692 kB
KernelStack:        1952 kB
PageTables:          636 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035012 kB
Committed_AS:     114860 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633468 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5606
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 62496
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
/dev/mmcblk0p1   15G  930M   14G   7% /
tmpfs           994M     0  994M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           994M     0  994M   0% /sys/fs/cgroup
tmpfs           994M  4.0K  994M   1% /tmp
/dev/zram0       49M  3.4M   42M   8% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M   3M 984.3K  1.7M         /var/log
/dev/zram1             248.4M   4K    78B    4K         [SWAP]
/dev/zram2             248.4M   4K    78B    4K         [SWAP]
/dev/zram3             248.4M   4K    78B    4K         [SWAP]
/dev/zram4             248.4M   4K    78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
22:39:19: 1152MHz  0.00  36%  12%  16%   0%   8%   0%   39°C   25°C  0/7
22:39:19: 1152MHz  0.00  43%   8%   3%   1%  30%   0%   39°C   25°C  0/7
22:39:19: 1152MHz  0.00  28%   4%   1%   0%  22%   0%   37°C   25°C  0/7
22:39:20: 1152MHz  0.00  29%   5%   0%   1%  22%   0%   36°C   25°C  0/7
22:39:20: 1152MHz  0.08  31%   4%  22%   1%   2%   0%   36°C   25°C  0/7
Wed Mar  6 05:15:08 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.078058] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.078067] pid_max: default: 32768 minimum: 301
[   10.078162] Security Framework initialized
[   10.078210] AppArmor: AppArmor initialized
[   10.078245] Mount-cache hash table entries: 256
[   10.088598] Initializing cgroup subsys memory
[   10.088644] Initializing cgroup subsys devices
[   10.088651] Initializing cgroup subsys freezer
[   10.088658] Initializing cgroup subsys blkio
[   10.088663] Initializing cgroup subsys perf_event
[   10.088673] Initializing cgroup subsys hugetlb
[   10.088739] ftrace: allocating 28898 entries in 113 pages
[   10.122497] CPU0: update cpu_power 1968128
[   10.122517] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.123506] virtual base = 0xffffff800000a000.
[   10.123519] gicd_base = 0xffffff800000c000.
[   10.123524] gicc_base = 0xffffff800000e000.
[   10.124152] CPU1: Booted secondary processor
[   10.124178] CPU1: update cpu_power 1968128
[   10.126778] CPU2: Booted secondary processor
[   10.126789] CPU2: update cpu_power 1968128
[   10.130896] CPU3: Booted secondary processor
[   10.130906] CPU3: update cpu_power 1968128
[   10.130978] Brought up 4 CPUs
[   10.130999] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.131507] devtmpfs: initialized
[   10.136490] pinctrl core: initialized pinctrl subsystem
[   10.138939] NET: Registered protocol family 16
[   10.139195] script_sysfs_init success
[   10.139433] dump_class_init,806, success
[   10.139675] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.139695] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.140974] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.142027] DMA: preallocated 256 KiB pool for atomic allocations
[   10.142142] Serial: AMBA PL011 UART driver
[   10.142242] axp81x_board_init: axp regl_devs num = 23
[   10.142386] pll_audio-set_default_rate=24576000 success!
[   10.142405] pll_video0-set_default_rate=297000000 success!
[   10.142477] pll_video1-set_default_rate=297000000 success!
[   10.142539] pll_de-set_default_rate=297000000 success!
[   10.143252] de-set_default_source=pll_de success!
[   10.143258] de-set_default_rate=297000000 success!
[   10.143300] tcon0-set_default_source=pll_mipi success!
[   10.143330] tcon1-set_default_source=pll_video0 success!
[   10.143545] hdmi-set_default_source=pll_video0 success!
[   10.145762] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.145918] [sun50iw1p1_pinctrl_probe][838]
[   10.147361] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.147984] sunxi hwspinlock vbase:0xffffff800005c000
[   10.158223] bio: create slab <bio-0> at 0
[   10.158569] pwm module init!
[   10.159788] SCSI subsystem initialized
[   10.159911] usbcore: registered new interface driver usbfs
[   10.159945] usbcore: registered new interface driver hub
[   10.160006] usbcore: registered new device driver usb
[   10.160704] Linux video capture interface: v2.00
[   10.161146] [ARISC] :sunxi-arisc driver v1.10
[   10.168094] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.168341] Advanced Linux Sound Architecture Driver Initialized.
[   10.168692] NetLabel: Initializing
[   10.168698] NetLabel:  domain hash size = 128
[   10.168702] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.168740] NetLabel:  unlabeled traffic allowed by default
[   10.168904] [pm]aw_pm_init!
[   10.168971] rtc physical base = 0x0000000001f00000 .
[   10.169005] np name = /soc@01c00000/rtc@01f00000.
[   10.169011] base = ffffff800006e100, len = 4.
[   10.169016] pmu name: pmu0 .
[   10.169050] pmu0_enable = 0x1.
[   10.169055] pmux_id = 0x6.
[   10.169062] pmux_twi_id = 0x1.
[   10.169067] pmux_twi_addr = 0x34.
[   10.169071] pmu name: pmu1 .
[   10.169121] Warning: can not find np for pmu1.
[   10.169352] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.169512] after inited: sys_mask config = 0x4a55.
[   10.169535] Warning: can not find np for dynamic_standby_para.
[   10.169674] [pm]valid
[   10.169678] [pm]valid
[   10.169682] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.169887] Switching to clocksource arch_sys_counter_ool
[   10.187889] AppArmor: AppArmor Filesystem Enabled
[   10.194500] NET: Registered protocol family 2
[   10.195188] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.195429] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.195736] TCP: Hash tables configured (established 16384 bind 16384)
[   10.195823] TCP: reno registered
[   10.195833] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.195884] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.196135] NET: Registered protocol family 1
[   10.196460] RPC: Registered named UNIX socket transport module.
[   10.196466] RPC: Registered udp transport module.
[   10.196471] RPC: Registered tcp transport module.
[   10.196475] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.196650] Trying to unpack rootfs image as initramfs...
[   10.401059] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.401644] kvm [1]: Using HYP init bounce page @b7889000
[   10.402147] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.402573] kvm [1]: timer IRQ27
[   10.402589] kvm [1]: Hyp mode initialized successfully
[   10.404292] lock super standby defaultly!
[   10.404309] lookup_scene_lock_name: new scene lock super_standby
[   10.404314] scene_lock_init name=super_standby
[   10.404321] scene_lock: super_standby, type 5, count 1
[   10.404732] audit: initializing netlink socket (disabled)
[   10.404788] type=2000 audit(0.310:1): initialized
[   10.405469] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.405933] VFS: Disk quotas dquot_6.5.2
[   10.406035] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.407016] NFS: Registering the id_resolver key type
[   10.407069] Key type id_resolver registered
[   10.407074] Key type id_legacy registered
[   10.407085] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.407223] NTFS driver 2.1.30 [Flags: R/W].
[   10.407399] fuse init (API version 7.22)
[   10.407571] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.407996] msgmni has been set to 3973
[   10.408952] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.409033] io scheduler noop registered
[   10.409039] io scheduler deadline registered
[   10.409064] io scheduler cfq registered (default)
[   10.409650] [DISP]disp_module_init
[   10.410101] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.410109] [DISP] boot_disp:0x0
[   10.410715] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.410846] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.410977] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.412089] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.412095] [DISP] fb_base:0x0
[   10.429804] Console: switching to colour frame buffer device 160x45
[   10.444254] [DISP]disp_module_init finish
[   10.444671] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.444695] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.445052] console [ttyS0] enabled
[   10.445428] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.445864] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.446175] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.446458] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.446811] misc dump reg init
[   10.446965] [drm] Initialized drm 1.1.0 20060810
[   10.449110] brd: module loaded
[   10.451226] loop: module loaded
[   10.451504] sunxi-bt bt.27: Missing bt_power.
[   10.451512] sunxi-bt bt.27: bt_power_name ((null))
[   10.451520] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.451555] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.451598] sunxi-bt bt.27: clk not config
[   10.451669] sunxi-bt bt.27: block state already is 1
[   10.451856] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.451863] sunxi-wlan wlan.26: Missing wlan_power.
[   10.451869] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.451877] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.451893] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.451912] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.451930] sunxi-wlan wlan.26: clk not config
[   10.452637] WARNING: Get ephy clock is failed
[   10.453250] chipid-sunxi serial 140050374620201507cf
[   10.453344] PPP generic driver version 2.4.2
[   10.453497] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453607] get ehci0-controller drv_vbus_gpio is fail
[   10.453613] get ehci0-controller, regulator_io is no nocare
[   10.453652] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.453707] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453726] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.454084] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.465147] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.465215] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.465223] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.465230] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.465237] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.465243] usb usb1: SerialNumber: sunxi-ehci
[   10.465602] hub 1-0:1.0: USB hub found
[   10.465619] hub 1-0:1.0: 1 port detected
[   10.465756] scene_lock_init name=ehci_standby
[   10.465830] get ehci1-controller drv_vbus_gpio is fail
[   10.465836] get ehci1-controller, regulator_io is no nocare
[   10.465876] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.465925] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.465944] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.466183] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.484832] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.484876] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.484884] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.484891] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.484897] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.484903] usb usb2: SerialNumber: sunxi-ehci
[   10.485182] hub 2-0:1.0: USB hub found
[   10.485196] hub 2-0:1.0: 1 port detected
[   10.485318] scene_lock_init name=ehci_standby
[   10.485503] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.485649] get ohci0-controller drv_vbus_gpio is fail
[   10.485654] get ohci0-controller, regulator_io is no nocare
[   10.485693] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.485739] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.485755] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.485785] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.547841] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.547849] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.547855] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.547862] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.547868] usb usb3: SerialNumber: sunxi-ohci
[   10.548136] hub 3-0:1.0: USB hub found
[   10.548150] hub 3-0:1.0: 1 port detected
[   10.548267] scene_lock_init name=ohci_standby
[   10.548328] get ohci1-controller drv_vbus_gpio is fail
[   10.548333] get ohci1-controller, regulator_io is no nocare
[   10.548368] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.548407] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.548424] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.548449] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.606872] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.606880] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.606887] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.606894] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.606900] usb usb4: SerialNumber: sunxi-ohci
[   10.607164] hub 4-0:1.0: USB hub found
[   10.607177] hub 4-0:1.0: 1 port detected
[   10.607292] scene_lock_init name=ohci_standby
[   10.607591] usbcore: registered new interface driver usb-storage
[   10.607622] usbcore: registered new interface driver ums-alauda
[   10.607649] usbcore: registered new interface driver ums-cypress
[   10.607674] usbcore: registered new interface driver ums-datafab
[   10.607698] usbcore: registered new interface driver ums_eneub6250
[   10.607721] usbcore: registered new interface driver ums-freecom
[   10.607746] usbcore: registered new interface driver ums-isd200
[   10.607768] usbcore: registered new interface driver ums-jumpshot
[   10.607791] usbcore: registered new interface driver ums-karma
[   10.607815] usbcore: registered new interface driver ums-onetouch
[   10.607849] usbcore: registered new interface driver ums-realtek
[   10.607875] usbcore: registered new interface driver ums-sddr09
[   10.607899] usbcore: registered new interface driver ums-sddr55
[   10.607924] usbcore: registered new interface driver ums-usbat
[   10.608007] usbcore: registered new interface driver usbserial
[   10.608034] usbcore: registered new interface driver usbserial_generic
[   10.608058] usbserial: USB Serial support registered for generic
[   10.608264] mousedev: PS/2 mouse device common for all mice
[   10.608705] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.609636] get ctp_para failed, -1
[   10.609655] get node gsensor failed
[   10.609659] get sysconfig para erro!
[   10.609669] get node lightsensor failed
[   10.609672] get sysconfig para erro!
[   10.609682] get node gyroscopesensor failed
[   10.609685] get sysconfig para erro!
[   10.609694] get node compasssensor failed
[   10.609697] get sysconfig para erro!
[   10.609979] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.610000] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.610170] i2c /dev entries driver
[   10.652678] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.656150] sunxi budget cooling probe start !
[   10.656180] CPU freq cooling register Success
[   10.656200] CPU hotplug cooling register Success
[   10.656288] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.656296] CPU budget cooling register Success
[   10.656510] sunxi gpu cooling probe start !
[   10.656519] CPU gpu cooling register Success
[   10.657174] cpuidle: using governor ladder
[   10.657181] cpuidle: using governor menu
[   10.657918] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.657947] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.657956] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.657965] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.658016] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.658023] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.658605] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.658627] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.609723] wakeup gpio set err!get node ctp failed
[   10.662008] get sysconfig para erro!
[   10.671779] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.691469] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.691842] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.691867] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.691875] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.691882] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.691887] get() with no identifier
[   10.691891] get() with no identifier
[   10.691894] get() with no identifier
[   10.691900] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.691905] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.691911] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.692292] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.692306] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.692323] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.693112] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.693132] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.695516] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.697652] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.698466] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.699277] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.700089] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.700716] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.700759] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.703133] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.711138] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.730825] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.731521] ledtrig-cpu: registered to indicate activity on CPUs
[   10.731589] hidraw: raw HID events driver (C) Jiri Kosina
[   10.731728] usbcore: registered new interface driver usbhid
[   10.731733] usbhid: USB HID core driver
[   10.732595] usbcore: registered new interface driver snd-usb-audio
[   10.734580] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.735367] TCP: cubic registered
[   10.735377] Initializing XFRM netlink socket
[   10.735460] NET: Registered protocol family 10
[   10.736276] mip6: Mobile IPv6
[   10.736283] sit: IPv6 over IPv4 tunneling driver
[   10.736662] NET: Registered protocol family 17
[   10.736683] NET: Registered protocol family 15
[   10.736732] 8021q: 802.1Q VLAN Support v1.8
[   10.736786] Key type dns_resolver registered
[   10.736993] Registering SWP/SWPB emulation handler
[   10.737281] registered taskstats version 1
[   10.749261] Key type encrypted registered
[   10.749284] AppArmor: AppArmor sha1 policy hashing enabled
[   10.749727] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.749735] [DISP] boot_disp:0x0
[   10.749780] HDMI base address: ffffff8000b40000
[   10.750557] [HDMI] power vcc-hdmi-33
[   10.751080] [HDMI] cec support = 0
[   10.770145] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.772651] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.772726] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.772827] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.772853] mmc0: new high speed SDHC card at address aaaa
[   10.773251] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.775280]  mmcblk0: p1
[   10.776393] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.777202] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.777221] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.779613] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.781431] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.782239] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.783046] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.783851] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.784658] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.785465] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.786271] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.787078] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.787885] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.787902] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.788740] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.788757] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.861532] input: sunxi-ths as /devices/virtual/input/input2
[   10.861694] thermal thermal_zone0: failed to read out thermal zone 0
[   10.862118] ALSA device list:
[   10.862124]   #0: sndhdmi
[   10.862557] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.458995] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.145304] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.145318] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.145339] scene_lock_destroy name=ehci_standby
[   14.145352] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.145374] usb usb1: USB disconnect, device number 1
[   14.145930] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.145963] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.145971] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.145976] scene_lock_destroy name=ohci_standby
[   14.145984] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.146000] usb usb3: USB disconnect, device number 1
[   14.146367] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.146403] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.146412] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.146456] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.146480] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.149862] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.165000] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.165096] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.165104] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.165111] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.165118] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.165124] usb usb1: SerialNumber: sunxi-ehci
[   14.165588] hub 1-0:1.0: USB hub found
[   14.165608] hub 1-0:1.0: 1 port detected
[   14.165761] scene_lock_init name=ehci_standby
[   14.165770] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.165778] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.165831] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.165849] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.165892] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.228041] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.228058] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.228065] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.228071] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.228077] usb usb3: SerialNumber: sunxi-ohci
[   14.228539] hub 3-0:1.0: USB hub found
[   14.228557] hub 3-0:1.0: 1 port detected
[   14.228745] scene_lock_init name=ohci_standby
[   16.432977] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.816003] systemd[1]: System time before build time, advancing clock.
[   16.853225] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.853543] systemd[1]: Detected architecture arm64.
[   16.883597] systemd[1]: Set hostname to <cluster0>.
[   17.244264] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.264930] systemd[1]: Listening on Syslog Socket.
[   17.284426] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.304011] systemd[1]: Reached target Remote File Systems (Pre).
[   17.323674] systemd[1]: Reached target Remote File Systems.
[   17.343524] systemd[1]: Listening on udev Control Socket.
[   17.363101] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.382985] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.402422] systemd[1]: Reached target Swap.
[   17.422495] systemd[1]: Created slice System Slice.
[   17.442109] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.461595] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.481130] systemd[1]: Reached target Encrypted Volumes.
[   17.500927] systemd[1]: Listening on Journal Socket.
[   17.526193] systemd[1]: Starting Load Kernel Modules...
[   17.542129] systemd[1]: Mounting POSIX Message Queue File System...
[   17.562647] systemd[1]: Starting Nameserver information manager...
[   17.596044] systemd[1]: Starting Restore / save the current clock...
[   17.621153] systemd[1]: Starting Set console keymap...
[   17.640704] systemd[1]: Mounting Huge Pages File System...
[   17.661105] systemd[1]: Mounting Debug File System...
[   17.680283] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.699799] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.717562] systemd[1]: Listening on udev Kernel Socket.
[   17.727216] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.737376] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.748623] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.748922] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.749101] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.749280] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.750482] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.756811] systemd[1]: Reached target Paths.
[   17.777059] systemd[1]: Created slice User and Session Slice.
[   17.796201] systemd[1]: Reached target Slices.
[   17.808995] cfg80211: Calling CRDA to update world regulatory domain
[   17.820016] systemd[1]: Mounted Debug File System.
[   17.835727] systemd[1]: Mounted POSIX Message Queue File System.
[   17.855425] systemd[1]: Mounted Huge Pages File System.
[   17.879274] systemd[1]: Started Restore / save the current clock.
[   17.896274] systemd[1]: Started Set console keymap.
[   17.916631] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.926416] RTL871X: module init start
[   17.926432] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.926438] RTL871X: build time: Feb  8 2019 10:22:36
[   17.926442] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.926458] sunxi-wlan wlan.26: bus_index: 1
[   17.926627] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.944746] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.965491] systemd[1]: Started Nameserver information manager.
[   17.992120] systemd[1]: Time has been changed
[   18.034988] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.035105] RTL871X: module init ret=0
[   18.035120] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.037412] systemd[1]: Started Load Kernel Modules.
[   18.051823] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.072332] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.073168] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.073198] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.075633] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.077511] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.078332] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.079141] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.079956] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.080781] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.081616] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.082451] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.083286] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.084106] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.084137] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.085032] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.085055] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.102247] systemd[1]: Mounting Configuration File System...
[   18.123018] systemd[1]: Starting Apply Kernel Variables...
[   18.142698] systemd[1]: Mounting FUSE Control File System...
[   18.160286] systemd[1]: Reached target Network (Pre).
[   18.185185] systemd[1]: Starting udev Coldplug all Devices...
[   18.201655] systemd[1]: Starting Load/Save Random Seed...
[   18.221615] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.241842] systemd[1]: Mounted FUSE Control File System.
[   18.258764] systemd[1]: Mounted Configuration File System.
[   18.279935] systemd[1]: Started Apply Kernel Variables.
[   18.300831] systemd[1]: Started Load/Save Random Seed.
[   18.318857] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.394398] systemd[1]: Starting udev Kernel Device Manager...
[   18.416100] systemd[1]: Reached target Local File Systems (Pre).
[   18.438546] systemd[1]: Mounting /tmp...
[   18.458826] systemd[1]: Mounted /tmp.
[   18.475724] systemd[1]: Started udev Kernel Device Manager.
[   18.495862] systemd[1]: Started udev Coldplug all Devices.
[   18.537386] systemd[1]: Reached target Sound Card.
[   18.554094] systemd[1]: Reached target Local File Systems.
[   18.576410] systemd[1]: Starting Armbian ZRAM config...
[   18.595882] systemd[1]: Starting Set console font and keymap...
[   18.626592] systemd[1]: Starting Raise network interfaces...
[   18.669672] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.688847] cfg80211: World regulatory domain updated:
[   18.688865] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.688872] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.688877] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.688883] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.688888] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.688893] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.688898] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.688903] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.688909] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.694757] systemd[1]: Starting Journal Service...
[   18.839497] systemd[1]: Found device /dev/ttyS0.
[   18.846435] sunxi cedar version 0.1
[   18.846646] [cedar]: install start!!!
[   18.846790] ycy the get irq is 90
[   18.848503] ycy clk_bass_vir 0x18  is ffffff8000b6e018, the value:3006207
[   18.848522] ycy clk_bass_vir 0x13c  is ffffff8000b6e13c, the value:0
[   18.848527] ycy clk_bass_vir 0x64  is ffffff8000b6e064, the value:601810
[   18.848533] ycy clk_bass_vir 0x2c4  is ffffff8000b6e2c4, the value:601c10
[   18.848537] ycy clk_bass_vir 0x100  is ffffff8000b6e100, the value:0
[   18.848542] [cedar]: install end!!!
[   18.863698] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.894110] Registered IR keymap rc_map_sunxi
[   18.894709] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.894917] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.921359] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   18.933344] Driver for 1-wire Dallas network protocol.
[   18.973796] systemd[1]: Started Journal Service.
[   19.029942] [VFE]cci probe end cci_sel = 0!
[   19.030213] [VFE]cci_init end
[   19.107935] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   19.108692] IR MCE Keyboard/mouse protocol handler initialized
[   19.108705] IR NEC protocol handler initialized
[   19.109410] IR RC5(x) protocol handler initialized
[   19.109868] IR RC6 protocol handler initialized
[   19.110359] IR Sony protocol handler initialized
[   19.110361] IR SANYO protocol handler initialized
[   19.110718] IR JVC protocol handler initialized
[   19.129384] sunxi-bt bt.27: block state already is 1
[   19.145813] lirc_dev: IR Remote Control driver registered, major 248
[   19.148298] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   19.148314] IR LIRC bridge handler initialized
[   19.203856] systemd-journald[306]: Received request to flush runtime journal from PID 1
[   19.218864] [VFE]Welcome to Video Front End driver
[   19.219246] [VFE]csi probe end csi_sel = 0!
[   19.220606] [VFE]csi_init end
[   19.221230] [VFE]isp probe start isp_sel = 0!
[   19.222338] [ISP] isp platform_id = 3!
[   19.222366] [VFE]isp probe end isp_sel = 0!
[   19.222461] [VFE]sunxi_isp_platform_register end
[   19.223942] [VFE]mipi probe start mipi_sel = 0!
[   19.224018] [VFE]mipi probe end mipi_sel = 0!
[   19.224175] [VFE]mipi_init end
[   19.224191] [VFE]flash_init end
[   19.224706] [VFE]vfe_init end
[   19.278266] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.282770] zram: Created 6 device(s) ...
[   19.434082] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.457793] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.485348] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.513222] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.738097] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.738124] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1886604 kB
Buffers:            9304 kB
Cached:            56332 kB
SwapCached:            0 kB
Active:            33044 kB
Inactive:          52444 kB
Active(anon):      20064 kB
Inactive(anon):     2856 kB
Active(file):      12980 kB
Inactive(file):    49588 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         19940 kB
Mapped:            15180 kB
Shmem:              3028 kB
Slab:              23828 kB
SReclaimable:      10432 kB
SUnreclaim:        13396 kB
KernelStack:        1920 kB
PageTables:          604 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:     113660 kB
VmallocChunk:   251633532 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62493
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
/dev/zram0       49M  3.7M   42M   9% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  3.3M  1.1M  1.9M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
05:15:11: 1152MHz  0.00  36%  11%  16%   0%   8%   0%   36°C   23°C  0/7
05:15:11: 1152MHz  0.00  49%   6%   5%   1%  36%   0%   38°C   23°C  0/7
05:15:11: 1152MHz  0.00  28%   4%   1%   0%  21%   0%   36°C   23°C  0/7
05:15:12: 1152MHz  0.00  28%   4%   1%   1%  21%   0%   35°C   23°C  0/7
05:15:12: 1152MHz  0.08  31%   3%  23%   3%   1%   0%   35°C   23°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Wed Mar  6 07:04:43 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@armbian.com) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #2 SMP PREEMPT Fri Feb 8 10:23:10 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s19520 r8192 d21440 u49152
[    0.000000] pcpu-alloc: s19520 r8192 d21440 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1964644k/1964644k available, 116124k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000b59000 - 0xffffffc000be0c40   (   544 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000b58164   ( 11105 kB)
                     .data : 0xffffffc000be1000 - 0xffffffc000d50e48   (  1472 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.065176] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.065186] pid_max: default: 32768 minimum: 301
[   10.065278] Security Framework initialized
[   10.065325] AppArmor: AppArmor initialized
[   10.065361] Mount-cache hash table entries: 256
[   10.075712] Initializing cgroup subsys memory
[   10.075760] Initializing cgroup subsys devices
[   10.075767] Initializing cgroup subsys freezer
[   10.075773] Initializing cgroup subsys blkio
[   10.075779] Initializing cgroup subsys perf_event
[   10.075789] Initializing cgroup subsys hugetlb
[   10.075851] ftrace: allocating 28898 entries in 113 pages
[   10.109560] CPU0: update cpu_power 1968128
[   10.109582] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.110576] virtual base = 0xffffff800000a000.
[   10.110588] gicd_base = 0xffffff800000c000.
[   10.110593] gicc_base = 0xffffff800000e000.
[   10.111217] CPU1: Booted secondary processor
[   10.111244] CPU1: update cpu_power 1968128
[   10.113842] CPU2: Booted secondary processor
[   10.113853] CPU2: update cpu_power 1968128
[   10.117960] CPU3: Booted secondary processor
[   10.117971] CPU3: update cpu_power 1968128
[   10.118042] Brought up 4 CPUs
[   10.118063] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.118562] devtmpfs: initialized
[   10.123538] pinctrl core: initialized pinctrl subsystem
[   10.125957] NET: Registered protocol family 16
[   10.126215] script_sysfs_init success
[   10.126450] dump_class_init,806, success
[   10.126691] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.126711] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.127989] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.129041] DMA: preallocated 256 KiB pool for atomic allocations
[   10.129156] Serial: AMBA PL011 UART driver
[   10.129258] axp81x_board_init: axp regl_devs num = 23
[   10.129402] pll_audio-set_default_rate=24576000 success!
[   10.129421] pll_video0-set_default_rate=297000000 success!
[   10.129493] pll_video1-set_default_rate=297000000 success!
[   10.129554] pll_de-set_default_rate=297000000 success!
[   10.130267] de-set_default_source=pll_de success!
[   10.130273] de-set_default_rate=297000000 success!
[   10.130315] tcon0-set_default_source=pll_mipi success!
[   10.130345] tcon1-set_default_source=pll_video0 success!
[   10.130559] hdmi-set_default_source=pll_video0 success!
[   10.132767] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.132924] [sun50iw1p1_pinctrl_probe][838]
[   10.134370] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.134989] sunxi hwspinlock vbase:0xffffff800005c000
[   10.145218] bio: create slab <bio-0> at 0
[   10.145566] pwm module init!
[   10.146787] SCSI subsystem initialized
[   10.146910] usbcore: registered new interface driver usbfs
[   10.146943] usbcore: registered new interface driver hub
[   10.147009] usbcore: registered new device driver usb
[   10.147710] Linux video capture interface: v2.00
[   10.148149] [ARISC] :sunxi-arisc driver v1.10
[   10.155107] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.155359] Advanced Linux Sound Architecture Driver Initialized.
[   10.155708] NetLabel: Initializing
[   10.155713] NetLabel:  domain hash size = 128
[   10.155717] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.155757] NetLabel:  unlabeled traffic allowed by default
[   10.155923] [pm]aw_pm_init!
[   10.155987] rtc physical base = 0x0000000001f00000 .
[   10.156020] np name = /soc@01c00000/rtc@01f00000.
[   10.156026] base = ffffff800006e100, len = 4.
[   10.156031] pmu name: pmu0 .
[   10.156066] pmu0_enable = 0x1.
[   10.156072] pmux_id = 0x6.
[   10.156078] pmux_twi_id = 0x1.
[   10.156083] pmux_twi_addr = 0x34.
[   10.156087] pmu name: pmu1 .
[   10.156133] Warning: can not find np for pmu1.
[   10.156364] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.156525] after inited: sys_mask config = 0x4a55.
[   10.156547] Warning: can not find np for dynamic_standby_para.
[   10.156684] [pm]valid
[   10.156688] [pm]valid
[   10.156692] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.156895] Switching to clocksource arch_sys_counter_ool
[   10.174861] AppArmor: AppArmor Filesystem Enabled
[   10.181460] NET: Registered protocol family 2
[   10.182148] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.182389] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.182699] TCP: Hash tables configured (established 16384 bind 16384)
[   10.182783] TCP: reno registered
[   10.182793] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.182845] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.183099] NET: Registered protocol family 1
[   10.183428] RPC: Registered named UNIX socket transport module.
[   10.183434] RPC: Registered udp transport module.
[   10.183438] RPC: Registered tcp transport module.
[   10.183443] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.183617] Trying to unpack rootfs image as initramfs...
[   10.388007] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.388594] kvm [1]: Using HYP init bounce page @b788b000
[   10.389129] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.389553] kvm [1]: timer IRQ27
[   10.389568] kvm [1]: Hyp mode initialized successfully
[   10.391278] lock super standby defaultly!
[   10.391295] lookup_scene_lock_name: new scene lock super_standby
[   10.391300] scene_lock_init name=super_standby
[   10.391307] scene_lock: super_standby, type 5, count 1
[   10.391714] audit: initializing netlink socket (disabled)
[   10.391772] type=2000 audit(0.310:1): initialized
[   10.392454] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.392915] VFS: Disk quotas dquot_6.5.2
[   10.393017] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.393993] NFS: Registering the id_resolver key type
[   10.394037] Key type id_resolver registered
[   10.394041] Key type id_legacy registered
[   10.394053] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.394190] NTFS driver 2.1.30 [Flags: R/W].
[   10.394365] fuse init (API version 7.22)
[   10.394538] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.394964] msgmni has been set to 3973
[   10.395921] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.396003] io scheduler noop registered
[   10.396008] io scheduler deadline registered
[   10.396034] io scheduler cfq registered (default)
[   10.396622] [DISP]disp_module_init
[   10.397075] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.397083] [DISP] boot_disp:0x0
[   10.397679] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.397810] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.397941] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.399049] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.399056] [DISP] fb_base:0x0
[   10.416763] Console: switching to colour frame buffer device 160x45
[   10.431218] [DISP]disp_module_init finish
[   10.431641] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.431664] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.432023] console [ttyS0] enabled
[   10.432399] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.432838] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.433149] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.433434] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.433792] misc dump reg init
[   10.433947] [drm] Initialized drm 1.1.0 20060810
[   10.436091] brd: module loaded
[   10.438214] loop: module loaded
[   10.438494] sunxi-bt bt.27: Missing bt_power.
[   10.438502] sunxi-bt bt.27: bt_power_name ((null))
[   10.438510] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.438545] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.438587] sunxi-bt bt.27: clk not config
[   10.438657] sunxi-bt bt.27: block state already is 1
[   10.438845] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.438853] sunxi-wlan wlan.26: Missing wlan_power.
[   10.438859] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.438866] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.438881] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.438901] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.438918] sunxi-wlan wlan.26: clk not config
[   10.439622] WARNING: Get ephy clock is failed
[   10.440247] chipid-sunxi serial 140050374620201507cf
[   10.440340] PPP generic driver version 2.4.2
[   10.440492] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.440597] get ehci0-controller drv_vbus_gpio is fail
[   10.440603] get ehci0-controller, regulator_io is no nocare
[   10.440642] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.440696] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.440715] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.441076] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.452156] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.452225] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.452233] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.452240] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.452246] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.452253] usb usb1: SerialNumber: sunxi-ehci
[   10.452606] hub 1-0:1.0: USB hub found
[   10.452623] hub 1-0:1.0: 1 port detected
[   10.452760] scene_lock_init name=ehci_standby
[   10.452834] get ehci1-controller drv_vbus_gpio is fail
[   10.452839] get ehci1-controller, regulator_io is no nocare
[   10.452879] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.452928] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.452946] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.453187] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.471839] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.471881] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.471889] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.471896] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.471903] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.471909] usb usb2: SerialNumber: sunxi-ehci
[   10.472191] hub 2-0:1.0: USB hub found
[   10.472204] hub 2-0:1.0: 1 port detected
[   10.472325] scene_lock_init name=ehci_standby
[   10.472509] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.472653] get ohci0-controller drv_vbus_gpio is fail
[   10.472658] get ohci0-controller, regulator_io is no nocare
[   10.472696] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.472743] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.472758] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.472789] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.534848] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.534857] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.534864] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.534871] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.534877] usb usb3: SerialNumber: sunxi-ohci
[   10.535150] hub 3-0:1.0: USB hub found
[   10.535163] hub 3-0:1.0: 1 port detected
[   10.535279] scene_lock_init name=ohci_standby
[   10.535338] get ohci1-controller drv_vbus_gpio is fail
[   10.535343] get ohci1-controller, regulator_io is no nocare
[   10.535377] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.535416] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.535434] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.535461] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.593877] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.593885] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.593892] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.593898] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.593904] usb usb4: SerialNumber: sunxi-ohci
[   10.594166] hub 4-0:1.0: USB hub found
[   10.594179] hub 4-0:1.0: 1 port detected
[   10.594293] scene_lock_init name=ohci_standby
[   10.594593] usbcore: registered new interface driver usb-storage
[   10.594623] usbcore: registered new interface driver ums-alauda
[   10.594650] usbcore: registered new interface driver ums-cypress
[   10.594676] usbcore: registered new interface driver ums-datafab
[   10.594700] usbcore: registered new interface driver ums_eneub6250
[   10.594722] usbcore: registered new interface driver ums-freecom
[   10.594747] usbcore: registered new interface driver ums-isd200
[   10.594771] usbcore: registered new interface driver ums-jumpshot
[   10.594794] usbcore: registered new interface driver ums-karma
[   10.594818] usbcore: registered new interface driver ums-onetouch
[   10.594853] usbcore: registered new interface driver ums-realtek
[   10.594878] usbcore: registered new interface driver ums-sddr09
[   10.594902] usbcore: registered new interface driver ums-sddr55
[   10.594926] usbcore: registered new interface driver ums-usbat
[   10.595012] usbcore: registered new interface driver usbserial
[   10.595039] usbcore: registered new interface driver usbserial_generic
[   10.595062] usbserial: USB Serial support registered for generic
[   10.595266] mousedev: PS/2 mouse device common for all mice
[   10.595705] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.596638] get ctp_para failed, -1
[   10.596657] get node gsensor failed
[   10.596661] get sysconfig para erro!
[   10.596671] get node lightsensor failed
[   10.596674] get sysconfig para erro!
[   10.596684] get node gyroscopesensor failed
[   10.596687] get sysconfig para erro!
[   10.596696] get node compasssensor failed
[   10.596700] get sysconfig para erro!
[   10.596973] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.596995] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.597169] i2c /dev entries driver
[   10.639684] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.643148] sunxi budget cooling probe start !
[   10.643179] CPU freq cooling register Success
[   10.643198] CPU hotplug cooling register Success
[   10.643285] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.643293] CPU budget cooling register Success
[   10.643508] sunxi gpu cooling probe start !
[   10.643518] CPU gpu cooling register Success
[   10.644174] cpuidle: using governor ladder
[   10.644181] cpuidle: using governor menu
[   10.644928] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.644957] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.644965] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.644974] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.645023] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.645030] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.645617] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.645640] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.596725] wakeup gpio set err!get node ctp failed
[   10.649017] get sysconfig para erro!
[   10.658786] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.678477] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.678859] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.678886] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.678893] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.678900] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.678905] get() with no identifier
[   10.678909] get() with no identifier
[   10.678912] get() with no identifier
[   10.678918] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.678924] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.678929] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.679299] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.679322] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.679341] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.680120] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.680139] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.682522] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.684656] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.685470] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.686282] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687094] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687718] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.687761] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.690136] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.698145] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.717834] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.718534] ledtrig-cpu: registered to indicate activity on CPUs
[   10.718603] hidraw: raw HID events driver (C) Jiri Kosina
[   10.718746] usbcore: registered new interface driver usbhid
[   10.718750] usbhid: USB HID core driver
[   10.719608] usbcore: registered new interface driver snd-usb-audio
[   10.721614] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.722414] TCP: cubic registered
[   10.722423] Initializing XFRM netlink socket
[   10.722504] NET: Registered protocol family 10
[   10.723319] mip6: Mobile IPv6
[   10.723327] sit: IPv6 over IPv4 tunneling driver
[   10.723702] NET: Registered protocol family 17
[   10.723724] NET: Registered protocol family 15
[   10.723772] 8021q: 802.1Q VLAN Support v1.8
[   10.723832] Key type dns_resolver registered
[   10.724038] Registering SWP/SWPB emulation handler
[   10.724326] registered taskstats version 1
[   10.736255] Key type encrypted registered
[   10.736279] AppArmor: AppArmor sha1 policy hashing enabled
[   10.736719] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.736726] [DISP] boot_disp:0x0
[   10.736774] HDMI base address: ffffff8000b40000
[   10.737541] [HDMI] power vcc-hdmi-33
[   10.738067] [HDMI] cec support = 0
[   10.757143] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.759638] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.759713] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.759818] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.759843] mmc0: new high speed SDHC card at address aaaa
[   10.760242] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.762271]  mmcblk0: p1
[   10.763388] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.764195] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.764213] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.766605] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.768423] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.769232] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.770038] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.770843] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771647] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772454] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.773261] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774068] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774875] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774892] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.775725] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.775741] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.848530] input: sunxi-ths as /devices/virtual/input/input2
[   10.848697] thermal thermal_zone0: failed to read out thermal zone 0
[   10.849120] ALSA device list:
[   10.849126]   #0: sndhdmi
[   10.849560] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.446004] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.132311] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.132327] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.132348] scene_lock_destroy name=ehci_standby
[   14.132362] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.132383] usb usb1: USB disconnect, device number 1
[   14.132936] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.132971] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.132979] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.132985] scene_lock_destroy name=ohci_standby
[   14.132993] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.133009] usb usb3: USB disconnect, device number 1
[   14.133381] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.133418] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.133426] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.133472] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.133499] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.136853] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.152006] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.152118] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.152126] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.152133] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.152139] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.152146] usb usb1: SerialNumber: sunxi-ehci
[   14.152623] hub 1-0:1.0: USB hub found
[   14.152642] hub 1-0:1.0: 1 port detected
[   14.152792] scene_lock_init name=ehci_standby
[   14.152800] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.152809] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.152859] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.152878] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.152922] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.215046] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.215062] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.215069] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.215075] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.215082] usb usb3: SerialNumber: sunxi-ohci
[   14.215543] hub 3-0:1.0: USB hub found
[   14.215562] hub 3-0:1.0: 1 port detected
[   14.215741] scene_lock_init name=ohci_standby
[   16.468457] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.852287] systemd[1]: System time before build time, advancing clock.
[   16.889303] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.889613] systemd[1]: Detected architecture arm64.
[   16.919801] systemd[1]: Set hostname to <cluster0>.
[   17.281976] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.301179] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.320926] systemd[1]: Created slice System Slice.
[   17.340597] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.360116] systemd[1]: Listening on Journal Socket.
[   17.381392] systemd[1]: Starting Set console keymap...
[   17.411117] systemd[1]: Starting Load Kernel Modules...
[   17.431484] systemd[1]: Mounting POSIX Message Queue File System...
[   17.451363] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.479919] systemd[1]: Mounting Huge Pages File System...
[   17.497917] systemd[1]: Reached target Remote File Systems (Pre).
[   17.517535] systemd[1]: Reached target Remote File Systems.
[   17.548581] systemd[1]: Starting Restore / save the current clock...
[   17.566904] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.586523] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.606475] systemd[1]: Listening on udev Control Socket.
[   17.625726] systemd[1]: Reached target Swap.
[   17.632996] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.633260] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.633399] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.633538] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.634619] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.647369] systemd[1]: Starting Nameserver information manager...
[   17.665510] systemd[1]: Created slice User and Session Slice.
[   17.685014] systemd[1]: Reached target Slices.
[   17.694892] cfg80211: Calling CRDA to update world regulatory domain
[   17.704648] systemd[1]: Listening on Syslog Socket.
[   17.726324] systemd[1]: Mounting Debug File System...
[   17.744143] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.765680] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.783527] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.802903] systemd[1]: Reached target Paths.
[   17.814761] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.820180] RTL871X: module init start
[   17.820201] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.820206] RTL871X: build time: Feb  8 2019 10:22:36
[   17.820211] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.820227] sunxi-wlan wlan.26: bus_index: 1
[   17.820384] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.822571] systemd[1]: Reached target Encrypted Volumes.
[   17.842171] systemd[1]: Listening on udev Kernel Socket.
[   17.868786] systemd[1]: Mounted Debug File System.
[   17.881545] systemd[1]: Mounted POSIX Message Queue File System.
[   17.901152] systemd[1]: Mounted Huge Pages File System.
[   17.921493] systemd[1]: Started Set console keymap.
[   17.928734] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.928836] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   17.928952] RTL871X: module init ret=0
[   17.940436] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.941877] systemd[1]: Started Load Kernel Modules.
[   17.960874] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.961261] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.961698] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.961719] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.964134] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.965952] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   17.966761] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.967567] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.968372] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.969176] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.969986] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.970793] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.971599] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.972406] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.972423] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.973256] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   17.973273] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   17.980910] systemd[1]: Started Restore / save the current clock.
[   18.003344] systemd[1]: Started Remount Root and Kernel File Systems.
[   18.021749] systemd[1]: Started Nameserver information manager.
[   18.042296] systemd[1]: Time has been changed
[   18.135066] systemd[1]: Reached target Network (Pre).
[   18.159411] systemd[1]: Starting Load/Save Random Seed...
[   18.180429] systemd[1]: Starting udev Coldplug all Devices...
[   18.198636] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.218497] systemd[1]: Starting Apply Kernel Variables...
[   18.224910] systemd[1]: Mounting Configuration File System...
[   18.247918] systemd[1]: Mounting FUSE Control File System...
[   18.267860] systemd[1]: Mounted FUSE Control File System.
[   18.285007] systemd[1]: Mounted Configuration File System.
[   18.306034] systemd[1]: Started Load/Save Random Seed.
[   18.327077] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.345146] systemd[1]: Started Apply Kernel Variables.
[   18.420231] systemd[1]: Reached target Local File Systems (Pre).
[   18.447201] systemd[1]: Mounting /tmp...
[   18.464242] systemd[1]: Starting udev Kernel Device Manager...
[   18.485175] systemd[1]: Mounted /tmp.
[   18.502321] systemd[1]: Started udev Coldplug all Devices.
[   18.536816] systemd[1]: Reached target Local File Systems.
[   18.562796] systemd[1]: Starting Set console font and keymap...
[   18.583454] systemd[1]: Starting Raise network interfaces...
[   18.602780] systemd[1]: Starting Armbian ZRAM config...
[   18.660205] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.681875] systemd[1]: Starting Journal Service...
[   18.699528] systemd[1]: Started udev Kernel Device Manager.
[   18.786651] sunxi cedar version 0.1
[   18.786863] [cedar]: install start!!!
[   18.786991] ycy the get irq is 90
[   18.787414] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.787426] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.787432] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.787438] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.787443] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.787447] [cedar]: install end!!!
[   18.813260] systemd[1]: Found device /dev/ttyS0.
[   18.874127] Registered IR keymap rc_map_sunxi
[   18.874642] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.875039] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.882815] systemd[1]: Reached target Sound Card.
[   18.907688] IR RC5(x) protocol handler initialized
[   18.908729] IR NEC protocol handler initialized
[   18.920585] [VFE]cci probe end cci_sel = 0!
[   18.920878] [VFE]cci_init end
[   18.944387] systemd[1]: Started Journal Service.
[   18.982653] Driver for 1-wire Dallas network protocol.
[   19.071372] lirc_dev: IR Remote Control driver registered, major 248
[   19.075917] IR RC6 protocol handler initialized
[   19.075920] IR SANYO protocol handler initialized
[   19.076826] IR Sony protocol handler initialized
[   19.077917] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   19.078196] IR MCE Keyboard/mouse protocol handler initialized
[   19.079078] IR JVC protocol handler initialized
[   19.079362] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   19.079365] IR LIRC bridge handler initialized
[   19.122726] systemd-journald[313]: Received request to flush runtime journal from PID 1
[   19.151414] sunxi-bt bt.27: block state already is 1
[   19.174614] [VFE]Welcome to Video Front End driver
[   19.175061] [VFE]csi probe end csi_sel = 0!
[   19.177099] [VFE]csi_init end
[   19.177680] [VFE]isp probe start isp_sel = 0!
[   19.182708] [ISP] isp platform_id = 3!
[   19.182736] [VFE]isp probe end isp_sel = 0!
[   19.182826] [VFE]sunxi_isp_platform_register end
[   19.183311] [VFE]mipi probe start mipi_sel = 0!
[   19.183337] [VFE]mipi probe end mipi_sel = 0!
[   19.183383] [VFE]mipi_init end
[   19.183390] [VFE]flash_init end
[   19.183699] [VFE]vfe_init end
[   19.316106] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.328535] zram: Created 6 device(s) ...
[   19.486606] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.510342] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.536738] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.561471] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.774999] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.775033] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035016 kB
MemFree:         1881408 kB
Buffers:            9384 kB
Cached:            58272 kB
SwapCached:            0 kB
Active:            36360 kB
Inactive:          53968 kB
Active(anon):      22740 kB
Inactive(anon):     2840 kB
Active(file):      13620 kB
Inactive(file):    51128 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017504 kB
SwapFree:        1017504 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         22504 kB
Mapped:            16552 kB
Shmem:              3028 kB
Slab:              23952 kB
SUnreclaim:        13520 kB
KernelStack:        1888 kB
PageTables:          552 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035012 kB
Committed_AS:     116980 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633496 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5606
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
/dev/mmcblk0p1   15G  931M   14G   7% /
tmpfs           994M     0  994M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           994M     0  994M   0% /sys/fs/cgroup
tmpfs           994M  4.0K  994M   1% /tmp
/dev/zram0       49M  3.9M   42M   9% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M  3.5M  1.2M    2M         /var/log
/dev/zram1             248.4M    4K   78B    4K         [SWAP]
/dev/zram2             248.4M    4K   78B    4K         [SWAP]
/dev/zram3             248.4M    4K   78B    4K         [SWAP]
/dev/zram4             248.4M    4K   78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
07:04:46: 1152MHz  0.00  35%  11%  16%   0%   7%   0%   46°C   31°C  0/7
07:04:46: 1152MHz  0.00  44%   8%   3%   2%  31%   0%   44°C   31°C  0/7
07:04:47: 1152MHz  0.00  27%   3%   0%   0%  22%   0%   44°C   31°C  0/7
07:04:47: 1152MHz  0.00  28%   4%   6%   1%  16%   0%   43°C   31°C  0/7
07:04:47: 1152MHz  0.16  31%   4%  25%   1%   0%   0%   43°C   31°C  0/7
Wed Mar  6 07:37:06 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.065381] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.065390] pid_max: default: 32768 minimum: 301
[   10.065485] Security Framework initialized
[   10.065533] AppArmor: AppArmor initialized
[   10.065568] Mount-cache hash table entries: 256
[   10.075921] Initializing cgroup subsys memory
[   10.075967] Initializing cgroup subsys devices
[   10.075975] Initializing cgroup subsys freezer
[   10.075981] Initializing cgroup subsys blkio
[   10.075987] Initializing cgroup subsys perf_event
[   10.075997] Initializing cgroup subsys hugetlb
[   10.076057] ftrace: allocating 28898 entries in 113 pages
[   10.109796] CPU0: update cpu_power 1968128
[   10.109817] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.110795] virtual base = 0xffffff800000a000.
[   10.110808] gicd_base = 0xffffff800000c000.
[   10.110812] gicc_base = 0xffffff800000e000.
[   10.111440] CPU1: Booted secondary processor
[   10.111465] CPU1: update cpu_power 1968128
[   10.114065] CPU2: Booted secondary processor
[   10.114075] CPU2: update cpu_power 1968128
[   10.118185] CPU3: Booted secondary processor
[   10.118195] CPU3: update cpu_power 1968128
[   10.118267] Brought up 4 CPUs
[   10.118288] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.118790] devtmpfs: initialized
[   10.123812] pinctrl core: initialized pinctrl subsystem
[   10.126256] NET: Registered protocol family 16
[   10.126502] script_sysfs_init success
[   10.126736] dump_class_init,806, success
[   10.126969] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.126989] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.128268] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.129262] DMA: preallocated 256 KiB pool for atomic allocations
[   10.129377] Serial: AMBA PL011 UART driver
[   10.129471] axp81x_board_init: axp regl_devs num = 23
[   10.129627] pll_audio-set_default_rate=24576000 success!
[   10.129646] pll_video0-set_default_rate=297000000 success!
[   10.129715] pll_video1-set_default_rate=297000000 success!
[   10.129777] pll_de-set_default_rate=297000000 success!
[   10.130495] de-set_default_source=pll_de success!
[   10.130501] de-set_default_rate=297000000 success!
[   10.130546] tcon0-set_default_source=pll_mipi success!
[   10.130576] tcon1-set_default_source=pll_video0 success!
[   10.130791] hdmi-set_default_source=pll_video0 success!
[   10.133018] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.133181] [sun50iw1p1_pinctrl_probe][838]
[   10.134613] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.135228] sunxi hwspinlock vbase:0xffffff800005c000
[   10.145410] bio: create slab <bio-0> at 0
[   10.145795] pwm module init!
[   10.147009] SCSI subsystem initialized
[   10.147126] usbcore: registered new interface driver usbfs
[   10.147162] usbcore: registered new interface driver hub
[   10.147233] usbcore: registered new device driver usb
[   10.147936] Linux video capture interface: v2.00
[   10.148395] [ARISC] :sunxi-arisc driver v1.10
[   10.155304] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.155552] Advanced Linux Sound Architecture Driver Initialized.
[   10.155912] NetLabel: Initializing
[   10.155917] NetLabel:  domain hash size = 128
[   10.155921] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.155963] NetLabel:  unlabeled traffic allowed by default
[   10.156123] [pm]aw_pm_init!
[   10.156186] rtc physical base = 0x0000000001f00000 .
[   10.156219] np name = /soc@01c00000/rtc@01f00000.
[   10.156225] base = ffffff800006e100, len = 4.
[   10.156230] pmu name: pmu0 .
[   10.156265] pmu0_enable = 0x1.
[   10.156271] pmux_id = 0x6.
[   10.156278] pmux_twi_id = 0x1.
[   10.156283] pmux_twi_addr = 0x34.
[   10.156287] pmu name: pmu1 .
[   10.156334] Warning: can not find np for pmu1.
[   10.156563] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.156723] after inited: sys_mask config = 0x4a55.
[   10.156745] Warning: can not find np for dynamic_standby_para.
[   10.156863] [pm]valid
[   10.156867] [pm]valid
[   10.156871] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.157066] Switching to clocksource arch_sys_counter_ool
[   10.175014] AppArmor: AppArmor Filesystem Enabled
[   10.181125] NET: Registered protocol family 2
[   10.181804] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.182045] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.182361] TCP: Hash tables configured (established 16384 bind 16384)
[   10.182444] TCP: reno registered
[   10.182455] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.182506] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.182775] NET: Registered protocol family 1
[   10.183099] RPC: Registered named UNIX socket transport module.
[   10.183105] RPC: Registered udp transport module.
[   10.183109] RPC: Registered tcp transport module.
[   10.183113] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.183286] Trying to unpack rootfs image as initramfs...
[   10.387735] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.388321] kvm [1]: Using HYP init bounce page @b789e000
[   10.388824] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.389237] kvm [1]: timer IRQ27
[   10.389250] kvm [1]: Hyp mode initialized successfully
[   10.390912] lock super standby defaultly!
[   10.390928] lookup_scene_lock_name: new scene lock super_standby
[   10.390933] scene_lock_init name=super_standby
[   10.390939] scene_lock: super_standby, type 5, count 1
[   10.391347] audit: initializing netlink socket (disabled)
[   10.391398] type=2000 audit(0.310:1): initialized
[   10.392085] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.392559] VFS: Disk quotas dquot_6.5.2
[   10.392661] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.393648] NFS: Registering the id_resolver key type
[   10.393699] Key type id_resolver registered
[   10.393703] Key type id_legacy registered
[   10.393715] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.393855] NTFS driver 2.1.30 [Flags: R/W].
[   10.394032] fuse init (API version 7.22)
[   10.394208] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.394636] msgmni has been set to 3973
[   10.395627] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.395707] io scheduler noop registered
[   10.395713] io scheduler deadline registered
[   10.395746] io scheduler cfq registered (default)
[   10.396319] [DISP]disp_module_init
[   10.396768] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.396775] [DISP] boot_disp:0x0
[   10.397372] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.397505] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.397635] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.398743] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.398749] [DISP] fb_base:0x0
[   10.416451] Console: switching to colour frame buffer device 160x45
[   10.430908] [DISP]disp_module_init finish
[   10.431327] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.431350] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.431708] console [ttyS0] enabled
[   10.432089] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.432318] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.432618] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.433074] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.433430] misc dump reg init
[   10.433582] [drm] Initialized drm 1.1.0 20060810
[   10.435695] brd: module loaded
[   10.437831] loop: module loaded
[   10.438102] sunxi-bt bt.27: Missing bt_power.
[   10.438110] sunxi-bt bt.27: bt_power_name ((null))
[   10.438117] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.438150] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.438191] sunxi-bt bt.27: clk not config
[   10.438261] sunxi-bt bt.27: block state already is 1
[   10.438442] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.438449] sunxi-wlan wlan.26: Missing wlan_power.
[   10.438456] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.438463] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.438477] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.438496] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.438514] sunxi-wlan wlan.26: clk not config
[   10.439216] WARNING: Get ephy clock is failed
[   10.439831] chipid-sunxi serial 140050374620201507cf
[   10.439928] PPP generic driver version 2.4.2
[   10.440080] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.440188] get ehci0-controller drv_vbus_gpio is fail
[   10.440194] get ehci0-controller, regulator_io is no nocare
[   10.440233] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.440287] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.440306] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.440680] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.452330] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.452412] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.452420] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.452427] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.452433] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.452439] usb usb1: SerialNumber: sunxi-ehci
[   10.452771] hub 1-0:1.0: USB hub found
[   10.452787] hub 1-0:1.0: 1 port detected
[   10.452926] scene_lock_init name=ehci_standby
[   10.453000] get ehci1-controller drv_vbus_gpio is fail
[   10.453005] get ehci1-controller, regulator_io is no nocare
[   10.453047] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.453093] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453109] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.453353] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.472012] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.472056] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.472063] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.472070] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.472076] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.472083] usb usb2: SerialNumber: sunxi-ehci
[   10.472358] hub 2-0:1.0: USB hub found
[   10.472371] hub 2-0:1.0: 1 port detected
[   10.472489] scene_lock_init name=ehci_standby
[   10.472674] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.472817] get ohci0-controller drv_vbus_gpio is fail
[   10.472822] get ohci0-controller, regulator_io is no nocare
[   10.472862] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.472909] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.472925] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.472954] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.535020] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.535028] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.535035] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.535042] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.535048] usb usb3: SerialNumber: sunxi-ohci
[   10.535333] hub 3-0:1.0: USB hub found
[   10.535347] hub 3-0:1.0: 1 port detected
[   10.535464] scene_lock_init name=ohci_standby
[   10.535533] get ohci1-controller drv_vbus_gpio is fail
[   10.535538] get ohci1-controller, regulator_io is no nocare
[   10.535573] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.535614] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.535629] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.535655] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.594081] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.594090] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.594097] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.594104] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.594110] usb usb4: SerialNumber: sunxi-ohci
[   10.594393] hub 4-0:1.0: USB hub found
[   10.594407] hub 4-0:1.0: 1 port detected
[   10.594521] scene_lock_init name=ohci_standby
[   10.594825] usbcore: registered new interface driver usb-storage
[   10.594857] usbcore: registered new interface driver ums-alauda
[   10.594881] usbcore: registered new interface driver ums-cypress
[   10.594906] usbcore: registered new interface driver ums-datafab
[   10.594932] usbcore: registered new interface driver ums_eneub6250
[   10.594956] usbcore: registered new interface driver ums-freecom
[   10.594980] usbcore: registered new interface driver ums-isd200
[   10.595003] usbcore: registered new interface driver ums-jumpshot
[   10.595030] usbcore: registered new interface driver ums-karma
[   10.595054] usbcore: registered new interface driver ums-onetouch
[   10.595086] usbcore: registered new interface driver ums-realtek
[   10.595111] usbcore: registered new interface driver ums-sddr09
[   10.595138] usbcore: registered new interface driver ums-sddr55
[   10.595163] usbcore: registered new interface driver ums-usbat
[   10.595249] usbcore: registered new interface driver usbserial
[   10.595276] usbcore: registered new interface driver usbserial_generic
[   10.595298] usbserial: USB Serial support registered for generic
[   10.595491] mousedev: PS/2 mouse device common for all mice
[   10.595949] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.596775] get ctp_para failed, -1
[   10.596795] get node gsensor failed
[   10.596799] get sysconfig para erro!
[   10.596809] get node lightsensor failed
[   10.596812] get sysconfig para erro!
[   10.596821] get node gyroscopesensor failed
[   10.596825] get sysconfig para erro!
[   10.596834] get node compasssensor failed
[   10.596837] get sysconfig para erro!
[   10.597129] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.597149] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.597311] i2c /dev entries driver
[   10.639855] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.643310] sunxi budget cooling probe start !
[   10.643343] CPU freq cooling register Success
[   10.643363] CPU hotplug cooling register Success
[   10.643453] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.643461] CPU budget cooling register Success
[   10.643671] sunxi gpu cooling probe start !
[   10.643681] CPU gpu cooling register Success
[   10.644336] cpuidle: using governor ladder
[   10.644344] cpuidle: using governor menu
[   10.645092] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.645121] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.645130] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.645138] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.645186] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.645193] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.645795] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.645817] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.596864] wakeup gpio set err!get node ctp failed
[   10.649179] get sysconfig para erro!
[   10.658961] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.678651] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.679033] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.679059] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.679066] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.679073] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.679078] get() with no identifier
[   10.679082] get() with no identifier
[   10.679085] get() with no identifier
[   10.679091] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.679097] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.679103] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.679453] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.679471] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.679477] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.680293] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.680313] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.682697] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.684837] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.685651] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.686463] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687274] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687898] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.687942] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.690316] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.698320] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.718008] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.718712] ledtrig-cpu: registered to indicate activity on CPUs
[   10.718783] hidraw: raw HID events driver (C) Jiri Kosina
[   10.718908] usbcore: registered new interface driver usbhid
[   10.718913] usbhid: USB HID core driver
[   10.719814] usbcore: registered new interface driver snd-usb-audio
[   10.721886] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.722696] TCP: cubic registered
[   10.722706] Initializing XFRM netlink socket
[   10.722789] NET: Registered protocol family 10
[   10.723589] mip6: Mobile IPv6
[   10.723597] sit: IPv6 over IPv4 tunneling driver
[   10.723972] NET: Registered protocol family 17
[   10.723994] NET: Registered protocol family 15
[   10.724038] 8021q: 802.1Q VLAN Support v1.8
[   10.724083] Key type dns_resolver registered
[   10.724288] Registering SWP/SWPB emulation handler
[   10.724578] registered taskstats version 1
[   10.736579] Key type encrypted registered
[   10.736602] AppArmor: AppArmor sha1 policy hashing enabled
[   10.737047] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.737055] [DISP] boot_disp:0x0
[   10.737101] HDMI base address: ffffff8000b40000
[   10.737893] [HDMI] power vcc-hdmi-33
[   10.738414] [HDMI] cec support = 0
[   10.757311] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.759810] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.759885] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.759988] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.760013] mmc0: new high speed SDHC card at address aaaa
[   10.760428] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.762452]  mmcblk0: p1
[   10.763559] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.764368] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.764386] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.766779] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.768596] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.769405] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.770212] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771016] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771821] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772628] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.773434] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774241] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775048] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775065] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.775899] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.775915] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.848865] input: sunxi-ths as /devices/virtual/input/input2
[   10.849019] thermal thermal_zone0: failed to read out thermal zone 0
[   10.849433] ALSA device list:
[   10.849439]   #0: sndhdmi
[   10.849882] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.446183] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.132489] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.132504] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.132524] scene_lock_destroy name=ehci_standby
[   14.132538] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.132560] usb usb1: USB disconnect, device number 1
[   14.134522] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.134568] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.134577] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.134583] scene_lock_destroy name=ohci_standby
[   14.134593] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.134614] usb usb3: USB disconnect, device number 1
[   14.135042] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.135076] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.135085] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.135131] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.135156] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.138037] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.152194] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.152290] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.152299] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.152306] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.152312] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.152318] usb usb1: SerialNumber: sunxi-ehci
[   14.152779] hub 1-0:1.0: USB hub found
[   14.152798] hub 1-0:1.0: 1 port detected
[   14.152949] scene_lock_init name=ehci_standby
[   14.152957] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.152965] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.153017] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.153034] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.153078] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.215220] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.215235] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.215242] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.215248] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.215255] usb usb3: SerialNumber: sunxi-ohci
[   14.215715] hub 3-0:1.0: USB hub found
[   14.215735] hub 3-0:1.0: 1 port detected
[   14.215923] scene_lock_init name=ohci_standby
[   16.437860] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.820795] systemd[1]: System time before build time, advancing clock.
[   16.857791] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.858096] systemd[1]: Detected architecture arm64.
[   16.890437] systemd[1]: Set hostname to <cluster0>.
[   17.252862] systemd[1]: Listening on udev Control Socket.
[   17.271573] systemd[1]: Reached target Encrypted Volumes.
[   17.291315] systemd[1]: Listening on Syslog Socket.
[   17.310870] systemd[1]: Reached target Remote File Systems (Pre).
[   17.330631] systemd[1]: Listening on udev Kernel Socket.
[   17.350314] systemd[1]: Reached target Swap.
[   17.370031] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.389968] systemd[1]: Created slice User and Session Slice.
[   17.409367] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.429240] systemd[1]: Created slice System Slice.
[   17.448657] systemd[1]: Reached target Slices.
[   17.468467] systemd[1]: Listening on Journal Socket.
[   17.489790] systemd[1]: Starting Nameserver information manager...
[   17.509842] systemd[1]: Mounting Huge Pages File System...
[   17.529434] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.548002] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.550006] systemd[1]: Starting Set console keymap...
[   17.571003] systemd[1]: Starting Restore / save the current clock...
[   17.588832] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.606923] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.631703] systemd[1]: Starting Load Kernel Modules...
[   17.645903] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.665349] systemd[1]: Reached target Remote File Systems.
[   17.687081] systemd[1]: Mounting Debug File System...
[   17.704911] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.724300] systemd[1]: Reached target Paths.
[   17.745861] systemd[1]: Mounting POSIX Message Queue File System...
[   17.764223] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.783467] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.817580] systemd[1]: Mounted Debug File System.
[   17.832582] systemd[1]: Mounted POSIX Message Queue File System.
[   17.849666] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.849975] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.850156] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.850330] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.851539] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.852354] systemd[1]: Mounted Huge Pages File System.
[   17.876290] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.893336] systemd[1]: Started Set console keymap.
[   17.909633] cfg80211: Calling CRDA to update world regulatory domain
[   17.912655] systemd[1]: Started Restore / save the current clock.
[   17.932180] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.953930] systemd[1]: Started Nameserver information manager.
[   17.973567] systemd[1]: Time has been changed
[   18.026867] RTL871X: module init start
[   18.026885] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.026890] RTL871X: build time: Feb  8 2019 10:22:36
[   18.026895] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.026911] sunxi-wlan wlan.26: bus_index: 1
[   18.027074] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.075710] systemd[1]: Reached target Network (Pre).
[   18.100694] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.127499] systemd[1]: Starting udev Coldplug all Devices...
[   18.135543] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.135664] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.135815] RTL871X: module init ret=0
[   18.147282] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.149460] systemd[1]: Starting Load/Save Random Seed...
[   18.167738] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.167993] systemd[1]: Started Load Kernel Modules.
[   18.168595] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.168636] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.171105] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.173026] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.173866] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.174693] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.175522] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.176388] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.177250] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.178120] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.178966] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.179811] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.179857] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.180779] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.180803] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.187882] systemd[1]: Started Load/Save Random Seed.
[   18.207645] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.272594] systemd[1]: Starting udev Kernel Device Manager...
[   18.295185] systemd[1]: Reached target Local File Systems (Pre).
[   18.317779] systemd[1]: Mounting /tmp...
[   18.337173] systemd[1]: Mounting Configuration File System...
[   18.356734] systemd[1]: Starting Apply Kernel Variables...
[   18.364759] systemd[1]: Mounting FUSE Control File System...
[   18.386028] systemd[1]: Mounted FUSE Control File System.
[   18.403619] systemd[1]: Mounted Configuration File System.
[   18.423095] systemd[1]: Mounted /tmp.
[   18.443454] systemd[1]: Started udev Kernel Device Manager.
[   18.463215] systemd[1]: Started udev Coldplug all Devices.
[   18.483786] systemd[1]: Started Apply Kernel Variables.
[   18.562638] systemd[1]: Reached target Sound Card.
[   18.568856] cfg80211: World regulatory domain updated:
[   18.568877] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.568884] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.568889] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.568894] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.568900] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.568905] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.568910] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.568915] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.568920] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.580544] systemd[1]: Reached target Local File Systems.
[   18.607238] systemd[1]: Starting Raise network interfaces...
[   18.632254] systemd[1]: Starting Armbian ZRAM config...
[   18.637412] sunxi cedar version 0.1
[   18.637617] [cedar]: install start!!!
[   18.637760] ycy the get irq is 90
[   18.638197] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.638200] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.638203] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.638205] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.638207] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.638208] [cedar]: install end!!!
[   18.660304] systemd[1]: Starting Set console font and keymap...
[   18.775489] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.796784] [VFE]cci probe end cci_sel = 0!
[   18.797140] [VFE]cci_init end
[   18.800271] systemd[1]: Starting Journal Service...
[   18.860865] systemd[1]: Found device /dev/ttyS0.
[   18.933178] Driver for 1-wire Dallas network protocol.
[   18.934723] Registered IR keymap rc_map_sunxi
[   18.935208] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.935403] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.996850] lirc_dev: IR Remote Control driver registered, major 248
[   19.016417] IR RC5(x) protocol handler initialized
[   19.017839] IR SANYO protocol handler initialized
[   19.017842] IR RC6 protocol handler initialized
[   19.018768] IR Sony protocol handler initialized
[   19.019587] IR NEC protocol handler initialized
[   19.019972] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   19.020261] IR MCE Keyboard/mouse protocol handler initialized
[   19.021708] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   19.021727] IR LIRC bridge handler initialized
[   19.021741] IR JVC protocol handler initialized
[   19.078009] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   19.081154] [VFE]Welcome to Video Front End driver
[   19.084185] [VFE]csi probe end csi_sel = 0!
[   19.085237] [VFE]csi_init end
[   19.086260] [VFE]isp probe start isp_sel = 0!
[   19.089856] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   19.101378] [ISP] isp platform_id = 3!
[   19.101413] [VFE]isp probe end isp_sel = 0!
[   19.101535] [VFE]sunxi_isp_platform_register end
[   19.102773] [VFE]mipi probe start mipi_sel = 0!
[   19.102826] [VFE]mipi probe end mipi_sel = 0!
[   19.102918] [VFE]mipi_init end
[   19.102926] [VFE]flash_init end
[   19.103383] [VFE]vfe_init end
[   19.136279] sunxi-bt bt.27: block state already is 1
[   19.136975] systemd[1]: Started Load/Save RF Kill Switch Status.
[   19.195407] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.211401] zram: Created 6 device(s) ...
[   19.211547] systemd[1]: Started Journal Service.
[   19.312329] systemd-journald[361]: Received request to flush runtime journal from PID 1
[   19.410675] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.444643] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.470657] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.493427] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.692722] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.692745] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1882692 kB
Buffers:            9336 kB
Cached:            58244 kB
SwapCached:            0 kB
Active:            34200 kB
Inactive:          54052 kB
Active(anon):      20764 kB
Active(file):      13436 kB
Inactive(file):    51212 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         20564 kB
Mapped:            16508 kB
Shmem:              3032 kB
Slab:              24052 kB
SReclaimable:      10500 kB
SUnreclaim:        13552 kB
KernelStack:        1952 kB
PageTables:          592 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:     115920 kB
VmallocChunk:   251633476 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62496
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
/dev/zram0       49M  4.1M   41M  10% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  3.7M  1.3M  2.1M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
07:37:09: 1152MHz  0.00  37%  12%  16%   0%   9%   0%   36°C   23°C  0/7
07:37:09: 1152MHz  0.00  49%   9%   3%   1%  35%   0%   37°C   23°C  0/7
07:37:09: 1152MHz  0.00  28%   4%   1%   1%  21%   0%   35°C   23°C  0/7
07:37:10: 1152MHz  0.00  28%   2%   2%   2%  21%   0%   34°C   23°C  0/7
07:37:10: 1152MHz  0.08  29%   4%  20%   1%   2%   0%   34°C   23°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Wed Mar  6 22:21:48 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@armbian.com) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #2 SMP PREEMPT Fri Feb 8 10:23:10 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s19520 r8192 d21440 u49152
[    0.000000] pcpu-alloc: s19520 r8192 d21440 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1964644k/1964644k available, 116124k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000b59000 - 0xffffffc000be0c40   (   544 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000b58164   ( 11105 kB)
                     .data : 0xffffffc000be1000 - 0xffffffc000d50e48   (  1472 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.066159] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.066168] pid_max: default: 32768 minimum: 301
[   10.066262] Security Framework initialized
[   10.066311] AppArmor: AppArmor initialized
[   10.066346] Mount-cache hash table entries: 256
[   10.076704] Initializing cgroup subsys memory
[   10.076751] Initializing cgroup subsys devices
[   10.076758] Initializing cgroup subsys freezer
[   10.076764] Initializing cgroup subsys blkio
[   10.076770] Initializing cgroup subsys perf_event
[   10.076780] Initializing cgroup subsys hugetlb
[   10.076845] ftrace: allocating 28898 entries in 113 pages
[   10.110573] CPU0: update cpu_power 1968128
[   10.110593] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.111569] virtual base = 0xffffff800000a000.
[   10.111582] gicd_base = 0xffffff800000c000.
[   10.111586] gicc_base = 0xffffff800000e000.
[   10.112214] CPU1: Booted secondary processor
[   10.112241] CPU1: update cpu_power 1968128
[   10.114839] CPU2: Booted secondary processor
[   10.114850] CPU2: update cpu_power 1968128
[   10.118959] CPU3: Booted secondary processor
[   10.118970] CPU3: update cpu_power 1968128
[   10.119042] Brought up 4 CPUs
[   10.119063] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.119566] devtmpfs: initialized
[   10.124522] pinctrl core: initialized pinctrl subsystem
[   10.126947] NET: Registered protocol family 16
[   10.127204] script_sysfs_init success
[   10.127441] dump_class_init,806, success
[   10.127682] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.127703] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.128982] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.130020] DMA: preallocated 256 KiB pool for atomic allocations
[   10.130135] Serial: AMBA PL011 UART driver
[   10.130237] axp81x_board_init: axp regl_devs num = 23
[   10.130380] pll_audio-set_default_rate=24576000 success!
[   10.130400] pll_video0-set_default_rate=297000000 success!
[   10.130472] pll_video1-set_default_rate=297000000 success!
[   10.130533] pll_de-set_default_rate=297000000 success!
[   10.131247] de-set_default_source=pll_de success!
[   10.131253] de-set_default_rate=297000000 success!
[   10.131295] tcon0-set_default_source=pll_mipi success!
[   10.131326] tcon1-set_default_source=pll_video0 success!
[   10.131543] hdmi-set_default_source=pll_video0 success!
[   10.133778] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.133937] [sun50iw1p1_pinctrl_probe][838]
[   10.135383] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.136004] sunxi hwspinlock vbase:0xffffff800005c000
[   10.146211] bio: create slab <bio-0> at 0
[   10.146555] pwm module init!
[   10.147779] SCSI subsystem initialized
[   10.147902] usbcore: registered new interface driver usbfs
[   10.147936] usbcore: registered new interface driver hub
[   10.148000] usbcore: registered new device driver usb
[   10.148696] Linux video capture interface: v2.00
[   10.149141] [ARISC] :sunxi-arisc driver v1.10
[   10.156077] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.156326] Advanced Linux Sound Architecture Driver Initialized.
[   10.156673] NetLabel: Initializing
[   10.156679] NetLabel:  domain hash size = 128
[   10.156682] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.156722] NetLabel:  unlabeled traffic allowed by default
[   10.156888] [pm]aw_pm_init!
[   10.156954] rtc physical base = 0x0000000001f00000 .
[   10.156989] np name = /soc@01c00000/rtc@01f00000.
[   10.156995] base = ffffff800006e100, len = 4.
[   10.157000] pmu name: pmu0 .
[   10.157035] pmu0_enable = 0x1.
[   10.157040] pmux_id = 0x6.
[   10.157047] pmux_twi_id = 0x1.
[   10.157052] pmux_twi_addr = 0x34.
[   10.157056] pmu name: pmu1 .
[   10.157104] Warning: can not find np for pmu1.
[   10.157336] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.157498] after inited: sys_mask config = 0x4a55.
[   10.157520] Warning: can not find np for dynamic_standby_para.
[   10.157641] [pm]valid
[   10.157644] [pm]valid
[   10.157649] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.157851] Switching to clocksource arch_sys_counter_ool
[   10.175850] AppArmor: AppArmor Filesystem Enabled
[   10.182424] NET: Registered protocol family 2
[   10.183113] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.183354] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.183666] TCP: Hash tables configured (established 16384 bind 16384)
[   10.183751] TCP: reno registered
[   10.183761] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.183812] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.184063] NET: Registered protocol family 1
[   10.184393] RPC: Registered named UNIX socket transport module.
[   10.184399] RPC: Registered udp transport module.
[   10.184403] RPC: Registered tcp transport module.
[   10.184408] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.184583] Trying to unpack rootfs image as initramfs...
[   10.389069] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.389655] kvm [1]: Using HYP init bounce page @b7889000
[   10.390177] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.390597] kvm [1]: timer IRQ27
[   10.390612] kvm [1]: Hyp mode initialized successfully
[   10.392320] lock super standby defaultly!
[   10.392336] lookup_scene_lock_name: new scene lock super_standby
[   10.392341] scene_lock_init name=super_standby
[   10.392348] scene_lock: super_standby, type 5, count 1
[   10.392757] audit: initializing netlink socket (disabled)
[   10.392816] type=2000 audit(0.310:1): initialized
[   10.393501] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.393962] VFS: Disk quotas dquot_6.5.2
[   10.394109] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.395041] NFS: Registering the id_resolver key type
[   10.395086] Key type id_resolver registered
[   10.395091] Key type id_legacy registered
[   10.395103] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.395240] NTFS driver 2.1.30 [Flags: R/W].
[   10.395413] fuse init (API version 7.22)
[   10.395583] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.396007] msgmni has been set to 3973
[   10.396970] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.397052] io scheduler noop registered
[   10.397058] io scheduler deadline registered
[   10.397083] io scheduler cfq registered (default)
[   10.397665] [DISP]disp_module_init
[   10.398112] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.398121] [DISP] boot_disp:0x0
[   10.398712] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.398844] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.398976] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.400091] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.400097] [DISP] fb_base:0x0
[   10.417805] Console: switching to colour frame buffer device 160x45
[   10.432261] [DISP]disp_module_init finish
[   10.432683] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.432706] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.433064] console [ttyS0] enabled
[   10.433632] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.433877] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.434183] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.434466] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.434822] misc dump reg init
[   10.434973] [drm] Initialized drm 1.1.0 20060810
[   10.437119] brd: module loaded
[   10.439237] loop: module loaded
[   10.439513] sunxi-bt bt.27: Missing bt_power.
[   10.439520] sunxi-bt bt.27: bt_power_name ((null))
[   10.439528] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.439560] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.439601] sunxi-bt bt.27: clk not config
[   10.439672] sunxi-bt bt.27: block state already is 1
[   10.439855] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.439862] sunxi-wlan wlan.26: Missing wlan_power.
[   10.439868] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.439876] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.439891] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.439910] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.439928] sunxi-wlan wlan.26: clk not config
[   10.440635] WARNING: Get ephy clock is failed
[   10.441275] chipid-sunxi serial 140050374620201507cf
[   10.441366] PPP generic driver version 2.4.2
[   10.441517] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.441622] get ehci0-controller drv_vbus_gpio is fail
[   10.441628] get ehci0-controller, regulator_io is no nocare
[   10.441667] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.441723] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.441742] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.442115] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.453113] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.453181] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.453189] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.453196] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453202] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.453209] usb usb1: SerialNumber: sunxi-ehci
[   10.453565] hub 1-0:1.0: USB hub found
[   10.453582] hub 1-0:1.0: 1 port detected
[   10.453717] scene_lock_init name=ehci_standby
[   10.453795] get ehci1-controller drv_vbus_gpio is fail
[   10.453800] get ehci1-controller, regulator_io is no nocare
[   10.453841] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.453888] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453908] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.454149] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.472795] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.472837] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.472845] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.472851] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.472858] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.472864] usb usb2: SerialNumber: sunxi-ehci
[   10.473140] hub 2-0:1.0: USB hub found
[   10.473152] hub 2-0:1.0: 1 port detected
[   10.473272] scene_lock_init name=ehci_standby
[   10.473452] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.473597] get ohci0-controller drv_vbus_gpio is fail
[   10.473602] get ohci0-controller, regulator_io is no nocare
[   10.473640] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.473688] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.473704] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.473733] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.535804] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.535812] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.535819] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.535826] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.535832] usb usb3: SerialNumber: sunxi-ohci
[   10.536107] hub 3-0:1.0: USB hub found
[   10.536121] hub 3-0:1.0: 1 port detected
[   10.536237] scene_lock_init name=ohci_standby
[   10.536301] get ohci1-controller drv_vbus_gpio is fail
[   10.536307] get ohci1-controller, regulator_io is no nocare
[   10.536340] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.536379] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.536397] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.536424] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.594834] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.594843] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.594849] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.594856] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.594862] usb usb4: SerialNumber: sunxi-ohci
[   10.595126] hub 4-0:1.0: USB hub found
[   10.595138] hub 4-0:1.0: 1 port detected
[   10.595254] scene_lock_init name=ohci_standby
[   10.595547] usbcore: registered new interface driver usb-storage
[   10.595578] usbcore: registered new interface driver ums-alauda
[   10.595605] usbcore: registered new interface driver ums-cypress
[   10.595630] usbcore: registered new interface driver ums-datafab
[   10.595654] usbcore: registered new interface driver ums_eneub6250
[   10.595677] usbcore: registered new interface driver ums-freecom
[   10.595702] usbcore: registered new interface driver ums-isd200
[   10.595725] usbcore: registered new interface driver ums-jumpshot
[   10.595748] usbcore: registered new interface driver ums-karma
[   10.595772] usbcore: registered new interface driver ums-onetouch
[   10.595806] usbcore: registered new interface driver ums-realtek
[   10.595831] usbcore: registered new interface driver ums-sddr09
[   10.595856] usbcore: registered new interface driver ums-sddr55
[   10.595880] usbcore: registered new interface driver ums-usbat
[   10.595965] usbcore: registered new interface driver usbserial
[   10.595991] usbcore: registered new interface driver usbserial_generic
[   10.596015] usbserial: USB Serial support registered for generic
[   10.596221] mousedev: PS/2 mouse device common for all mice
[   10.596656] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.597585] get ctp_para failed, -1
[   10.597604] get node gsensor failed
[   10.597608] get sysconfig para erro!
[   10.597618] get node lightsensor failed
[   10.597621] get sysconfig para erro!
[   10.597630] get node gyroscopesensor failed
[   10.597634] get sysconfig para erro!
[   10.597643] get node compasssensor failed
[   10.597646] get sysconfig para erro!
[   10.597929] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.597950] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.598121] i2c /dev entries driver
[   10.640639] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.644113] sunxi budget cooling probe start !
[   10.644145] CPU freq cooling register Success
[   10.644164] CPU hotplug cooling register Success
[   10.644250] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.644258] CPU budget cooling register Success
[   10.644469] sunxi gpu cooling probe start !
[   10.644478] CPU gpu cooling register Success
[   10.645131] cpuidle: using governor ladder
[   10.645138] cpuidle: using governor menu
[   10.645882] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.645911] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.645919] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.645927] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.645977] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.645983] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.646590] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.646613] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.597672] wakeup gpio set err!get node ctp failed
[   10.649972] get sysconfig para erro!
[   10.659744] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.679434] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.679817] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.679844] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.679851] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.679858] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.679863] get() with no identifier
[   10.679867] get() with no identifier
[   10.679870] get() with no identifier
[   10.679876] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.679882] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.679887] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.680254] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.680273] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.680291] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.681073] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.681092] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.683475] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.685605] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.686419] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687231] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688042] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688667] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.688710] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.691085] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.699102] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.718789] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.719486] ledtrig-cpu: registered to indicate activity on CPUs
[   10.719556] hidraw: raw HID events driver (C) Jiri Kosina
[   10.719697] usbcore: registered new interface driver usbhid
[   10.719702] usbhid: USB HID core driver
[   10.720566] usbcore: registered new interface driver snd-usb-audio
[   10.722548] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.723333] TCP: cubic registered
[   10.723343] Initializing XFRM netlink socket
[   10.723422] NET: Registered protocol family 10
[   10.724238] mip6: Mobile IPv6
[   10.724246] sit: IPv6 over IPv4 tunneling driver
[   10.724626] NET: Registered protocol family 17
[   10.724650] NET: Registered protocol family 15
[   10.724699] 8021q: 802.1Q VLAN Support v1.8
[   10.724763] Key type dns_resolver registered
[   10.724969] Registering SWP/SWPB emulation handler
[   10.725260] registered taskstats version 1
[   10.737241] Key type encrypted registered
[   10.737265] AppArmor: AppArmor sha1 policy hashing enabled
[   10.737703] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.737711] [DISP] boot_disp:0x0
[   10.737756] HDMI base address: ffffff8000b40000
[   10.738531] [HDMI] power vcc-hdmi-33
[   10.739056] [HDMI] cec support = 0
[   10.758096] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.760593] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.760669] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.760771] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.760796] mmc0: new high speed SDHC card at address aaaa
[   10.761192] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.763224]  mmcblk0: p1
[   10.764338] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.765148] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.765166] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.767558] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.769378] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.770187] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.770994] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771798] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772603] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.773410] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774216] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775023] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775830] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775847] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.776680] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.776697] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.849522] input: sunxi-ths as /devices/virtual/input/input2
[   10.849685] thermal thermal_zone0: failed to read out thermal zone 0
[   10.850107] ALSA device list:
[   10.850113]   #0: sndhdmi
[   10.850550] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.446968] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.133268] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.133283] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.133304] scene_lock_destroy name=ehci_standby
[   14.133317] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.133339] usb usb1: USB disconnect, device number 1
[   14.133890] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.133924] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.133932] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.133937] scene_lock_destroy name=ohci_standby
[   14.133944] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.133960] usb usb3: USB disconnect, device number 1
[   14.134326] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.134362] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.134370] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.134414] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.134438] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.135443] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.152960] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.153057] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.153065] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.153072] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.153078] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.153084] usb usb1: SerialNumber: sunxi-ehci
[   14.153548] hub 1-0:1.0: USB hub found
[   14.153566] hub 1-0:1.0: 1 port detected
[   14.153717] scene_lock_init name=ehci_standby
[   14.153725] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.153733] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.153788] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.153806] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.153847] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.215999] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.216014] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.216021] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.216027] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.216034] usb usb3: SerialNumber: sunxi-ohci
[   14.216490] hub 3-0:1.0: USB hub found
[   14.216510] hub 3-0:1.0: 1 port detected
[   14.216699] scene_lock_init name=ohci_standby
[   16.402266] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.785357] systemd[1]: System time before build time, advancing clock.
[   16.822353] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.822656] systemd[1]: Detected architecture arm64.
[   16.851847] systemd[1]: Set hostname to <cluster0>.
[   17.211048] systemd[1]: Reached target Swap.
[   17.223498] systemd[1]: Created slice User and Session Slice.
[   17.243021] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.262573] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.282224] systemd[1]: Reached target Encrypted Volumes.
[   17.302206] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.321495] systemd[1]: Reached target Remote File Systems (Pre).
[   17.341162] systemd[1]: Reached target Remote File Systems.
[   17.360952] systemd[1]: Listening on udev Kernel Socket.
[   17.380843] systemd[1]: Created slice System Slice.
[   17.400528] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.419903] systemd[1]: Reached target Slices.
[   17.440171] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.459431] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.478933] systemd[1]: Reached target Paths.
[   17.498730] systemd[1]: Listening on Syslog Socket.
[   17.518384] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.538090] systemd[1]: Listening on udev Control Socket.
[   17.557786] systemd[1]: Listening on Journal Socket.
[   17.579197] systemd[1]: Mounting Huge Pages File System...
[   17.599176] systemd[1]: Mounting Debug File System...
[   17.619300] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.640323] systemd[1]: Mounting POSIX Message Queue File System...
[   17.645944] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.658116] systemd[1]: Starting Set console keymap...
[   17.678017] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.701663] systemd[1]: Starting Restore / save the current clock...
[   17.727254] systemd[1]: Starting Nameserver information manager...
[   17.750613] systemd[1]: Starting Load Kernel Modules...
[   17.768810] systemd[1]: Mounted Debug File System.
[   17.784364] systemd[1]: Mounted POSIX Message Queue File System.
[   17.803942] systemd[1]: Mounted Huge Pages File System.
[   17.825205] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.844852] systemd[1]: Started Set console keymap.
[   17.863698] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.883309] systemd[1]: Started Restore / save the current clock.
[   17.907758] systemd[1]: Time has been changed
[   17.930524] systemd[1]: Started Nameserver information manager.
[   17.970243] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.970595] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.970743] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.970947] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.972197] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   18.022918] systemd[1]: Reached target Network (Pre).
[   18.030078] cfg80211: Calling CRDA to update world regulatory domain
[   18.042841] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.069723] systemd[1]: Starting udev Coldplug all Devices...
[   18.091306] systemd[1]: Starting Load/Save Random Seed...
[   18.223960] RTL871X: module init start
[   18.223978] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.223983] RTL871X: build time: Feb  8 2019 10:22:36
[   18.223988] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.224003] sunxi-wlan wlan.26: bus_index: 1
[   18.224156] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.240988] systemd[1]: Started Load/Save Random Seed.
[   18.288314] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.310214] systemd[1]: Starting udev Kernel Device Manager...
[   18.325405] systemd[1]: Reached target Local File Systems (Pre).
[   18.332668] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.332794] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.332950] RTL871X: module init ret=0
[   18.344900] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.349234] systemd[1]: Mounting /tmp...
[   18.365349] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.366182] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.366210] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.367474] systemd[1]: Mounted /tmp.
[   18.368646] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.370514] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.371346] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.372156] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.372963] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.373769] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.374585] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.375400] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.376210] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.377016] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.377038] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.377920] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.377938] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.385291] systemd[1]: Started Load Kernel Modules.
[   18.406907] systemd[1]: Started udev Kernel Device Manager.
[   18.459281] systemd[1]: Started udev Coldplug all Devices.
[   18.482369] systemd[1]: Reached target Sound Card.
[   18.504789] systemd[1]: Mounting FUSE Control File System...
[   18.524542] systemd[1]: Mounting Configuration File System...
[   18.544295] systemd[1]: Starting Apply Kernel Variables...
[   18.591273] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.613151] systemd[1]: Starting Journal Service...
[   18.630442] systemd[1]: Reached target Local File Systems.
[   18.630476] cfg80211: World regulatory domain updated:
[   18.630483] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.630490] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.630500] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.630506] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.630512] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.630516] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.630521] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.630526] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.630531] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.652628] systemd[1]: Starting Armbian ZRAM config...
[   18.665440] sunxi cedar version 0.1
[   18.665629] [cedar]: install start!!!
[   18.665746] ycy the get irq is 90
[   18.666925] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.666942] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.666947] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.666952] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.666957] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.666960] [cedar]: install end!!!
[   18.672002] systemd[1]: Starting Set console font and keymap...
[   18.694946] systemd[1]: Mounted FUSE Control File System.
[   18.719436] systemd[1]: Mounted Configuration File System.
[   18.736980] Driver for 1-wire Dallas network protocol.
[   18.740789] systemd[1]: Started Apply Kernel Variables.
[   18.788558] systemd[1]: Found device /dev/ttyS0.
[   18.792653] Registered IR keymap rc_map_sunxi
[   18.793166] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.793545] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.842745] IR NEC protocol handler initialized
[   18.842748] IR RC5(x) protocol handler initialized
[   18.843276] [VFE]cci probe end cci_sel = 0!
[   18.843559] [VFE]cci_init end
[   18.845003] IR JVC protocol handler initialized
[   18.846312] IR RC6 protocol handler initialized
[   18.847544] IR SANYO protocol handler initialized
[   18.848001] IR Sony protocol handler initialized
[   18.898293] lirc_dev: IR Remote Control driver registered, major 248
[   18.900726] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.900744] IR LIRC bridge handler initialized
[   18.901936] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.902216] IR MCE Keyboard/mouse protocol handler initialized
[   19.058521] systemd[1]: Started Journal Service.
[   19.175937] [VFE]Welcome to Video Front End driver
[   19.177551] [VFE]csi probe end csi_sel = 0!
[   19.178490] [VFE]csi_init end
[   19.179728] [VFE]isp probe start isp_sel = 0!
[   19.197577] [ISP] isp platform_id = 3!
[   19.197608] [VFE]isp probe end isp_sel = 0!
[   19.198177] [VFE]sunxi_isp_platform_register end
[   19.199070] [VFE]mipi probe start mipi_sel = 0!
[   19.199114] [VFE]mipi probe end mipi_sel = 0!
[   19.199406] [VFE]mipi_init end
[   19.199415] [VFE]flash_init end
[   19.200174] [VFE]vfe_init end
[   19.220534] systemd-journald[300]: Received request to flush runtime journal from PID 1
[   19.259418] sunxi-bt bt.27: block state already is 1
[   19.309860] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.312663] zram: Created 6 device(s) ...
[   19.468521] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.505364] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.541072] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.563580] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.760298] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.760319] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035016 kB
MemFree:         1886784 kB
Buffers:            9208 kB
Cached:            57036 kB
SwapCached:            0 kB
Active:            31884 kB
Inactive:          53100 kB
Active(anon):      19128 kB
Inactive(anon):     2860 kB
Active(file):      12756 kB
Inactive(file):    50240 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017504 kB
SwapFree:        1017504 kB
Dirty:               168 kB
Writeback:             0 kB
AnonPages:         19012 kB
Mapped:            15136 kB
Shmem:              3028 kB
Slab:              23876 kB
SReclaimable:      10468 kB
SUnreclaim:        13408 kB
KernelStack:        1872 kB
PageTables:          544 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035012 kB
Committed_AS:     126888 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633508 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5606
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 62493
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
/dev/mmcblk0p1   15G  931M   14G   7% /
tmpfs           994M     0  994M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           994M     0  994M   0% /sys/fs/cgroup
tmpfs           994M  4.0K  994M   1% /tmp
/dev/zram0       49M  4.4M   41M  10% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M   4M  1.4M  2.2M         /var/log
/dev/zram1             248.4M   4K   78B    4K         [SWAP]
/dev/zram2             248.4M   4K   78B    4K         [SWAP]
/dev/zram3             248.4M   4K   78B    4K         [SWAP]
/dev/zram4             248.4M   4K   78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
22:21:52: 1152MHz  0.08  37%  12%  16%   0%   8%   0%   40°C   24°C  0/7
22:21:52: 1152MHz  0.08  41%   7%   3%   0%  29%   0%   40°C   24°C  0/7
22:21:52: 1152MHz  0.08  29%   4%   2%   0%  21%   0%   37°C   24°C  0/7
22:21:53: 1152MHz  0.08  28%   2%   0%   2%  22%   0%   36°C   24°C  0/7
22:21:53: 1152MHz  0.39  31%   6%  15%   2%   6%   0%   35°C   24°C  0/7
Wed Mar  6 23:38:00 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.078191] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.078200] pid_max: default: 32768 minimum: 301
[   10.078293] Security Framework initialized
[   10.078341] AppArmor: AppArmor initialized
[   10.078376] Mount-cache hash table entries: 256
[   10.088716] Initializing cgroup subsys memory
[   10.088763] Initializing cgroup subsys devices
[   10.088770] Initializing cgroup subsys freezer
[   10.088776] Initializing cgroup subsys blkio
[   10.088782] Initializing cgroup subsys perf_event
[   10.088793] Initializing cgroup subsys hugetlb
[   10.088857] ftrace: allocating 28898 entries in 113 pages
[   10.122566] CPU0: update cpu_power 1968128
[   10.122587] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.123563] virtual base = 0xffffff800000a000.
[   10.123575] gicd_base = 0xffffff800000c000.
[   10.123579] gicc_base = 0xffffff800000e000.
[   10.124204] CPU1: Booted secondary processor
[   10.124230] CPU1: update cpu_power 1968128
[   10.126830] CPU2: Booted secondary processor
[   10.126841] CPU2: update cpu_power 1968128
[   10.130947] CPU3: Booted secondary processor
[   10.130958] CPU3: update cpu_power 1968128
[   10.131030] Brought up 4 CPUs
[   10.131051] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.131556] devtmpfs: initialized
[   10.136521] pinctrl core: initialized pinctrl subsystem
[   10.138968] NET: Registered protocol family 16
[   10.139225] script_sysfs_init success
[   10.139460] dump_class_init,806, success
[   10.139702] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.139723] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.141002] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.142052] DMA: preallocated 256 KiB pool for atomic allocations
[   10.142168] Serial: AMBA PL011 UART driver
[   10.142271] axp81x_board_init: axp regl_devs num = 23
[   10.142412] pll_audio-set_default_rate=24576000 success!
[   10.142431] pll_video0-set_default_rate=297000000 success!
[   10.142503] pll_video1-set_default_rate=297000000 success!
[   10.142564] pll_de-set_default_rate=297000000 success!
[   10.143280] de-set_default_source=pll_de success!
[   10.143286] de-set_default_rate=297000000 success!
[   10.143329] tcon0-set_default_source=pll_mipi success!
[   10.143360] tcon1-set_default_source=pll_video0 success!
[   10.143575] hdmi-set_default_source=pll_video0 success!
[   10.145788] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.145945] [sun50iw1p1_pinctrl_probe][838]
[   10.147388] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.148008] sunxi hwspinlock vbase:0xffffff800005c000
[   10.158241] bio: create slab <bio-0> at 0
[   10.158587] pwm module init!
[   10.159810] SCSI subsystem initialized
[   10.159935] usbcore: registered new interface driver usbfs
[   10.159969] usbcore: registered new interface driver hub
[   10.160034] usbcore: registered new device driver usb
[   10.160737] Linux video capture interface: v2.00
[   10.161180] [ARISC] :sunxi-arisc driver v1.10
[   10.168111] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.168359] Advanced Linux Sound Architecture Driver Initialized.
[   10.168706] NetLabel: Initializing
[   10.168711] NetLabel:  domain hash size = 128
[   10.168715] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.168754] NetLabel:  unlabeled traffic allowed by default
[   10.168920] [pm]aw_pm_init!
[   10.168985] rtc physical base = 0x0000000001f00000 .
[   10.169016] np name = /soc@01c00000/rtc@01f00000.
[   10.169022] base = ffffff800006e100, len = 4.
[   10.169028] pmu name: pmu0 .
[   10.169063] pmu0_enable = 0x1.
[   10.169069] pmux_id = 0x6.
[   10.169075] pmux_twi_id = 0x1.
[   10.169081] pmux_twi_addr = 0x34.
[   10.169085] pmu name: pmu1 .
[   10.169132] Warning: can not find np for pmu1.
[   10.169361] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.169521] after inited: sys_mask config = 0x4a55.
[   10.169543] Warning: can not find np for dynamic_standby_para.
[   10.169667] [pm]valid
[   10.169671] [pm]valid
[   10.169675] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.169881] Switching to clocksource arch_sys_counter_ool
[   10.187821] AppArmor: AppArmor Filesystem Enabled
[   10.194427] NET: Registered protocol family 2
[   10.195119] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.195359] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.195672] TCP: Hash tables configured (established 16384 bind 16384)
[   10.195756] TCP: reno registered
[   10.195766] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.195818] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.196071] NET: Registered protocol family 1
[   10.196399] RPC: Registered named UNIX socket transport module.
[   10.196405] RPC: Registered udp transport module.
[   10.196409] RPC: Registered tcp transport module.
[   10.196414] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.196590] Trying to unpack rootfs image as initramfs...
[   10.401108] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.401692] kvm [1]: Using HYP init bounce page @b788b000
[   10.402208] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.402628] kvm [1]: timer IRQ27
[   10.402644] kvm [1]: Hyp mode initialized successfully
[   10.404348] lock super standby defaultly!
[   10.404364] lookup_scene_lock_name: new scene lock super_standby
[   10.404369] scene_lock_init name=super_standby
[   10.404376] scene_lock: super_standby, type 5, count 1
[   10.404778] audit: initializing netlink socket (disabled)
[   10.404835] type=2000 audit(0.310:1): initialized
[   10.405516] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.405976] VFS: Disk quotas dquot_6.5.2
[   10.406122] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.407054] NFS: Registering the id_resolver key type
[   10.407100] Key type id_resolver registered
[   10.407105] Key type id_legacy registered
[   10.407117] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.407254] NTFS driver 2.1.30 [Flags: R/W].
[   10.407430] fuse init (API version 7.22)
[   10.407600] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.408026] msgmni has been set to 3973
[   10.408981] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.409063] io scheduler noop registered
[   10.409069] io scheduler deadline registered
[   10.409094] io scheduler cfq registered (default)
[   10.409688] [DISP]disp_module_init
[   10.410141] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.410148] [DISP] boot_disp:0x0
[   10.410737] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.410868] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.410999] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.412112] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.412119] [DISP] fb_base:0x0
[   10.429820] Console: switching to colour frame buffer device 160x45
[   10.444270] [DISP]disp_module_init finish
[   10.444694] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.444718] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.445075] console [ttyS0] enabled
[   10.445640] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.445889] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.446200] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.446486] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.446843] misc dump reg init
[   10.446997] [drm] Initialized drm 1.1.0 20060810
[   10.449146] brd: module loaded
[   10.451264] loop: module loaded
[   10.451543] sunxi-bt bt.27: Missing bt_power.
[   10.451551] sunxi-bt bt.27: bt_power_name ((null))
[   10.451559] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.451594] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.451638] sunxi-bt bt.27: clk not config
[   10.451708] sunxi-bt bt.27: block state already is 1
[   10.451901] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.451908] sunxi-wlan wlan.26: Missing wlan_power.
[   10.451915] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.451922] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.451937] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.451957] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.451975] sunxi-wlan wlan.26: clk not config
[   10.452678] WARNING: Get ephy clock is failed
[   10.453301] chipid-sunxi serial 140050374620201507cf
[   10.453395] PPP generic driver version 2.4.2
[   10.453545] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453655] get ehci0-controller drv_vbus_gpio is fail
[   10.453662] get ehci0-controller, regulator_io is no nocare
[   10.453699] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.453754] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453773] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.454132] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.465142] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.465211] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.465219] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.465226] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.465232] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.465238] usb usb1: SerialNumber: sunxi-ehci
[   10.465590] hub 1-0:1.0: USB hub found
[   10.465606] hub 1-0:1.0: 1 port detected
[   10.465741] scene_lock_init name=ehci_standby
[   10.465818] get ehci1-controller drv_vbus_gpio is fail
[   10.465824] get ehci1-controller, regulator_io is no nocare
[   10.465865] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.465913] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.465933] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.466173] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.484824] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.484867] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.484875] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.484882] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.484889] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.484895] usb usb2: SerialNumber: sunxi-ehci
[   10.485173] hub 2-0:1.0: USB hub found
[   10.485186] hub 2-0:1.0: 1 port detected
[   10.485306] scene_lock_init name=ehci_standby
[   10.485491] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.485634] get ohci0-controller drv_vbus_gpio is fail
[   10.485639] get ohci0-controller, regulator_io is no nocare
[   10.485677] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.485725] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.485740] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.485769] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.547834] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.547842] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.547849] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.547856] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.547862] usb usb3: SerialNumber: sunxi-ohci
[   10.548135] hub 3-0:1.0: USB hub found
[   10.548148] hub 3-0:1.0: 1 port detected
[   10.548266] scene_lock_init name=ohci_standby
[   10.548326] get ohci1-controller drv_vbus_gpio is fail
[   10.548331] get ohci1-controller, regulator_io is no nocare
[   10.548364] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.548404] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.548421] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.548445] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.606865] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.606874] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.606880] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.606887] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.606893] usb usb4: SerialNumber: sunxi-ohci
[   10.607154] hub 4-0:1.0: USB hub found
[   10.607167] hub 4-0:1.0: 1 port detected
[   10.607282] scene_lock_init name=ohci_standby
[   10.607576] usbcore: registered new interface driver usb-storage
[   10.607607] usbcore: registered new interface driver ums-alauda
[   10.607635] usbcore: registered new interface driver ums-cypress
[   10.607660] usbcore: registered new interface driver ums-datafab
[   10.607683] usbcore: registered new interface driver ums_eneub6250
[   10.607706] usbcore: registered new interface driver ums-freecom
[   10.607731] usbcore: registered new interface driver ums-isd200
[   10.607754] usbcore: registered new interface driver ums-jumpshot
[   10.607777] usbcore: registered new interface driver ums-karma
[   10.607801] usbcore: registered new interface driver ums-onetouch
[   10.607835] usbcore: registered new interface driver ums-realtek
[   10.607860] usbcore: registered new interface driver ums-sddr09
[   10.607884] usbcore: registered new interface driver ums-sddr55
[   10.607908] usbcore: registered new interface driver ums-usbat
[   10.607994] usbcore: registered new interface driver usbserial
[   10.608020] usbcore: registered new interface driver usbserial_generic
[   10.608044] usbserial: USB Serial support registered for generic
[   10.608253] mousedev: PS/2 mouse device common for all mice
[   10.608694] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.609646] get ctp_para failed, -1
[   10.609665] get node gsensor failed
[   10.609669] get sysconfig para erro!
[   10.609679] get node lightsensor failed
[   10.609682] get sysconfig para erro!
[   10.609691] get node gyroscopesensor failed
[   10.609695] get sysconfig para erro!
[   10.609704] get node compasssensor failed
[   10.609707] get sysconfig para erro!
[   10.609987] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.610008] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.610181] i2c /dev entries driver
[   10.652669] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.656151] sunxi budget cooling probe start !
[   10.656181] CPU freq cooling register Success
[   10.656200] CPU hotplug cooling register Success
[   10.656286] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.656293] CPU budget cooling register Success
[   10.656508] sunxi gpu cooling probe start !
[   10.656517] CPU gpu cooling register Success
[   10.657171] cpuidle: using governor ladder
[   10.657178] cpuidle: using governor menu
[   10.657921] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.657949] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.657958] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.657966] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.658014] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.658021] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.658616] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.658639] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.609734] wakeup gpio set err!get node ctp failed
[   10.662006] get sysconfig para erro!
[   10.671774] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.691463] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.691842] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.691867] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.691875] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.691881] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.691886] get() with no identifier
[   10.691889] get() with no identifier
[   10.691893] get() with no identifier
[   10.691898] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.691904] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.691910] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.692285] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.692305] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.692323] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.693107] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.693126] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.695511] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.697639] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.698453] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.699264] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.700076] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.700700] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.700743] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.703118] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.711132] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.730820] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.731517] ledtrig-cpu: registered to indicate activity on CPUs
[   10.731586] hidraw: raw HID events driver (C) Jiri Kosina
[   10.731729] usbcore: registered new interface driver usbhid
[   10.731734] usbhid: USB HID core driver
[   10.732592] usbcore: registered new interface driver snd-usb-audio
[   10.734586] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.735362] TCP: cubic registered
[   10.735371] Initializing XFRM netlink socket
[   10.735450] NET: Registered protocol family 10
[   10.736270] mip6: Mobile IPv6
[   10.736278] sit: IPv6 over IPv4 tunneling driver
[   10.736657] NET: Registered protocol family 17
[   10.736680] NET: Registered protocol family 15
[   10.736727] 8021q: 802.1Q VLAN Support v1.8
[   10.736771] Key type dns_resolver registered
[   10.736978] Registering SWP/SWPB emulation handler
[   10.737268] registered taskstats version 1
[   10.749266] Key type encrypted registered
[   10.749288] AppArmor: AppArmor sha1 policy hashing enabled
[   10.749732] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.749740] [DISP] boot_disp:0x0
[   10.749786] HDMI base address: ffffff8000b40000
[   10.750581] [HDMI] power vcc-hdmi-33
[   10.751101] [HDMI] cec support = 0
[   10.770130] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.772627] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.772702] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.772803] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.772829] mmc0: new high speed SDHC card at address aaaa
[   10.773223] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.775253]  mmcblk0: p1
[   10.776372] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.777181] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.777199] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.779594] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.781412] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.782220] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.783027] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.783831] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.784636] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.785443] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.786250] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.787057] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.787864] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.787880] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.788716] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.788733] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.861550] input: sunxi-ths as /devices/virtual/input/input2
[   10.861712] thermal thermal_zone0: failed to read out thermal zone 0
[   10.862131] ALSA device list:
[   10.862137]   #0: sndhdmi
[   10.862568] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.458993] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.145298] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.145316] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.145337] scene_lock_destroy name=ehci_standby
[   14.145351] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.145373] usb usb1: USB disconnect, device number 1
[   14.147348] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.147393] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.147403] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.147409] scene_lock_destroy name=ohci_standby
[   14.147418] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.147439] usb usb3: USB disconnect, device number 1
[   14.147851] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.147888] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.147896] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.147942] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.147968] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.150527] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.164993] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.165107] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.165115] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.165122] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.165128] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.165134] usb usb1: SerialNumber: sunxi-ehci
[   14.165601] hub 1-0:1.0: USB hub found
[   14.165619] hub 1-0:1.0: 1 port detected
[   14.165773] scene_lock_init name=ehci_standby
[   14.165782] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.165789] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.165841] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.165860] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.165905] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.228043] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.228059] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.228066] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.228073] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.228079] usb usb3: SerialNumber: sunxi-ohci
[   14.228539] hub 3-0:1.0: USB hub found
[   14.228558] hub 3-0:1.0: 1 port detected
[   14.228736] scene_lock_init name=ohci_standby
[   16.461827] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.845693] systemd[1]: System time before build time, advancing clock.
[   16.882788] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.883096] systemd[1]: Detected architecture arm64.
[   16.913080] systemd[1]: Set hostname to <cluster0>.
[   17.273084] systemd[1]: Listening on udev Control Socket.
[   17.294224] systemd[1]: Reached target Swap.
[   17.314137] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.333637] systemd[1]: Listening on Syslog Socket.
[   17.353285] systemd[1]: Listening on udev Kernel Socket.
[   17.372961] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.392933] systemd[1]: Created slice User and Session Slice.
[   17.412396] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.431918] systemd[1]: Reached target Paths.
[   17.452075] systemd[1]: Created slice System Slice.
[   17.471318] systemd[1]: Reached target Slices.
[   17.491259] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.511205] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.530346] systemd[1]: Reached target Encrypted Volumes.
[   17.550152] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.569686] systemd[1]: Reached target Remote File Systems (Pre).
[   17.589370] systemd[1]: Reached target Remote File Systems.
[   17.609130] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.628835] systemd[1]: Listening on Journal Socket.
[   17.653305] systemd[1]: Starting Restore / save the current clock...
[   17.671958] systemd[1]: Starting Nameserver information manager...
[   17.690130] systemd[1]: Mounting POSIX Message Queue File System...
[   17.710427] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.730171] systemd[1]: Mounting Huge Pages File System...
[   17.738653] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.749057] systemd[1]: Starting Set console keymap...
[   17.769134] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.778979] systemd[1]: Mounting Debug File System...
[   17.801967] systemd[1]: Starting Load Kernel Modules...
[   17.825902] systemd[1]: Mounted Debug File System.
[   17.848444] systemd[1]: Mounted POSIX Message Queue File System.
[   17.865065] systemd[1]: Mounted Huge Pages File System.
[   17.885675] systemd[1]: Started Restore / save the current clock.
[   17.909140] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.925386] systemd[1]: Started Set console keymap.
[   17.944575] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.966549] systemd[1]: Started Nameserver information manager.
[   17.986786] systemd[1]: Time has been changed
[   18.018390] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   18.018687] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   18.018834] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   18.018968] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   18.020145] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   18.077321] systemd[1]: Reached target Network (Pre).
[   18.094120] cfg80211: Calling CRDA to update world regulatory domain
[   18.103612] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.134506] systemd[1]: Starting udev Coldplug all Devices...
[   18.152629] systemd[1]: Starting Load/Save Random Seed...
[   18.233322] RTL871X: module init start
[   18.233339] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.233344] RTL871X: build time: Feb  8 2019 10:22:36
[   18.233349] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.233364] sunxi-wlan wlan.26: bus_index: 1
[   18.233520] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.268015] systemd[1]: Started Load/Save Random Seed.
[   18.309623] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.342011] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.342124] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.342278] RTL871X: module init ret=0
[   18.344269] systemd[1]: Started Load Kernel Modules.
[   18.356903] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.377395] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.378232] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.378265] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.380722] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.382601] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.383040] systemd[1]: Mounting FUSE Control File System...
[   18.383463] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.384285] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.385099] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.385917] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.386748] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.387654] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.388487] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.389299] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.389321] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.390211] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.390229] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.408524] systemd[1]: Starting Apply Kernel Variables...
[   18.428251] systemd[1]: Mounting Configuration File System...
[   18.445714] systemd[1]: Reached target Local File Systems (Pre).
[   18.470077] systemd[1]: Mounting /tmp...
[   18.487311] systemd[1]: Starting udev Kernel Device Manager...
[   18.507826] systemd[1]: Mounted FUSE Control File System.
[   18.524405] systemd[1]: Mounted Configuration File System.
[   18.544235] systemd[1]: Mounted /tmp.
[   18.564284] systemd[1]: Started udev Kernel Device Manager.
[   18.584476] systemd[1]: Started udev Coldplug all Devices.
[   18.604376] systemd[1]: Started Apply Kernel Variables.
[   18.677728] systemd[1]: Reached target Sound Card.
[   18.692489] systemd[1]: Reached target Local File Systems.
[   18.720764] systemd[1]: Starting Raise network interfaces...
[   18.742928] systemd[1]: Starting Set console font and keymap...
[   18.763047] systemd[1]: Starting Armbian ZRAM config...
[   18.788217] cfg80211: World regulatory domain updated:
[   18.788241] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.788248] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.788254] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.788259] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.788264] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.788269] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.788274] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.788279] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.788285] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.807577] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.833913] sunxi cedar version 0.1
[   18.834212] [cedar]: install start!!!
[   18.834397] ycy the get irq is 90
[   18.835156] systemd[1]: Starting Journal Service...
[   18.836992] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.837014] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.837020] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.837025] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.837030] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.837034] [cedar]: install end!!!
[   18.919124] systemd[1]: Found device /dev/ttyS0.
[   19.020491] Registered IR keymap rc_map_sunxi
[   19.021067] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   19.021426] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   19.044667] [VFE]cci probe end cci_sel = 0!
[   19.045028] [VFE]cci_init end
[   19.078788] IR NEC protocol handler initialized
[   19.079372] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   19.079966] IR RC5(x) protocol handler initialized
[   19.079969] IR MCE Keyboard/mouse protocol handler initialized
[   19.081107] IR JVC protocol handler initialized
[   19.081904] IR Sony protocol handler initialized
[   19.081907] IR SANYO protocol handler initialized
[   19.082397] IR RC6 protocol handler initialized
[   19.114387] Driver for 1-wire Dallas network protocol.
[   19.141222] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   19.177224] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   19.264170] systemd[1]: Started Journal Service.
[   19.277282] [VFE]Welcome to Video Front End driver
[   19.277670] [VFE]csi probe end csi_sel = 0!
[   19.277985] [VFE]csi_init end
[   19.278470] [VFE]isp probe start isp_sel = 0!
[   19.286073] [ISP] isp platform_id = 3!
[   19.286104] [VFE]isp probe end isp_sel = 0!
[   19.286231] [VFE]sunxi_isp_platform_register end
[   19.286734] [VFE]mipi probe start mipi_sel = 0!
[   19.286760] [VFE]mipi probe end mipi_sel = 0!
[   19.286824] [VFE]mipi_init end
[   19.286831] [VFE]flash_init end
[   19.287943] [VFE]vfe_init end
[   19.295936] lirc_dev: IR Remote Control driver registered, major 248
[   19.298605] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   19.298620] IR LIRC bridge handler initialized
[   19.361188] sunxi-bt bt.27: block state already is 1
[   19.401632] systemd-journald[311]: Received request to flush runtime journal from PID 1
[   19.415923] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.420834] zram: Created 6 device(s) ...
[   19.613504] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.648535] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.682867] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.717652] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.917162] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.917185] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1887132 kB
Buffers:            9296 kB
Cached:            56808 kB
SwapCached:            0 kB
Active:            31072 kB
Inactive:          52704 kB
Active(anon):      18228 kB
Inactive(anon):     2844 kB
Active(file):      12844 kB
Inactive(file):    49860 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:               176 kB
Writeback:             0 kB
AnonPages:         18272 kB
Mapped:            15632 kB
Shmem:              3028 kB
Slab:              23612 kB
SReclaimable:      10280 kB
SUnreclaim:        13332 kB
KernelStack:        1808 kB
PageTables:          516 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:     125108 kB
VmallocChunk:   251633464 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
/dev/mmcblk0p1   15G  932M   14G   7% /
/dev/zram0       49M  4.6M   41M  11% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  4.2M  1.4M  2.3M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
23:38:03: 1152MHz  0.00  36%  12%  15%   0%   8%   0%   44°C   29°C  0/7
23:38:03: 1152MHz  0.00  51%   9%   1%   2%  37%   0%   43°C   29°C  0/7
23:38:04: 1152MHz  0.00  30%   3%   5%   0%  21%   0%   41°C   29°C  0/7
23:38:04: 1152MHz  0.08  29%   3%   0%   2%  23%   0%   40°C   29°C  0/7
23:38:04: 1152MHz  0.08  28%   3%  11%   1%  11%   0%   41°C   29°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Thu Mar  7 01:06:29 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@armbian.com) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #2 SMP PREEMPT Fri Feb 8 10:23:10 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s19520 r8192 d21440 u49152
[    0.000000] pcpu-alloc: s19520 r8192 d21440 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1964644k/1964644k available, 116124k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000b59000 - 0xffffffc000be0c40   (   544 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000b58164   ( 11105 kB)
                     .data : 0xffffffc000be1000 - 0xffffffc000d50e48   (  1472 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.067835] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.067845] pid_max: default: 32768 minimum: 301
[   10.067938] Security Framework initialized
[   10.067985] AppArmor: AppArmor initialized
[   10.068020] Mount-cache hash table entries: 256
[   10.078379] Initializing cgroup subsys memory
[   10.078426] Initializing cgroup subsys devices
[   10.078434] Initializing cgroup subsys freezer
[   10.078440] Initializing cgroup subsys blkio
[   10.078445] Initializing cgroup subsys perf_event
[   10.078455] Initializing cgroup subsys hugetlb
[   10.078518] ftrace: allocating 28898 entries in 113 pages
[   10.112282] CPU0: update cpu_power 1968128
[   10.112303] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.113281] virtual base = 0xffffff800000a000.
[   10.113295] gicd_base = 0xffffff800000c000.
[   10.113299] gicc_base = 0xffffff800000e000.
[   10.113928] CPU1: Booted secondary processor
[   10.113954] CPU1: update cpu_power 1968128
[   10.116552] CPU2: Booted secondary processor
[   10.116564] CPU2: update cpu_power 1968128
[   10.120672] CPU3: Booted secondary processor
[   10.120683] CPU3: update cpu_power 1968128
[   10.120755] Brought up 4 CPUs
[   10.120776] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.121278] devtmpfs: initialized
[   10.126257] pinctrl core: initialized pinctrl subsystem
[   10.128698] NET: Registered protocol family 16
[   10.128957] script_sysfs_init success
[   10.129196] dump_class_init,806, success
[   10.129437] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.129457] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.130736] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.131783] DMA: preallocated 256 KiB pool for atomic allocations
[   10.131900] Serial: AMBA PL011 UART driver
[   10.132002] axp81x_board_init: axp regl_devs num = 23
[   10.132146] pll_audio-set_default_rate=24576000 success!
[   10.132165] pll_video0-set_default_rate=297000000 success!
[   10.132237] pll_video1-set_default_rate=297000000 success!
[   10.132296] pll_de-set_default_rate=297000000 success!
[   10.133014] de-set_default_source=pll_de success!
[   10.133020] de-set_default_rate=297000000 success!
[   10.133062] tcon0-set_default_source=pll_mipi success!
[   10.133092] tcon1-set_default_source=pll_video0 success!
[   10.133308] hdmi-set_default_source=pll_video0 success!
[   10.135538] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.135694] [sun50iw1p1_pinctrl_probe][838]
[   10.137134] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.137754] sunxi hwspinlock vbase:0xffffff800005c000
[   10.147991] bio: create slab <bio-0> at 0
[   10.148337] pwm module init!
[   10.149552] SCSI subsystem initialized
[   10.149677] usbcore: registered new interface driver usbfs
[   10.149711] usbcore: registered new interface driver hub
[   10.149774] usbcore: registered new device driver usb
[   10.150468] Linux video capture interface: v2.00
[   10.150905] [ARISC] :sunxi-arisc driver v1.10
[   10.157841] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.158089] Advanced Linux Sound Architecture Driver Initialized.
[   10.158434] NetLabel: Initializing
[   10.158440] NetLabel:  domain hash size = 128
[   10.158444] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.158482] NetLabel:  unlabeled traffic allowed by default
[   10.158644] [pm]aw_pm_init!
[   10.158710] rtc physical base = 0x0000000001f00000 .
[   10.158743] np name = /soc@01c00000/rtc@01f00000.
[   10.158750] base = ffffff800006e100, len = 4.
[   10.158755] pmu name: pmu0 .
[   10.158788] pmu0_enable = 0x1.
[   10.158794] pmux_id = 0x6.
[   10.158801] pmux_twi_id = 0x1.
[   10.158806] pmux_twi_addr = 0x34.
[   10.158810] pmu name: pmu1 .
[   10.158858] Warning: can not find np for pmu1.
[   10.159087] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.159247] after inited: sys_mask config = 0x4a55.
[   10.159269] Warning: can not find np for dynamic_standby_para.
[   10.159401] [pm]valid
[   10.159405] [pm]valid
[   10.159409] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.159612] Switching to clocksource arch_sys_counter_ool
[   10.177604] AppArmor: AppArmor Filesystem Enabled
[   10.184214] NET: Registered protocol family 2
[   10.184901] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.185146] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.185454] TCP: Hash tables configured (established 16384 bind 16384)
[   10.185538] TCP: reno registered
[   10.185548] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.185599] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.185850] NET: Registered protocol family 1
[   10.186178] RPC: Registered named UNIX socket transport module.
[   10.186183] RPC: Registered udp transport module.
[   10.186187] RPC: Registered tcp transport module.
[   10.186192] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.186371] Trying to unpack rootfs image as initramfs...
[   10.390773] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.391362] kvm [1]: Using HYP init bounce page @b7889000
[   10.391876] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.392301] kvm [1]: timer IRQ27
[   10.392315] kvm [1]: Hyp mode initialized successfully
[   10.394022] lock super standby defaultly!
[   10.394039] lookup_scene_lock_name: new scene lock super_standby
[   10.394044] scene_lock_init name=super_standby
[   10.394050] scene_lock: super_standby, type 5, count 1
[   10.394457] audit: initializing netlink socket (disabled)
[   10.394515] type=2000 audit(0.310:1): initialized
[   10.395200] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.395659] VFS: Disk quotas dquot_6.5.2
[   10.395759] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.396732] NFS: Registering the id_resolver key type
[   10.396776] Key type id_resolver registered
[   10.396781] Key type id_legacy registered
[   10.396792] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.396929] NTFS driver 2.1.30 [Flags: R/W].
[   10.397103] fuse init (API version 7.22)
[   10.397275] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.397698] msgmni has been set to 3973
[   10.398658] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.398738] io scheduler noop registered
[   10.398744] io scheduler deadline registered
[   10.398769] io scheduler cfq registered (default)
[   10.399352] [DISP]disp_module_init
[   10.399806] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.399814] [DISP] boot_disp:0x0
[   10.400419] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.400552] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.400682] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.401791] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.401797] [DISP] fb_base:0x0
[   10.419519] Console: switching to colour frame buffer device 160x45
[   10.433971] [DISP]disp_module_init finish
[   10.434397] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.434421] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.434779] console [ttyS0] enabled
[   10.435156] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.435588] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.435898] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.436183] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.436537] misc dump reg init
[   10.436689] [drm] Initialized drm 1.1.0 20060810
[   10.438834] brd: module loaded
[   10.440956] loop: module loaded
[   10.441229] sunxi-bt bt.27: Missing bt_power.
[   10.441237] sunxi-bt bt.27: bt_power_name ((null))
[   10.441245] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.441277] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.441319] sunxi-bt bt.27: clk not config
[   10.441391] sunxi-bt bt.27: block state already is 1
[   10.441578] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.441585] sunxi-wlan wlan.26: Missing wlan_power.
[   10.441592] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.441599] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.441614] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.441634] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.441651] sunxi-wlan wlan.26: clk not config
[   10.442352] WARNING: Get ephy clock is failed
[   10.442975] chipid-sunxi serial 140050374620201507cf
[   10.443071] PPP generic driver version 2.4.2
[   10.443224] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.443330] get ehci0-controller drv_vbus_gpio is fail
[   10.443336] get ehci0-controller, regulator_io is no nocare
[   10.443376] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.443431] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.443449] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.443815] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.454873] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.454942] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.454950] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.454957] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454963] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.454969] usb usb1: SerialNumber: sunxi-ehci
[   10.455331] hub 1-0:1.0: USB hub found
[   10.455347] hub 1-0:1.0: 1 port detected
[   10.455483] scene_lock_init name=ehci_standby
[   10.455557] get ehci1-controller drv_vbus_gpio is fail
[   10.455563] get ehci1-controller, regulator_io is no nocare
[   10.455603] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.455651] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.455671] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.455913] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.474556] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.474598] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.474606] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.474613] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.474619] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.474626] usb usb2: SerialNumber: sunxi-ehci
[   10.474903] hub 2-0:1.0: USB hub found
[   10.474917] hub 2-0:1.0: 1 port detected
[   10.475038] scene_lock_init name=ehci_standby
[   10.475225] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.475373] get ohci0-controller drv_vbus_gpio is fail
[   10.475378] get ohci0-controller, regulator_io is no nocare
[   10.475417] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.475463] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.475479] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.475510] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.537565] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.537573] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.537580] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.537587] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.537593] usb usb3: SerialNumber: sunxi-ohci
[   10.537865] hub 3-0:1.0: USB hub found
[   10.537879] hub 3-0:1.0: 1 port detected
[   10.537996] scene_lock_init name=ohci_standby
[   10.538060] get ohci1-controller drv_vbus_gpio is fail
[   10.538065] get ohci1-controller, regulator_io is no nocare
[   10.538099] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.538139] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.538156] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.538181] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.596596] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.596604] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.596611] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.596617] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.596624] usb usb4: SerialNumber: sunxi-ohci
[   10.596884] hub 4-0:1.0: USB hub found
[   10.596896] hub 4-0:1.0: 1 port detected
[   10.597012] scene_lock_init name=ohci_standby
[   10.597309] usbcore: registered new interface driver usb-storage
[   10.597341] usbcore: registered new interface driver ums-alauda
[   10.597368] usbcore: registered new interface driver ums-cypress
[   10.597393] usbcore: registered new interface driver ums-datafab
[   10.597417] usbcore: registered new interface driver ums_eneub6250
[   10.597440] usbcore: registered new interface driver ums-freecom
[   10.597465] usbcore: registered new interface driver ums-isd200
[   10.597488] usbcore: registered new interface driver ums-jumpshot
[   10.597510] usbcore: registered new interface driver ums-karma
[   10.597534] usbcore: registered new interface driver ums-onetouch
[   10.597569] usbcore: registered new interface driver ums-realtek
[   10.597594] usbcore: registered new interface driver ums-sddr09
[   10.597618] usbcore: registered new interface driver ums-sddr55
[   10.597642] usbcore: registered new interface driver ums-usbat
[   10.597728] usbcore: registered new interface driver usbserial
[   10.597754] usbcore: registered new interface driver usbserial_generic
[   10.597777] usbserial: USB Serial support registered for generic
[   10.597984] mousedev: PS/2 mouse device common for all mice
[   10.598422] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.599358] get ctp_para failed, -1
[   10.599376] get node gsensor failed
[   10.599380] get sysconfig para erro!
[   10.599389] get node lightsensor failed
[   10.599393] get sysconfig para erro!
[   10.599402] get node gyroscopesensor failed
[   10.599405] get sysconfig para erro!
[   10.599415] get node compasssensor failed
[   10.599418] get sysconfig para erro!
[   10.599702] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.599723] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.599889] i2c /dev entries driver
[   10.642402] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.645873] sunxi budget cooling probe start !
[   10.645904] CPU freq cooling register Success
[   10.645923] CPU hotplug cooling register Success
[   10.646012] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.646020] CPU budget cooling register Success
[   10.646233] sunxi gpu cooling probe start !
[   10.646243] CPU gpu cooling register Success
[   10.646898] cpuidle: using governor ladder
[   10.646905] cpuidle: using governor menu
[   10.647649] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.647678] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.647686] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.647695] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.647745] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.647752] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.648337] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.648360] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.599443] wakeup gpio set err!get node ctp failed
[   10.651734] get sysconfig para erro!
[   10.661504] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.681195] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.681569] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.681595] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.681603] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.681610] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.681615] get() with no identifier
[   10.681618] get() with no identifier
[   10.681622] get() with no identifier
[   10.681627] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.681633] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.681639] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.682016] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.682033] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.682051] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.682837] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.682857] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.685239] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.687369] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688183] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688995] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.689806] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.690433] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.690476] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.692851] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.700862] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.720551] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.721250] ledtrig-cpu: registered to indicate activity on CPUs
[   10.721319] hidraw: raw HID events driver (C) Jiri Kosina
[   10.721462] usbcore: registered new interface driver usbhid
[   10.721466] usbhid: USB HID core driver
[   10.722329] usbcore: registered new interface driver snd-usb-audio
[   10.724326] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.725125] TCP: cubic registered
[   10.725135] Initializing XFRM netlink socket
[   10.725214] NET: Registered protocol family 10
[   10.726026] mip6: Mobile IPv6
[   10.726034] sit: IPv6 over IPv4 tunneling driver
[   10.726413] NET: Registered protocol family 17
[   10.726434] NET: Registered protocol family 15
[   10.726482] 8021q: 802.1Q VLAN Support v1.8
[   10.726529] Key type dns_resolver registered
[   10.726736] Registering SWP/SWPB emulation handler
[   10.727025] registered taskstats version 1
[   10.738969] Key type encrypted registered
[   10.738993] AppArmor: AppArmor sha1 policy hashing enabled
[   10.739437] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.739446] [DISP] boot_disp:0x0
[   10.739491] HDMI base address: ffffff8000b40000
[   10.740272] [HDMI] power vcc-hdmi-33
[   10.740796] [HDMI] cec support = 0
[   10.759865] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.762361] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.762437] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.762541] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.762567] mmc0: new high speed SDHC card at address aaaa
[   10.762963] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.764993]  mmcblk0: p1
[   10.766111] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.766920] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.766939] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.769333] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.771150] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.771959] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772766] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.773573] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.774377] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.775184] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775991] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776798] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.777605] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.777621] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.778455] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.778471] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.851253] input: sunxi-ths as /devices/virtual/input/input2
[   10.851414] thermal thermal_zone0: failed to read out thermal zone 0
[   10.851835] ALSA device list:
[   10.851841]   #0: sndhdmi
[   10.852275] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.448729] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.135028] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.135043] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.135064] scene_lock_destroy name=ehci_standby
[   14.135077] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.135099] usb usb1: USB disconnect, device number 1
[   14.135655] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.135689] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.135698] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.135703] scene_lock_destroy name=ohci_standby
[   14.135710] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.135727] usb usb3: USB disconnect, device number 1
[   14.136100] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.136134] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.136144] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.136190] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.136214] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.139685] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.154738] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.154834] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.154842] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.154849] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.154855] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.154861] usb usb1: SerialNumber: sunxi-ehci
[   14.155331] hub 1-0:1.0: USB hub found
[   14.155350] hub 1-0:1.0: 1 port detected
[   14.155503] scene_lock_init name=ehci_standby
[   14.155511] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.155519] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.155573] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.155591] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.155637] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.217760] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.217776] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.217783] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.217789] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.217795] usb usb3: SerialNumber: sunxi-ohci
[   14.218259] hub 3-0:1.0: USB hub found
[   14.218279] hub 3-0:1.0: 1 port detected
[   14.218474] scene_lock_init name=ohci_standby
[   16.450944] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.835462] systemd[1]: System time before build time, advancing clock.
[   16.872651] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.872957] systemd[1]: Detected architecture arm64.
[   16.902797] systemd[1]: Set hostname to <cluster0>.
[   17.263739] systemd[1]: Listening on Syslog Socket.
[   17.284350] systemd[1]: Listening on Journal Socket.
[   17.303608] systemd[1]: Reached target Encrypted Volumes.
[   17.323380] systemd[1]: Listening on udev Control Socket.
[   17.342985] systemd[1]: Listening on udev Kernel Socket.
[   17.362985] systemd[1]: Created slice User and Session Slice.
[   17.382318] systemd[1]: Reached target Remote File Systems (Pre).
[   17.402243] systemd[1]: Created slice System Slice.
[   17.423417] systemd[1]: Mounting Debug File System...
[   17.443488] systemd[1]: Mounting Huge Pages File System...
[   17.464424] systemd[1]: Starting Restore / save the current clock...
[   17.480859] systemd[1]: Reached target Slices.
[   17.503171] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.522122] systemd[1]: Starting Set console keymap...
[   17.540652] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.566776] systemd[1]: Starting Load Kernel Modules...
[   17.591268] systemd[1]: Mounting POSIX Message Queue File System...
[   17.609232] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.628677] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.648210] systemd[1]: Reached target Swap.
[   17.668210] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.689270] systemd[1]: Starting Nameserver information manager...
[   17.707406] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.727145] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.746592] systemd[1]: Reached target Remote File Systems.
[   17.768530] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.782993] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.783285] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.783420] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.783595] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.784943] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.786274] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.800778] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.805650] systemd[1]: Reached target Paths.
[   17.830433] systemd[1]: Mounted Debug File System.
[   17.837854] cfg80211: Calling CRDA to update world regulatory domain
[   17.845103] systemd[1]: Mounted POSIX Message Queue File System.
[   17.864802] systemd[1]: Mounted Huge Pages File System.
[   17.885857] systemd[1]: Started Restore / save the current clock.
[   17.905401] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.924743] systemd[1]: Started Set console keymap.
[   17.949296] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.962214] RTL871X: module init start
[   17.962230] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.962234] RTL871X: build time: Feb  8 2019 10:22:36
[   17.962239] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.962255] sunxi-wlan wlan.26: bus_index: 1
[   17.962402] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.975030] systemd[1]: Started Nameserver information manager.
[   17.995593] systemd[1]: Time has been changed
[   18.070913] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.071073] RTL871X: module init ret=0
[   18.071100] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.074686] systemd[1]: Started Load Kernel Modules.
[   18.090768] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.111287] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.112131] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.112167] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.114624] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.116538] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.116940] systemd[1]: Mounting Configuration File System...
[   18.117397] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.118223] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.119051] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.119876] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.120713] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.121550] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.122369] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.123199] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.123248] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.124169] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.124202] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.142373] systemd[1]: Mounting FUSE Control File System...
[   18.161831] systemd[1]: Starting Apply Kernel Variables...
[   18.179527] systemd[1]: Reached target Network (Pre).
[   18.204641] systemd[1]: Starting udev Coldplug all Devices...
[   18.220934] systemd[1]: Starting Load/Save Random Seed...
[   18.241000] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.261689] systemd[1]: Mounted FUSE Control File System.
[   18.278009] systemd[1]: Mounted Configuration File System.
[   18.299534] systemd[1]: Started Apply Kernel Variables.
[   18.320026] systemd[1]: Started Load/Save Random Seed.
[   18.338068] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.415537] systemd[1]: Starting udev Kernel Device Manager...
[   18.435419] systemd[1]: Reached target Local File Systems (Pre).
[   18.457748] systemd[1]: Mounting /tmp...
[   18.478856] systemd[1]: Mounted /tmp.
[   18.495344] systemd[1]: Started udev Coldplug all Devices.
[   18.515448] systemd[1]: Started udev Kernel Device Manager.
[   18.557010] systemd[1]: Reached target Sound Card.
[   18.573157] systemd[1]: Reached target Local File Systems.
[   18.596002] systemd[1]: Starting Set console font and keymap...
[   18.619693] systemd[1]: Starting Raise network interfaces...
[   18.644369] systemd[1]: Starting Armbian ZRAM config...
[   18.693192] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.715833] cfg80211: World regulatory domain updated:
[   18.715860] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.715868] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.715874] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.715879] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.715884] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.715889] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.715894] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.715899] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.715905] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.718223] systemd[1]: Starting Journal Service...
[   18.792710] sunxi cedar version 0.1
[   18.792958] [cedar]: install start!!!
[   18.793127] ycy the get irq is 90
[   18.793568] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.793579] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.793585] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.793590] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.793595] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.793598] [cedar]: install end!!!
[   18.839293] systemd[1]: Found device /dev/ttyS0.
[   18.883632] [VFE]cci probe end cci_sel = 0!
[   18.883898] [VFE]cci_init end
[   18.908220] Driver for 1-wire Dallas network protocol.
[   18.929871] Registered IR keymap rc_map_sunxi
[   18.930465] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.930728] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.949424] systemd[1]: Started Journal Service.
[   18.999488] lirc_dev: IR Remote Control driver registered, major 248
[   18.999823] [VFE]Welcome to Video Front End driver
[   19.000219] [VFE]csi probe end csi_sel = 0!
[   19.000492] [VFE]csi_init end
[   19.000968] [VFE]isp probe start isp_sel = 0!
[   19.009428] [ISP] isp platform_id = 3!
[   19.009462] [VFE]isp probe end isp_sel = 0!
[   19.009567] [VFE]sunxi_isp_platform_register end
[   19.010101] [VFE]mipi probe start mipi_sel = 0!
[   19.010139] [VFE]mipi probe end mipi_sel = 0!
[   19.010225] [VFE]mipi_init end
[   19.010232] [VFE]flash_init end
[   19.010650] [VFE]vfe_init end
[   19.027356] IR RC5(x) protocol handler initialized
[   19.027359] IR NEC protocol handler initialized
[   19.028841] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   19.029924] IR MCE Keyboard/mouse protocol handler initialized
[   19.029928] IR Sony protocol handler initialized
[   19.030612] IR RC6 protocol handler initialized
[   19.031149] IR SANYO protocol handler initialized
[   19.031574] IR JVC protocol handler initialized
[   19.031869] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   19.031874] IR LIRC bridge handler initialized
[   19.235719] systemd-journald[301]: Received request to flush runtime journal from PID 1
[   19.291128] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.311625] zram: Created 6 device(s) ...
[   19.358596] sunxi-bt bt.27: block state already is 1
[   19.451355] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.485425] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.524622] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.550814] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.760879] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.760900] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035016 kB
MemFree:         1879940 kB
Buffers:            9248 kB
Cached:            59388 kB
SwapCached:            0 kB
Active:            36500 kB
Inactive:          53948 kB
Active(anon):      22252 kB
Inactive(anon):     2860 kB
Active(file):      14248 kB
Inactive(file):    51088 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017504 kB
SwapFree:        1017504 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         21848 kB
Mapped:            16480 kB
Shmem:              3028 kB
Slab:              24252 kB
SReclaimable:      10448 kB
SUnreclaim:        13804 kB
PageTables:          536 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035012 kB
Committed_AS:     117676 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633452 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5606
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 62493
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
tmpfs           994M     0  994M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           994M     0  994M   0% /sys/fs/cgroup
tmpfs           994M  4.0K  994M   1% /tmp
/dev/zram0       49M  4.8M   41M  11% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M  4.4M  1.5M  2.4M         /var/log
/dev/zram1             248.4M    4K   78B    4K         [SWAP]
/dev/zram2             248.4M    4K   78B    4K         [SWAP]
/dev/zram3             248.4M    4K   78B    4K         [SWAP]
/dev/zram4             248.4M    4K   78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
01:06:32: 1152MHz  0.00  36%  12%  16%   0%   7%   0%   33°C   21°C  0/7
01:06:32: 1152MHz  0.00  45%   5%   4%   1%  34%   0%   30°C   21°C  0/7
01:06:33: 1152MHz  0.00  28%   2%   2%   2%  21%   0%   30°C   21°C  0/7
01:06:33: 1152MHz  0.00  28%   4%   1%   0%  22%   0%   29°C   21°C  0/7
01:06:33: 1152MHz  0.24  32%   5%  22%   1%   1%   0%   29°C   21°C  0/7
Thu Mar  7 23:06:57 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.079920] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.079929] pid_max: default: 32768 minimum: 301
[   10.080023] Security Framework initialized
[   10.080070] AppArmor: AppArmor initialized
[   10.080105] Mount-cache hash table entries: 256
[   10.090460] Initializing cgroup subsys memory
[   10.090506] Initializing cgroup subsys devices
[   10.090514] Initializing cgroup subsys freezer
[   10.090520] Initializing cgroup subsys blkio
[   10.090525] Initializing cgroup subsys perf_event
[   10.090536] Initializing cgroup subsys hugetlb
[   10.090599] ftrace: allocating 28898 entries in 113 pages
[   10.124347] CPU0: update cpu_power 1968128
[   10.124369] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.125357] virtual base = 0xffffff800000a000.
[   10.125370] gicd_base = 0xffffff800000c000.
[   10.125375] gicc_base = 0xffffff800000e000.
[   10.126008] CPU1: Booted secondary processor
[   10.126034] CPU1: update cpu_power 1968128
[   10.128632] CPU2: Booted secondary processor
[   10.128643] CPU2: update cpu_power 1968128
[   10.132749] CPU3: Booted secondary processor
[   10.132760] CPU3: update cpu_power 1968128
[   10.132831] Brought up 4 CPUs
[   10.132852] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.133355] devtmpfs: initialized
[   10.138345] pinctrl core: initialized pinctrl subsystem
[   10.140787] NET: Registered protocol family 16
[   10.141030] script_sysfs_init success
[   10.141264] dump_class_init,806, success
[   10.141499] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.141519] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.142800] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.143792] DMA: preallocated 256 KiB pool for atomic allocations
[   10.143907] Serial: AMBA PL011 UART driver
[   10.144000] axp81x_board_init: axp regl_devs num = 23
[   10.144155] pll_audio-set_default_rate=24576000 success!
[   10.144174] pll_video0-set_default_rate=297000000 success!
[   10.144241] pll_video1-set_default_rate=297000000 success!
[   10.144302] pll_de-set_default_rate=297000000 success!
[   10.145016] de-set_default_source=pll_de success!
[   10.145022] de-set_default_rate=297000000 success!
[   10.145068] tcon0-set_default_source=pll_mipi success!
[   10.145099] tcon1-set_default_source=pll_video0 success!
[   10.145313] hdmi-set_default_source=pll_video0 success!
[   10.147545] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.147706] [sun50iw1p1_pinctrl_probe][838]
[   10.149137] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.149755] sunxi hwspinlock vbase:0xffffff800005c000
[   10.159930] bio: create slab <bio-0> at 0
[   10.160316] pwm module init!
[   10.161534] SCSI subsystem initialized
[   10.161651] usbcore: registered new interface driver usbfs
[   10.161686] usbcore: registered new interface driver hub
[   10.161756] usbcore: registered new device driver usb
[   10.162457] Linux video capture interface: v2.00
[   10.162923] [ARISC] :sunxi-arisc driver v1.10
[   10.169816] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.170065] Advanced Linux Sound Architecture Driver Initialized.
[   10.170424] NetLabel: Initializing
[   10.170430] NetLabel:  domain hash size = 128
[   10.170434] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.170475] NetLabel:  unlabeled traffic allowed by default
[   10.170632] [pm]aw_pm_init!
[   10.170699] rtc physical base = 0x0000000001f00000 .
[   10.170731] np name = /soc@01c00000/rtc@01f00000.
[   10.170737] base = ffffff800006e100, len = 4.
[   10.170742] pmu name: pmu0 .
[   10.170777] pmu0_enable = 0x1.
[   10.170783] pmux_id = 0x6.
[   10.170789] pmux_twi_id = 0x1.
[   10.170795] pmux_twi_addr = 0x34.
[   10.170799] pmu name: pmu1 .
[   10.170847] Warning: can not find np for pmu1.
[   10.171075] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.171235] after inited: sys_mask config = 0x4a55.
[   10.171257] Warning: can not find np for dynamic_standby_para.
[   10.171388] [pm]valid
[   10.171392] [pm]valid
[   10.171396] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.171589] Switching to clocksource arch_sys_counter_ool
[   10.189561] AppArmor: AppArmor Filesystem Enabled
[   10.195686] NET: Registered protocol family 2
[   10.196365] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.196605] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.196918] TCP: Hash tables configured (established 16384 bind 16384)
[   10.197003] TCP: reno registered
[   10.197014] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.197066] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.197333] NET: Registered protocol family 1
[   10.197656] RPC: Registered named UNIX socket transport module.
[   10.197662] RPC: Registered udp transport module.
[   10.197667] RPC: Registered tcp transport module.
[   10.197671] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.197845] Trying to unpack rootfs image as initramfs...
[   10.402370] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.402955] kvm [1]: Using HYP init bounce page @b789e000
[   10.403476] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.403892] kvm [1]: timer IRQ27
[   10.403905] kvm [1]: Hyp mode initialized successfully
[   10.405567] lock super standby defaultly!
[   10.405583] lookup_scene_lock_name: new scene lock super_standby
[   10.405588] scene_lock_init name=super_standby
[   10.405594] scene_lock: super_standby, type 5, count 1
[   10.405999] audit: initializing netlink socket (disabled)
[   10.406049] type=2000 audit(0.310:1): initialized
[   10.406735] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.407209] VFS: Disk quotas dquot_6.5.2
[   10.407312] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.408312] NFS: Registering the id_resolver key type
[   10.408356] Key type id_resolver registered
[   10.408360] Key type id_legacy registered
[   10.408372] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.408510] NTFS driver 2.1.30 [Flags: R/W].
[   10.408685] fuse init (API version 7.22)
[   10.408864] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.409287] msgmni has been set to 3973
[   10.410277] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.410356] io scheduler noop registered
[   10.410362] io scheduler deadline registered
[   10.410396] io scheduler cfq registered (default)
[   10.410974] [DISP]disp_module_init
[   10.411427] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.411434] [DISP] boot_disp:0x0
[   10.412035] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.412168] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.412298] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.413404] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.413410] [DISP] fb_base:0x0
[   10.431117] Console: switching to colour frame buffer device 160x45
[   10.445579] [DISP]disp_module_init finish
[   10.445998] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.446022] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.446380] console [ttyS0] enabled
[   10.446758] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.446984] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.447448] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.447741] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.448092] misc dump reg init
[   10.448244] [drm] Initialized drm 1.1.0 20060810
[   10.450355] brd: module loaded
[   10.452498] loop: module loaded
[   10.452773] sunxi-bt bt.27: Missing bt_power.
[   10.452781] sunxi-bt bt.27: bt_power_name ((null))
[   10.452788] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.452820] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.452862] sunxi-bt bt.27: clk not config
[   10.452932] sunxi-bt bt.27: block state already is 1
[   10.453111] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.453119] sunxi-wlan wlan.26: Missing wlan_power.
[   10.453125] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.453133] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.453148] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.453166] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.453184] sunxi-wlan wlan.26: clk not config
[   10.453880] WARNING: Get ephy clock is failed
[   10.454504] chipid-sunxi serial 140050374620201507cf
[   10.454598] PPP generic driver version 2.4.2
[   10.454752] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454858] get ehci0-controller drv_vbus_gpio is fail
[   10.454864] get ehci0-controller, regulator_io is no nocare
[   10.454902] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.454958] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454977] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.455375] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.466853] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.466934] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.466943] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.466949] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.466956] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.466962] usb usb1: SerialNumber: sunxi-ehci
[   10.467294] hub 1-0:1.0: USB hub found
[   10.467310] hub 1-0:1.0: 1 port detected
[   10.467452] scene_lock_init name=ehci_standby
[   10.467524] get ehci1-controller drv_vbus_gpio is fail
[   10.467530] get ehci1-controller, regulator_io is no nocare
[   10.467571] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.467620] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.467635] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.467877] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.486536] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.486578] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.486586] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.486592] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.486599] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.486605] usb usb2: SerialNumber: sunxi-ehci
[   10.486877] hub 2-0:1.0: USB hub found
[   10.486890] hub 2-0:1.0: 1 port detected
[   10.487008] scene_lock_init name=ehci_standby
[   10.487193] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.487337] get ohci0-controller drv_vbus_gpio is fail
[   10.487342] get ohci0-controller, regulator_io is no nocare
[   10.487381] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.487429] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.487444] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.487474] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.549544] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.549552] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.549559] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.549566] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.549572] usb usb3: SerialNumber: sunxi-ohci
[   10.549855] hub 3-0:1.0: USB hub found
[   10.549870] hub 3-0:1.0: 1 port detected
[   10.549988] scene_lock_init name=ohci_standby
[   10.550052] get ohci1-controller drv_vbus_gpio is fail
[   10.550058] get ohci1-controller, regulator_io is no nocare
[   10.550093] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.550133] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.550148] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.550172] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.608605] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.608613] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.608620] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.608627] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.608633] usb usb4: SerialNumber: sunxi-ohci
[   10.608913] hub 4-0:1.0: USB hub found
[   10.608925] hub 4-0:1.0: 1 port detected
[   10.609041] scene_lock_init name=ohci_standby
[   10.609341] usbcore: registered new interface driver usb-storage
[   10.609374] usbcore: registered new interface driver ums-alauda
[   10.609398] usbcore: registered new interface driver ums-cypress
[   10.609424] usbcore: registered new interface driver ums-datafab
[   10.609450] usbcore: registered new interface driver ums_eneub6250
[   10.609474] usbcore: registered new interface driver ums-freecom
[   10.609498] usbcore: registered new interface driver ums-isd200
[   10.609521] usbcore: registered new interface driver ums-jumpshot
[   10.609549] usbcore: registered new interface driver ums-karma
[   10.609573] usbcore: registered new interface driver ums-onetouch
[   10.609604] usbcore: registered new interface driver ums-realtek
[   10.609629] usbcore: registered new interface driver ums-sddr09
[   10.609656] usbcore: registered new interface driver ums-sddr55
[   10.609681] usbcore: registered new interface driver ums-usbat
[   10.609765] usbcore: registered new interface driver usbserial
[   10.609792] usbcore: registered new interface driver usbserial_generic
[   10.609814] usbserial: USB Serial support registered for generic
[   10.610010] mousedev: PS/2 mouse device common for all mice
[   10.610471] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.611304] get ctp_para failed, -1
[   10.611324] get node gsensor failed
[   10.611328] get sysconfig para erro!
[   10.611338] get node lightsensor failed
[   10.611341] get sysconfig para erro!
[   10.611350] get node gyroscopesensor failed
[   10.611354] get sysconfig para erro!
[   10.611363] get node compasssensor failed
[   10.611366] get sysconfig para erro!
[   10.611661] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.611681] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.611845] i2c /dev entries driver
[   10.654382] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.657837] sunxi budget cooling probe start !
[   10.657871] CPU freq cooling register Success
[   10.657890] CPU hotplug cooling register Success
[   10.657980] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.657988] CPU budget cooling register Success
[   10.658201] sunxi gpu cooling probe start !
[   10.658211] CPU gpu cooling register Success
[   10.658868] cpuidle: using governor ladder
[   10.658875] cpuidle: using governor menu
[   10.659624] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.659653] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.659661] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.659670] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.659716] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.659722] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.660305] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.660326] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.611393] wakeup gpio set err!get node ctp failed
[   10.663702] get sysconfig para erro!
[   10.673484] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.693174] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.693558] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.693584] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.693591] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.693598] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.693603] get() with no identifier
[   10.693607] get() with no identifier
[   10.693610] get() with no identifier
[   10.693616] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.693622] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.693628] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.693982] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.693996] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.694001] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.694819] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.694839] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.697223] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.699359] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.700170] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.700982] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.701794] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.702417] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.702461] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.704836] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.712843] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.732530] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.733234] ledtrig-cpu: registered to indicate activity on CPUs
[   10.733304] hidraw: raw HID events driver (C) Jiri Kosina
[   10.733430] usbcore: registered new interface driver usbhid
[   10.733434] usbhid: USB HID core driver
[   10.734335] usbcore: registered new interface driver snd-usb-audio
[   10.736401] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.737216] TCP: cubic registered
[   10.737226] Initializing XFRM netlink socket
[   10.737310] NET: Registered protocol family 10
[   10.738112] mip6: Mobile IPv6
[   10.738121] sit: IPv6 over IPv4 tunneling driver
[   10.738501] NET: Registered protocol family 17
[   10.738524] NET: Registered protocol family 15
[   10.738567] 8021q: 802.1Q VLAN Support v1.8
[   10.738611] Key type dns_resolver registered
[   10.738819] Registering SWP/SWPB emulation handler
[   10.739107] registered taskstats version 1
[   10.751080] Key type encrypted registered
[   10.751103] AppArmor: AppArmor sha1 policy hashing enabled
[   10.751543] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.751551] [DISP] boot_disp:0x0
[   10.751597] HDMI base address: ffffff8000b40000
[   10.752391] [HDMI] power vcc-hdmi-33
[   10.752918] [HDMI] cec support = 0
[   10.771848] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.774346] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.774421] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.774526] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.774552] mmc0: new high speed SDHC card at address aaaa
[   10.774978] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.777004]  mmcblk0: p1
[   10.778113] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.778921] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.778939] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.781332] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.783149] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.783958] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.784765] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.785571] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.786376] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.787183] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.787990] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.788797] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.789604] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.789620] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.790454] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.790471] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.863377] input: sunxi-ths as /devices/virtual/input/input2
[   10.863532] thermal thermal_zone0: failed to read out thermal zone 0
[   10.863945] ALSA device list:
[   10.863951]   #0: sndhdmi
[   10.864395] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.460701] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.147013] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.147028] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.147048] scene_lock_destroy name=ehci_standby
[   14.147062] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.147084] usb usb1: USB disconnect, device number 1
[   14.147641] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.147673] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.147681] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.147686] scene_lock_destroy name=ohci_standby
[   14.147694] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.147710] usb usb3: USB disconnect, device number 1
[   14.148080] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.148115] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.148124] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.148171] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.148196] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.151674] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.166713] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.166809] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.166817] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.166824] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.166831] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.166837] usb usb1: SerialNumber: sunxi-ehci
[   14.167310] hub 1-0:1.0: USB hub found
[   14.167329] hub 1-0:1.0: 1 port detected
[   14.167479] scene_lock_init name=ehci_standby
[   14.167487] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.167495] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.167547] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.167566] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.167611] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.229747] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.229763] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.229771] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.229777] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.229784] usb usb3: SerialNumber: sunxi-ohci
[   14.230257] hub 3-0:1.0: USB hub found
[   14.230280] hub 3-0:1.0: 1 port detected
[   14.230461] scene_lock_init name=ohci_standby
[   16.415547] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.797085] systemd[1]: System time before build time, advancing clock.
[   16.834192] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.834503] systemd[1]: Detected architecture arm64.
[   16.865602] systemd[1]: Set hostname to <cluster0>.
[   17.255562] systemd[1]: Listening on udev Control Socket.
[   17.276256] systemd[1]: Reached target Swap.
[   17.295965] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.315808] systemd[1]: Listening on Journal Socket.
[   17.335346] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.355320] systemd[1]: Created slice System Slice.
[   17.376210] systemd[1]: Mounting RPC Pipe File System...
[   17.396398] systemd[1]: Mounting Huge Pages File System...
[   17.416433] systemd[1]: Starting Nameserver information manager...
[   17.435646] systemd[1]: Starting Set console keymap...
[   17.454101] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.473456] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.493109] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.512556] systemd[1]: Reached target Paths.
[   17.532252] systemd[1]: Listening on Syslog Socket.
[   17.551983] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.577100] systemd[1]: Starting Load Kernel Modules...
[   17.597241] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.626168] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.652787] systemd[1]: Mounting Debug File System...
[   17.672119] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.692316] systemd[1]: Mounting POSIX Message Queue File System...
[   17.699600] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.709316] systemd[1]: Reached target Encrypted Volumes.
[   17.729437] systemd[1]: Created slice User and Session Slice.
[   17.748636] systemd[1]: Reached target Slices.
[   17.780482] systemd[1]: Starting Restore / save the current clock...
[   17.791592] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.791908] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.792063] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.792195] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.793332] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.798025] systemd[1]: Listening on udev Kernel Socket.
[   17.822011] systemd[1]: Mounted RPC Pipe File System.
[   17.837480] systemd[1]: Mounted Debug File System.
[   17.857257] systemd[1]: Mounted POSIX Message Queue File System.
[   17.858312] cfg80211: Calling CRDA to update world regulatory domain
[   17.876759] systemd[1]: Mounted Huge Pages File System.
[   17.900736] systemd[1]: Started Set console keymap.
[   17.917479] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.937015] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.956579] systemd[1]: Started Restore / save the current clock.
[   17.977853] systemd[1]: Started Nameserver information manager.
[   17.978380] RTL871X: module init start
[   17.978392] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.978397] RTL871X: build time: Feb  8 2019 10:22:36
[   17.978402] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.978417] sunxi-wlan wlan.26: bus_index: 1
[   17.978579] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.993386] systemd[1]: Time has been changed
[   18.081092] systemd[1]: Reached target Network (Pre).
[   18.086941] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.087050] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.087184] RTL871X: module init ret=0
[   18.102780] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.107066] systemd[1]: Starting udev Coldplug all Devices...
[   18.123246] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.124080] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.124119] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.124785] systemd[1]: Starting Load/Save Random Seed...
[   18.126574] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.128456] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.129292] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.130102] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.130912] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.131721] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.132535] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.133348] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.134157] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.134963] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.134985] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.135882] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.135908] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.145114] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.162601] systemd[1]: Started Load Kernel Modules.
[   18.185570] systemd[1]: Started Load/Save Random Seed.
[   18.202332] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.262983] systemd[1]: Reached target Local File Systems (Pre).
[   18.284733] systemd[1]: Mounting /tmp...
[   18.302282] systemd[1]: Starting udev Kernel Device Manager...
[   18.321503] systemd[1]: Mounting FUSE Control File System...
[   18.341308] systemd[1]: Mounting Configuration File System...
[   18.350556] systemd[1]: Starting Apply Kernel Variables...
[   18.372371] systemd[1]: Mounted FUSE Control File System.
[   18.388504] systemd[1]: Mounted Configuration File System.
[   18.408078] systemd[1]: Mounted /tmp.
[   18.428411] systemd[1]: Started udev Kernel Device Manager.
[   18.448281] systemd[1]: Started udev Coldplug all Devices.
[   18.469106] systemd[1]: Started Apply Kernel Variables.
[   18.529572] cfg80211: World regulatory domain updated:
[   18.529592] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.529598] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.529604] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.529609] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.529614] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.529619] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.529624] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.529629] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.529635] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.545832] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.549872] sunxi cedar version 0.1
[   18.550102] [cedar]: install start!!!
[   18.550231] ycy the get irq is 90
[   18.550569] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.550578] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.550583] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.550588] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.550593] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.550597] [cedar]: install end!!!
[   18.569963] systemd[1]: Starting Journal Service...
[   18.585159] systemd[1]: Reached target Local File Systems.
[   18.607515] systemd[1]: Starting Armbian ZRAM config...
[   18.627630] systemd[1]: Starting Preprocess NFS configuration...
[   18.635913] Driver for 1-wire Dallas network protocol.
[   18.672374] [VFE]cci probe end cci_sel = 0!
[   18.672659] [VFE]cci_init end
[   18.678408] Registered IR keymap rc_map_sunxi
[   18.678913] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.679219] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.692509] systemd[1]: Starting Raise network interfaces...
[   18.716154] systemd[1]: Starting Set console font and keymap...
[   18.729446] systemd[1]: Found device /dev/ttyS0.
[   18.761560] IR NEC protocol handler initialized
[   18.763761] IR JVC protocol handler initialized
[   18.785623] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.801684] systemd[1]: Reached target Sound Card.
[   18.826849] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   18.851652] systemd[1]: Started Preprocess NFS configuration.
[   18.881777] systemd[1]: Reached target NFS client services.
[   18.889331] systemd[1]: Reached target Remote File Systems (Pre).
[   18.910597] systemd[1]: Started Journal Service.
[   18.953381] lirc_dev: IR Remote Control driver registered, major 248
[   18.956269] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.956290] IR LIRC bridge handler initialized
[   18.957806] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.958153] IR MCE Keyboard/mouse protocol handler initialized
[   18.958307] IR RC5(x) protocol handler initialized
[   18.960074] IR SANYO protocol handler initialized
[   18.960077] IR Sony protocol handler initialized
[   18.960498] IR RC6 protocol handler initialized
[   19.011025] systemd-journald[321]: Received request to flush runtime journal from PID 1
[   19.204700] [VFE]Welcome to Video Front End driver
[   19.209319] [VFE]csi probe end csi_sel = 0!
[   19.209983] [VFE]csi_init end
[   19.212442] [VFE]isp probe start isp_sel = 0!
[   19.213637] [ISP] isp platform_id = 3!
[   19.213666] [VFE]isp probe end isp_sel = 0!
[   19.213798] [VFE]sunxi_isp_platform_register end
[   19.214366] [VFE]mipi probe start mipi_sel = 0!
[   19.214401] [VFE]mipi probe end mipi_sel = 0!
[   19.214453] [VFE]mipi_init end
[   19.214459] [VFE]flash_init end
[   19.214965] [VFE]vfe_init end
[   19.244743] sunxi-bt bt.27: block state already is 1
[   19.276166] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.295675] zram: Created 6 device(s) ...
[   19.434425] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.462000] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.499488] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.525708] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.724798] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.724819] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1888760 kB
Buffers:            9596 kB
Cached:            57196 kB
SwapCached:            0 kB
Active:            29016 kB
Inactive:          53344 kB
Active(anon):      15896 kB
Inactive(anon):     2844 kB
Active(file):      13120 kB
Inactive(file):    50500 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         15816 kB
Mapped:            14448 kB
Shmem:              3052 kB
Slab:              23840 kB
SReclaimable:      10272 kB
SUnreclaim:        13568 kB
KernelStack:        1888 kB
PageTables:          560 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:      76512 kB
VmallocChunk:   251633436 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62496
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
/dev/mmcblk0p1   15G  961M   14G   7% /
/dev/zram0       49M  5.1M   40M  12% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  4.8M  1.6M  2.5M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
23:07:00: 1008MHz  0.24  36%  11%  15%   0%   9%   0%   29°C   20°C  0/7
23:07:00: 1008MHz  0.24  61%  18%   7%   0%  34%   0%   28°C   20°C  0/7
23:07:00: 1152MHz  0.24  44%  14%   5%   0%  24%   0%   28°C   20°C  0/7
23:07:01: 1152MHz  0.24  33%   6%   4%   1%  21%   0%   28°C   20°C  0/7
23:07:01: 1152MHz  0.30  29%   3%  25%   0%   0%   0%   29°C   20°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Fri Mar  8 03:27:06 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@armbian.com) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #2 SMP PREEMPT Fri Feb 8 10:23:10 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s19520 r8192 d21440 u49152
[    0.000000] pcpu-alloc: s19520 r8192 d21440 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1964644k/1964644k available, 116124k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000b59000 - 0xffffffc000be0c40   (   544 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000b58164   ( 11105 kB)
                     .data : 0xffffffc000be1000 - 0xffffffc000d50e48   (  1472 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.066229] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.066238] pid_max: default: 32768 minimum: 301
[   10.066331] Security Framework initialized
[   10.066381] AppArmor: AppArmor initialized
[   10.066416] Mount-cache hash table entries: 256
[   10.076766] Initializing cgroup subsys memory
[   10.076815] Initializing cgroup subsys devices
[   10.076822] Initializing cgroup subsys freezer
[   10.076828] Initializing cgroup subsys blkio
[   10.076834] Initializing cgroup subsys perf_event
[   10.076844] Initializing cgroup subsys hugetlb
[   10.076909] ftrace: allocating 28898 entries in 113 pages
[   10.110663] CPU0: update cpu_power 1968128
[   10.110684] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.111674] virtual base = 0xffffff800000a000.
[   10.111687] gicd_base = 0xffffff800000c000.
[   10.111691] gicc_base = 0xffffff800000e000.
[   10.112318] CPU1: Booted secondary processor
[   10.112345] CPU1: update cpu_power 1968128
[   10.114943] CPU2: Booted secondary processor
[   10.114954] CPU2: update cpu_power 1968128
[   10.119062] CPU3: Booted secondary processor
[   10.119073] CPU3: update cpu_power 1968128
[   10.119146] Brought up 4 CPUs
[   10.119166] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.119669] devtmpfs: initialized
[   10.124644] pinctrl core: initialized pinctrl subsystem
[   10.127091] NET: Registered protocol family 16
[   10.127347] script_sysfs_init success
[   10.127584] dump_class_init,806, success
[   10.127826] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.127847] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.129124] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.130171] DMA: preallocated 256 KiB pool for atomic allocations
[   10.130287] Serial: AMBA PL011 UART driver
[   10.130392] axp81x_board_init: axp regl_devs num = 23
[   10.130534] pll_audio-set_default_rate=24576000 success!
[   10.130553] pll_video0-set_default_rate=297000000 success!
[   10.130626] pll_video1-set_default_rate=297000000 success!
[   10.130686] pll_de-set_default_rate=297000000 success!
[   10.131394] de-set_default_source=pll_de success!
[   10.131400] de-set_default_rate=297000000 success!
[   10.131442] tcon0-set_default_source=pll_mipi success!
[   10.131472] tcon1-set_default_source=pll_video0 success!
[   10.131686] hdmi-set_default_source=pll_video0 success!
[   10.133912] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.134070] [sun50iw1p1_pinctrl_probe][838]
[   10.135510] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.136130] sunxi hwspinlock vbase:0xffffff800005c000
[   10.146353] bio: create slab <bio-0> at 0
[   10.146696] pwm module init!
[   10.147920] SCSI subsystem initialized
[   10.148043] usbcore: registered new interface driver usbfs
[   10.148078] usbcore: registered new interface driver hub
[   10.148143] usbcore: registered new device driver usb
[   10.148844] Linux video capture interface: v2.00
[   10.149284] [ARISC] :sunxi-arisc driver v1.10
[   10.156234] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.156483] Advanced Linux Sound Architecture Driver Initialized.
[   10.156825] NetLabel: Initializing
[   10.156830] NetLabel:  domain hash size = 128
[   10.156834] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.156873] NetLabel:  unlabeled traffic allowed by default
[   10.157036] [pm]aw_pm_init!
[   10.157101] rtc physical base = 0x0000000001f00000 .
[   10.157135] np name = /soc@01c00000/rtc@01f00000.
[   10.157141] base = ffffff800006e100, len = 4.
[   10.157146] pmu name: pmu0 .
[   10.157181] pmu0_enable = 0x1.
[   10.157187] pmux_id = 0x6.
[   10.157193] pmux_twi_id = 0x1.
[   10.157199] pmux_twi_addr = 0x34.
[   10.157203] pmu name: pmu1 .
[   10.157251] Warning: can not find np for pmu1.
[   10.157480] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.157642] after inited: sys_mask config = 0x4a55.
[   10.157663] Warning: can not find np for dynamic_standby_para.
[   10.157794] [pm]valid
[   10.157798] [pm]valid
[   10.157802] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.158006] Switching to clocksource arch_sys_counter_ool
[   10.176001] AppArmor: AppArmor Filesystem Enabled
[   10.182612] NET: Registered protocol family 2
[   10.183297] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.183537] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.183847] TCP: Hash tables configured (established 16384 bind 16384)
[   10.183932] TCP: reno registered
[   10.183942] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.183994] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.184243] NET: Registered protocol family 1
[   10.184575] RPC: Registered named UNIX socket transport module.
[   10.184580] RPC: Registered udp transport module.
[   10.184585] RPC: Registered tcp transport module.
[   10.184589] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.184765] Trying to unpack rootfs image as initramfs...
[   10.389321] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.389909] kvm [1]: Using HYP init bounce page @b7889000
[   10.390444] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.390862] kvm [1]: timer IRQ27
[   10.390878] kvm [1]: Hyp mode initialized successfully
[   10.392589] lock super standby defaultly!
[   10.392604] lookup_scene_lock_name: new scene lock super_standby
[   10.392609] scene_lock_init name=super_standby
[   10.392616] scene_lock: super_standby, type 5, count 1
[   10.393031] audit: initializing netlink socket (disabled)
[   10.393089] type=2000 audit(0.310:1): initialized
[   10.393770] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.394274] VFS: Disk quotas dquot_6.5.2
[   10.394377] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.395314] NFS: Registering the id_resolver key type
[   10.395360] Key type id_resolver registered
[   10.395365] Key type id_legacy registered
[   10.395378] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.395515] NTFS driver 2.1.30 [Flags: R/W].
[   10.395691] fuse init (API version 7.22)
[   10.395863] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.396283] msgmni has been set to 3973
[   10.397237] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.397318] io scheduler noop registered
[   10.397323] io scheduler deadline registered
[   10.397348] io scheduler cfq registered (default)
[   10.397938] [DISP]disp_module_init
[   10.398389] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.398397] [DISP] boot_disp:0x0
[   10.398986] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.399118] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.399249] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.400356] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.400362] [DISP] fb_base:0x0
[   10.418077] Console: switching to colour frame buffer device 160x45
[   10.432530] [DISP]disp_module_init finish
[   10.432950] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.432973] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.433331] console [ttyS0] enabled
[   10.433908] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.434155] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.434466] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.434750] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.435109] misc dump reg init
[   10.435264] [drm] Initialized drm 1.1.0 20060810
[   10.437410] brd: module loaded
[   10.439525] loop: module loaded
[   10.439802] sunxi-bt bt.27: Missing bt_power.
[   10.439810] sunxi-bt bt.27: bt_power_name ((null))
[   10.439818] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.439852] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.439896] sunxi-bt bt.27: clk not config
[   10.439967] sunxi-bt bt.27: block state already is 1
[   10.440156] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.440163] sunxi-wlan wlan.26: Missing wlan_power.
[   10.440169] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.440176] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.440192] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.440211] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.440229] sunxi-wlan wlan.26: clk not config
[   10.440931] WARNING: Get ephy clock is failed
[   10.441561] chipid-sunxi serial 140050374620201507cf
[   10.441654] PPP generic driver version 2.4.2
[   10.441804] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.441911] get ehci0-controller drv_vbus_gpio is fail
[   10.441917] get ehci0-controller, regulator_io is no nocare
[   10.441957] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.442011] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.442030] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.442387] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.453266] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.453336] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.453344] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.453351] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453357] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.453363] usb usb1: SerialNumber: sunxi-ehci
[   10.453721] hub 1-0:1.0: USB hub found
[   10.453738] hub 1-0:1.0: 1 port detected
[   10.453875] scene_lock_init name=ehci_standby
[   10.453949] get ehci1-controller drv_vbus_gpio is fail
[   10.453955] get ehci1-controller, regulator_io is no nocare
[   10.453997] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.454045] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454064] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.454306] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.472951] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.472993] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.473000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.473007] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.473014] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.473020] usb usb2: SerialNumber: sunxi-ehci
[   10.473299] hub 2-0:1.0: USB hub found
[   10.473312] hub 2-0:1.0: 1 port detected
[   10.473433] scene_lock_init name=ehci_standby
[   10.473619] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.473763] get ohci0-controller drv_vbus_gpio is fail
[   10.473769] get ohci0-controller, regulator_io is no nocare
[   10.473808] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.473856] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.473872] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.473901] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.535960] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.535968] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.535975] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.535982] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.535988] usb usb3: SerialNumber: sunxi-ohci
[   10.536259] hub 3-0:1.0: USB hub found
[   10.536273] hub 3-0:1.0: 1 port detected
[   10.536389] scene_lock_init name=ohci_standby
[   10.536450] get ohci1-controller drv_vbus_gpio is fail
[   10.536455] get ohci1-controller, regulator_io is no nocare
[   10.536490] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.536529] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.536546] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.536573] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.594989] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.594997] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.595004] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.595010] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.595017] usb usb4: SerialNumber: sunxi-ohci
[   10.595279] hub 4-0:1.0: USB hub found
[   10.595293] hub 4-0:1.0: 1 port detected
[   10.595409] scene_lock_init name=ohci_standby
[   10.595707] usbcore: registered new interface driver usb-storage
[   10.595737] usbcore: registered new interface driver ums-alauda
[   10.595764] usbcore: registered new interface driver ums-cypress
[   10.595789] usbcore: registered new interface driver ums-datafab
[   10.595812] usbcore: registered new interface driver ums_eneub6250
[   10.595836] usbcore: registered new interface driver ums-freecom
[   10.595860] usbcore: registered new interface driver ums-isd200
[   10.595883] usbcore: registered new interface driver ums-jumpshot
[   10.595906] usbcore: registered new interface driver ums-karma
[   10.595929] usbcore: registered new interface driver ums-onetouch
[   10.595963] usbcore: registered new interface driver ums-realtek
[   10.595989] usbcore: registered new interface driver ums-sddr09
[   10.596013] usbcore: registered new interface driver ums-sddr55
[   10.596037] usbcore: registered new interface driver ums-usbat
[   10.596122] usbcore: registered new interface driver usbserial
[   10.596148] usbcore: registered new interface driver usbserial_generic
[   10.596172] usbserial: USB Serial support registered for generic
[   10.596379] mousedev: PS/2 mouse device common for all mice
[   10.596814] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.597742] get ctp_para failed, -1
[   10.597760] get node gsensor failed
[   10.597765] get sysconfig para erro!
[   10.597774] get node lightsensor failed
[   10.597778] get sysconfig para erro!
[   10.597787] get node gyroscopesensor failed
[   10.597790] get sysconfig para erro!
[   10.597799] get node compasssensor failed
[   10.597803] get sysconfig para erro!
[   10.598081] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.598103] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.598272] i2c /dev entries driver
[   10.640795] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.644266] sunxi budget cooling probe start !
[   10.644296] CPU freq cooling register Success
[   10.644315] CPU hotplug cooling register Success
[   10.644403] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.644411] CPU budget cooling register Success
[   10.644621] sunxi gpu cooling probe start !
[   10.644631] CPU gpu cooling register Success
[   10.645280] cpuidle: using governor ladder
[   10.645287] cpuidle: using governor menu
[   10.646028] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.646056] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.646065] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.646073] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.646123] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.646130] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.646728] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.646752] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.597828] wakeup gpio set err!get node ctp failed
[   10.650126] get sysconfig para erro!
[   10.659898] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.679592] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.679973] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.679998] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.680006] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.680013] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.680018] get() with no identifier
[   10.680021] get() with no identifier
[   10.680025] get() with no identifier
[   10.680030] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.680037] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.680042] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.680413] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.680447] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.680465] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.681234] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.681253] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.683636] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.685765] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.686579] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687391] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688202] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688827] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.688870] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.691244] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.699260] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.718947] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.719648] ledtrig-cpu: registered to indicate activity on CPUs
[   10.719717] hidraw: raw HID events driver (C) Jiri Kosina
[   10.719857] usbcore: registered new interface driver usbhid
[   10.719861] usbhid: USB HID core driver
[   10.720724] usbcore: registered new interface driver snd-usb-audio
[   10.722732] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.723521] TCP: cubic registered
[   10.723531] Initializing XFRM netlink socket
[   10.723610] NET: Registered protocol family 10
[   10.724425] mip6: Mobile IPv6
[   10.724433] sit: IPv6 over IPv4 tunneling driver
[   10.724811] NET: Registered protocol family 17
[   10.724833] NET: Registered protocol family 15
[   10.724880] 8021q: 802.1Q VLAN Support v1.8
[   10.724924] Key type dns_resolver registered
[   10.725129] Registering SWP/SWPB emulation handler
[   10.725417] registered taskstats version 1
[   10.737388] Key type encrypted registered
[   10.737412] AppArmor: AppArmor sha1 policy hashing enabled
[   10.737857] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.737866] [DISP] boot_disp:0x0
[   10.737911] HDMI base address: ffffff8000b40000
[   10.738678] [HDMI] power vcc-hdmi-33
[   10.739203] [HDMI] cec support = 0
[   10.758256] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.760753] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.760829] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.760933] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.760959] mmc0: new high speed SDHC card at address aaaa
[   10.761352] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.763379]  mmcblk0: p1
[   10.764497] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.765304] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.765322] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.767712] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.769530] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.770338] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771145] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771952] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772757] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.773566] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774373] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775180] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775987] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776003] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.776837] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.776853] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.849657] input: sunxi-ths as /devices/virtual/input/input2
[   10.849818] thermal thermal_zone0: failed to read out thermal zone 0
[   10.850234] ALSA device list:
[   10.850241]   #0: sndhdmi
[   10.850672] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.447113] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.133423] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.133439] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.133460] scene_lock_destroy name=ehci_standby
[   14.133474] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.133496] usb usb1: USB disconnect, device number 1
[   14.134066] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.134100] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.134108] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.134113] scene_lock_destroy name=ohci_standby
[   14.134121] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.134138] usb usb3: USB disconnect, device number 1
[   14.134497] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.134531] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.134540] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.134587] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.134610] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.137814] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.153132] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.153230] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.153238] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.153245] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.153252] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.153258] usb usb1: SerialNumber: sunxi-ehci
[   14.153724] hub 1-0:1.0: USB hub found
[   14.153743] hub 1-0:1.0: 1 port detected
[   14.153893] scene_lock_init name=ehci_standby
[   14.153901] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.153909] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.153961] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.153980] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.154025] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.216163] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.216179] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.216187] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.216193] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.216199] usb usb3: SerialNumber: sunxi-ohci
[   14.216654] hub 3-0:1.0: USB hub found
[   14.216673] hub 3-0:1.0: 1 port detected
[   14.216841] scene_lock_init name=ohci_standby
[   16.490912] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.874555] systemd[1]: System time before build time, advancing clock.
[   16.911575] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.911877] systemd[1]: Detected architecture arm64.
[   16.940563] systemd[1]: Set hostname to <cluster0>.
[   17.333295] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.351446] systemd[1]: Listening on udev Control Socket.
[   17.370899] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.390675] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.410353] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.429931] systemd[1]: Listening on Syslog Socket.
[   17.449567] systemd[1]: Reached target Encrypted Volumes.
[   17.470018] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.489116] systemd[1]: Listening on Journal Socket.
[   17.508769] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.528290] systemd[1]: Reached target Swap.
[   17.548359] systemd[1]: Created slice User and Session Slice.
[   17.567983] systemd[1]: Created slice System Slice.
[   17.589111] systemd[1]: Mounting Huge Pages File System...
[   17.609419] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.628893] systemd[1]: Starting Set console keymap...
[   17.648800] systemd[1]: Mounting Debug File System...
[   17.672773] systemd[1]: Starting Restore / save the current clock...
[   17.696393] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.721140] systemd[1]: Starting Load Kernel Modules...
[   17.740120] systemd[1]: Reached target Slices.
[   17.755099] systemd[1]: Listening on udev Kernel Socket.
[   17.776286] systemd[1]: Mounting RPC Pipe File System...
[   17.796615] systemd[1]: Starting Nameserver information manager...
[   17.816086] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.833588] systemd[1]: Reached target Paths.
[   17.839213] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.855050] systemd[1]: Mounting POSIX Message Queue File System...
[   17.880533] systemd[1]: Mounted RPC Pipe File System.
[   17.900584] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.900866] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.901019] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.901165] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.902372] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.902573] systemd[1]: Mounted Debug File System.
[   17.922272] systemd[1]: Mounted POSIX Message Queue File System.
[   17.941933] systemd[1]: Mounted Huge Pages File System.
[   17.953650] cfg80211: Calling CRDA to update world regulatory domain
[   17.962736] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.982630] systemd[1]: Started Set console keymap.
[   18.002204] systemd[1]: Started Restore / save the current clock.
[   18.024936] systemd[1]: Started Remount Root and Kernel File Systems.
[   18.043035] systemd[1]: Time has been changed
[   18.069744] systemd[1]: Started Nameserver information manager.
[   18.082479] RTL871X: module init start
[   18.082495] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.082500] RTL871X: build time: Feb  8 2019 10:22:36
[   18.082505] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.082523] sunxi-wlan wlan.26: bus_index: 1
[   18.082704] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.167748] systemd[1]: Reached target Network (Pre).
[   18.190458] systemd[1]: Starting Load/Save Random Seed...
[   18.191078] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.191192] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.191313] RTL871X: module init ret=0
[   18.203736] systemd[1]: Starting udev Coldplug all Devices...
[   18.207265] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.212886] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.227744] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.228070] systemd[1]: Started Load Kernel Modules.
[   18.228590] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.228629] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.231088] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.232979] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.233804] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.234616] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.235434] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.236243] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.237055] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.237864] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.238670] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.239478] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.246634] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.247575] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.247948] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.247951] systemd[1]: Started Load/Save Random Seed.
[   18.287030] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.334879] systemd[1]: Starting udev Kernel Device Manager...
[   18.355061] systemd[1]: Reached target Local File Systems (Pre).
[   18.377639] systemd[1]: Mounting /tmp...
[   18.396508] systemd[1]: Starting Apply Kernel Variables...
[   18.416376] systemd[1]: Mounting FUSE Control File System...
[   18.436751] systemd[1]: Mounting Configuration File System...
[   18.457075] systemd[1]: Mounted FUSE Control File System.
[   18.473354] systemd[1]: Mounted Configuration File System.
[   18.492903] systemd[1]: Mounted /tmp.
[   18.515709] systemd[1]: Started udev Kernel Device Manager.
[   18.533149] systemd[1]: Started udev Coldplug all Devices.
[   18.553628] systemd[1]: Started Apply Kernel Variables.
[   18.608567] systemd[1]: Reached target Sound Card.
[   18.619759] cfg80211: World regulatory domain updated:
[   18.619780] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.619787] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.619793] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.619798] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.619803] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.619808] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.619813] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.619818] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.619824] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.621424] systemd[1]: Reached target Local File Systems.
[   18.651763] systemd[1]: Starting Raise network interfaces...
[   18.672781] systemd[1]: Starting Armbian ZRAM config...
[   18.688558] sunxi cedar version 0.1
[   18.688794] [cedar]: install start!!!
[   18.688925] ycy the get irq is 90
[   18.690761] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.690781] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.690787] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.690792] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.690797] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.690801] [cedar]: install end!!!
[   18.692564] systemd[1]: Starting Preprocess NFS configuration...
[   18.712132] systemd[1]: Starting Set console font and keymap...
[   18.819695] [VFE]cci probe end cci_sel = 0!
[   18.820104] [VFE]cci_init end
[   18.820349] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.828454] Registered IR keymap rc_map_sunxi
[   18.828977] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.830755] Driver for 1-wire Dallas network protocol.
[   18.831162] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.840419] systemd[1]: Starting Journal Service...
[   18.865033] systemd[1]: Started Preprocess NFS configuration.
[   18.898254] IR NEC protocol handler initialized
[   18.902584] IR Sony protocol handler initialized
[   18.903743] IR SANYO protocol handler initialized
[   18.919593] IR JVC protocol handler initialized
[   18.920759] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.921161] IR MCE Keyboard/mouse protocol handler initialized
[   18.921306] IR RC5(x) protocol handler initialized
[   18.922452] IR RC6 protocol handler initialized
[   18.947610] lirc_dev: IR Remote Control driver registered, major 248
[   18.952659] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.952684] IR LIRC bridge handler initialized
[   18.968112] systemd[1]: Found device /dev/ttyS0.
[   19.121904] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.126490] zram: Created 6 device(s) ...
[   19.198365] [VFE]Welcome to Video Front End driver
[   19.198848] [VFE]csi probe end csi_sel = 0!
[   19.199142] [VFE]csi_init end
[   19.200479] [VFE]isp probe start isp_sel = 0!
[   19.203950] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   19.205333] [ISP] isp platform_id = 3!
[   19.205370] [VFE]isp probe end isp_sel = 0!
[   19.205502] [VFE]sunxi_isp_platform_register end
[   19.206073] [VFE]mipi probe start mipi_sel = 0!
[   19.206123] [VFE]mipi probe end mipi_sel = 0!
[   19.207215] [VFE]mipi_init end
[   19.207236] [VFE]flash_init end
[   19.207753] [VFE]vfe_init end
[   19.230959] systemd[1]: Reached target NFS client services.
[   19.250574] systemd[1]: Reached target Remote File Systems (Pre).
[   19.273183] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   19.291116] systemd[1]: Started Journal Service.
[   19.371298] systemd-journald[360]: Received request to flush runtime journal from PID 1
[   19.384086] sunxi-bt bt.27: block state already is 1
[   19.393270] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.424016] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.455124] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.486375] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.748623] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.748646] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035016 kB
MemFree:         1888036 kB
Buffers:            9544 kB
Cached:            57352 kB
SwapCached:            0 kB
Active:            29832 kB
Inactive:          53452 kB
Active(anon):      16672 kB
Inactive(anon):     2852 kB
Active(file):      13160 kB
Inactive(file):    50600 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017504 kB
SwapFree:        1017504 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         16484 kB
Mapped:            14844 kB
Shmem:              3052 kB
Slab:              23536 kB
SReclaimable:      10304 kB
SUnreclaim:        13232 kB
KernelStack:        1856 kB
PageTables:          552 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035012 kB
Committed_AS:      94824 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633524 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5606
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 62493
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
tmpfs           994M     0  994M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           994M     0  994M   0% /sys/fs/cgroup
tmpfs           994M  4.0K  994M   1% /tmp
/dev/zram0       49M  5.4M   40M  12% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M   5M  1.7M  2.6M         /var/log
/dev/zram1             248.4M   4K   78B    4K         [SWAP]
/dev/zram2             248.4M   4K   78B    4K         [SWAP]
/dev/zram3             248.4M   4K   78B    4K         [SWAP]
/dev/zram4             248.4M   4K   78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
03:27:09: 1008MHz  0.00  36%  11%  15%   0%   9%   0%   29°C   20°C  0/7
03:27:09: 1008MHz  0.00  56%  12%  14%   2%  26%   0%   28°C   20°C  0/7
03:27:09: 1152MHz  0.00  51%  12%   6%   0%  31%   0%   28°C   20°C  0/7
03:27:10: 1152MHz  0.00  34%   5%   2%   2%  24%   0%   28°C   20°C  0/7
03:27:10: 1152MHz  0.08  29%   3%  22%   1%   1%   0%   28°C   20°C  0/7
Fri Mar  8 07:39:58 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    9.940955] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    9.940964] pid_max: default: 32768 minimum: 301
[    9.941057] Security Framework initialized
[    9.941104] AppArmor: AppArmor initialized
[    9.941139] Mount-cache hash table entries: 256
[    9.951413] Initializing cgroup subsys memory
[    9.951458] Initializing cgroup subsys devices
[    9.951465] Initializing cgroup subsys freezer
[    9.951471] Initializing cgroup subsys blkio
[    9.951476] Initializing cgroup subsys perf_event
[    9.951487] Initializing cgroup subsys hugetlb
[    9.951547] ftrace: allocating 28898 entries in 113 pages
[    9.984669] CPU0: update cpu_power 1968128
[    9.984690] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[    9.985647] virtual base = 0xffffff800000a000.
[    9.985660] gicd_base = 0xffffff800000c000.
[    9.985664] gicc_base = 0xffffff800000e000.
[    9.986266] CPU1: Booted secondary processor
[    9.986292] CPU1: update cpu_power 1968128
[    9.988892] CPU2: Booted secondary processor
[    9.988903] CPU2: update cpu_power 1968128
[    9.993009] CPU3: Booted secondary processor
[    9.993019] CPU3: update cpu_power 1968128
[    9.993092] Brought up 4 CPUs
[    9.993112] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    9.993607] devtmpfs: initialized
[    9.998533] pinctrl core: initialized pinctrl subsystem
[   10.000907] NET: Registered protocol family 16
[   10.001157] script_sysfs_init success
[   10.001389] dump_class_init,806, success
[   10.001630] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.001650] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.002913] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.003948] DMA: preallocated 256 KiB pool for atomic allocations
[   10.004062] Serial: AMBA PL011 UART driver
[   10.004164] axp81x_board_init: axp regl_devs num = 23
[   10.004306] pll_audio-set_default_rate=24576000 success!
[   10.004324] pll_video0-set_default_rate=297000000 success!
[   10.004394] pll_video1-set_default_rate=297000000 success!
[   10.004456] pll_de-set_default_rate=297000000 success!
[   10.005159] de-set_default_source=pll_de success!
[   10.005165] de-set_default_rate=297000000 success!
[   10.005207] tcon0-set_default_source=pll_mipi success!
[   10.005238] tcon1-set_default_source=pll_video0 success!
[   10.005451] hdmi-set_default_source=pll_video0 success!
[   10.007674] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.007832] [sun50iw1p1_pinctrl_probe][838]
[   10.009267] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.009887] sunxi hwspinlock vbase:0xffffff800005c000
[   10.020078] bio: create slab <bio-0> at 0
[   10.020421] pwm module init!
[   10.021627] SCSI subsystem initialized
[   10.021750] usbcore: registered new interface driver usbfs
[   10.021784] usbcore: registered new interface driver hub
[   10.021847] usbcore: registered new device driver usb
[   10.022530] Linux video capture interface: v2.00
[   10.022956] [ARISC] :sunxi-arisc driver v1.10
[   10.029833] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.030073] Advanced Linux Sound Architecture Driver Initialized.
[   10.030413] NetLabel: Initializing
[   10.030418] NetLabel:  domain hash size = 128
[   10.030422] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.030460] NetLabel:  unlabeled traffic allowed by default
[   10.030616] [pm]aw_pm_init!
[   10.030680] rtc physical base = 0x0000000001f00000 .
[   10.030713] np name = /soc@01c00000/rtc@01f00000.
[   10.030719] base = ffffff800006e100, len = 4.
[   10.030724] pmu name: pmu0 .
[   10.030758] pmu0_enable = 0x1.
[   10.030763] pmux_id = 0x6.
[   10.030770] pmux_twi_id = 0x1.
[   10.030775] pmux_twi_addr = 0x34.
[   10.030779] pmu name: pmu1 .
[   10.030827] Warning: can not find np for pmu1.
[   10.031054] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.031212] after inited: sys_mask config = 0x4a55.
[   10.031234] Warning: can not find np for dynamic_standby_para.
[   10.031355] [pm]valid
[   10.031358] [pm]valid
[   10.031362] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.031564] Switching to clocksource arch_sys_counter_ool
[   10.049254] AppArmor: AppArmor Filesystem Enabled
[   10.055787] NET: Registered protocol family 2
[   10.056452] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.056692] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.056975] TCP: Hash tables configured (established 16384 bind 16384)
[   10.057057] TCP: reno registered
[   10.057067] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.057119] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.057360] NET: Registered protocol family 1
[   10.057663] RPC: Registered named UNIX socket transport module.
[   10.057668] RPC: Registered udp transport module.
[   10.057672] RPC: Registered tcp transport module.
[   10.057677] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.057841] Trying to unpack rootfs image as initramfs...
[   10.261237] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.261790] kvm [1]: Using HYP init bounce page @b7889000
[   10.262266] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.262667] kvm [1]: timer IRQ27
[   10.262681] kvm [1]: Hyp mode initialized successfully
[   10.264347] lock super standby defaultly!
[   10.264362] lookup_scene_lock_name: new scene lock super_standby
[   10.264367] scene_lock_init name=super_standby
[   10.264373] scene_lock: super_standby, type 5, count 1
[   10.264768] audit: initializing netlink socket (disabled)
[   10.264822] type=2000 audit(0.310:1): initialized
[   10.265485] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.265940] VFS: Disk quotas dquot_6.5.2
[   10.266040] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.266948] NFS: Registering the id_resolver key type
[   10.266999] Key type id_resolver registered
[   10.267004] Key type id_legacy registered
[   10.267015] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.267150] NTFS driver 2.1.30 [Flags: R/W].
[   10.267316] fuse init (API version 7.22)
[   10.267485] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.267952] msgmni has been set to 3973
[   10.268898] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.268977] io scheduler noop registered
[   10.268983] io scheduler deadline registered
[   10.269007] io scheduler cfq registered (default)
[   10.269576] [DISP]disp_module_init
[   10.270014] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.270021] [DISP] boot_disp:0x0
[   10.270603] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.270734] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.270864] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.271975] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.271981] [DISP] fb_base:0x0
[   10.289524] Console: switching to colour frame buffer device 160x45
[   10.303964] [DISP]disp_module_init finish
[   10.304367] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.304390] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.304743] console [ttyS0] enabled
[   10.305114] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.305352] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.305657] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.305940] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.306275] misc dump reg init
[   10.306421] [drm] Initialized drm 1.1.0 20060810
[   10.308748] brd: module loaded
[   10.310861] loop: module loaded
[   10.311137] sunxi-bt bt.27: Missing bt_power.
[   10.311145] sunxi-bt bt.27: bt_power_name ((null))
[   10.311153] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.311192] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.311233] sunxi-bt bt.27: clk not config
[   10.311303] sunxi-bt bt.27: block state already is 1
[   10.311484] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.311491] sunxi-wlan wlan.26: Missing wlan_power.
[   10.311498] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.311505] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.311521] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.311541] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.311558] sunxi-wlan wlan.26: clk not config
[   10.312255] WARNING: Get ephy clock is failed
[   10.312854] chipid-sunxi serial 140050374620201507cf
[   10.312945] PPP generic driver version 2.4.2
[   10.313088] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.313190] get ehci0-controller drv_vbus_gpio is fail
[   10.313196] get ehci0-controller, regulator_io is no nocare
[   10.313234] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.313287] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.313305] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.313649] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.326823] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.326890] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.326898] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.326905] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.326911] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.326917] usb usb1: SerialNumber: sunxi-ehci
[   10.327263] hub 1-0:1.0: USB hub found
[   10.327278] hub 1-0:1.0: 1 port detected
[   10.327411] scene_lock_init name=ehci_standby
[   10.327482] get ehci1-controller drv_vbus_gpio is fail
[   10.327487] get ehci1-controller, regulator_io is no nocare
[   10.327527] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.327574] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.327594] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.327829] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.346506] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.346548] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.346556] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.346563] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.346569] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.346576] usb usb2: SerialNumber: sunxi-ehci
[   10.346850] hub 2-0:1.0: USB hub found
[   10.346863] hub 2-0:1.0: 1 port detected
[   10.346983] scene_lock_init name=ehci_standby
[   10.347164] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.347301] get ohci0-controller drv_vbus_gpio is fail
[   10.347307] get ohci0-controller, regulator_io is no nocare
[   10.347344] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.347390] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.347406] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.347434] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.409515] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.409523] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.409530] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.409537] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.409543] usb usb3: SerialNumber: sunxi-ohci
[   10.409815] hub 3-0:1.0: USB hub found
[   10.409829] hub 3-0:1.0: 1 port detected
[   10.409944] scene_lock_init name=ohci_standby
[   10.410003] get ohci1-controller drv_vbus_gpio is fail
[   10.410008] get ohci1-controller, regulator_io is no nocare
[   10.410042] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.410082] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.410099] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.410125] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.468582] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.468591] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.468598] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.468604] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.468610] usb usb4: SerialNumber: sunxi-ohci
[   10.468888] hub 4-0:1.0: USB hub found
[   10.468901] hub 4-0:1.0: 1 port detected
[   10.469017] scene_lock_init name=ohci_standby
[   10.469315] usbcore: registered new interface driver usb-storage
[   10.469345] usbcore: registered new interface driver ums-alauda
[   10.469373] usbcore: registered new interface driver ums-cypress
[   10.469398] usbcore: registered new interface driver ums-datafab
[   10.469421] usbcore: registered new interface driver ums_eneub6250
[   10.469445] usbcore: registered new interface driver ums-freecom
[   10.469469] usbcore: registered new interface driver ums-isd200
[   10.469492] usbcore: registered new interface driver ums-jumpshot
[   10.469515] usbcore: registered new interface driver ums-karma
[   10.469538] usbcore: registered new interface driver ums-onetouch
[   10.469573] usbcore: registered new interface driver ums-realtek
[   10.469598] usbcore: registered new interface driver ums-sddr09
[   10.469622] usbcore: registered new interface driver ums-sddr55
[   10.469646] usbcore: registered new interface driver ums-usbat
[   10.469729] usbcore: registered new interface driver usbserial
[   10.469756] usbcore: registered new interface driver usbserial_generic
[   10.469779] usbserial: USB Serial support registered for generic
[   10.469981] mousedev: PS/2 mouse device common for all mice
[   10.470418] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.471245] get ctp_para failed, -1
[   10.471264] get node gsensor failed
[   10.471269] get sysconfig para erro!
[   10.471278] get node lightsensor failed
[   10.471281] get sysconfig para erro!
[   10.471290] get node gyroscopesensor failed
[   10.471294] get sysconfig para erro!
[   10.471302] get node compasssensor failed
[   10.471306] get sysconfig para erro!
[   10.471597] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.471617] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.471780] i2c /dev entries driver
[   10.514342] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.517753] sunxi budget cooling probe start !
[   10.517781] CPU freq cooling register Success
[   10.517800] CPU hotplug cooling register Success
[   10.517887] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.517894] CPU budget cooling register Success
[   10.518101] sunxi gpu cooling probe start !
[   10.518111] CPU gpu cooling register Success
[   10.518737] cpuidle: using governor ladder
[   10.518743] cpuidle: using governor menu
[   10.519482] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.519511] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.519519] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.519528] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.519577] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.519584] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.520142] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.520165] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.471330] wakeup gpio set err!get node ctp failed
[   10.523675] get sysconfig para erro!
[   10.533455] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.553144] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.553520] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.553546] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.553554] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.553561] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.553565] get() with no identifier
[   10.553569] get() with no identifier
[   10.553572] get() with no identifier
[   10.553578] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.553584] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.553590] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.553941] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.553958] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.553966] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.554785] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.554804] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.557185] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.559326] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.560140] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.560951] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.561763] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.562387] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.562431] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.564806] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.572813] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.592501] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.593175] ledtrig-cpu: registered to indicate activity on CPUs
[   10.593243] hidraw: raw HID events driver (C) Jiri Kosina
[   10.593382] usbcore: registered new interface driver usbhid
[   10.593386] usbhid: USB HID core driver
[   10.594234] usbcore: registered new interface driver snd-usb-audio
[   10.596245] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.597028] TCP: cubic registered
[   10.597037] Initializing XFRM netlink socket
[   10.597116] NET: Registered protocol family 10
[   10.597900] mip6: Mobile IPv6
[   10.597908] sit: IPv6 over IPv4 tunneling driver
[   10.598277] NET: Registered protocol family 17
[   10.598300] NET: Registered protocol family 15
[   10.598344] 8021q: 802.1Q VLAN Support v1.8
[   10.598385] Key type dns_resolver registered
[   10.598587] Registering SWP/SWPB emulation handler
[   10.598871] registered taskstats version 1
[   10.610465] Key type encrypted registered
[   10.610487] AppArmor: AppArmor sha1 policy hashing enabled
[   10.610906] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.610915] [DISP] boot_disp:0x0
[   10.610958] HDMI base address: ffffff8000b40000
[   10.611702] [HDMI] power vcc-hdmi-33
[   10.612266] [HDMI] cec support = 0
[   10.631812] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.634308] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.634379] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.634479] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.634504] mmc0: new high speed SDHC card at address aaaa
[   10.634885] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.636887]  mmcblk0: p1
[   10.637997] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.638806] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.638825] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.641214] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.643032] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.643841] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.644647] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.645452] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.646256] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.647063] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.647870] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.648677] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.649484] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.649500] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.650334] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.650351] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.722658] input: sunxi-ths as /devices/virtual/input/input2
[   10.722807] thermal thermal_zone0: failed to read out thermal zone 0
[   10.723223] ALSA device list:
[   10.723230]   #0: sndhdmi
[   10.723646] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.320673] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.006982] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.006997] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.007017] scene_lock_destroy name=ehci_standby
[   14.007030] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.007050] usb usb1: USB disconnect, device number 1
[   14.008891] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.008933] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.008942] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.008948] scene_lock_destroy name=ohci_standby
[   14.008956] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.008979] usb usb3: USB disconnect, device number 1
[   14.009385] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.009420] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.009428] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.009470] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.009494] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.012088] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.026683] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.026774] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.026782] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.026789] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.026796] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.026802] usb usb1: SerialNumber: sunxi-ehci
[   14.027251] hub 1-0:1.0: USB hub found
[   14.027270] hub 1-0:1.0: 1 port detected
[   14.027414] scene_lock_init name=ehci_standby
[   14.027421] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.027428] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.027479] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.027497] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.027536] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.089706] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.089721] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.089729] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.089735] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.089742] usb usb3: SerialNumber: sunxi-ohci
[   14.090180] hub 3-0:1.0: USB hub found
[   14.090198] hub 3-0:1.0: 1 port detected
[   14.090381] scene_lock_init name=ohci_standby
[   16.344601] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.727089] systemd[1]: System time before build time, advancing clock.
[   16.763950] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.764249] systemd[1]: Detected architecture arm64.
[   16.794441] systemd[1]: Set hostname to <cluster0>.
[   17.185058] systemd[1]: Reached target Encrypted Volumes.
[   17.205438] systemd[1]: Created slice User and Session Slice.
[   17.224914] systemd[1]: Listening on udev Kernel Socket.
[   17.244532] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.264177] systemd[1]: Listening on Syslog Socket.
[   17.283910] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.303726] systemd[1]: Created slice System Slice.
[   17.323452] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.343362] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.362704] systemd[1]: Reached target Swap.
[   17.382266] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.401985] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.421511] systemd[1]: Reached target Paths.
[   17.441334] systemd[1]: Listening on Journal Socket.
[   17.465630] systemd[1]: Starting Restore / save the current clock...
[   17.485388] systemd[1]: Mounting RPC Pipe File System...
[   17.502675] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.532333] systemd[1]: Starting Load Kernel Modules...
[   17.551827] systemd[1]: Mounting POSIX Message Queue File System...
[   17.560759] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.581942] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.582348] systemd[1]: Mounting Huge Pages File System...
[   17.600568] systemd[1]: Starting Set console keymap...
[   17.620932] systemd[1]: Mounting Debug File System...
[   17.639973] systemd[1]: Starting Nameserver information manager...
[   17.657824] systemd[1]: Reached target Slices.
[   17.677798] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.697460] systemd[1]: Listening on udev Control Socket.
[   17.724156] systemd[1]: Mounted RPC Pipe File System.
[   17.738070] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.738347] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.738531] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.738701] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.739909] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.746524] systemd[1]: Mounted Debug File System.
[   17.766255] systemd[1]: Mounted POSIX Message Queue File System.
[   17.785942] systemd[1]: Mounted Huge Pages File System.
[   17.790858] cfg80211: Calling CRDA to update world regulatory domain
[   17.806292] systemd[1]: Started Restore / save the current clock.
[   17.826963] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.846109] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.866018] systemd[1]: Started Set console keymap.
[   17.889571] systemd[1]: Time has been changed
[   17.904255] systemd[1]: Started Nameserver information manager.
[   17.908174] RTL871X: module init start
[   17.908188] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.908193] RTL871X: build time: Feb  8 2019 10:22:36
[   17.908198] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.908212] sunxi-wlan wlan.26: bus_index: 1
[   17.908352] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.002446] systemd[1]: Reached target Network (Pre).
[   18.016723] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.016834] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.016955] RTL871X: module init ret=0
[   18.026948] systemd[1]: Starting udev Coldplug all Devices...
[   18.031607] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.043693] systemd[1]: Starting Load/Save Random Seed...
[   18.052061] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.052881] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.052904] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.055341] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.057201] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.058014] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.058822] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.059631] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.060445] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.061268] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.062793] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.063633] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.063735] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.064486] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.064520] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.065426] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.065465] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.081682] systemd[1]: Started Load Kernel Modules.
[   18.102345] systemd[1]: Started Load/Save Random Seed.
[   18.122784] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.181473] systemd[1]: Starting udev Kernel Device Manager...
[   18.199032] systemd[1]: Reached target Local File Systems (Pre).
[   18.221598] systemd[1]: Mounting /tmp...
[   18.240387] systemd[1]: Mounting FUSE Control File System...
[   18.246761] systemd[1]: Starting Apply Kernel Variables...
[   18.269985] systemd[1]: Mounting Configuration File System...
[   18.290847] systemd[1]: Mounted FUSE Control File System.
[   18.307507] systemd[1]: Mounted Configuration File System.
[   18.327042] systemd[1]: Mounted /tmp.
[   18.347914] systemd[1]: Started udev Kernel Device Manager.
[   18.367257] systemd[1]: Started udev Coldplug all Devices.
[   18.387664] systemd[1]: Started Apply Kernel Variables.
[   18.475680] cfg80211: World regulatory domain updated:
[   18.475701] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.475709] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.475714] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.475719] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.475724] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.475729] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.475735] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.475740] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.475745] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.500158] systemd[1]: Reached target Sound Card.
[   18.523471] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.560296] systemd[1]: Starting Journal Service...
[   18.573256] systemd[1]: Reached target Local File Systems.
[   18.595545] sunxi cedar version 0.1
[   18.595835] [cedar]: install start!!!
[   18.596021] ycy the get irq is 90
[   18.596342] systemd[1]: Starting Preprocess NFS configuration...
[   18.596780] ycy clk_bass_vir 0x18  is ffffff8000b6e018, the value:3006207
[   18.596784] ycy clk_bass_vir 0x13c  is ffffff8000b6e13c, the value:0
[   18.596786] ycy clk_bass_vir 0x64  is ffffff8000b6e064, the value:601810
[   18.596789] ycy clk_bass_vir 0x2c4  is ffffff8000b6e2c4, the value:601c10
[   18.596791] ycy clk_bass_vir 0x100  is ffffff8000b6e100, the value:0
[   18.596792] [cedar]: install end!!!
[   18.624903] systemd[1]: Starting Set console font and keymap...
[   18.685156] Registered IR keymap rc_map_sunxi
[   18.685660] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.686020] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.700370] IR JVC protocol handler initialized
[   18.709368] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.709805] IR MCE Keyboard/mouse protocol handler initialized
[   18.710042] IR NEC protocol handler initialized
[   18.710894] IR RC5(x) protocol handler initialized
[   18.716491] systemd[1]: Starting Raise network interfaces...
[   18.733846] systemd[1]: Starting Armbian ZRAM config...
[   18.742291] Driver for 1-wire Dallas network protocol.
[   18.753004] systemd[1]: Started Preprocess NFS configuration.
[   18.756075] [VFE]cci probe end cci_sel = 0!
[   18.756369] [VFE]cci_init end
[   18.871138] systemd[1]: Found device /dev/ttyS0.
[   18.901141] lirc_dev: IR Remote Control driver registered, major 248
[   18.905317] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.905489] IR SANYO protocol handler initialized
[   18.906211] IR RC6 protocol handler initialized
[   18.906966] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.906981] IR LIRC bridge handler initialized
[   18.928881] systemd[1]: Reached target NFS client services.
[   18.947955] systemd[1]: Reached target Remote File Systems (Pre).
[   18.954442] IR Sony protocol handler initialized
[   18.966891] systemd[1]: Started Journal Service.
[   19.060420] sunxi-bt bt.27: block state already is 1
[   19.109972] systemd-journald[322]: Received request to flush runtime journal from PID 1
[   19.182138] [VFE]Welcome to Video Front End driver
[   19.183572] [VFE]csi probe end csi_sel = 0!
[   19.183820] [VFE]csi_init end
[   19.184943] [VFE]isp probe start isp_sel = 0!
[   19.185581] [ISP] isp platform_id = 3!
[   19.185602] [VFE]isp probe end isp_sel = 0!
[   19.185689] [VFE]sunxi_isp_platform_register end
[   19.187005] [VFE]mipi probe start mipi_sel = 0!
[   19.187040] [VFE]mipi probe end mipi_sel = 0!
[   19.187101] [VFE]mipi_init end
[   19.187108] [VFE]flash_init end
[   19.188118] [VFE]vfe_init end
[   19.254507] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.265671] zram: Created 6 device(s) ...
[   19.393356] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.415255] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.437782] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.460100] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.652856] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.652877] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1891744 kB
Buffers:            9504 kB
Cached:            54784 kB
SwapCached:            0 kB
Active:            29416 kB
Inactive:          50824 kB
Active(anon):      16492 kB
Inactive(anon):     2848 kB
Active(file):      12924 kB
Inactive(file):    47976 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:               164 kB
Writeback:             0 kB
AnonPages:         16280 kB
Mapped:            13880 kB
Shmem:              3048 kB
Slab:              23384 kB
SReclaimable:      10128 kB
SUnreclaim:        13256 kB
KernelStack:        1840 kB
PageTables:          600 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:      98540 kB
VmallocChunk:   251633572 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
### ip addr:
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
### partitions:
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
/dev/mmcblk0p1   15G  962M   14G   7% /
/dev/zram0       49M  5.7M   40M  13% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  5.3M  1.8M  2.7M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
07:40:00: 1008MHz  0.00  33%  11%  14%   0%   7%   0%   30°C   21°C  0/7
07:40:00: 1008MHz  0.00  64%  10%  17%   0%  36%   0%   28°C   21°C  0/7
07:40:01: 1008MHz  0.00  51%   7%  10%   2%  30%   0%   28°C   21°C  0/7
07:40:01: 1008MHz  0.00  58%  16%   8%   2%  31%   0%   28°C   21°C  0/7
07:40:01: 1152MHz  0.00  47%  12%   6%   0%  28%   0%   28°C   21°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Fri Mar  8 07:48:58 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@armbian.com) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #2 SMP PREEMPT Fri Feb 8 10:23:10 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s19520 r8192 d21440 u49152
[    0.000000] pcpu-alloc: s19520 r8192 d21440 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1964644k/1964644k available, 116124k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000b59000 - 0xffffffc000be0c40   (   544 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000b58164   ( 11105 kB)
                     .data : 0xffffffc000be1000 - 0xffffffc000d50e48   (  1472 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.066484] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.066494] pid_max: default: 32768 minimum: 301
[   10.066588] Security Framework initialized
[   10.066635] AppArmor: AppArmor initialized
[   10.066671] Mount-cache hash table entries: 256
[   10.077028] Initializing cgroup subsys memory
[   10.077074] Initializing cgroup subsys devices
[   10.077082] Initializing cgroup subsys freezer
[   10.077088] Initializing cgroup subsys blkio
[   10.077094] Initializing cgroup subsys perf_event
[   10.077104] Initializing cgroup subsys hugetlb
[   10.077168] ftrace: allocating 28898 entries in 113 pages
[   10.110918] CPU0: update cpu_power 1968128
[   10.110939] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.111907] virtual base = 0xffffff800000a000.
[   10.111920] gicd_base = 0xffffff800000c000.
[   10.111925] gicc_base = 0xffffff800000e000.
[   10.112550] CPU1: Booted secondary processor
[   10.112577] CPU1: update cpu_power 1968128
[   10.115176] CPU2: Booted secondary processor
[   10.115188] CPU2: update cpu_power 1968128
[   10.119294] CPU3: Booted secondary processor
[   10.119305] CPU3: update cpu_power 1968128
[   10.119378] Brought up 4 CPUs
[   10.119399] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.119902] devtmpfs: initialized
[   10.124891] pinctrl core: initialized pinctrl subsystem
[   10.127350] NET: Registered protocol family 16
[   10.127596] script_sysfs_init success
[   10.127831] dump_class_init,806, success
[   10.128064] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.128084] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.129364] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.130354] DMA: preallocated 256 KiB pool for atomic allocations
[   10.130469] Serial: AMBA PL011 UART driver
[   10.130562] axp81x_board_init: axp regl_devs num = 23
[   10.130717] pll_audio-set_default_rate=24576000 success!
[   10.130736] pll_video0-set_default_rate=297000000 success!
[   10.130804] pll_video1-set_default_rate=297000000 success!
[   10.130866] pll_de-set_default_rate=297000000 success!
[   10.131579] de-set_default_source=pll_de success!
[   10.131586] de-set_default_rate=297000000 success!
[   10.131632] tcon0-set_default_source=pll_mipi success!
[   10.131663] tcon1-set_default_source=pll_video0 success!
[   10.131877] hdmi-set_default_source=pll_video0 success!
[   10.134121] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.134282] [sun50iw1p1_pinctrl_probe][838]
[   10.135718] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.136334] sunxi hwspinlock vbase:0xffffff800005c000
[   10.146535] bio: create slab <bio-0> at 0
[   10.146920] pwm module init!
[   10.148151] SCSI subsystem initialized
[   10.148268] usbcore: registered new interface driver usbfs
[   10.148303] usbcore: registered new interface driver hub
[   10.148375] usbcore: registered new device driver usb
[   10.149080] Linux video capture interface: v2.00
[   10.149541] [ARISC] :sunxi-arisc driver v1.10
[   10.156439] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.156684] Advanced Linux Sound Architecture Driver Initialized.
[   10.157040] NetLabel: Initializing
[   10.157046] NetLabel:  domain hash size = 128
[   10.157050] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.157092] NetLabel:  unlabeled traffic allowed by default
[   10.157252] [pm]aw_pm_init!
[   10.157314] rtc physical base = 0x0000000001f00000 .
[   10.157347] np name = /soc@01c00000/rtc@01f00000.
[   10.157353] base = ffffff800006e100, len = 4.
[   10.157358] pmu name: pmu0 .
[   10.157393] pmu0_enable = 0x1.
[   10.157399] pmux_id = 0x6.
[   10.157405] pmux_twi_id = 0x1.
[   10.157411] pmux_twi_addr = 0x34.
[   10.157415] pmu name: pmu1 .
[   10.157462] Warning: can not find np for pmu1.
[   10.157690] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.157850] after inited: sys_mask config = 0x4a55.
[   10.157872] Warning: can not find np for dynamic_standby_para.
[   10.157992] [pm]valid
[   10.157996] [pm]valid
[   10.158000] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.158193] Switching to clocksource arch_sys_counter_ool
[   10.176156] AppArmor: AppArmor Filesystem Enabled
[   10.182275] NET: Registered protocol family 2
[   10.182956] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.183196] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.183514] TCP: Hash tables configured (established 16384 bind 16384)
[   10.183595] TCP: reno registered
[   10.183605] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.183656] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.183920] NET: Registered protocol family 1
[   10.184245] RPC: Registered named UNIX socket transport module.
[   10.184251] RPC: Registered udp transport module.
[   10.184255] RPC: Registered tcp transport module.
[   10.184259] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.184432] Trying to unpack rootfs image as initramfs...
[   10.388972] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.389552] kvm [1]: Using HYP init bounce page @b789c000
[   10.390076] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.390497] kvm [1]: timer IRQ27
[   10.390509] kvm [1]: Hyp mode initialized successfully
[   10.392174] lock super standby defaultly!
[   10.392191] lookup_scene_lock_name: new scene lock super_standby
[   10.392195] scene_lock_init name=super_standby
[   10.392202] scene_lock: super_standby, type 5, count 1
[   10.392607] audit: initializing netlink socket (disabled)
[   10.392658] type=2000 audit(0.310:1): initialized
[   10.393335] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.393810] VFS: Disk quotas dquot_6.5.2
[   10.393911] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.394909] NFS: Registering the id_resolver key type
[   10.394954] Key type id_resolver registered
[   10.394959] Key type id_legacy registered
[   10.394971] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.395111] NTFS driver 2.1.30 [Flags: R/W].
[   10.395285] fuse init (API version 7.22)
[   10.395462] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.395886] msgmni has been set to 3973
[   10.396879] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.396960] io scheduler noop registered
[   10.396966] io scheduler deadline registered
[   10.397000] io scheduler cfq registered (default)
[   10.397579] [DISP]disp_module_init
[   10.398026] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.398034] [DISP] boot_disp:0x0
[   10.398638] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.398770] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.398901] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.400011] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.400017] [DISP] fb_base:0x0
[   10.417736] Console: switching to colour frame buffer device 160x45
[   10.432201] [DISP]disp_module_init finish
[   10.432621] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.432644] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.433002] console [ttyS0] enabled
[   10.433382] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.433610] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.434071] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.434366] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.434717] misc dump reg init
[   10.434869] [drm] Initialized drm 1.1.0 20060810
[   10.436979] brd: module loaded
[   10.439115] loop: module loaded
[   10.439389] sunxi-bt bt.27: Missing bt_power.
[   10.439397] sunxi-bt bt.27: bt_power_name ((null))
[   10.439405] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.439438] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.439478] sunxi-bt bt.27: clk not config
[   10.439550] sunxi-bt bt.27: block state already is 1
[   10.439733] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.439740] sunxi-wlan wlan.26: Missing wlan_power.
[   10.439746] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.439753] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.439770] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.439789] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.439806] sunxi-wlan wlan.26: clk not config
[   10.440506] WARNING: Get ephy clock is failed
[   10.441117] chipid-sunxi serial 140050374620201507cf
[   10.441213] PPP generic driver version 2.4.2
[   10.441370] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.441475] get ehci0-controller drv_vbus_gpio is fail
[   10.441482] get ehci0-controller, regulator_io is no nocare
[   10.441519] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.441574] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.441593] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.441968] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.453456] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.453538] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.453546] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.453553] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453559] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.453565] usb usb1: SerialNumber: sunxi-ehci
[   10.453900] hub 1-0:1.0: USB hub found
[   10.453916] hub 1-0:1.0: 1 port detected
[   10.454058] scene_lock_init name=ehci_standby
[   10.454131] get ehci1-controller drv_vbus_gpio is fail
[   10.454136] get ehci1-controller, regulator_io is no nocare
[   10.454176] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.454224] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454239] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.454485] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.473138] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.473180] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.473188] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.473195] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.473202] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.473208] usb usb2: SerialNumber: sunxi-ehci
[   10.473484] hub 2-0:1.0: USB hub found
[   10.473496] hub 2-0:1.0: 1 port detected
[   10.473614] scene_lock_init name=ehci_standby
[   10.473800] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.473941] get ohci0-controller drv_vbus_gpio is fail
[   10.473946] get ohci0-controller, regulator_io is no nocare
[   10.473983] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.474029] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.474044] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.474074] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.536147] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.536155] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.536162] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.536168] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.536175] usb usb3: SerialNumber: sunxi-ohci
[   10.536461] hub 3-0:1.0: USB hub found
[   10.536474] hub 3-0:1.0: 1 port detected
[   10.536593] scene_lock_init name=ohci_standby
[   10.536655] get ohci1-controller drv_vbus_gpio is fail
[   10.536660] get ohci1-controller, regulator_io is no nocare
[   10.536695] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.536736] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.536751] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.536777] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.595206] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.595214] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.595221] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.595227] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.595234] usb usb4: SerialNumber: sunxi-ohci
[   10.595513] hub 4-0:1.0: USB hub found
[   10.595526] hub 4-0:1.0: 1 port detected
[   10.595641] scene_lock_init name=ohci_standby
[   10.595938] usbcore: registered new interface driver usb-storage
[   10.595969] usbcore: registered new interface driver ums-alauda
[   10.595993] usbcore: registered new interface driver ums-cypress
[   10.596018] usbcore: registered new interface driver ums-datafab
[   10.596045] usbcore: registered new interface driver ums_eneub6250
[   10.596069] usbcore: registered new interface driver ums-freecom
[   10.596093] usbcore: registered new interface driver ums-isd200
[   10.596116] usbcore: registered new interface driver ums-jumpshot
[   10.596144] usbcore: registered new interface driver ums-karma
[   10.596167] usbcore: registered new interface driver ums-onetouch
[   10.596199] usbcore: registered new interface driver ums-realtek
[   10.596223] usbcore: registered new interface driver ums-sddr09
[   10.596251] usbcore: registered new interface driver ums-sddr55
[   10.596275] usbcore: registered new interface driver ums-usbat
[   10.596361] usbcore: registered new interface driver usbserial
[   10.596388] usbcore: registered new interface driver usbserial_generic
[   10.596409] usbserial: USB Serial support registered for generic
[   10.596607] mousedev: PS/2 mouse device common for all mice
[   10.597069] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.597903] get ctp_para failed, -1
[   10.597923] get node gsensor failed
[   10.597927] get sysconfig para erro!
[   10.597937] get node lightsensor failed
[   10.597940] get sysconfig para erro!
[   10.597950] get node gyroscopesensor failed
[   10.597953] get sysconfig para erro!
[   10.597962] get node compasssensor failed
[   10.597965] get sysconfig para erro!
[   10.598260] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.598281] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.598442] i2c /dev entries driver
[   10.640981] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.644436] sunxi budget cooling probe start !
[   10.644469] CPU freq cooling register Success
[   10.644488] CPU hotplug cooling register Success
[   10.644578] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.644586] CPU budget cooling register Success
[   10.644796] sunxi gpu cooling probe start !
[   10.644806] CPU gpu cooling register Success
[   10.645470] cpuidle: using governor ladder
[   10.645478] cpuidle: using governor menu
[   10.646221] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.646248] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.646257] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.646265] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.646316] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.646323] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.646905] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.646930] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.597992] wakeup gpio set err!get node ctp failed
[   10.650307] get sysconfig para erro!
[   10.660086] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.679777] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.680159] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.680185] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.680192] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.680199] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.680204] get() with no identifier
[   10.680207] get() with no identifier
[   10.680211] get() with no identifier
[   10.680217] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.680223] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.680228] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.680585] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.680598] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.680604] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.681419] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.681438] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.683823] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.685963] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.686777] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687588] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688400] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.689024] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.689068] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.691442] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.699445] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.719134] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.719832] ledtrig-cpu: registered to indicate activity on CPUs
[   10.719901] hidraw: raw HID events driver (C) Jiri Kosina
[   10.720028] usbcore: registered new interface driver usbhid
[   10.720033] usbhid: USB HID core driver
[   10.720926] usbcore: registered new interface driver snd-usb-audio
[   10.722984] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.723801] TCP: cubic registered
[   10.723810] Initializing XFRM netlink socket
[   10.723894] NET: Registered protocol family 10
[   10.724697] mip6: Mobile IPv6
[   10.724705] sit: IPv6 over IPv4 tunneling driver
[   10.725086] NET: Registered protocol family 17
[   10.725108] NET: Registered protocol family 15
[   10.725152] 8021q: 802.1Q VLAN Support v1.8
[   10.725203] Key type dns_resolver registered
[   10.725410] Registering SWP/SWPB emulation handler
[   10.725694] registered taskstats version 1
[   10.737703] Key type encrypted registered
[   10.737727] AppArmor: AppArmor sha1 policy hashing enabled
[   10.738171] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.738179] [DISP] boot_disp:0x0
[   10.738225] HDMI base address: ffffff8000b40000
[   10.739024] [HDMI] power vcc-hdmi-33
[   10.739546] [HDMI] cec support = 0
[   10.758446] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.760946] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.761020] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.761123] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.761148] mmc0: new high speed SDHC card at address aaaa
[   10.761565] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.763597]  mmcblk0: p1
[   10.764710] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.765518] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.765537] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.767934] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.769751] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.770560] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771367] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772171] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772976] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.773783] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774589] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775396] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776203] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776220] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.777054] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.777070] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.850001] input: sunxi-ths as /devices/virtual/input/input2
[   10.850156] thermal thermal_zone0: failed to read out thermal zone 0
[   10.850565] ALSA device list:
[   10.850572]   #0: sndhdmi
[   10.851012] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.447306] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.133614] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.133629] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.133649] scene_lock_destroy name=ehci_standby
[   14.133663] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.133685] usb usb1: USB disconnect, device number 1
[   14.134252] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.134285] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.134293] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.134298] scene_lock_destroy name=ohci_standby
[   14.134306] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.134321] usb usb3: USB disconnect, device number 1
[   14.134696] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.134730] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.134738] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.134784] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.134809] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.138099] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.153320] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.153419] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.153427] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.153434] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.153441] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.153447] usb usb1: SerialNumber: sunxi-ehci
[   14.153914] hub 1-0:1.0: USB hub found
[   14.153934] hub 1-0:1.0: 1 port detected
[   14.154088] scene_lock_init name=ehci_standby
[   14.154096] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.154104] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.154154] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.154172] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.154216] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.216342] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.216358] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.216364] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.216371] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.216377] usb usb3: SerialNumber: sunxi-ohci
[   14.216839] hub 3-0:1.0: USB hub found
[   14.216860] hub 3-0:1.0: 1 port detected
[   14.217049] scene_lock_init name=ohci_standby
[   16.471194] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.855982] systemd[1]: System time before build time, advancing clock.
[   16.893230] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.893536] systemd[1]: Detected architecture arm64.
[   16.921048] systemd[1]: Set hostname to <cluster0>.
[   17.313919] systemd[1]: Listening on udev Kernel Socket.
[   17.331882] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.351404] systemd[1]: Reached target Swap.
[   17.371154] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.391337] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.410556] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.430226] systemd[1]: Listening on udev Control Socket.
[   17.449752] systemd[1]: Reached target Paths.
[   17.469547] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.489183] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.508921] systemd[1]: Listening on Journal Socket.
[   17.529142] systemd[1]: Created slice System Slice.
[   17.549929] systemd[1]: Mounting Huge Pages File System...
[   17.570160] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.588241] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.609212] systemd[1]: Mounting POSIX Message Queue File System...
[   17.628744] systemd[1]: Mounting RPC Pipe File System...
[   17.652365] systemd[1]: Starting Load Kernel Modules...
[   17.672001] systemd[1]: Starting Restore / save the current clock...
[   17.688475] systemd[1]: Starting Nameserver information manager...
[   17.710522] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.725466] systemd[1]: Reached target Encrypted Volumes.
[   17.743646] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.745647] systemd[1]: Created slice User and Session Slice.
[   17.764815] systemd[1]: Reached target Slices.
[   17.786386] systemd[1]: Mounting Debug File System...
[   17.806069] systemd[1]: Starting Set console keymap...
[   17.823998] systemd[1]: Listening on Syslog Socket.
[   17.834034] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.834350] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.834550] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.834709] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.835938] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.848031] systemd[1]: Mounted RPC Pipe File System.
[   17.863459] systemd[1]: Mounted Debug File System.
[   17.883009] systemd[1]: Mounted POSIX Message Queue File System.
[   17.897473] cfg80211: Calling CRDA to update world regulatory domain
[   17.902686] systemd[1]: Mounted Huge Pages File System.
[   17.923570] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.944056] systemd[1]: Started Restore / save the current clock.
[   17.965781] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.983106] systemd[1]: Started Set console keymap.
[   18.012690] systemd[1]: Started Nameserver information manager.
[   18.015980] RTL871X: module init start
[   18.015995] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.016000] RTL871X: build time: Feb  8 2019 10:22:36
[   18.016004] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.016019] sunxi-wlan wlan.26: bus_index: 1
[   18.016159] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.022489] systemd[1]: Time has been changed
[   18.112640] systemd[1]: Reached target Network (Pre).
[   18.124525] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.124618] RTL871X: module init ret=0
[   18.124653] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.131209] systemd[1]: Starting Load/Save Random Seed...
[   18.138568] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.152157] systemd[1]: Starting udev Coldplug all Devices...
[   18.159047] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.159881] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.159912] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.162374] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.164265] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.165105] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.165922] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.166732] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.167547] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.168361] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.170396] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.171540] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.172419] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.173234] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.173267] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.174159] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.174178] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.188574] systemd[1]: Started Load Kernel Modules.
[   18.209338] systemd[1]: Started Load/Save Random Seed.
[   18.228395] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.293076] systemd[1]: Starting udev Kernel Device Manager...
[   18.315910] systemd[1]: Reached target Local File Systems (Pre).
[   18.338176] systemd[1]: Mounting /tmp...
[   18.357196] systemd[1]: Mounting Configuration File System...
[   18.377511] systemd[1]: Mounting FUSE Control File System...
[   18.397686] systemd[1]: Starting Apply Kernel Variables...
[   18.416926] systemd[1]: Mounted FUSE Control File System.
[   18.434198] systemd[1]: Mounted Configuration File System.
[   18.453695] systemd[1]: Mounted /tmp.
[   18.474021] systemd[1]: Started udev Kernel Device Manager.
[   18.494019] systemd[1]: Started udev Coldplug all Devices.
[   18.514985] systemd[1]: Started Apply Kernel Variables.
[   18.582165] systemd[1]: Reached target Sound Card.
[   18.594326] cfg80211: World regulatory domain updated:
[   18.594348] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.594354] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.594360] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.594365] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.594370] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.594375] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.594380] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.594386] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.594391] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.601717] systemd[1]: Reached target Local File Systems.
[   18.618415] sunxi cedar version 0.1
[   18.618726] [cedar]: install start!!!
[   18.618930] ycy the get irq is 90
[   18.619519] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.619530] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.619536] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.619541] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.619547] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.619551] [cedar]: install end!!!
[   18.624624] systemd[1]: Starting Set console font and keymap...
[   18.646297] systemd[1]: Starting Raise network interfaces...
[   18.663055] systemd[1]: Starting Preprocess NFS configuration...
[   18.683055] systemd[1]: Starting Armbian ZRAM config...
[   18.728464] [VFE]cci probe end cci_sel = 0!
[   18.728720] [VFE]cci_init end
[   18.746465] Registered IR keymap rc_map_sunxi
[   18.747025] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.748078] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.754459] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.779121] Driver for 1-wire Dallas network protocol.
[   18.782365] systemd[1]: Starting Journal Service...
[   18.797523] systemd[1]: Started Preprocess NFS configuration.
[   18.837975] IR NEC protocol handler initialized
[   18.843444] systemd[1]: Found device /dev/ttyS0.
[   18.892327] lirc_dev: IR Remote Control driver registered, major 248
[   18.937789] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.966608] IR RC5(x) protocol handler initialized
[   18.968718] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.969519] IR MCE Keyboard/mouse protocol handler initialized
[   18.969884] IR Sony protocol handler initialized
[   18.970301] IR SANYO protocol handler initialized
[   18.970914] IR RC6 protocol handler initialized
[   18.972175] IR JVC protocol handler initialized
[   18.975578] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.975608] IR LIRC bridge handler initialized
[   18.978250] systemd[1]: Reached target NFS client services.
[   18.996554] systemd[1]: Reached target Remote File Systems (Pre).
[   19.021676] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   19.065978] sunxi-bt bt.27: block state already is 1
[   19.066541] systemd[1]: Started Load/Save RF Kill Switch Status.
[   19.155943] [VFE]Welcome to Video Front End driver
[   19.156380] [VFE]csi probe end csi_sel = 0!
[   19.157156] [VFE]csi_init end
[   19.158382] [VFE]isp probe start isp_sel = 0!
[   19.163434] [ISP] isp platform_id = 3!
[   19.163462] [VFE]isp probe end isp_sel = 0!
[   19.167030] [VFE]sunxi_isp_platform_register end
[   19.171300] [VFE]mipi probe start mipi_sel = 0!
[   19.171339] [VFE]mipi probe end mipi_sel = 0!
[   19.172822] [VFE]mipi_init end
[   19.172839] [VFE]flash_init end
[   19.174266] [VFE]vfe_init end
[   19.191799] systemd[1]: Started Journal Service.
[   19.233554] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.251033] zram: Created 6 device(s) ...
[   19.301375] systemd-journald[347]: Received request to flush runtime journal from PID 1
[   19.408447] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.440022] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.467641] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.500655] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.771675] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.771697] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035016 kB
MemFree:         1883760 kB
Buffers:            9608 kB
Cached:            59016 kB
SwapCached:            0 kB
Active:            33228 kB
Inactive:          54456 kB
Active(anon):      19484 kB
Inactive(anon):     2852 kB
Active(file):      13744 kB
Inactive(file):    51604 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017504 kB
SwapFree:        1017504 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         19508 kB
Mapped:            15112 kB
Shmem:              3052 kB
Slab:              23592 kB
SReclaimable:      10376 kB
SUnreclaim:        13216 kB
KernelStack:        1824 kB
PageTables:          708 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035012 kB
Committed_AS:     113720 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633516 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5606
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 62496
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
tmpfs           994M     0  994M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           994M     0  994M   0% /sys/fs/cgroup
tmpfs           994M  4.0K  994M   1% /tmp
/dev/zram0       49M  5.9M   40M  13% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M  5.5M  1.9M  2.8M         /var/log
/dev/zram1             248.4M    4K   78B    4K         [SWAP]
/dev/zram2             248.4M    4K   78B    4K         [SWAP]
/dev/zram3             248.4M    4K   78B    4K         [SWAP]
/dev/zram4             248.4M    4K   78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
07:49:01: 1008MHz  0.00  36%  11%  15%   0%   9%   0%   30°C   22°C  0/7
07:49:01: 1008MHz  0.00  56%  14%  11%   2%  27%   0%   30°C   22°C  0/7
07:49:02: 1152MHz  0.00  52%  12%   6%   2%  31%   0%   30°C   22°C  0/7
07:49:02: 1152MHz  0.08  33%   6%   4%   2%  19%   0%   29°C   22°C  0/7
07:49:02: 1152MHz  0.08  29%   2%  25%   2%   0%   0%   30°C   22°C  0/7
Fri Mar  8 08:55:57 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.065326] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.065335] pid_max: default: 32768 minimum: 301
[   10.065428] Security Framework initialized
[   10.065477] AppArmor: AppArmor initialized
[   10.065512] Mount-cache hash table entries: 256
[   10.075851] Initializing cgroup subsys memory
[   10.075897] Initializing cgroup subsys devices
[   10.075905] Initializing cgroup subsys freezer
[   10.075911] Initializing cgroup subsys blkio
[   10.075917] Initializing cgroup subsys perf_event
[   10.075927] Initializing cgroup subsys hugetlb
[   10.075991] ftrace: allocating 28898 entries in 113 pages
[   10.109751] CPU0: update cpu_power 1968128
[   10.109773] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.110747] virtual base = 0xffffff800000a000.
[   10.110760] gicd_base = 0xffffff800000c000.
[   10.110764] gicc_base = 0xffffff800000e000.
[   10.111396] CPU1: Booted secondary processor
[   10.111423] CPU1: update cpu_power 1968128
[   10.114019] CPU2: Booted secondary processor
[   10.114030] CPU2: update cpu_power 1968128
[   10.118138] CPU3: Booted secondary processor
[   10.118149] CPU3: update cpu_power 1968128
[   10.118221] Brought up 4 CPUs
[   10.118242] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.118743] devtmpfs: initialized
[   10.123706] pinctrl core: initialized pinctrl subsystem
[   10.126141] NET: Registered protocol family 16
[   10.126399] script_sysfs_init success
[   10.126633] dump_class_init,806, success
[   10.126875] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.126896] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.128175] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.129228] DMA: preallocated 256 KiB pool for atomic allocations
[   10.129344] Serial: AMBA PL011 UART driver
[   10.129444] axp81x_board_init: axp regl_devs num = 23
[   10.129587] pll_audio-set_default_rate=24576000 success!
[   10.129605] pll_video0-set_default_rate=297000000 success!
[   10.129676] pll_video1-set_default_rate=297000000 success!
[   10.129737] pll_de-set_default_rate=297000000 success!
[   10.130452] de-set_default_source=pll_de success!
[   10.130458] de-set_default_rate=297000000 success!
[   10.130501] tcon0-set_default_source=pll_mipi success!
[   10.130532] tcon1-set_default_source=pll_video0 success!
[   10.130748] hdmi-set_default_source=pll_video0 success!
[   10.132977] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.133135] [sun50iw1p1_pinctrl_probe][838]
[   10.134571] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.135196] sunxi hwspinlock vbase:0xffffff800005c000
[   10.145433] bio: create slab <bio-0> at 0
[   10.145780] pwm module init!
[   10.147002] SCSI subsystem initialized
[   10.147126] usbcore: registered new interface driver usbfs
[   10.147159] usbcore: registered new interface driver hub
[   10.147221] usbcore: registered new device driver usb
[   10.147918] Linux video capture interface: v2.00
[   10.148357] [ARISC] :sunxi-arisc driver v1.10
[   10.155292] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.155538] Advanced Linux Sound Architecture Driver Initialized.
[   10.155884] NetLabel: Initializing
[   10.155890] NetLabel:  domain hash size = 128
[   10.155894] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.155933] NetLabel:  unlabeled traffic allowed by default
[   10.156096] [pm]aw_pm_init!
[   10.156160] rtc physical base = 0x0000000001f00000 .
[   10.156194] np name = /soc@01c00000/rtc@01f00000.
[   10.156201] base = ffffff800006e100, len = 4.
[   10.156206] pmu name: pmu0 .
[   10.156241] pmu0_enable = 0x1.
[   10.156246] pmux_id = 0x6.
[   10.156253] pmux_twi_id = 0x1.
[   10.156258] pmux_twi_addr = 0x34.
[   10.156262] pmu name: pmu1 .
[   10.156311] Warning: can not find np for pmu1.
[   10.156541] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.156701] after inited: sys_mask config = 0x4a55.
[   10.156723] Warning: can not find np for dynamic_standby_para.
[   10.156858] [pm]valid
[   10.156862] [pm]valid
[   10.156866] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.157069] Switching to clocksource arch_sys_counter_ool
[   10.175034] AppArmor: AppArmor Filesystem Enabled
[   10.181618] NET: Registered protocol family 2
[   10.182303] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.182544] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.182854] TCP: Hash tables configured (established 16384 bind 16384)
[   10.182938] TCP: reno registered
[   10.182947] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.182999] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.183252] NET: Registered protocol family 1
[   10.183577] RPC: Registered named UNIX socket transport module.
[   10.183583] RPC: Registered udp transport module.
[   10.183587] RPC: Registered tcp transport module.
[   10.183592] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.183768] Trying to unpack rootfs image as initramfs...
[   10.388248] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.388834] kvm [1]: Using HYP init bounce page @b7889000
[   10.389350] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.389772] kvm [1]: timer IRQ27
[   10.389787] kvm [1]: Hyp mode initialized successfully
[   10.391501] lock super standby defaultly!
[   10.391517] lookup_scene_lock_name: new scene lock super_standby
[   10.391522] scene_lock_init name=super_standby
[   10.391528] scene_lock: super_standby, type 5, count 1
[   10.391934] audit: initializing netlink socket (disabled)
[   10.391992] type=2000 audit(0.310:1): initialized
[   10.392671] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.393134] VFS: Disk quotas dquot_6.5.2
[   10.393233] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.394210] NFS: Registering the id_resolver key type
[   10.394256] Key type id_resolver registered
[   10.394261] Key type id_legacy registered
[   10.394273] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.394409] NTFS driver 2.1.30 [Flags: R/W].
[   10.394583] fuse init (API version 7.22)
[   10.394754] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.395177] msgmni has been set to 3973
[   10.396135] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.396217] io scheduler noop registered
[   10.396223] io scheduler deadline registered
[   10.396248] io scheduler cfq registered (default)
[   10.396836] [DISP]disp_module_init
[   10.397289] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.397296] [DISP] boot_disp:0x0
[   10.397885] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.398017] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.398148] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.399259] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.399265] [DISP] fb_base:0x0
[   10.416976] Console: switching to colour frame buffer device 160x45
[   10.431430] [DISP]disp_module_init finish
[   10.431848] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.431870] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.432229] console [ttyS0] enabled
[   10.432605] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.433036] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.433343] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.433628] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.433984] misc dump reg init
[   10.434139] [drm] Initialized drm 1.1.0 20060810
[   10.436283] brd: module loaded
[   10.438403] loop: module loaded
[   10.438681] sunxi-bt bt.27: Missing bt_power.
[   10.438689] sunxi-bt bt.27: bt_power_name ((null))
[   10.438697] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.438733] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.438776] sunxi-bt bt.27: clk not config
[   10.438847] sunxi-bt bt.27: block state already is 1
[   10.439034] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.439041] sunxi-wlan wlan.26: Missing wlan_power.
[   10.439047] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.439055] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.439071] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.439089] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.439107] sunxi-wlan wlan.26: clk not config
[   10.439811] WARNING: Get ephy clock is failed
[   10.440435] chipid-sunxi serial 140050374620201507cf
[   10.440527] PPP generic driver version 2.4.2
[   10.440680] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.440787] get ehci0-controller drv_vbus_gpio is fail
[   10.440793] get ehci0-controller, regulator_io is no nocare
[   10.440832] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.440888] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.440907] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.441294] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.452330] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.452399] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.452406] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.452413] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.452420] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.452426] usb usb1: SerialNumber: sunxi-ehci
[   10.452779] hub 1-0:1.0: USB hub found
[   10.452795] hub 1-0:1.0: 1 port detected
[   10.452930] scene_lock_init name=ehci_standby
[   10.453004] get ehci1-controller drv_vbus_gpio is fail
[   10.453010] get ehci1-controller, regulator_io is no nocare
[   10.453052] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.453101] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.453120] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.453360] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.472014] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.472056] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.472064] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.472071] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.472077] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.472083] usb usb2: SerialNumber: sunxi-ehci
[   10.472362] hub 2-0:1.0: USB hub found
[   10.472375] hub 2-0:1.0: 1 port detected
[   10.472496] scene_lock_init name=ehci_standby
[   10.472684] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.472829] get ohci0-controller drv_vbus_gpio is fail
[   10.472835] get ohci0-controller, regulator_io is no nocare
[   10.472876] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.472923] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.472939] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.472968] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.535024] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.535032] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.535039] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.535046] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.535052] usb usb3: SerialNumber: sunxi-ohci
[   10.535330] hub 3-0:1.0: USB hub found
[   10.535343] hub 3-0:1.0: 1 port detected
[   10.535459] scene_lock_init name=ohci_standby
[   10.535518] get ohci1-controller drv_vbus_gpio is fail
[   10.535523] get ohci1-controller, regulator_io is no nocare
[   10.535557] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.535596] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.535614] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.535640] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.594053] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.594061] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.594068] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.594075] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.594081] usb usb4: SerialNumber: sunxi-ohci
[   10.594341] hub 4-0:1.0: USB hub found
[   10.594354] hub 4-0:1.0: 1 port detected
[   10.594468] scene_lock_init name=ohci_standby
[   10.594768] usbcore: registered new interface driver usb-storage
[   10.594799] usbcore: registered new interface driver ums-alauda
[   10.594827] usbcore: registered new interface driver ums-cypress
[   10.594853] usbcore: registered new interface driver ums-datafab
[   10.594877] usbcore: registered new interface driver ums_eneub6250
[   10.594900] usbcore: registered new interface driver ums-freecom
[   10.594925] usbcore: registered new interface driver ums-isd200
[   10.594948] usbcore: registered new interface driver ums-jumpshot
[   10.594971] usbcore: registered new interface driver ums-karma
[   10.594995] usbcore: registered new interface driver ums-onetouch
[   10.595029] usbcore: registered new interface driver ums-realtek
[   10.595054] usbcore: registered new interface driver ums-sddr09
[   10.595079] usbcore: registered new interface driver ums-sddr55
[   10.595103] usbcore: registered new interface driver ums-usbat
[   10.595189] usbcore: registered new interface driver usbserial
[   10.595216] usbcore: registered new interface driver usbserial_generic
[   10.595240] usbserial: USB Serial support registered for generic
[   10.595447] mousedev: PS/2 mouse device common for all mice
[   10.595885] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.596824] get ctp_para failed, -1
[   10.596843] get node gsensor failed
[   10.596847] get sysconfig para erro!
[   10.596857] get node lightsensor failed
[   10.596860] get sysconfig para erro!
[   10.596870] get node gyroscopesensor failed
[   10.596873] get sysconfig para erro!
[   10.596882] get node compasssensor failed
[   10.596886] get sysconfig para erro!
[   10.597160] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.597181] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.597351] i2c /dev entries driver
[   10.639859] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.643325] sunxi budget cooling probe start !
[   10.643355] CPU freq cooling register Success
[   10.643375] CPU hotplug cooling register Success
[   10.643462] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.643469] CPU budget cooling register Success
[   10.643683] sunxi gpu cooling probe start !
[   10.643693] CPU gpu cooling register Success
[   10.644341] cpuidle: using governor ladder
[   10.644348] cpuidle: using governor menu
[   10.645091] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.645121] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.645130] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.645138] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.645188] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.645195] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.645795] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.645818] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.596911] wakeup gpio set err!get node ctp failed
[   10.649189] get sysconfig para erro!
[   10.658962] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.678652] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.679033] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.679059] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.679066] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.679073] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.679078] get() with no identifier
[   10.679081] get() with no identifier
[   10.679085] get() with no identifier
[   10.679091] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.679097] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.679102] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.679475] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.679491] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.679509] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.680297] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.680316] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.682698] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.684843] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.685657] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.686469] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687280] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687905] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.687948] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.690322] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.698320] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.718007] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.718702] ledtrig-cpu: registered to indicate activity on CPUs
[   10.718771] hidraw: raw HID events driver (C) Jiri Kosina
[   10.718912] usbcore: registered new interface driver usbhid
[   10.718917] usbhid: USB HID core driver
[   10.719784] usbcore: registered new interface driver snd-usb-audio
[   10.721761] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.722541] TCP: cubic registered
[   10.722550] Initializing XFRM netlink socket
[   10.722631] NET: Registered protocol family 10
[   10.723451] mip6: Mobile IPv6
[   10.723459] sit: IPv6 over IPv4 tunneling driver
[   10.723840] NET: Registered protocol family 17
[   10.723862] NET: Registered protocol family 15
[   10.723910] 8021q: 802.1Q VLAN Support v1.8
[   10.723957] Key type dns_resolver registered
[   10.724165] Registering SWP/SWPB emulation handler
[   10.724458] registered taskstats version 1
[   10.736417] Key type encrypted registered
[   10.736439] AppArmor: AppArmor sha1 policy hashing enabled
[   10.736879] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.736887] [DISP] boot_disp:0x0
[   10.736933] HDMI base address: ffffff8000b40000
[   10.737706] [HDMI] power vcc-hdmi-33
[   10.738230] [HDMI] cec support = 0
[   10.757312] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.759811] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.759887] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.759988] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.760014] mmc0: new high speed SDHC card at address aaaa
[   10.760408] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.762439]  mmcblk0: p1
[   10.763554] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.764362] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.764379] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.766769] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.768587] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.769395] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.770202] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771007] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771811] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772618] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.773425] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.774232] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775039] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775055] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.775889] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.775906] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.848689] input: sunxi-ths as /devices/virtual/input/input2
[   10.848854] thermal thermal_zone0: failed to read out thermal zone 0
[   10.849276] ALSA device list:
[   10.849282]   #0: sndhdmi
[   10.849719] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.446179] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.132486] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.132503] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.132524] scene_lock_destroy name=ehci_standby
[   14.132537] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.132559] usb usb1: USB disconnect, device number 1
[   14.133119] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.133152] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.133160] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.133165] scene_lock_destroy name=ohci_standby
[   14.133172] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.133187] usb usb3: USB disconnect, device number 1
[   14.133562] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.133596] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.133604] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.133648] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.133671] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.137106] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.152196] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.152291] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.152299] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.152306] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.152312] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.152319] usb usb1: SerialNumber: sunxi-ehci
[   14.152786] hub 1-0:1.0: USB hub found
[   14.152805] hub 1-0:1.0: 1 port detected
[   14.152959] scene_lock_init name=ehci_standby
[   14.152967] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.152975] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.153025] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.153045] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.153089] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.215218] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.215233] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.215240] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.215247] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.215253] usb usb3: SerialNumber: sunxi-ohci
[   14.215712] hub 3-0:1.0: USB hub found
[   14.215733] hub 3-0:1.0: 1 port detected
[   14.215919] scene_lock_init name=ohci_standby
[   16.380427] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.765267] systemd[1]: System time before build time, advancing clock.
[   16.802365] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.802669] systemd[1]: Detected architecture arm64.
[   16.831389] systemd[1]: Set hostname to <cluster0>.
[   17.219911] systemd[1]: Reached target Encrypted Volumes.
[   17.242179] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.262167] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.281473] systemd[1]: Listening on Syslog Socket.
[   17.301100] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.320727] systemd[1]: Reached target Swap.
[   17.340847] systemd[1]: Created slice User and Session Slice.
[   17.360242] systemd[1]: Listening on Journal Socket.
[   17.380076] systemd[1]: Created slice System Slice.
[   17.401100] systemd[1]: Mounting RPC Pipe File System...
[   17.421218] systemd[1]: Mounting POSIX Message Queue File System...
[   17.441787] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.461410] systemd[1]: Starting Restore / save the current clock...
[   17.478932] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.500098] systemd[1]: Starting Nameserver information manager...
[   17.511923] systemd[1]: Starting Load Kernel Modules...
[   17.517034] systemd[1]: Reached target Slices.
[   17.537599] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.559205] systemd[1]: Mounting Huge Pages File System...
[   17.578542] systemd[1]: Starting Set console keymap...
[   17.596590] systemd[1]: Listening on udev Kernel Socket.
[   17.616765] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.619628] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.619958] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.620136] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.620313] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.621539] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.653873] systemd[1]: Mounting Debug File System...
[   17.665501] systemd[1]: Listening on udev Control Socket.
[   17.675646] cfg80211: Calling CRDA to update world regulatory domain
[   17.686938] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.705006] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.724388] systemd[1]: Reached target Paths.
[   17.748380] systemd[1]: Mounted RPC Pipe File System.
[   17.763835] systemd[1]: Mounted Debug File System.
[   17.783505] systemd[1]: Mounted POSIX Message Queue File System.
[   17.787383] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.802113] RTL871X: module init start
[   17.802129] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.802134] RTL871X: build time: Feb  8 2019 10:22:36
[   17.802139] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.802154] sunxi-wlan wlan.26: bus_index: 1
[   17.802319] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   17.803245] systemd[1]: Mounted Huge Pages File System.
[   17.825937] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.853319] systemd[1]: Started Restore / save the current clock.
[   17.875477] systemd[1]: Started Set console keymap.
[   17.892827] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.910675] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.910771] RTL871X: module init ret=0
[   17.910785] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   17.913811] systemd[1]: Started Nameserver information manager.
[   17.920966] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.922005] systemd[1]: Started Load Kernel Modules.
[   17.941401] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.942233] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   17.942265] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.943772] systemd[1]: Time has been changed
[   17.944750] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.946624] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   17.947442] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.948251] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.949061] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.949871] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   17.950692] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.951504] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.952315] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.953127] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   17.953150] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   17.954022] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   17.954041] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.050622] systemd[1]: Mounting FUSE Control File System...
[   18.057524] systemd[1]: Starting Apply Kernel Variables...
[   18.064274] systemd[1]: Mounting Configuration File System...
[   18.088471] systemd[1]: Reached target Network (Pre).
[   18.109874] systemd[1]: Starting Load/Save Random Seed...
[   18.131068] systemd[1]: Starting udev Coldplug all Devices...
[   18.149479] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.169955] systemd[1]: Mounted FUSE Control File System.
[   18.187009] systemd[1]: Mounted Configuration File System.
[   18.208115] systemd[1]: Started Apply Kernel Variables.
[   18.227098] systemd[1]: Started Load/Save Random Seed.
[   18.248322] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.323165] systemd[1]: Reached target Local File Systems (Pre).
[   18.348857] systemd[1]: Mounting /tmp...
[   18.365927] systemd[1]: Starting udev Kernel Device Manager...
[   18.386467] systemd[1]: Mounted /tmp.
[   18.409127] systemd[1]: Reached target Local File Systems.
[   18.435254] systemd[1]: Starting Set console font and keymap...
[   18.455249] systemd[1]: Starting Preprocess NFS configuration...
[   18.475036] systemd[1]: Starting Armbian ZRAM config...
[   18.514345] systemd[1]: Starting Raise network interfaces...
[   18.556717] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.583382] systemd[1]: Starting Journal Service...
[   18.603083] systemd[1]: Started udev Kernel Device Manager.
[   18.624287] systemd[1]: Started udev Coldplug all Devices.
[   18.640864] systemd[1]: Started Preprocess NFS configuration.
[   18.832481] cfg80211: World regulatory domain updated:
[   18.832509] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.832516] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.832521] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.832527] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.832533] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.832538] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.832543] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.832549] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.832554] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.880714] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   18.888797] systemd[1]: Reached target Sound Card.
[   18.905403] systemd[1]: Reached target NFS client services.
[   18.915085] sunxi cedar version 0.1
[   18.915371] [cedar]: install start!!!
[   18.915529] ycy the get irq is 90
[   18.916065] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.916068] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.916071] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.916080] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.916084] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.916088] [cedar]: install end!!!
[   18.925606] systemd[1]: Reached target Remote File Systems (Pre).
[   18.945029] systemd[1]: Started Journal Service.
[   19.128662] Registered IR keymap rc_map_sunxi
[   19.129171] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   19.130871] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   19.166408] Driver for 1-wire Dallas network protocol.
[   19.193644] [VFE]cci probe end cci_sel = 0!
[   19.193896] [VFE]cci_init end
[   19.230203] systemd-journald[318]: Received request to flush runtime journal from PID 1
[   19.231539] IR NEC protocol handler initialized
[   19.232522] IR RC5(x) protocol handler initialized
[   19.232707] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   19.233128] IR MCE Keyboard/mouse protocol handler initialized
[   19.233376] IR JVC protocol handler initialized
[   19.234434] IR RC6 protocol handler initialized
[   19.235534] IR SANYO protocol handler initialized
[   19.238107] IR Sony protocol handler initialized
[   19.253251] sunxi-bt bt.27: block state already is 1
[   19.259887] lirc_dev: IR Remote Control driver registered, major 248
[   19.281072] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   19.281088] IR LIRC bridge handler initialized
[   19.309386] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.329143] zram: Created 6 device(s) ...
[   19.455402] [VFE]Welcome to Video Front End driver
[   19.455789] [VFE]csi probe end csi_sel = 0!
[   19.456573] [VFE]csi_init end
[   19.457061] [VFE]isp probe start isp_sel = 0!
[   19.458799] [ISP] isp platform_id = 3!
[   19.458823] [VFE]isp probe end isp_sel = 0!
[   19.458916] [VFE]sunxi_isp_platform_register end
[   19.460093] [VFE]mipi probe start mipi_sel = 0!
[   19.460133] [VFE]mipi probe end mipi_sel = 0!
[   19.460194] [VFE]mipi_init end
[   19.460202] [VFE]flash_init end
[   19.461719] [VFE]vfe_init end
[   19.520681] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.546422] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.570208] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.596005] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.804505] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.804526] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1885780 kB
Buffers:            9536 kB
Cached:            57952 kB
SwapCached:            0 kB
Active:            31420 kB
Inactive:          53820 kB
Active(anon):      18300 kB
Inactive(anon):     2864 kB
Active(file):      13120 kB
Inactive(file):    50956 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:               168 kB
Writeback:             0 kB
AnonPages:         18304 kB
Mapped:            14708 kB
Shmem:              3052 kB
Slab:              23660 kB
SReclaimable:      10240 kB
SUnreclaim:        13420 kB
PageTables:          508 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:     102616 kB
VmallocChunk:   251633468 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62493
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
/dev/mmcblk0p1   15G  962M   14G   7% /
/dev/zram0       49M  6.1M   39M  14% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  5.7M    2M  2.9M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
08:56:00: 1008MHz  0.00  36%  11%  15%   0%   8%   0%   28°C   20°C  0/7
08:56:01: 1008MHz  0.00  53%  15%   8%   3%  26%   0%   28°C   20°C  0/7
08:56:01: 1152MHz  0.00  49%  10%   7%   1%  29%   0%   28°C   20°C  0/7
08:56:01: 1152MHz  0.16  35%   6%   9%   0%  18%   0%   28°C   20°C  0/7
08:56:02: 1152MHz  0.16  29%   3%  25%   0%   0%   0%   28°C   20°C  0/7
### Activated 4 lzo zram swap devices with 248 MB each
### Activated Armbian ramlog partition with  compression
Fri Mar  8 09:36:34 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.107-pine64 (root@armbian.com) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #2 SMP PREEMPT Fri Feb 8 10:23:10 CET 2019
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: SOPine
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s19520 r8192 d21440 u49152
[    0.000000] pcpu-alloc: s19520 r8192 d21440 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: root=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr= panic=10 consoleblank=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1964644k/1964644k available, 116124k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                     .init : 0xffffffc000b59000 - 0xffffffc000be0c40   (   544 kB)
                     .text : 0xffffffc000080000 - 0xffffffc000b58164   ( 11105 kB)
                     .data : 0xffffffc000be1000 - 0xffffffc000d50e48   (  1472 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[   10.066885] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.066894] pid_max: default: 32768 minimum: 301
[   10.066987] Security Framework initialized
[   10.067036] AppArmor: AppArmor initialized
[   10.067071] Mount-cache hash table entries: 256
[   10.077404] Initializing cgroup subsys memory
[   10.077451] Initializing cgroup subsys devices
[   10.077458] Initializing cgroup subsys freezer
[   10.077464] Initializing cgroup subsys blkio
[   10.077470] Initializing cgroup subsys perf_event
[   10.077480] Initializing cgroup subsys hugetlb
[   10.077543] ftrace: allocating 28898 entries in 113 pages
[   10.111313] CPU0: update cpu_power 1968128
[   10.111335] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.112322] virtual base = 0xffffff800000a000.
[   10.112334] gicd_base = 0xffffff800000c000.
[   10.112339] gicc_base = 0xffffff800000e000.
[   10.112968] CPU1: Booted secondary processor
[   10.112995] CPU1: update cpu_power 1968128
[   10.115594] CPU2: Booted secondary processor
[   10.115605] CPU2: update cpu_power 1968128
[   10.119711] CPU3: Booted secondary processor
[   10.119722] CPU3: update cpu_power 1968128
[   10.119795] Brought up 4 CPUs
[   10.119817] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.120319] devtmpfs: initialized
[   10.125283] pinctrl core: initialized pinctrl subsystem
[   10.127736] NET: Registered protocol family 16
[   10.127994] script_sysfs_init success
[   10.128232] dump_class_init,806, success
[   10.128475] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.128495] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.129772] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.130820] DMA: preallocated 256 KiB pool for atomic allocations
[   10.130937] Serial: AMBA PL011 UART driver
[   10.131037] axp81x_board_init: axp regl_devs num = 23
[   10.131180] pll_audio-set_default_rate=24576000 success!
[   10.131200] pll_video0-set_default_rate=297000000 success!
[   10.131271] pll_video1-set_default_rate=297000000 success!
[   10.131334] pll_de-set_default_rate=297000000 success!
[   10.132051] de-set_default_source=pll_de success!
[   10.132057] de-set_default_rate=297000000 success!
[   10.132099] tcon0-set_default_source=pll_mipi success!
[   10.132130] tcon1-set_default_source=pll_video0 success!
[   10.132344] hdmi-set_default_source=pll_video0 success!
[   10.134576] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.134732] [sun50iw1p1_pinctrl_probe][838]
[   10.136178] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.136802] sunxi hwspinlock vbase:0xffffff800005c000
[   10.147060] bio: create slab <bio-0> at 0
[   10.147403] pwm module init!
[   10.148627] SCSI subsystem initialized
[   10.148751] usbcore: registered new interface driver usbfs
[   10.148785] usbcore: registered new interface driver hub
[   10.148845] usbcore: registered new device driver usb
[   10.149540] Linux video capture interface: v2.00
[   10.149979] [ARISC] :sunxi-arisc driver v1.10
[   10.156903] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.157152] Advanced Linux Sound Architecture Driver Initialized.
[   10.157497] NetLabel: Initializing
[   10.157502] NetLabel:  domain hash size = 128
[   10.157506] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.157544] NetLabel:  unlabeled traffic allowed by default
[   10.157705] [pm]aw_pm_init!
[   10.157771] rtc physical base = 0x0000000001f00000 .
[   10.157802] np name = /soc@01c00000/rtc@01f00000.
[   10.157808] base = ffffff800006e100, len = 4.
[   10.157813] pmu name: pmu0 .
[   10.157846] pmu0_enable = 0x1.
[   10.157852] pmux_id = 0x6.
[   10.157859] pmux_twi_id = 0x1.
[   10.157864] pmux_twi_addr = 0x34.
[   10.157868] pmu name: pmu1 .
[   10.157916] Warning: can not find np for pmu1.
[   10.158146] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.158307] after inited: sys_mask config = 0x4a55.
[   10.158329] Warning: can not find np for dynamic_standby_para.
[   10.158459] [pm]valid
[   10.158462] [pm]valid
[   10.158467] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.158670] Switching to clocksource arch_sys_counter_ool
[   10.176650] AppArmor: AppArmor Filesystem Enabled
[   10.183247] NET: Registered protocol family 2
[   10.183938] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.184179] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.184489] TCP: Hash tables configured (established 16384 bind 16384)
[   10.184573] TCP: reno registered
[   10.184583] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.184635] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.184886] NET: Registered protocol family 1
[   10.185206] RPC: Registered named UNIX socket transport module.
[   10.185212] RPC: Registered udp transport module.
[   10.185216] RPC: Registered tcp transport module.
[   10.185220] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.185398] Trying to unpack rootfs image as initramfs...
[   10.389810] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.390397] kvm [1]: Using HYP init bounce page @b7889000
[   10.390921] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.391342] kvm [1]: timer IRQ27
[   10.391357] kvm [1]: Hyp mode initialized successfully
[   10.393059] lock super standby defaultly!
[   10.393076] lookup_scene_lock_name: new scene lock super_standby
[   10.393081] scene_lock_init name=super_standby
[   10.393088] scene_lock: super_standby, type 5, count 1
[   10.393502] audit: initializing netlink socket (disabled)
[   10.393560] type=2000 audit(0.310:1): initialized
[   10.394243] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.394703] VFS: Disk quotas dquot_6.5.2
[   10.394804] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.395782] NFS: Registering the id_resolver key type
[   10.395827] Key type id_resolver registered
[   10.395832] Key type id_legacy registered
[   10.395844] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.395983] NTFS driver 2.1.30 [Flags: R/W].
[   10.396159] fuse init (API version 7.22)
[   10.396330] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.396753] msgmni has been set to 3973
[   10.397708] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.397790] io scheduler noop registered
[   10.397796] io scheduler deadline registered
[   10.397821] io scheduler cfq registered (default)
[   10.398409] [DISP]disp_module_init
[   10.398857] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.398865] [DISP] boot_disp:0x0
[   10.399458] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.399590] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.399722] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.400832] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.400838] [DISP] fb_base:0x0
[   10.418579] Console: switching to colour frame buffer device 160x45
[   10.433028] [DISP]disp_module_init finish
[   10.433446] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.433469] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.433827] console [ttyS0] enabled
[   10.434203] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.434642] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.434952] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.435235] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.435587] misc dump reg init
[   10.435738] [drm] Initialized drm 1.1.0 20060810
[   10.437884] brd: module loaded
[   10.440003] loop: module loaded
[   10.440283] sunxi-bt bt.27: Missing bt_power.
[   10.440291] sunxi-bt bt.27: bt_power_name ((null))
[   10.440299] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.440332] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.440375] sunxi-bt bt.27: clk not config
[   10.440446] sunxi-bt bt.27: block state already is 1
[   10.440632] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.440639] sunxi-wlan wlan.26: Missing wlan_power.
[   10.440646] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.440653] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.440670] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.440688] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.440706] sunxi-wlan wlan.26: clk not config
[   10.441405] WARNING: Get ephy clock is failed
[   10.442029] chipid-sunxi serial 140050374620201507cf
[   10.442124] PPP generic driver version 2.4.2
[   10.442278] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.442386] get ehci0-controller drv_vbus_gpio is fail
[   10.442392] get ehci0-controller, regulator_io is no nocare
[   10.442430] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.442486] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.442505] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.442861] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.453932] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.454001] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.454009] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.454016] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454022] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.454028] usb usb1: SerialNumber: sunxi-ehci
[   10.454387] hub 1-0:1.0: USB hub found
[   10.454404] hub 1-0:1.0: 1 port detected
[   10.454538] scene_lock_init name=ehci_standby
[   10.454614] get ehci1-controller drv_vbus_gpio is fail
[   10.454620] get ehci1-controller, regulator_io is no nocare
[   10.454660] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.454708] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454727] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.454965] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.473615] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.473657] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.473665] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.473672] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.473678] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.473684] usb usb2: SerialNumber: sunxi-ehci
[   10.473965] hub 2-0:1.0: USB hub found
[   10.473978] hub 2-0:1.0: 1 port detected
[   10.474099] scene_lock_init name=ehci_standby
[   10.474285] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.474431] get ohci0-controller drv_vbus_gpio is fail
[   10.474437] get ohci0-controller, regulator_io is no nocare
[   10.474476] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.474523] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.474539] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.474569] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.536623] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.536632] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.536639] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.536645] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.536651] usb usb3: SerialNumber: sunxi-ohci
[   10.536925] hub 3-0:1.0: USB hub found
[   10.536939] hub 3-0:1.0: 1 port detected
[   10.537055] scene_lock_init name=ohci_standby
[   10.537115] get ohci1-controller drv_vbus_gpio is fail
[   10.537121] get ohci1-controller, regulator_io is no nocare
[   10.537154] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.537194] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.537212] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.537236] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.595654] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.595662] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.595669] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.595676] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.595682] usb usb4: SerialNumber: sunxi-ohci
[   10.595943] hub 4-0:1.0: USB hub found
[   10.595956] hub 4-0:1.0: 1 port detected
[   10.596072] scene_lock_init name=ohci_standby
[   10.596368] usbcore: registered new interface driver usb-storage
[   10.596399] usbcore: registered new interface driver ums-alauda
[   10.596425] usbcore: registered new interface driver ums-cypress
[   10.596451] usbcore: registered new interface driver ums-datafab
[   10.596474] usbcore: registered new interface driver ums_eneub6250
[   10.596497] usbcore: registered new interface driver ums-freecom
[   10.596522] usbcore: registered new interface driver ums-isd200
[   10.596545] usbcore: registered new interface driver ums-jumpshot
[   10.596568] usbcore: registered new interface driver ums-karma
[   10.596592] usbcore: registered new interface driver ums-onetouch
[   10.596626] usbcore: registered new interface driver ums-realtek
[   10.596651] usbcore: registered new interface driver ums-sddr09
[   10.596676] usbcore: registered new interface driver ums-sddr55
[   10.596700] usbcore: registered new interface driver ums-usbat
[   10.596783] usbcore: registered new interface driver usbserial
[   10.596810] usbcore: registered new interface driver usbserial_generic
[   10.596835] usbserial: USB Serial support registered for generic
[   10.597041] mousedev: PS/2 mouse device common for all mice
[   10.597480] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.598433] get ctp_para failed, -1
[   10.598449] get node gsensor failed
[   10.598454] get sysconfig para erro!
[   10.598464] get node lightsensor failed
[   10.598468] get sysconfig para erro!
[   10.598477] get node gyroscopesensor failed
[   10.598480] get sysconfig para erro!
[   10.598489] get node compasssensor failed
[   10.598493] get sysconfig para erro!
[   10.598658] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.598679] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.598852] i2c /dev entries driver
[   10.641462] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.644935] sunxi budget cooling probe start !
[   10.644965] CPU freq cooling register Success
[   10.644984] CPU hotplug cooling register Success
[   10.645071] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.645078] CPU budget cooling register Success
[   10.645292] sunxi gpu cooling probe start !
[   10.645301] CPU gpu cooling register Success
[   10.645951] cpuidle: using governor ladder
[   10.645958] cpuidle: using governor menu
[   10.646700] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.646729] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.646738] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.646746] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.646795] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.646802] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.647414] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.647439] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.598521] wakeup gpio set err!get node ctp failed
[   10.650758] get sysconfig para erro!
[   10.660563] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.680251] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.680617] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.680643] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.680650] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.680657] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.680662] get() with no identifier
[   10.680666] get() with no identifier
[   10.680669] get() with no identifier
[   10.680675] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.680681] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.680686] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.681068] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.681085] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.681103] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.681887] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.681906] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.684291] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.686431] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687245] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688057] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688868] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.689493] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.689536] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.691910] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.699922] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.719610] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.720315] ledtrig-cpu: registered to indicate activity on CPUs
[   10.720384] hidraw: raw HID events driver (C) Jiri Kosina
[   10.720525] usbcore: registered new interface driver usbhid
[   10.720530] usbhid: USB HID core driver
[   10.721391] usbcore: registered new interface driver snd-usb-audio
[   10.723370] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.724152] TCP: cubic registered
[   10.724162] Initializing XFRM netlink socket
[   10.724241] NET: Registered protocol family 10
[   10.725060] mip6: Mobile IPv6
[   10.725068] sit: IPv6 over IPv4 tunneling driver
[   10.725448] NET: Registered protocol family 17
[   10.725470] NET: Registered protocol family 15
[   10.725518] 8021q: 802.1Q VLAN Support v1.8
[   10.725561] Key type dns_resolver registered
[   10.725766] Registering SWP/SWPB emulation handler
[   10.726060] registered taskstats version 1
[   10.738084] Key type encrypted registered
[   10.738106] AppArmor: AppArmor sha1 policy hashing enabled
[   10.738550] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.738558] [DISP] boot_disp:0x0
[   10.738605] HDMI base address: ffffff8000b40000
[   10.739444] [HDMI] power vcc-hdmi-33
[   10.739966] [HDMI] cec support = 0
[   10.758918] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.761417] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.761492] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.761594] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.761620] mmc0: new high speed SDHC card at address aaaa
[   10.762016] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.764046]  mmcblk0: p1
[   10.765160] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.765969] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.765987] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.768380] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.770200] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.771009] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.771815] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772620] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.773424] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.774231] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775038] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775845] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776652] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776668] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.777502] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.777518] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.850431] input: sunxi-ths as /devices/virtual/input/input2
[   10.850593] thermal thermal_zone0: failed to read out thermal zone 0
[   10.851020] ALSA device list:
[   10.851027]   #0: sndhdmi
[   10.851465] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.447790] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.134086] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.134101] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.134121] scene_lock_destroy name=ehci_standby
[   14.134134] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.134157] usb usb1: USB disconnect, device number 1
[   14.134701] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.134733] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.134742] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.134747] scene_lock_destroy name=ohci_standby
[   14.134755] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.134771] usb usb3: USB disconnect, device number 1
[   14.135132] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.135167] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.135175] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.135223] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.135247] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.136275] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.153787] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.153881] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.153889] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.153896] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.153903] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.153909] usb usb1: SerialNumber: sunxi-ehci
[   14.154403] hub 1-0:1.0: USB hub found
[   14.154421] hub 1-0:1.0: 1 port detected
[   14.154575] scene_lock_init name=ehci_standby
[   14.154583] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.154592] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.154642] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.154661] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.154721] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.216827] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.216843] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.216851] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.216857] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.216864] usb usb3: SerialNumber: sunxi-ohci
[   14.217325] hub 3-0:1.0: USB hub found
[   14.217347] hub 3-0:1.0: 1 port detected
[   14.217506] scene_lock_init name=ohci_standby
[   16.422885] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.805260] systemd[1]: System time before build time, advancing clock.
[   16.842368] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.842672] systemd[1]: Detected architecture arm64.
[   16.872351] systemd[1]: Set hostname to <cluster0>.
[   17.261832] systemd[1]: Created slice System Slice.
[   17.283233] systemd[1]: Listening on udev Control Socket.
[   17.302930] systemd[1]: Created slice User and Session Slice.
[   17.322395] systemd[1]: Reached target Slices.
[   17.342579] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.361680] systemd[1]: Reached target Swap.
[   17.381456] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.401186] systemd[1]: Listening on Journal Socket.
[   17.422361] systemd[1]: Mounting RPC Pipe File System...
[   17.442514] systemd[1]: Mounting POSIX Message Queue File System...
[   17.462741] systemd[1]: Mounting Huge Pages File System...
[   17.482771] systemd[1]: Starting Restore / save the current clock...
[   17.501437] systemd[1]: Starting Nameserver information manager...
[   17.521323] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.539225] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.558617] systemd[1]: Listening on Syslog Socket.
[   17.578457] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.603678] systemd[1]: Starting Load Kernel Modules...
[   17.619562] systemd[1]: Starting Set console keymap...
[   17.642281] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.657405] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.678808] systemd[1]: Mounting Debug File System...
[   17.696595] systemd[1]: Listening on udev Kernel Socket.
[   17.716036] systemd[1]: Reached target Encrypted Volumes.
[   17.735864] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.755397] systemd[1]: Reached target Paths.
[   17.776969] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.799556] systemd[1]: Mounted RPC Pipe File System.
[   17.803244] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.810400] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.810694] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.810848] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.810984] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.812109] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.814658] systemd[1]: Mounted Debug File System.
[   17.834349] systemd[1]: Mounted POSIX Message Queue File System.
[   17.854075] systemd[1]: Mounted Huge Pages File System.
[   17.861576] cfg80211: Calling CRDA to update world regulatory domain
[   17.877243] systemd[1]: Started Restore / save the current clock.
[   17.897182] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.923898] systemd[1]: Started Set console keymap.
[   17.944165] systemd[1]: Started Remount Root and Kernel File Systems.
[   17.964968] systemd[1]: Started Nameserver information manager.
[   17.986226] systemd[1]: Time has been changed
[   17.996303] RTL871X: module init start
[   17.996320] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   17.996325] RTL871X: build time: Feb  8 2019 10:22:36
[   17.996330] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   17.996348] sunxi-wlan wlan.26: bus_index: 1
[   17.996597] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.081158] systemd[1]: Reached target Network (Pre).
[   18.091161] systemd[1]: Starting udev Coldplug all Devices...
[   18.104980] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.105075] RTL871X: module init ret=0
[   18.105104] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.111831] systemd[1]: Starting Load/Save Random Seed...
[   18.119353] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.131566] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.139886] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.140726] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.140765] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.143217] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.145085] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.146345] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.147182] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.148023] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.148844] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.149773] systemd[1]: Started Load Kernel Modules.
[   18.150733] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.151573] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.152414] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.153263] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.153385] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.154304] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.154357] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.171568] systemd[1]: Started Load/Save Random Seed.
[   18.197147] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.256262] systemd[1]: Starting udev Kernel Device Manager...
[   18.276956] systemd[1]: Reached target Local File Systems (Pre).
[   18.299632] systemd[1]: Mounting /tmp...
[   18.318471] systemd[1]: Starting Apply Kernel Variables...
[   18.338158] systemd[1]: Mounting Configuration File System...
[   18.358406] systemd[1]: Mounting FUSE Control File System...
[   18.379413] systemd[1]: Mounted FUSE Control File System.
[   18.395314] systemd[1]: Mounted Configuration File System.
[   18.414869] systemd[1]: Mounted /tmp.
[   18.435089] systemd[1]: Started udev Kernel Device Manager.
[   18.455118] systemd[1]: Started udev Coldplug all Devices.
[   18.475187] systemd[1]: Started Apply Kernel Variables.
[   18.543758] systemd[1]: Reached target Sound Card.
[   18.552671] cfg80211: World regulatory domain updated:
[   18.552692] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.552699] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.552705] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.552710] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.552715] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.552721] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.552726] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.552731] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.552736] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.576657] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.589801] sunxi cedar version 0.1
[   18.590121] [cedar]: install start!!!
[   18.590316] ycy the get irq is 90
[   18.590909] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.590922] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.590929] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.590934] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.590941] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.590946] [cedar]: install end!!!
[   18.605315] systemd[1]: Starting Journal Service...
[   18.622450] systemd[1]: Reached target Local File Systems.
[   18.643582] systemd[1]: Starting Preprocess NFS configuration...
[   18.663454] systemd[1]: Starting Armbian ZRAM config...
[   18.673239] systemd[1]: Starting Set console font and keymap...
[   18.691202] Registered IR keymap rc_map_sunxi
[   18.691764] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.692039] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.729038] systemd[1]: Starting Raise network interfaces...
[   18.751680] systemd[1]: Started Preprocess NFS configuration.
[   18.773262] systemd[1]: Found device /dev/ttyS0.
[   18.787277] Driver for 1-wire Dallas network protocol.
[   18.799591] [VFE]cci probe end cci_sel = 0!
[   18.799775] [VFE]cci_init end
[   18.901893] IR RC5(x) protocol handler initialized
[   18.901895] IR NEC protocol handler initialized
[   18.903371] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.904694] IR MCE Keyboard/mouse protocol handler initialized
[   18.904865] IR Sony protocol handler initialized
[   18.905412] IR RC6 protocol handler initialized
[   18.906104] IR SANYO protocol handler initialized
[   18.907241] IR JVC protocol handler initialized
[   18.954784] lirc_dev: IR Remote Control driver registered, major 248
[   18.957410] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.957430] IR LIRC bridge handler initialized
[   19.022136] [VFE]Welcome to Video Front End driver
[   19.022589] [VFE]csi probe end csi_sel = 0!
[   19.023508] [VFE]csi_init end
[   19.027952] [VFE]isp probe start isp_sel = 0!
[   19.029188] [ISP] isp platform_id = 3!
[   19.029210] [VFE]isp probe end isp_sel = 0!
[   19.029399] [VFE]sunxi_isp_platform_register end
[   19.030777] [VFE]mipi probe start mipi_sel = 0!
[   19.030821] [VFE]mipi probe end mipi_sel = 0!
[   19.030928] [VFE]mipi_init end
[   19.030936] [VFE]flash_init end
[   19.031551] [VFE]vfe_init end
[   19.078126] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   19.103767] systemd[1]: Reached target NFS client services.
[   19.123393] systemd[1]: Reached target Remote File Systems (Pre).
[   19.144829] systemd[1]: Started Journal Service.
[   19.195927] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.204630] sunxi-bt bt.27: block state already is 1
[   19.206304] zram: Created 6 device(s) ...
[   19.324487] systemd-journald[327]: Received request to flush runtime journal from PID 1
[   19.346607] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.370789] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.411120] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.455892] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.773789] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.773811] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=pine64so
BOARD_NAME="SoPine A64"
BOARDFAMILY=sun50iw1
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
overlay_prefix=sun50i-a64
rootdev=UUID=33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
rootfstype=ext4
### lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
Architecture:          aarch64
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
CPU max MHz:           1344.0000
CPU min MHz:           408.0000
Hypervisor vendor:     horizontal
Virtualization type:   full
### cpuinfo:
Processor    : AArch64 Processor rev 4 (aarch64)
processor    : 0
processor    : 1
processor    : 2
processor    : 3
Features    : fp asimd aes pmull sha1 sha2 crc32
CPU implementer    : 0x41
CPU architecture: AArch64
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemTotal:        2035016 kB
MemFree:         1886532 kB
Buffers:            9688 kB
Cached:            58016 kB
SwapCached:            0 kB
Active:            29904 kB
Inactive:          53960 kB
Active(anon):      16748 kB
Inactive(anon):     2852 kB
Active(file):      13156 kB
Inactive(file):    51108 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1017504 kB
SwapFree:        1017504 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         16500 kB
Mapped:            14996 kB
Shmem:              3052 kB
Slab:              23844 kB
SReclaimable:      10332 kB
SUnreclaim:        13512 kB
KernelStack:        1856 kB
PageTables:          536 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2035012 kB
Committed_AS:     109988 kB
VmallocTotal:   251658176 kB
VmallocUsed:       19380 kB
VmallocChunk:   251633516 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.extra_free_kbytes = 0
vm.hugepages_treat_as_movable = 0
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256    32
vm.max_map_count = 65530
vm.min_free_kbytes = 5606
vm.min_free_order_shift = 1
vm.mmap_min_addr = 32768
vm.nr_hugepages = 0
vm.nr_overcommit_hugepages = 0
vm.nr_pdflush_threads = 0
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.scan_unevictable_pages = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.vfs_cache_pressure = 100
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 86:57:fe:23:25:3f brd ff:ff:ff:ff:ff:ff
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
### partitions:
major minor  #blocks  name
 179        0   15558144 mmcblk0
 179        1   15398464 mmcblk0p1
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
udev            960M     0  960M   0% /dev
tmpfs           199M  3.0M  196M   2% /run
tmpfs           994M     0  994M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           994M     0  994M   0% /sys/fs/cgroup
tmpfs           994M  4.0K  994M   1% /tmp
/dev/zram0       49M  6.4M   39M  15% /var/log
### lsblk:
NAME        FSTYPE   SIZE MOUNTPOINT UUID
zram0                 50M /var/log
mmcblk0             14.9G
└─mmcblk0p1 ext4    14.7G /          33f1fc4b-7b71-4a22-b2aa-239ce54f27f4
### zramctl:
NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0                50M   6M  2.1M  2.9M         /var/log
/dev/zram1             248.4M   4K   78B    4K         [SWAP]
/dev/zram2             248.4M   4K   78B    4K         [SWAP]
/dev/zram3             248.4M   4K   78B    4K         [SWAP]
/dev/zram4             248.4M   4K   78B    4K         [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,discard 0 0
### mmc0:aaaa info:
                 cid: 03534453533136478069a31e7f01261d
                 csd: 400e00325b59000076b27f800a404013
                 scr: 0235800300000000
                date: 06/2018
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SS16G MODALIAS=mmc:block
          erase_size: 512
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU   PMIC  C.St.
09:36:37: 1008MHz  0.00  36%  11%  16%   0%   9%   0%   29°C   20°C  0/7
09:36:37: 1008MHz  0.00  50%  13%  10%   0%  25%   0%   28°C   20°C  0/7
09:36:38: 1152MHz  0.00  50%  11%   6%   2%  28%   0%   28°C   20°C  0/7
09:36:38: 1152MHz  0.00  33%   4%   3%   2%  24%   0%   28°C   20°C  0/7
09:36:38: 1152MHz  0.08  28%   6%   4%   0%  16%   0%   28°C   20°C  0/7
Fri Mar  8 10:58:48 UTC 2019 | SoPine A64 | 5.73 | arm64 | aarch64 | 3.10.107-pine64
### dmesg:
[   10.067081] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[   10.067090] pid_max: default: 32768 minimum: 301
[   10.067184] Security Framework initialized
[   10.067232] AppArmor: AppArmor initialized
[   10.067266] Mount-cache hash table entries: 256
[   10.077623] Initializing cgroup subsys memory
[   10.077670] Initializing cgroup subsys devices
[   10.077677] Initializing cgroup subsys freezer
[   10.077683] Initializing cgroup subsys blkio
[   10.077689] Initializing cgroup subsys perf_event
[   10.077699] Initializing cgroup subsys hugetlb
[   10.077762] ftrace: allocating 28898 entries in 113 pages
[   10.111516] CPU0: update cpu_power 1968128
[   10.111538] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[   10.112540] virtual base = 0xffffff800000a000.
[   10.112554] gicd_base = 0xffffff800000c000.
[   10.112558] gicc_base = 0xffffff800000e000.
[   10.113185] CPU1: Booted secondary processor
[   10.113211] CPU1: update cpu_power 1968128
[   10.115810] CPU2: Booted secondary processor
[   10.115821] CPU2: update cpu_power 1968128
[   10.119929] CPU3: Booted secondary processor
[   10.119939] CPU3: update cpu_power 1968128
[   10.120013] Brought up 4 CPUs
[   10.120035] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[   10.120539] devtmpfs: initialized
[   10.125497] pinctrl core: initialized pinctrl subsystem
[   10.127981] NET: Registered protocol family 16
[   10.128241] script_sysfs_init success
[   10.128477] dump_class_init,806, success
[   10.128719] vdso: 2 pages (1 code, 1 data) at base ffffffc000be9000
[   10.128739] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   10.130021] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[   10.131069] DMA: preallocated 256 KiB pool for atomic allocations
[   10.131185] Serial: AMBA PL011 UART driver
[   10.131289] axp81x_board_init: axp regl_devs num = 23
[   10.131431] pll_audio-set_default_rate=24576000 success!
[   10.131451] pll_video0-set_default_rate=297000000 success!
[   10.131523] pll_video1-set_default_rate=297000000 success!
[   10.131583] pll_de-set_default_rate=297000000 success!
[   10.132302] de-set_default_source=pll_de success!
[   10.132308] de-set_default_rate=297000000 success!
[   10.132350] tcon0-set_default_source=pll_mipi success!
[   10.132381] tcon1-set_default_source=pll_video0 success!
[   10.132594] hdmi-set_default_source=pll_video0 success!
[   10.134835] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[   10.134993] [sun50iw1p1_pinctrl_probe][838]
[   10.136438] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[   10.137058] sunxi hwspinlock vbase:0xffffff800005c000
[   10.147314] bio: create slab <bio-0> at 0
[   10.147663] pwm module init!
[   10.148877] SCSI subsystem initialized
[   10.149001] usbcore: registered new interface driver usbfs
[   10.149035] usbcore: registered new interface driver hub
[   10.149096] usbcore: registered new device driver usb
[   10.149793] Linux video capture interface: v2.00
[   10.150230] [ARISC] :sunxi-arisc driver v1.10
[   10.157164] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[   10.157411] Advanced Linux Sound Architecture Driver Initialized.
[   10.157761] NetLabel: Initializing
[   10.157766] NetLabel:  domain hash size = 128
[   10.157770] NetLabel:  protocols = UNLABELED CIPSOv4
[   10.157808] NetLabel:  unlabeled traffic allowed by default
[   10.157972] [pm]aw_pm_init!
[   10.158038] rtc physical base = 0x0000000001f00000 .
[   10.158070] np name = /soc@01c00000/rtc@01f00000.
[   10.158076] base = ffffff800006e100, len = 4.
[   10.158082] pmu name: pmu0 .
[   10.158114] pmu0_enable = 0x1.
[   10.158120] pmux_id = 0x6.
[   10.158126] pmux_twi_id = 0x1.
[   10.158131] pmux_twi_addr = 0x34.
[   10.158135] pmu name: pmu1 .
[   10.158184] Warning: can not find np for pmu1.
[   10.158415] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[   10.158576] after inited: sys_mask config = 0x4a55.
[   10.158597] Warning: can not find np for dynamic_standby_para.
[   10.158727] [pm]valid
[   10.158731] [pm]valid
[   10.158735] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                 change to super standby.
[   10.158938] Switching to clocksource arch_sys_counter_ool
[   10.176962] AppArmor: AppArmor Filesystem Enabled
[   10.183558] NET: Registered protocol family 2
[   10.184248] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[   10.184490] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[   10.184798] TCP: Hash tables configured (established 16384 bind 16384)
[   10.184883] TCP: reno registered
[   10.184893] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[   10.184944] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[   10.185198] NET: Registered protocol family 1
[   10.185522] RPC: Registered named UNIX socket transport module.
[   10.185528] RPC: Registered udp transport module.
[   10.185532] RPC: Registered tcp transport module.
[   10.185537] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.185712] Trying to unpack rootfs image as initramfs...
[   10.390048] Freeing initrd memory: 4296K (ffffffc075a83000 - ffffffc075eb5000)
[   10.390634] kvm [1]: Using HYP init bounce page @b7889000
[   10.391152] kvm [1]: interrupt-controller@1c84000 IRQ25
[   10.391571] kvm [1]: timer IRQ27
[   10.391586] kvm [1]: Hyp mode initialized successfully
[   10.393292] lock super standby defaultly!
[   10.393309] lookup_scene_lock_name: new scene lock super_standby
[   10.393314] scene_lock_init name=super_standby
[   10.393320] scene_lock: super_standby, type 5, count 1
[   10.393729] audit: initializing netlink socket (disabled)
[   10.393788] type=2000 audit(0.310:1): initialized
[   10.394472] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[   10.394933] VFS: Disk quotas dquot_6.5.2
[   10.395034] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.396007] NFS: Registering the id_resolver key type
[   10.396055] Key type id_resolver registered
[   10.396060] Key type id_legacy registered
[   10.396072] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.396210] NTFS driver 2.1.30 [Flags: R/W].
[   10.396387] fuse init (API version 7.22)
[   10.396561] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   10.396983] msgmni has been set to 3973
[   10.397941] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[   10.398021] io scheduler noop registered
[   10.398027] io scheduler deadline registered
[   10.398052] io scheduler cfq registered (default)
[   10.398639] [DISP]disp_module_init
[   10.399094] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.399102] [DISP] boot_disp:0x0
[   10.399696] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.399827] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.399959] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[   10.401070] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[   10.401075] [DISP] fb_base:0x0
[   10.418797] Console: switching to colour frame buffer device 160x45
[   10.433252] [DISP]disp_module_init finish
[   10.433671] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[   10.433695] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[   10.434053] console [ttyS0] enabled
[   10.434426] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[   10.434860] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[   10.435172] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[   10.435455] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[   10.435810] misc dump reg init
[   10.435966] [drm] Initialized drm 1.1.0 20060810
[   10.438115] brd: module loaded
[   10.440230] loop: module loaded
[   10.440509] sunxi-bt bt.27: Missing bt_power.
[   10.440516] sunxi-bt bt.27: bt_power_name ((null))
[   10.440524] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[   10.440557] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.440601] sunxi-bt bt.27: clk not config
[   10.440674] sunxi-bt bt.27: block state already is 1
[   10.440860] sunxi-wlan wlan.26: wlan_busnum (1)
[   10.440867] sunxi-wlan wlan.26: Missing wlan_power.
[   10.440874] sunxi-wlan wlan.26: wlan_power_name ((null))
[   10.440881] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[   10.440898] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[   10.440916] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[   10.440933] sunxi-wlan wlan.26: clk not config
[   10.441638] WARNING: Get ephy clock is failed
[   10.442271] chipid-sunxi serial 140050374620201507cf
[   10.442363] PPP generic driver version 2.4.2
[   10.442516] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.442623] get ehci0-controller drv_vbus_gpio is fail
[   10.442629] get ehci0-controller, regulator_io is no nocare
[   10.442669] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   10.442723] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.442742] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   10.443101] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00060960c
[   10.454199] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   10.454268] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.454275] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.454282] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454289] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.454295] usb usb1: SerialNumber: sunxi-ehci
[   10.454651] hub 1-0:1.0: USB hub found
[   10.454667] hub 1-0:1.0: 1 port detected
[   10.454802] scene_lock_init name=ehci_standby
[   10.454875] get ehci1-controller drv_vbus_gpio is fail
[   10.454880] get ehci1-controller, regulator_io is no nocare
[   10.454921] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000dd9e90, 0x:ffffff80000b2000, irq_no:6a
[   10.454969] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.454988] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[   10.455229] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00060960c
[   10.473882] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.473925] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.473933] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.473940] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.473946] usb usb2: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   10.473953] usb usb2: SerialNumber: sunxi-ehci
[   10.474228] hub 2-0:1.0: USB hub found
[   10.474241] hub 2-0:1.0: 1 port detected
[   10.474362] scene_lock_init name=ehci_standby
[   10.474549] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.474692] get ohci0-controller drv_vbus_gpio is fail
[   10.474698] get ohci0-controller, regulator_io is no nocare
[   10.474738] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   10.474785] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.474801] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   10.474831] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[   10.536891] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.536899] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.536906] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.536912] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.536919] usb usb3: SerialNumber: sunxi-ohci
[   10.537188] hub 3-0:1.0: USB hub found
[   10.537202] hub 3-0:1.0: 1 port detected
[   10.537317] scene_lock_init name=ohci_standby
[   10.537376] get ohci1-controller drv_vbus_gpio is fail
[   10.537382] get ohci1-controller, regulator_io is no nocare
[   10.537414] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000dd99f0
[   10.537453] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.537470] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[   10.537496] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[   10.595921] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.595929] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.595936] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.595943] usb usb4: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   10.595949] usb usb4: SerialNumber: sunxi-ohci
[   10.596209] hub 4-0:1.0: USB hub found
[   10.596222] hub 4-0:1.0: 1 port detected
[   10.596338] scene_lock_init name=ohci_standby
[   10.596633] usbcore: registered new interface driver usb-storage
[   10.596663] usbcore: registered new interface driver ums-alauda
[   10.596691] usbcore: registered new interface driver ums-cypress
[   10.596716] usbcore: registered new interface driver ums-datafab
[   10.596739] usbcore: registered new interface driver ums_eneub6250
[   10.596763] usbcore: registered new interface driver ums-freecom
[   10.596787] usbcore: registered new interface driver ums-isd200
[   10.596811] usbcore: registered new interface driver ums-jumpshot
[   10.596834] usbcore: registered new interface driver ums-karma
[   10.596858] usbcore: registered new interface driver ums-onetouch
[   10.596893] usbcore: registered new interface driver ums-realtek
[   10.596918] usbcore: registered new interface driver ums-sddr09
[   10.596943] usbcore: registered new interface driver ums-sddr55
[   10.596967] usbcore: registered new interface driver ums-usbat
[   10.597053] usbcore: registered new interface driver usbserial
[   10.597079] usbcore: registered new interface driver usbserial_generic
[   10.597103] usbserial: USB Serial support registered for generic
[   10.597312] mousedev: PS/2 mouse device common for all mice
[   10.597748] input: sunxi-keyboard as /devices/virtual/input/input0
[   10.598683] get ctp_para failed, -1
[   10.598703] get node gsensor failed
[   10.598707] get sysconfig para erro!
[   10.598717] get node lightsensor failed
[   10.598720] get sysconfig para erro!
[   10.598730] get node gyroscopesensor failed
[   10.598733] get sysconfig para erro!
[   10.598742] get node compasssensor failed
[   10.598745] get sysconfig para erro!
[   10.599027] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.599049] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.599219] i2c /dev entries driver
[   10.641727] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[   10.645188] sunxi budget cooling probe start !
[   10.645219] CPU freq cooling register Success
[   10.645238] CPU hotplug cooling register Success
[   10.645326] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[   10.645334] CPU budget cooling register Success
[   10.645546] sunxi gpu cooling probe start !
[   10.645555] CPU gpu cooling register Success
[   10.646211] cpuidle: using governor ladder
[   10.646218] cpuidle: using governor menu
[   10.646962] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.646991] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.646999] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.647008] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.647059] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.647066] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.647665] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.647687] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.598771] wakeup gpio set err!get node ctp failed
[   10.651059] get sysconfig para erro!
[   10.660831] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.680520] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000c6000 irq:92
[   10.680901] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Feb  8 2019 at 10:22:15
[   10.680927] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   10.680934] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   10.680941] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   10.680946] get() with no identifier
[   10.680949] get() with no identifier
[   10.680953] get() with no identifier
[   10.680958] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.680964] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.680970] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.681341] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.681370] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.681390] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.682162] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.682181] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.684563] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.686706] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.687520] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.688332] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.689143] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.689767] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.689811] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.692185] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.700189] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.719876] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000ce000 irq:93
[   10.720574] ledtrig-cpu: registered to indicate activity on CPUs
[   10.720644] hidraw: raw HID events driver (C) Jiri Kosina
[   10.720783] usbcore: registered new interface driver usbhid
[   10.720787] usbhid: USB HID core driver
[   10.721654] usbcore: registered new interface driver snd-usb-audio
[   10.723643] sndhdmi sound.8:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.724432] TCP: cubic registered
[   10.724442] Initializing XFRM netlink socket
[   10.724523] NET: Registered protocol family 10
[   10.725343] mip6: Mobile IPv6
[   10.725351] sit: IPv6 over IPv4 tunneling driver
[   10.725732] NET: Registered protocol family 17
[   10.725753] NET: Registered protocol family 15
[   10.725801] 8021q: 802.1Q VLAN Support v1.8
[   10.725846] Key type dns_resolver registered
[   10.726052] Registering SWP/SWPB emulation handler
[   10.726343] registered taskstats version 1
[   10.738317] Key type encrypted registered
[   10.738341] AppArmor: AppArmor sha1 policy hashing enabled
[   10.738785] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[   10.738793] [DISP] boot_disp:0x0
[   10.738838] HDMI base address: ffffff8000b40000
[   10.739605] [HDMI] power vcc-hdmi-33
[   10.740131] [HDMI] cec support = 0
[   10.759187] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.761684] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.761758] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.761864] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.761890] mmc0: new high speed SDHC card at address aaaa
[   10.762288] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[   10.764320]  mmcblk0: p1
[   10.765435] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.766243] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.766262] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.768656] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.770476] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.771284] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772091] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.772896] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.773700] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.774507] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.775314] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776121] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776928] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.776944] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.777778] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.777795] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.850588] input: sunxi-ths as /devices/virtual/input/input2
[   10.850753] thermal thermal_zone0: failed to read out thermal zone 0
[   10.851169] ALSA device list:
[   10.851175]   #0: sndhdmi
[   10.851609] Freeing unused kernel memory: 540K (ffffffc000b59000 - ffffffc000be0000)
[   11.448051] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[   14.134355] [ehci0-controller]: sunxi_usb_disable_ehci
[   14.134370] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40
[   14.134390] scene_lock_destroy name=ehci_standby
[   14.134404] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   14.134425] usb usb1: USB disconnect, device number 1
[   14.134985] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   14.135017] [ohci0-controller]: sunxi_usb_disable_ohci
[   14.135025] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.135030] scene_lock_destroy name=ohci_standby
[   14.135037] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   14.135054] usb usb3: USB disconnect, device number 1
[   14.135425] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   14.135461] [ehci0-controller]: sunxi_usb_enable_ehci
[   14.135469] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000dd9c40, 0x:ffffff80000aa000, irq_no:68
[   14.135516] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.135541] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   14.138896] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0000b8660
[   14.154048] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   14.154146] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   14.154154] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.154161] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   14.154168] usb usb1: Manufacturer: Linux 3.10.107-pine64 ehci_hcd
[   14.154174] usb usb1: SerialNumber: sunxi-ehci
[   14.154668] hub 1-0:1.0: USB hub found
[   14.154687] hub 1-0:1.0: 1 port detected
[   14.154840] scene_lock_init name=ehci_standby
[   14.154849] [ohci0-controller]: sunxi_usb_enable_ohci
[   14.154857] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000dd97a0
[   14.154908] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.154927] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   14.154970] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0000b8660
[   14.217088] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   14.217105] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.217112] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   14.217119] usb usb3: Manufacturer: Linux 3.10.107-pine64 ohci_hcd
[   14.217125] usb usb3: SerialNumber: sunxi-ohci
[   14.217586] hub 3-0:1.0: USB hub found
[   14.217604] hub 3-0:1.0: 1 port detected
[   14.217782] scene_lock_init name=ohci_standby
[   16.439622] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   16.824024] systemd[1]: System time before build time, advancing clock.
[   16.861199] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   16.861523] systemd[1]: Detected architecture arm64.
[   16.892298] systemd[1]: Set hostname to <cluster0>.
[   17.281841] systemd[1]: Listening on Journal Socket.
[   17.302990] systemd[1]: Reached target Swap.
[   17.323194] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   17.342430] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   17.362035] systemd[1]: Listening on fsck to fsckd communication Socket.
[   17.381999] systemd[1]: Created slice User and Session Slice.
[   17.401432] systemd[1]: Listening on Journal Socket (/dev/log).
[   17.421335] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   17.440674] systemd[1]: Reached target Paths.
[   17.460421] systemd[1]: Listening on Syslog Socket.
[   17.480018] systemd[1]: Reached target Encrypted Volumes.
[   17.499762] systemd[1]: Listening on udev Kernel Socket.
[   17.519590] systemd[1]: Listening on udev Control Socket.
[   17.539169] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   17.559068] systemd[1]: Created slice System Slice.
[   17.578459] systemd[1]: Reached target Slices.
[   17.599861] systemd[1]: Mounting POSIX Message Queue File System...
[   17.619842] systemd[1]: Starting Nameserver information manager...
[   17.644803] systemd[1]: Starting Load Kernel Modules...
[   17.668935] systemd[1]: Mounting RPC Pipe File System...
[   17.687424] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   17.708636] systemd[1]: Mounting Huge Pages File System...
[   17.728786] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   17.765928] systemd[1]: Starting Restore / save the current clock...
[   17.787438] systemd[1]: Mounting Debug File System...
[   17.807122] systemd[1]: Starting Set console keymap...
[   17.826586] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.849735] systemd[1]: Mounted RPC Pipe File System.
[   17.861159] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   17.873914] systemd[1]: Mounted Debug File System.
[   17.876000] sunxi-codec-machine sound.7:  codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[   17.876303] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.876483] sunxi-codec-machine sound.7:  codec-aif2 <-> bb-dai mapping ok
[   17.876663] sunxi-codec-machine sound.7:  codec-aif3 <-> bb-dai mapping ok
[   17.877862] input: audiocodec sunxi Audio Jack as /devices/soc.1/sound.7/sound/card1/input3
[   17.893557] systemd[1]: Mounted POSIX Message Queue File System.
[   17.913374] systemd[1]: Mounted Huge Pages File System.
[   17.929505] cfg80211: Calling CRDA to update world regulatory domain
[   17.938998] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   17.963865] systemd[1]: Started Restore / save the current clock.
[   17.983500] systemd[1]: Started Set console keymap.
[   18.002876] systemd[1]: Started Remount Root and Kernel File Systems.
[   18.024287] systemd[1]: Started Nameserver information manager.
[   18.049808] systemd[1]: Time has been changed
[   18.050305] RTL871X: module init start
[   18.050312] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   18.050317] RTL871X: build time: Feb  8 2019 10:22:36
[   18.050322] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   18.050340] sunxi-wlan wlan.26: bus_index: 1
[   18.050536] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   18.142332] systemd[1]: Reached target Network (Pre).
[   18.159014] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.159126] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   18.159266] RTL871X: module init ret=0
[   18.162983] systemd[1]: Starting Load/Save Random Seed...
[   18.178689] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.182785] systemd[1]: Starting udev Coldplug all Devices...
[   18.199139] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.199968] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   18.199995] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.200735] systemd[1]: Starting Create Static Device Nodes in /dev...
[   18.202462] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.204324] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   18.205140] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.205969] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.206785] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.207610] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   18.208456] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.209290] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.210126] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.210950] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   18.210978] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   18.211864] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   18.211890] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   18.218826] systemd[1]: Started Load Kernel Modules.
[   18.239463] systemd[1]: Started Load/Save Random Seed.
[   18.258899] systemd[1]: Started Create Static Device Nodes in /dev.
[   18.323557] systemd[1]: Starting udev Kernel Device Manager...
[   18.346150] systemd[1]: Reached target Local File Systems (Pre).
[   18.369087] systemd[1]: Mounting /tmp...
[   18.387925] systemd[1]: Mounting FUSE Control File System...
[   18.407392] systemd[1]: Mounting Configuration File System...
[   18.427388] systemd[1]: Starting Apply Kernel Variables...
[   18.447023] systemd[1]: Mounted FUSE Control File System.
[   18.464446] systemd[1]: Mounted Configuration File System.
[   18.484026] systemd[1]: Mounted /tmp.
[   18.504149] systemd[1]: Started udev Kernel Device Manager.
[   18.524381] systemd[1]: Started udev Coldplug all Devices.
[   18.573491] systemd[1]: Started Apply Kernel Variables.
[   18.609256] cfg80211: World regulatory domain updated:
[   18.609276] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   18.609282] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   18.609287] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.609292] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   18.609298] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.609303] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.609308] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   18.609313] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   18.609319] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   18.632004] systemd[1]: Reached target Sound Card.
[   18.659744] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[   18.669705] sunxi cedar version 0.1
[   18.669990] [cedar]: install start!!!
[   18.670202] ycy the get irq is 90
[   18.670778] ycy clk_bass_vir 0x18  is ffffff8000b3a018, the value:3006207
[   18.670791] ycy clk_bass_vir 0x13c  is ffffff8000b3a13c, the value:0
[   18.670797] ycy clk_bass_vir 0x64  is ffffff8000b3a064, the value:601810
[   18.670801] ycy clk_bass_vir 0x2c4  is ffffff8000b3a2c4, the value:601c10
[   18.670806] ycy clk_bass_vir 0x100  is ffffff8000b3a100, the value:0
[   18.670810] [cedar]: install end!!!
[   18.683888] systemd[1]: Starting Journal Service...
[   18.700480] systemd[1]: Reached target Local File Systems.
[   18.752492] systemd[1]: Starting Set console font and keymap...
[   18.755030] Registered IR keymap rc_map_sunxi
[   18.755573] input: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0/input4
[   18.755806] rc0: sunxi_ir_recv as /devices/soc.1/1f02000.s_cir/rc/rc0
[   18.772491] systemd[1]: Starting Preprocess NFS configuration...
[   18.772965] [VFE]cci probe end cci_sel = 0!
[   18.773249] [VFE]cci_init end
[   18.774112] IR RC5(x) protocol handler initialized
[   18.774500] IR Sony protocol handler initialized
[   18.800164] Driver for 1-wire Dallas network protocol.
[   18.838862] systemd[1]: Starting Raise network interfaces...
[   18.865638] systemd[1]: Starting Armbian ZRAM config...
[   18.877573] IR RC6 protocol handler initialized
[   18.878125] IR NEC protocol handler initialized
[   18.879674] IR SANYO protocol handler initialized
[   18.881443] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[   18.881787] IR MCE Keyboard/mouse protocol handler initialized
[   18.884892] IR JVC protocol handler initialized
[   18.886448] [VFE]Welcome to Video Front End driver
[   18.886878] [VFE]csi probe end csi_sel = 0!
[   18.887371] [VFE]csi_init end
[   18.887927] [VFE]isp probe start isp_sel = 0!
[   18.895869] lirc_dev: IR Remote Control driver registered, major 248
[   18.898482] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[   18.898489] IR LIRC bridge handler initialized
[   18.899319] [ISP] isp platform_id = 3!
[   18.899332] [VFE]isp probe end isp_sel = 0!
[   18.899428] [VFE]sunxi_isp_platform_register end
[   18.899968] [VFE]mipi probe start mipi_sel = 0!
[   18.900000] [VFE]mipi probe end mipi_sel = 0!
[   18.900045] [VFE]mipi_init end
[   18.900048] [VFE]flash_init end
[   18.900438] [VFE]vfe_init end
[   18.922052] systemd[1]: Started Preprocess NFS configuration.
[   19.010258] systemd[1]: Found device /dev/ttyS0.
[   19.092624] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   19.100583] systemd[1]: Reached target NFS client services.
[   19.123634] systemd[1]: Reached target Remote File Systems (Pre).
[   19.143984] systemd[1]: Started Journal Service.
[   19.190782] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   19.201786] sunxi-bt bt.27: block state already is 1
[   19.214244] zram: Created 6 device(s) ...
[   19.279189] systemd-journald[316]: Received request to flush runtime journal from PID 1
[   19.351821] Adding 254376k swap on /dev/zram1.  Priority:5 extents:1 across:254376k SS
[   19.382669] Adding 254376k swap on /dev/zram2.  Priority:5 extents:1 across:254376k SS
[   19.406694] Adding 254376k swap on /dev/zram3.  Priority:5 extents:1 across:254376k SS
[   19.432342] Adding 254376k swap on /dev/zram4.  Priority:5 extents:1 across:254376k SS
[   19.648975] EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
[   19.648991] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
BOARD=pine64so
VERSION=5.73
LINUXFAMILY=pine64
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
verbosity=1
console=both
disp_mode=720p60
camera_type=none
pine64_lcd=off
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             4
### cpuinfo:
processor    : 0
processor    : 1
processor    : 2
processor    : 3
CPU variant    : 0x0
CPU part    : 0xd03
CPU revision    : 4
Hardware    : SOPine
### meminfo:
MemFree:         1886644 kB
Buffers:            9584 kB
Cached:            57920 kB
SwapCached:            0 kB
Active:            30320 kB
Inactive:          53728 kB
Active(anon):      17132 kB
Active(file):      13188 kB
Inactive(file):    50876 kB
Unevictable:           0 kB
Mlocked:               0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         16800 kB
Mapped:            14468 kB
Shmem:              3052 kB
Slab:              23632 kB
SReclaimable:      10284 kB
SUnreclaim:        13348 kB
KernelStack:        1904 kB
PageTables:          596 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:     110276 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
### virtual memory:
vm.block_dump = 0
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.drop_caches = 0
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 62493
### ip addr:
### partitions:
 253        0      51200 zram0
 253        1     254380 zram1
 253        2     254380 zram2
 253        3     254380 zram3
 253        4     254380 zram4
### df:
/dev/mmcblk0p1   15G  963M   14G   7% /
/dev/zram0       49M  6.6M   39M  15% /var/log
### lsblk:
zram0                 50M /var/log
mmcblk0             14.9G
### zramctl:
/dev/zram0                50M  6.3M  2.2M  3.1M         /var/log
### mtab:
### mmc0:aaaa info:
                date: 06/2018
                type: SD
               fwrev: 0x0
               hwrev: 0x8
               oemid: 0x5344
              manfid: 0x000003
              serial: 0x69a31e7f
          erase_size: 512
10:58:52: 1008MHz  0.16  35%  11%  15%   0%   8%   0%   29°C   21°C  0/7
10:58:52: 1008MHz  0.16  54%  17%  10%   0%  26%   0%   28°C   21°C  0/7
10:58:52: 1152MHz  0.16  49%  10%   8%   1%  29%   0%   29°C   21°C  0/7
10:58:53: 1152MHz  0.16  28%   4%   0%   2%  21%   0%   29°C   21°C  0/7
10:58:53: 1152MHz  0.23  29%   2%  18%   2%   6%   0%   28°C   21°C  0/7
Edited by lanefu
putting log data in spoiler
18 minutes ago, AZClusterboard said:
I have a Clusterboard and the latest images (Stretch and Bionic) do not work with my SOPINE modules.  Legacy 3.10 (Xenial) works.  I've been told this is a problem that has been resolved before but somehow the fix has been left out of the latest images.  What is the process for getting it back in?
Can you share logs and describe what troubleshooting you've done.
armbianmonitor didn't generate a URL so I did a manual paste to the post.  I do not have the hardware to UART in or plug it in to a LTS baseboard.  I only have the clusterboard.  I tried all 3 images and 3.10 is the only one that pulled DHCP.
5 minutes ago, AZClusterboard said:
armbianmonitor didn't generate a URL so I did a manual paste to the post.  I do not have the hardware to UART in or plug it in to a LTS baseboard.  I onlu have the clusterboard and I tried the images.  3.10 is the only one that pulled DHCP.
Uhh yeah i see you were ... quite generous with your logs.  anyway I edited your post to encapsulate your logs in a "spoiler" to keep the forum clean.
What version _were_ you running?
archives here https://dl.armbian.com/pine64so/archive/ if you want to rollback
That log is from 3.10.  It's the only one I can SSH into to get it.
So the most helpful info would be to get logs for the TTL serial console of one of the fail boards.. looks like the cluster board has some IO pins for each.. I'd assume there's the TTL console port there.... Do you have a TTL serial cable you could use... or you can even use another SBC to connect if you really needed to.
No.  I ordered something to do that but it still hasn't come.  It's supposed to come in this week but I've never used one.  Even when it gets here it will take time for me to learn how to use it.  Not to mention I installed heatsinks on the chips that might prevent me from getting at the pins.  It's the same board, just a different OS image.
Here is a link to a conversation we were having about it in the other forum:
https://forum.pine64.org/showthread.php?tid=7263
Clusterboard is different hardware - not among supported list. The problem is probably related to timing due to different PCB lines length.
It's a SOPINE compute module.  The compute module is supported.  Why wouldn't the board be supported?  If it's not supported, why does 3.10 work and what's the problem with getting that solution in to the latest distribution?
Because our resources are limited? Because dealing with you and boards is very expensive and nobody is covering not a fraction of those costs?
I don't understand.  How is dealing with me expensive?  Isn't it just a matter of making some config changes?  Isn't this an open source project?  I get the feeling you have some misconceptions about what's going on.
Yes ! That means your code contributions are welcome !
What Igor mean by "resources are limited" which can't focus on everything at the same time, there are priorities ...
True.  Fork, invest your time and fix. If you are unable to solve the problem, hire someone. Stop asking us to work for you - we don't.
Armbian is licenced under GPL:
BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
For better overview on OSS, perhaps read Producing Open Source Software or/and Social Architecture: Building On-line Communities. Our "as is" support is forum, documentation and holding this together already requires enormous efforts. From many people.
It's not just you having problems and it is not just you having a desire asking things. Answering questions requires time and attention. Dealing with issue require more time and attention. If this could be possible to do in a reasonable time / day, no problem, but since "you" are asking for questions and solutions all the time and they would require wasting hours and hours for you is simply not possible. Remember, "you" pay nothing and answering costs time(money). We can't afford to support you in such numbers. Even you are willing to pay for the time.
I am investing my time.  I'm just not familiar with everything that is going in with the armbian software
It takes time for me to try and collaborate with you to try to get to the root of the problem.  I don't think my time is any less valuable than yours.
I'm not asking for that much.  Just some help in trying to find the update that makes a piece of supported hardware not work.  Not just for me but for everyone trying to use armbian.
I managed to get the terminal working this morning.  This is the output (starting from the last dmesg) of "cat /var/log/armbian-hardware-monitor.log
armbian-hardware-monitor.txt
It's about knowing hardware, which we didn't build, don't have and don't support. It only saves some time if you use Armbian tools.
Is it? You will use 500, 1000 or more units of time and perhaps only learn something. We might be able to fix this in 1
http://jeffacubed.com/the-boilermaker-story-or-knowing-where-to-tap/
Once again. Our resources are limited and "your" contribution to the budget doesn't allow to expand this, to hire help. We can't deal with every pcs of electronics that industry plunges out. Hardware (where "you" are willing to waste your money on) design is much cheaper than software support. Crazy world, but that's it ;)
Keep researching. The thrill of solved problem is the nicest reward. Better than lousy sex :)
So then why do you say you support SOPINE if you don't want to support SPOINE?
Because you can do it in less time means it makes more sense that I should be able to get some help rather than me wasting my time trying to do it on my own blind.  There is no point in wasting that much time.  That's the point of community support.  I might not know a lot about this hardware or this software but clearly it's the best you have at the moment.  Judging by your reaction to me, I can see why more people aren't even trying to come forward.
As for your analogy, it does not apply.  Money should not be a factor unless you're trying to run some kind of extortion scheme.
I have never found satisfaction in finding a solution to a problem.  I find satisfaction in doing work instead of trying to find out why the machine doesn't work.  The troubleshooting I do is all in service of that goal as opposed to being the goal itself.
If device is supported, you report a problem and wait. If it is not supported, your pleads are moved to community section that community (support) picked them up or not. If your board is supported (that we have hardware, choose to help you and already invested some of our time and money into them), issues is recognized and prioritized. If there is an urgent issues we try the best but it still can easily takes days to weeks, while for non-urgent matters it takes months to years. People that move things forward and know something vs. random users is probably somewhere between 5.000  - 10.000 vs. 1. Now do the math.
For that past few years I was working 8-16h/day on the project. Now, I have some personal issues and I can't afford to work more than few hours per day which means only basic maintaining & administration. This means waiting time for small issues - if you want that they go on my 2do list - temporally jumped from 1-2 to 5-8 years. I know this sounds ridiculous but when you consider there are a lot of people like you (and issues) out there and since we have very complicated situation on the other side this is quite normal. Just a few people, who have the interest to play with those board in their free time, can't cover a job of 100 people.  Or more.
How is money here incorporated? All major open-source project needs money to operate and many of them have full-time people. We would definitely need them, but since you are not willing to pay anything more than for a beer, we will run on amateur force. This means - you found a problem that needs to be fixed? Well, you need to wait two years. With one full timer, we could perhaps get down to a year an half, with 3 down to a year ...
This is the same problem as this thread.
@AZClusterboard Did you try the fix of siffland yourself?
https://www.pine64.org/?product=clusterboard-with-7-sopine-compute-module-slots
NOTE: Clusterboard is a development board that requires experience with operating headless Linux systems
Maybe it's not the right tool for the job for you? Pine makes a lot of hardware, but doesn't support it. So people buying it are supposed to know how to make these things work. Or at least find pleasure in searching for fixes.
If you want a device that works out of the box, with software support. Then you've bought the wrong device from the wrong company.
Maybe try this.
@siffland
I use my cluserboard as a docker swarm, works pretty nice.  See my post above about the solution i found with the custom u-boot version.  I just burn armbian to a micro sdcard and then dd the custom u-boot to the card and everything works fine.
The second link from the jan willies github explains how to do this and doing a diff from his github shows the changes he has to make to u-boot.  I dont know if this can be submitted upstream to u-boot, i wish i knew a lot more about u-boot.
So this is a u-boot problem.
Following this post on the pine pages with the same issue:
https://forum.pine64.org/archive/index.php?thread-5581-3.html
and using this u-boot (referenced from the above link) fixed the issue for me.
https://github.com/janwillies/u-boot/releases/tag/v2019.01-cb-1
So which method is the best fix for this.  I would think your driver method is, but this u-boot modification also worked.
Thanks,
Sean
It is a work around. But once you've got them running, you can go further.
It does seem nice hardware, but since not many people are using it, you're not going to have a lot of help. But best is to join those who are working with it.
@lanefu
Can this u-boot be easily merged into the sopine build? (I don't know, just trying to help...)
Take care of yourself. Most could not handle the stress of such a huge project. Try not to worry too much about Armbian, there's others who do. Best of luck.
40 minutes ago, NicoD said:
lanefu
Looks like just a few patches to u-boot 2019.01.  I can at least try to build an image from it
So then why do you say you support SOPINE if you don't want to support SPOINE?  This is not just some random user problem.  This is a problem with the distribution image image that probably could have been fixed by now.  The only reason you need to hire people is because this is how you treat them when they do their best to try and help for free.
Hey Man, can we just kind of back away from this back and forth?     Lets focus on the fix that we'd like you to try
Maybe try this.
@lanefu
I got the serial console working the other day.  It took me some time to figure out how to do it, but I was able to convert the dtb to dts for editing, insert the rx change and convert it back.  That did fix the problem.
I have plenty of experience running headless linux.  What I don't have is any kind of experience with messing with linux drivers.  On the PC side, I never use linux because of all the driver problems.  I mostly use it on embedded hardware that has drivers working.  I am aware that Pine64 does have problems with drivers.  I supported their kickstarter and got a bord that I couldn't use because it didn't work with my monitor.  I never thought that would translate in to problems with something so basic as a network card.  If I would have known it was going to be like this, I never would have started this project.  That being said, this is where I find myself and I'm doing my best to try and help.
15 hours ago, lanefu said:
@AZClusterboard
Please try this image that I built and let me know how your testing goes.  I don't have any pin64 stuff.
Patch is in this PR https://github.com/armbian/build/pull/1324
@martinayotte
Would you mind taking a look at my PR and make sure I put the patch in the proper location, named correctly, and other adult things I'm supposed to do?
I booted the image.  It did pull down DHCP.  I was able to SSH in to it and run apt-get update/upgrade.  What else should I test?  Off the top of my head, the only thing I can think of is to try it on more than just 1 module to make sure it's generating MAC addresses without conflicts.  I'm going to try and find an empty SD card to work with.
Will do.  I was going chronologically.  Please give the same advice to Igor.
Ya thats a great idea.  Probably the most impactful edge case to happen.
Does Cpu frequency and all of that kind of stuff look good with `armbianmonitor -m` ?
Good news is that it is generating unique MAC addresses.  armbianmonitor is showing my frequency at 648 but that might just be scaling based on load.   Should I try running SETI@Home or is there something that is part of the existing OS image I can do to make it crunch some numbers?
