  2. It depends on how you have bricked it. Reflashing Android takes you back to a clean starting point.
  3. Hello - Very new to this all and trying to learn my way around. I have an OPi4a which I was previously using for octoprint, etc. Was able to get it going using OrangePi's provided Ubuntu22.04 Jammy image, but am needing to reconfigure and was interested in armbian as the official images from OrangePi can be hard to access at times (site seems to intermittently go down / time out?), and from what I've seen there's very limited support from the manufacturer. Anyways - for the uninitiated, what is the status of the image for the 4a? Seeing the most recent post - does the backport being merged mean that it is possible to build from armbian main? Which target board should be selected? I am not seeing an option for the 4a, or any with the T527 chip. Alternatively, the most recent image I'm seeing is from @JuanEsf - to get this to work do I just need to use something like balena and flash from URL? Very new to all this, any help is appreciated.
  4. The x96q-v5-1 image support aic8800 wifi chip without modify anything from dtb. Follow this https://github.com/LYU4662/aic8800-sdio-linux-1.0, the AIC8800 and alternate based on AIC8800 will work!
  5. Alright, found something. @Meestor_X please try this one: https://testing.armbian.de/Armbian-unofficial_26.02.0-trunk_Radxa-cubie-a5e_trixie_edge_6.18.2_minimal.img.xz
  6. Well, at this point, hard to say what's going on: I'm not sure what happened during my chroot sessions but it looks like / in now non crypted and the boot options were completely overridden by who know's what verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-rock-5-itx.dtb rootdev=UUID=92f542d4-5a03-424e-b953-e711111186dc rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u And I can boot without having to luks decrypt. It is probably a side effect of what I mounted in the chroot (/run /sys, etc) but I did not know this was even possible and I would be interested in theories or possible explanations. Thanks to all of you, especially @IBV
  7. Would you please tell me How to enable OTG network?I flash "Armbian 25.11.2 trixie" with kernel 6.12.58.But typec port can't active as slave device,when I connect a usb2.0 cable between the typec and my compuer usb-A port. Thanks!
  8. Will you please give the detail step?I flash "Armbian 25.11.2 trixie" ,but I can't find any useful dtbo file.
  9. Today
  10. How can you active spi support?I burn " 25.11.2" image,but I can't find any overlay of spi ,uart or i2c. This is my system status: cat /etc/os-release PRETTY_NAME="Armbian 25.11.2 trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.2 ID=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian 25.11.2 trixie" uname -a Linux Pi-s 6.12.58-current-rockchip64 #3 SMP PREEMPT Thu Nov 13 20:34:41 UTC 2025 aarch64 GNU/Linux ls /boot/dtb/rockchip/overlay/rk3308* /boot/dtb/rockchip/overlay/rk3308-b@1.3ghz.dtbo /boot/dtb/rockchip/overlay/rk3308-otg-host.dtbo /boot/dtb/rockchip/overlay/rk3308-bs@1.3ghz.dtbo /boot/dtb/rockchip/overlay/rk3308-s0-ext-antenna.dtbo /boot/dtb/rockchip/overlay/rk3308-bs.dtbo
  11. Post the UART log.
  12. @Werner OK, since I have a few Duos (v1.0 and v1.1) I tried same Jammy with 6.1.63 kernel SD in each and let idle. The 1.1 with copper heatsink runs about 40C, the 1.1 with same aluminum heat sink runs around 45C. The v1.0 runs around 50C. So weird. I'll try latest build, but stress-ng causing thermal shutdowns worries me. I used to run decent loads on these little boards. Good thing is thermal shutdown works or it would burn up the board.
  13. How can I force it to boot from SD though?
  14. Yesterday
  15. sven-ola
    As a followup: hardware crypto is damn slow on the Ky / SpacemIt platform, at least for default LUKS block encryption with AES. This probably also affects the Banana Pi F3 image. With default sector-size of 512 byte, HW-AES is 5 times slower than SW-AES, while cryptsetup benchmark reports 5 times faster. Main reason: block size. With sector-size of 4096 LUKS is reasonable fast. Also there is leftover debug (cannot be switched off) and a small bugs in the driver that triggers SW crypto fallback after HW crypto succeeds. Patches: https://github.com/sven-ola/armbian-build/tree/orangepi-rv2/patch/kernel/ky-current Best // Sven-Ola
  16. I do not use chatgpt Most of them are rubbish anwers
  17. Here is ukrainian forum with Android for this box: https://legione.name/upload/?dir=Smart-TV-Box/Q1/ Any chance to find linux for the same box? Android tv box q1 v3.0 Allwinner H313 If someone will find working version, please share
  18. Hello! It seems that there is some issue with the user files FTP server. The multitool image should be acessessible from: https://users.armbian.com/jock/web/rk322x/multitool/ But it is present in: https://users.armbian.com/users.armbian.com/jock/web/rk322x/multitool/
  19. I now actually see after some more reading and checking other SoC's that the CPU's in the A733 must start the kernel at EL2. See also ARM reference doc: 102412_0103_01_en So also 5.x kernel should work if EL2 I think If the A733 has not implemented EL2 and EL3 as could be the case as suggested in ARM reference doc, no KVM. See chapter6: As it is Allwinner, I won't be surprised, but wait and see what Radxa will come up with.
  20. npu is there in both vendor bsp kernel 6.1.y. There is no node exposed afaik. Everthing beyond like libraries to use npu is userspace and out of scope of Armbian. edge 6.18.y also has reverse-engineered npu support with a driver called Rocket.
  21. Last week
  22. Good afternoon. I'm trying to stream video to my orange pi zero 2w. I am using Gstreamer and while testing I saw that v4l2slh264dec fails. When using autosink, only a transparent window is shown and when using a specific sink, no window is opened. My intention is to take advantage of the VPU with Gstreamer but that failure has caused me headaches. I tried using MVP and it works fine but it's not what I need. Maybe I will choose other options for what I want to do but first I would like to ask here about the topic- Thank you very much to whoever takes the trouble to read this and thanks in advance to whoever responds ❤️ By.: Google Translate
  23. Developing solutions and sharing by sending PR and/or using customize image script might be the way address those.
  24. Hi, I'm new to this forum but I've been researching this topic for quite some time. I have a Mecool KM1 Deluxe with 4GB of RAM and 64GB of storage, and an Amlogic S905X3 chip. I wanted to install Armbian to use it as a Linux device, but I've tried several versions and it hasn't worked. Someone mentioned on this forum that installing CoreELEC would prevent Armbian from booting. I installed emuelec and it worked perfectly, but I haven't been able to run Armbian. Could this be the reason? Thanks.
  25. I've been using my Helios64 nonstop since i got it in 2020 (and the Helios 4 since 2018). It's been great the whole time; does exactly what I want it to do, and now I've made it my sole Plex server to save power. My only problem is that the internal eMMC is now 100% full (thanks to Plex), and I can't work out how to move the install back to the SDCard (Linux noob...), which is my I'm here. I'm sad these guys had to shut down. This could have been a magnificent project
  26. Hello, Here is a config file that works with linux-6.6.119 config-6.6.119 And a tarball here : https://drive.google.com/file/d/14EHPMT01-geYNflC2lqXNue4ZH25z-lA/view?usp=drive_link with a fresh built kernel. Two small patches are needed : one to activate the wifi/bluetooth card (in dtb file), another to add a delay in mwifiex_sdio.c What works : wifi, eth0 and eth1 cards I can't activate the bluetooth card with btmrvl_sdio (need to be investigate) If someone else can test this (@rolli_44 , @umiddelb ? ). Next : propose a patch to integrate this board in armbian ?
  27. log says: No space left on device So you need to look at that, remove unneeded stuff etc. Also check the output of df Maybe something else is wrong
  28. OrangePi in general is bad support, as also is stated on the image download page. For just driving a relay, so a pin change between high and low, you first need to select which pin from the GPIO header you want to use. You can see what are probably generic GPIO by default from picture here: http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-Zero-2W.html In the latest image, I see there is no real support for OrangePi02W, only H5 and A64, not the actual H618 (it seems to use H616, so also that might lead to issues). You can look in file maybe, if you want other then defaults: /boot/dtb/allwinner/overlay/README.sun50i-H5-overlays I have older 32-bit Allwinner things, H3 for example. Analog and SPDIF audio works great there, that is why I bought those mainly. Also GPIO6 I use for driving a switch (via extra resistors and some MOSFET/TRIAC). I did some C-code and got working temp sensor and switch, see lgio code https://abyz.me.uk/lg/download.html But currently for years already in bash script: init: test -f /sys/class/gpio/gpio6/value && echo 6 > /sys/class/gpio/unexport echo 6 > /sys/class/gpio/export echo out > /sys/class/gpio/gpio6/direction chown root:gpio /sys/class/gpio/gpio6/value chmod g+w /sys/class/gpio/gpio6/value on: gpioset gpiochip0 6=1 off: gpioset gpiochip0 6=0 This still works since Armbian Buster, now kernel 6.12. Not tested yet with 6.18
