  2. Hi, i think the rpm setting-step#S of the onboard fan is to low. - how can this be adjusted? SBC: Rock5b
  4. ...or maybe an r8169 driver problem under heavy load dmesg -w | grep -i r8169 [ 5.072779] r8169 0004:41:00.0: enabling device (0000 -> 0003) [ 5.115535] r8169 0004:41:00.0 eth0: RTL8125B, 00:e0:4c:03:00:fc, XID 641, IRQ 166 [ 5.115550] r8169 0004:41:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko] [ 6.328634] RTL8226B_RTL8221B 2.5Gbps PHY r8169-4-4100:00: attached PHY driver (mii_bus:phy_addr=r8169-4-4100:00, irq=MAC) [ 6.518776] r8169 0004:41:00.0 eth0: Link is Down [ 9.721015] r8169 0004:41:00.0 eth0: Link is Up - 2.5Gbps/Full - flow control off [ 9717.405068] r8169 0004:41:00.0 eth0: NETDEV WATCHDOG: CPU: 3: transmit queue 0 timed out 5227 ms [ 9717.405345] r8169 0004:41:00.0 eth0: ASPM disabled on Tx timeout [ 9717.418437] r8169 0004:41:00.0 eth0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100). [ 9941.759110] r8169 0004:41:00.0 eth0: Link is Down [ 9945.329364] r8169 0004:41:00.0 eth0: Link is Up - 2.5Gbps/Full - flow control off I have a frigate container running on this sbc. A second Rock 5b (same os version) with 10 docker images but very low traffic run smoth on the same switch with 2.5Gbps. Could someone check which driver Radxa OS uses?
  5. Hello everyone, I'm still having trouble flashing the h96 max m9 to armbian os, I still haven't succeeded in using the maskrom, but the uart connection has worked, is it possible to flash only the uart connection? Please help me with the steps for flashing the H96 M9.
  6. If there is anyone still running an older version of the kernel and the USB-C is working it would be helpful if I can get a copy of your rk3588s-odroid-m2.dtb.
  7. I initially tried the instructions in the original post and it didn't work for me. On an allwinner h618 box with a mali-G31. I then spent pretty much all day today trying to find a fix. I came across a post on here stating the version of mpv that works with v4l2 needs to be compiled with the same package versions as ffmpeg or something along those lines. When I first tried the instructions I already had mpv installed and I remember it stating that it didn't update it. So for a hail mary I ran apt remove ffmpeg and apt remove mpv. Then I ran the instructions again and noticed first one didn't actually run successfully which could have been why they didn't work this morning.... When I copy pasted into the terminal it left the $ signs in there and caused errors. So I manually typed it out and got everything to run successfully. Now everything works. mpv is buttery smooth. Previously mpv stated drm was unsupported now it says "using hardware decoding (drm)". I had checked ffmpeg and it did list v4l2 as supported so maybe that didn't need to be reinstalled. Anyway, if it hasn't worked for you maybe try uninstalling ffmpeg and mpv and running the commands again.
  8. And now I've hit a road block. I can't get video acceleration to work. VLC just displays a blank screen no matter what output I select and MPV playback is very stuttered. I wanted this box to act as an Emby client, got it all configured to load emby via the ir remote and got all the functionality working but when I play a video it's so choppy it's basically unwatchable. 576p is almost bearable, 1080p is not. I've spent all day on it and got nowhere. I've followed the instruction in this post but it made no difference - Repository for v4l2request hardware video decoding (rockchip, allwinner) edit: Ok the instructions in that post did actually work, I just didn't notice one of the commands had not run properly when I first tried it. Video playback in mpv is buttery smooth, now I just need to figure out how to get emby to do the same.
  9. Yesterday
  10. https://github.com/armbian/os/pull/426 Once automation finishes - couple of hours, repo will have a missing package. Workaround: manually install package from https://packages.debian.org/forky/zfs-zed
  11. Igor
    Linux Headers
    Headers are present. https://imola.armbian.com/apt/pool/main/l/linux-headers-current-rockchip64/ Upgrade packages to latest and try again.
  12. etcher did decompess before flash to the SD card
  13. Hi @Anto, Igor has built that version if you look in his post above: https://forum.armbian.com/applications/core/interface/file/attachment.php?id=15377&key=f234d69d5a19f0081fdad46abb21cc36
  14. Version 3 Has been released! Complete UI Overhaul The entire user interface has been rebuilt from the ground up using Qt QML, delivering a modern automotive HMI experience optimized for touchscreen displays. New Home Screen - Large centered clock with configurable 12-hour/24-hour format - Gradient background (#00021A → #001D3F) - Swipe navigation to media player - Clean, minimal design with Readex Pro typography New Bottom Navigation Dock - 5-button dock: Home | Music | Android Auto | Volume | Settings - Always visible for quick access (except when running AA) - Icon-based navigation with visual feedback New Music Player - Album art display with track metadata - Playback controls (Previous, Play/Pause, Next) - Integrated with system media Redesigned Settings - Modern two-column layout with left sidebar navigation - 8 categories: General, Video, Audio, Input, Bluetooth, WiFi, System, About - Toggle switches, sliders, and radio buttons - Real-time system info (CPU temp, memory, frequency) - Live date/time display in header New Features - 12/24-Hour Time Toggle: Switch between time formats in Settings → General - Readex Pro Font: Variable weight font for consistent automotive typography - Modernized UI: The Original Crankshaft-NG was just not suitable for car use so i had to refresh it Technical Changes - Qt Widgets → QML Migration — Complete rewrite of UI layer - UIBackend Bridge — New C++ backend class exposing 50+ properties to QML - EGLFS Optimized — Designed for direct framebuffer rendering - No Animations — Instant transitions for 1GB RAM constraint - Centralized Theming — Theme.qml singleton for consistent styling Removed - GPIO settings (not applicable to TV Boxes) - DAC settings (using ALSA directly) - RTC settings (no CMOS battery, NTP only) - TSL2561 light sensor support (Pi-specific) - Camera module settings (Pi-specific) Bug Fixes - Fixed Cursor issue by utilizing Cursor plane (41, z-pos 2) - Fixed std::mutex missing include in RtAudioOutput - Fixed ColorOverlay import for Qt GraphicalEffects - Fixed time display showing 24hr with AM/PM suffix - Fixed buffer overflow warning in FFmpegDrmVideoOutput - Fixed QCursor conversion error in autoapp.cpp Known Issues: - Music player metadata not populated (requires media service integration, will be done in the next patch) - Volume popup not implemented (this require modifying the asound.conf before implementing) Issues? Open a ticket in https://github.com/Harleythetech/openauto-rk3229-armbian/issues Download https://github.com/Harleythetech/openauto-rk3229-armbian/releases/tag/oark322x-V3.0.0-alpha
  15. Some context: https://docs.armbian.com/User-Guide_FAQ/#why-things-stop-working The hardest part and expensive for time is keeping functions working while kernel changes, goes up. Image you are referring too is probably a demo image with some ancient kernel that will never be changed. This is usual way to sell hardware. It is made to work, but you will stay at this very old SW stack without any real option to change or fix anything. All functions on 300+ boards, which on top of extreme diversity, have also different revisions, quality issue ... is already not possible to keep up by entire open source community. Armbian is small part focused into SBCs and we do what we can. Work we are doing is never complete, we (nobody) can't solve bugs and especially not near to (expected) real-time. We (or community open source in total) can address a problem within weeks or months fastest as resources are tiny compared to problems that are constantly found in open source code that somebody else made. We have no option to expand the team / project as users don't care about well being of SW developers. We can only try to keep SW stack operational on a best effort principle. Once this job becomes too expensive (<1% of costs share is on users side), we have to step back and declare support as "community". We will continue to build and ship images as they might still work for some use cases and as downstream projects will provide those Armbian images anyway.
  16. A month ago when doing test boots and power measurements, see I discovered that when using the RPL 27W 'Pi5' PSU, the NanoPi-R6C with the indicated bootloader(s) and kernel(s) sticks to 5V. But when using a 45W USB-C PD PSU from a HP laptop or 60W USB-C PD PSU white-label, switch is made I saw on a USB-C PD power measurement device that was also in the chain. More detailed USB-C PD protocol analysis seems to be needed in order to figure out what happens. One could guess 3A is requested at highest possible voltage as with the 45W PSU, I saw 15V. 9V or 12V would also be OK, but the PD handler cannot be 100% sure I think, depends also what is inserted in USB type-A ports on device etc.
  17. does emmc working yet?
  18. armbianmonitor - u result: https://paste.armbian.com/nocetohemu Best regards Rolf
  19. @Nick A Oh yeah, I did change a few things as well for type c. Maybe the drm heap changes are not needed after all. Looking at my changes. husb311 is now under drivers/power/typec, so just enable it. et7304 is not included in the original bsp, radxa team added them later so simply apply this same patch. https://github.com/radxa/allwinner-bsp/commit/156b6578cc173855b41ea311a229403ccbadb17c
  20. Last week
  21. Hi, I wanted to report an issue with the currently available Armbian images for the PocketBeagle 2 (all of them from what I can tell), that stops them from booting up. I attempted to go through the bug reporting form, but it seems to only point you to the forum, so here I am. I couldn't find a location to post about the PocketBeagle 2 board specifically, so I am putting this under the Beagle Y board (they have the same maintainer listed). Please move this to the right place (or maybe create it if it doesn't exist?) or tell me how I should do this myself. The issue is in the file "/boot/extlinux/extlinux.conf", where a ".dts" file is being referenced from the directory "/boot/dtb/ti/", which contains only ".dtb" files. U-Boot fails to find the device tree file and fails to boot. Changing the file extension of the device tree in "extlinux.conf" to ".dtb" fixes the boot up issue and everything else seems to be working fine. If this is not the right place to be reporting this issue, please direct me to the correct place, so this can be brought to the attention of the appropriate maintainer. It should be a quick fix, but the images currently available to download are likely unusable for inexperienced users. Many Thanks, Paul
  22. With new python based build system there is error compiling headers while installing headers deb. Im not sure is it because of new build system or the problem is in 6.1.15 kernel branch. My compile command was: ./compile.sh BOARD=orangepione BRANCH=current BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_ONLY=yes KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,img SKIP_EXTERNAL_TOOLCHAINS=no BUILD_KSRC=no PRIVATE_CCACHE=yes RELEASE=bionic ARTIFACT_IGNORE_CACHE=yes BUILD_KSRC=yes KERNEL_GIT=full While installing i got: igor@honeypot:~/trash/debs$ ls -1 armbian-config_23.05.0-trunk_all.deb armbian-firmware_1-SA56ad-Bf566_all.deb linux-dtb-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb linux-headers-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb linux-image-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb linux-u-boot-orangepione-current_2022.07-Se092-P12e0-Be261_armhf.deb igor@honeypot:~/trash/debs$ sudo dpkg -i * [sudo] password for igor: (Reading database ... 107907 files and directories currently installed.) Preparing to unpack armbian-config_23.05.0-trunk_all.deb ... Unpacking armbian-config (23.05.0-trunk) over (23.02.0-82) ... dpkg: warning: downgrading armbian-firmware from 23.02.0-82 to 1-SA56ad-Bf566 Preparing to unpack armbian-firmware_1-SA56ad-Bf566_all.deb ... Unpacking armbian-firmware (1-SA56ad-Bf566) over (23.02.0-82) ... dpkg: warning: downgrading linux-dtb-current-sunxi from 23.02.0-82 to 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8 Preparing to unpack linux-dtb-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb ... Armbian 'linux-dtb-current-sunxi' for '6.1.15-sunxi': 'preinst' starting. + rm -rf /boot/dtb + rm -rf /boot/dtb-6.1.15-sunxi + set +x Armbian 'linux-dtb-current-sunxi' for '6.1.15-sunxi': 'preinst' finishing. Unpacking linux-dtb-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) over (23.02.0-82) ... dpkg: warning: downgrading linux-headers-current-sunxi from 23.02.0-82 to 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8 Preparing to unpack linux-headers-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb ... Armbian 'linux-headers-current-sunxi' for '6.1.15-sunxi': 'preinst' starting. + [[ -d /usr/src/linux-headers-6.1.15-sunxi ]] + set +x Armbian 'linux-headers-current-sunxi' for '6.1.15-sunxi': 'preinst' finishing. Unpacking linux-headers-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) over (23.02.0-82) ... dpkg: warning: downgrading linux-image-current-sunxi from 23.02.0-82 to 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8 Preparing to unpack linux-image-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb ... Armbian 'linux-image-current-sunxi' for '6.1.15-sunxi': 'preinst' starting. + export 'DEB_MAINT_PARAMS=upgrade 23.02.0-82 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8' + DEB_MAINT_PARAMS='upgrade 23.02.0-82 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8' + export INITRD=Yes + INITRD=Yes + test -d /etc/kernel/preinst.d + run-parts --arg=6.1.15-sunxi --arg=/boot/vmlinuz-6.1.15-sunxi /etc/kernel/preinst.d update-initramfs: Deleting /boot/initrd.img-5.15.93-sunxi Removing obsolete file uInitrd-5.15.93-sunxi + mountpoint -q /boot + set +x Armbian 'linux-image-current-sunxi' for '6.1.15-sunxi': 'preinst' finishing. Unpacking linux-image-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) over (23.02.0-82) ... Preparing to unpack linux-u-boot-orangepione-current_2022.07-Se092-P12e0-Be261_armhf.deb ... Unpacking linux-u-boot-orangepione-current (2022.07-Se092-P12e0-Be261) over (23.02.0-82) ... Setting up armbian-config (23.05.0-trunk) ... Setting up armbian-firmware (1-SA56ad-Bf566) ... Setting up linux-dtb-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) ... Armbian 'linux-dtb-current-sunxi' for '6.1.15-sunxi': 'postinst' starting. + cd /boot + ln -sfT dtb-6.1.15-sunxi dtb + set +x Armbian 'linux-dtb-current-sunxi' for '6.1.15-sunxi': 'postinst' finishing. Setting up linux-headers-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) ... Armbian 'linux-headers-current-sunxi' for '6.1.15-sunxi': 'postinst' starting. + cd /usr/src/linux-headers-6.1.15-sunxi ++ grep -c processor /proc/cpuinfo + NCPU=4 + echo 'Compiling kernel-headers tools (6.1.15-sunxi) using 4 CPUs - please wait ...' Compiling kernel-headers tools (6.1.15-sunxi) using 4 CPUs - please wait ... + yes '' + make ARCH=arm oldconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/confdata.o HOSTCC scripts/kconfig/expr.o LEX scripts/kconfig/lexer.lex.c YACC scripts/kconfig/parser.tab.[ch] HOSTCC scripts/kconfig/lexer.lex.o HOSTCC scripts/kconfig/menu.o HOSTCC scripts/kconfig/parser.tab.o HOSTCC scripts/kconfig/preprocess.o HOSTCC scripts/kconfig/symbol.o HOSTCC scripts/kconfig/util.o HOSTLD scripts/kconfig/conf # # configuration written to .config # + make ARCH=arm -j4 scripts SYNC include/config/auto.conf.cmd HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.[ch] HOSTCC scripts/dtc/libfdt/fdt.o HOSTCC scripts/dtc/libfdt/fdt_ro.o HOSTCC scripts/dtc/libfdt/fdt_wip.o HOSTCC scripts/dtc/libfdt/fdt_sw.o HOSTCC scripts/dtc/libfdt/fdt_rw.o HOSTCC scripts/dtc/libfdt/fdt_strerror.o HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o HOSTCC scripts/dtc/libfdt/fdt_addresses.o HOSTCC scripts/dtc/libfdt/fdt_overlay.o HOSTCC scripts/dtc/fdtoverlay.o HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/fdtoverlay HOSTLD scripts/dtc/dtc HOSTCC scripts/bin2c HOSTCC scripts/kallsyms HOSTCC scripts/recordmcount HOSTCC scripts/selinux/genheaders/genheaders HOSTCC scripts/selinux/mdp/mdp HOSTCC scripts/sorttable HOSTCC scripts/asn1_compiler HOSTCC scripts/insert-sys-cert + make ARCH=arm -j4 M=scripts/mod/ CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig CC scripts/mod/devicetable-offsets.s UPD scripts/mod/devicetable-offsets.h MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/modpost.o HOSTCC scripts/mod/sumversion.o HOSTCC scripts/mod/file2alias.o HOSTLD scripts/mod/modpost MODPOST scripts/mod/Module.symvers + make ARCH=arm -j4 tools/objtool DESCEND objtool HOSTCC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/fixdep.o HOSTLD /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/fixdep-in.o LINK /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/fixdep CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/weak.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/check.o MKDIR /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/arch/arm/ LD /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/arch/arm/objtool-in.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/special.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/exec-cmd.o check.c:11:10: fatal error: arch/elf.h: No such file or directory 11 | #include <arch/elf.h> | ^~~~~~~~~~~~ compilation terminated. make[3]: *** [/usr/src/linux-headers-6.1.15-sunxi/tools/build/Makefile.build:97: /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/check.o] Error 1 make[3]: *** Waiting for unfinished jobs.... special.c:14:10: fatal error: arch/special.h: No such file or directory 14 | #include <arch/special.h> | ^~~~~~~~~~~~~~~~ compilation terminated. CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/help.o make[3]: *** [/usr/src/linux-headers-6.1.15-sunxi/tools/build/Makefile.build:97: /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/special.o] Error 1 CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/pager.o make[2]: *** [Makefile:54: /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/objtool-in.o] Error 2 make[2]: *** Waiting for unfinished jobs.... CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/parse-options.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/run-command.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/sigchain.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/subcmd-config.o LD /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/libsubcmd-in.o AR /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/libsubcmd.a make[1]: *** [Makefile:73: objtool] Error 2 make: *** [Makefile:1437: tools/objtool] Error 2 dpkg: error processing package linux-headers-current-sunxi (--install): installed linux-headers-current-sunxi package post-installation script subprocess returned error exit status 2 Setting up linux-image-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) ... Armbian 'linux-image-current-sunxi' for '6.1.15-sunxi': 'postinst' starting. + export 'DEB_MAINT_PARAMS=configure 23.02.0-82' + DEB_MAINT_PARAMS='configure 23.02.0-82' + export INITRD=Yes + INITRD=Yes + test -d /etc/kernel/postinst.d + run-parts --arg=6.1.15-sunxi --arg=/boot/vmlinuz-6.1.15-sunxi /etc/kernel/postinst.d update-initramfs: Generating /boot/initrd.img-6.1.15-sunxi update-initramfs: Converting to u-boot format + echo 'Armbian: update last-installed kernel symlink to '\''zImage'\''...' Armbian: update last-installed kernel symlink to 'zImage'... + ln -sfv vmlinuz-6.1.15-sunxi /boot/zImage '/boot/zImage' -> 'vmlinuz-6.1.15-sunxi' + touch /boot/.next + set +x Armbian 'linux-image-current-sunxi' for '6.1.15-sunxi': 'postinst' finishing. Setting up linux-u-boot-orangepione-current (2022.07-Se092-P12e0-Be261) ... Errors were encountered while processing: linux-headers-current-sunxi
  23. Thank you a lot, my Dragon Q6A now has audio
  24. Hey just checking in. I haven't forgotten about this yet, I want to make sure everything is repeatable and possible to do on multiple versions of armbian before I write a guide and confuse a lot of people. Noticing that mpv doesn't work, I tried to do what jock suggested to Harleyyyu and update to a newer kernel version. So far... no luck. Seems like the problem boils down to having to write u-boot.bin to the eMCP before burning the actual OS onto it. I'll write again if anything goes.
  25. https://github.com/armbian/build/pull/9323
  26. @jock Thank you for your reply. Unfortunately, I can't do it I tried to short it, but it doesn't load from the SD card. I shorted it with a piece of wire. When I do it with USB connected, I see the device is in Maskrom. Here the console output from rkdeveloptool using: root@lensky-lp:~# lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 004: ID 10c4:8105 Silicon Labs USB OPTICAL MOUSE Bus 001 Device 005: ID 04ca:707f Lite-On Technology Corp. HP Wide Vision HD Camera Bus 001 Device 006: ID 0bda:b00b Realtek Semiconductor Corp. Realtek Bluetooth 4.2 Adapter Bus 001 Device 008: ID 1ea7:0066 SHARKOON Technologies GmbH [Mediatrack Edge Mini Keyboard] Bus 001 Device 009: ID 2207:320c Fuzhou Rockchip Electronics Company RK3328 in Mask ROM mode Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub root@lensky-lp:~# rkdeveloptool ld DevNo=1 Vid=0x2207,Pid=0x320c,LocationID=104 Maskrom root@lensky-lp:~# rkdeveloptool td Test Device failed! root@lensky-lp:~# rkdeveloptool ---------------------Tool Usage --------------------- Help: -h or --help Version: -v or --version ListDevice: ld DownloadBoot: db <Loader> UpgradeLoader: ul <Loader> ReadLBA: rl <BeginSec> <SectorLen> <File> WriteLBA: wl <BeginSec> <File> WriteLBA: wlx <PartitionName> <File> WriteGPT: gpt <gpt partition table> WriteParameter: prm <parameter> PrintPartition: ppt EraseFlash: ef TestDevice: td ResetDevice: rd [subcode] ChangeStorage: cs [storage: 1=EMMC, 2=SD, 9=SPINOR] ReadFlashID: rid ReadFlashInfo: rfi ReadChipInfo: rci ReadCapability: rcb PackBootLoader: pack UnpackBootLoader: unpack <boot loader> TagSPL: tagspl <tag> <U-Boot SPL> ------------------------------------------------------- root@lensky-lp:~# rkdeveloptool rid Reading flash ID failed! root@lensky-lp:~# rkdeveloptool cs 2 AMO: ERR_DEVICE_WRITE_FAILED Change Storage failed! root@lensky-lp:~# rkdeveloptool ppt Read GPT failed! Read parameter failed! Not found any partition table! root@lensky-lp:~# rkdeveloptool db /home/lensky/Downloads/For\ RK3328\ devices/RK3328MiniLoaderAll_V2.50.bin Downloading bootloader succeeded. root@lensky-lp:~# rkdeveloptool ppt **********Partition Info(parameter)********** NO LBA Name 00 00002000 uboot 01 00004000 trust 02 00008000 misc 03 0000A000 baseparamer 04 0000A800 resource 05 00012000 kernel 06 00022000 boot 07 00032000 recovery 08 00042000 backup 09 00062000 cache 10 000A2000 metadata 11 000AA000 kpanic 12 000AC000 system 13 003AC000 userdata As you see after boot it looks like the flash is empty. I can't ready any info and there no partitions. But after download bootloader command I see partiosions and can read flash info and chip info. After reboot all is disappear again. This is my board: This is my eMMC chip: I have found YouTube video how to short the clock pin for my board. On the opposite side, I need to short these pins: When I insert the SD card and boot the device, it just lights the red led and nothing more. Is something I do wrong?
  27. Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 652da4fbc (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v1.6.1 30~60fps@720p (low settings, high texture, no AA) box64 environment variables: Black Mesa
  28. diy image and you get it immediately
  29. Decided to see how far the LLM have come along and give this another crack. Gemini 3 Flash seems to have got me a few steps forward. It had me add zswap and build a swap file while adjusting some of the U-Boot variables. /boot/armbianEnv.txt additions/changes fdt_addr_r=0x42000000 ramdisk_addr_r=0x42800000 fdt_high=0xffffffff initrd_high=0xffffffff extraargs=zswap.enabled=0 swiotlb=1024 I had to expand the filesystem to use more of the SD card then added a 512M swapfile sudo fallocate -l 512M /mnt/pinecube/swapfile sudo chmod 600 /mnt/pinecube/swapfile sudo mkswap /mnt/pinecube/swapfile It took a solid 5 or so minutes but I got booted. It's very slow but at least I got this far! Just leaving this here for anyone else that may stumble along.
