  2. there are a few caveats that may need a bit of attention It is documented somewhere that if you use channel 0, the driver would automatically select an appropriate channel / frequency. However, it seemed that back then initially while I tested it, that didn't seem to work. (i'm not sure if it may have changed) hence to list the channels one needs to run iw list and you would get a list of channels like such * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) * 2472 MHz [13] (20.0 dBm) * 2484 MHz [14] (20.0 dBm) * 5170 MHz [34] (disabled) * 5180 MHz [36] (20.0 dBm) * 5200 MHz [40] (20.0 dBm) * 5220 MHz [44] (20.0 dBm) * 5240 MHz [48] (20.0 dBm) * 5260 MHz [52] (20.0 dBm) (radar detection) * 5280 MHz [56] (20.0 dBm) (radar detection) ... * 5720 MHz [144] (20.0 dBm) (radar detection) * 5745 MHz [149] (20.0 dBm) * 5765 MHz [153] (20.0 dBm) * 5785 MHz [157] (20.0 dBm) * 5805 MHz [161] (20.0 dBm) * 5825 MHz [165] (20.0 dBm) what I normally do is to do a scan and pick an unused / least used channel : iw wlan0 scan pick an appropriate channel and specify it in hostapd.conf. 5ghz channels (hw_mode=a) delivers a max throughput of like 140 Mbps which is fast. https://docs.armbian.com/WifiPerformance/#uwe-5622 accordingly there are some country specific requirements for 5ghz channel selections and one may like review https://en.wikipedia.org/wiki/List_of_WLAN_channels iw reg set etc I did a google search and some of these resources may be useful https://wiki.archlinux.org/title/NetworkManager https://www.baeldung.com/linux/nmcli-wap-sharing-internet in a same way you may need to set the channel if necessary then that this repo is found in a google search which may be useful https://github.com/pi-top/Wi-Fi-Access-Point-and-Station-Mode/tree/master
  3. Yesterday
  4. I'm trying to compile an LED display driver: https://github.com/arthur-liberman/linux_openvfd I follow this description: https://github.com/bk3a12/openvfd_enable_for_tx3_mini However, I can't build anything and the whole process ends with errors: sh ./scripts/modules-check.sh /home/user/INSTALKI/linux_openvfd/driver/modules.order make -f ./scripts/Makefile.modpost make[3]: *** No rules to make an object '/home/user/INSTALKI/linux_openvfd/driver/modules.order', required by '/home/user/INSTALKI/linux_openvfd/driver/Module.symvers'. Stop. make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1897: modpost] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64' make: *** [Makefile:5: modules] Error 2
  5. @werner Sorry the delay, I was trying to get the TTL adapter. Here is what I get from the TTL in the first boot after flashing Armbian_community_25.8.0-trunk.228_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:l0,l0 CH0 RX Vref:27.1%, TX Vref:20.0%,20.0% DQ rds:h3 h4 h2 h1 h5 h2 h2 h1, h1 h3 h3 h5 h1 h3 h2 h2 DQS rds:l0,h1 CH1 RX Vref:27.9%, TX Vref:21.0%,20.0% DQ rds:l0 h1 h2 h3 h6 h2 h3 h6, h4 h2 h2 h2 h2 h1 h4 l0 DQS rds:l0,l0 CH2 RX Vref:26.7%, TX Vref:19.0%,21.0% DQ rds:h3 l0 l0 l0 h4 h1 h7 h3, h2 l0 h1 l0 h2 h4 h1 h1 DQS rds:l0,h1 CH3 RX Vref:27.9%, TX Vref:20.0%,20.0% DQ rds:h5 h3 h7 h4 h2 h2 h4 h4, h4 h3 h4 h2 h3 h1 h3 h1 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0 x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL board init U-Boot SPL 2017.09 (Jun 13 2025 - 02:18:34) unknown raw ID ff ff ff unrecognized JEDEC id bytes: ff, ff, ff Trying to boot from MMC1 Card did not respond to voltage select! spl: mmc init failed with error: -95 Trying to boot from MMC2 Card did not respond to voltage select! spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### # Reset the board to bootrom # Not sure if it matters, but I have a EMMC installed and flashed the image to it using the rkdevelop tool. ( The same way I do to flash the firmware from orangepi site ) Just in case, here are the commands I use ./rkdeveloptool db MiniLoaderAll.bin ./rkdeveloptool wl 0 Armbian_community_25.8.0-trunk.228_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img ./rkdeveloptool rd
  6. Hi, I also tried to run this sensor, tried different ports but to no avail. maybe you found a way to solve this problem?
  7. Hi! So, I tried this overlay, and the device still did not detect USB. Although when I tried switching the dts file to the topwise a721, the HDMI stopped working but USB devices were correctly detected. On top of that, no the display still does not work even with the topwise device tree. I checked the RAM clock speed with the command you mentioned and it said 432000000, which is much higher than what I found from the boot file from original Android (384000000). Is there a way I can rebuild just u-boot and install it in this working image?
  8. Share the image of your assembly, preferably server-side.
  9. I think I solved it! In the upgraded system there was no package pahole! After I installed the pahole and reinstalled the package linux-headers-6.12.33-current-x86, I got the BTF stuff as described above in the .config file and I can compile modules! Pfff, finally! I checked the Raspberry Pi 4 version, I see no pahole package installed there, and I can compile modules and zfs. I don't see any BTF stuff in the .config there also. So, I don't know what is really going on here, I should install pahole on arm64 systems as well? And should pahole not be included when you upgrade your system to 25.5.1 ?
  10. Thanks a lot for your help, Igor. That did not make the trick, as the available packages are still in the old form (docker.io instead of docker-ce for example. Nonetheless, I now have a working (but old) docker binary, which is enough for my use case. Now, I will try to build a more recent docker binary. The next problem to solve will be to get the NVMe to work. I'm sorry your F3 died.
  11. accordingly H618 do not have mic in hardware https://www.cnx-software.com/2023/07/03/orange-pi-zero-3-allwinner-h618-sbc-ships-with-up-to-4gb-ram/ hence, an option is to use a usb soundcard / dongle https://www.aliexpress.com/w/wholesale-usb-sound-card.html there are also those 'arduinoish' approaches e.g. to use a ADC module board e.g. https://www.ti.com/lit/ds/symlink/ads1110.pdf https://www.aliexpress.com/w/wholesale-ads1110.html https://www.instructables.com/Arduino-and-the-TI-ADS1110-16-bit-ADC/ but that you would need to hack the pin interfaces to use i2c etc. note it seemed ads1110 is a bit too slow for sound. alternatives are like stm32, which has built-in adc that can go to like 1-2.5 Msps, but you would need to hack the spi interface etc. the 'easiest / cheapest' way seemed to be generic 'usb sound cards'
  12. Has a fixed image been posted? Just upgraded to 25.5 from 25.2, so havent tested a new image download yet.
  13. probably best to specify location for any sales offer
  14. Last week
  15. @Nguyễn Tất Hùng If you want to use Armbian, you should start here: https://www.armbian.com/amlogic-s9xx-tv-box/ And specifically look at the link to the Status of TV Boxes on Armbian information.
  16. Improving access, flexibility, and CI integration for development boards, making it easier for developers to work with embedded hardware, no matter where they are. View the full article
  17. @ScoreABSM I don't think that is the reason? No, I haven't solved the Bluetooth issue. I have theories, but I still haven't cracked the nut. You are more than welcome to give it a whirl
  18. Nice Are you going to use apps that will need high fps? If so, comment about the performance. Does the touch function feel steady and reliable? (dragging windows without jumpiness, with the stylus) The app for keyboard emulation with touch screen is "matchbox", if you need it.
  19. @Igor, all just like to say that I installed Armbian_community_25.8.0-trunk.228_Orangepizero3_bookworm_current_6.12.30_minimal.imgArmbian_community_25.8.0-trunk.228_Orangepizero3_bookworm_current_6.12.30_minimal.img from the boards page https://www.armbian.com/orange-pi-zero-3/ apt update works 'out of the box', no PUBKEY errors thanks for the the updates @vtech, you may like to try the same for orange pi zero 2
  20. Hi, thank you for your comments, at least I learned about the SysRq sequence this way. I actually have no clue which process should send this sequence, an hardware issue of the RX line seems also unlikely to me (very short wire to the RS232-USB converter). The only additional observations: -it is a rare event, 24x7 system, most recent events: Jun 9th: at the end of a shutdown sequence Jun, 5th: no obviously related entries in syslog before it May, 28th: no obviously related entries in syslog before it May, 24th: at the end of a shutdown sequence May, 23rd: at the end of a shutdown sequence May 22nd: at the end of a shutdown sequence -it always occurs in pairs, timestamps separated by some µs, e.g. 16:50:49.191219 and 16:50:49.191355 Meanwhile on v25.5.1 for Banana Pi Pro running Armbian Linux 6.12.30-current-sunxi. I guess I will have to live with this effect, which is not harmful as long as the system continues to run. Greetings.
  21. Here are some:https://github.com/armbian/community/releases/
  22. I have the same problem, and for me it seems unrelated to kernel revisions. I have a whole bunch of Orange Pi Zeros, all running the same kernel and all with the same updated packages. However, the ones that run from old SD cards and have been updated from earlier releases, they reboot fine, while those that running from relatively recently flashed SD cards struggle and halt instead of reboot. Since this is super annoying, I wish to find out what's causing this, so I will do some diffing between the systems to see if I can find the culprit.
  23. Bumps dtschema from 2025.2 to 2025.6.1. Commits 18ac2d8 validator: Fix ordering issue with properties referencing another property 4dbacd6 tests: Add test for DTSchema.check_schema_refs() 2c5f057 schema: Rework instantiating DTSchema.validator 19c88b9 schemas: gpio-nexus-node: Fix schema $ref paths fb770c7 schema: Fix a false positive unevaluatedProperties/additionalProperties check b7f612c schemas: reset: Add '#reset-cells' into schema 7e3ef3e schemas: reset: Add descriptions from original text binding 53a2132 meta-schemas: nodes: Allow if-then-else directly in patternProperties objects 9d1305d schemas: PCI: Add standard PCIe WAKE# signal 49451a5 schemas: root-node: Add 'all-in-one' chassis-type Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
  24. Bumps oras from 0.2.33 to 0.2.37. Release notes Sourced from oras's releases. Oras Python v0.2.37 What's Changed Use correct credsStore/credHelpers binary by @rasmusfaber in oras-project/oras-py#212 Full Changelog: https://github.com/oras-project/oras-py/compare/0.2.36...0.2.37 Oras Python v0.2.36 What's Changed Fix authentication priority: AWS-native -> docker login -> credHelpers -> credsStore by @rasmusfaber in oras-project/oras-py#211 Full Changelog: https://github.com/oras-project/oras-py/compare/0.2.35...0.2.36 Oras Python v0.2.35 What's Changed fix: auth via ECR to be an extra by @tarilabs in oras-project/oras-py#208 Full Changelog: https://github.com/oras-project/oras-py/compare/0.2.34...0.2.35 Oras Python v0.2.34 What's Changed [tributors] contributors/update-2025-05-31 by @github-actions in oras-project/oras-py#203 Add support for Docker credsStore and credHelpers by @rasmusfaber in oras-project/oras-py#206 [tributors] contributors/update-2025-06-08 by @github-actions in oras-project/oras-py#207 Ecr auth support by @rasmusfaber in oras-project/oras-py#205 New Contributors @rasmusfaber made their first contribution in oras-project/oras-py#206 Full Changelog: https://github.com/oras-project/oras-py/compare/0.2.33...0.2.34 Changelog Sourced from oras's changelog. CHANGELOG This is a manually generated log to track changes to the repository for each release. Each section should include general headers such as Implemented enhancements and Merged pull requests. Critical items to know are: renamed commands deprecated / removed commands changed defaults backward incompatible changes (recipe file format? image file format?) migration guidance (how to convert images?) changed behaviour (recipe sections work differently) The versions coincide with releases on pip. Only major versions will be released as tags on Github. 0.0.x (0.0.x) Use the correct credsStore/credHelpers binary (0.2.37) Properly prioritize auth methods (0.2.36) fix 'authentication with ECR' to be an extra as intended (0.2.35) Add support for authentication with ECR registries (0.2.34) Add support for Docker credsStore and credHelpers fix 'get_manifest()' method with adding 'load_configs()' calling (0.2.33) fix 'Provider' method signature to allow custom CA-Bundles (0.2.32) initialize headers variable in do_request (0.2.31) Make reproducible targz without mimetype (0.2.30) don't include Content-Length header in upload_manifest (0.2.29) propagate the tls_verify parameter to auth backends (0.2.28) don't add an Authorization header is there is no token (0.2.27), closes issue 182 check for blob existence before uploading (0.2.26) fix get_tags for ECR when limit is None, closes issue 173 fix empty token for anon tokens to work, closes issue 167 retry on 500 (0.2.25) align provider config_path type annotations (0.2.24) add missing prefix property to auth backend (0.2.23) allow for filepaths to include : (0.2.22) release request (0.2.21) add missing basic auth data for request token function in token auth backend (0.2.2) re-enable chunked upload (0.2.1) refactor of auth to be provided by backend modules (0.2.0) bugfix maintain requests's verify valorization for all invocations, augment basic auth header to existing headers Allow generating a Subject from a pre-existing Manifest (0.1.30) add option to not refresh headers during the pushing flow, useful for push with basic auth (0.1.29) enable additionalProperties in schema validation (0.1.28) Introduce the option to not refresh headers when fetching manifests when pulling artifacts (0.1.27) To make it available for more OCI registries, the value of config used when manifest_config is not specified in client.push() has been changed from a pure empty string to {} (0.1.26) refactor tests using fixtures and rework pre-commit configuration (0.1.25) eliminate the additional subdirectory creation while pulling an image to a custom output directory (0.1.24) updating the exclude string in the pyproject.toml file to match the data type black expects patch fix for pulling artifacts by digest (0.1.23) patch fix to reject cookies as this could trigger registries into handling the lib as a web client ... (truncated) Commits 5d3c15d Use correct credsStore/credHelpers binary (#212) 385f138 Fix authentication priority: AWS-native -> docker login -> credHelpers -> cre... d296ffd fix: auth via ECR to be an extra (#208) 1d448f2 Ecr auth support (#205) dad7734 Automated deployment to update contributors 2025-06-08 (#207) 2a421e2 Add support for Docker credsStore and credHelpers (#206) b63ede0 Merge pull request #203 from oras-project/contributors/update-2025-05-31 6886229 Automated deployment to update contributors 2025-05-31 See full diff in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
  25. Bumps tj-actions/changed-files from 4140eb99d2cced9bfd78375c2088371853262f79 to d52d20fa3f981cb852b861fd8f55308b5fe29637. Changelog Sourced from tj-actions/changed-files's changelog. Changelog 46.0.5 - (2025-04-09) ⚙️ Miscellaneous Tasks deps: Bump yaml from 2.7.0 to 2.7.1 (#2520) (ed68ef8) - (dependabot[bot]) deps-dev: Bump typescript from 5.8.2 to 5.8.3 (#2516) (a7bc14b) - (dependabot[bot]) deps-dev: Bump @types/node from 22.13.11 to 22.14.0 (#2517) (3d751f6) - (dependabot[bot]) deps-dev: Bump eslint-plugin-prettier from 5.2.3 to 5.2.6 (#2519) (e2fda4e) - (dependabot[bot]) deps-dev: Bump ts-jest from 29.2.6 to 29.3.1 (#2518) (0bed1b1) - (dependabot[bot]) deps: Bump github/codeql-action from 3.28.12 to 3.28.15 (#2530) (6802458) - (dependabot[bot]) deps: Bump tj-actions/branch-names from 8.0.1 to 8.1.0 (#2521) (cf2e39e) - (dependabot[bot]) deps: Bump tj-actions/verify-changed-files from 20.0.1 to 20.0.4 (#2523) (6abeaa5) - (dependabot[bot]) ⬆️ Upgrades Upgraded to v46.0.4 (#2511) Co-authored-by: github-actions[bot] (6f67ee9) - (github-actions[bot]) 46.0.4 - (2025-04-03) 🐛 Bug Fixes Bug modified_keys and changed_key outputs not set when no changes detected (#2509) (6cb76d0) - (Tonye Jack) 📚 Documentation Update readme (#2508) (b74df86) - (Tonye Jack) ⬆️ Upgrades Upgraded to v46.0.3 (#2506) Co-authored-by: github-actions[bot] Co-authored-by: Tonye Jack jtonye@ymail.com (27ae6b3) - (github-actions[bot]) 46.0.3 - (2025-03-23) 🔄 Update Updated README.md (#2501) Co-authored-by: github-actions[bot] (41e0de5) - (github-actions[bot]) Updated README.md (#2499) Co-authored-by: github-actions[bot] (9457878) - (github-actions[bot]) 📚 Documentation ... (truncated) Commits d52d20f chore(deps-dev): bump @types/node from 22.15.26 to 24.0.1 (#2587) f1c0eb9 chore(deps-dev): bump eslint-plugin-prettier from 5.4.0 to 5.4.1 (#2578) 944a0f7 chore(deps-dev): bump eslint-plugin-jest from 28.13.0 to 28.13.3 (#2585) 3dbc1e1 Updated README.md (#2592) 7a7221b chore(deps): bump github/codeql-action from 3.28.18 to 3.29.0 (#2588) c260d49 feat: add any_added to outputs (#2567) b1ccff8 Updated README.md (#2591) a892f50 docs: update link to glob patterns (#2590) 5ca5422 chore(deps-dev): bump ts-jest from 29.3.4 to 29.4.0 (#2589) See full diff in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
  26. If you are on a relatively recent kernel, the kernel probably already has support, but the default DTB has it disabled. This is from a bookworm nightly build for a radxa zero 3 ~$ grep rknpu /usr/lib/modules/6.1.115-vendor-rk35xx/modules.builtin kernel/drivers/rknpu/rknpu.ko However, it's disabled in the DTB by default $ cat /sys/firmware/devicetree/base/npu@fde40000/status disabled For the board that I am using, the vendor publises a DTO source that enables it at https://github.com/radxa-pkg/radxa-overlays/blob/main/arch/arm64/boot/dts/rockchip/overlays/rk3568-npu-enable.dts Which works well with armbian-add-overlay. Though you may need to make a similar overlay for your DTB if it is different enough. Note that the NPU in the 3566 and 3568 are interoperable.
