I recently had to modify a device tree file for a different reason. I showed what I did (and how I did it) here: https://forum.armbian.com/topic/52118-hdmi-audio-and-analog-audio-do-not-work-on-opi5plus/?do=findComment&comment=224923 To summarize, I used the device-tree-compiler package (command line: dtc) to convert the device tree binary (.dtb) file to a device tree source (.dts) file. Then I edited the .dts file, then converted it back. The process won't show you all the variable names, but the resulting .dts is readable enough to likely see what and where you need to change... and even moreso if you have the original (pre-compiled) .dts file to compare it with. If you need to match variable names with specific numbers, they will likely be #defined in the #includes at the top of the original .dts file.
Orange Pi 5 6.12 images in website do not work
Werner replied to Fabricio Martínez Tamayo's topic in Orange Pi 5
Yes, current broke at some point. More up to date packages should be available via apt. In general the support for rk3588 in 6.12 (current as of today) is barely there but there won't be updates regarding that matter, bug fixes only due to its LTS nature. Better use vendor or edge. -
Great, svvolf! This fix boot problem on OPI Zero v1 (Armbian v25.8.1, Linux 6.12.43-current-sunxi) 😁 Thank you!
- 23 replies
- Orange Pi Zero
- Orange Pi Zero 2
(and 1 more)
Tagged with:
T'is one reason to prefer boards that take 12V power. and yes, barrel-connectors, but I can't think of any recent boards that use 5V and barrel connectors. NanoPi-M4 vs NanoPC-T4, with a WD Blue SN500, the T4 was stable. the M4 was not. yes, the M4 used the official power supply.
armbian-truncate-logs and PostgreSQL
Wytze van der Raay replied to Tim Makarios's topic in Software, Applications, Userspace
As far as I know, the permissions of /var/log/postgresql after a reboot are recreated from those on /var/log.hdd/postgresql. So if you modify those as well (remove the sticky bit), the workaround should be permanent. Thanks for highlighting this problem, I've encountered the very same issue, but didn't realize it was caused by this somewhat peculiar directory permission. So I just applied your workaround (plus my extension) and hope it will fix this once and for all. -
I think there are some userspace drivers needed as well. Armbian provides the kernel module only. Not exactly sure what's needed but I think the stuff is from here: https://github.com/airockchip/rknn-toolkit2/tree/master/rknpu2
I see. Well there is a similar topic, maybe this can give some clues: https://forum.armbian.com/topic/50228-i2s-audio-not-working-on-orange-pi-zero-2w-allwinner-h618-with-max98357a/
Orange Pi Zero 3 ili9486 TFT LCD (WaveShare 35a)
WDR_s replied to goodfvh _YT_'s topic in Allwinner sunxi
Hi goodfvh _YT_. I wanted to know if you are using Dupont wires? -
If someone interested on this tv box: I've managed to download original firmware image (update.zip) from backup partition. Also I cleaned it from malware (at least I think so) and packed as modified update.zip. Files are located here: https://drive.google.com/drive/folders/1etPmH8ZG4UtPHI3Vf1U9MUHl5_gK_s-E Further info available here (in Russian): https://4pda.to/forum/index.php?showtopic=1016510&view=findpost&p=139209499 -
Hello @Eks Ma, how are you? Unfortunately not. I gave up trying. The TV box is just sitting here at home.
Why does the system restart trigger at 3:30 every day?
SteeMan replied to lay's topic in Khadas EDGE2
Also note that if you are on a community build or anything that points to the "beta" armbian apt repository, you will get a new linux kernel image pushed out to you each day, which would then trigger the need for a reboot (depending on settings) for that new kernel to be run. -
laibsch replied to Giuseppe93's topic in NanoPi R4S
unfortunately, your board has no maintainer in Armbian, it is only supported by the community -
what version of OS are you guys running? are you possibly affected by the hardening of fancontrol in trixie?
After like a week of trying to make my tinkerboard rk3288 play videos I finally found the holy grail: https://users.armbian.com/jmcc/output/ Find the latest version and install that with all his dependencies, all the dependencies are in the debian archive: deb http://archive.debian.org/debian buster main contrib non-free deb http://archive.debian.org/debian buster-updates main contrib non-free deb http://archive.debian.org/debian buster-backports main contrib non-free deb http://archive.debian.org/debian-security buster/updates main contrib non-free deb [signed-by=/usr/share/keyrings/armbian.gpg] https://github.armbian.com/configng stable main deb http://apt.armbian.com buster main buster-utils buster-desktop I managed to play 4k hevc dolby atmos 5.1 movie streaming from my jellyfin server at my parents house using kodi-gbm and it worked flawlessly! I couldn't do the same with mpv yet. I hope this helps ppl with this ancient (2017) sbc.
I flashed same image to a SD card and tried to boot from it. Following is the result of `grep mmcblk1p2 /var/log/syslog` 2025-09-17T09:52:44.015489+00:00 rock-5-itx armbian-resize-filesystem[947]: ### [resize2fs] Trying to resize ext4 filesystem on /dev/mmcblk1p2: 2025-09-17T09:52:44.015493+00:00 rock-5-itx armbian-resize-filesystem[947]: Running 'resize2fs /dev/mmcblk1p2' now... 2025-09-17T09:52:44.015508+00:00 rock-5-itx armbian-resize-filesystem[947]: Filesystem at /dev/mmcblk1p2 is mounted on /; on-line resizing required 2025-09-17T09:52:44.021891+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Quota mode: none. 2025-09-17T09:52:44.021891+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): unmounting filesystem. 2025-09-17T09:52:44.021893+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Quota mode: none. I will try booting from a different medium and running `fsck mmcblk1p2` too.
read first How to build my own image or kernel?
pberki replied to Igor's topic in Advanced users - Development
Hi, In the documentation (https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-kernel-config) it says: "User provided kernel config: If the file userpatches/linux-$LINUXFAMILY-$BRANCH.config exists, it will be used instead of the default one from config." Is there a way to define only the desired changes to the kernel parameters? -
@SteeMan That is actually a good question, to which I do not have the answer. Here's a picture of the chip itself: I have not been able to find any information on that particular chip, so it may as well be nand...
Orange Pi H3 soc images doesn't have lpae enabled in kernel
laibsch replied to sea's topic in Allwinner sunxi
this can easily be answered with a quick web search or AI request for "disadvantage of LPAE on armhf". As expected, one of the drawbacks is increased use of memory when the benefit of larger addressable memory applies only to few installations and in a limited way. -
Certainly worth a look. It is also probably worth comparing the Armbian commit from when I last had it working until now, but it will need to be when I have a bit more time, and me remembering just when I first started seeing these issues.
Hi pcduino2user, glad you are finding it useful. Maybe CMA Buffer size needs to be lowered during the kernel, which actually appears to get ignore anyway once the board has fully booted and replaced with 96mb based on the reserve memory node within the A10 DTSI. This is definitely needed if trying to run a desktop although I wouldn't recommend running a desktop on the Pcduino2. There are still some minor issues that I would like to address in future but I don't have as much time as I used to. For example the pcduino2 is actually booting from the Pcduino1 DTS although this problem is more cosmetic than functional. Both the Pcduino1 and Pcduino2 share the same uboot defconfig file but the Pcduino2 has a USB2 VBUS pin defined within its DTS and physically connected on the PCB. This is normally pulled high by a resistor so does not cause any problems with USB power being enabled. The build framework allows us to configure the kernel but there must be a way to customize uboot more dynamically as well? Now certain Armbian board configuration files appear to contain configuration data for adjusting the dram speed as can be found in the cubieboard.csc so I wonder if a similar setup in the pcduino2 configuration file to override the default device tree property to use sun4i-a10-pcduino2.dts instead of sun4i-pcduino.dts. Given the closeness of hardware it does not seem worth creating a separate defconfig file. Ryzer
Hi @Nick A, the armbian in afiftyp board just see 2GB to, at least it was this way in 2024 when he sent me his boot log. My board is very similar to afiftyp board, except of a number near the QC sticker, that looks like a version number. afiftyp number is 2336 and the mine is 2333. The amout of memory chips is identical to (8 chips), but tha labels is a litle different, but I cant found the label meaning. I use your image since very old one, so I don't think it is about u-boot update, but I could try an older one. About Secure Boot, A patch that you give me solved it and it isn't a problem any more (thanks again for it). @afiftyp, if I'm wrong and you already solve your rom amount in armbian, please let us know and if you could, explain us what you did to solve it, thanks.
