Raspberry Pi 5 missing video decode hardware acceleration in chromium
geoW replied to otte's topic in Raspberry Pi
How to Change hardware configuration? Use /boot/firmware/config.txt to configure hardware settings. This is the official Raspberry Pi method. From https://www.armbian.com/rpi4b/ I assume same for your gpu settings. - Today
@sven-ola it works with official ubuntu image and with debian 13 image from romanrm, so this ssd is 100% works
hey i seem ho have same exact issues have you found any fix yet!
Armbian_24.11.2_Orangepi5_noble_current_6.12.0-kisak NPU driver version
usual user replied to thanh_tan's topic in Rockchip
From an OS's point of view, only a Mesa build with Teflon and Rocket driver support is needed (available since Mesa 25.3). Inferences can then be executed with ai-edge-litert. I have been experimenting with this for some time on all my devices equipped with Rockchip RK3588/RK3588s. -
First of all thanks to the people maintaining armbian for helios64. I recently upgraded (well I reinstalled) to trixie and everything mostly runs stable for me. However I have a problem with the 2.5GB adapter. It is connected to a 2.5GB switch and when for example running iperf3 I get proper results close to 2.5 GBit. So in general it seems to be running ok. I have a DLNA server (minidlna) running on that machine and when I stream from my TV (streaming via VLC from my laptop triggers the same problems) the network connection drops for a moment and works again after a few seconds (which you can guess is super annoying when watching something). I am not sure what exactly is triggering this. most of the time the network is super stable but during streaming I get hickups. This is what my kernel log spits out when this is happending: ``` Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event TRB for slot 4 ep 3 with no TDs queued Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event TRB for slot 4 ep 3 with no TDs queued Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event TRB for slot 4 ep 3 with no TDs queued Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event TRB for slot 4 ep 3 with no TDs queued Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f10 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f20 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f30 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f40 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f50 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f60 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f70 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f80 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8f90 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:54 hermann-walter kernel: xhci-hcd xhci-hcd.0.auto: Event dma 0x00000000053f8fa0 for ep 3 status 1 not part of TD at 00000000053f8ed0 - 00000000053f8ed0 Apr 09 17:45:59 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: NETDEV WATCHDOG: CPU: 0: transmit queue 0 timed out 5152 ms Apr 09 17:45:59 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx timeout Apr 09 17:46:00 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx status -2 Apr 09 17:46:00 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx status -2 Apr 09 17:46:00 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx status -2 Apr 09 17:46:00 hermann-walter kernel: r8152 2-1.4:1.0 enx646266d00873: Tx status -2 Apr 09 17:46:02 hermann-walter kernel: r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd ``` the usb related messages are not always there but the r8152 related messages are always there. I found a similar problem here: https://github.com/openwrt/openwrt/issues/22130 I tried replacing the firmware but that didn't help and I later found out that the helios64 uses a different firmware so that explains why it didn't help: ``` Apr 10 05:48:30 hermann-walter kernel: r8152 2-1.4:1.0: Loaded FW: rtl_nic/rtl8156a-2.fw, sha256: 7b50f4a307bde7b3f384935537c4d9705457fa42613eb0003ffbc4e19461a1e0 Apr 10 05:48:30 hermann-walter kernel: r8152 2-1.4:1.0: Loaded FW: rtl_nic/rtl8156a-2.fw, sha256: 7b50f4a307bde7b3f384935537c4d9705457fa42613eb0003ffbc4e19461a1e0 ``` does anybody know what is going on? I am quite sure that the problem wasn't there before the upgrade (but I might be mistaken because I only started observing the helios64 again after the upgrade. also it seems to be related to the amount of network traffic going on. i.e. lower bitrate streams seem to not trigger the problem). Streaming via the 1GBit NIC is working fine.
3D Graphics Acceleration on T95N (A98X Jackbox) - RK3229 with 2GB RAM / 16GB eMMC - Educational Project for Schools Hi, I’m working on a project using a specific TV Box model (A98X Jackbox) to repurpose these boxes as low-cost computers for schools. The goal is to provide students with a platform to use AI tools and basic productivity, but I need better browser rendering. Hardware Specs (Confirmed via board teardown and logs): Board ID: T95N-RK3229_512X4_V1.5 CPU: Rockchip RK3229 RAM: 2GB (Confirmed via free -m) Storage: 16GB eMMC (SanDisk SDIN9DS2-16G) OS: Armbian 21.08.8 Bullseye (Legacy Kernel 4.4.194-rk322x) What I have done so far: Installed the Minimal image and set up LXDE with LightDM. Optimized the system (Governor set to performance, swappiness set to 10). Ran glxinfo -B which confirms it's currently using llvmpipe (Accelerated: no). Tried searching for Mali drivers via apt, but armbian-config is not available in the repositories for this specific build/architecture. Verified Wi-Fi functionality (working fine with LED config 2 via rk322x-config). The system is stable and surprisingly fast thanks to the 2GB RAM, but the CPU is struggling with 100% spikes during browser rendering (Epiphany WebKit) because it lacks GPU acceleration. Question: Is there a way to enable Mali-400 MP2 drivers for X11 on this Legacy 4.4 kernel? Are there any specific packages, blobs, or workarounds to get hardware acceleration working and replace llvmpipe? I’m available to run any tests or provide further logs if needed. Thanks for this amazing project!
Hi, First of all i'd like to thanks thanks all of you for your job or questions that help me to rescue from trash rk3318 based devices. I recover from a friend a X88 pro 10 (4G/128G), witch is a really chip old android-box. I looking for making a media center running kodi and and minimal web browser for unsupported kodi streaming services. I successfully install armbian_community trunk (Rk3318-box_noble_current_6.xx.xx_xfce_desktop.img.xz) using multitool. _ _ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, | |___| |__/ v26.2 rolling for RK3318 Box running Armbian Linux 6.18.21-current-rockchip64 Packages: Ubuntu stable (noble) Support: for advanced users (rolling release) IPv4: (LAN) 192.168.xxx.xxx (WAN) xxx.xxx.xxx.xxx Performance: Load: 2% Uptime: 1d 22h 21m Memory usage: 14% of 3.87G CPU temp: 45°C Usage of /: 6% of 114G RX today: 1 MiB Tips: Becoming a sponsor? https://github.com/sponsors/armbian I run rk3318-config and choose this config: RK3318 (max 1.1Ghz...) no selection on eMMC additional speed options rk3318-box-led-conf2 X88_PR_B_boards Reboot and Install kodi and codec with : sudo apt install ffmpeg mpv kodi kodi-repository-kodi --install-recommends I have some issues : xfce menu is quite slow when I navigate for choosing app. chromium is very very slow and video on youtube are too lagy when decoding Kodi works on xfce but can't decode video, i try on standalone (choose on connection window), still can't decode. I looking on this post without success and this one, same issue. If anyone have a idea to help me to save this device and make me able to use it as a media center. Thanks
Wayland 1.25 refreshes its documentation with three new chapters covering Wayland XML specification, content model updates, and color management design. View the full article
hey hows it going? is there someone who could point me to the right direction on if my device supports armbian and where i could get the files i need to flash my emmc. ive had no luck with pre built rasp pi i get the errors with firmware and it wont let me flash it. kind regrads Daniel
I have seen some kernel errors w.r.t. trim on Silicon Power 16GB SD-card, was in ROCK3A. But no other errors. Kernel is unspecified, although I might be able to figure out which/what, you can even search this forum, then you know yourself. This errors do not occur on a RPi4 v1.1 (with RPL OS and kernel). So if you want to know, dig more into logs, doe specialistic blocklevel error checking. In general: welcome to SD-card magic!. See also this:
Kernel not updating in image with armbian build
eselarm replied to KV1's topic in Armbian Project Administration
Why repair the filesystem first while you anyway overwrite the whole storage device then? /dev/sdb1 suggests an USB SD-card adaptor is used. Both the adaptor, which translates USB protocol into MMC commands, and the SD-card itself, which also does internal block managing, can mess up the filesystem. Not as long as this is plugged into the computer where the imager (or dd) is running, but once removed and put into the SBC, power is lost and re-applied. The USB + SD-card hardware (and also OS driver in the computer) might have flaws in its implementation. It could easily be that SD-card signals 'ready' to OS, so you then take out USB + SD-card, but that actually not all is committed to the actual flash and still some is in buffers or the SD-card is still doing wear-leveling and doesn't do that in a correct way. And worse, if fake sized counterfeit, the firmware might be busy doing its 'magic tricks' to fake hundreds of GB size while only 8 or 32 GB is actual flash chip. So unfortunately, even if using a verify step in writing an image, the actual content on the SD-card might be different from the image file once the SD-card is put in the SBC. I remember such a case on this forum where someone did manual block-level compare of storage device and image. I also have had such issue at least once. It is the situation where you just re-do / re-write again without knowing what is wrong. And/or use other SD-card, other USB-adaptor, other computer, etc. To prevent such issues, I tend to use (the) SBC itself to write SD-cards. My RPI4 runs from USB-SSD, so SD-card slot is free. I trust RPL HW more than various USB SD-card adaptors. Earlier test I mentioned using the the Armbian-imager was on NanoPi-R6C running from eMMC+NVME, so same story, free SD-card slot. It ran Armbian Trixie KDE6 and 7.0-rc rockchip64 kernel. I was also forced to more or less, because on my Tumbleweed N100 box the Armbian Imager only stayed white (some EGL error). That was with x86-64 AppImage. I thought it would be better to install from a .deb hence walked to my powered-on ARM64 running Debian. Anyway I do normally not use images. I would rather use ddrescue (enable mapfile option) to check and make sure image is same as on storage device. That helped also in the past for 4TB HDD's (when risk of bit-rot). It is CLI based and allows to re-do check after power-cycle. -
Booting armbian manually from u-boot shell over UART
Thành replied to user03's topic in Amlogic CPU Boxes
Could you please send me the DTB file that your motherboard displays and only receives internet signals? I have a motherboard that's similar to that one. -
It is not working with this patch because offcially AIC8800 is not supported in kernel > 7.0-rc6 plus in my image Wifi was initially disabled With new image it is better: I made a small fix to make it running with some commands as root: ``` # unzip AIC_FIX.zip # mkdir -p /lib/modules/$(uname -r)/kernel/drivers/net/wireless/aic8800 # cp aic_btusb.ko aic_load_fw.ko aic8800_fdrv.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/aic8800/ # depmod -a # cat /etc/modules-load.d/aic8800.conf aic_load_fw aic8800_fdrv aic_btusb # cp -r aic8800_fw /lib/firmware/ # cp -pr aic8800_fw/USB/aic8800D80/ /lib/firmware/ # modprobe aic_load_fw # modprobe aic8800_fdrv # modprobe aic_btusb # lsmod |grep -i aic aic_btusb 57344 0 aic8800_fdrv 626688 0 cfg80211 1200128 1 aic8800_fdrv aic_load_fw 86016 1 aic8800_fdrv ``` Please also remember as it is experimental and all you do it is on your own risk HDMI is not working and we need some code first, I guess for this part: CONFIG_PHY_ROCKCHIP_INNO_HDMI_QP
Ok, maybe I am not able to boot because this image is not for the stock PocketCHIP but for one which requires a custom breakout board: https://github.com/armbian/build/pull/7647 Maybe I could have found that out sooner if there was a device page for this custom PocketCHIP in the community supported devices page at ttps://www.armbian.com/community/. Who/how is supposed to create it? The board maintainer? How is one supposed to do that? There is no mention in the Board Maintainers Procedures and Guidelines. I haven't anything on the armbian github repositories about the boards information on this page. It would be important to have the device page, especially when the image was created for custom developed PCBs. Only after some digging and finding the PR where the device was added, I was able to figure out why I may not be able to boot the pocketchip-sd armbian image.
OK I see, now I remember, HAOS aarch64 has been there for download for a long time, I even recommended it to some one on another forum who also only saw the Intel VM, but as I indicated, is a bit hidden on github: https://github.com/home-assistant/operating-system/releases/ and direct latest link: https://github.com/home-assistant/operating-system/releases/download/17.2/haos_generic-aarch64-17.2.img.xz I personally don't want the Proxmox stuff indicated by Markus, I just use the standard packages available In Debian (or Opensuse) for years, on both Intel and Arm. Like indicated install virt-manager. It is manual install, but at least then more control. I used/use a mix of LVM based block devices and also just raw images (like unxz the one referenced). I see on RPi4 I have the HAOS VM configured with 2 vCPUs and 1GB RAM. On RK3588, so OPi5+, you will need CPU pinning if you use the vendor kernel (6.1) as it does not support mixing big and little (Cortex-A76 and Cortex-A55). Or use just 1 vCPU for the VM, then de-facto no mixing. Mixing is no problem with mainline based kernel, so then you can just use 8 vCPU's if you want. I currently have my NanoPi-R6C running with kernel 6.19.10+deb14-arm64-16k (from Debian sid) and works fine with VM's and all 8 cores.
networking in bpi-m5 with new 26.03.1 release.
SteeMan replied to gene1934's topic in Software, Applications, Userspace
As a moderator having watched this thread, I'm going to close it down, as I don't think anything else productive will be said at this point. However I do want to thank both @bedna and @eselarm for their time and effort to help. Armbian appreciates all the volunteers who make these forums possible. -
I have tested the latest build (26.2.0-trunk.668) and found that USB 3.0 is still not operational. Has anyone been able to get this working?
