  2. @djoness My build uses the miniarch patches. https://github.com/NickAlilovic/build/releases/tag/20250306 Here's a direct link to X96q ddr3 server image. https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz
  3. Official development for inclusion in upstream are carried out by working on the project's main branch. That's exactly what this pull request branch does by tracking the project's master tree. Applying commits to anything else is backporting. Backporting is possible, but you will have to deal with the consequences yourself that arise from your outdated versions lacking the functions required for your backport, and you may need to backport those as well. Since this project is a user program and not a framework with libraries that other programs depend on, it is solely the user who has to deal with it as a dependency in its use. At first, I also tried to use the sources of the current release version as a base, but since the commits couldn't be applied without errors, I simply built the current master branch. For the FFMPEG framework, this is already a whole different ballgame. There are many programs, which mpv is just one, that depend on the libraries and need to be rebuilt accordingly in case of an upgrade. Since my chosen distribution recently released ffmpeg 8.0 and thus made all dependent programs available accordingly, I just had to rebuild the ffmpeg package with the v4l2request support commits and put that in place. And since the commits could be applied to the current release sources without any errors, I didn't even need to switch to the master branch.
  4. @qwerty keyboard here are some links that will help you. Find your Dram settings https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/#findComment-218660 Find boot.bin and extract dts. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/#findComment-187672 Uboot defconfig. I have two x96q builds with ddr3. https://github.com/NickAlilovic/build/blob/v20250306/patch/u-boot/u-boot-h616/151-add-x96-q-ddr3-defconfig.patch Or https://github.com/NickAlilovic/build/blob/v20250306/patch/u-boot/u-boot-h616/163-add-x96-q-ddr3-v5.1-defconfig.patch You can edit the patch and enter the new values. if you need to add a new line in the defconfig patch then add a + infront of the line. Also increase @@ -0,0 +1,39 @@ to @@ -0,0 +1,40 @@. Download and compile my build: git clone https://github.com/NickAlilovic/build.git --branch v20250306 cd build ./compile.sh choose "Do not change kernel configuration" choose "Show CSC/WIP/EOS/TVB" choose "I understand and agree" choose "X96Q DDR3” or “X96Q DDR3 v5.1” choose "edge" rest is up to you.
  5. As I mentioned before, I am a Newby and I am able to use the Terminal. But I don’t know, what to do to remove knotes.
  6. Today
  7. What do you mean by "normal" and WiFi direct?
  8. Orange PI has very good hardware (better than RPI) but bad support of software from factory devellopers. Raspberry PI 5 is a bit slower but we have more support and always new versions. I have both.
  9. Hi All, I'm struggling with my Orange PI 5 Plus and various Armbian Flavors for 3 days. My Preferred DE, Armbian_25.8.1_Orangepi5-plus_noble_vendor_6.1.115_kde-neon_desktop, after all setup on second boot... failed msg: wait until boot finishes... XFCE, Sound does not work over HDMI. Finally, Armbian_25.8.1_Orangepi5-plus_trixie_vendor_6.1.115_cinnamon_desktop, is doing well. Except for, I'm missing start button. If I want Firefox, I have to open it via cmd If I want to capture screen... I dont know even the name to call via cmd... See my Phone shot https://drive.google.com/file/d/1d6K4i_yshHCrKvXR-13VFkpWzPKx8GaA/view?usp=sharing Could somebody tell me what is wrong? Thanks,
  10. @Maurizio Finesso Try editing on a linux machine instead of windows. I've seen some windows machines not be able to read the boot partition
  11. Yesterday
  12. Please open the case and post images of your board so we can see what Ethernet chip you have.
  13. In this case ethernet chip is realtek so it should be supported by armbian kernel? So problem is to find or make a modern DTS for this board?
  14. This site deals with Armbian Linux not android. You should direct your question about restoring Android to a more appropriate forum
  15. not recommended for rockchip socs since it cannot handle the rather high baud rate of 1.5Mbaud. Use FT232, CH340 or CP2104 instead.
  16. Collabora’s long-term leadership in KernelCI has delivered a completely revamped architecture, new tooling, stronger infrastructure, and deeper integrations—modernizing the entire ecosystem and enabling reliable, scalable upstream kernel testing. View the full article
  17. Hello all, Ok, I'm going to comment on my own question here... I just now installed the Armbian 25.8.0 6.18.0 RC5 xfce version. It's not yet on the nvme drive but, it's significant faster than the 25.5.1 version. Now HD video works on the 5b+. It needs 2 seconds to stabilize but than it is perfectly fine to watch. I use Firefox as my browser. So thanks to the team! Ernst-Jan
  18. Hi all, I would like to ask support for the board EMB-3531. I'm having problem with booting this board from SD card. Here are some informations about this board. I hope that someone can help me with it. Thank you so much! I try to erase the emmc and flash the MiniLoaderAll.bin but it doesn't help. Or i don't have a correct image with armbian for this board. https://my.kos.org.cn:5154/rockchip/EMB3531/emb3531.pdf
  19. Try from here: https://fi.mirror.armbian.de/incoming/igorpecovnik/ (this is going to be next release - first test build).
  20. Your best bet is to compile your own image. It's super easy: "git clone https://github.com/armbian/build.git;cd build;./compile.sh" https://docs.armbian.com/Developer-Guide_Building-with-Docker/ https://docs.armbian.com/Developer-Guide_Build-Preparation/ https://www.youtube.com/watch?v=kQcEFsXEJEE
  21. I hope this helps... For the TX3 Mini, I used the distributions listed on https://www.armbian.com/amlogic-s9xx-tv-box/. Here's what I did: * Create a bootable image using Rufus (following the instructions). * Once the image was created, I went to the SD card's storage drive on a PC and made the following changes: * In the root directory of the SD card, I copied the file u-boot-s905x-s912 and pasted it as u-boot.ext. * In extlinux\extlinux.conf, on line 4, I changed it to "fdt /dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb". * I ejected the SD card, inserted it into the TX3 Mini, and turned it on. If it doesn't work, try a different distribution.
  22. Last week
  23. @laibsch https://u-boot.org/ edit: as I said earlier, it would be better to switch to upstream to get rid of patches and get some nice bugfixes in the process, but I assume this thing is mostly abandoned. A bunch of my containers no longer offer ARM32 support. Home Assistant too at the end of this year.
  24. @Henrik Larsson Did you end up changing anything or is this with the default configuration? Are you still using kernel 6.12? Have you tried build with a 6.16 edge based image yet?
  25. Made some progress. after installing Armbian_25.8.1_Odroidxu4_noble_current_6.6.102 to eMMC ran armbian-upgrade Installed xubuntu-desktop or xubuntu-desktop-minimal package reboot now i'm getting the greeter screen. after login, I entered xfce desktop. functions ok could only install firefox via snap. installed firefox via snap ran firefox to view a video on youtube. audio is not working. install pulseaudio reboot system audio still not working when viewing a youtube video any suggestions?
  26. There are no other images available at the moment. Regarding this, there is some initial but incomplete work in progress here: https://github.com/armbian/build/pull/8831 We can’t merge it in its current state, as it still requires a significant amount of additional work and refinement. Unfortunately, this means there isn’t a quick solution right now, so we’ll need to wait until the implementation is completed and validated.
  27. Apparently the key needs to go to `/etc/apt/trusted.gpg.d/armbian.gpg` too...
  28. hello i have updated with wrong firmware throw usb c nothing happens when flashing with USB_Burning_Tool or booting from sd card this box has no recovery button only on off inside earsphone
  29. The 6.18.0-rc5 kernel doesn't require any patches, just have to been build with DRM_ACCEL_ROCKET.
