  2. Nice work, Armbian support for RK3318/RK3328 boxes makes these cheap devices so much more useful.
  3. @djurny Sorry for the super late response. Here the answers on your questions: ls -Failh /dev/rtc* 457 lrwxrwxrwx 1 root root 4 Mar 7 01:56 /dev/rtc -> rtc0 107 crw------- 1 root root 253, 0 Mar 7 01:56 /dev/rtc0 542 crw------- 1 root root 253, 1 Mar 7 01:56 /dev/rtc1 ls -Failh /sys/class/rtc/ total 0 3926 drwxr-xr-x 2 root root 0 Jan 1 1970 ./ 10 drwxr-xr-x 63 root root 0 Jan 1 1970 ../ 8295 lrwxrwxrwx 1 root root 0 Jan 1 1970 rtc0 -> ../../devices/platform/soc/1f00000.rtc/rtc/rtc0/ 21463 lrwxrwxrwx 1 root root 0 Sep 3 23:18 rtc1 -> ../../devices/platform/soc/1c2ac00.i2c/i2c-0/0-0068/rtc/rtc1/ egrep -- . /sys/class/rtc/*/name /sys/class/rtc/rtc0/name:sun6i-rtc 1f00000.rtc /sys/class/rtc/rtc1/name:rtc-ds1307 0-0068 dmesg | egrep -i -- 'rtc' [ 1.042165] sun6i-rtc 1f00000.rtc: registered as rtc0 [ 1.042235] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4) [ 1.774229] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 1.776966] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 19.347508] rtc-ds1307 0-0068: registered as rtc1 sudo hwclock --rtc=/dev/rtc0 # per default this is the H2+ built-in RTC 2025-09-03 23:32:07.935209+10:00 ==> date set to Australia (Tasmania) sudo hwclock --rtc=/dev/rtc1 # per default this is going to be the I2C RTC 2000-01-02 15:51:14.147878+11:00 ==> ?????????? So, I clearly don't understand the system. What do I want? Just the right time when connected to a wireless network. (If not available, my system switches to being an Access Point) If my system is acting as an Access Point, the date and time needs to be correct to, that's why I thought I need an RTC module. If not needed, how do I get the right time when my system operates as an Access Point. Thanks for helping
  4. Hey there. Thanks for the detailed tutorial. I tried following it to install Armbian Trixie minimal on my Raspberry Pi 5's nVME (I'm on a headless setup with SSH access). The SD card that boots and runs the system so far is also an Armbian Trixie minimal installation. Apparently nobody has confirmed the instructions to work for that device / setup in this thread yet. So far I also have failed. After following through all steps my device wouldn't connect via ethernet (the LEDs didn't even blink). For simplifying things and rule out a source for possible mistakes, I then repeated the whole process without encrypting the drive, again without much success. Here's what I suspect to be the problem: The Armbian minimal image for the Raspberry family comes already with two partitions: a boot partition with a number of .dtb files for each device of the Raspberry family a "root" partition with all other files Device Boot Start End Sectors Size Id Type /dev/loop0p1 8192 532479 524288 256M b W95 FAT32 /dev/loop0p2 532480 3088383 2555904 1.2G 83 Linux I suspect it to boot in a different way than the image in the example, which seems to directily have all the files which I find in my second partition of the image. So, what I tried was to just create two partitions, mimicing the ones on the Image: Device Boot Start End Sectors Size Id Type /dev/nvme0n1p1 8192 532479 524288 256M b W95 FAT32 /dev/nvme0n1p2 532480 3907029167 3906496688 1.8T 83 Linux I would then just copy the contents of each partition respectively. But even that wouldn't boot the way it did with the SD card. Of course I could just use dd to copy the image to the 2TB nVME but that would take forever (20 h aprox.) and it wouldn't result in an encrypted system. My questions are: Is it even possible to use the way of copying boot files and contents in this tutorial to achieve a bootable nVME? If the image for the Raspi family relies on its own boot partition will I ever be able to use it for decrypting an encrypted drive before booting from it at all? Can I use it for both, booting the device and decrypting the drive, or would that be principally impossible? I'll be happy for any help for making it work or hint if the described procedure cannot work for my setup. Tonight I'll also join an install party and might have the opportunity to plug a screen to my Raspi and see if it gives hints during the boot sequence. EDIT: I think I understand now that this script is probably only for SD cards …
  5. @Nick AHow to use your code repository(https://github.com/NickAlilovic/build) to add a 1.5GB RAM patch.
  6. Here it is: https://paste.armbian.com/ququgojasu
  7. Hi again, It took some time but finally I was able to take a look at it myself. It seems to me that the original kernel patch from @brentr is still a working solution as the affected kernel code didn't change in the current kernel. So by applying the original patch, 10mpbs Ethernet started working again on my Rockpi S. I'm not able I created PR #8575 - Fixes regression of failing 10Mbit built-in Ethernet in Rockpi S to add the patch again. I hope, that's ok as I'm lacking experience in this field so please apologize if I missed something, I just want to help and improve 🙂 Cheers,
  8. Thank you all, I appreciate your patience! 🙏 I'm not sure on how deep I should go here. I started to learn about the process to address the problem that 10mpbs ethernet not is not working on my Rockpi S and I now know enough to deal with this problem. So my feeling is to not go further but focus on the functional problem to solve it 😉 Thanks again!
  9. @SteeMani also did some commands prompted by chatgpt since it said it was manufactored by allwinner also related to cortex-a53, aida64 said it too, so i doubt that mine are using a allwinner h313 chip
  10. Collabora is headed to Amsterdam. Meet us at Booth A63 in Hall 14 as we showcase GStreamer Analytics combined with ML, hardware-accelerated video decoding in Dante Studio using GStreamer, remote rendering for standalone XR, and more! View the full article
  11. Context of the TV boxes section might be helpful, especially in the sticky thread re their status in Armbian.
  12. Hi! @jwalds did yo mange to make hw decoding work with cedrus? (Note: you initially wrote cedar_ve, that's a different driver) I'm fighting with a nanopi duo2. If it works at your end I'd like to know your setup kernel version armbianEnv.txt whatelse has been installed, how could you please provide your dts / dto ? T.
  13. Hi again! Quick update after i wrote that below. I found something very promising here https://codesandbox.io/p/github/NathanJohnNJ/BananaPi-Camcorder/master This is a different approach. Behind the scenes the cedar_ve driver gets used which also supports encoding accel. I think I'll give it a try but that may take some time ... (btw. this is where some confusion exists, at several places - there are two drivers: cedrus aka. sunxi-cedrus and cedar_ve) -------------------------------------------------------------------------------- Im not using X11, i am using direct frambebuffer. But i'm quite sure the output is not the root cause as output to null also doesnt work So for testing there is no need for SPI LCD ffmpeg -hwaccel drm -i Big_Buck_Bunny_720_10s_10MB.mp4 -f null - @robertoj Maybe you can test this above and watch the framerate. if that achieves the 30fps run again with trace ffmpeg -v trace -hwaccel drm -i Big_Buck_Bunny_720_10s_10MB.mp4 -f null - and provide me the console output? also tested again mpv just with the input file and debug output (but this time not the specific v4l request thread) mpv Big_Buck_Bunny_720_10s_10MB.mp4 --msg-level=vd=v,vo=v,vo/gpu/vaapi-egl=trace ... ... [vd] No hardware decoding requested. [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vd] DR failed - disabling. [vd] Using software decoding. [vd] Decoder format: 1280x720 yuv420p auto/auto/auto/auto/auto CL=mpeg2/4/h264 of course tested different parmeters but mpv always falls back to soft. mpv Big_Buck_Bunny_720_10s_10MB.mp4 --msg-level=vd=v,vo=v,vo/gpu/vaapi-egl=trace --no-config --hwdec=yes [vd] Trying hardware decoding via h264_v4l2m2m-v4l2m2m-copy. [vd] Using underlying hw-decoder 'h264_v4l2m2m' [ffmpeg/video] h264_v4l2m2m: Could not find a valid device [ffmpeg/video] h264_v4l2m2m: can't configure decoder Could not open codec.
  14. That sounds very interesting. Where can I read more about this? @m11k I hope you are still active in this forum.
  15. Yesterday
  16. For debian problems, do what I do: Get the cheapest raspberry Recreate the problem Ask the question in the raspberry forum Apply solution to Armbian XD
  17. Oh, sorry, I didn't notice the non-existent 6 and read it as Helios64. Of course, my description of the boot method is not limited to Rockchip devices; it works on all for which a mainline U-Boot is available. I have used it on iMX6, LX2160A and S922X devices, but my remaining devices are all based on Rockchip. The solutions are too varied to present a turnkey solution here. However, I am sure that only a corresponding configuration for implementation is required to achieve the desired behavior, but for that, the U-Boot documentation must be consulted to decide which solution should be chosen.
  18. If tester is not available, I'd try powering failing ports with their respective cables but feeding them from pins powering other ports (eg with wires from some molex cable, just need to be careful with polarity and shortcuts) and then powering working ports from pins on the board feeding failing ports - to exclude failure of the power rail feeding these ports on the board. If cables are faulty, I'd check them for electrical connections and if they are ok, would replace capacitors.
  19. What I like to do in such a case is link to archive.org. some spam got posted to this thread which I removed, so I felt like I might as well add an answer at the same time
  20. fair enough, no idea where i would get the right android image from for my unknown box so I guess I am stuffed putting Armbian on my box. never mind, will repurpose an old laptop when corelec updates for the s905x2 stop thanks for the help
  21. probably time for the serial console my suspicion tells me that it will be hard to get proper logs otherwise my suspicion is that some umounts does not come back. <- try to unmount everything you can before the reboot and see if that helps.
  22. This is great. Apparently mine didnt persist after reboot either, yours seems to be permanent and working even better. Thanks!
  23. spendist is the maintainer of the Nanopi Neo. Maybe he has something to say. Did you try another kernel? Another OS?
  24. @dale it seems like vfd-convert has not worked well. Perhaps because of some mix between script version and the template files version. Whatsoever, I've looked closer at the patch link you previously posted, this is the older pre-review dt-bindings syntax. You should be go to start with something like: /dts-v1/; /plugin/; #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/leds/common.h> &{/} { display_client: spi { #address-cells = <1>; #size-cells = <0>; compatible = "spi-gpio"; sck-gpios = <&gpio 7 GPIO_ACTIVE_HIGH>; mosi-gpios = <&gpio 2 GPIO_ACTIVE_HIGH>; cs-gpios = <&gpio 12 GPIO_ACTIVE_LOW>; num-chipselects = <1>; display@0 { compatible = "fdhisi,fd628"; reg = <0x0>; spi-3wire; spi-lsb-first; spi-rx-delay-us = <1>; spi-max-frequency = <500000>; titanmec,digits = [00 01 02 03]; titanmec,segment-mapping = [03 01 02 06 04 05 00]; #address-cells = <2>; #size-cells = <0>; led@4,0 { reg = <4 0>; function = LED_FUNCTION_ALARM; }; led@4,1 { reg = <4 1>; function = LED_FUNCTION_USB; }; led@4,2 { reg = <4 2>; function = "play"; }; led@4,3 { reg = <4 3>; function = "pause"; }; led@4,4 { reg = <4 4>; function = "colon"; }; led@4,5 { reg = <4 5>; function = LED_FUNCTION_LAN; }; led@4,6 { reg = <4 6>; function = LED_FUNCTION_WLAN; }; }; }; }; Note that I haven't tested it, just made it from some copy-paste. If it doesn't work, even partially, you would most likely need to replace &gpio with the right reference to the gpio controller wired to the display.
  25. Hello, I am new to arm board, I had this android tv stick called S moon mx10 5G, it have rk322x cpu, 2GB Ram, and ap6330 wifi chip. I tried armbian on this device but wifi chip was not detected, I tried using "rockchip-rk3318-box-wlan-ap6330.dtbo" as user_overlays, but still not working, could anyone tell me how to make this wifi chip working on rk322x armbian?. I attached some files for information: dmesg.txt s_moon_mx10_5g.dts
  26. Hey Guys, I know this post is old but I have some questions. I was following @Jaybyrd's instructions and I have a question pertaining to the Plugin USB-C to the power on the device "I am assuming that is on The OPi5 device." Am I supposed to plug in something else? Because it says to open a terminal "what terminal? On what device?" Thank you for your time, Michael
  27. I wouldn't be so categorical - I have rock pi 4b, which never saw android or any os other than armbian, which has same thing- two boot devices on emmc. Since it doesn't bother me, I didn't investigate further.
