@kimo Can you post your uart data?
I tried but failed because I didn't understand at first, but now I understand part of it, and my TV box is malfunctioning. The problem is that when I plug in the power cord with the adapter, no lights or anything come on, but when I plug in the USB cable near the LAN port, it starts up normally (because I initially followed method 4.2. Full install to NAND / eMMC). Now I've flashed the Android firmware and it's working, but the error is as I described above. So, is the power IC dead or is the problem somewhere else?
Nice work! I saw those messages but couldn't download it Can you tell me how you built it? or could you upload it again to filebin.net if possible.. I need the image too
How you can help test upcoming Armbian 26.05 images?
Werner replied to Igor's topic in Advanced users - Development
I have sent a new pr. basically you do something like this: code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } ./compile.sh BOARD=orangepioneplus BRANCH=edge kernel-config This will spawn a kernel menuconfig where you can modify the kernel config. This menu also takes all necessary dependencies into account. Once everything is done the kernel config file in config/kernel is modified. If you use a tool like vscode this will automatically visualize. If you manually change the kernel config file and want to check if your settings are persistent to rewriting you can use the code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } rewrite-kernel-config command similar to the one above. -
Armbian 26.05.0 Noble KDE-Plasma (Kernel: 7.1.0-rc7-bleedingedge-rockchip64) + PanVk - Mesa 26.2.0-devel (git-a0859b31b0) + Box64 arm64 v0.4.3 e694f2ca8 (https://ryanfortner.github.io/box64-debs/) + wine-11.9-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/) + DXVK-stripped v2.7.1 ~30fps@1080p Assassin's Creed: Director's Cut Edition -
You was right, i entered wrong name in /boot/armbianEnv.txt now it is: verbosity=7 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=... rootfstype=ext4 overlays=orangepi-5-ap6275p usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u But wifi still not working I also recorded successful launch of Joshua-Riek ubuntu Both with dtb files loading log Armbian Working FDT set to 12000000 398 bytes read in 56 ms (6.8 KiB/s) Applying kernel provided DT overlay rockchip-rk3588-orangepi-5-ap6275p.dtbo Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Ubuntu Joshua-Riek Retrieving file: /boot/initrd.img-6.1.0-1025-rockchip 16754764 bytes read in 1362 ms (11.7 MiB/s) Retrieving file: /boot/vmlinuz-6.1.0-1025-rockchip 53682688 bytes read in 4334 ms (11.8 MiB/s) append: root=UUID=... rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory Retrieving file: /lib/firmware/6.1.0-1025-rockchip/device-tree/rockchip/rk3588s-orangepi-5.dtb 260529 bytes read in 287 ms (885.7 KiB/s) Retrieving file: /lib/firmware/6.1.0-1025-rockchip/device-tree/rockchip/overlay/orangepi-5-ap6275p.dtbo 398 bytes read in 329 ms (1000 Bytes/s) Fdt Ramdisk skip relocation and key differense in the end: Armbian -> [ 117.425678] rk-pcie fe190000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=0 Joshuas Ubuntu -> [ 20.633531] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 Ai tolds me it is PHY problems or wrons vcc3v3_pcie2x1l2 power consumption setup but is same for Joshua-Riek and Armbian (1800000 mA) Attaching full logs u-Ubuntu a-Armbian a_wifi_uart_debug u_wifi_uart_debug
@alexc Hi, thanks for the response and for the patch! Just to clarify — we actually used your PCIe BSP fix (commit a9eaa51d) and the stock, unmodified hailo_pci 4.21.0 driver from the official Hailo GitHub (v4.21.0 tag). No changes were made to the Hailo driver side at all. Earlier in the process we had experimented with workarounds on the Hailo driver (INTx bypass + polling thread), but those were reverted completely before the final test. The report describes the end state: your kernel patch + stock driver. Result with your fix: hailo 0000:04:00.0: Enabled MSI interrupt No INTx fallback, no polling. Load average dropped from 18+ to ~12, Frigate CPU from ~485% to ~83% (real inference on 9 cameras). Regarding the GitHub PR / kernel patch — that would be great. The fix is clearly in the right place (PCIe driver), and a proper patch submission would help other Allwinner A733 users with PCIe devices.
There is only this overlay for vendor kernel: /usr/lib/linux-image-6.1.115-vendor-rk35xx/rockchip/overlay/radxa-zero3-rpi-camera-v1.3.dtbo The mainline based kernel, what you use, there is none. So you would need to port it, from this radxa03 SBC or look at other devicetree overlay files, maybe from RadxaOS, maybe from RPiOS See 'man dtc' as a start, it might be a complete renaming of a lot of the .dtso file is needed, maybe it is just an enable line.
Next week we'll be in Long Beach, California for AWE USA 2026. Catch our talk exploring OpenXR, from its practical foundation for cross-platform XR interoperability, to its extension support across devices, and more! View the full article
edit: nope it looks like that the server was blacklisted somewhere in my adblocker blacklist.
@Ovaday First of all, thank you for the initiative. This repository contains the files that will be used as example to enable your board in Armbian: https://github.com/hqnicolas/ArmBoardBringUp The example file you're referring to is this one: https://github.com/hqnicolas/ArmBoardBringUp/blob/main/config/boards/h96-tvbox-3566.tvb The boot settings you should use may vary considerably from this reference, but your device will need a configured bootloader. https://github.com/hqnicolas/ArmBoardBringUp/tree/main/patch/u-boot/v2026.04/board_h96-tvbox-3566 You will need to focus on the new kernels like: https://github.com/hqnicolas/ArmBoardBringUp/tree/main/patch/kernel/archive/rockchip64-7.1/dt The repository you need to interact with to include these files is this one: https://github.com/armbian/build You need to validate everything before publishing, so do some hard work using this compiler: https://docs.armbian.com/Developer-Guide_Overview/
I again apologize, even though I can not see what was "hostile" in what I wrote. I simply misunderstood and apologized for that, even though I think you are the passive aggressive one here. I am so sorry. (I will add you to ignore list so I will never accidentally interact with you again, so no need to leave the community if it is due to me)
After a few days of testing I have to say it works great. No issue whatsoever. Stable, usb, eth, wifi, bt works. Great work! -
I have a few of those and when connected to RPi5 PSU and set to 12V, it can power my Rock5B with NVME SSD and some other peripherals as well.
I tested the new driver in my box (the router and box are in two different rooms). As you can see, just as @WallaceWebs mentioned, the upload speed has improved significantly. Before merging this pull request, the speed was 8.25Mbps, and now it is 33.46Mbps. Idle Latency: 11.17 ms (jitter: 1.63ms, low: 10.02ms, high: 12.42ms) Download: 38.57 Mbps (data used: 22.8 MB) 97.38 ms (jitter: 31.45ms, low: 16.86ms, high: 432.50ms) Upload: 33.46 Mbps (data used: 54.8 MB) 127.94 ms (jitter: 41.37ms, low: 28.14ms, high: 628.78ms) Packet Loss: 0.0% -
@8lall0 Thank you very much for helpfull comittment. I put the changes into the Repro. New Release 0.7
I'm trying to use the radxa 4k camera with armbian. The camera worked on Radxa OS but i wanted to have more camera drivers, hence why I made a custom armbian build with more drivers enabled. The /boot/dtb/ folder was missing so I tried to get the same structure as what I have on my radxa zero3 /boot/dtb/qcom/overlay/qcs6490-radxa-cm-q64-rpi-cm5-io-cam0-imx415.dtbo /boot/dtb/qcom/qcs6490-radxa-dragon-q6a.dtb armbianEnv.txt rootfstype=ext4 user_overlays=qcs6490-radxa-dragon-q6a-cam1-radxa-camera-4k overlay_prefix=qcs6490 overlays=radxa-dragon-q6a-cam1-radxa-camera-4k fdtfile=qcom/qcs6490-radxa-dragon-q6a.dtb usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u I used the overlays that I build with radxa overlays both use 6.18.2-current-qcs6490
I am coming from a yocto build for a dev board. I had to make u-boot patches, kernel config changes, and custom DTS tree. I'm trying to adapt this to Armbian, one step at a time. I started with building am image for sk-am62b.conf. I did not expect u-boot to boot from correctly. I was glad to see console messages, but expectedly, u-boot didn't continue. I made a new board config for this, duplicating sk-am62b.conf, but changing a critical line I made to get this to work previously. TIBOOT3_FILE="tiboot3-am62x-gp-evm.bin" Now, the boot process gets through u-boot and loads the Linux kernel. However, the kernel halts because it cannot find the root file system. Waiting for root device PARTUUID=26aa2b10-02... I confirmed the device in u-boot, and it seems to agree. Environment size: 5112/126972 bytes => echo load mmc ${bootpart} ${fdtaddr} ${bootdir}/dtb/${fdtfile} load mmc 1:2 0x88000000 /boot/dtb/ti/k3-am625-sk.dtb => run finduuid => echo part uuid ${boot} ${bootpart} uuid part uuid mmc 1:2 uuid => part uuid mmc 1:2 26aa2b10-02 I then modified my board config: BOOT_FDT_FILE="myir-6254-am62x/myir-6254-am62x.dts" But after booting, u-boot didn't acknowledge this: (From the u-boot environment) fdtfile=ti/k3-am625-sk.dtb So, I finished applying my u-boot patches that I made under the Yocto build. Some of these changes may be redundant: edited: am62x_evm_a53_defconfig + CONFIG_DEFAULT_FDT_FILE="myir-6254-am62x.dts" +CONFIG_TI_FDT_FOLDER_PATH="myir-6254-am62x" After booting into u-boot, now I see the change made: fdtfile=myir-6254-am62x.dts Then I see this: Running uenvcmd ... 14857759 bytes read in 983 ms (14.4 MiB/s) 36805120 bytes read in 1549 ms (22.7 MiB/s) Failed to load '/dtb/myir-6254-am62x.dts' libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree Scanning for bootflows in all bootdevs This is not unexpected either - since the files are not the image yet. When u-boot can't find the device tree, it loads a grub interface. And when I 'e'dit that I see the line linux /Image root=PARTUUID=076c4a2a-02 rootwait rootfstype=ext4 and change it to: linux /Image root=/dev/mmcblk1p2 rootwait rootfstype=ext4 The kernel sees the rootfs, and proceeds to boot. If I change it to using the PARTUUID, as above, it also boots. If I manually place the DTB file where u-boot reported it is is looking (copied from my running yocto system) (in /dtb/) The kernel boots, without the grub interface. However, the same situation occurs, where it is waiting for the root device. Waiting for root device PARTUUID=26aa2b10-02... I have a few things going on here. I think in order to boot to an OS I need: 1) Solve why the kernel does not see the root partition when booting from u-boot (but does when I can get into the grub interface) 2) How to properly implement a custom device tree structure. I know there are overlays, but I'd prefer to just drop in my whole custom tree. Once I get there, I can proceed to implement some of the kernel modification I did within the yocto build environment, but this first. Thanks for the assistance.
Basicly, a LLM has dozens of transformer layers (attention layer + ffn layer). We cannot load the whole model data, or even a single transformer layer on NPU sram(~1MB). So, we put the whole model in RAM, transport a slice of data to NPU by command stream each time, then next slice. Several times of the model size may be transported between ddr and npu. This cost is huge so I still run LLM on pure cpu.
lote replied to Deoptim's topic in Rockchip CPU Boxes
Hey OP, the Loader.zip link is dead. Mind resharing it? Can't proceed without it. Thanks!Hey OP, the Loader.zip link is dead. Mind resharing it? Can't proceed without it. Thanks! -
my rock64 sometimes hangs with unknow reason. Enabling/testing watchdog did not help. Does hardware watchdog is working at all ? some outputs: # dmesg | grep -i watchd [ 0.838922] dw_wdt ff1a0000.watchdog: No valid TOPs array specified [ 0.928770] rk_gmac-dwmac ff540000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.920201] systemd[1]: Using hardware watchdog 'Synopsys DesignWare Watchdog', version 0, device /dev/watchdog0 [ 3.921218] systemd[1]: Watchdog running with a hardware timeout of 28s. # wdctl Device: /dev/watchdog0 Identity: Synopsys DesignWare Watchdog [version 0] Timeout: 28 seconds Timeleft: 18 seconds Pre-timeout: 0 seconds After doing kernel panic via echo c > /proc/sysrq-trigger device not rebooting. On raspberry pi that test is working fine.
A guide to installing Armbian on the H96 Max V11
Samzz replied to Maxxim's topic in Rockchip CPU Boxes
i am running a H96(model RK3318) android tv box, its old, i have lost itss remote as well. basically noow i am tryinh to install ambrain os on it, but the conditon now is , even the android id now visible on the tv/monitor, basically when i insert the power cable on the display "boot" is showing with blue light. after few sec, some number like "07:01" is showing, but when i connect my htmi cable, the tv is detecting the htmi. but its showing no signal. basically there is no output on the display. i have tried many methods, there is no problem in htmi, or tv or cable. the andoird itself not booting. and the sd card method for ambrain also not working . tried the toothpick method and everything. but still its nott working!. i dont know why there is no output on the display. i dont know whhat issue. usb, htmi, everything is working. even charger also working.
