  1. Yesterday
  2. Hello, I'm trying to play a video on my Orange Pi Zero 2w using MPV. I tried using different Armbian images including Armbian-unofficial_26.05.0-trunk_Orangepizero2w_bookworm_current_6.18.25_minimal.img. This however results in a "Failed to create framebuffer with drmModeAddFB2 on layer 0" for every frame. Can anyone help me to get it working? (+) Video --vid=1 (*) (h264 1920x1080 24.000fps) (+) Audio --aid=1 (*) (aac 6ch 48000Hz) [vo/gpu] VT_GETMODE failed: Inappropriate ioctl for device [vo/gpu/opengl] Failed to set up VT switcher. Terminal switching will be unavailable. Using hardware decoding (drm). [W][00814.699591] pw.conf | [ conf.c: 939 try_load_conf()] can't load config client.conf: No such file or directory [E][00814.699881] pw.conf | [ conf.c: 963 pw_conf_load_conf_for_context()] can't load default config client.conf: No such file or directory AO: [alsa] 48000Hz stereo 2ch float VO: [gpu] 1920x1080 drm_prime[nv12] [vo/gpu] Using HW-overlay mode. No GL filtering is performed on the video! [vo/gpu/drmprime-overlay] Failed to create framebuffer with drmModeAddFB2 on layer 0: Invalid argument [vo/gpu/drmprime-overlay] Failed to create framebuffer with drmModeAddFB2 on layer 0: Invalid argument AV: 00:00:00 / 00:00:30 (0%) A-V: 0.000 [vo/gpu/drmprime-overlay] Failed to create framebuffer with drmModeAddFB2 on layer 0: Invalid argument
  3. Ok, I gave it a go. I used the settings - baud rate 1500000, Data bit=8,Parity check=None,Stopbit=1,Flow control=None. Most of what I got was largely garbled but here's what I could read: [code] DDR fcb0cfd52f cym 24/10/09-19:36:03,fwver: v1.08 In ch1 ddoY�H��~␦j�DR5, 2736MHzttot6 channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB ch1 ttot7 ��@ )�j�-��o � ����������~�����������channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB Manufacturer ID:0xff �h�0 RX Vref:24.9%, RX DQS Vref:30.8%, TX Vref:20.0%,0.0%/� Kk�k|/��~��~������� DQ roc: p4 n0, p7 n0, p4 n0, p3 n0, p5 n4, p1 n0, p7 n0, p0 n2, p0 n0, p4 n3, p2 n0, p5 n0, p3 n0, p4 n0, p4 n0, p5 n0, p0 n0, p3 n1, DQ rds:h1 h1 l0 l0 l0 l0 l0 l0, l0 l0 l0 l0 l0 l0 h1 l0 ��� �B(N@x�|�|�~�~�~~����������CH1 RX Vref:24.1%, RX DQS Vref:29.2%, TX Vre��Jo��{��������������� DQ roc: p6 n0, p2 n0, p7 n0, p3 n1, p1 n0, p0 n2, p3 n0, p7 n0, p3 n0, p3 n0, p2 n0, p0 n1, p6 n0 p1 )��d!�@��DQS roc: p1, n0, p3, n0 stride=0x3, ddr_config=0x2 hash bank_mask0-3 0x0 0x2100 0x44200 0x88400, rank_mask0 0x0 nge to F1: 534MHz >l ttot6 l1 ttot6 ?lange to F2: 1320MHz ch0 ttot8 ch1 ttop8 c@aNg@@ ch0 ttot6 ch1 ttot6 �~l�ange to F0: 2736MHz ����x�x�|�|�������������ch0 ttot7 ch1 ttop7 out U-Boot SPL board init>_p U-Boot SPL 2017.09_armbian-2017.09-S39cd-P60ca-H8822-V586d-B138f-R448a (Apr 27 2026 - 17:35:35) SPL Hotkey: ctrl+` "�!)�#P��K=�|�~�~�~�~���������sfc cmd=0�� )��������������������� @jj��%����������������������. ����ᯍ�������������spl: par�K� y!��������dd�Verified-boot: 0 ~@@�������������������## Checking atf-1 0x40060000 ... sha256(868eaf583a...) + OK � ��/��oo-����������������������%␦� +���������������������� _B��� / ��x����������������������ZH)�)���-�������������������x-�/ �������������������## Checking uboot 0x4020000�����l�e1593752...) + OK �dd�Checking fdt 0x40339460 ... sha256(e3b0c44298...) + OK 6�t_record_lgadable: FDT_ERR_BADMAGIC �@dd�ChekA�;\6�F�f�400f0000 ... sha256(8afb712810...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC �#" Checkin1�� !��������{���+�:�ICE: BL31: v2.3():v2.3-931-g4d7e811c6:derrick.huang, fwver: v1.20 NOTICE: BL31: Built : 19:19:38, May 26 2025 ��NFO: SOC (0x35760101) INFO: spec: 0x1 INFO: test version: 0x0 INFO: cost 477531 us before hptimer restart k������������������INFO: soc cold boot INFO: ARk�P��& b �$@�H@�@� `]w�mask: 1 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x40200000 INFO: SPSR = 0x3c9 No valid device tree binary found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> initcall sequence 00000000402c54c0 failed at call 00000000402b81e8 (err=-1) [/code] The rest after this was unreadable. ljones
  4. After long break, I have found some free time to test latest updates that can be found in github It seems that pyavitz made a great progress there with his DTS implementation over Debian. https://github.com/pyavitz/debian-image-builder Now i am able to boot Debian out of the reproduced image. No uboot patching: Here is a copy of my work inside above repository: make config make all board=kickpik2b-v2 sudo dd if=output/kickpik2b-v2/image/sun50i-h618-kickpi-k2b-debian-trixie-6.12.84-arm64-ext4-2026-04-29-1923.img of=/dev/mmcblk0 And boom. Flawless boot into Debian Linux U-Boot SPL 2026.01 (Apr 29 2026 - 18:28:52 +0300) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.12.9(debug):lts-v2.12.9 NOTICE: BL31: Built : 18:28:34, Apr 29 2026 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0cd628, model: KickPi K2B INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: Probing for PMIC on I2C: INFO: PMIC: found AXP313 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. U-Boot 2026.01 (Apr 29 2026 - 18:28:52 +0300) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: KickPi K2B DRAM: 2 GiB Core: 74 devices, 23 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Allwinner mUSB OTG (Peripheral) Net: eth0: ethernet@5020000using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready , eth1: usb_ether starting USB... USB EHCI 1.00 USB OHCI 1.0 USB EHCI 1.00 USB OHCI 1.0 USB EHCI 1.00 USB OHCI 1.0 Bus usb@5101000: 1 USB Device(s) found Bus usb@5101400: 1 USB Device(s) found Bus usb@5200000: 1 USB Device(s) found Bus usb@5200400: 1 USB Device(s) found Bus usb@5310000: 1 USB Device(s) found Bus usb@5310400: 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf KickPi K2B V2 1: Debian Trixie Enter choice: 1: Debian Trixie Retrieving file: /boot/extlinux/../Image Retrieving file: /boot/extlinux/../uInitrd append: earlyprintk console=tty1 console=ttyS0,115200n8 rw root=PARTUUID=e0688e9b-01 rootwait rootfstype=ext4 fsck.repair=yes loglevel=1 net.ifnames=0 video=HDMI-A-1:1920x1080 init=/sbin/init Retrieving file: /boot/extlinux/../allwinner/sun50i-h618-kickpi-k2b.dtb Moving Image from 0x40080000 to 0x40200000, end=0x41930000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: initramfs-6.12.84 Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 11668168 Bytes = 11.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 494df000, end 49fffac8 ... OK Loading Device Tree to 00000000494d2000, end 00000000494de815 ... OK Working FDT set to 494d2000 Starting kernel ... Loading, please wait... Starting systemd-udevd version 257.9-1~deb13u1 Most important part - communication devices are available: Pyavitz did a great job! kickpik2b-v2root~: dmesg | grep -i "eth0\|wlan0" [ 19.638015] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.784938] dwmac-sun8i 5020000.ethernet eth0: PHY [stmmac-0:00] driver [MAE0621A-Q2C Gigabit Ethernet] (irq=POLL) [ 19.784980] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found [ 19.784991] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available [ 19.784999] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW [ 19.785390] dwmac-sun8i 5020000.ethernet eth0: configuring for phy/rgmii link mode [ 19.826219] [chip1][SKWIFI6621S DBG] skw_ndo_open: dev: wlan0, type: STA [ 19.826262] [chip1][SKWIFI6621S DBG] skw_ndo_set_rx_mode: wlan0, mc: 1, uc: 0 [ 19.826723] [chip1][SKWIFI6621S DBG] skw_ndo_set_rx_mode: wlan0, mc: 2, uc: 0 [ 19.826885] [chip1][SKWIFI6621S DBG] skw_set_power_mgmt: wlan0, enabled: 0, timeout: -1 I haven't tried Armbian yet, but the heavy lifting part is already done. Big kudos to pyavitz @c0rnelius Thanks, Nasko
  5. Welcome to the latest Armbian Newsletter: your source for the latest developments, community highlights, and behind-the-scenes updates from the world of open-source ARM and RISC-V computing. Armbian has released images based on Ubuntu 26.04 LTS, codenamed Resolute Raccoon the latest long-term support base. As always, Armbian applies its own platform-optimized kernel, board-specific patches, and tested drivers on top so what you get is a clean, stable foundation across SBCs, PCs, and cloud environments, with no Snap packages, fully compatible with the Ubuntu ecosystem, and no surprises. SPONSORED Join us in making open source better! Every donation helps Armbian improve security, performance, and reliability — so everyone can enjoy a solid foundation for their devices. We rewrote how Armbian installs desktops. Here’s what changedA friendlier, faster, snap-free desktop install in armbian-config If you’ve installed a desktop environment with armbian-config over the last few months, you may have noticed things feel different: there’s a tier you can pick, the browser actually works on every arch, uninstall doesn’t take half your system with it, andArmbian blogIgor PecovnikArmbian Q1 2026: Technical Milestones and the Road to Embedded WorldThe first quarter of 2026 has been a period of significant technical consolidation for the Armbian project. Driven by the v26.02 (Goa) release cycle, the project has focused on three core pillars: aggressive framework refactoring, the stable rollout of the Linux 6.18 LTS kernel, and the maturation ofArmbian blogMichael RobinsonGithub HighlightsThis week in Armbian development saw a broad range of updates spanning kernel enhancements, desktop improvements, and infrastructure refinements. Notable changes include new developer documentation for the desktop submodule, expanded GPU and multimedia support for vendor-kernel desktops, and several kernel version bumps for various platforms. The build system received fixesArmbian blogMichael RobinsonView the full article
  6. Welcome to the latest Armbian Newsletter: your source for the latest developments, community highlights, and behind-the-scenes updates from the world of open-source ARM and RISC-V computing. Armbian has released images based on Ubuntu 26.04 LTS, codenamed Resolute Raccoon the latest long-term support base. As always, Armbian applies its own platform-optimized kernel, board-specific patches, and tested drivers on top so what you get is a clean, stable foundation across SBCs, PCs, and cloud environments, with no Snap packages, fully compatible with the Ubuntu ecosystem, and no surprises. SPONSORED Join us in making open source better! Every donation helps Armbian improve security, performance, and reliability — so everyone can enjoy a solid foundation for their devices. We rewrote how Armbian installs desktops. Here’s what changedA friendlier, faster, snap-free desktop install in armbian-config If you’ve installed a desktop environment with armbian-config over the last few months, you may have noticed things feel different: there’s a tier you can pick, the browser actually works on every arch, uninstall doesn’t take half your system with it, andArmbian blogIgor PecovnikArmbian Q1 2026: Technical Milestones and the Road to Embedded WorldThe first quarter of 2026 has been a period of significant technical consolidation for the Armbian project. Driven by the v26.02 (Goa) release cycle, the project has focused on three core pillars: aggressive framework refactoring, the stable rollout of the Linux 6.18 LTS kernel, and the maturation ofArmbian blogMichael RobinsonGithub HighlightsThis week in Armbian development saw a broad range of updates spanning kernel enhancements, desktop improvements, and infrastructure refinements. Notable changes include new developer documentation for the desktop submodule, expanded GPU and multimedia support for vendor-kernel desktops, and several kernel version bumps for various platforms. The build system received fixesArmbian blogMichael RobinsonView the full article
  7. driver for sv6051p working in kernel 7 @Qvy: https://github.com/eloirotava/6051 horray!
  8. now working with: Download: 8.06 Mbit/s Upload: 10.08 Mbit/s in kernel 7. https://github.com/eloirotava/6051 testes on s90w amlogic. also work with 6030p rockchip.
  9. Will try to find my UART to USB and see what I get. ljones
  10. @Igor Maybe we can add a lastchange.txt file with unix timestamp to the root and use it for a status page? Then periodically let it check and output status in a separate tab on https://actions.armbian.com/
  11. Hello, Can you connect the UART to the NanoPi and see where it gets stuck? I'll take a look at it over the weekend. Thank you.
  12. Last week
  13. Hello all! Not sure what is going on at all but I'm having a problem booting the "rolling release" of armbian (debian 14/forky) minimal cli. I'm using a nano pi R76S with 4gb of RAM and 64GB emmc. I can successfully burn a microsd for the previous version (also minimal cli vesion) which boots ok.However if I try to use the newer version nothing happens -- the red LED on the R76S stays permanently on and I get no display or any other life. I did try using different microsd cards but it did not make any difference. I also tried using the same microsd (I wrote the older version first to the microsd which boots) then wrote again on the same microsd. I'm using the download page for the images from here - https://armbian.com/boards/nanopi-r76s ljones
  14. As for promised photos, here they are. Note custom-trimmed bifurcation adapter.
  15. As for QRTR patch, WIP version is attached bellow. Be aware that this patch doesn't work yet. It builds, it writes to registries, but QCNFA765 ignores it. rk3588-ath11k-QRTR.patch
  16. As for QCNFA765, using more than one NIC in the same system still won't do. I have found correct MHI registries (0x28 and 0x48) which are used to store QRTR ID, but the driver omitts it completely during cold-boot of the NIC. So, for now, I moved over to use single QCNFA765 and Intel AX210 combo. Which brought another issue - annoying LAR. Bellow are patches I do use to be able to use both cards in HostAP Master mode with no restrictions on selected channels. I do use regdomain CZ. Should you need different regdom, use example found in those patches for CZ, and just copy over the changes made (removing NO-IR, DFS, and other flags). 404-regd_no_assoc_hints.patch atheros-dfs_fix.patch atheros-regdomainfix.patch regdb-fix.patch rk3588-iwlwifi-disable-lar.patch
  17. small update... last tries I've made: with an SD card loaded with armbian 26.2 (from Armbian archives) and DIP on SD, the boot is ok, boot is U-Boot 2025.10_armbian-2025.10-Se50b-P915a-H3623-V44f7-B2eb2-R448a. However, no option to load bootloader in SPI present in nand-sata-install, most probably because no SPI block listed in lsblk output. nan-sata-install complains that the command line is incomplete and request to try option 'help', but I could not figure how to get to the help, any common option passing I've tried did not worked. I tried to get to the initial install procedure from Kobol, modifying the spi_workaround from off to on in armbianEnv.txt on the SD, but this prevent the kernel to boot from SD. Any help would be appreciated...
  18. As you might see in my signature I decided to retain the Helios4 withdrawing the goodbye message above. @laibsch Actual problem: I didn't succeed in configuring Wake-on-LAN on 26.2.1. What I did was to replace "eth0" by "end1" in /lib/systemd/system/helios4-wol.service Triggering the suspend mode by pm-suspend Decompilation of armada-388-helios4.dtb didn't contain the device tree patch mentioned in https://wiki.kobol.io/helios4/files/wol/helios4-dts-add-wake-on-lan-support.patch Any clue what's missing? @Igor armbian-config does not find any .dtb files in /boot/dtb ("Device Tree Editor") /boot/dtb is a symlink to the directory dtb-6.6.124-current-mvebu.
  19. Now this issue seems to be fixed. I tried to build 6.18.25 kernel and it can complete boot wizard as expected.
  20. Thank you for the Input! Yes Proxmox and then different VM like HAos to gain access to HACS.
  21. Hi everyone! Can anyone tell me how to make the system boot without displaying any text characters? I'd like to just see the Radxa logo, then a black screen and the login screen (GDM). What settings do I need to configure to achieve this? I have the Armbian 2.6.4 Trixie CLI image installed with GNOME.
  22. the problem is solved
  23. Community images are tied to daily beta repo where it should always be a match kernel - headers. Just make sure you have a clean updated system then proceeding to header installation via armbian-config. And only if this doesn't work, report so we can look into.
  24. I see it like who is motivated to check and do the work w.r.t U-Boot. Especially while EDK2 UEFIv1.1 is available already a year and at least for my ROCK5B and NanoPi-R6C with both Armbian rockchip edge kernels as well as standard Debian arm64 kernels works OK. We call those things 'firmware' but the 'firm' selling this OP5 HW is not delivering this. Good thing is that it is all open source at least. For the ROCK5B I also used it in 'vendor' mode, so 6.1.115 works and so video encoders as well (for Jellyfin). For NanoPi-R6C (RK3588S, same as OP5) it is in the on-board eMMC, that is some disadvantage compared to SPI and more as SD-card. So not sure how OP5 will deal with it.
  25. At least that explains the result of the nvme scan command. Now it remains to find out why this is the case, but since improvements are still pending for PCIe support even in the mainline kernel, the question arises whether all of this has already been migrated into the firmware.
  26. It doesn't see NVMe device on PCI bus. => pci enum => pci BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x1d87 0x3588 Bridge device 0x04
  27. This week in Armbian development saw a broad range of updates spanning kernel enhancements, desktop improvements, and infrastructure refinements. Notable changes include new developer documentation for the desktop submodule, expanded GPU and multimedia support for vendor-kernel desktops, and several kernel version bumps for various platforms. The build system received fixes for filesystem resizing and improved dependency handling, while CI workflows were optimized with increased timeouts and better error handling. New hardware targets were added, including Radxa Dragon Q6A and Nio 12L, alongside updates to u-boot and kernel drivers for multiple devices. Additional improvements focused on patch maintenance, logo updates, and enhanced automation for VM provisioning. These collective efforts continue to strengthen Armbian’s reliability, performance, and hardware compatibility. ChangesAdd developer guide for the desktop submodule. by @igorpecovnik in armbian/documentation#912armbian-kernel: btf: fixes + enable KPROBES. by @rpardini in armbian/build#9715armbian-resize-filesystem: fix typo $rootdev → $diskdev in do_expand_partition. by @iav in armbian/build#9702artifact-uboot: add UBOOT_GIT_CACHE_TTL (fixes #7710). by @iav in armbian/build#9699ci/unit-tests: bump job timeouts by +30 minutes. by @igorpecovnik in armbian/configng#890ci/unit-tests: cancel in-flight runs on supersede. by @igorpecovnik in armbian/configng#891cli: kernel-dtb: pass -@ to normalized dtc invocation. by @rpardini in armbian/build#9720config.system: add Bianbu to the desktop install menu. by @igorpecovnik in armbian/configng#893desktops: enable panthor-gpu DT overlay on rk3588 vendor-kernel desktops. by @igorpecovnik in armbian/configng#886desktops: install libv4l-0 before rockchip-multimedia packages. by @igorpecovnik in armbian/configng#887desktops: move mesa/GPU runtime + diagnostics to common mid tier. by @igorpecovnik in armbian/configng#885desktops: prune unused wallpaper assets (-15 MB). by @igorpecovnik in armbian/configng#882desktops: strip libreoffice on jammy/riscv64 (no upstream build). by @igorpecovnik in armbian/configng#883env_init: reconcile BRANCH from installed kernel on every startup. by @igorpecovnik in armbian/configng#892external: enable code (VSCode) pull for jammy. by @igorpecovnik in armbian/os#457generate-armbian-images-json: detect preinstalled app past kernel rc/beta tag. by @igorpecovnik in armbian/armbian.github.io#294genio: edge: bump to collabora's 6.19.8. by @rpardini in armbian/build#9721helios64: u-boot: bump to v2026.04 + diagnostics + CMD_FILEENV; v2026.04: generic btrfs zstd fix. by @iav in armbian/build#9675hetzner: validate GitHub runner token before provisioning any VM. by @igorpecovnik in armbian/actions#19Improve Radxa logo. by @igorpecovnik in armbian/armbian.github.io#293kernel: add dependency of initramfs-tools for linux-image package. by @amazingfate in armbian/build#9727libbpf: fix const correctness in resolve_full_path for gcc15. by @EvilOlaf in armbian/linux-rockchip#474meson64-6.12: oldlts: update meson-axg mmc phase configuration patch. by @rpardini in armbian/build#9712mvebu: edge → 6.18 LTS family-wide + restore 4 patches lost in #6135. by @iav in armbian/build#9709Odin2: Now we can switch back to upstream sdhci-msm driver. by @kasimling in armbian/build#9703odroidhc4: u-boot: bump 2026.01 -> 2026.04 (final) & add LWIP. by @rpardini in armbian/build#9714owncloud: fix CI install test + docker_operation_progress pull/error-handling bugs it exposed. by @igorpecovnik in armbian/configng#888owncloud: fix CI install test + docker_operation_progress pull/error-handling bugs it exposed. by @igorpecovnik in armbian/configng#889patch maintenance: some rewriting against recent patch versions. by @EvilOlaf in armbian/build#9711pkg: prevent interactive dpkg prompts in automated builds. by @igorpecovnik in armbian/configng#884qrb2210: switch edge kernel to mainline linux v7.0. by @SuperKali in armbian/build#9710radxa-aic8800: Use gcc-14 for Noble release. by @HeyMeco in armbian/build#9707refactor(api): normalize application='ufs' to storage='ufs'. by @HeyMeco in armbian/website#9release-targets: add radxa-dragon-q6a and radxa-nio-12l with ufs extension. by @igorpecovnik in armbian/armbian.github.io#292Revert "Disable Sk-am64b as its not compiling on Resolute". by @jonaswood01 in armbian/armbian.github.io#289SpacemiT: Enable additional audio support in legacy and current. by @pyavitz in armbian/build#9717targets: set DESKTOP_TIER per desktop block, keyed on DESKTOP_APPGROUPS_SELECTED. by @igorpecovnik in armbian/armbian.github.io#288thinkpad-x13s: bump to steev's 7.0.y. by @rpardini in armbian/build#9716u-boot: 2026.04: drop #warnings in fdt_fixup_ethernet logging patch. by @rpardini in armbian/build#9713Update odroidxu4-current to 6.6.135. by @belegdol in armbian/build#9705Update Radxa logo. by @igorpecovnik in armbian/armbian.github.io#290workflows/hetzner: expose machine_count and server_type as dispatch inputs. by @igorpecovnik in armbian/armbian.github.io#291View the full article
