Just a small note here - I recently added Bianbu desktop (can be installed from armbian-config), where acceleration works on K1 based Musebook (legacy kernel). This should be possible to adopt to any other K1 board. Youtube video works fine in Chromium ...
Hooray!!
This will be addressed shortly. I will update this thread when the fix is merged
"mmc1(part 0) is current device". Is that really a usb? Never seen a usb be named that, sound more like an internal storage.
The MLIR pipeline, lowering from TOSA to TIM-VX C++, is now available here: https://github.com/MaverickLong/MLIR-TIM-VX It's *kinda* working, currently only supports conv2d (image processing) CNN models or simple MLPs, and it's far from mature, so expect a lot of errors. With this (plus the unified driver) we are heading towards running any ML model on the NPU...
At Radxa's suggestion I grabbed their latest image `rock-5t_bookworm_kde_r5.output_512.img` which contains `DDR b8ce94f14b cym 25/09/26-15:48.05,fwver: v1.20` and `stress-ng` now passes without any errors.
Does the box have an sd card slot and have you tried booting from that? (That is the common method). Also are you sure the box has an s905x3? Have you opened the box and inspected the chip? You might want to try all the uboot binaries just in case.
Thanks. URL is https://paste.armbian.com/liqeyelovi
I am trying to boot from a USB stick, but it shows the error you can see in the screenshot. I am using the update button on the back of the TV box. It does start the boot process from the USB, but according to the error message it seems unable to actually read the drive. I have been stuck on this issue for several days now.
The s905x3 one. Also, how are you booting this? You say it doesn't recognize usb, so what are you using to boot Armbian?
Ubuntu 26.04 with or without KDE Plasma with working drivers for WiFi, GPU, Nic, Bluetooth. Enjoy! https://github.com/mack42/OrangePi5Pro Note: There are Minimal and Graphical images available. It also supports installing to the NVME.
Thank you very much for your responses, it totally make sense. I will try to build it myself, tho I have never done that, and my knowledge is very limited. I'd love to help one day, but this really is beyond what I can offer, for now.
Thanks for clarifying. And which would be the correct version of u‑boot for my BTV OTT BOX (model B11, Amlogic S905X3)? I admit I’m a bit lost at this point.
The screen shot you have shows you are using the Ugoos X3 version of uboot. That will not work as that is specific to that box.
moved post to correct forum
Friends, as shown in the image, I am trying to install a Linux system on this BTV: OTT BOX, model B11 with an Amlogic S905X3 CPU. However, I am not succeeding because it cannot read the USB drive. I have already tried changing the .ext, attempted to burn the image using Rufus, Balena, and nothing worked. I am using a Multilaser USB drive which I believe is 2.0. At the moment I don’t have another USB drive or memory card to test. Any suggestions?
Answered: Module bcache not found on 6.18.10-current-bcm2711
Werner replied to eduring's topic in Raspberry Pi
Well if you want to live on the edge, then use code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } egde as branch instead of code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } current -
Radxa Cubie A7A/A7Z - Allwinner a733
Daniel - Ni Qinghai replied to Nick A's topic in Allwinner sunxi
Thank you so much for the Armbian version for A7Z , Armbian is My most love system in all kinds of systems fro SBC - Arm based -
eduring replied to eduring's topic in Raspberry Pi
Ah, thank you so much! I love being "on the edge" 😉 The only way we learn in our profession / super hobby! Ps, for people who want to know, I'm building two of these: * https://makerworld.com/en/models/1605027-raspberry-pi-5-based-4-bay-nas#profileId-1692368 -
I have also encountered this using Orange pi 5 and latest Armbian updated as of today. That the "standing" USB port does not work also means that the USB-C port doesn't work -- they are electrically connected. So Mitu's question is also mine: Is this a limitation of the mainstream kernel (6.18.x) - i.e. does this work only with the vendor kernel (6.1.x)? EDIT: typo
For Ubuntu Resolute desktops you need to build from this branch: https://github.com/armbian/build/pull/9683 It is a matter of days when this will be merged. You can speed this process by reviewing the code. P.S. We lack 1-2 beefy arm64 servers or 30-40k $ and unknown $ for storage space as we would need to upgrade from free storage which is limited to 1000 artifacts in order to provide more build combinations. We are far away ...
Newer kernel packages may not have hit apt repo yet. Use the build framework to generate a set of kernel packages to be installed via dpkg -i by yourself: https://docs.armbian.com/Developer-Guide_Overview/ code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } ./compile.sh BOARD=rpi4b BRANCH=current kernel -
Our resources are limited so we cannot provide images for each board with each kernel and each desktop environment. Feel free to use the framework to build the combination you want by yourself. https://docs.armbian.com/Developer-Guide_Overview/
