@jock well thanks but I already figured that part out ๐ my problem right now is that i can't find a single distro that works with my box . almost every one (even multitool) goes to a black screen and freezes excatly after 60 seconds . the best thing i could find was a android rom that have the same problem but in excatly 30 minute after booting up ! i did this stupid thing that did not backed up my original rom before writing to internal emcp flash ๐คฆโโ๏ธ if i can find any version that doesn't have this problem , i know how to merge armbian rootfs with it ! thank you again !
Have you tried your python script with your Linux PC? If it happens again, you can tell that the problem is within the ESP32 program. I generally prefer having the most complex system (Armbian) poll the simplest device (ESP32), instead of the ESP32 interrupting the Armbian system. I found it more stable that way. Stay with wifi, and use the ESP32 serial port just for debugging. Program the ESP32 print an acknowledgement of data requests, and an alarm if it gets stuck in an unexpected state. I have also found ESP32 circuit or micro python very stable for serial port communications.
I do not have any other monitor available but I did order a UART to usb device, and I have identified with a multimeter the uart pads, which are next to the SD card slot. I will keep this feed updated!
Hello! You should really look to the board name in rk3318-config rather than relying to led-conf numbering; also your dmesg is showing a very bad error which is probably due to an unstable system rather than a bug
rk322x armbian images never used the offset of 8192 sectors, only the multitool has such offset to increase compatibility with stock images
Vincenzoernst1 replied to Hqnicolas's topic in Rockchip CPU Boxes
@Hqnicolas would it be possible to have the driver @guenter pointed out in the base image? -
I think the core problem is that headers were compiled with Ubuntu compiler / userspace and you try to use it on Debian. I used this on Ubuntu, which is the reason why it worked. We are aware of this problem - headers should be distro specific. Which adds complexity on our side ...
Feel free to pr any missing overlay here: https://github.com/armbian/linux-rockchip
moved to csc https://docs.armbian.com/User-Guide_FAQ/#why-no-universal-image tl;dr: You are using the wrong image. Get/build one for your board
It works, but I found that the i2c dtbo file I needed was not in the armbian repository, so I manually extracted it from the radxa official image.
Armbian 25.8.1 Noble Gnome (Kernel: 6.1.115) + libMali (https://github.com/ginkage/libmali-rockchip) + box64 3.7 (https://ryanfortner.github.io/box64-debs/) + wine-9.22-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/9.22) + DXVK-Sarek v1.11.1 - Mali GPU Fix by Ayman-Zeyada (https://github.com/Ayman-Zeyada/DXVK-Sarek/releases/tag/v1.11.1-mali-fix) ~60fps@1080p HK: SilkSong -
What? Sharing various gaming experiences with RK3588 (Orange Pi 5) on Armbian. Why? Because RK3588 is a capable gaming chipset, Armbian is a good OS; Vulkan on RK3588 is getting better over time (PanVk) How? Posting your gaming results here (preferably with setup and screenshots/videos) so people can learn more.
We already did that. I think the problem is that our keys are not packed (yet) but added at build time. When a person upgrades from Bookworm to Trixie, this will show up, while on new Trixie images this shouldn't manifest. @zital debian Is this the case? https://github.com/armbian/configng/commit/5d866b9b105bfd46cb341c21c70ba76e32e1fea2 We are signing with old and new key (which is aligned with current standards) since then.
Hi everyone, I recently got an ESP-WROOM-32 Development Board to use as a companion board for my Armbian SBC setup. My goal is to have the ESP32 collect sensor data and send it to the Armbian host over serial or WiFi. It works okay at first, but after a while running a Python script, the ESP32 crashes or stops sending data. Setup Details: Armbian running on a Banana Pi (or similar SBC) ESP-WROOM-32 connected over serial (USB-to-TTL) and also configured via WiFi Python script (on the Armbian side) reads from the serial port / receives via a simple socket over WiFi Power supply is stable; using 3.3 V TTL logic on ESP and stable USB power Now here are my issues: Script runs fine for some minutes (5โ10), then suddenly no data from ESP3. ESP32 sometimes reboots (observed via onboard LED), sometimes appears alive but unresponsive. Logs show no obvious error messages; serial just quiet or times out I've tried lowering the serial baud rate. Added delays / sleeps in code to reduce data flood. Ensured the USB-power to ESP32 is stable / using good cable. Tried Py serial and different socket listener scripts Could USB-TTL or serial USB drivers under Armbian be causing issues (overheating, buffer overflows)? Would switching fully to WiFi (TCP/UDP) instead of serial help stability? Any tools or logging tips on Armbian to catch the crash (kernel logs, serial trace, etc.)? Thanks in advance for any advice. Jordan
I don't see it as the very latest bleeding edge kernel version. I see it as a newish Linux, which already has the armbian patches updated for. Some CPUs end up with newer or older Linux versions, due to varying levels of development success. For example, sunxi's armbian edge is 6.15.4 today, but the linux trunk is up to 6.17-rc6 ... (not available in Armbian)
I tried it on 6.16.7, and the log started working: [ 4.838111] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device Error again after initialization: [ 5.118148] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 5.637839] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
I have an Orangepi5 ultra RK5388. I have tried the following versions of Armbian13. It doesn't recognize my USBs so I don't have a keyboard. vendor: https://armbian.systemonachip.net/dl/orangepi5-plus/archive/Armbian_25.8.1_Orangepi5-plus_trixie_vendor_6.1.115_minimal.img.xz.sha This one won't start ,current: https://armbian.systemonachip.net/dl/orangepi5-plus/archive/Armbian_25.8.1_Orangepi5-plus_trixie_current_6.12.43_minimal.img.xz There is also no reference to Debian13 in any repository on the Orangepi website.
Has anyone ever gotten the Radxa Zero 3w working in gadget mode? I bought a Zero 3w about a week ago and have been beating this horse most of the time. I can't get the device to connect via USB. A or C. When I try to connect (radxa.local) it will always go through wifi. If I have wlan0 disabled or even my internet off it just will NOT connect. It clearly is using wifi to connect even if I use the hostname. Maybe this is something simple but I and another engineer I work with have been scratching our heads about it. The obligatory AI search was an endless loop of everything we had already tried. Anybody have any advice?
@hexdump hey mate , do you know if new armbian image still uses an offset of 8192 sector ? i'm trying the workaround you proveded in first page for linux hanging excatly after 60 seconds , but it only worked with multitool.img . with new armbian images it doesn't even boot after applying the trick ๐ thanks
What type of monitor do you have connected? If you have another monitor, I'd try that. What I find works best is a monitor that is native 1920x1080. I sometimes have issues with monitors that are higher resolution or lower resolution than a standard 1080P display. Otherwise finding the uart pads is the only other advice I have, so that you can see what is going on during the boot.
Thanks for the background information. I installed the orange pi 5 - 6.1.115 release with XFCE desktop. I edited the armbianEnv.txt to set up the pointer to the orange pi pro dtb entry. and booted it up just fine. With this, most things work well, To run the OS on the nvme M.2 drive, you cannot boot up from the nvme m.2 drive. Through some mistake that was made by the designers, you must always boot from an SD card for the initramfs to work enough to find the nvme m.2 drive. I made a copy - of the SD card to a second SD card on a separate system. Used this SD card to restart the Orange Pi 5 pro. Then changed the UUID of the /dev/nvme0n1p1 partition. (tune2fs -U) updated the armbianEnv.txt file on the boot SD card and the nvme0n1p1 drive. and rebooted - Now root is mounted to /dev/nvme0n1p1 partition. I have to leave the SD card in the slot to boot the system. but I am running off the NVME drive - Gen3 x 4 which should run at roughly 800-1000 MB/s on average according to Tom's hardware. That is probably 10x most SD cards transfer rate. Bottom line - I have a working Orange Pi 5 pro running on an NVMe M.2 drive - with the ability to get 10x throughput over using an SD card and up to 8TB of storage . Now it wasn't simple to actually set it up. It took some research and a learning curve. So I am not too happy about the lack of upfront information about getting this to work. But it is working. I had tried too build a real time kernel for this system. I did rebuild a kernel, but when I set the RT config up - I didn't have list of configuration question answers ready - Needed more information. The general idea was to get a fast multicore system with huge storage capacity and use this to run robotic systems. I am missing the real time kernel, I will run some latency tests to check the worst case jitter and look for a config setup. I see that there is now a Raspberry Pi 4 and Raspberry P5 real time kernel on a debian 12 release. I will see if I can get any build information for the real time kernel build. Thanks for the feedback. I will start looking for a different sbc model - among the platinum supported group.
GBEM replied to Hqnicolas's topic in Rockchip CPU Boxes
Awesome, @guenter. I'm debugging a board support layer for the Home Assistant OS, which targets the H96 Max. The fabulous work found in this thread, has been both inspiration and foundation for the port to Buildroot. With your very welcome direction, guenter, I'll have a far more polished result, if I ever get my images to boot. Thanks, so much, one and all, M. -
Hello, I am selling a working unit of Kobol Helios64 with the fix done, without drives. Based in Czech Republic, able to send within EU. Please DM me if interested.
