I can't mount the SD card to do the modification... It says the GPT table is corrupt. Well that may explains why belenaEtcher throws an error. I used USBImage instead, it doesn't throw an error but the main GPT table is still corrupt. I have tested with 2 different SD cards. I believe there is a problem with these Trixie (Desktop) images for Rock 5b+. I'm currently downloading the older bookworm image to check if it works, and that there is no hardware issue.
hello please need the stock firmware to reflash please
Logs from what? It doesn't boot from SD, I have a blank screen. Should I erase the SPI ROM to make it boot from the SD again? https://docs.radxa.com/en/rock5/rock5b/low-level-dev/install-os/rkdevtool_spi
Hello I have burned bookworm onto a sd card,booted on it with a Rock 5B+ and installed the bootloader on the SPI flash of the board and transferred the OS to the nvme drive. Now I I'm trying to install the new trixie image, but I can't burn it on my nvme drive. With USBImage it does not work. It doesn't detect my nvme drive installed on my USB adapter. With belena Etcher it throws an error during the validation of the image. Win32Imager doesn't load at all on Windows 11. I don't know which other tool (Windows) I could use. I'm stuck. How can I boot again from my SD card on a Rock 5b+?
I used the latest official image for a brand new install and set up OMV afterwards. So far everything works, but I ran into the "sata-reboot" bug. That said: Once I reboot after an update for example the sata drive is not being recognized. M2 nvme does come up as usual but not the sata ssd. Only remedy: Shutdown the M1, unplug, replug power cable and this cold reboot does the trick and the sata drive comes up again properly. It seems to be a kernel bug somehow and via armbian-config I tried several kernels but the bug unfortunately persists. Any ideas?
I tried several options, each time on a clean system. 1) echo "deb http://apt.armbian.com bookworm main bookworm-utils" | sudo tee /etc/apt/sources.list.d/armbian.list wget -qO - https://apt.armbian.com/armbian.key | sudo gpg --dearmor -o /etc/apt/trusted.gpg.d/armbian.gpg sudo apt-get update sudo apt-get install make sudo apt-get install git sudo apt-get upgrade sudo reboot sudo apt install linux-headers-current-meson64 -y git clone https://github.com/xProbe/aic8800d80-wifi-driver.git sudo cp aic.rules /lib/udev/rules.d/ sudo cp -r ./fw/aic8800D80 /lib/firmware/ cd ./drivers/aic8800 make sudo make install sudo modprobe aic8800_fdrv lsmod | grep aic ะัะฒะพะด aic8800_fdrv 499712 0 aic_load_fw 65536 1 aic8800_fdrv cfg80211 385024 3 mac80211,rtl8xxxu,aic8800_fdrv dmesg ะฒัะดะฐัั: [ 14.463892] Bluetooth: hci0: command 0xfc18 tx timeout [ 14.471627] Bluetooth: hci0: BCM: failed to write update baudrate (-110) [ 14.477696] Bluetooth: hci0: Failed to set baudrate [ 14.765636] wlan0: authenticate with 58:f8:5c:58:72:6c (local address=00:c6:a 2:25:44:eb) [ 14.770507] systemd[1]: Finished armbian-ramlog.service - Armbian memory supp orted logging. [ 14.772632] wlan0: send auth to 58:f8:5c:58:72:6c (try 1/3) [ 14.783084] wlan0: authenticated [ 14.791828] wlan0: associate with 58:f8:5c:58:72:6c (try 1/3) [ 14.796409] wlan0: RX AssocResp from 58:f8:5c:58:72:6c (capab=0x411 status=0 aid=4) [ 14.803902] usb 1-2: rtl8xxxu_bss_info_changed: HT supported [ 14.809513] wlan0: associated [ 14.809799] systemd[1]: Starting systemd-journald.service - Journal Service.. . [ 14.972227] systemd-journald[1340]: Collecting audit messages is disabled. [ 15.122032] systemd[1]: Started systemd-journald.service - Journal Service. [ 15.252235] systemd-journald[1340]: Received client request to flush runtime journal. [ 15.342582] systemd-journald[1340]: /var/log/journal/d44cb1f74dea4809a2af30db 6816ca18/system.journal: Realtime clock jumped backwards relative to last journa l entry, rotating. [ 15.410914] systemd-journald[1340]: Rotating system journal. [ 16.511866] Bluetooth: hci0: command 0xfc18 tx timeout [ 16.514129] Bluetooth: hci0: BCM: Reset failed (-110) [ 17.317977] systemd-journald[1340]: Received client request to relinquish /va r/log/journal/d44cb1f74dea4809a2af30db6816ca18 access. [ 950.587521] aic_load_fw: loading out-of-tree module taints kernel. [ 950.600781] aic_bluetooth_mod_init [ 950.606085] RELEASE DATE:2025_0423_71b66e7b [ 950.611193] AICWFDBG(LOGINFO) aicwf_prealloc_init enter [ 950.635622] AICWFDBG(LOGINFO) pre alloc rxbuff list len: 1000 [ 950.640969] usbcore: registered new interface driver aic_load_fw [ 950.678054] AICWFDBG(LOGINFO) rwnx v6.4.3.0 - 1a4b0054d2M (master) [ 950.680449] AICWFDBG(LOGINFO) RELEASE DATE:2025_0423_71b66e7b [ 950.686449] usbcore: registered new interface driver aic8800_fdrv 2) 3) 4) I tried it, it didn't help. 5)
And further, what do you need? I know Armbian and Opensuse use chrony instead of older ntp things. Chrony can serve the time to others, do you need that? If not remove it I would say and keep/use a standard client-only method.
2 captains on the same ship is my first note. Then there is fake-hwclock and maybe an RTC onchip/silicon and/or your own or PCB vendor added RTC module like DS3231. And the battery can be almost empty. Early Debian Trixie had a bug with fake hwclock script, I already removed it years ago on SBCs where I added DS3231, but if you haven't there is the sort of 3rd captain. RPi/Raspbian users had that issue.
keep pushing, this device is not brickable, you can make your trip worry-free -
I think it still makes sense. And in the off chance that you DO find you have some time leftover, it's also nice to tinker and hobby about with. Mine is still running Buster and has not missed a beat since I got the thing - besides some issues with the SATA connector on the top drive and the inability to upgrade RAM. Groetjes,
Can anyone tell me if it's possible to install renegade firmware on a Rasperry Pi build for example? Libre used to host a script for a tool that achieved this but it hasn't been updated since Buster TIA
Hello, I am using an X96 Air (S905X3) with Armbian (6.1.127-ophub) and I can see the hardware decoder working: v4l2-ctl --list-devices Amlogic Video Decoder (platform:meson-vdec): /dev/video0 However, the hardware encoder (VENC) does not appear: ls /dev/video* /dev/video0 ls /dev/amvenc* ls: cannot access '/dev/amvenc*': No such file or directory I want to use ffmpeg with hardware encoding (h264_v4l2m2m) for real-time RTMP streaming, but without the encoder device, it is not possible. Could you please explain: Does this kernel support VENC on S905X3 at all? If not, what changes are required to enable hardware encoder in the kernel? Is there any instructions or topics ? Any guidance or examples would be very helpful. Thank you!
What you need to understand is that whatever money you paid, you paid for the hardware not for software support. So, the hardware vendor does not give you software support. And we are just a bunch of enthusiasts trying to keep our own boards alive. I am sure that you can understand that your understandable nonetheless misguided rant does not necessarily help in making us more enthusiastic. Armbian provides you with some help to maintain your own board yourself. Whenever somebody does so and provides their work back to the community you are in luck and can freeload off of their work. Still doesn't give you the right to make demands and rant. In your case, you are in luck as there is a person donating their expertise and time. Let's see if @NicoD has anything to say about the issue with your board. Buy him a coffee on Paypal or Patreon for the time he already donated to keep YOUR board alive while getting 0 cents from you so far?
try and tell us
Because they sell you the hardware only. Their software support is very poorly made since for the price they cannot afford proper software support and - even more important - maintenance. They leave this burden to - mostly unpaid - random developers across the world like us. At least I'd go for a device with Standard Support which the Ultra and Max hasn't: https://www.armbian.com/download/?device_support=Standard support For the raspberry you would need additional hardware (an AI kit I guess). No clue though about how they both perform in comparsion. For RK3588 you have two choices for now: The rockchip bsp implementation and https://github.com/rockchip-linux/rknn-toolkit2. Or using 6.18 kernel using the reverse engineered Rocket driver and latest bleeding edge mesa to get npu access. I personally did not play with either of these options and have no intention to do so for the moment.
I'm working on a project that utilises AI, GPS, Bluetooth... and i can't decide whether i should choose OPi or RPi. I've been researching for the past couple of days and I'm amazed at what the OPi can do, it's crazy for it's price. But my concern is how little support and community there is out there, idk if it's worth the risk. So if any one worked with it can you please tell me what kind of difficulties have you faced and how similar is it to working with the raspberry?
@Nick A this is updated patch for x98h that enables wifi after warm reboot. 2001-arm64-dts-allwinner-h618-add-x98h.patch
Armbian 25.8.1 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~20fps@720p (low settings) Skyrim SE
