  2. Hi @BipBip1981, thank you for sharing your thoughts. It is positive to hear from people still running these, much appreciated!
  4. I found this thread https://forum.armbian.com/topic/47929-banana-pi-bpi-m2-ultra-with-armbian-stops-load-after-scanning-for-btrfs-filesystems/
  5. I just tried it on a clean system. I didn't know about this package before. It didn't help me, even though it seemed to have the necessary drivers. But maybe they're for a different version of the adapter. https://github.com/armbian/firmware/tree/master/aic8800/USB
  6. Have you installed armbian-firmware-full package?
  7. The Wi-Fi isn't working. I've been trying to get it working for a week now. My hardware is a board from a TV set-top box based on the Amlogic S905X. I have six of them. Armbian OS v26.2, kernel 6.12.59-current-meson64 There are 6 adapters: noname aic8800 ax900 bt5.4 usb (Two types. Some are detected slightly differently by the system, but I want to figure out the first type first (on the left in the photo)) Photo of adapters: https://disk.yandex.ru/i/x37stQnEgEW52gра As far as I can tell, the manufacturer's website: https://www.fenvi.com/index.php/drive.html?id=1&page=2 What I've tried: https://resource.tp-link.com.cn/pc/docCenter/showDocproductId=3343&type=DRIVER&id=1744265707665927 https://www.tendacn.com/ru/material/show/105769 https://www.lulian.cn/download/135.html https://github.com/Wolfdv1/aic8800/ https://github.com/radxapkg/aic8800 https://github.com/geniuskidkanyi/aic8800 https://github.com/nbfalcon/aic8800 https://github.com/shenmintao/aic8800d80 In the related thread https://www.linux.org.ru/forum/linux-hardware/18109581?cid=18151734 , they suggested installing: https://github.com/shenmintao/aic8800d80 , but that didn't help me. What helped: 1) I tried following the instructions from https://linux.brostrend.com/ After that, the adapter worked once, but after a reboot, it didn't work again. I couldn't try again on a clean system. 2) On a clean system, the description from the first post helped once: https://forums.linuxmint.com/viewtopic.php?t=437357 ``` sudo dkms remove aic8800/1.0.8 –all sudo dpkg –remove –force-all aic8800-dkms sudo dpkg –remove –force-all aic8800-dkms sudo rm -rf /var/lib/dkms/aic8800 ``` then installed the deb packages from https://github.com/radxa-pkg/aic8800/releases/tag/4.0%2Bgit20250410.b99ca8b6-3 ``` sudo dpkg -i aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb sudo dpkg -i aic8800-usb-dkms_4.0+git20250410.b99ca8b6-3_all.deb ``` But after two reboots, for some reason, it crashed and I can't retry. I also disable the storage on the Wi-Fi adapter: according to the instructions at https://linux.brostrend.com/advanced/usb_modeswitch/, that is, ``` sudo apt install usb-modeswitch lsusb | grep -E '(0bda|368b|a69c):(8812|b812|c811|b832|c832|1a2b|88df|8d80|8d83|5721|5723)' sudo /usr/sbin/usb_modeswitch -KQ -v a69c -p 5721 ``` When running the lsusb command, the output is: ``` Bus 001 Device 004: ID 368b:8d81 AICSemi AIC 8800D80 ``` I also tried this one because the description says it supports my adapter. They promise support for 368b:* https://github.com/xProbe/aic8800d80-wifi-driver But there are a lot of mistakes there: '''/home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:259:5: warning: no previous prototype for ‘aic_crc32’ [-Wmissing-prototypes] 259 | u32 aic_crc32(u8 p, u32 len, u32 crc) | ^~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c: In function ‘rwnx_plat_flash_bin_upload_android’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:760:15: warning: conversion from ‘long unsigned int’ to ‘u32’ {aka ‘unsigned int’} changes value from ‘18446744073709551615’ to ‘4294967295’ [-Woverflow] 760 | u32 crc = ~0UL; | ^ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c: At top level: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:900:6: warning: no previous prototype for ‘get_fw_path’ [-Wmissing-prototypes] 900 | void get_fw_path(char fw_path){ | ^~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:908:6: warning: no previous prototype for ‘set_testmode’ [-Wmissing-prototypes] 908 | void set_testmode(int val){ | ^~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:912:5: warning: no previous prototype for ‘get_testmode’ [-Wmissing-prototypes] 912 | int get_testmode(void){ | ^~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:916:5: warning: no previous prototype for ‘get_hardware_info’ [-Wmissing-prototypes] 916 | int get_hardware_info(void){ | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:921:5: warning: no previous prototype for ‘get_adap_test’ [-Wmissing-prototypes] 921 | int get_adap_test(void){ | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:925:5: warning: no previous prototype for ‘get_flash_bin_size’ [-Wmissing-prototypes] 925 | int get_flash_bin_size(void) | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:930:5: warning: no previous prototype for ‘get_flash_bin_crc’ [-Wmissing-prototypes] 930 | u32 get_flash_bin_crc(void) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:949:6: warning: no previous prototype for ‘get_userconfig_xtal_cap’ [-Wmissing-prototypes] 949 | void get_userconfig_xtal_cap(xtal_cap_conf_t *xtal_cap) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:962:6: warning: no previous prototype for ‘get_userconfig_txpwr_idx’ [-Wmissing-prototypes] 962 | void get_userconfig_txpwr_idx(txpwr_idx_conf_t *txpwr_idx){ | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:989:6: warning: no previous prototype for ‘get_userconfig_txpwr_ofst’ [-Wmissing-prototypes] 989 | void get_userconfig_txpwr_ofst(txpwr_ofst_conf_t *txpwr_ofst){ | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:1012:6: warning: no previous prototype for ‘rwnx_plat_userconfig_set_value’ [-Wmissing-prototypes] 1012 | void rwnx_plat_userconfig_set_value(char *command, char *value){ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:1060:6: warning: no previous prototype for ‘rwnx_plat_userconfig_parsing’ [-Wmissing-prototypes] 1060 | void rwnx_plat_userconfig_parsing(char *buffer, int size){ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_usb.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:174:18: warning: no previous prototype for ‘rwnx_cmd_malloc’ [-Wmissing-prototypes] 174 | struct rwnx_cmd *rwnx_cmd_malloc(void){ | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:203:6: warning: no previous prototype for ‘rwnx_cmd_free’ [-Wmissing-prototypes] 203 | void rwnx_cmd_free(struct rwnx_cmd *cmd){ | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:213:5: warning: no previous prototype for ‘rwnx_init_cmd_array’ [-Wmissing-prototypes] 213 | int rwnx_init_cmd_array(void){ | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:228:6: warning: no previous prototype for ‘rwnx_free_cmd_array’ [-Wmissing-prototypes] 228 | void rwnx_free_cmd_array(void){ | ^~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_rx.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_txrxif.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_usb.c:1375:5: warning: no previous prototype for ‘aicfw_download_fw_8800’ [-Wmissing-prototypes] 1375 | int aicfw_download_fw_8800(struct aic_usb_dev *usb_dev){ | ^~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_usb.c:1650:5: warning: no previous prototype for ‘aicfw_download_fw’ [-Wmissing-prototypes] 1650 | int aicfw_download_fw(struct aic_usb_dev *usb_dev) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_rx.c:1655:6: warning: no previous prototype for ‘rwnx_rx_handle_msg’ [-Wmissing-prototypes] 1655 | void rwnx_rx_handle_msg(struct rwnx_hw *rwnx_hw, struct ipc_e2a_msg *msg) | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_rx.c:1667:6: warning: no previous prototype for ‘rwnx_rx_handle_print’ [-Wmissing-prototypes] 1667 | void rwnx_rx_handle_print(struct rwnx_hw *rwnx_hw, u8 *msg, u32 len) | ^~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_utils.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth_cmds.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_cmds.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_irqs.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_utils.c:23:5: warning: no previous prototype for ‘rwnx_init_aic’ [-Wmissing-prototypes] 23 | int rwnx_init_aic(struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_cfgfile.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_cmds.c:339:6: warning: no previous prototype for ‘cmd_mgr_task_process’ [-Wmissing-prototypes] 339 | void cmd_mgr_task_process(struct work_struct *work) | ^~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c: In function ‘aicfw_download_fw_8800d80’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c:375:31: warning: unused variable ‘patch_info’ [-Wunused-variable] 375 | struct aicbt_patch_info_t patch_info = { | ^~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c:374:31: warning: unused variable ‘head’ [-Wunused-variable] 374 | struct aicbt_patch_table *head = NULL; | ^~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c: At top level: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c:340:12: warning: ‘aicbt_ext_patch_data_load’ defined but not used [-Wunused-function] 340 | static int aicbt_ext_patch_data_load(struct aic_usb_dev *usb_dev, struct aicbt_patch_info_t *patch_info) | ^~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80x2.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_strs.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_irqs.c:21:13: warning: no previous prototype for ‘rwnx_irq_hdlr’ [-Wmissing-prototypes] 21 | irqreturn_t rwnx_irq_hdlr(int irq, void *dev_id) | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_irqs.c:34:6: warning: no previous prototype for ‘rwnx_task’ [-Wmissing-prototypes] 34 | void rwnx_task(unsigned long data) | ^~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_tx.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/md5.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_txq.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_rx_prealloc.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:344:6: warning: no previous prototype for ‘rwnx_rx_data_skb_resend’ [-Wmissing-prototypes] 344 | void rwnx_rx_data_skb_resend(struct rwnx_hw *rwnx_hw, struct rwnx_vif *rwnx_vif, struct sk_buff *skb) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1533:5: warning: no previous prototype for ‘reord_flush_tid’ [-Wmissing-prototypes] 1533 | int reord_flush_tid(struct aicwf_rx_priv *rx_priv, struct sk_buff *skb, u8 tid) | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1793:6: warning: no previous prototype for ‘reord_rxframes_process’ [-Wmissing-prototypes] 1793 | bool reord_rxframes_process(struct aicwf_rx_priv *rx_priv, struct reord_ctrl *preorder_ctrl, int bforced) | ^~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1829:6: warning: no previous prototype for ‘reord_rxframes_ind’ [-Wmissing-prototypes] 1829 | void reord_rxframes_ind(struct aicwf_rx_priv *rx_priv, | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1915:5: warning: no previous prototype for ‘reord_process_unit’ [-Wmissing-prototypes] 1915 | int reord_process_unit(struct recv_msdu *pframe, struct aicwf_rx_priv *rx_priv, struct sk_buff *skb, u16 seq_num, u8 tid, u8 forward, u8 is_amsdu) | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:2115:6: warning: no previous prototype for ‘remove_sec_hdr_mgmt_frame’ [-Wmissing-prototypes] 2115 | void remove_sec_hdr_mgmt_frame(struct hw_rxhdr *hw_rxhdr,struct sk_buff *skb) | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:2196:6: warning: no previous prototype for ‘defrag_timeout_cb’ [-Wmissing-prototypes] 2196 | void defrag_timeout_cb(struct timer_list *t) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_tx.c:1244:5: warning: no previous prototype for ‘intf_tx’ [-Wmissing-prototypes] 1244 | int intf_tx(struct rwnx_hw *priv,struct msg_buf *msg) | ^~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.o In file included from ./include/linux/string.h:390, from ./include/linux/dma-mapping.h:7, from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:10: In function ‘fortify_memcpy_chk’, inlined from ‘rwnx_rx_add_rtap_hdr’ at /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1365:9, inlined from ‘rwnx_rx_monitor’ at /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1405:5, inlined from ‘rwnx_rxdataind_aicwf’ at /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:2335:13: ./include/linux/fortify-string.h:571:25: warning: call to ‘__write_overflow_field’ declared with attribute warning: detected write beyond size of field (1st parameter); maybe use struct_group()? [-Wattribute-warning] 571 | write_overflow_field(p_size_field, size); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_txq_prealloc.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_txq.c:154:6: warning: no previous prototype for ‘rwnx_txq_flush’ [-Wmissing-prototypes] 154 | void rwnx_txq_flush(struct rwnx_hw *rwnx_hw, struct rwnx_txq *txq) | ^~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_txq_prealloc.c:13:7: warning: no previous prototype for ‘aicwf_prealloc_txq_alloc’ [-Wmissing-prototypes] 13 | void aicwf_prealloc_txq_alloc(size_t size) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_txq_prealloc.c:50:6: warning: no previous prototype for ‘aicwf_prealloc_txq_free’ [-Wmissing-prototypes] 50 | void aicwf_prealloc_txq_free(void) | ^~~~~~~~~~~~~~~~~~~~~~~ LD [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_load_fw.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_mod_params.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_mesh.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:552:6: warning: no previous prototype for ‘rwnx_skb_align_8bytes’ [-Wmissing-prototypes] 552 | void rwnx_skb_align_8bytes(struct sk_buff skb){ | ^~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:619:6: warning: no previous prototype for ‘rwnx_frame_parser’ [-Wmissing-prototypes] 619 | void rwnx_frame_parser(char tag, char data, unsigned long len){ | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:1157:6: warning: no previous prototype for ‘rwnx_update_mesh_power_mode’ [-Wmissing-prototypes] 1157 | void rwnx_update_mesh_power_mode(struct rwnx_vif *vif) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_defs.h:32, from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:25: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_compat.h:395:5: warning: no previous prototype for ‘rwnx_select_queue’ [-Wmissing-prototypes] 395 | rwnx_select_queue(dev, skb, sb_dev) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:1736:5: note: in expansion of macro ‘rwnx_select_queue’ 1736 | u16 rwnx_select_queue(struct net_device *dev, struct sk_buff *skb, | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:2029:6: warning: no previous prototype for ‘aicwf_p2p_alive_timeout’ [-Wmissing-prototypes] 2029 | void aicwf_p2p_alive_timeout(struct timer_list *t) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:2708:5: warning: no previous prototype for ‘rwnx_send_check_p2p’ [-Wmissing-prototypes] 2708 | int rwnx_send_check_p2p(struct cfg80211_scan_request *param){ | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:3564:6: warning: no previous prototype for ‘apm_staloss_work_process’ [-Wmissing-prototypes] 3564 | void apm_staloss_work_process(struct work_struct *work) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:3678:6: warning: no previous prototype for ‘apm_probe_sta_work_process’ [-Wmissing-prototypes] 3678 | void apm_probe_sta_work_process(struct work_struct *work) | ^~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:4216:5: warning: no previous prototype for ‘rwnx_cfg80211_set_monitor_channel’ [-Wmissing-prototypes] 4216 | int rwnx_cfg80211_set_monitor_channel(struct wiphy *wiphy, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:4228:5: warning: no previous prototype for ‘rwnx_cfg80211_probe_client’ [-Wmissing-prototypes] 4228 | int rwnx_cfg80211_probe_client(struct wiphy *wiphy, struct net_device *dev, | ^~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:4265:6: warning: no previous prototype for ‘rwnx_cfg80211_mgmt_frame_register’ [-Wmissing-prototypes] 4265 | void rwnx_cfg80211_mgmt_frame_register(struct wiphy *wiphy, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:4969:5: warning: no previous prototype for ‘rwnx_cfg80211_channel_switch’ [-Wmissing-prototypes] 4969 | int rwnx_cfg80211_channel_switch(struct wiphy *wiphy, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:5311:5: warning: no previous prototype for ‘rwnx_cfg80211_change_bss’ [-Wmissing-prototypes] 5311 | int rwnx_cfg80211_change_bss(struct wiphy *wiphy, struct net_device *dev, | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:8438:5: warning: no previous prototype for ‘rwnx_ic_system_init’ [-Wmissing-prototypes] 8438 | int rwnx_ic_system_init(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:8477:5: warning: no previous prototype for ‘rwnx_ic_rf_init’ [-Wmissing-prototypes] 8477 | int rwnx_ic_rf_init(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:8516:6: warning: no previous prototype for ‘aic_ipc_setting’ [-Wmissing-prototypes] 8516 | void aic_ipc_setting(struct rwnx_vif rwnx_vif){ | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_mod_params.c:270:6: warning: no previous prototype for ‘rwnx_get_countrycode_channels’ [-Wmissing-prototypes] 270 | void rwnx_get_countrycode_channels(struct wiphy wiphy, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_pci.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:762:5: warning: no previous prototype for ‘rwnx_request_firmware_common’ [-Wmissing-prototypes] 762 | int rwnx_request_firmware_common(struct rwnx_hw rwnx_hw, u32 buffer, const char filename) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:773:6: warning: no previous prototype for ‘rwnx_release_firmware_common’ [-Wmissing-prototypes] 773 | void rwnx_release_firmware_common(u32 buffer) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:790:5: warning: no previous prototype for ‘rwnx_plat_bin_fw_upload_2’ [-Wmissing-prototypes] 790 | int rwnx_plat_bin_fw_upload_2(struct rwnx_hw *rwnx_hw, u32 fw_addr, | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:1959:5: warning: no previous prototype for ‘rwnx_atoi2’ [-Wmissing-prototypes] 1959 | int rwnx_atoi2(char *value, int c_len) | ^~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:1986:5: warning: no previous prototype for ‘rwnx_atoi’ [-Wmissing-prototypes] 1986 | int rwnx_atoi(char *value) | ^~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:2334:6: warning: no previous prototype for ‘get_userconfig_xtal_cap’ [-Wmissing-prototypes] 2334 | void get_userconfig_xtal_cap(xtal_cap_conf_t *xtal_cap) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:2343:6: warning: no previous prototype for ‘rwnx_plat_nvram_set_value’ [-Wmissing-prototypes] 2343 | void rwnx_plat_nvram_set_value(char *command, char *value) | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:2649:6: warning: no previous prototype for ‘rwnx_plat_nvram_set_value_8800d80x2’ [-Wmissing-prototypes] 2649 | void rwnx_plat_nvram_set_value_8800d80x2(char *command, char *value) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:2872:6: warning: no previous prototype for ‘rwnx_plat_userconfig_parsing_8800d80x2’ [-Wmissing-prototypes] 2872 | void rwnx_plat_userconfig_parsing_8800d80x2(char *buffer, int size) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_dini.o In function ‘rwnx_plat_patch_load’, inlined from ‘rwnx_platform_on’ at /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:3563:11: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:1589:9: warning: ‘sprintf’ argument 3 overlaps destination object ‘aic_fw_path’ [-Wrestrict] 1589 | sprintf(aic_fw_path, «%s/%s», aic_fw_path, «aic8800DC»); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c: In function ‘rwnx_platform_on’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:51:13: note: destination object referenced by ‘restrict’-qualified argument 1 was declared here 51 | extern char aic_fw_path[FW_PATH_MAX_LEN]; | ^~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_pci.c:85:5: warning: no previous prototype for ‘rwnx_pci_register_drv’ [-Wmissing-prototypes] 85 | int rwnx_pci_register_drv(void) | ^~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_pci.c:90:6: warning: no previous prototype for ‘rwnx_pci_unregister_drv’ [-Wmissing-prototypes] 90 | void rwnx_pci_unregister_drv(void) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_dini.c:105:5: warning: no previous prototype for ‘rwnx_cfpga_irq_enable’ [-Wmissing-prototypes] 105 | int rwnx_cfpga_irq_enable(struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_dini.c:129:5: warning: no previous prototype for ‘rwnx_cfpga_irq_disable’ [-Wmissing-prototypes] 129 | int rwnx_cfpga_irq_disable(struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_v7.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/ipc_host.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_tdls.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/regdb.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/md5.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_vendor.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800dc.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_vendor.c:41:5: warning: no previous prototype for ‘aic_dev_start_mkeep_alive’ [-Wmissing-prototypes] 41 | int aic_dev_start_mkeep_alive(struct rwnx_hw *rwnx_hw, struct rwnx_vif *rwnx_vif, | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_vendor.c:69:5: warning: no previous prototype for ‘aic_dev_stop_mkeep_alive’ [-Wmissing-prototypes] 69 | int aic_dev_stop_mkeep_alive(struct rwnx_hw *rwnx_hw, struct rwnx_vif *rwnx_vif, u8 mkeep_alive_id) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_vendor.c:1064:5: warning: no previous prototype for ‘aicwf_vendor_init’ [-Wmissing-prototypes] 1064 | int aicwf_vendor_init(struct wiphy *wiphy) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.c:235:14: warning: no previous prototype for ‘command_strtoul’ [-Wmissing-prototypes] 235 | unsigned int command_strtoul(const char *cp, char **endp, unsigned int base) | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.c:268:5: warning: no previous prototype for ‘str_starts’ [-Wmissing-prototypes] 268 | int str_starts(const char *str, const char *start) | ^~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.c:1614:5: warning: no previous prototype for ‘handle_private_cmd’ [-Wmissing-prototypes] 1614 | int handle_private_cmd(struct net_device *net, char *command, u32 cmd_len) | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.c:1730:6: warning: no previous prototype for ‘set_mon_chan’ [-Wmissing-prototypes] 1730 | void set_mon_chan(struct rwnx_vif *vif, char *parameter) | ^~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800dc.c:2637:5: warning: no previous prototype for ‘aicwf_patch_var_config_8800dc’ [-Wmissing-prototypes] 2637 | int aicwf_patch_var_config_8800dc(struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800dc.c:3585:5: warning: no previous prototype for ‘set_bbpll_config’ [-Wmissing-prototypes] 3585 | int set_bbpll_config(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c:19:5: warning: no previous prototype for ‘aicwf_set_rf_config_8800d80’ [-Wmissing-prototypes] 19 | int aicwf_set_rf_config_8800d80(struct rwnx_hw *rwnx_hw, struct mm_set_rf_calib_cfm *cfm) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c:39:9: warning: no previous prototype for ‘rwnx_plat_userconfig_load_8800d80’ [-Wmissing-prototypes] 39 | int rwnx_plat_userconfig_load_8800d80(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c: In function ‘rwnx_plat_userconfig_load_8800d80’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c:57:13: warning: ‘sprintf’ argument 3 overlaps destination object ‘aic_fw_path’ [-Wrestrict] 57 | sprintf(aic_fw_path, «%s/%s», aic_fw_path, «aic8800D80»); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c:11:13: note: destination object referenced by ‘restrict’-qualified argument 1 was declared here 11 | extern char aic_fw_path[200]; | ^~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_radar.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/usb_host.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c:17:5: warning: no previous prototype for ‘aicwf_set_rf_config_8800d80x2’ [-Wmissing-prototypes] 17 | int aicwf_set_rf_config_8800d80x2(struct rwnx_hw *rwnx_hw, struct mm_set_rf_calib_cfm *cfm) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c:37:9: warning: no previous prototype for ‘rwnx_plat_userconfig_load_8800d80x2’ [-Wmissing-prototypes] 37 | int rwnx_plat_userconfig_load_8800d80x2(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c: In function ‘rwnx_plat_userconfig_load_8800d80x2’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c:43:5: warning: ‘sprintf’ argument 3 overlaps destination object ‘aic_fw_path’ [-Wrestrict] 43 | sprintf(aic_fw_path, «%s/%s», aic_fw_path, «aic8800D80X2»); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c:8:13: note: destination object referenced by ‘restrict’-qualified argument 1 was declared here 8 | extern char aic_fw_path[200]; | ^~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_txrxif.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_radar.c:904:22: warning: no previous prototype for ‘pri_detector_init’ [-Wmissing-prototypes] 904 | struct pri_detector *pri_detector_init(struct dfs_pattern_detector *dpd, | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_radar.c:1073:6: warning: no previous prototype for ‘print_radar_detect_info’ [-Wmissing-prototypes] 1073 | void print_radar_detect_info(struct pri_detector *pde, struct pri_sequence *ps) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:17:6: warning: no previous prototype for ‘intf_tcp_drop_msg’ [-Wmissing-prototypes] 17 | void intf_tcp_drop_msg(struct rwnx_hw *priv, | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:30:6: warning: no previous prototype for ‘tcp_ack_timeout’ [-Wmissing-prototypes] 30 | void tcp_ack_timeout(struct timer_list *t) | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:123:5: warning: no previous prototype for ‘tcp_check_quick_ack’ [-Wmissing-prototypes] 123 | int tcp_check_quick_ack(unsigned char *buf, | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:216:5: warning: no previous prototype for ‘tcp_check_ack’ [-Wmissing-prototypes] 216 | int tcp_check_ack(unsigned char *buf, | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:260:5: warning: no previous prototype for ‘tcp_ack_match’ [-Wmissing-prototypes] 260 | int tcp_ack_match(struct tcp_ack_manage *ack_m, | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:288:6: warning: no previous prototype for ‘tcp_ack_update’ [-Wmissing-prototypes] 288 | void tcp_ack_update(struct tcp_ack_manage *ack_m) | ^~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:313:5: warning: no previous prototype for ‘tcp_ack_alloc_index’ [-Wmissing-prototypes] 313 | int tcp_ack_alloc_index(struct tcp_ack_manage *ack_m) | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:352:5: warning: no previous prototype for ‘tcp_ack_handle’ [-Wmissing-prototypes] 352 | int tcp_ack_handle(struct msg_buf *new_msgbuf, | ^~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:447:5: warning: no previous prototype for ‘tcp_ack_handle_new’ [-Wmissing-prototypes] 447 | int tcp_ack_handle_new(struct msg_buf *new_msgbuf, | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/usb_host.c:35:30: warning: no previous prototype for ‘aicwf_usb_host_txdesc_get’ [-Wmissing-prototypes] 35 | volatile struct txdesc_host *aicwf_usb_host_txdesc_get(struct usb_host_env_tag *env, const int queue_idx) | ^~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_usb.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_txrxif.c:1300:17: warning: no previous prototype for ‘rxbuff_queue_penq’ [-Wmissing-prototypes] 1300 | struct rx_buff *rxbuff_queue_penq(struct rx_frame_queue *pq, struct rx_buff *p) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_usb.c:158:6: warning: no previous prototype for ‘rwnx_stop_sta_all_queues’ [-Wmissing-prototypes] 158 | void rwnx_stop_sta_all_queues(struct rwnx_sta *sta, struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_usb.c:168:6: warning: no previous prototype for ‘rwnx_wake_sta_all_queues’ [-Wmissing-prototypes] 168 | void rwnx_wake_sta_all_queues(struct rwnx_sta *sta, struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c: In function ‘aicwf_get_iwe_stream_mac_addr’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c:403:25: warning: the comparison will always evaluate as ‘true’ for the address of ‘bssid’ will never be NULL [-Waddress] 403 | if(scan_re->bss && &scan_re->bss->bssid[0]){ | ^~ In file included from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_defs.h:20, from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.h:16, from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c:10: ./include/net/cfg80211.h:2980:12: note: ‘bssid’ declared here 2980 | u8 bssid[ETH_ALEN]; | ^~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c: At top level: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c:717:5: warning: no previous prototype for ‘aic_get_sec_ie’ [-Wmissing-prototypes] 717 | int aic_get_sec_ie(u8 *in_ie, uint in_len, u8 *rsn_ie, u16 *rsn_len, u8 *wpa_ie, u16 *wpa_len) | ^~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_usb.c:1964:6: warning: no previous prototype for ‘aicwf_usb_cancel_all_urbs’ [-Wmissing-prototypes] 1964 | void aicwf_usb_cancel_all_urbs(struct aic_usb_dev *usb_dev){ | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c:830:4: warning: no previous prototype for ‘aicwf_get_is_wps_ie’ [-Wmissing-prototypes] 830 | u8 aicwf_get_is_wps_ie(u8 *ie_ptr, uint *wps_ielen) | ^~~~~~~~~~~~~~~~~~~ '''
  8. I recently updated my Orange-Pi-PC2 to Debian 13 (trixie). Image: "Armbian_community_26.2.0-trunk.7_Orangepipc2_trixie_current_6.12.58_minimal.img.xz". Everything works now, and the issue mentioned above no longer exists! Maybe it will be useful to someone... However, I still had to make some adjustments to "/boot/dtb/allwinner/sun50i-h5-orangepi-pc2.dtb" sun50i-h5-orangepi-pc2.dtb: Overclocked the processor to 1.44 GHz (new board revision 1.368 GHz CPU!); Similar to the other firmware versions, I configured the red LED as a power indicator (constantly lit) and the green LED as a heartbeat indicator. For everything to work, you also need to correct the parameter MAX_SPEED=1440000 in the file "/etc/default/cpufrequtils" cpufrequtils.
  9. No need to recompile, rk322x already have had all the right bits in the right place for years. Everything is written down in the first page of the thread for rk332x tv boxes (What works: ---> Hardware video acceleration) in the hope people read it.
  10. Good that you posted serial console output. A bit more and text (starting at power on when U-Boot starts) would be clearer, but I think the 2 top lines with 'Android' mentioned already indicate what is wrong I think; ROCK3C has SPI-flash where also the bootloader (U-Boot usually) can be stored and this has priority over SD-card bootloader. So it seems older/incompatible Android U-Boot variant in the SPI-flash loads Linux and as you use mainline Linux kernel, this won't work correctly as you see. On my ROCK3A, almost similar SoC I get all sorts of strange crashes/hangs in that situation. So use MaskROM mode to wipe SPI-flash or write a correct U-Boot version to it; see https://docs.radxa.com/en/rock3/rock3c/low-level-dev/3c-maskrom?host_os=Linux_MacOS Other option maybe is to boot with an image that has vendor kernel (I use 6.1.115 on my ROCK3A with legacy U-Boot) so then the board can be operated via serial console and from there write the SPI-flash with dd or flashcp (see /dev/mtd*).
  11. Thank you @KhanhDTP. I think I have a pretty good handle on how (and your post on that thread was in particular very helpful, thank you). It looks like a lot of people here are desktop optimized. My plan is headless, so expectation is 25.11.1 / 6.1 and libMali route but with RKNN (XFCE only for occasional desktop, Gnome is too hungry, XFCE + X11 + software rendering is fine on rare occasions I'd need it). I think the question I was trying to ask is more along the lines of understanding what to expect for the default, and if it made sense to enable one of the drivers by default, but I'm realizing there are proprietary dependencies and enough obscure use cases that this gets more challenging. Thanks to everyone for all of the thoughts, hard to imagine navigating all of this without your contributions.
  12. Noble image didn't boot on Orange pi 4A
  13. I have a unit that I am unable to boot from SD card as it has no such physical device. Using a terminal emulator in Android I can see partitions being loaded, and have managed to get several "partitions" (mmcblk01p01 to p20) copied off to a flash drive. These turn out to be data files, so I can't load/modify them on a VM. I had hoped to find the boot.scr/boot.cmd file and modify it to force it to mount from USB in the first instance. The unit has 2 USB ports. There is a push switch that I had to unglue. It runs Android when pushed in, and I get a black screen when it is in the OUT position, so I'm assuming that the OUT position puts the unit into USB burning mode, or whatever. I have ordered UART header pins and adapter so will be able to do more research once those are in place. From your analysis above, can you recommend a way of forcing a boot from USB using the UART serial interface (I don't see a recover-from-usb U-Boot command)? I have an armbian s905x image all ready to go. Ideal situation would be that I get the Armbian running from USB then flash the eMMC. Any help gratefully received, Best, John
  14. I did a new build this time removind BTRfs from kernel but I still get stucked on ... Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems I dont see how can I remove that FS since I never use it in my TV Box?
  15. Armbian provides vanilla Debian (or Ubuntu) Cinnamon. In general, touch to the user-space part is minimal, so you are running plain Debian Cinnamon desktop, more or less. And as packages comes from there, bugs follow. Armbian team don't have resources for dealing with desktop. Minor problems only. And as it was already mentioned Exactly. I saw this (recently introduced) problem but since I have absolutely no idea where to look, I removed Cinnamon images from upcoming release. We don't touch Cinnamon nor other desktops beyond installing wallpaper. Probably tasksel installed variant will likely be broken too.
  16. Yes. It is only enabled / working with 6.1 and desktop (Gnome) builds. For mainline based, perhaps 6.18.y ...
  17. @gpupoor You want to set up GPU Acceleration, right? Have you read this post yet?
  18. I've successfully booted Armbian from USB following the tutorial above, and I've managed to write Armbian from the USB drive to the eMMC. Now I want to create an Armbian firmware that can be directly flashed to the H96 M9/S eMMC using RKDevTool.exe, but I'm not very smart - even simple things take me a very long time to figure out. If any of you have this, please share it. If I manage to figure it out, I'll also share my findings.
  19. "no". but don't trust anybody, that was the point. you don't know me. moreover, you probably already have on your stock firmware, like a lot of chinese android tvbox
  20. Yesterday
  21. I have nothing to complain about. glmark2-wayland-odroid-m2.log vkmark-wayland-odroid-m2.log
  22. In case everyone else is interested: the easiest way I found to get a running system with the latest kernel is Start with an image based upon the vendor 6.1 kernel (I used "Armbian_25.8.2_Orangepi5_noble_vendor_6.1.115_minimal.img.xz") Once it's running, launch "armbian-config" Choose "System", then the entry to install a different kernel Now you can select the latest kernel, in my case "6.18-RC5" Just for the records, I was interested in trying the latest kernel because, with the vendor-provided 6.1 kernel, my NVMe drive was limited to 400 MB/s ("downgraded link speed"). Unfortunately, the same applies to the latest 6.18-RC5: probably a DTS issue, but I don't know how to fix it, so be it. Best, Fernando
  23. Hello, I just flashed the latest minimal img from the github releases (Armbian_community_26.2.0-trunk.7_Rock-3c_trixie_current_6.12.58_minimal.img.xz) but I see no output on hdmi and it gets stuck at login, nothing I type works.
  24. Digging deeper @Igor... I tried 25.11.1 Noble Gnome Vendor 6.1.115 from today, and am also seeing Mali-G610. However it's [disabled for xfce](https://github.com/armbian/build/blob/d2e208ace18b8003f926057ddfc038f8cce0bce0/extensions/mesa-vpu.sh#L19). I'm also reading some conflicting info so guessing there have been other conversations I'm not aware of. I started another post to try and better understand expectations.
  25. I understand that panthor is not supported for wayland but in that case I would expect libmali to fill in... but I ended up with lvmpipe. The overlay along with another recent post led me to believe that panthor was the expected default and libmali was an artifact, but I'm now questioning that after finding a thread identifying use cases where libmali can be preferred and a comment suggesting panthor wouldn't be available until 6.13. As a result, I am now questioning if there is a reason that software acceleration is the default and the user is expected to determine which path they want to go? I know support for the hardware has been slow going so I understand that it's not well supported yet, but hoping to get a better handle on expectations. Is there an expected default for a Rockchip RK3588 SoC with the Mali‑G610 GPU? Does it vary between 6.1/6.12 and the desktop/server builds?
  26. I never said it was a Debian issue (you failed to mention which userspace you were running in your original post, btw). The issue is with whereever you got your authelia package from (which you also failed to mention). You also failed to mention what error exactly you are running into. But yes, you are right, Debian will and can do nothing about it. Basically the same is true for Armbian, the symlink is there for a reason and there to stay. You are in the wrong place to get this fixed.
