Package armbian-config is not available
Werner replied to Dyfcom's topic in Software, Applications, Userspace
Yes. Checkout this PR and build yourself. https://www.google.com/search?q=github+checkout+pr https://docs.armbian.com/Developer-Guide_Build-Preparation/ -
Dyfcom replied to Dyfcom's topic in Software, Applications, Userspace
How can I test this? I am not so familiar with changes in github 😅 Edit: I think I need to build it myself? - Today
Would probably use it to replace one of my home or office servers. Mostly RPIs, 3, 4 and 5 (would probably replace the 3b or the 3b+ although none of them is struggling). I currently run Nextcloud, Gitlab-CE, Stirling-pdf, tracd and a number of other smaller services, all managed with Portainer and started up initially by docker-compose files. It's unbelievable what these little guys can provide and at what cost.
Igor replied to Dyfcom's topic in Software, Applications, Userspace
Perhaps this is a solution? https://github.com/armbian/build/pull/6652 -
Hi, I've been running the OMV7 latest with the armbian headless latest. I've set the power button for powering the system off in the OMV's gui. When the system is "on" I can power the system down by short press on the power button, the system powers off after couple of seconds (so hopefully a clean shut down), the power led and network led get off, but the USB HDD (320GB WD) still shows activity after power down - the activity led on it blinks (like 3-5 blinks per second) and from time to time I can hear a light click. The disk does not spin, however. I've been using a battery backup (3.7V lion) wired to the BPi M1 board permanently (there is an onboard controller for the battery backup). What needs to be set in order the USB HDD stops showing activity after the power down?
Hello, I installed a fresh `Armbian_23.02.2_Nanopim4v2_bullseye_current_5.15.93_minimal.img.xz` for the Nanopi M4v2. But when I try to install `armbian-config' after an `apt update`, I got following error: root@nanopim4v2:~# apt install armbian-config Reading package lists... Done Building dependency tree... Done Reading state information... Done Package armbian-config is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'armbian-config' has no installation candidate also checked the apt-cache: apt-cache showpkg armbian-config Package: armbian-config Versions: Reverse Depends: armbian-bsp-cli-nanopim4v2,armbian-config Dependencies: Provides: Reverse Provides: Also tried the `3rd party Debian based distributions`from https://github.com/armbian/config, but got the same error. There is also a second unsolved thread: I stay now with the non-minimal, but is there a solution for future using of the minimal with armbian-config? Thanks and greeting!
- Update: Kernel 6.1 ✔️ HDMI Audio ✔️ WIFI 2.4 + 5ghz ✔️ Ethernet ❌ Bluetooth ❌ NPU ❌ VPU ❌ GPU Wifi-K610: https://drive.google.com/file/d/1B1LmAylalETcnBEWiPiJHL0MjK5xlIV4/view cd /lib/firmware/brcm/ sudo wget https://github.com/CoreELEC/brcmfmac_sdio-firmware-aml/raw/master/firmware/brcm/fw_bcm4335b0_ag.bin sudo ln -s fw_bcm4335b0_ag.bin brcmfmac4335-sdio.h96-TVbox,rk3566.bin sudo reboot now nmcli dev wifi sudo rmmod brcmfmac_wcc brcmfmac brcmutil modprobe brcmfmac - Image: Updated K610 test image: https://drive.google.com/file/d/1G3ne0N0DX-sKNr36uqGhnaVXHt6sqBMz/view?usp=sharing - BaseFiles: RK3566-H96-MAX-VENDOR-61-V3: https://drive.google.com/file/d/1Y5sGIE8uAo-eASNvkBkZ6SX3vdpiBFRU/view?usp=sharing edit Rockchip U-boot Legacy 4.19 DTS: https://github.com/hqnicolas/u-boot/blob/next-dev-v2024.03/arch/arm/dts/rk3566-h96.dts edit Rockchip U-boot Legacy 4.19 DEFCONFIG: https://github.com/hqnicolas/u-boot/blob/next-dev-v2024.03/configs/h96-rk3566_defconfig dmesg before install wifi & BT dmesg short: Full dmesg: -
Fresh install, package armbian-config is unavailable
Werner replied to wrobelda's topic in Allwinner sunxi
Did you do code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } apt update beforehand? Images usually are shipped with empty lists to avoid having outdated ones packed which also increase image size. -
Dyfcom replied to wrobelda's topic in Allwinner sunxi
Got the same problem with `Armbian_23.02.2_Nanopim4v2_bullseye_current_5.15.93_minimal.img.xz` for the Nanopi M4v2. Did you get it fixed? root@nanopim4v2:~# apt install armbian-config Reading package lists... Done Building dependency tree... Done Reading state information... Done Package armbian-config is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'armbian-config' has no installation candidate apt-cache showpkg armbian-config Package: armbian-config Versions: Reverse Depends: armbian-bsp-cli-nanopim4v2,armbian-config Dependencies: Provides: Reverse Provides: Greeting -
The video processor unit can decode your file but the rendering unit (GPU) can't display it. You can view your file at lower resolution and so you have half of 4k capabilities. Even at 1080p you get low FPS because the CPU can't resize fast enough. You need rk3588 or mabe rk3576 to view full 4k. An rk3566 with stand alone kodi can do the job but librelec or corelec are not supported for this CPU. Odroid M1 have this on its forum.
Linux cubieboard2 6.1.63-current-sunxi #1 SMP Mon Nov 20 11:52:19 CET 2023 armv7l armv7l armv7l GNU/Linux is build and runs good so far (stable version, jammy). ..at the moment I'm fighting with the keyboard mapping, got an german keyboard w/o the "<>|" key.. Tomorrow I'll look if I can enable the 2nd uart.. Regards, Holm
However RK3528 seems to be ok with 2160p (not p60 by the way). NewPipe plays the video just fine.Many users seem to suggest that standard 4k clips with reasonable bitrate are fine, it is just that the screen resolution is hardcoded in some way onto the device. It's really strange Ok then, if it's just a lie, then more people should hear about this, since all manufacturers claim these boxes are able to play 4k, I think most users don't even realize, that when they are watching 4k it is actuallu FullHD
I don't believe mainline kernels support the NAND, and aren't likely to as it is flaky. I would try whatever the current image is and see what you get.
@specs A current 6.9.0 edge kernel (collabora version) is availale on beta.armbian.com (linux-dtb and linux-headers are available too). They can be downloaded to the filesystem using 'wget <URL>' and installed via 'dpkg -i linux*' (without armbian-config). After updating Armbian 24.2.1 (minimal) from linux 5.10.160 to 6.9.0: (system on emmc, data on a 4TB sata ssd (m.2)) ____ _ ____ ____ | _ \ ___ ___| | __ | ___|| __ ) | |_) / _ \ / __| |/ / |___ \| _ \ | _ < (_) | (__| < ___) | |_) | |_| \_\___/ \___|_|\_\ |____/|____/ Welcome to Armbian 24.2.1 Bookworm with Linux 6.9.0-collabora-rockchip-rk3588 No end-user support: community creations System load: 1% Up time: 27 min Memory usage: 3% of 7.35G IP: 192.168.xx.31 CPU temp: 45°C Usage of /: 33% of 14G I tried a network performance benchmark and it rocks: 2x 2.34 Gbits/s (bidirectional) ! (armbian-hardware-optimize disabled) # ./iperf3 -c 192.168.xx.31 -p 5201 (client -> rock 5b) Connecting to host 192.168.xx.31, port 5201 [ 5] local 192.168.xx.54 port 63943 connected to 192.168.xx.31 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.01 sec 284 MBytes 2.37 Gbits/sec [ 5] 1.01-2.00 sec 280 MBytes 2.35 Gbits/sec [ 5] 2.00-3.00 sec 280 MBytes 2.35 Gbits/sec [ 5] 3.00-4.00 sec 281 MBytes 2.35 Gbits/sec [ 5] 4.00-5.00 sec 281 MBytes 2.35 Gbits/sec [ 5] 5.00-6.01 sec 282 MBytes 2.35 Gbits/sec [ 5] 6.01-7.00 sec 280 MBytes 2.35 Gbits/sec [ 5] 7.00-8.00 sec 281 MBytes 2.35 Gbits/sec [ 5] 8.00-9.00 sec 281 MBytes 2.35 Gbits/sec [ 5] 9.00-10.00 sec 280 MBytes 2.35 Gbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-10.00 sec 2.74 GBytes 2.36 Gbits/sec sender [ 5] 0.00-10.01 sec 2.74 GBytes 2.35 Gbits/sec receiver # ./iperf3 -c 192.168.xx.31 -p 5201 -R (rock 5b -> client) Connecting to host 192.168.xx.31, port 5201 Reverse mode, remote host 192.168.xx.31 is sending [ 5] local 192.168.xx.54 port 63945 connected to 192.168.xx.31 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.01 sec 279 MBytes 2.33 Gbits/sec [ 5] 1.01-2.01 sec 281 MBytes 2.35 Gbits/sec [ 5] 2.01-3.01 sec 280 MBytes 2.35 Gbits/sec [ 5] 3.01-4.01 sec 281 MBytes 2.35 Gbits/sec [ 5] 4.01-5.00 sec 280 MBytes 2.35 Gbits/sec [ 5] 5.00-6.01 sec 281 MBytes 2.35 Gbits/sec [ 5] 6.01-7.01 sec 280 MBytes 2.35 Gbits/sec [ 5] 7.01-8.01 sec 281 MBytes 2.35 Gbits/sec [ 5] 8.01-9.01 sec 280 MBytes 2.35 Gbits/sec [ 5] 9.01-10.01 sec 281 MBytes 2.35 Gbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.01 sec 2.74 GBytes 2.35 Gbits/sec 2 sender [ 5] 0.00-10.01 sec 2.74 GBytes 2.35 Gbits/sec receiver #./iperf3 -c 192.168.xx.31 -p 5201 --bidir (bidirectional) Connecting to host 192.168.xx.31, port 5201 [ 5] local 192.168.xx.54 port 63948 connected to 192.168.xx.31 port 5201 [ 7] local 192.168.xx.54 port 63949 connected to 192.168.xx.31 port 5201 [ ID][Role] Interval Transfer Bitrate [ 5][TX-C] 0.00-1.00 sec 278 MBytes 2.33 Gbits/sec [ 7][RX-C] 0.00-1.00 sec 273 MBytes 2.29 Gbits/sec [ 5][TX-C] 1.00-2.01 sec 280 MBytes 2.34 Gbits/sec [ 7][RX-C] 1.00-2.01 sec 281 MBytes 2.35 Gbits/sec [ 5][TX-C] 2.01-3.00 sec 278 MBytes 2.34 Gbits/sec [ 7][RX-C] 2.01-3.00 sec 279 MBytes 2.35 Gbits/sec [ 5][TX-C] 3.00-4.01 sec 280 MBytes 2.34 Gbits/sec [ 7][RX-C] 3.00-4.01 sec 281 MBytes 2.35 Gbits/sec [ 5][TX-C] 4.01-5.01 sec 279 MBytes 2.34 Gbits/sec [ 7][RX-C] 4.01-5.01 sec 280 MBytes 2.35 Gbits/sec [ 5][TX-C] 5.01-6.01 sec 279 MBytes 2.34 Gbits/sec [ 7][RX-C] 5.01-6.01 sec 280 MBytes 2.35 Gbits/sec [ 5][TX-C] 6.01-7.01 sec 279 MBytes 2.34 Gbits/sec [ 7][RX-C] 6.01-7.01 sec 280 MBytes 2.35 Gbits/sec [ 5][TX-C] 7.01-8.00 sec 278 MBytes 2.34 Gbits/sec [ 7][RX-C] 7.01-8.00 sec 279 MBytes 2.35 Gbits/sec [ 5][TX-C] 8.00-9.01 sec 280 MBytes 2.34 Gbits/sec [ 7][RX-C] 8.00-9.01 sec 281 MBytes 2.35 Gbits/sec [ 5][TX-C] 9.01-10.01 sec 279 MBytes 2.34 Gbits/sec [ 7][RX-C] 9.01-10.01 sec 280 MBytes 2.35 Gbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID][Role] Interval Transfer Bitrate Retr [ 5][TX-C] 0.00-10.01 sec 2.72 GBytes 2.34 Gbits/sec sender [ 5][TX-C] 0.00-10.01 sec 2.72 GBytes 2.34 Gbits/sec receiver [ 7][RX-C] 0.00-10.01 sec 2.73 GBytes 2.35 Gbits/sec 1 sender [ 7][RX-C] 0.00-10.01 sec 2.73 GBytes 2.34 Gbits/sec receiver
I realize this is probably a nob question and I am missing something here, but I haven't been able to find any answer to this problem, even though I was digging really hard. Whenever a streaming app allows you to see screen resolution in the settings, in my case it always shows 1080p even though all of my TVs are 4k. Same goes for Kodi, Cpuz also shows 1080p only. It is my 3rd Chinese Rockchp Box (this time HK1 RK 3528), and it has allways been the same, the prevoius ones even stuttered when playing 4k. Am I doing something wrong, or is it just jet another Chinese scam?
how could I setup wifi headlessly for orange pi 5B?
ledivar777 replied to Carl Hung's topic in Orange Pi 5 / 5B
I realized that, and connected the pi5 to the lan port on my wifi router but wasn't able to see it in the clients list on my router dashboard (192.168.1.1). Waited for 10-15 mins. -
As this SBC have good hardware, I plan to use it as my main desktop and develop in Java/Spring Boot/Docker stack and check how it perform. A lot of people try to use the SBCs as desktop machines, but the perform is the main point when they do some complain. With this hardware I think this can be different.
SteeMan replied to Carl Hung's topic in Orange Pi 5 / 5B
You normally connect ethernet to a switch or router not directly to a laptop. You need something providing dhcp addresses and routing traffic between connected devices. While is is possible to setup a laptop to at as a dhcp server and to route traffic that isn't normal and isn't easy to setup correctly. You just need to plug the board into your 'network' and plug you laptop into the same network.
