https://docs.armbian.com/Developer-Guide_Build-Preparation/
OK. I will test it myself. Is building Armbian from trunk only possible from Ubuntu 20.04 or from newer releases,too?
You missed my point. You choose the edge kernel version of the trunk versions. There are also vendor kernel versions. The vendor kernel is going to be more stable than the edge kernel.
Good morning everyone. My problem is that I had armbian installed in emmc and using armbian config I changed it to usb but I did not update the boot to sd and when I restart it only shows what I put in the photo and it remains black. Is there any way to fix it. By pressing reset with the HDMI unplugged it tries to start but stays in initramfs. Thank you
It happens that my SBC arrived with "details", a defective sdcard reader and the stable versions of armbian do not work... I had the sbc (opi5) lying in a corner... until one day I read about the "trunk" versions ..I installed one and it worked for several hours...days...with no problems. So... since that day I only use "trunk" versions. That's the story of my first SBC IPO. With the stable version with an "apt update" my OPI5 crashes.
Hello, I am happy to report that after I commented the lines from the build/lib/functions/compilation/armbian-kernel.sh script and manually doing a "pip install pylibfdt" (because it was complaining that it cannot compile it due to a missing "ld" which was there, in /usr/bin/ld), I was able to compile the edge kernel for rpi5b. No other steps were required. Now I have /proc/schedstats which will make cilium happy, I hope. Probably there will be no problems with the rest of the boards. Thank you very much for the great work you are doing! Stefanita Vilcu
Ok Here is the response from VHD the company that built our devices It is based on Rockchip RK3588 Development Board EVB1
sudo apt-get install armbian-config sudo armbian-config # SYSTEM # FREEZE wayland.sh #!/bin/bash sudo add-apt-repository ppa:liujianfeng1994/panfork-mesa -y sudo add-apt-repository ppa:liujianfeng1994/rockchip-multimedia -y sudo apt update sudo apt dist-upgrade sudo apt install rockchip-multimedia-config -y sudo apt install libwidevinecdm -y sudo apt install mali-bifrost-wayland-driver -y sudo apt install libv4l-rkmpp -y sudo apt install v4l-utils -y sudo apt install ffmpeg -y sudo apt install glmark2-es2-wayland -y sudo glmark2-es2-wayland Go to chrome://flags Search "Preferred Ozone platform" Set it to "Wayland" ozone-platform-hint auto Restart sudo nano .profile # add to the bottom line: export MOZ_ENABLE_WAYLAND=1 # or just: env MOZ_ENABLE_WAYLAND=1 /snap/bin/firefox export MOZ_ENABLE_WAYLAND=1 Open the firefox and text: about:config in Firefox. Search for the media.ffmpeg preference and set it to true. Restart Firefox. -
pocosparc replied to Hqnicolas's topic in Rockchip CPU Boxes
I have installed the PPA and stuff from this thread: When I run it it produces the following trace. When playing videos all 4 cores are at 100% so I´d say it is not HW accelerated. Maybe there are also missing settings, but I have not seen any proper tutorial on how to set it up. h96-tvbox-3566:~:% chromium-browser [35467:35467:0426/133812.562432:ERROR:chrome_browser_cloud_management_controller.cc(162)] Cloud management controller initialization aborted as CBCM is not enabled. [35467:35467:0426/133813.132334:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files [35528:35528:0426/133813.233668:ERROR:gl_angle_util_vulkan.cc(189)] Failed to retrieve vkGetInstanceProcAddr [35528:35528:0426/133813.234447:ERROR:vulkan_instance.cc(91)] Failed to get vkGetInstanceProcAddr pointer from ANGLE. -
sudo apt-get install armbian-config sudo armbian-config # SYSTEM # FREEZE @pocosparc You will need to edit the DTS or try to enable it via openvfd fddis_dev { compatible = "fddis_dev"; fddis_gpio_clk = <gpio0 RK_PB3 &pcfg_pull_none>; fddis_gpio_dat = <gpio0 RK_PB4 &pcfg_pull_none>; status = "okay"; }; fddis_dev { fddis_gpio_clk { rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; fddis_gpio_dat { rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; }; -
A while ago I debugged the ssh problem and added some comments in this thread here. I don't remember if I used bookworm or trixie. Seems to me a timing issue or in which order things start. For now, whenever I do some dev work, I just do either another reboot after the first setup or restart the sshd service.
Hi @jock! Recently I do really look into the rockchip docs and try to work on that little dongle toy a bit. And then I look back at my original post, and I realize that at that time I totally didn't know what I was doing At that time, after trying and failing the other rkdeveloptool commands (rfi, ppt etc), I did have execute rkdeveloptool db rk322x_loader_v1.10.256.bin at that time, but I was not aware that these commands would now work after the loader bin file had been loaded, and then I stopped trying. OK, these are what I have tried this time: root@debianvm:~# ./rkdeveloptool/rkdeveloptool ld DevNo=1 Vid=0x2207,Pid=0x320b,LocationID=101 Maskrom root@debianvm:~# ./rkdeveloptool/rkdeveloptool db /home/h__c___g/rk322x_loader_v1.10.256.bin Downloading bootloader succeeded. root@debianvm:~# ./rkdeveloptool/rkdeveloptool ul /home/h__c___g/rk322x_loader_v1.10.256.bin Upgrading loader succeeded. root@debianvm:~# ./rkdeveloptool/rkdeveloptool rfi Flash Info: Manufacturer: SAMSUNG, value=00 Flash Size: 0 MB Flash Size: 0 Sectors Block Size: 512 KB Page Size: 2 KB ECC Bits: 0 Access Time: 40 Flash CS: root@debianvm:~# ./rkdeveloptool/rkdeveloptool rci Chip Info: 41 32 32 33 FF FF FF FF FF FF FF FF FF FF FF FF root@debianvm:~# ./rkdeveloptool/rkdeveloptool rcb Capability:07 00 00 00 00 00 00 00 Direct LBA: enabled Vendor Storage: enabled First 4m Access: enabled Read Com Log: enabled I realize that the Flash Size read 0 mb. I obtain rk322x_loader_v1.10.256.bin by commenting out the rm -f line in the (github) rkbin/scripts/checkpatch.sh file. Maybe the loader firmware did not support SPI? But before I do the ul line, I do try dumping the storage using rkdeveloptool rl 0 xxxxx dump.bin and then strings dump.bin, and nothing comes out; but after I do the ul line, the strings really do spit out many random lines, and I think it is evidence that I can use the rkdeveloptool binary to write bytes to the SPI... Is there any chance for me to make this dongle sort of working by using the rockchip proprietary binaries to pack up the uboot.img, trust.img and boot.img files, and then flash them in?
Helios64 u-boot does not build anymore after we bumped to 2022.07
BipBip1981 replied to Igor's topic in Rockchip
Hi, To my side, it's too complex and risky for me to change hardware components on Helios64. I prefer for my case of uses change CPU Freq and Governor for less performance but stable inside take risk of damage my board by change components. Have a good day -
How to compile a kernel with CONF_SCHEDSTATS=y?
going replied to Stefanita Vilcu's topic in Advanced users - Development
@Igor This line may sound rude, but you are probably waiting for the developers of the source code to take some action to improve patches or kernel settings. As long as this heresy is present in the build system (bad package build scripts), the project will receive crumbs from what developers can and do locally. -
Orange Pi Zero Plus not booting on Armbian 24.2.1 Jammy CLI
cvxx replied to gyrex's topic in Orange Pi Zero Plus
I don't have a TTL at the moment, but I can confirm too that: Armbian 24.2.1 Jammy CLI - does not boot Armbian 24.2.1 Bookworm CLI - boots tagging the maintainer for visibility @schwar3kat -
The developers of Armbian have signed their own impotence with this. They cannot or do not want to add support for creating an additional package with debugging symbols. If we look at simple scripts for creating debian packages directly in the kernel source codes, we will see that the debugging package is created automatically when the configuration option is selected: CONFIG_DEBUG_INFO The only way is to change the script of the build system itself by removing these lines and adding 10 lines to the script to create a debugging package. With respect to all free software developers. Leonid. -
Werner replied to Stefanita Vilcu's topic in Advanced users - Development
Well you can try to disable the mentioned switch and see what goes wrong when packaging happens. Then you need to figure out how to fix it. -
Currently as a desktop. Wanted to try it out, but the kernel update over apt upgrade bricked my device. So I need to reflash everything. I am still doing everything on the current 6.6 kernel. IR works I just need to create a keymap and I will test KODI out - just need to recompile it in a VM. I am still waiting for my sound bar that has SPDIF to test it out. I think currently it is not working as I saw that spdif@fe460000 is currently disabled. I am also looking for the current Linux-headers file 6.6.28 so that I can try with openvfd. I was unable to find them with the previous kernel version 6.6.27. Once I install everything back I will retry this. What is funny about this box - every reinstallation brings a new MAC address. I am also trying to set up a CasaOS - currently in YouTube mode on how to set up Cloudflare tunnels. -
Hello, I have a bunch of boards (rpi4b, rpi5, orangepi5, orangepi5-plus, nanopct6, rock3a, rock5b, vim4) in a Kubernetes cluster using Cilium. Cilium requires CONF_SCHEDSTATS=y in the kernel, which is dependent on CONFIG_DEBUG_KERNEL=y but... in build/lib/functions/compilation/armbian-kernel.sh we have # DONE: Disable: debug option kernel_config_set_n DEBUG_KERNEL # Armbian doesn't know how to package a debug kernel. Which invalidates the option I enabled during ./compile.sh BOARD=... BRANCH=... kernel-config Except for the VIM4, with DEBUG_KERNEL enabled in build/config/sources/families/meson-s4t7.conf Is there a way to enable DEBUG_KERNEL for the rest of the boards? Thank you! Stefanita Vilcu
You are choosing to use the edge kernel, which is the 'bleeding edge" development work area, it is expected to be unstable. If you want fewer issues you shouldn't be using edge.
Is this message important or will I be able to continue with this trunk version (kernel)? This is what I have so far on my system:
Installed this on an old Heltec Helium miner Any idea how to enable SPI so spidev shows in /dev/?
I'm also keeping this two torrent files from official release 24.5.0-trunk.474 in my H96 MAX torrent server Armbian_community_24.5.0-trunk.474_H96-tvbox-3566_jammy_current_6.6.28_gnome_desktop.img.xz.torrent Armbian_community_24.5.0-trunk.474_H96-tvbox-3566_bookworm_current_6.6.28_minimal.img.xz.torrent
