  2. balbes150
    Armbian for Amlogic S9xxx kernel 4.1x (>= ver 5.55)
    any 5.78 (setup use dtb for x96max)
  3. Hello, hello, I have test the method you have posted, while It always tell me "Your kernel does not support CONFIG OF OVERLAY", and my folder /sys/kernel/config is empty. Is that mean I need to compile linux firmware by myself to enable I2c interface? The firmware I used is Raw Firmware ubuntu16.04 provided by Firefly official. Thanks a lot for your help.
  4. RedCat
    OrangePi R1 RTWHALXT runs 100% CPU
    root@orangepi:~# armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/1HfY Please post the URL in the forum where you've been asked for.
  5. haajee
    H6 Famous Reboot problem
    Thank you very much for you update! I will wait and what i say i use the orangepi one plus headless so it's not an big problem. I don't has buyed another TV.
  6. Igor
    I am looking for this: igorp@bananapim2plus:~$ sudo su root@bananapim2plus:/home/igorp# armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/1HfY Please post the URL in the forum where you've been asked for.
  7. IIRC we postponed upgrade to 4.19.y (at the time others were bumped to it) because lack of time for testing and some problems (forgot the details). IMO moving to 4.19.y makes sense, but testing would needed. There is no need to wait for 5.x What this means for Helios4 @gprovost?
  8. RedCat
    On this system? Yes, this hardware distributes the Internet to my house, and it is now located about 500 meters from me br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.240.3 netmask 255.255.255.0 broadcast 255.255.255.255 inet6 fe80::c274:2bff:feff:f42c prefixlen 64 scopeid 0x20<link> ether c0:74:2b:ff:f4:2c txqueuelen 1000 (Ethernet) RX packets 57503 bytes 3600845 (3.4 MiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 53900 bytes 35972762 (34.3 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 enxc0742bfff42c: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 ether c0:74:2b:ff:f4:2c txqueuelen 1000 (Ethernet) RX packets 1200513 bytes 1190307502 (1.1 GiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 1154809 bytes 176479396 (168.3 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 02:42:26:2e:9a:e0 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 39 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 16 bytes 1296 (1.2 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 16 bytes 1296 (1.2 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet6 fe80::d6b7:61ff:feaa:31b3 prefixlen 64 scopeid 0x20<link> ether d4:b7:61:aa:31:b3 txqueuelen 1000 (Ethernet) RX packets 1193979 bytes 212348235 (202.5 MiB) RX errors 0 dropped 107872 overruns 0 frame 0 TX packets 1206367 bytes 1232094064 (1.1 GiB) TX errors 0 dropped 5 overruns 0 carrier 0 collisions 0
  9. Igor
    Kernel looks O.K., Did you perhaps uninstall something or run some dirty scripts? Do you have a working network connection?
  10. Today
  11. RedCat
    yes ARMBIAN 5.75 stable Debian GNU/Linux 9 (stretch) 4.19.20-sunxi
  12. Igor
    Are you running armbian? Something looks corrupted or broken then. Can you start with a clean image?
  13. RedCat
    System diagnosis information will now be uploaded to(I pressed enter) Could not find the database of available applications, run update-command-not-found as root to fix this
  14. Igor
    Type this into the console.
  15. RedCat
    How to use it?
  16. teridotoji
    which version of armbian do you used?
  17. Read what I wrote. Again.
  18. jiapei100
    Build NEWEST Linux Kernel 5.0.9 on Banana Pi M3
    Thank you Igor... I noticed sun8i-a83t-bananapi-m3 is supported by kernel 5.0.9 ? sky@bananapim3:~/Downloads/kernel/linux-5.0.9/arch/arm/boot/dts$ ll sun8i-a83t* -rw-rw-r-- 1 sky sky 6724 Apr 20 15:17 sun8i-a83t-allwinner-h8homlet-v2.dts -rw-rw-r-- 1 sky sky 8944 Apr 20 15:17 sun8i-a83t-bananapi-m3.dts -rw-rw-r-- 1 sky sky 9913 Apr 20 15:17 sun8i-a83t-cubietruck-plus.dts -rw-rw-r-- 1 sky sky 9438 Apr 20 15:17 sun8i-a83t-tbs-a711.dts -rw-rw-r-- 1 sky sky 26406 Apr 20 15:17 sun8i-a83t.dtsi However, when I tried to convert from .dts to .dtb, I obtained the following ERROR message: sky@bananapim3:~/Downloads/kernel/linux-5.0.9/arch/arm/boot/dts$ dtc -I dts -O dtb -f ./sun8i-a83t-bananapi-m3.dts -o ./sun8i-a83t-bananapi-m3.dtb Error: ./sun8i-a83t-bananapi-m3.dts:46.1-9 syntax error FATAL ERROR: Unable to parse input tree It looks it's reporting an ERROR from the following lines: 45 /dts-v1/; 46 #include "sun8i-a83t.dtsi" Is /dts-v1/; buggy??? BTW, I'm NOT using cross compiling... Sorry for my NAIVE question, is it possible to specify my DTS and build a particular .dtbs for a particular board (banana pi M3) ? Thank you Pei
  19. Mathias
    [RockPro64] Armbian upstream kernel/uboot test?
    I have replaced the cable by another one (freshly purchased and tested on my laptop), I still have the same problems. I've not been able to capture the backtrace this time, but at least I have some kernel messages showing how the kernel is fighting to make it work: some messages early on and then more later on (it fully crashed a few minutes later). Again, this is with kernel 4.4.174 and a JMS578 (patched firmware) based enclosure...
  20. crazystick
    Can't install PINE A64-LTS to eMMC
    Did you ever manage to get the Pine to boot from eMMC?
  21. pkfox
    NanoPI M4
    What would be the offset for an Armbian image ? Edit I worked it out with googles help if you run fdisk -lu /path/to/your/image.img it will give you start and end numbers , if you multiply the start figure by 512 this gives you the offset. I just tried it with my dd created Armbian EMMC image and it mounted ok - this is a useful piece of knowledge when you want to retrieve some files from your backup.
  22. Thanks for the info and pointer. Now I understand where this -20°C tweak we asked about here comes from It means it wasn't so smart to remove already the tweak... well at least it will already be aligned when armbian mvebu next jump to 4.19 or 5.x The kernel change you mention are from this commit and effectively it didn't made it to v4.14 https://github.com/torvalds/linux/commit/8c0b888f6610d0ebbc4bdfb52d2fef9f4a11adfc I'm also not 100% sure how this bitwise tweak works :/ FYI The Marvell errata (#132698) mentioned in the commit is an internal errata, it wasn't even made public.
  23. Mainline Linux kernel is from six months ago and one year behind Armbian kernel, also stable version v4.19.y where most of the stuff is regularly back ported. Compiling mainline kernel and expecting (better) functionality is overoptimistic/pointless, especially in case of Banana M3. You can try new Armbian kernel, but I have no idea if it boots at all on your board, by using armbian-config tools -> system -> alternative kernels.
  24. Hello, today I tried upgrading my ClearfogPro Kernel from 4.14.106 (next) to 4.19.20(dev). So far everything seems to be working (samba, dnsmasq, minidlna, network etc.), see also attached armbianmonitor link. Great work @ armbian. I also noticed that the reported temperature by "cat /sys/devices/virtual/thermal/thermal_zone0/temp" seems to be about 20°C lower than with the old kernel. I appreciate this, because it seems to be closer to the real value (measured with thermal probe at heatsink). The old 4.14 kernel always reported some value around 65-70°C which seemed a bit high for idling (cpu running at 800Mhz like 80% of the time). The new value of 35°C is quite realistic I guess. Does anyone know / have information about a change in temperature reading on the clearfog in the last kernel upgrades? EDIT: Checked in the kernel diff between 4.14 and 4.19 and there are some changes to https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/drivers/thermal/armada_thermal.c?h=linux-4.19.y They definitely changed something regarding some trim values - though I don't understand enough to really say if that changes the temperature reading. But if it did it might also be interesting for the Helios4 guys, I remember seeing some questions about high temperatures in their thread. @gprovost could this be related? Can I somehow help getting the 4.19 Kernel to be next? Like specific things to test? Or is your plan to skip 4.19 completely and go directly to 5.x? Greetings, count-doku
  25. lzb
    armbianmonitor error
    @guidol I can spot some difference in uptime and "a board just booted" and "a board with some uptime doing things". My is running urbackup (mostly active two or three times a day) and nextcloud (mostly idle at the moment). I had issues running this setup for more than 24h (freezes), but it seems to improve: root@bananapi:~# uptime 08:56:57 up 2 days, 8:13, 3 users, load average: 0.59, 0.56, 0.55 And current uptime is still growing after some serious testing (running stress, running btrfs scrub and btrfs balance to simulate "typical" workload). Not sure where this 4.76V came from? (cant see it in the uploaded log) I've changed governor and min_freq as the board is idle most of the time (as mentioned above). I think that my power supply isnt that bad: root@bananapi:~# grep -v Time armmon.log | cut -d\. -f1,4,5 | cut -d\ -f8 | sed '/^$/d' | sort | uniq -c 1 4.84V 1 4.85V 6 4.86V 2 4.87V 6 4.88V 24 4.89V 32 4.90V 69 4.91V 107 4.92V 85 4.93V 210 4.94V 335 4.95V 339 4.96V 458 4.97V 929 4.98V 1739 4.99V 3566 5.00V 7853 5.01V 8978 5.02V 7890 5.03V 2703 5.04V 367 5.05V 21 5.06V root@bananapi:~# wc -l armmon.log 38129 armmon.log I sure can try newer kernel if that can help. I can also ignore it as my uptime finally hit over 24h, but would be nice to solve that bug.
  26. Hi, all: I wonder if there is a manual to DIRECTLY build Linux Kernel (Say, current version 5.0.9) against any board, as far as uname -a is known ? For instance, current Armbian for Banana Pi M3 is of the following uname -a value: sky@bananapim3:~/Downloads/sunxi$ uname -a Linux bananapim3 4.19.25-sunxi #5.78 SMP Mon Apr 8 07:46:22 CEST 2019 armv7l armv7l armv7l GNU/Linux Anyway, I'm trying to test it out... Cheers Pei
  27. S.Alireza
    USB 2.0 notworking
    Hi, i bought a nanopc t4, then i installed armbian on it's eMmc , after starting os, i plug in a usb flash to it's usb2.0 ports(both usb 2.0 ports) but not working but when i plug in the usb flash to it's usb port 3.0 it will be work, i tried this issue with mouse and keyboard usb and some another usb flashes that has usb 2.0 compatibility, can anyone help me to setup my nanopc t4 usb 2.0 ports?
