Werner Posted May 2, 2019 Share Posted May 2, 2019 Hey there, I just build a fresh dev image for the OrangePi One Plus (Stretch, console only, 5.0.x megous sources, latest commit was https://github.com/armbian/build/commit/783c2d0e25ff4542876943cfef6a7ac2921d1262) and unfortunately it seems to be unbootable. I put verbosity to 7 to get some more information rather than being stuck at "Starting kernel..." and this is what came up: Spoiler U-Boot SPL 2019.01-armbian (May 02 2019 - 13:14:43 +0200) DRAM: 1024 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):9a25f98-dirty NOTICE: BL31: Built : 13:14:40, May 2 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc0732e8, model: OrangePi One Plus INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (May 02 2019 - 13:14:43 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi One Plus DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 13 ms (228.5 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 116 bytes read in 11 ms (9.8 KiB/s) 24389 bytes read in 44 ms (541 KiB/s) 4161 bytes read in 53 ms (76.2 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 5523536 bytes read in 574 ms (9.2 MiB/s) 14436360 bytes read in 1473 ms (9.3 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 5523472 Bytes = 5.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49abb000, end 49fff810 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049a4c000, end 0000000049abafff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.0.11-sunxi64 (root@s2) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.83 SMP Thu May 2 13:26:36 CEST 2019 [ 0.000000] Machine model: OrangePi One Plus [ 0.000000] cma: Reserved 128 MiB at 0x0000000078000000 [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x77dde840-0x77ddffff] [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x3f0 with crng_init=0 [ 0.000000] percpu: Embedded 22 pages/cpu s53016 r8192 d28904 u90112 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048 [ 0.000000] Policy zone: DMA32 [ 0.000000] Kernel command line: root=UUID=84d8a82d-28a0-44c6-8f9d-40d263bdd5e3 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 panic=10 consoleblank=0 loglevel=7 ubootpart=977042f2-01 usb-storage.quirks= cgroup_enable=memory swapaccount=1 [ 0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes [ 0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes [ 0.000000] printk: log_buf_len min size: 16384 bytes [ 0.000000] printk: log_buf_len: 32768 bytes [ 0.000000] printk: early log buf free: 13868(84%) [ 0.000000] Memory: 878132K/1048576K available (10238K kernel code, 722K rwdata, 2504K rodata, 576K init, 288K bss, 39372K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000207] Console: colour dummy device 80x25 [ 0.000538] printk: console [tty1] enabled [ 0.000611] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000631] pid_max: default: 32768 minimum: 301 [ 0.000715] LSM: Security Framework initializing [ 0.000731] AppArmor: AppArmor disabled by boot time parameter [ 0.001143] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.001354] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.001393] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes) [ 0.001414] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes) [ 0.002618] ASID allocator initialised with 32768 entries [ 0.002698] rcu: Hierarchical SRCU implementation. [ 0.003193] smp: Bringing up secondary CPUs ... [ 0.003886] Detected VIPT I-cache on CPU1 [ 0.003936] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.004559] Detected VIPT I-cache on CPU2 [ 0.004586] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.005149] Detected VIPT I-cache on CPU3 [ 0.005176] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.005238] smp: Brought up 1 node, 4 CPUs [ 0.005292] SMP: Total of 4 processors activated. [ 0.005303] CPU features: detected: 32-bit EL0 Support [ 0.005314] CPU features: detected: CRC32 instructions [ 0.005562] CPU: All CPU(s) started at EL2 [ 0.005585] alternatives: patching kernel code [ 0.006544] devtmpfs: initialized [ 0.010867] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.010919] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.015140] xor: measuring software checksum speed [ 0.052076] 8regs : 1750.000 MB/sec [ 0.092117] 32regs : 2151.000 MB/sec [ 0.132166] arm64_neon: 1907.000 MB/sec [ 0.132177] xor: using function: 32regs (2151.000 MB/sec) [ 0.132234] pinctrl core: initialized pinctrl subsystem [ 0.132970] NET: Registered protocol family 16 [ 0.133436] audit: initializing netlink subsys (disabled) [ 0.133589] audit: type=2000 audit(0.132:1): state=initialized audit_enabled=0 res=1 [ 0.134025] cpuidle: using governor menu [ 0.134291] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 0.134309] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.135392] DMA: preallocated 256 KiB pool for atomic allocations [ 0.135485] Serial: AMBA PL011 UART driver [ 0.144211] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.144236] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.144249] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.144261] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.144727] cryptd: max_cpu_qlen set to 1000 [ 0.212324] raid6: neonx8 gen() 1254 MB/s [ 0.280387] raid6: neonx8 xor() 1168 MB/s [ 0.348492] raid6: neonx4 gen() 1153 MB/s [ 0.416564] raid6: neonx4 xor() 1103 MB/s [ 0.484689] raid6: neonx2 gen() 885 MB/s [ 0.552769] raid6: neonx2 xor() 923 MB/s [ 0.620855] raid6: neonx1 gen() 553 MB/s [ 0.688935] raid6: neonx1 xor() 653 MB/s [ 0.757029] raid6: int64x8 gen() 748 MB/s [ 0.825152] raid6: int64x8 xor() 566 MB/s [ 0.893270] raid6: int64x4 gen() 792 MB/s [ 0.961297] raid6: int64x4 xor() 583 MB/s [ 1.029494] raid6: int64x2 gen() 517 MB/s [ 1.097543] raid6: int64x2 xor() 460 MB/s [ 1.165606] raid6: int64x1 gen() 337 MB/s [ 1.233681] raid6: int64x1 xor() 338 MB/s [ 1.233692] raid6: using algorithm neonx8 gen() 1254 MB/s [ 1.233701] raid6: .... xor() 1168 MB/s, rmw enabled [ 1.233711] raid6: using neon recovery algorithm [ 1.234419] SCSI subsystem initialized [ 1.234581] usbcore: registered new interface driver usbfs [ 1.234620] usbcore: registered new interface driver hub [ 1.234680] usbcore: registered new device driver usb [ 1.234877] pps_core: LinuxPPS API ver. 1 registered [ 1.234888] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.234911] PTP clock support registered [ 1.235898] clocksource: Switched to clocksource arch_sys_counter [ 1.236024] VFS: Disk quotas dquot_6.6.0 [ 1.236079] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.241613] NET: Registered protocol family 2 [ 1.242133] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes) [ 1.242187] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 1.242300] TCP bind hash table entries: 8192 (order: 5, 131072 bytes) [ 1.242447] TCP: Hash tables configured (established 8192 bind 8192) [ 1.242554] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.242596] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.242758] NET: Registered protocol family 1 [ 1.243152] RPC: Registered named UNIX socket transport module. [ 1.243165] RPC: Registered udp transport module. [ 1.243174] RPC: Registered tcp transport module. [ 1.243183] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.243393] Unpacking initramfs... [ 1.537043] Freeing initrd memory: 5392K [ 1.663470] Initialise system trusted keyrings [ 1.663647] workingset: timestamp_bits=44 max_order=18 bucket_order=0 [ 1.668266] zbud: loaded [ 1.669536] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.670165] NFS: Registering the id_resolver key type [ 1.670197] Key type id_resolver registered [ 1.670207] Key type id_legacy registered [ 1.670223] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.670235] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 1.670996] 9p: Installing v9fs 9p2000 file system support [ 1.779602] NET: Registered protocol family 38 [ 1.782003] Key type asymmetric registered [ 1.782026] Asymmetric key parser 'x509' registered [ 1.782090] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 1.782248] io scheduler mq-deadline registered [ 1.782260] io scheduler kyber registered [ 1.782415] io scheduler bfq registered [ 1.782688] sun50i-de2-bus 1000000.display-engine: Error couldn't map SRAM to device [ 1.783018] sun4i-usb-phy 5100400.phy: Couldn't request ID GPIO [ 1.786631] sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver [ 1.793201] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.795395] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 1.799407] loop: module loaded [ 1.800376] libphy: Fixed MDIO Bus: probed [ 1.800798] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.800811] ehci-platform: EHCI generic platform driver [ 1.800991] ehci-platform 5101000.usb: EHCI Host Controller [ 1.801018] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1 [ 1.801939] ehci-platform 5101000.usb: irq 15, io mem 0x05101000 [ 1.815901] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 1.816107] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00 [ 1.816126] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.816140] usb usb1: Product: EHCI Host Controller [ 1.816152] usb usb1: Manufacturer: Linux 5.0.11-sunxi64 ehci_hcd [ 1.816165] usb usb1: SerialNumber: 5101000.usb [ 1.816588] hub 1-0:1.0: USB hub found [ 1.816645] hub 1-0:1.0: 1 port detected [ 1.817152] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.817178] ohci-platform: OHCI generic platform driver [ 1.817310] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 1.817335] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2 [ 1.817562] ohci-platform 5101400.usb: irq 16, io mem 0x05101400 [ 1.880078] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.00 [ 1.880097] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.880112] usb usb2: Product: Generic Platform OHCI controller [ 1.880125] usb usb2: Manufacturer: Linux 5.0.11-sunxi64 ohci_hcd [ 1.880137] usb usb2: SerialNumber: 5101400.usb [ 1.880510] hub 2-0:1.0: USB hub found [ 1.880552] hub 2-0:1.0: 1 port detected [ 1.881240] usbcore: registered new interface driver usb-storage [ 1.881632] mousedev: PS/2 mouse device common for all mice [ 1.882029] sun6i-rtc 7000000.rtc: registered as rtc0 [ 1.882043] sun6i-rtc 7000000.rtc: RTC enabled [ 1.882102] i2c /dev entries driver [ 1.882256] sun50i-h6-r-pinctrl 7022000.pinctrl: 7022000.pinctrl supply vcc-pl not found, using dummy regulator [ 1.882344] sun50i-h6-r-pinctrl 7022000.pinctrl: Linked as a consumer to regulator.0 [ 1.882803] axp20x-i2c 0-0036: AXP20x variant AXP806 found [ 1.888071] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input0 [ 1.889186] dcdca: supplied by vcc-5v [ 1.890201] dcdcc: supplied by vcc-5v [ 1.890791] dcdcd: supplied by vcc-5v [ 1.891238] vdd-sys: Bringing 900000uV into 960000-960000uV [ 1.891680] dcdce: supplied by vcc-5v [ 1.892243] aldo1: supplied by vcc-5v [ 1.892813] aldo2: supplied by vcc-5v [ 1.893262] vcc-ac200: Bringing 700000uV into 3300000-3300000uV [ 1.893688] aldo3: supplied by vcc-5v [ 1.894134] vcc25-dram: Bringing 700000uV into 3300000-3300000uV [ 1.894873] bldo1: supplied by vcc-5v [ 1.895913] bldo2: supplied by vcc-5v [ 1.896470] bldo3: supplied by vcc-5v [ 1.896917] vcc-dcxoio: Bringing 700000uV into 1800000-1800000uV [ 1.897650] bldo4: supplied by vcc-5v [ 1.898233] cldo1: supplied by vcc-5v [ 1.898802] cldo2: supplied by vcc-5v [ 1.899251] vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV [ 1.899679] cldo3: supplied by vcc-5v [ 1.900147] vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV [ 1.900597] sw: supplied by regulator-dummy [ 1.900744] axp20x-i2c 0-0036: AXP20X driver loaded [ 1.901357] sdhci: Secure Digital Host Controller Interface driver [ 1.901368] sdhci: Copyright(c) Pierre Ossman [ 1.901400] Synopsys Designware Multimedia Card Interface Driver [ 1.901775] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.902306] ledtrig-cpu: registered to indicate activity on CPUs [ 1.902550] hidraw: raw HID events driver (C) Jiri Kosina [ 1.902637] usbcore: registered new interface driver usbhid [ 1.902648] usbhid: USB HID core driver [ 1.903782] NET: Registered protocol family 10 [ 1.918434] Segment Routing with IPv6 [ 1.918542] NET: Registered protocol family 17 [ 1.918718] 8021q: 802.1Q VLAN Support v1.8 [ 1.918875] 9pnet: Installing 9P2000 support [ 1.918937] Key type dns_resolver registered [ 1.919571] registered taskstats version 1 [ 1.919582] Loading compiled-in X.509 certificates [ 1.919668] zswap: loaded using pool lzo/zbud [ 1.920677] Btrfs loaded, crc32c=crc32c-generic [ 1.927657] Key type encrypted registered [ 1.936280] sun4i-usb-phy 5100400.phy: Couldn't request ID GPIO [ 1.940655] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 1.940925] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-ph not found, using dummy regulator [ 1.941020] sun50i-h6-pinctrl 300b000.pinctrl: Linked as a consumer to regulator.0 [ 1.941386] printk: console [ttyS0] disabled [ 1.962242] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 13, base_baud = 1500000) is a 16550A [ 3.275462] printk: console [ttyS0] enabled [ 3.281196] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pf not found, using dummy regulator [ 3.291296] sunxi-mmc 4020000.mmc: Linked as a consumer to regulator.13 [ 3.298647] sunxi-mmc 4020000.mmc: Got CD GPIO [ 3.328544] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 3.337711] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pc not found, using dummy regulator [ 3.347876] sun4i-usb-phy 5100400.phy: Linked as a consumer to regulator.1 [ 3.355339] ehci-platform 5311000.usb: EHCI Host Controller [ 3.360936] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 3 [ 3.369133] ehci-platform 5311000.usb: irq 17, io mem 0x05311000 [ 3.387906] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00 [ 3.394163] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00 [ 3.402439] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.409671] usb usb3: Product: EHCI Host Controller [ 3.414556] usb usb3: Manufacturer: Linux 5.0.11-sunxi64 ehci_hcd [ 3.420655] usb usb3: SerialNumber: 5311000.usb [ 3.425597] hub 3-0:1.0: USB hub found [ 3.429388] hub 3-0:1.0: 1 port detected [ 3.433933] ohci-platform 5311400.usb: Generic Platform OHCI controller [ 3.440569] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 4 [ 3.448559] ohci-platform 5311400.usb: irq 18, io mem 0x05311400 [ 3.465329] mmc0: host does not support reading read-only switch, assuming write-enable [ 3.479525] mmc0: new high speed SDHC card at address aaaa [ 3.486040] mmcblk0: mmc0:aaaa SL16G 14.8 GiB [ 3.496051] mmcblk0: p1 [ 3.516062] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.00 [ 3.524339] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.531568] usb usb4: Product: Generic Platform OHCI controller [ 3.537497] usb usb4: Manufacturer: Linux 5.0.11-sunxi64 ohci_hcd [ 3.543596] usb usb4: SerialNumber: 5311400.usb [ 3.549341] hub 4-0:1.0: USB hub found [ 3.553124] hub 4-0:1.0: 1 port detected [ 3.557802] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 3.568548] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0 [ 3.576821] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 3.582582] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5 [ 3.590573] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00 [ 3.598853] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.606083] usb usb5: Product: MUSB HDRC host driver [ 3.611054] usb usb5: Manufacturer: Linux 5.0.11-sunxi64 musb-hcd [ 3.617154] usb usb5: SerialNumber: musb-hdrc.1.auto [ 3.622447] hub 5-0:1.0: USB hub found [ 3.626232] hub 5-0:1.0: 1 port detected [ 3.630792] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-01T00:22:43 UTC (1363) [ 3.639088] of_cfs_init [ 3.641616] of_cfs_init: OK [ 3.644614] vdd-gpu: disabling [ 3.648327] Freeing unused kernel memory: 576K [ 3.663948] Run /init as init process [ 3.695679] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 3.699601] random: udevadm: uninitialized urandom read (16 bytes read) [ 3.703203] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 4.248661] random: fast init done [ 4.274614] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 4.791348] systemd[1]: System time before build time, advancing clock. [ 4.832902] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 4.851310] systemd[1]: Detected architecture arm64. [ 4.861174] systemd[1]: Set hostname to <orangepioneplus>. [ 5.179963] systemd[1]: Listening on Journal Audit Socket. [ 5.186102] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 5.194409] systemd[1]: Listening on Journal Socket. [ 5.199705] systemd[1]: Listening on udev Control Socket. [ 5.205390] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 5.213138] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 5.222865] systemd[1]: Listening on Syslog Socket. [ 5.325714] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro @martinayotte I know you are running on 5.1-RCx locally right now but do you have any chance to verify this behavior? Edit: Just tried the same with Armbian_5.82.190423_Orangepioneplus_Debian_stretch_dev_5.0.7 and works fine. Edit2: Using APT to upgrade to the latest packages and reboot working as well. Though ethernet is not detected any longer...this is getting weird... Link to comment Share on other sites More sharing options...
martinayotte Posted May 2, 2019 Share Posted May 2, 2019 2 hours ago, Werner said: but do you have any chance to verify this behavior? As I don't want to undo the work I've done for 5.1.y, I've decided to download https://dl.armbian.com/orangepioneplus/nightly/Armbian_5.83.190502_Orangepioneplus_Debian_stretch_dev_5.0.10.7z instead. Effectively, it seems broken, stopping/freezing during boot with the following errors : [ 6.550967] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz [ 6.558474] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1080000 KHz This must have been introduced between 5.0.7 and 5.0.10 ... I will investigate a bit more ... EDIT : I found something, replacing the 5.0.10 DTB by the one of 5.0.7 allows booting successfully ! ... I will compare them ... 2 Link to comment Share on other sites More sharing options...
Werner Posted May 2, 2019 Author Share Posted May 2, 2019 Thank you for taking a look into! Link to comment Share on other sites More sharing options...
martinayotte Posted May 2, 2019 Share Posted May 2, 2019 3 hours ago, Werner said: Thank you for taking a look into! Strangely, I've put back the original DTB and it still working ... I will try again with a "virgin" image. EDIT : I took another SDCard, reburned 5.0.10, and this time, although still showing those "cpufreq" error, it booted successfully, although "filesystem resize" took more time than usual ... 1 Link to comment Share on other sites More sharing options...
The7up Posted May 2, 2019 Share Posted May 2, 2019 (edited) Hello there! I have an OP One Plus board, but I'm not able to boot armbian on it. (If I flash image downloaded from orangepi.org, it works well) I have tried different images without any luck. The situation is the following: after connecting the power supply (it was ordered together with the board) it seems nothing happened, after a while the red led turns on. I have connected the UART port, and got the following messages: Spoiler U-Boot SPL 2019.01-armbian (May 02 2019 - 03:33:39 +0200) DRAM: 1024 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):9a25f98-dirty NOTICE: BL31: Built : 03:33:31, May 2 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc0732e8, model: OrangePi One Plus INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (May 02 2019 - 03:33:39 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi One Plus DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 1 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 18 ms (165 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 116 bytes read in 14 ms (7.8 KiB/s) 24389 bytes read in 42 ms (566.4 KiB/s) 4161 bytes read in 48 ms (84 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 5526745 bytes read in 581 ms (9.1 MiB/s) 14436360 bytes read in 1482 ms (9.3 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 5526681 Bytes = 5.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49aba000, end 49fff499 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049a4b000, end 0000000049ab9fff ... OK Starting kernel ... I have tried all suggestion in the faq, the SD card is a 16GB SanDisk A1 class card. Any suggestion or help would be highly appreciated... The7up Edited May 2, 2019 by Igor spoilers Link to comment Share on other sites More sharing options...
Igor Posted May 2, 2019 Share Posted May 2, 2019 29 minutes ago, The7up said: I have tried all suggestion in the faq How long do you wait? First boot takes a little longer. Link to comment Share on other sites More sharing options...
Werner Posted May 2, 2019 Author Share Posted May 2, 2019 Might be a known issue: tl;dr: try an older nightly, 5.0.7 kernel working for me. Link to comment Share on other sites More sharing options...
martinayotte Posted May 2, 2019 Share Posted May 2, 2019 39 minutes ago, The7up said: I have connected the UART port, and got the following messages: Edit the /boot/armbianEnv.txt to add more verbosity with "verbosity=7" and "console=serial" and repost the logs ... 10 minutes ago, Igor said: First boot takes a little longer. Please, check the other thread here and my following posts, something strange : 1 Link to comment Share on other sites More sharing options...
The7up Posted May 3, 2019 Share Posted May 3, 2019 I have made the modifications advised by @martinayotte Still not booting Find logs attached. Which image is working now and where can I download it? putty.log Link to comment Share on other sites More sharing options...
martinayotte Posted May 3, 2019 Share Posted May 3, 2019 6 minutes ago, The7up said: Which image is working now and where can I download it? I think the old one from https://dl.armbian.com/orangepioneplus/nightly/Armbian_5.82.190423_Orangepioneplus_Debian_stretch_dev_5.0.7.7z was still working. (Keep it as a safe backup) @Igor , it seems that The7Up log is also pointing at a hang at the same place as experienced in the other thread ... But no clue, even "melding" both DTS ... Link to comment Share on other sites More sharing options...
Werner Posted May 3, 2019 Author Share Posted May 3, 2019 Yes, 5.0.7 image is working. Do not upgrade the kernel though or you will run into the same issue. Link to comment Share on other sites More sharing options...
The7up Posted May 3, 2019 Share Posted May 3, 2019 Thanks @martinayotte It works well! Link to comment Share on other sites More sharing options...
data Posted May 4, 2019 Share Posted May 4, 2019 Just in case nobody noticed yet: Current nightly as of May 2nd does not work on the lite2. Probably the issue exists since a few days. After my last apt upgrade on wednesday, my board did hang on boot. After a fresh install with the current nightly, it does not boot as well. These are the last lines from verbose boot output: Quote [ 3.630355] sun6i-rtc 7000000.rtc: setting system clock to 2019-05-04T12:19:17 UTC (1556972357) [ 3.639170] of_cfs_init [ 3.641701] of_cfs_init: OK [ 3.644699] vdd-gpu: disabling [ 3.648404] Freeing unused kernel memory: 576K [ 3.664016] Run /init as init process [ 3.695698] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 3.699727] random: udevadm: uninitialized urandom read (16 bytes read) [ 3.703222] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 5.032205] random: fast init done [ 5.653993] random: crng init done [ 5.657397] random: 7 urandom warning(s) missed due to ratelimiting [ 5.726192] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 6.314872] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 6.333231] systemd[1]: Detected architecture arm64. [ 6.339798] systemd[1]: Set hostname to <orangepilite2>. [ 6.664121] systemd[1]: Listening on udev Control Socket. [ 6.670242] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 6.677571] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.685582] systemd[1]: Listening on Journal Audit Socket. [ 6.691363] systemd[1]: Listening on Syslog Socket. [ 6.696533] systemd[1]: Listening on Journal Socket. [ 6.701719] systemd[1]: Reached target Swap. [ 6.810448] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 6.944233] systemd-journald[369]: Received request to flush runtime journal from PID 1 [ 7.300118] thermal thermal_zone0: failed to read out thermal zone (-16) [ 7.300306] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz [ 7.306963] thermal thermal_zone1: failed to read out thermal zone (-16) [ 7.314324] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1080000 KHz Link to comment Share on other sites More sharing options...
data Posted May 4, 2019 Share Posted May 4, 2019 Same issue on the lite2. Fortunatelly, I had a backup of Armbian_5.82.190423_Orangepilite2_Debian_stretch_dev_5.0.7.7z Can I do anything to help identify the issue? Link to comment Share on other sites More sharing options...
martinayotte Posted May 4, 2019 Share Posted May 4, 2019 6 minutes ago, data said: [ 7.300118] thermal thermal_zone0: failed to read out thermal zone (-16) [ 7.300306] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz [ 7.306963] thermal thermal_zone1: failed to read out thermal zone (-16) [ 7.314324] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1080000 KHz According to the other thread, it seems that you figure out that the issue been introduced between working 5.07 and broken 5.0.10 ... We didn't find the culprit change yet ... Also, as developer, I figured that the issue isn't present in my private 5.1.0-rc7 build ... Link to comment Share on other sites More sharing options...
Igor Posted May 4, 2019 Share Posted May 4, 2019 21 hours ago, martinayotte said: Keep it as a safe backup Now this is last one - others broken ones were removed + nightly building has been disabled. Latest one from the download should boot, but upgrade will break it most likely. 1 Link to comment Share on other sites More sharing options...
haajee Posted May 5, 2019 Share Posted May 5, 2019 The nightly from 23-04-18 works well. But after update/upgrade it looks like it reboots well but (the red light comes up) but no network and no display (but a known issue) i thought it was a NIC problem but also with a USB NIC it won't work. But thnx for the tip. I don't upgrade for now. Link to comment Share on other sites More sharing options...
裙下孤魂 Posted May 9, 2019 Share Posted May 9, 2019 latest available version: Armbian_5.83.190426_Orangepioneplus_Debian_stretch_dev_5.0.9.7z Link to comment Share on other sites More sharing options...
Werner Posted May 14, 2019 Author Share Posted May 14, 2019 Seems to be solved. Welcome to ARMBIAN 5.82.190423 nightly Debian GNU/Linux 9 (stretch) 5.1.0-sunxi64 Working well. Link to comment Share on other sites More sharing options...
