I've made my first build for OPiPC+ with 5.3.0-rc3 ...
Things are not looking very good : Wifi 8189fs is crashing, but eth0 is working.
I will investigate more ...
I tried to build an image for the OPi 1+ using megis orangepi-5.3 branch but did not even compile without any changes to the patches. Could not find the cause yet.
I didn't got any compile error, only one patch rejected, but because already present in 5.3.y.
One more thing I found with my OPiPC+ experiment : reboot doesn't restart, it stall at "reaching restart", but U-Boot "restarting" never appears ...
(a bit like the early days of H6, but OPiPC+ is H3 and never got this issue)
Now trying again with 5.2.6 to figure out when bugs has been introduced ...
EDIT: 5.2.6 still look good ...
EDIT2: Same behaviours with OPiPlus2E 5.3.0-rc3 image ...
EDIT3: Doing an OPiZeroPlus2-H5 images : No Wifi problem, and since no crash, "reboot" work properly, so, maybe related ...
Nice. Started my daily build process, lets see what we have after two or three hours.
In my case, I've done the tour of my AllWinner's garden : OPiPC+, OPiOne, OPiZero, OPi+2E, OPiPC2, OPi3, OPiOne+, OPiZero+2, OPiWin, OPiPrime, Pine64 and OlinuxinoA64. :lol:
Nightly builds are ... building and will be out in 1-2h.
6 hours ago, martinayotte said:
Commit for the 5.3.y switch is now done !
At dinner time I did try to compile for the OPi PC2 and the kernel doesnt build....but now in the evening it does compile fine with kernel 5.3 ;) Thanks!
With previous 5.2.y, it was working fine too since more than a month ...
41 minutes ago, TonyMac32 said:
I'll try to give it a look tomorrow, I finished my exploration of the La Frite tonight.
thank you.
My Opi R1 doenst like the enw compiled image
Armbian_5.93_Orangepi-r1_Debian_buster_dev_5.3.0-rc3
Couldnt connect via SSH and teh serial gadget via MicroUSB doenst repond :(
Have to check tomorrow via USB-TTL-console....
here the serial-boot-console log:
U-Boot SPL 2019.04-armbian (Aug 15 2019 - 18:05:39 +0300)
DRAM: 256 MiB
Trying to boot from MMC1
U-Boot 2019.04-armbian (Aug 15 2019 - 18:05:39 +0300) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi R1
DRAM:  256 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB EHCI 1.00
USB4:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3798 bytes read in 1 ms (3.6 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
228 bytes read in 1 ms (222.7 KiB/s)
7069513 bytes read in 341 ms (19.8 MiB/s)
7681160 bytes read in 371 ms (19.7 MiB/s)
30025 bytes read in 8 ms (3.6 MiB/s)
504 bytes read in 6 ms (82 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
504 bytes read in 7 ms (70.3 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4155 bytes read in 7 ms (579.1 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    7069449 Bytes = 6.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
EHCI failed to shut down host controller.
   Loading Ramdisk to 49942000, end 49ffff09 ... OK
   Loading Device Tree to 498d2000, end 49941fff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    6.543361] [<c0666a49>] (device_driver_attach) from [<c0666aa5>] (__driver_attach+0x4d/0x78)
[    6.543370] [<c0666aa5>] (__driver_attach) from [<c0665245>] (bus_for_each_dev+0x41/0x68)
[    6.543379] [<c0665245>] (bus_for_each_dev) from [<c0665d6b>] (bus_add_driver+0xe7/0x14c)
[    6.543388] [<c0665d6b>] (bus_add_driver) from [<c06671cb>] (driver_register+0x3b/0xa4)
[    6.543724] [<c06671cb>] (driver_register) from [<bf98e033>] (rtw_drv_entry+0x33/0x1000 [8189es])
[    6.544040] [<bf98e033>] (rtw_drv_entry [8189es]) from [<c0102ccd>] (do_one_initcall+0x39/0x19c)
[    6.544057] [<c0102ccd>] (do_one_initcall) from [<c018b3e9>] (do_init_module+0x4d/0x194)
[    6.544068] [<c018b3e9>] (do_init_module) from [<c018aa27>] (load_module+0x1783/0x1a8c)
[    6.544078] [<c018aa27>] (load_module) from [<c018aeb1>] (sys_finit_module+0x6d/0x88)
[    6.544087] [<c018aeb1>] (sys_finit_module) from [<c0101001>] (ret_fast_syscall+0x1/0x62)
[    6.544092] Exception stack(0xcf0bbfa8 to 0xcf0bbff0)
[    6.544100] bfa0:                   b6c2ae88 00000000 00000007 b6c2a59c 00000000 b6c2b0b0
[    6.544109] bfc0: b6c2ae88 00000000 a231aa00 0000017b 01a87868 00000000 00000000 01a8a5b0
[    6.544114] bfe0: beda4b48 beda4b38 b6c241cd b6e7dd92
[    6.544182] ---[ end trace 7655d88acceaea1f ]---
[    6.544189] ------------[ cut here ]------------
[    6.544204] WARNING: CPU: 3 PID: 284 at kernel/workqueue.c:3031 __flush_work+0x15b/0x168
[    6.544208] Modules linked in: 8189es(+) cfg80211 rfkill r8152 usb_f_acm u_serial g_serial libcomposite ip_tables x_tables pwrseq_simple
[    6.544238] CPU: 3 PID: 284 Comm: systemd-modules Tainted: G        W         5.3.0-rc3-sunxi #5.93
[    6.544241] Hardware name: Allwinner sun8i Family
[    6.544256] [<c010d751>] (unwind_backtrace) from [<c010a32d>] (show_stack+0x11/0x14)
[    6.544269] [<c010a32d>] (show_stack) from [<c0921d69>] (dump_stack+0x69/0x78)
[    6.544284] [<c0921d69>] (dump_stack) from [<c011b439>] (__warn+0xa1/0xb4)
[    6.544295] [<c011b439>] (__warn) from [<c011b513>] (warn_slowpath_null+0x2f/0x34)
[    6.544306] [<c011b513>] (warn_slowpath_null) from [<c012fbe7>] (__flush_work+0x15b/0x168)
[    6.544319] [<c012fbe7>] (__flush_work) from [<c012fd9b>] (__cancel_work_timer+0xbb/0x154)
[    6.544347] [<c012fd9b>] (__cancel_work_timer) from [<bf84bfad>] (rfkill_unregister+0x31/0x94 [rfkill])
[    6.544540] [<bf84bfad>] (rfkill_unregister [rfkill]) from [<bf8512d1>] (wiphy_unregister+0x3d/0x25c [cfg80211])
[    6.545028] [<bf8512d1>] (wiphy_unregister [cfg80211]) from [<bf8f54c3>] (rtw_wiphy_unregister+0x15/0x16 [8189es])
[    6.545736] [<bf8f54c3>] (rtw_wiphy_unregister [8189es]) from [<bf8f567b>] (rtw_cfg80211_ndev_res_unregister+0x1f/0x20 [8189es])
[    6.546554] [<bf8f567b>] (rtw_cfg80211_ndev_res_unregister [8189es]) from [<bf8e6c55>] (rtw_os_ndev_unregister+0x2b/0x3a [8189es])
[    6.547167] [<bf8e6c55>] (rtw_os_ndev_unregister [8189es]) from [<bf8e73b3>] (rtw_os_ndevs_register+0xcf/0xda [8189es])
[    6.547821] [<bf8e73b3>] (rtw_os_ndevs_register [8189es]) from [<bf8e7415>] (rtw_os_ndevs_init+0x1f/0x2c [8189es])
[    6.548371] [<bf8e7415>] (rtw_os_ndevs_init [8189es]) from [<bf8e8033>] (rtw_drv_init+0x59/0x92 [8189es])
[    6.548690] [<bf8e8033>] (rtw_drv_init [8189es]) from [<c07ac5a7>] (sdio_bus_probe+0x63/0xc8)
[    6.548706] [<c07ac5a7>] (sdio_bus_probe) from [<c06665f3>] (really_probe+0xab/0x1ec)
[    6.548718] [<c06665f3>] (really_probe) from [<c0666863>] (driver_probe_device+0x43/0x118)
[    6.548727] [<c0666863>] (driver_probe_device) from [<c0666a49>] (device_driver_attach+0x3d/0x4c)
[    6.548741] [<c0666a49>] (device_driver_attach) from [<c0666aa5>] (__driver_attach+0x4d/0x78)
[    6.548750] [<c0666aa5>] (__driver_attach) from [<c0665245>] (bus_for_each_dev+0x41/0x68)
[    6.548759] [<c0665245>] (bus_for_each_dev) from [<c0665d6b>] (bus_add_driver+0xe7/0x14c)
[    6.548767] [<c0665d6b>] (bus_add_driver) from [<c06671cb>] (driver_register+0x3b/0xa4)
[    6.549131] [<c06671cb>] (driver_register) from [<bf98e033>] (rtw_drv_entry+0x33/0x1000 [8189es])
[    6.549504] [<bf98e033>] (rtw_drv_entry [8189es]) from [<c0102ccd>] (do_one_initcall+0x39/0x19c)
[    6.549531] [<c0102ccd>] (do_one_initcall) from [<c018b3e9>] (do_init_module+0x4d/0x194)
[    6.549556] [<c018b3e9>] (do_init_module) from [<c018aa27>] (load_module+0x1783/0x1a8c)
[    6.549572] [<c018aa27>] (load_module) from [<c018aeb1>] (sys_finit_module+0x6d/0x88)
[    6.549589] [<c018aeb1>] (sys_finit_module) from [<c0101001>] (ret_fast_syscall+0x1/0x62)
[    6.549594] Exception stack(0xcf0bbfa8 to 0xcf0bbff0)
[    6.549615] bfa0:                   b6c2ae88 00000000 00000007 b6c2a59c 00000000 b6c2b0b0
[    6.549632] bfc0: b6c2ae88 00000000 a231aa00 0000017b 01a87868 00000000 00000000 01a8a5b0
[    6.549642] bfe0: beda4b48 beda4b38 b6c241cd b6e7dd92
[    6.549682] ---[ end trace 7655d88acceaea20 ]---
[    6.549697] 8<--- cut here ---
[    6.549703] Unable to handle kernel NULL pointer dereference at virtual address 00000064
[    6.549709] pgd = (ptrval)
[    6.549714] [00000064] *pgd=00000000
[    6.549724] Internal error: Oops: 5 [#1] SMP THUMB2
[    6.549728] Modules linked in: 8189es(+) cfg80211 rfkill r8152 usb_f_acm u_serial g_serial libcomposite ip_tables x_tables pwrseq_simple
[    6.549761] CPU: 3 PID: 284 Comm: systemd-modules Tainted: G        W         5.3.0-rc3-sunxi #5.93
[    6.549765] Hardware name: Allwinner sun8i Family
[    6.549775] PC is at device_del+0x2c/0x254
[    6.549780] LR is at device_del+0x29/0x254
[    6.549784] pc : [<c06632e8>]    lr : [<c06632e5>]    psr: 60050133
[    6.549788] sp : cf0bbc08  ip : 00000000  fp : c0f04d48
[    6.549791] r10: d0a95f91  r9 : 00000001  r8 : ce106a80
[    6.549795] r7 : c0f04d48  r6 : c0f04d48  r5 : ce70748c  r4 : ce707448
[    6.549799] r3 : cfbbc780  r2 : 00000000  r1 : 00000000  r0 : ce70748c
[    6.549806] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment none
[    6.549810] Control: 50c5387d  Table: 4f17406a  DAC: 00000051
[    6.549815] Process systemd-modules (pid: 284, stack limit = 0x(ptrval))
[    6.549819] Stack: (0xcf0bbc08 to 0xcf0bc000)
[    6.549827] bc00:                   60050113 c0f04d48 d0a95f91 cf0bbc14 cf0bbc14 5b1ac318
[    6.549835] bc20: ce707400 ce707610 c0f04d48 00000000 d0a95ba4 00000001 d0a95f91 bf84bfb9
[    6.549844] bc40: ce1069a0 ce106800 c0f04d48 bf8512d1 d0a96e5c bf8f4297 cf0bbc54 00000000
[    6.549871] bc60: bf941c34 5b1ac318 ce1069a0 ce219124 ce219000 00000000 d0a95ba4 bf8f54c3
[    6.549884] bc80: d0a93000 bf8f567b d0a93000 bf8e6c55 ce219124 bf8e73b3 ce219000 cd5ab800
[    6.549893] bca0: d0a93000 bf93d018 bf954844 bf954844 0000001b bf8e7415 ce219000 bf8e8033
[    6.549902] bcc0: cd5ab808 00000000 cd5ab800 c07ac5a7 c1048944 cd5ab808 c1048948 00000000
[    6.549910] bce0: 00000000 c06665f3 cd5ab808 bf954844 bf954844 c0f04d48 cf199464 00000000
[    6.549919] bd00: bf96bfc0 c0666863 c104df48 00000000 00000000 cd5ab808 00000000 bf954844
[    6.549927] bd20: c0f04d48 cf199464 00000000 bf96bfc0 c0f04d48 c0666a49 00000000 bf954844
[    6.549936] bd40: cd5ab808 c0666aa5 bf954844 bf954844 c0666a59 c0665245 cf0bbd80 cfa63358
[    6.549945] bd60: cd5e32b4 5b1ac318 00000000 bf954844 ce5e8700 00000000 c0fdb190 c0665d6b
[    6.549954] bd80: bf941ce4 c0924e85 bf954844 bf954844 c0f04d48 cd742840 bf98e001 c06671cb
[    6.549967] bda0: bf954834 bf954834 c0f04d48 bf98e033 bf96bfc0 c0102ccd cf0bbdd8 cff75aa4
[    6.549979] bdc0: 00210d00 8010000f c0f04d48 cd4c2f00 c0fed840 5b1ac318 00060013 cffad6a0
[    6.549987] bde0: cfa6b800 c023dac3 00000000 c023dac3 cfa6b800 5b1ac318 cf801800 00000000
[    6.549996] be00: cd4c2f00 5b1ac318 00000001 bf96bfc0 00000001 cd742840 00000001 cf199464
[    6.550004] be20: d0de7000 c018b3e9 cf0bbf38 00000001 cf0bbf38 00000001 cf199440 c018aa27
[    6.550014] be40: bf96bfcc 00007fff bf96bfc0 c018883d 00000001 bf96c008 c018834d bf96c0d4
[    6.550023] be60: c0b91f04 bf9ba063 bf96c1c8 bf98f000 c0b91e50 c0b91e5c c0b91eb4 c0f04d48
[    6.550032] be80: cf0ba000 bf94d55b 00000001 cf0bbeb8 0014517c c0250c67 bf93b024 00000005
[    6.550040] bea0: 00000000 00000000 00000000 00000000 6e72656b 00006c65 00000000 00000000
[    6.550051] bec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    6.550060] bee0: 00000000 00000000 00000000 5b1ac318 7fffffff c0f04d48 00000000 d0de7000
[    6.550069] bf00: b6c2a59c c0101224 cf0ba000 0000017b 01a8a5b0 c018aeb1 7fffffff 00000000
[    6.550077] bf20: 00000003 00000000 0014517c d0de7000 0014517c 00000000 d0e7bb0b d0e95140
[    6.550086] bf40: d0de7000 0014517c d0f2ba24 d0f2b85c d0eb6208 000b9000 000c5cf0 0002b0cc
[    6.550095] bf60: 000d2b15 00000000 00000000 00000000 0002b0bc 0000002c 0000002d 00000021
[    6.550103] bf80: 00000000 00000011 00000000 5b1ac318 00000000 b6c2ae88 00000000 a231aa00
[    6.550112] bfa0: 0000017b c0101001 b6c2ae88 00000000 00000007 b6c2a59c 00000000 b6c2b0b0
[    6.550120] bfc0: b6c2ae88 00000000 a231aa00 0000017b 01a87868 00000000 00000000 01a8a5b0
[    6.550129] bfe0: beda4b48 beda4b38 b6c241cd b6e7dd92 40010030 00000007 00000000 00000000
[    6.550161] [<c06632e8>] (device_del) from [<bf84bfb9>] (rfkill_unregister+0x3d/0x94 [rfkill])
[    6.550355] [<bf84bfb9>] (rfkill_unregister [rfkill]) from [<bf8512d1>] (wiphy_unregister+0x3d/0x25c [cfg80211])
[    6.550913] [<bf8512d1>] (wiphy_unregister [cfg80211]) from [<bf8f54c3>] (rtw_wiphy_unregister+0x15/0x16 [8189es])
[    6.551605] [<bf8f54c3>] (rtw_wiphy_unregister [8189es]) from [<bf8f567b>] (rtw_cfg80211_ndev_res_unregister+0x1f/0x20 [8189es])
[    6.552268] [<bf8f567b>] (rtw_cfg80211_ndev_res_unregister [8189es]) from [<bf8e6c55>] (rtw_os_ndev_unregister+0x2b/0x3a [8189es])
[    6.552928] [<bf8e6c55>] (rtw_os_ndev_unregister [8189es]) from [<bf8e73b3>] (rtw_os_ndevs_register+0xcf/0xda [8189es])
[    6.553592] [<bf8e73b3>] (rtw_os_ndevs_register [8189es]) from [<bf8e7415>] (rtw_os_ndevs_init+0x1f/0x2c [8189es])
[    6.554217] [<bf8e7415>] (rtw_os_ndevs_init [8189es]) from [<bf8e8033>] (rtw_drv_init+0x59/0x92 [8189es])
[    6.554539] [<bf8e8033>] (rtw_drv_init [8189es]) from [<c07ac5a7>] (sdio_bus_probe+0x63/0xc8)
[    6.554556] [<c07ac5a7>] (sdio_bus_probe) from [<c06665f3>] (really_probe+0xab/0x1ec)
[    6.554568] [<c06665f3>] (really_probe) from [<c0666863>] (driver_probe_device+0x43/0x118)
[    6.554577] [<c0666863>] (driver_probe_device) from [<c0666a49>] (device_driver_attach+0x3d/0x4c)
[    6.554586] [<c0666a49>] (device_driver_attach) from [<c0666aa5>] (__driver_attach+0x4d/0x78)
[    6.554595] [<c0666aa5>] (__driver_attach) from [<c0665245>] (bus_for_each_dev+0x41/0x68)
[    6.554604] [<c0665245>] (bus_for_each_dev) from [<c0665d6b>] (bus_add_driver+0xe7/0x14c)
[    6.554612] [<c0665d6b>] (bus_add_driver) from [<c06671cb>] (driver_register+0x3b/0xa4)
[    6.554937] [<c06671cb>] (driver_register) from [<bf98e033>] (rtw_drv_entry+0x33/0x1000 [8189es])
[    6.555270] [<bf98e033>] (rtw_drv_entry [8189es]) from [<c0102ccd>] (do_one_initcall+0x39/0x19c)
[    6.555285] [<c0102ccd>] (do_one_initcall) from [<c018b3e9>] (do_init_module+0x4d/0x194)
[    6.555296] [<c018b3e9>] (do_init_module) from [<c018aa27>] (load_module+0x1783/0x1a8c)
[    6.555305] [<c018aa27>] (load_module) from [<c018aeb1>] (sys_finit_module+0x6d/0x88)
[    6.555315] [<c018aeb1>] (sys_finit_module) from [<c0101001>] (ret_fast_syscall+0x1/0x62)
[    6.555320] Exception stack(0xcf0bbfa8 to 0xcf0bbff0)
[    6.555328] bfa0:                   b6c2ae88 00000000 00000007 b6c2a59c 00000000 b6c2b0b0
[    6.555336] bfc0: b6c2ae88 00000000 a231aa00 0000017b 01a87868 00000000 00000000 01a8a5b0
[    6.555342] bfe0: beda4b48 beda4b38 b6c241cd b6e7dd92
[    6.555353] Code: f2d0 fd06 6aa2 4628 (f892) 3064
[    6.555425] ---[ end trace 7655d88acceaea21 ]---
[    6.756368] cfg80211: failed to load regulatory.db
[    6.815603] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[    6.856644] r8152 3-1:1.0 enxc0742bffe8ff: renamed from eth1
[    6.860796] cpu cpu0: _opp_add: OPP not supported by regulators (1056000000)
[    7.628900] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[    7.638928] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
[    7.639084] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[    7.639091] cpu cpu0: _opp_add: OPP not supported by regulators (1152000000)
[    7.639214] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[    7.639221] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
[    7.639308] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
[    7.639314] cpu cpu0: _opp_add: OPP not supported by regulators (1224000000)
[    7.639428] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
[    7.639435] cpu cpu0: _opp_add: OPP not supported by regulators (1248000000)
[    7.639550] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
[    7.639557] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
[    7.639641] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
[    7.639647] cpu cpu0: _opp_add: OPP not supported by regulators (1344000000)
[    7.639757] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
[    7.639764] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
[    7.640240] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-22
[    7.974342] sun8i_ths 1c25000.thermal-sensor: no memory resources defined
[    7.981235] sun8i_ths: probe of 1c25000.thermal-sensor failed with error -22
[    8.056310] thermal thermal_zone0: failed to read out thermal zone (-110)
[    8.104695] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
[    8.111108] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
[    8.117554] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[    8.124011] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[    8.160894] lima 1c40000.gpu: bus rate = 200000000
[    8.165841] lima 1c40000.gpu: mod rate = 384000000
[    8.176537] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 0
[BUT WAIT]
while copying the output from the serial console and doing some other stuff the login prompt does appear ;)
Debian Buster with Armbian Linux ttyS0
orangepi login:
So here also the armbianmonitor -u
System diagnosis information will now be uploaded to http://ix.io/1RQA
Seems to be some problem with the 8189es network driver....
Yesterday - I think - I also waited some minutes, but got no DHCP-IP-Request.
Strange - my OPi R1 doenst also like the mainline
Armbian_5.93_Orangepi-r1_Debian_buster_next_4.19.67
Many TimeOuts of services and CPU-stalling :(
[EDIT]
4.19.67 mainline is now running - problem was the attached OPi Zero NAS-Hat
Without the NAS-Hat (which wasnt a problem in the past) the mainline does boot fine.
but the 5.3 stays with the exception while booting.
2 hours ago, martinayotte said:
When you did your build, did you have this commit already ?
https://github.com/armbian/build/commit/a89842487398157cf91487acb414ccfe42a16331
Your commit seems to be 6 days old.
The first compile was around 6 hours ago and I did recompile now the same image.
While booting I got the following error-messages in boot-log:
[  OK  ] Started Load/Save Random Seed.
[    6.622431] Internal error: Oops: 5 [#1] SMP THUMB2
[    6.623527] r8152 3-1:1.0 eth1: v1.09.10
[    6.627317] Modules linked in: 8189es(+) cfg80211 rfkill r8152 usb_f_acm u_serial g_serial libcomposite ip_tables x_tables pwrseq_simple
[    6.627355] CPU: 2 PID: 294 Comm: systemd-modules Tainted: G        W         5.3.0-rc3-sunxi #5.93
[    6.627362] Hardware name: Allwinner sun8i Family
[    6.657289] PC is at device_del+0x2c/0x254
[    6.657300] LR is at device_del+0x29/0x254
[    6.665484] pc : [<c06632e8>]    lr : [<c06632e5>]    psr: 60030133
[    6.671749] sp : ce413c08  ip : 00000000  fp : c0f04d48
[[    6.676973] r10: d0a83f91  r9 : 00000001  r8 : ce46ea80
  OK  ] Started Flush Journal to Persistent Storage.
[    6.689057] r7 : c0f04d48  r6 : c0f04d48  r5 : cf18608c  r4 : cf186048
[    6.695592] r3 : cdbc6e80  r2 : 00000000  r1 : 00000000  r0 : cf18608c
[    6.702122] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment none
[    6.709428] Control: 50c5387d  Table: 4e58406a  DAC: 00000051
[    6.715199] Process systemd-modules (pid: 294, stack limit = 0x(ptrval))
[    6.715208] Stack: (0xce413c08 to 0xce414000)
[    6.726268] 3c00:                   60030113 c0f04d48 c0101001 ce413c14 ce413c14 2cfb3da8
[    6.734452] 3c20: cf186000 cf186210 c0f04d48 00000000 d0a83ba4 00000001 d0a83f91 bf84bfb9
[    6.742623] 3c40: ce46e9a0 ce46e800 c0f04d48 bf8512d1 d0a84e5c bf8f4297 ce413c54 00000000
[    6.750792] 3c60: bf941c34 2cfb3da8 ce46e9a0 cc802924 cc802800 00000000 d0a83ba4 bf8f54c3
[    6.758960] 3c80: d0a81000 bf8f567b d0a81000 bf8e6c55 cc802924 bf8e73b3 cc802800 cd56cc00
[    6.767128] 3ca0: d0a81000 bf93d018 bf954844 bf954844 0000001a bf8e7415 cc802800 bf8e8033
[    6.775308] 3cc0: cd56cc08 00000000 cd56cc00 c07ac5a7 c1048944 cd56cc08 c1048948 00000000
[    6.783482] 3ce0: 00000000 c06665f3 cd56cc08 bf954844 bf954844 c0f04d48 cc8ba5a4 00000000
[    6.791652] 3d00: bf96bfc0 c0666863 c104df48 00000000 00000000 cd56cc08 00000000 bf954844
[    6.799839] 3d20: c0f04d48 cc8ba5a4 00000000 bf96bfc0 c0f04d48 c0666a49 00000000 bf954844
[    6.808013] 3d40: cd56cc08 c0666aa5 bf954844 bf954844 c0666a59 c0665245 ce413d80 cfa62358
[    6.816180] 3d60: cd5171b4 2cfb3da8 00000000 bf954844 ce2abe00 00000000 c0fdb190 c0665d6b
[    6.824348] 3d80: bf941ce4 c0924e85 bf954844 bf954844 c0f04d48 cc8baf80 bf98e001 c06671cb
[    6.832516] 3da0: bf954834 bf954834 c0f04d48 bf98e033 bf96bfc0 c0102ccd ce413dd8 cff76a64
[    6.840684] 3dc0: 00210d00 8010000e c0f04d48 ce4e3540 c0fed840 2cfb3da8 d0f3ffff cffad6a0
[    6.848852] 3de0: cfa6a800 c023dac3 00000000 c023dac3 d0df9000 2cfb3da8 c0f04d48 00000000
[    6.857020] 3e00: ce4e3540 2cfb3da8 00000001 bf96bfc0 00000001 cc8baf80 00000001 cc8ba5a4
[    6.865188] 3e20: d0df9000 c018b3e9 ce413f38 00000001 ce413f38 00000001 cc8ba580 c018aa27
[    6.873355] 3e40: bf96bfcc 00007fff bf96bfc0 c018883d 00000001 bf96c008 c018834d bf96c0d4
[    6.881523] 3e60: c0b91f04 bf9ba063 bf96c1c8 bf98f000 c0b91e50 c0b91e5c c0b91eb4 c0f04d48
[    6.889691] 3e80: ce412000 bf94d55b 00000001 ce413eb8 0014517c c0250c67 bf93b024 00000005
[    6.897858] 3ea0: 00000000 00000000 00000000 00000000 6e72656b 00006c65 00000000 00000000
[    6.906025] 3ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    6.914193] 3ee0: 00000000 00000000 00000000 2cfb3da8 7fffffff c0f04d48 00000000 d0df9000
[    6.922361] 3f00: b6d0859c c0101224 ce412000 0000017b 01ec4588 c018aeb1 7fffffff 00000000
[    6.930528] 3f20: 00000003 00000000 0014517c d0df9000 0014517c 00000000 d0e8db0b d0ea7140
[    6.938697] 3f40: d0df9000 0014517c d0f3da24 d0f3d85c d0ec8208 000b9000 000c5cf0 0002b0cc
[    6.946864] 3f60: 000d2b15 00000000 00000000 00000000 0002b0bc 0000002c 0000002d 00000021
[    6.955032] 3f80: 00000000 00000011 00000000 2cfb3da8 00000000 b6d08e88 00000000 359e4000
[    6.963200] 3fa0: 0000017b c0101001 b6d08e88 00000000 00000007 b6d0859c 00000000 b6d090b0
[    6.971367] 3fc0: b6d08e88 00000000 359e4000 0000017b 01ec4350 00000000 00000000 01ec4588
[    6.979535] 3fe0: be890b48 be890b38 b6d021cd b6f5bd92 40010030 00000007 00000000 00000000
[    6.987730] [<c06632e8>] (device_del) from [<bf84bfb9>] (rfkill_unregister+0x3d/0x94 [rfkill])
[    6.996514] [<bf84bfb9>] (rfkill_unregister [rfkill]) from [<bf8512d1>] (wiphy_unregister+0x3d/0x25c [cfg80211])
[    7.007279] [<bf8512d1>] (wiphy_unregister [cfg80211]) from [<bf8f54c3>] (rtw_wiphy_unregister+0x15/0x16 [8189es])
[    7.018121] [<bf8f54c3>] (rtw_wiphy_unregister [8189es]) from [<bf8f567b>] (rtw_cfg80211_ndev_res_unregister+0x1f/0x20 [8189es])
[    7.030128] [<bf8f567b>] (rtw_cfg80211_ndev_res_unregister [8189es]) from [<bf8e6c55>] (rtw_os_ndev_unregister+0x2b/0x3a [8189es])
[    7.042308] [<bf8e6c55>] (rtw_os_ndev_unregister [8189es]) from [<bf8e73b3>] (rtw_os_ndevs_register+0xcf/0xda [8189es])
[    7.053532] [<bf8e73b3>] (rtw_os_ndevs_register [8189es]) from [<bf8e7415>] (rtw_os_ndevs_init+0x1f/0x2c [8189es])
[    7.064322] [<bf8e7415>] (rtw_os_ndevs_init [8189es]) from [<bf8e8033>] (rtw_drv_init+0x59/0x92 [8189es])
[    7.074112] [<bf8e8033>] (rtw_drv_init [8189es]) from [<c07ac5a7>] (sdio_bus_probe+0x63/0xc8)
[    7.082632] [<c07ac5a7>] (sdio_bus_probe) from [<c06665f3>] (really_probe+0xab/0x1ec)
[    7.090455] [<c06665f3>] (really_probe) from [<c0666863>] (driver_probe_device+0x43/0x118)
[    7.098711] [<c0666863>] (driver_probe_device) from [<c0666a49>] (device_driver_attach+0x3d/0x4c)
[    7.107573] [<c0666a49>] (device_driver_attach) from [<c0666aa5>] (__driver_attach+0x4d/0x78)
[    7.116088] [<c0666aa5>] (__driver_attach) from [<c0665245>] (bus_for_each_dev+0x41/0x68)
[    7.124255] [<c0665245>] (bus_for_each_dev) from [<c0665d6b>] (bus_add_driver+0xe7/0x14c)
[    7.132424] [<c0665d6b>] (bus_add_driver) from [<c06671cb>] (driver_register+0x3b/0xa4)
[    7.140650] [<c06671cb>] (driver_register) from [<bf98e033>] (rtw_drv_entry+0x33/0x1000 [8189es])
[    7.149744] [<bf98e033>] (rtw_drv_entry [8189es]) from [<c0102ccd>] (do_one_initcall+0x39/0x19c)
[    7.158525] [<c0102ccd>] (do_one_initcall) from [<c018b3e9>] (do_init_module+0x4d/0x194)
[    7.166608] [<c018b3e9>] (do_init_module) from [<c018aa27>] (load_module+0x1783/0x1a8c)
[    7.174604] [<c018aa27>] (load_module) from [<c018aeb1>] (sys_finit_module+0x6d/0x88)
[    7.182426] [<c018aeb1>] (sys_finit_module) from [<c0101001>] (ret_fast_syscall+0x1/0x62)
[    7.190589] Exception stack(0xce413fa8 to 0xce413ff0)
[    7.195636] 3fa0:                   b6d08e88 00000000 00000007 b6d0859c 00000000 b6d090b0
[    7.203804] 3fc0: b6d08e88 00000000 359e4000 0000017b 01ec4350 00000000 00000000 01ec4588
[    7.211968] 3fe0: be890b48 be890b38 b6d021cd b6f5bd92
[    7.217017] Code: f2d0 fd06 6aa2 4628 (f892) 3064
[    7.221862] ---[ end trace b53a28fb2c99ff88 ]---
[   24.629252] random: crng init done
[   24.632664] random: 7 urandom warning(s) missed due to ratelimiting
[  OK  ] Started Set the console keyboard layout.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Create System Users.
 but system came up including the 2 network-interfaces:
armbianmonitor -u
more messages while booting could be found at:
System diagnosis information will now be uploaded to http://ix.io/1RUh
It actually crashed for me too, but so far I was not able to recreate. On NEXT branch, not on DEV.
@martinayotte network-interfaces are only available with network-manager.
if I only use ipupdown they wont be ready :(
BTW: reboot doenst work because it wouldnt restart and hang at the restart-message:
[  OK  ] Reached target Final Step.
[  OK  ] Started Reboot.
[  OK  ] Reached target Reboot.
I've compile it too on my side, and I got the 8189fs crash too. I've even tested 5.3.0-rc3 kernel with 5.0.0 DT, but crash still there.
So, that must be something else directly in the kernel.
I will now try building a 5.2.y and 5.1.y kernels to narrow the issue ...
Yes, I've seen that too, but on my previous 5.0.0 reboot works ...
I think I figured out : my commit of 6 days ago was for 8189fs and 8723cs, but not 8189es !
I will create a new patch for that one ...
EDIT : Oh ! @Igor Where the 8189es sources comes from ? I didn't found a patch for it neither than a git clone ...
EDIT2 : I've founded the patch, I was a bit blind earlier ...
I don't recall. Perhaps by email from Xunlong ? :) ES is missing from DEV. They are inside NEXT branch only.
No ! it is there as wifi-3002-add-realtek-8189es.patch ...
As I said in EDIT2, I was a bit blind earlier ...
I will fix that patch for 5.3.y !
13 minutes ago, Igor said:
OK. I will also add all of them here later/over weekend:
If you turn those patch into "git clone" in compilation-prepare.sh, remember that we failed to use some patching on them since they are cloned AFTER patching phase ...
(remember that we tried to get this order reversed a month ago, but you decided to revert it)
Otherwise, the "git clone" would need to be done from Armbian branches to keep controls of them ... :P
