Nobby42 Posted December 10, 2019 Posted December 10, 2019 Hi, I have a problem with my NanoPi M4V2 (with Raspberry Pi 4 power supply) and the new Armbian release 19.11.3 (Buster). I can boot the image from SD, eMMC. But when I connect any USB storage (USB-Stick or SSD with USB to SATA) then I have packet lost on the Ethernet connection. Any idea where the problem is? On the interface I can't see problems. eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.xx.36 netmask 255.255.255.0 broadcast 192.168.42.255 inet6 fd58:xxxx:xxxx:1::1006 prefixlen 64 scopeid 0x0<global> inet6 fe80::94ad:f6ff:fe0d:757b prefixlen 64 scopeid 0x20<link> ether 96:ad:f6:0d:75:7b txqueuelen 1000 (Ethernet) RX packets 1475 bytes 231894 (226.4 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 1088 bytes 129189 (126.1 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 24 Thanks for your support and kind regards Norbert
Nobby42 Posted December 10, 2019 Author Posted December 10, 2019 Hi, I have testet the image with the 5.4.2 kernel. No problems. Can anyone reproduce the problem with the 4.4.192 kernel? Kind regards Norbert
pkfox Posted December 11, 2019 Posted December 11, 2019 On 12/10/2019 at 12:38 PM, Nobby42 said: Hi, I have a problem with my NanoPi M4V2 (with Raspberry Pi 4 power supply) and the new Armbian release 19.11.3 (Buster). I can boot the image from SD, eMMC. But when I connect any USB storage (USB-Stick or SSD with USB to SATA) then I have packet lost on the Ethernet connection. Any idea where the problem is? On the interface I can't see problems. eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.xx.36 netmask 255.255.255.0 broadcast 192.168.42.255 inet6 fd58:xxxx:xxxx:1::1006 prefixlen 64 scopeid 0x0<global> inet6 fe80::94ad:f6ff:fe0d:757b prefixlen 64 scopeid 0x20<link> ether 96:ad:f6:0d:75:7b txqueuelen 1000 (Ethernet) RX packets 1475 bytes 231894 (226.4 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 1088 bytes 129189 (126.1 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 24 Thanks for your support and kind regards Norbert Expand Hi I have one of these boards and haven't noticed any degradation in signal ( but unless it was dropping the connection I wouldn't check ) do you have WiFi working on this Buster release?
Nobby42 Posted December 11, 2019 Author Posted December 11, 2019 Hi, I work without WiFi. Regards Norbert
pkfox Posted December 11, 2019 Posted December 11, 2019 On 12/11/2019 at 8:51 AM, Nobby42 said: Hi, I work without WiFi. Regards Norbert Expand Oh ok WiFi doesn't work on Buster
piter75 Posted December 12, 2019 Posted December 12, 2019 On 12/10/2019 at 7:09 PM, Nobby42 said: Can anyone reproduce the problem with the 4.4.192 kernel Expand I verified and can confirm there are issues with networking on 4.4.192. LAN is not working well and WLAN cannot connect to AP. I will look into fixing that but no ETA guaranteed ;-)
SpringPeace Endy Posted December 12, 2019 Posted December 12, 2019 (edited) Hello, 'openpvn' is still waiting and does not make new network interface. I suppose that a reason is missed TUN kernel module. but manually I can make a TAP device ip tuntap add mode tap dev tap0 root@nanopim4v2:/etc/openvpn/client# ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether fe:0f:8e:36:d4:22 brd ff:ff:ff:ff:ff:ff 3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 96:ad:f6:0d:75:7b brd ff:ff:ff:ff:ff:ff inet 192.168.100.105/24 brd 192.168.100.255 scope global noprefixroute eth0 valid_lft forever preferred_lft forever inet6 fe80::a0d5:e8e8:9ecf:42b3/64 scope link noprefixroute valid_lft forever preferred_lft forever 4: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether c0:84:7d:18:b0:6a brd ff:ff:ff:ff:ff:ff 6: tap0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 3e:61:c0:43:ae:4a brd ff:ff:ff:ff:ff:ff root@nanopim4v2:/etc/openvpn/client# openvpn --config client.conf Jarek PS: Armbian_19.11.3_Nanopim4v2_buster_legacy_4.4.192 has a very slow network (it is not usable) Edited December 12, 2019 by SpringPeace Endy Add next details
Igor Posted December 12, 2019 Posted December 12, 2019 On 12/12/2019 at 8:53 AM, SpringPeace Endy said: Armbian_19.11.3_Nanopim4v2_buster_legacy_4.4.192 has a very slow network (it is not usable) Expand Devices labelled as testing will have troubles and are not ready for deployment / real use case. https://www.armbian.com/get-involved
NicoD Posted December 12, 2019 Posted December 12, 2019 Did you copy the needed files for M4V2 wifi? 4th comment from Martinayotte
SpringPeace Endy Posted December 16, 2019 Posted December 16, 2019 On 12/12/2019 at 9:52 AM, Igor said: Devices labelled as testing will have troubles and are not ready for deployment / real use case. https://www.armbian.com/get-involved Expand Ohh ... there is a difference between `NanoPi M4` and `NanoPi M4 V2` :-( ... it is pitty ... Thank you for info. I overlooked that
Igor Posted December 16, 2019 Posted December 16, 2019 On 12/16/2019 at 3:40 PM, SpringPeace Endy said: Ohh ... there is a difference between `NanoPi M4` and `NanoPi M4 V2` :-( ... it is pitty ... Thank you for info. I overlooked that Expand Yes. We do have image for V2 but it need some work - for testing only at this point: https://www.armbian.com/nanopi-m4-v2/
Matthias Posted December 18, 2019 Posted December 18, 2019 Some further observations of mine in case it helps identifying the problems using ethernet: After noticing that the throughput using the native ethernet connection (eth0) of the M4V2 is low, I checked it using iperf3. I tested the legacy kernel, the current kernel and the dev kernel. The results are quite interesting: Legacy kernel: Can receive data via TCP from anoter host with high speed (~940MBit/s) but the other way around is quite slow (<1MBit/s). Current/dev kernel: Can send data via TCP to another host with high speed (~950MBit/s) but the other way around is quite slow (~3MBit/s). Further information: If I set the link speed to 10MBit half duplex there seems to be almost no packet loss that slows down the connection. Using a USB3-ethernet adapter speed is good in both directions. I did not care about WiFi. It's not connected. There is a SATA hat attached to my NanoPi M4V2. Only power supply is used, no hdds are connected. Of course I only have one device at hand, so I cannot guarantee that the behavior is representative. Generally: If there is somebody working on further bringup of NanoPi M4V2 and needs somebody for testing, I'm happy to assist. 1
piter75 Posted December 18, 2019 Posted December 18, 2019 On 12/18/2019 at 8:52 AM, Matthias said: Legacy kernel: Can receive data via TCP from anoter host with high speed (~940MBit/s) but the other way around is quite slow (<1MBit/s). Current/dev kernel: Can send data via TCP to another host with high speed (~950MBit/s) but the other way around is quite slow (~3MBit/s). Expand Thanks for verifying and sharing this valuable insights. I never noticed / verified that for mainline kernels the issue exists but is opposite in direction.
SpringPeace Endy Posted December 20, 2019 Posted December 20, 2019 On 12/12/2019 at 8:53 AM, SpringPeace Endy said: Hello, 'openpvn' is still waiting and does not make new network interface. I suppose that a reason is missed TUN kernel module. but manually I can make a TAP device Expand My apologies, openvpn client is working correctly, but this new version requires to add an option 'tls-version-min 1.0'. BTW: It is strange that there was not any output
piter75 Posted December 27, 2019 Posted December 27, 2019 @Nobby42 @Matthias I hopefully fixed ethernet issues on legacy kernel in Armbian master. It works well on my unit. The issue with USB drives borking ethernet are also gone. Downloadable images were recreated. I also verified current (5.4.6) kernel and it does not exhibit the problems with network bandwidth in either direction - it's a strong 930-940mbps in both directions.
Matthias Posted December 27, 2019 Posted December 27, 2019 On 12/27/2019 at 9:33 AM, piter75 said: @Nobby42 @Matthias I hopefully fixed ethernet issues on legacy kernel in Armbian master. It works well on my unit. The issue with USB drives borking ethernet are also gone. Downloadable images were recreated. I also verified current (5.4.6) kernel and it does not exhibit the problems with network bandwidth in either direction - it's a strong 930-940mbps in both directions. Expand I can confirm your patched legacy-kernel can receive and transmit at about 930mbps. Good job, @piter75! Unfortunately I cannot confirm high rates for receiving data using kernel 5.4.6 on my hardware. I used this image to test the current kernel: Armbian_19.11.4_Nanopim4v2_buster_current_5.4.6.img (downloaded from server, no local compilation)
piter75 Posted December 28, 2019 Posted December 28, 2019 On 12/27/2019 at 11:19 PM, Matthias said: I cannot confirm high rates for receiving data using kernel 5.4.6 on my hardware Expand @Matthias thanks for verifying that. Could you try to fiddle a bit with `rx_delay` setting on your M4V2 with current kernel? The easiest and fastest way IMHO would be to add the following line to "/boot/boot.cmd" after "fdt resize 65536" line: fdt set /ethernet@fe300000 rx_delay <0x0E> rebuilding the boot script with: mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr and rebooting. You could try "0x0E", "0x14" and then maybe "0x0C" and "0x16" and see if it helps to move your receiving rates into expected levels.
Matthias Posted December 28, 2019 Posted December 28, 2019 On 12/28/2019 at 10:30 AM, piter75 said: The easiest and fastest way IMHO would be to add the following line to "/boot/boot.cmd" after "fdt resize 65536" line: fdt set /ethernet@fe300000 rx_delay <0x0E> rebuilding the boot script with: mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr and rebooting. You could try "0x0E", "0x14" and then maybe "0x0C" and "0x16" and see if it helps to move your receiving rates into expected levels. Expand Sure, I can do that. Thanks for the manual, looks quite straight forward. I was afraid I need to much "heavier" steps of the build process to check the different options. Just give me a day or two.
Matthias Posted December 28, 2019 Posted December 28, 2019 @piter75 I just tested the values for rx_delay you provided with kernel 5.4.6-rockchip64. 0x16 seems to be the best value for me, 0x14 offers a similar quality. You can find the details in the table below. rx_delay Observation 0x0E No connection to device via SSH possible. Problems receiving data? 0x14 Receives data at ~ 930mbit/s, but on very rare occasions drops down to ~200mbit/s but then normalizes again 0x0C No connection to device via SSH possible. Problems receiving data? 0x16 Receives data at ~ 930mbit/s, seems to be more stable than 0x14
piter75 Posted December 28, 2019 Posted December 28, 2019 On 12/28/2019 at 7:46 PM, Matthias said: 0x16 seems to be the best value for me Expand Thanks for verifying @Matthias! I also verified that 0x18 still works well with my unit and then settled with 0x16. I created a PR covering the change: https://github.com/armbian/build/pull/1698
chwe Posted December 29, 2019 Posted December 29, 2019 On 12/28/2019 at 10:50 PM, piter75 said: Thanks for verifying @Matthias! I also verified that 0x18 still works well with my unit and then settled with 0x1 Expand there's a tool to test this: https://github.com/ayufan-rock64/linux-build/blob/02fae982767ca242009baaf995f7ce64b5d82469/recipes/gmac-delays-test/range-test @tkaiser wrote one too back then.. but I can't remember where I have it anymore.. Nevermind https://github.com/ayufan-rock64/linux-build/blob/02fae982767ca242009baaf995f7ce64b5d82469/recipes/gmac-delays-test/range-test#L3 https://github.com/armbian/build/issues/546 1
piter75 Posted December 29, 2019 Posted December 29, 2019 On 12/29/2019 at 12:43 AM, chwe said: there's a tool to test this Expand Thanks for pointing that out. I did not know about it. Sometimes I feel like I know nothing Anyway, this reminded me that I need to add a patch with dynamic overlay support for rockchip64 in current target.
martinayotte Posted December 29, 2019 Posted December 29, 2019 On 12/29/2019 at 9:04 AM, piter75 said: this reminded me that I need to add a patch with dynamic overlay support for rockchip64 in current target. Expand Isn't that available since more than a year, at least in DEV ?
chwe Posted December 29, 2019 Posted December 29, 2019 let me fix that... On 12/29/2019 at 9:04 AM, piter75 said: Thanks for pointing that out. I did not know about it. Sometimes I feel like I know nothing not everything Expand spotting this one (https://github.com/TinkerBoard/debian_kernel/commit/30a8401c2f3851f4e9b46c9d3e8e1138ce8d5b51) to fix camera support for the tinkerboard took me over a year... it happens and when it happens it's IMO not something you should feel ashamed for. iperf3 (combined with a computer/sbc with known good settings) is a great tool to test this. But it's interesting that the settings work well on the legacy drivers but not on mainline.
piter75 Posted December 29, 2019 Posted December 29, 2019 On 12/29/2019 at 1:39 PM, martinayotte said: Isn't that available since more than a year, at least in DEV ? Expand It is available in DEV indeed. I thought about bringing it into current kernel where it is missing. On 12/29/2019 at 2:21 PM, chwe said: it happens and when it happens it's IMO not something you should feel ashamed for Expand I am not. Sometimes I am just amazed at how much there is still to discover / learn ;-)
martinayotte Posted December 29, 2019 Posted December 29, 2019 On 12/29/2019 at 2:43 PM, piter75 said: It is available in DEV indeed. I thought about bringing it into current kernel where it is missing. Expand Looking at kernel configs, it seems to be there ... Did you check the /sys/kernel/config/device-tree/overlays directory presence ?
Nobby42 Posted December 29, 2019 Author Posted December 29, 2019 @piter75 Thanks. Now the ethernet workes and I can test the legacy kernel. With the 5.4.6 kernel I have a lot of problems. Sometimes the Pi crashes. I cannot verify the reason. I boot the Pi from emmc and rootfs on a SSD. Looks like a problem with the USB SSD adapter but I am not shure. I use USB adapters with JM567 and ASM1153 chipset.
piter75 Posted December 29, 2019 Posted December 29, 2019 On 12/29/2019 at 2:57 PM, martinayotte said: Did you check the /sys/kernel/config/device-tree/overlays directory presence ? Expand It was not there on rockchip64-current. I prepared a PR that adds it: https://github.com/armbian/build/pull/1699 On 12/29/2019 at 6:38 PM, Nobby42 said: Sometimes the Pi crashes. I cannot verify the reason. I boot the Pi from emmc and rootfs on a SSD. Looks like a problem with the USB SSD adapter but I am not shure. Expand I am using similar setup but with NVMe hat and I would call it very stable. One thing to mention is that I am using it as a server and not a desktop.
martinayotte Posted December 29, 2019 Posted December 29, 2019 On 12/29/2019 at 8:04 PM, piter75 said: It was not there on rockchip64-current. I prepared a PR that adds it: https://github.com/armbian/build/pull/1699 Expand I've look about rockchip64-dev history from about 1 year ago, and apparently I've only added overlays, but not CONFIGFS like I did for meson64 around the same time. Simply that I've forgot. Since you did a PR, it would be good to have the same patch also in rockchip64-dev ...
piter75 Posted December 29, 2019 Posted December 29, 2019 On 12/29/2019 at 9:24 PM, martinayotte said: Since you did a PR, it would be good to have the same patch also in rockchip64-dev Expand The patch is not needed in rockchip64-dev as it is already incorporated in ayufan's kernel sources we use for dev target. That's why it's being added to current target only with my PR.
