Skip to content
View in the app
Armbian Community Forums
Opi One H6 -- 1.8 Ghz on 5.4.x+ ?
Featured Replies
Hi All!
Is it possible to enable 1.8 Ghz on kernels 5.4.x (stable one) and 5.5-rc2 ?
Thanks in advance!
I can easily crash one of my test boards when clocking it to 1.8, while it works stable if limited lower. Perhaps speed can be achieved, but not with current DVFS/thermal settings. Since instability is only rasing spam & more questions and since "you" don't care to help us moderating forum, such experiment is out of the question.
Perhaps we rather wait that 1.8Ghz become stable.
In general: in case you want some changes to the code, prepare a patch https://github.com/armbian/build It will be accepted or denied - in this case.
On 2/25/2020 at 7:50 AM, Werner said:
sunxi-current has been patched to run on higher clocks. Build an image from master to give it a shot.
Mine is shortly clocked down to 1Ghz due to functional thermal throttling. A heat sink is mandatory if you want to run it at 1.6 - 1.8
I still believe that there are manufacturing discrepancies with this board since I never experienced significant throttling with my board(s) without any cooling whatsoever.
Proper cooling is up to the end-user anyways.
I added a kind of solution for that here:https://github.com/armbian/build/pull/1811
The downside is this should be documented somewhere useful.
Mine seems fine.
root@orangepioneplus:~# armbianmonitor -m
Stop monitoring using [ctrl]-[c]
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
07:59:02:  720MHz  0.28   7%   3%   2%   0%   1%   0% 39.3°C  0/8
07:59:07:  480MHz  0.26   0%   0%   0%   0%   0%   0% 39.7°C  0/8
07:59:12:  480MHz  0.24   0%   0%   0%   0%   0%   0% 39.6°C  0/8
07:59:17: 1800MHz  0.30  21%  19%   1%   0%   0%   0% 47.8°C  0/8
07:59:23: 1800MHz  0.35  25%  23%   1%   0%   0%   0% 48.9°C  0/8
07:59:28: 1800MHz  0.41  25%  23%   1%   0%   0%   0% 50.5°C  0/8
07:59:33: 1800MHz  0.45  25%  23%   1%   0%   0%   0% 50.8°C  0/8
07:59:38: 1800MHz  0.50  25%  23%   0%   0%   0%   0% 51.9°C  0/8
07:59:43: 1800MHz  0.54  25%  23%   0%   1%   0%   0% 52.8°C  0/8
07:59:48: 1800MHz  0.66  49%  46%   0%   2%   0%   0% 56.6°C  0/8
07:59:53: 1800MHz  0.92  60%  59%   0%   1%   0%   0% 59.3°C  0/8
07:59:58: 1800MHz  1.17 100%  97%   0%   2%   0%   0% 61.2°C  0/8
08:00:04: 1800MHz  1.40 100%  97%   0%   2%   0%   0% 61.6°C  0/8
08:00:09: 1800MHz  1.61 100%  97%   0%   2%   0%   0% 63.2°C  0/8
08:00:15: 1800MHz  1.80 100%  98%   0%   1%   0%   0% 64.2°C  0/8
08:00:20: 1800MHz  1.97 100%  97%   0%   2%   0%   0% 64.8°C  0/8
08:00:26: 1800MHz  2.14 100%  97%   0%   2%   0%   0% 66.2°C  0/8
08:00:31: 1800MHz  2.29 100%  97%   0%   2%   0%   0% 66.7°C  0/8
08:00:37: 1800MHz  2.42 100%  97%   0%   2%   0%   0% 66.7°C  0/8
08:00:42: 1800MHz  2.55 100%  97%   0%   2%   0%   0% 67.7°C  0/8
08:00:47: 1800MHz  2.85 100%  97%   0%   2%   0%   0% 68.5°C  0/8
08:00:53: 1800MHz  2.94 100%  98%   0%   1%   0%   0% 68.7°C  0/8
08:00:58: 1800MHz  3.02 100%  97%   0%   2%   0%   0% 68.5°C  0/8
08:01:04: 1800MHz  3.10 100%  97%   0%   2%   0%   0% 69.1°C  0/8
08:01:09: 1800MHz  3.18 100%  97%   0%   2%   0%   0% 70.6°C  0/8
08:01:15: 1800MHz  3.24 100%  97%   0%   2%   0%   0% 71.2°C  0/8
08:01:20: 1800MHz  3.30 100%  97%   0%   2%   0%   0% 70.4°C  0/8
08:01:26: 1800MHz  3.36 100%  97%   0%   2%   0%   0% 72.0°C  0/8
08:01:31: 1800MHz  3.41 100%  97%   0%   2%   0%   0% 72.2°C  0/8
08:01:37: 1800MHz  3.46 100%  97%   0%   2%   0%   0% 72.2°C  0/8
08:01:42: 1800MHz  3.50 100%  97%   0%   2%   0%   0% 73.0°C  0/8^C
root@orangepioneplus:~# uname -a
Linux orangepioneplus 5.4.23-sunxi64 #trunk SMP Sat Feb 29 10:55:58 CET 2020 aarch64 GNU/Linux
The load was created by four threads of dd if=/dev/urandom of=/dev/zero &
Tried the same with armbianmonitor -z. The frequenzcy broke down
p7zip Version 16.02 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,64 bits,4 CPUs LE)
LE
CPU Freq:  1796  1796  1797  1797  1795  1797  1797  1798  1798
RAM size:     989 MB,  # CPU hardware threads:   4
RAM usage:    882 MB,  # Benchmark threads:      4
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:       2400   333    702   2335  |      63841   396   1374   5447
23:       2295   338    692   2339  |      61105   392   1347   5287
24:       2277   350    700   2449  |      59712   392   1338   5242
Meanwhile:
08:03:39: 1800MHz  3.96  65%  58%   5%   1%   0%   0% 73.8°C  0/8
08:03:46: 1800MHz  3.96  95%   1%  94%   0%   0%   0% 89.3°C  0/8
08:03:51: 1800MHz  4.13  80%   2%  77%   0%   0%   0% 73.8°C  0/8
08:03:56: 1800MHz  4.12  88%   1%  87%   0%   0%   0% 74.3°C  0/8
08:04:03: 1080MHz  4.11  93%   1%  91%   0%   0%   0% 88.5°C  0/8
08:04:08: 1800MHz  4.08  80%   1%  79%   0%   0%   0% 74.6°C  0/8
08:04:14: 1800MHz  4.16  82%   1%  80%   0%   0%   0% 84.1°C  4/8
08:04:19: 1080MHz  4.14  88%   2%  85%   0%   0%   0% 84.5°C  4/8
08:04:25: 1800MHz  4.29  93%   3%  90%   0%   0%   0% 84.7°C  4/8
I guess it depends on which kind of load you apply to the chip. On the whole it seems to do fine.
I put a heatsink as listed here at Pine, left OrangePiOnePlus running for three days now ( idle ) with Kernel 5.6.2 and its temperature was 50-51.
However I just put it now in a more open space and that saves immediately 10 degrees.
I added screenshot in which the OpiOnePlus is receiving data , " iperf3 -s " (  10 parr. threads )  and  once sending data ( also 10 parr. threads ).
Now things start to move towards 70 degrees once " armbianmonitor -z " is being executed
As as side note it seems the H5 chip runs in idle mode at least 5 degrees lower as both boards are in same location
On overall it might be interesting using this board as a VPN/ piHole server
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
