HI, sorry if I bother the community so much.
Is there a way (I'm sure that is) to setup armbian without DE and without eth connection?
I've noticed that I need wired connection to launch armbian-config. Can I do the same with a wifi USB stick? How?
If I want to use armbian as wireless AP, do I need to install the DE? Can you guide me?
Thank you in advance
3 minutes ago, Werner said:
DE?
Desktop Environment.
Yes. You need a serial connection and temporal network connection to setup AP armbian-config way.
or build a custom image with support for
Can you link me a guide or explain me some steps?
I achieve to connect to a wifi hotspot with armbian-config but i need to configure it as AP for an router that as PEAP WPA2 security. For what I've tested this security is not supported out of the box for Linux...
Thank you in advance for your patience
I have another issue.
I can setup WiFi using nmtui. But it requires connect using ethernet or TTL. If I just set wpa_supplicant.conf, WiFi not works. Do we have any tutorial for Armbian how to setup wifi by editing config on sd card?
Most of the work on Armbian's side is to provide a working kernel where Debian or Ubuntu is set up on top. The OS itself contains minimal adjustments only. Therefore tutorials outthere that are ment to be used on your causal PC should work for Armbian as well.
** Network Manager CLI **
use NMCLI
$ nmcli device status
DEVICE  TYPE      STATE         CONNECTION
enp1s0  ethernet  connected     Wired connection 1
wlp2s0  wifi      disconnected  --
lo      loopback  unmanaged     --
to check radio
$ nmcli radio
WIFI-HW  WIFI     WWAN-HW  WWAN
enabled  enabled  enabled  enabled
Let's see what's out there... scan for AP's
$ nmcli dev wifi list
SSID                  MODE   CHAN  RATE       SIGNAL  BARS  SECURITY
MYSSID         Infra  11    54 Mbit/s  100     ▂▄▆█  WPA2
MYSSID         Infra  132   54 Mbit/s  100     ▂▄▆█  WPA2
SOMEOTHERSSID  Infra  52    54 Mbit/s  49      ▂▄__  WPA2
MYSSID         Infra  149   54 Mbit/s  45      ▂▄__  WPA2
MYSSID         Infra  11    54 Mbit/s  42      ▂▄__  WPA2
SOMEOTHERSSID  Infra  1     54 Mbit/s  27      ▂___  WPA2
Now, let's connect to WiFi (note, one must be root or sudo access)
Connecting to an open AP
$ nmcli device wifi connect <SSID|BSSID>
For a password protected AP, see below
$ nmcli device wifi connect <SSID|BSSID> password <password>
Cool, eh?
To set up a device as an AP - this assumes that WLAN0 is the wireless interface...
$ nmcli dev wifi hotspot ifname wlan0 <SSID> password "<password>"
Cool, eh?
Thank you for the tips. However when I enter the above I get the error Unknown parameter <SSID>. I passed <SSID> as ARMBIAN_WiFi. Any ideas on why this is the case?
Edited by TRS-80
move reply out of quote
