With our Current moving to 5.7, anyone building it themselves should report anything missing/new/different/wanted here.
  Le Potato La Frite NanoPi K2 ODROID C2 VIM 1
USB OK OK OK OK OK
REBOOT NOK OK OK NOK NOK
SOUND OK OK OK OK OK
HDMI OK OK OK OK OK
Onboard WiFi NA NA OK NA OK
Thanks @ning, I just wanted to pin a thread so we could get the conversation going, I'll take a look at Khadas and the upstream, hopefully avoiding the patchtastrophy that resulted from multiple patch sources last time.
  On 6/28/2020 at 2:33 AM, ning said:
you can copy patches from:
Expand
If you give links, use the original sources, and not dubious places where the full set and part of the damaged patches are not complete.
I tried reverting a patch in 5.7 that chewitt blamed for some problems but it didn't restore sound.  @balbes150 our current Amlogic patch situation is, well, interesting.  I need to go through one by one and figure out what each one is for.  I neglected my duties for too long.
Expand
use alsamix, F6 select audio card, enable some switch. then you can have sound out.
Expand
Expand
The @ning solution worked for me (kernel 5.6.15). The exact fields to change are: AIU_HDMI to I2S and AIU_SPDI to SPDIF. I don't know the exact meaning of that settings, but worked for me.
on 5.6 yes, I patched 5.6  ;-)  However my quick test on 5.7 this was not the case.  I will check again of course
[Edit] Found the issue, all of the board dts patches got wiped with the bump to 5.7 somehow.  putting them back.  :)
[edit2] Can anyone run iozone on their meson64 boards and tell me the outcome?  I'm working on sound, but my SD performance seems really bad.
Expand
Sure, I can. I have an odroid C2 and C4.
Please let me know the parameters to use when running iozone.
Expand
let's go with
iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
We used to do this to benchmark SD cards, however I think we should probably do it to benchmark Kernel/SBC/etc.  It will only tell us if something is very wrong or significantly improved, small differences are meaningless because too many variables
This is the odroid-c2 on a emmc card 5.6.15-meson64 kernel:
    Output is in kBytes/sec
    Time Resolution = 0.000001 seconds.
    Processor cache size set to 1024 kBytes.
    Processor cache line size set to 32 bytes.
    File stride size set to 17 * record size.
                                                              random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
          102400       4    20862    23923    36707    37745    16132    23547
          102400      16    49258    50791    86457    86847    46566    47480
          102400     512    61312    60990   141035   144966   143599    53339
          102400    1024    66198    55525   143661   145428   145463    53871
          102400   16384    63540    55740   155268   155155   155885    67918
This is on an odroid-c4 on an emmc card 5.7.9-meson64 kernel:
          102400       4    34196    29580    29412    29404    29253    37403
          102400      16    77697    61790    75844    73546    73434    68884
          102400     512    62322    55775   155527   155390   155128    56261
          102400    1024    55730    46808   159324   158184   158408    61598
          102400   16384    60143    66612   165367   165369   165589    56678
Let me know if you want other tests.
[Edited to improve readability.  Using the '<>' gives mono-space "code" text formatting. -Tonymac32]
Could someone tell me if sound works on hdmi output with Odroid C2 with armbian kernel 5.7.15 ?
I've got no sound, just 'dummy' settings and nothing on jack or hdmi out... Maybe i did something wrong while installing...
Thanks
Regards
  • Igor unpinned this topic
