TonyMac32 Posted June 28, 2020 Share Posted June 28, 2020 With our Current moving to 5.7, anyone building it themselves should report anything missing/new/different/wanted here. Le Potato La Frite NanoPi K2 ODROID C2 VIM 1 USB OK OK OK OK OK REBOOT NOK OK OK NOK NOK SOUND OK OK OK OK OK HDMI OK OK OK OK OK Onboard WiFi NA NA OK NA OK Link to comment Share on other sites More sharing options...
ning Posted June 28, 2020 Share Posted June 28, 2020 you can copy patches from: https://github.com/khadas/fenix/tree/master/packages/linux-mainline/patches/5.7 2 Link to comment Share on other sites More sharing options...
TonyMac32 Posted June 28, 2020 Author Share Posted June 28, 2020 Thanks @ning, I just wanted to pin a thread so we could get the conversation going, I'll take a look at Khadas and the upstream, hopefully avoiding the patchtastrophy that resulted from multiple patch sources last time. Link to comment Share on other sites More sharing options...
Igor Posted June 28, 2020 Share Posted June 28, 2020 Also useful source: https://github.com/tobetter/linux/commits/odroid-5.7.y Link to comment Share on other sites More sharing options...
balbes150 Posted June 29, 2020 Share Posted June 29, 2020 On 6/28/2020 at 5:33 AM, ning said: you can copy patches from: If you give links, use the original sources, and not dubious places where the full set and part of the damaged patches are not complete. Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 3, 2020 Author Share Posted July 3, 2020 I tried reverting a patch in 5.7 that chewitt blamed for some problems but it didn't restore sound. @balbes150 our current Amlogic patch situation is, well, interesting. I need to go through one by one and figure out what each one is for. I neglected my duties for too long. Link to comment Share on other sites More sharing options...
ning Posted July 3, 2020 Share Posted July 3, 2020 1 hour ago, TonyMac32 said: chewitt blamed for some problems but it didn't restore sound use alsamix, F6 select audio card, enable some switch. then you can have sound out. Link to comment Share on other sites More sharing options...
balbes150 Posted July 3, 2020 Share Posted July 3, 2020 1 hour ago, TonyMac32 said: some problems but it didn't restore sound. What does (aplay -l) show ? What name is assigned to the registered sound card in DTB ? Link to comment Share on other sites More sharing options...
UniformBuffer Posted July 3, 2020 Share Posted July 3, 2020 11 hours ago, ning said: use alsamix, F6 select audio card, enable some switch. then you can have sound out. 12 hours ago, TonyMac32 said: I tried reverting a patch in 5.7 that chewitt blamed for some problems but it didn't restore sound. The @ning solution worked for me (kernel 5.6.15). The exact fields to change are: AIU_HDMI to I2S and AIU_SPDI to SPDIF. I don't know the exact meaning of that settings, but worked for me. Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 3, 2020 Author Share Posted July 3, 2020 on 5.6 yes, I patched 5.6 ;-) However my quick test on 5.7 this was not the case. I will check again of course [Edit] Found the issue, all of the board dts patches got wiped with the bump to 5.7 somehow. putting them back. [edit2] Can anyone run iozone on their meson64 boards and tell me the outcome? I'm working on sound, but my SD performance seems really bad. Link to comment Share on other sites More sharing options...
jrober19 Posted July 18, 2020 Share Posted July 18, 2020 On 7/3/2020 at 4:45 PM, TonyMac32 said: Can anyone run iozone on their meson64 boards and tell me the outcome? I'm working on sound, but my SD performance seems really bad. Sure, I can. I have an odroid C2 and C4. Please let me know the parameters to use when running iozone. Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 19, 2020 Author Share Posted July 19, 2020 3 hours ago, jrober19 said: Sure, I can. I have an odroid C2 and C4. Please let me know the parameters to use when running iozone. let's go with iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 We used to do this to benchmark SD cards, however I think we should probably do it to benchmark Kernel/SBC/etc. It will only tell us if something is very wrong or significantly improved, small differences are meaningless because too many variables Link to comment Share on other sites More sharing options...
jrober19 Posted July 20, 2020 Share Posted July 20, 2020 This is the odroid-c2 on a emmc card 5.6.15-meson64 kernel: Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 20862 23923 36707 37745 16132 23547 102400 16 49258 50791 86457 86847 46566 47480 102400 512 61312 60990 141035 144966 143599 53339 102400 1024 66198 55525 143661 145428 145463 53871 102400 16384 63540 55740 155268 155155 155885 67918 This is on an odroid-c4 on an emmc card 5.7.9-meson64 kernel: Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 34196 29580 29412 29404 29253 37403 102400 16 77697 61790 75844 73546 73434 68884 102400 512 62322 55775 155527 155390 155128 56261 102400 1024 55730 46808 159324 158184 158408 61598 102400 16384 60143 66612 165367 165369 165589 56678 Let me know if you want other tests. [Edited to improve readability. Using the '<>' gives mono-space "code" text formatting. -Tonymac32] Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 20, 2020 Author Share Posted July 20, 2020 Thank you @jrober19, that's what I would expect from an eMMC in this case. Link to comment Share on other sites More sharing options...
ning Posted July 20, 2020 Share Posted July 20, 2020 about amlogic audio in kernel 5.7, there is an issue: http://lists.infradead.org/pipermail/linux-amlogic/2020-July/007558.html revert related patch or wait 5.8 Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 27, 2020 Author Share Posted July 27, 2020 @ning Yeah, I was keeping up with the mailing list, reverted it here: https://github.com/armbian/build/commit/9372fcdedfb6af9709ba1a046e983523997aeada Now it all works, we had a Vim1 issue because it wasn't using the modified card name so PA wasn't immediately enabling it (I chose to use "gx-sound-card") I have not touched vim2 and up, I don't have test boards. Link to comment Share on other sites More sharing options...
4RK4DI3N Posted August 29, 2020 Share Posted August 29, 2020 Hello, Could someone tell me if sound works on hdmi output with Odroid C2 with armbian kernel 5.7.15 ? I've got no sound, just 'dummy' settings and nothing on jack or hdmi out... Maybe i did something wrong while installing... Thanks Regards Link to comment Share on other sites More sharing options...
4RK4DI3N Posted August 29, 2020 Share Posted August 29, 2020 Maybe its not the right place to put my message.... Link to comment Share on other sites More sharing options...
