In the past I did also install vsftpd, but some time ago I did see that the package oppenssh not only has openssh-client / openssh-server...
As third part there is the openssh-sftp-server which armbian does install.
So I never installed vsftpd additionally again ;)
The 3 packets in armbian (on my installation) are:
openssh-client		1:8.2p1-4ubuntu0.1	arm64
secure shell (SSH) client, for secure access to remote machines
openssh-server		1:8.2p1-4ubuntu0.1	arm64
secure shell (SSH) server, for secure access from remote machines
openssh-sftp-server	1:8.2p1-4ubuntu0.1	arm64
secure shell (SSH) sftp server module, for SFTP access from remote machines
An idea for the configuration of openssh-sftp-server could be found at
https://www.allthingsdigital.nl/2013/05/12/setting-up-an-sftp-only-account-with-openssh/
Moved to P2P since this is not an actual issue with the tvbox but a userspace project.
Btw. Depending on your Armbian flavor (Buster, Focal, Bullseye...) any FTPd tutorial you can find with Google & Co. should work.
