Forget it. I was able to get the ports.ubuntu.com repositories saved and working on the Orange Pi Ubuntu distro shared above by Yoshi.
Hi all
I was tested the last image orangepi xfce 5.16 kernel released few dais back in orangepi web.
But I was therified... The usage of its is 0, worst experience even whit compare to old rpi zero with desktop test.
There I think is broken wifi can't conect to 2.4ghz 40mhz wide (20mhz is OK).
And my question is, is there any usable kernel right now that has working h265 hw decode?
Because in the last opi image it was impossible to play it even on sw. I have tride default player in opi image and vlc.
I have plans for this board I want swap for rpi4 in multimedia home center, because lower powerconsumotion.. But still not usable...  I thin more months to wait now... :-(
  On 5/19/2022 at 12:22 AM, DvoraNoob said:
Why my armbian don't have a Hardware option on system?
Expand
You mean adjusting HW features? Because there are no overlays and nobody developed them. No, we have not plans nor budget for that.
  On 5/14/2022 at 8:33 PM, CyberDeath said:
I thin more months to wait now... 😞
Expand
We are also waiting and waiting that you realise that you need to support R&D in order to have some small rights to complain ;)
This graph below shows how many days is needed before reported issues is resolved. Terrible, right? https://docs.armbian.com/User-Guide_FAQ/#development-time Remember that if you don't contribute on the project, you can't add bugs / tasks to the system at all. With another words - we have no resources not even for write bugs into the system and if we would listen to your problems, situation for the project that helps you, but you don't help it, would only be much worse.
If all people that complain and report bugs to themselves would have Angel https://forum.armbian.com/subscriptions/ we would be able to perhaps hire full time person for you that would record bugs and solve them one by one. Since this is not the case and you expect the impossible, graph can only get steeper.
  On 4/23/2022 at 10:43 PM, mrjack said:
please help me... i learned to install ipset but the result is always the same...
How to fix...please..
Expand
you should change kernel config (iptables and depends )to y
  On 11/28/2020 at 10:08 AM, Werner said:
在抱怨问题之前,请阅读此内容!
tl;dr:将您的 Zero2 和/或任何其他基于 H616 的设备放在架子上,等待适当的支持。和不。没有预计到达时间。假设可用状态为 2021 年底/2022 年初。
软件支持仍在进行中并正在大力开发中。提供的预览图像可以随时中断。请勿举报,我们知道这一点,如果您不愿意自行调查和研究,我们可以/不会帮助您。
随时与其他开发人员一起努力创建适当的软件支持。但是不要浪费我们的时间抱怨。谢谢!
https://github.com/apritzel/linux/commits/h616-v5
https://github.com/jernejsk/u-boot/tree/h616-v2
https://github.com/apritzel/arm-trusted-firmware/tree/h616-v2-wip _
我开始玩这个板,显然失败了,创建一个基本的 Armbian 集成。
反正。这些是我到目前为止收集的信息:
旭龙图片dtb提取: https ://pastebin.com/raw/Uni2JzBF
橙皮监视器🙄   http://ix.io/2FM0
内核配置:https ://pastebin.com/raw/e2jTTZ7A
Expand
h616-v11 can be built success and uboot is a challange to match kernel image format from uImage to Image
Expand
Yes, I think is needed activate SPI HW features to add a ADXL345.
Expand
Sorry for misunderstanding.
I did not complain. I just state the fact and houpet that somebody will tell me otherwise.  It lays in my desk for few months so... It will lays more, no trouble... I did play meanwhile with other boards and other projects.
If I take the board in cli most of the stuff works OK. It's pitti that the developer/manufacturer of the board dit not provide at least some working kernel (even old) ...
But I did not get answer to the h265 so I thing it's not that easy to get it working... If even on orange pi kernel it's not working.
Expand
They are providing old working kernel even you only paid hardware at BOM price. Not saying everything works, but for the price you pay (nothing) ... its something to boot. If you want luxury you mention before, you need to actively contribute.
Expand
What is wrong with not getting an answer?
Hm.. Why you pick only part of my sentens and getting it out of contex?
I amsvered the question in second part of that sentences.
  On 8/24/2021 at 5:37 PM, iHackFX said:
Hi, I recently received this board and I was able to get the docker started. Maybe someone may find it useful.
After installing via "armbian-confix" if try to start docker service with
$ systemctl start docker
 we get this error:
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Tue 2021-08-24 20:09:34 MSK; 26ms ago
     Docs: https://docs.docker.com
  Process: 11947 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
 Main PID: 11947 (code=exited, status=1/FAILURE)
dpkg: error handling package docker-ce (--configure):
 installed docker-ce package post-installation script subprocess returned error exit status 1
In "journalctl -xe" we get the following - "Running iptables --wait -t nat -L -n failed with message: `# Warning: iptables-legacy tables present, use iptables-legacy to see them\niptables: Operation not supported.`, error: exit status 1."
And to fix it, you need to use the following command:
$ update-alternatives --set iptables /usr/sbin/iptables-legacy
Then restart the service and docker works.
Expand
Thank you very much for sharing this!
Hello there.
I acquired this card recently, and when researching a bit more, to my surprise, I just came across the info that the h616 linux support isn't mainlined (this explain why it was so cheap).
I would like to know how close h616 is to get mainline support, what is still missing? there were some reports that device tree was missing, but some reports stating that it was added in 5.16 or something.
Expand
Kernel 5.19 (rc1 will be released in about one week) will have all drivers, but no DT. So 5.20 will presumably have initial support, with DT included. Probably USB too. However, patches exists for most features.
Expand
That is certainly not the reason. All hardware is released with some old private / BSP / Android / presentation kernel. It always takes years to get to the mainline. Some HW never came there and never all functions gets there. This is just how this world function and Armbian is also mitigating this problem to the best possible degree. Otherwise you would be destined to much lower quality / usability and have it much later.
Welcome!
Expand
This welcome news indeed, although its all discovery for me, personally I've been trying to get cpu frequency working 5.17.11-sunxi64. CONFIG_ARM_ALLWINNER_SUN50I_CPUFREQ_NVMEM=m and dependencies can be configured and built, however the device tree has no opp table etc
 opp_l_table {
                compatible = "allwinner,sun50i-operating-points";
                nvmem-cells = <0xd7>;
                nvmem-cell-names = "speed";
                opp-shared;
                linux,phandle = <0xd4>;
                phandle = <0xd4>;
I have so-far seen the differences in 4.9.255 cpufreq-dt.c and 5.17.5, but still have much to learn, and possibly way beyond my current comprehension state to begin solving....
At this point I have h616-cpu-opp table parameters with which I can patch a new build, any advise from seasoned armbians welcome, there are sure to be gotchas.
failure points cpufreq-dt.ko
cpufreq_dt:
    failed to find data for cpu%d
    failed to get clk: %d
    no regulator for cpu%d
    failed to set regulators: %d
    OPP table can't be empty
    failed to mark OPPs as shared: %d
    failed to init cpufreq table: %d
    failed register driver: %d
Having a crack at this but not much success!
alistair@orangepizero2:/boot/dtb-5.17.11-sunxi64/allwinner$ dtdiff sun50i-h616-orangepi-zero2.dts \ sun50i-h616-orangepi-zero2.dtb | grep "^+" | wc -l
Unrecognized format for  sun50i-h616-orangepi-zero2.dtb
Error: sun50i-h616-cpu-opp.dtsi:95.1-6 Label or path cpu0 not found
Error: sun50i-h616-cpu-opp.dtsi:99.1-6 Label or path cpu1 not found
Error: sun50i-h616-cpu-opp.dtsi:103.1-6 Label or path cpu2 not found
Error: sun50i-h616-cpu-opp.dtsi:107.1-6 Label or path cpu3 not found
FATAL ERROR: Syntax error parsing input tree
0
i did manage to get opp-tables compiled, with correct H616 bin's, but there are still other issues to work through, so no joy yet!
Help with Bullseye, My Orange Pi was working normally, but Now I can't boot more neither if I flashing the Armbian again.
Serial LOG:
  Reveal hidden contents
Posted (edited)
Expand
one my zero2 was received with the same trouble. it's looks like RAM fault. item from ali was refunded by seller without dispute after video evidence
Edited by nightguest
Expand
I already used Armbian on this device, I think it was the update, now I'm testing the Orange Pi official firmware
  On 1/29/2021 at 6:08 PM, Werner said:
If you really wanna do serious stuff with it do what I did: Put it on the shelf and let it sit there for about a year from now. Then come back to it.
Expand
Ok, i've done it. Put it on the shelf behind my desk and waited for much than a year. ))
And now I can only see nice words in the center of screen "armbian initializing boot loader" for more than an hour. (Reboot didn't help, alas).
May be I should read something to understand what to do next? Really don't want to wait one year more.
Expand
Nobody wants to wait but also very few of those are a willing to do something to decrease waiting time. One year was a rough estimation. Mainline development of arm platform is very slow in comparison to x86.
For example it took several years to bring RK3399 SoC to a well matured state and still not all functions are well supported yet. Now think about how long it might take for a mid-grade SoC like H616;)
  Quote
Expand
Well yeah its a long swim, dive in though, mainline has enough already working, from 5.20 seriously wishing that more is there to make it easier!
Expand
So what really can I do for help besides donating? Can it be that it's the right time to read Chris Simmonds's book that waited for this moment for two years exactly next to inoperative zero2.
Good start if you have the time and use case.
  Quote
Expand
You will have to think outside the 'book' its examples are different soc.
Whats your use case? Is it fun or fairly serious project.
If it a project that you have time to put into, then effort might be justifiable, should you make some progress contribute back to the community. Otherwise keep hoping that someone else will make the effort and part with that back to community.
Best of luck.
Best of luck.
Expand
Nobody has enough time to do everything the do but as for me I want to enroll in embedded linux programming. I always had a lot of interest but never tried seriously. I wanted begin with small private project of automated garage surveillance and security system with all features like logging to remote server, mobile app and web application. And I've done almost all environment: backend, frontend, draft of mobile app, but stopped on hardware stage. So I don't see any obstacles to finish the project except inoperative device. By the way, I've done something with RPi, but it looks like cheating. I used pigpio lib to make sensors and actuators work, but still haven't managed to understand underlying mechanisms of OS.
