I've been trying to get OMV setup on the Helios prior to adding my hard drives and I keep getting errors and communication failures when I try to do pretty much anything. I like OMV for it's GUI, but honestly, I've never been a fan of it functionally. Is there anything comparable to it that works with the Helios64? Anyone have any suggestions how to fix it?
I have logs but I don't see a place to attach them.
I've been running OMV on my Helios64 ever since it's been delivered, without issue (even on the older, buggy kernels).
Could you share your logs (in a spoiler then code block works fine) or on a Pastebin-like service?
@BacchusIX Yes please provide some log or screenshot.
Also which Ethernet port are you using on Helios64 ? I'm asking because in early version, the OMV install script was removing the TX offload setting on 2.5GbE instead of keeping it.
why can I only post once a day??
using the 1 GbE port. I was able to connect via SSH and the OMV GUI no problem. I tried uninstalling and reinstalling, but it pretty much rendered the entire OS unusable. I did a complete rebuild this morning and still getting a communication failure while trying to enable the extras repo.
Nov 30 00:00:06 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="1236" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
Nov 30 00:00:06 localhost systemd[1]: logrotate.service: Succeeded.
Nov 30 00:00:06 localhost systemd[1]: Started Rotate log files.
Nov 30 00:00:06 localhost systemd[1]: man-db.service: Succeeded.
Nov 30 00:00:06 localhost systemd[1]: Started Daily man-db regeneration.
Nov 30 00:00:12 localhost fstrim[23809]: /: 11.8 GiB (12664385536 bytes) trimmed on /dev/mmcblk1p1
Nov 30 00:00:12 localhost systemd[1]: fstrim.service: Succeeded.
Nov 30 00:00:12 localhost systemd[1]: Started Discard unused blocks on filesystems from /etc/fstab.
Nov 30 00:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 3880064
Nov 30 00:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 3837920
Nov 30 00:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 3837920
Nov 30 00:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 194
Nov 30 00:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 00:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 00:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 00:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 00:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 00:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 00:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=198.789; max=635.783)Mibits/s
Nov 30 00:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=7.996; max=29.031)Mibits/s
Nov 30 00:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 00:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 00:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 00:05:01 localhost CRON[23984]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 00:09:01 localhost CRON[24069]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 00:09:05 localhost systemd[1]: Starting Clean php session files...
Nov 30 00:09:06 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 00:09:06 localhost systemd[1]: Started Clean php session files.
Nov 30 00:15:01 localhost CRON[24253]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 00:15:01 localhost CRON[24256]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 00:15:01 localhost CRON[24255]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 00:17:01 localhost CRON[24452]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 00:25:01 localhost CRON[24621]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 00:30:01 localhost CRON[24726]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 00:30:01 localhost CRON[24728]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 00:33:06 localhost systemd[1]: Starting Daily apt download activities...
Nov 30 00:33:36 localhost systemd-networkd-wait-online[24953]: Event loop failed: Connection timed out
Nov 30 00:33:36 localhost apt-helper[24951]: E: Sub-process /lib/systemd/systemd-networkd-wait-online returned an error code (1)
Nov 30 00:33:36 localhost systemd[1]: apt-daily.service: Succeeded.
Nov 30 00:33:36 localhost systemd[1]: Started Daily apt download activities.
Nov 30 00:35:01 localhost CRON[25002]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 00:39:01 localhost CRON[25086]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 00:39:06 localhost systemd[1]: Starting Clean php session files...
Nov 30 00:39:06 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 00:39:06 localhost systemd[1]: Started Clean php session files.
Nov 30 00:45:01 localhost CRON[25270]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 00:45:01 localhost CRON[25268]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 00:45:01 localhost CRON[25271]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 00:55:01 localhost CRON[25632]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 01:00:01 localhost CRON[25737]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 01:00:01 localhost CRON[25739]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 01:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 3920064
Nov 30 01:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 3867680
Nov 30 01:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 3867680
Nov 30 01:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 196
Nov 30 01:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 01:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 01:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 01:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 01:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 01:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 01:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=199.158; max=635.783)Mibits/s
Nov 30 01:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=8.010; max=29.031)Mibits/s
Nov 30 01:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 01:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 01:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 01:05:01 localhost CRON[25996]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 01:09:01 localhost CRON[26081]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 01:09:06 localhost systemd[1]: Starting Clean php session files...
Nov 30 01:09:06 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 01:09:06 localhost systemd[1]: Started Clean php session files.
Nov 30 01:15:01 localhost CRON[26266]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 01:15:01 localhost CRON[26268]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 01:15:01 localhost CRON[26269]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 01:17:01 localhost CRON[26464]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 01:25:01 localhost CRON[26632]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 01:30:01 localhost CRON[26738]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 01:30:01 localhost CRON[26739]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 01:35:02 localhost CRON[26996]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 01:39:01 localhost CRON[27080]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 01:39:06 localhost systemd[1]: Starting Clean php session files...
Nov 30 01:39:06 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 01:39:06 localhost systemd[1]: Started Clean php session files.
Nov 30 01:45:01 localhost CRON[27262]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 01:45:01 localhost CRON[27265]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 01:45:01 localhost CRON[27263]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 01:55:01 localhost CRON[27623]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 02:00:01 localhost CRON[27729]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 02:00:01 localhost CRON[27730]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 02:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 3940064
Nov 30 02:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 3897920
Nov 30 02:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 3897920
Nov 30 02:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 197
Nov 30 02:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 02:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 02:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 02:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 02:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 02:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 02:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=199.040; max=635.783)Mibits/s
Nov 30 02:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=8.004; max=29.031)Mibits/s
Nov 30 02:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 02:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 02:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 02:05:01 localhost CRON[27988]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 02:09:01 localhost CRON[28071]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 02:09:06 localhost systemd[1]: Starting Clean php session files...
Nov 30 02:09:07 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 02:09:07 localhost systemd[1]: Started Clean php session files.
Nov 30 02:15:01 localhost CRON[28258]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 02:15:01 localhost CRON[28256]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 02:15:01 localhost CRON[28259]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 02:17:01 localhost CRON[28454]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 02:25:01 localhost CRON[28622]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 02:30:01 localhost CRON[28730]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 02:30:01 localhost CRON[28729]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 02:35:01 localhost CRON[28987]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 02:39:01 localhost CRON[29070]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 02:39:06 localhost systemd[1]: Starting Clean php session files...
Nov 30 02:39:07 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 02:39:07 localhost systemd[1]: Started Clean php session files.
Nov 30 02:45:01 localhost CRON[29253]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 02:45:01 localhost CRON[29254]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 02:45:01 localhost CRON[29255]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 02:55:01 localhost CRON[29618]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 03:00:01 localhost CRON[29723]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 03:00:01 localhost CRON[29722]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 03:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 3980064
Nov 30 03:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 3927680
Nov 30 03:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 3927680
Nov 30 03:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 199
Nov 30 03:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 03:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 03:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 03:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 03:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 03:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 03:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=198.817; max=635.783)Mibits/s
Nov 30 03:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=7.991; max=29.031)Mibits/s
Nov 30 03:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 03:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 03:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 03:05:01 localhost CRON[29981]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 03:09:01 localhost CRON[30064]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 03:09:07 localhost systemd[1]: Starting Clean php session files...
Nov 30 03:09:07 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 03:09:07 localhost systemd[1]: Started Clean php session files.
Nov 30 03:15:01 localhost CRON[30249]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 03:15:01 localhost CRON[30251]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 03:15:01 localhost CRON[30252]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 03:17:01 localhost CRON[30446]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 03:25:01 localhost CRON[30616]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 03:30:01 localhost CRON[30722]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 03:30:01 localhost CRON[30724]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 03:35:01 localhost CRON[30984]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 03:39:01 localhost CRON[31070]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 03:39:07 localhost systemd[1]: Starting Clean php session files...
Nov 30 03:39:07 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 03:39:07 localhost systemd[1]: Started Clean php session files.
Nov 30 03:45:01 localhost CRON[31256]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 03:45:01 localhost CRON[31258]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 03:45:01 localhost CRON[31257]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 03:55:01 localhost CRON[31618]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 04:00:01 localhost CRON[31726]: (root) CMD (test -x /usr/sbin/cron-apt && /usr/sbin/cron-apt)
Nov 30 04:00:01 localhost CRON[31725]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 04:00:01 localhost CRON[31727]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 04:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 4000064
Nov 30 04:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 3957920
Nov 30 04:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 3957920
Nov 30 04:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 200
Nov 30 04:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 04:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 04:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 04:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 04:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 04:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 04:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=198.713; max=635.783)Mibits/s
Nov 30 04:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=7.984; max=29.031)Mibits/s
Nov 30 04:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 04:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 04:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 04:05:01 localhost CRON[876]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 04:05:43 localhost cron-apt: CRON-APT RUN [/etc/cron-apt/config]: Mon Nov 30 04:00:01 CST 2020
Nov 30 04:05:43 localhost cron-apt: CRON-APT SLEEP: 258, Mon Nov 30 04:04:19 CST 2020
Nov 30 04:05:43 localhost cron-apt: CRON-APT ACTION: 0-update
Nov 30 04:05:43 localhost cron-apt: CRON-APT LINE: /usr/bin/apt-get  update -o quiet=2
Nov 30 04:09:01 localhost CRON[1038]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 04:09:07 localhost systemd[1]: Starting Clean php session files...
Nov 30 04:09:07 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 04:09:07 localhost systemd[1]: Started Clean php session files.
Nov 30 04:15:01 localhost CRON[1227]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 04:15:01 localhost CRON[1230]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 04:15:01 localhost CRON[1228]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 04:17:01 localhost CRON[1452]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 04:25:01 localhost CRON[1620]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 04:30:01 localhost CRON[1741]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 04:30:01 localhost CRON[1743]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 04:35:01 localhost CRON[2001]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 04:39:01 localhost CRON[2087]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 04:39:07 localhost systemd[1]: Starting Clean php session files...
Nov 30 04:39:08 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 04:39:08 localhost systemd[1]: Started Clean php session files.
Nov 30 04:45:01 localhost CRON[2274]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 04:45:01 localhost CRON[2275]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 04:45:01 localhost CRON[2276]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 04:55:01 localhost CRON[2632]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 05:00:01 localhost CRON[2737]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 05:00:01 localhost CRON[2738]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 05:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 4040064
Nov 30 05:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 3987168
Nov 30 05:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 3987168
Nov 30 05:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 202
Nov 30 05:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 05:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 05:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 05:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 05:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 05:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 05:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=198.529; max=635.783)Mibits/s
Nov 30 05:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=7.970; max=29.031)Mibits/s
Nov 30 05:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 05:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 05:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 05:05:01 localhost CRON[2996]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 05:09:01 localhost CRON[3083]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 05:09:07 localhost systemd[1]: Starting Clean php session files...
Nov 30 05:09:08 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 05:09:08 localhost systemd[1]: Started Clean php session files.
Nov 30 05:15:01 localhost CRON[3267]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 05:15:01 localhost CRON[3269]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 05:15:01 localhost CRON[3270]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 05:17:01 localhost CRON[3472]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 05:25:01 localhost CRON[3644]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 05:30:01 localhost CRON[3750]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 05:30:01 localhost CRON[3751]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 05:35:01 localhost CRON[4008]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 05:39:01 localhost CRON[4093]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 05:39:08 localhost systemd[1]: Starting Clean php session files...
Nov 30 05:39:08 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 05:39:08 localhost systemd[1]: Started Clean php session files.
Nov 30 05:45:01 localhost CRON[4277]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 05:45:01 localhost CRON[4278]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 05:45:01 localhost CRON[4279]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 05:55:01 localhost CRON[4635]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 06:00:01 localhost CRON[4739]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 06:00:01 localhost CRON[4740]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 06:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 4060064
Nov 30 06:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 4017408
Nov 30 06:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 4017408
Nov 30 06:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 203
Nov 30 06:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 06:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 06:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 06:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 06:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 06:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 06:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=198.407; max=635.783)Mibits/s
Nov 30 06:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=7.963; max=29.031)Mibits/s
Nov 30 06:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 06:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 06:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 06:05:01 localhost CRON[4997]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 06:09:01 localhost CRON[5080]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 06:09:08 localhost systemd[1]: Starting Clean php session files...
Nov 30 06:09:08 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 06:09:08 localhost systemd[1]: Started Clean php session files.
Nov 30 06:15:01 localhost CRON[5265]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 06:15:01 localhost CRON[5266]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 06:15:01 localhost CRON[5268]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 06:17:01 localhost CRON[5463]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 06:24:18 localhost systemd[1]: Starting Daily apt upgrade and clean activities...
Nov 30 06:24:48 localhost systemd-networkd-wait-online[5623]: Event loop failed: Connection timed out
Nov 30 06:24:48 localhost apt-helper[5621]: E: Sub-process /lib/systemd/systemd-networkd-wait-online returned an error code (1)
Nov 30 06:24:48 localhost systemd[1]: apt-daily-upgrade.service: Succeeded.
Nov 30 06:24:48 localhost systemd[1]: Started Daily apt upgrade and clean activities.
Nov 30 06:25:01 localhost CRON[5649]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 06:25:01 localhost CRON[5651]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
Nov 30 06:30:01 localhost CRON[5755]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 06:30:01 localhost CRON[5757]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 06:35:01 localhost CRON[6013]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 06:39:01 localhost CRON[6096]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 06:39:08 localhost systemd[1]: Starting Clean php session files...
Nov 30 06:39:08 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 06:39:08 localhost systemd[1]: Started Clean php session files.
Nov 30 06:45:01 localhost CRON[6281]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 06:45:01 localhost CRON[6284]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 06:45:01 localhost CRON[6282]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 06:55:01 localhost CRON[6641]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 07:00:01 localhost CRON[6746]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 07:00:01 localhost CRON[6747]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 07:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 4100064
Nov 30 07:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 4047168
Nov 30 07:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 4047168
Nov 30 07:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 205
Nov 30 07:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 07:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 07:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 07:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 07:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 07:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 07:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=198.209; max=635.783)Mibits/s
Nov 30 07:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=7.951; max=29.031)Mibits/s
Nov 30 07:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 07:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 07:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 07:05:01 localhost CRON[7003]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 07:09:01 localhost CRON[7089]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 07:09:08 localhost systemd[1]: Starting Clean php session files...
Nov 30 07:09:09 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 07:09:09 localhost systemd[1]: Started Clean php session files.
Nov 30 07:15:01 localhost CRON[7273]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 07:15:01 localhost CRON[7274]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 07:15:01 localhost CRON[7275]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 07:17:01 localhost CRON[7471]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 07:25:01 localhost CRON[7640]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 07:30:01 localhost CRON[7746]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 07:30:01 localhost CRON[7747]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 07:30:01 localhost CRON[7748]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
Nov 30 07:32:08 localhost systemd[1]: Started Run anacron jobs.
Nov 30 07:32:08 localhost anacron[7949]: Anacron 2.3 started on 2020-11-30
Nov 30 07:32:08 localhost anacron[7949]: Will run job `cron.daily' in 5 min.
Nov 30 07:32:08 localhost anacron[7949]: Jobs will be executed sequentially
Nov 30 07:35:01 localhost CRON[8006]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 07:37:08 localhost anacron[7949]: Job `cron.daily' started
Nov 30 07:37:08 localhost anacron[8059]: Updated timestamp for job `cron.daily' to 2020-11-30
Nov 30 07:37:09 localhost cracklib: no dictionary update necessary.
Nov 30 07:39:01 localhost CRON[8138]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 07:39:08 localhost systemd[1]: Starting Clean php session files...
Nov 30 07:39:09 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 07:39:09 localhost systemd[1]: Started Clean php session files.
Nov 30 07:45:01 localhost CRON[8321]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 07:45:01 localhost CRON[8322]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 07:45:01 localhost CRON[8323]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 07:55:01 localhost CRON[8686]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 08:00:01 localhost CRON[8788]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 08:00:01 localhost CRON[8789]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 08:04:08 localhost cron-apt: CRON-APT RUN [/etc/cron-apt/config]: Mon Nov 30 07:37:09 CST 2020
Nov 30 08:04:08 localhost cron-apt: CRON-APT SLEEP: 1597, Mon Nov 30 08:03:46 CST 2020
Nov 30 08:04:08 localhost cron-apt: CRON-APT ACTION: 0-update
Nov 30 08:04:08 localhost cron-apt: CRON-APT LINE: /usr/bin/apt-get  update -o quiet=2
Nov 30 08:04:08 localhost postfix/postsuper[10419]: Deleted: 1 message
Nov 30 08:04:08 localhost anacron[7949]: Job `cron.daily' terminated (mailing output)
Nov 30 08:04:08 localhost anacron[7949]: Normal exit (1 job run)
Nov 30 08:04:08 localhost systemd[1]: anacron.service: Succeeded.
Nov 30 08:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 4120064
Nov 30 08:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 4077408
Nov 30 08:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 4077408
Nov 30 08:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 206
Nov 30 08:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 08:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 08:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 08:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 08:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 08:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 08:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=198.091; max=635.783)Mibits/s
Nov 30 08:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=7.945; max=29.031)Mibits/s
Nov 30 08:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 08:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 08:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 08:05:01 localhost CRON[10453]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 08:09:01 localhost CRON[10538]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 08:09:09 localhost systemd[1]: Starting Clean php session files...
Nov 30 08:09:09 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 08:09:09 localhost systemd[1]: Started Clean php session files.
Nov 30 08:15:01 localhost CRON[10723]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 08:15:01 localhost CRON[10724]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 08:15:01 localhost CRON[10725]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 08:17:01 localhost CRON[10920]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 30 08:25:01 localhost CRON[11088]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 08:30:01 localhost CRON[11197]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 08:30:01 localhost CRON[11196]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 08:30:01 localhost CRON[11198]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
Nov 30 08:34:46 localhost systemd[1]: Started Run anacron jobs.
Nov 30 08:34:46 localhost anacron[11448]: Anacron 2.3 started on 2020-11-30
Nov 30 08:34:46 localhost anacron[11448]: Normal exit (0 jobs run)
Nov 30 08:34:46 localhost systemd[1]: anacron.service: Succeeded.
Nov 30 08:35:01 localhost CRON[11458]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 08:39:01 localhost CRON[11541]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 08:39:09 localhost systemd[1]: Starting Clean php session files...
Nov 30 08:39:09 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 08:39:09 localhost systemd[1]: Started Clean php session files.
Nov 30 08:45:01 localhost CRON[11727]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 08:45:01 localhost CRON[11725]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 08:45:01 localhost CRON[11726]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 08:55:01 localhost CRON[12087]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 09:00:01 localhost CRON[12188]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Nov 30 09:00:01 localhost CRON[12190]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 09:04:47 localhost rngd[1718]: stats: bits received from HRNG source: 4160064
Nov 30 09:04:47 localhost rngd[1718]: stats: bits sent to kernel pool: 4107168
Nov 30 09:04:47 localhost rngd[1718]: stats: entropy added to kernel pool: 4107168
Nov 30 09:04:47 localhost rngd[1718]: stats: FIPS 140-2 successes: 208
Nov 30 09:04:47 localhost rngd[1718]: stats: FIPS 140-2 failures: 0
Nov 30 09:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 30 09:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 30 09:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 30 09:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 30 09:04:47 localhost rngd[1718]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 30 09:04:47 localhost rngd[1718]: stats: HRNG source speed: (min=126.314; avg=198.454; max=635.783)Mibits/s
Nov 30 09:04:47 localhost rngd[1718]: stats: FIPS tests speed: (min=3.593; avg=7.979; max=29.031)Mibits/s
Nov 30 09:04:47 localhost rngd[1718]: stats: Lowest ready-buffers level: 2
Nov 30 09:04:47 localhost rngd[1718]: stats: Entropy starvations: 0
Nov 30 09:04:47 localhost rngd[1718]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 30 09:05:01 localhost CRON[12447]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 09:09:02 localhost CRON[12532]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Nov 30 09:09:09 localhost systemd[1]: Starting Clean php session files...
Nov 30 09:09:09 localhost systemd[1]: phpsessionclean.service: Succeeded.
Nov 30 09:09:09 localhost systemd[1]: Started Clean php session files.
Nov 30 09:15:01 localhost CRON[15072]: (root) CMD (/usr/sbin/omv-mkrrdgraph >/dev/null 2>&1)
Nov 30 09:15:01 localhost CRON[15073]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 30 09:15:01 localhost CRON[15074]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
ec  1 15:46:15 localhost systemd-modules-load[397]: Inserted module 'lm75'
Dec  1 15:46:15 localhost systemd-modules-load[397]: Inserted module 'ledtrig_netdev'
Dec  1 15:46:15 localhost systemd-sysusers[420]: Creating group systemd-coredump with gid 999.
Dec  1 15:46:15 localhost systemd-sysusers[420]: Creating user systemd-coredump (systemd Core Dumper) with uid 999 and gid 999.
Dec  1 15:46:15 localhost systemd-udevd[500]: Using default interface naming scheme 'v240'.
Dec  1 15:46:15 localhost systemd-udevd[500]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Dec  1 15:46:15 localhost systemd-udevd[500]: link_config: could not get ethtool features for eth0
Dec  1 15:46:15 localhost systemd-udevd[500]: Could not set offload features of eth0: Device or resource busy
Dec  1 15:46:15 localhost keyboard-setup.sh[399]: kbd_mode: invalid option -- 'x'
Dec  1 15:46:15 localhost keyboard-setup.sh[399]: usage: kbd_mode [-a|-u|-k|-s] [-C device]
Dec  1 15:46:15 localhost systemd-udevd[502]: Process '/bin/ln -sf /sys/devices/platform/ff120000.i2c/i2c-2/2-004c/hwmon/hwmon2 /dev/thermal-board' failed with exit code 1.
Dec  1 15:46:15 localhost kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Dec  1 15:46:15 localhost kernel: [    0.000000] Linux version 5.9.11-rockchip64 (root@beast) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.11.1 SMP PREEMPT Fri Nov 27 21:59:08 CET 2020
Dec  1 15:46:15 localhost kernel: [    0.000000] Machine model: Helios64
Dec  1 15:46:15 localhost systemd-udevd[502]: Process '/bin/ln -sf /sys/devices/virtual/thermal/thermal_zone0/hwmon0 /dev/thermal-cpu' failed with exit code 1.
Dec  1 15:46:15 localhost systemd-udevd[443]: Using default interface naming scheme 'v240'.
Dec  1 15:46:15 localhost resolvconf[407]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
Dec  1 15:46:15 localhost systemd-udevd[443]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Dec  1 15:46:15 localhost armbian-zram-config[439]: Setting up swapspace version 1, size = 1.9 GiB (1992224768 bytes)
Dec  1 15:46:15 localhost armbian-zram-config[439]: no label, UUID=7bd071e9-1280-48ba-ad12-7b486bfa9894
Dec  1 15:46:15 localhost armbian-zram-config[439]: mke2fs 1.44.5 (15-Dec-2018)
Dec  1 15:46:15 localhost armbian-zram-config[439]: ext2fs_check_if_mount: Can't check if filesystem is mounted due to missing mtab file while determining whether /dev/zram0 is mounted.
Dec  1 15:46:15 localhost armbian-zram-config[439]: Discarding device blocks:  4096/12800#010#010#010#010#010#010#010#010#010#010#010           #010#010#010#010#010#010#010#010#010#010#010done
Dec  1 15:46:15 localhost armbian-zram-config[439]: Creating filesystem with 12800 4k blocks and 12800 inodes
Dec  1 15:46:15 localhost armbian-zram-config[439]: Allocating group tables: 0/1#010#010#010   #010#010#010done
Dec  1 15:46:15 localhost armbian-zram-config[439]: Writing inode tables: 0/1#010#010#010   #010#010#010done
Dec  1 15:46:15 localhost armbian-zram-config[439]: Writing superblocks and filesystem accounting information: 0/1#010#010#010   #010#010#010done
Dec  1 15:46:15 localhost armbian-zram-config[439]: grep: /etc/mtab: No such file or directory
Dec  1 15:46:15 localhost armbian-zram-config[439]: ext2fs_check_if_mount: Can't check if filesystem is mounted due to missing mtab file while determining whether /dev/zram2 is mounted.
Dec  1 15:46:15 localhost armbian-zram-config[439]: Discarding device blocks:   4096/486384#010#010#010#010#010#010#010#010#010#010#010#010#010             #010#010#010#010#010#010#010#010#010#010#010#010#010done
Dec  1 15:46:15 localhost armbian-zram-config[439]: Creating filesystem with 486384 4k blocks and 121680 inodes
Dec  1 15:46:15 localhost armbian-zram-config[439]: Filesystem UUID: 2954ca98-00ea-487e-9e0b-b2eb002d512f
Dec  1 15:46:15 localhost armbian-zram-config[439]: Superblock backups stored on blocks:
Dec  1 15:46:15 localhost armbian-zram-config[439]: #01132768, 98304, 163840, 229376, 294912
Dec  1 15:46:15 localhost armbian-zram-config[439]: Allocating group tables:  0/15#010#010#010#010#010     #010#010#010#010#010done
Dec  1 15:46:15 localhost armbian-zram-config[439]: Writing inode tables:  0/15#010#010#010#010#010     #010#010#010#010#010done
Dec  1 15:46:15 localhost armbian-zram-config[439]: Writing superblocks and filesystem accounting information:  0/15#010#010#010#010#010     #010#010#010#010#010done
Dec  1 15:46:15 localhost armbian-ramlog[632]: Mounting /dev/zram0 as /var/log/
Dec  1 15:46:15 localhost armbian-ramlog[632]: Tue 01 Dec 2020 03:46:08 PM UTC: Loading logs from storage
Dec  1 15:46:15 localhost armbian-ramlog[632]: sending incremental file list
Dec  1 15:46:15 localhost armbian-ramlog[632]: ./
Dec  1 15:46:15 localhost armbian-ramlog[632]: alternatives.log
Dec  1 15:46:15 localhost armbian-ramlog[632]: armbian-hardware-monitor.log
Dec  1 15:46:15 localhost armbian-ramlog[632]: bootstrap.log
Dec  1 15:46:15 localhost armbian-ramlog[632]: btmp
Dec  1 15:46:15 localhost armbian-ramlog[632]: dpkg.log
Dec  1 15:46:15 localhost armbian-ramlog[632]: faillog
Dec  1 15:46:15 localhost armbian-ramlog[632]: lastlog
Dec  1 15:46:15 localhost armbian-ramlog[632]: wtmp
Dec  1 15:46:15 localhost armbian-ramlog[632]: apt/
Dec  1 15:46:15 localhost armbian-ramlog[632]: apt/history.log
Dec  1 15:46:15 localhost armbian-ramlog[632]: apt/term.log
Dec  1 15:46:15 localhost armbian-ramlog[632]: chrony/
Dec  1 15:46:15 localhost armbian-ramlog[632]: sysstat/
Dec  1 15:46:15 localhost armbian-ramlog[632]: unattended-upgrades/
Dec  1 15:46:15 localhost armbian-ramlog[632]: sent 487,820 bytes  received 233 bytes  325,368.67 bytes/sec
Dec  1 15:46:15 localhost armbian-ramlog[632]: total size is 486,791  speedup is 1.00
Dec  1 15:46:15 localhost systemd[1]: Starting Flush Journal to Persistent Storage...
Dec  1 15:46:15 localhost systemd[1]: Started Flush Journal to Persistent Storage.
Dec  1 15:46:15 localhost systemd[1]: Starting Create Volatile Files and Directories...
Dec  1 15:46:15 localhost systemd[1]: Started Create Volatile Files and Directories.
Dec  1 15:46:15 localhost systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
Dec  1 15:46:15 localhost kernel: [    0.000000] efi: UEFI not found.
Dec  1 15:46:15 localhost kernel: [    0.000000] cma: Reserved 128 MiB at 0x00000000ed000000
Dec  1 15:46:15 localhost kernel: [    0.000000] NUMA: No NUMA configuration found
Dec  1 15:46:15 localhost kernel: [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 15:46:15 localhost kernel: [    0.000000] NUMA: NODE_DATA [mem 0xf77d9100-0xf77dafff]
Dec  1 15:46:15 localhost kernel: [    0.000000] Zone ranges:
Dec  1 15:46:15 localhost kernel: [    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
Dec  1 15:46:15 localhost kernel: [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
Dec  1 15:46:15 localhost kernel: [    0.000000]   Normal   empty
Dec  1 15:46:15 localhost kernel: [    0.000000] Movable zone start for each node
Dec  1 15:46:15 localhost kernel: [    0.000000] Early memory node ranges
Dec  1 15:46:15 localhost kernel: [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 15:46:15 localhost kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 15:46:15 localhost kernel: [    0.000000] On node 0 totalpages: 1015296
Dec  1 15:46:15 localhost kernel: [    0.000000]   DMA zone: 4088 pages used for memmap
Dec  1 15:46:15 localhost kernel: [    0.000000]   DMA zone: 0 pages reserved
Dec  1 15:46:15 localhost kernel: [    0.000000]   DMA zone: 261632 pages, LIFO batch:63
Dec  1 15:46:15 localhost kernel: [    0.000000]   DMA32 zone: 11776 pages used for memmap
Dec  1 15:46:15 localhost kernel: [    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
Dec  1 15:46:15 localhost kernel: [    0.000000] psci: probing for conduit method from DT.
Dec  1 15:46:15 localhost kernel: [    0.000000] psci: PSCIv1.0 detected in firmware.
Dec  1 15:46:15 localhost kernel: [    0.000000] psci: Using standard PSCI v0.2 function IDs
Dec  1 15:46:15 localhost kernel: [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
Dec  1 15:46:15 localhost kernel: [    0.000000] psci: SMC Calling Convention v1.0
Dec  1 15:46:15 localhost kernel: [    0.000000] percpu: Embedded 32 pages/cpu s93784 r8192 d29096 u131072
Dec  1 15:46:15 localhost kernel: [    0.000000] pcpu-alloc: s93784 r8192 d29096 u131072 alloc=32*4096
Dec  1 15:46:15 localhost kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
Dec  1 15:46:15 localhost kernel: [    0.000000] Detected VIPT I-cache on CPU0
Dec  1 15:46:15 localhost kernel: [    0.000000] CPU features: detected: ARM erratum 845719
Dec  1 15:46:15 localhost kernel: [    0.000000] CPU features: detected: GIC system register CPU interface
Dec  1 15:46:15 localhost kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
Dec  1 15:46:15 localhost kernel: [    0.000000] Policy zone: DMA32
Dec  1 15:46:15 localhost kernel: [    0.000000] Kernel command line: root=UUID=a60f3956-17d4-4744-bc2b-021293160020 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=92c32d3c-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
Dec  1 15:46:15 localhost kernel: [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
Dec  1 15:46:15 localhost kernel: [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
Dec  1 15:46:15 localhost kernel: [    0.000000] Memory: 3741864K/4061184K available (14528K kernel code, 2096K rwdata, 5992K rodata, 4224K init, 575K bss, 188248K reserved, 131072K cma-reserved)
Dec  1 15:46:15 localhost kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Dec  1 15:46:15 localhost kernel: [    0.000000] rcu: Preemptible hierarchical RCU implementation.
Dec  1 15:46:15 localhost kernel: [    0.000000] rcu: 	RCU event tracing is enabled.
Dec  1 15:46:15 localhost kernel: [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
Dec  1 15:46:15 localhost kernel: [    0.000000] 	Trampoline variant of Tasks RCU enabled.
Dec  1 15:46:15 localhost kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
Dec  1 15:46:15 localhost kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
Dec  1 15:46:15 localhost kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Dec  1 15:46:15 localhost kernel: [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
Dec  1 15:46:15 localhost kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: 256 SPIs implemented
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: 0 Extended SPIs implemented
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: Distributor has no Range Selector support
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: 16 PPIs implemented
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
Dec  1 15:46:15 localhost kernel: [    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
Dec  1 15:46:15 localhost kernel: [    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @f6d00000 (flat, esz 8, psz 64K, shr 0)
Dec  1 15:46:15 localhost kernel: [    0.000000] ITS: using cache flushing for cmd queue
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: using LPI property table @0x00000000f6cb0000
Dec  1 15:46:15 localhost kernel: [    0.000000] GIC: using cache flushing for LPI property table
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f6cc0000
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
Dec  1 15:46:15 localhost kernel: [    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
Dec  1 15:46:15 localhost kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x690/0x848 with crng_init=0
Dec  1 15:46:15 localhost kernel: [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
Dec  1 15:46:15 localhost kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Dec  1 15:46:15 localhost kernel: [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Dec  1 15:46:15 localhost kernel: [    0.001484] Console: colour dummy device 80x25
Dec  1 15:46:15 localhost kernel: [    0.001501] printk: console [tty1] enabled
Dec  1 15:46:15 localhost kernel: [    0.001629] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
Dec  1 15:46:15 localhost kernel: [    0.001643] pid_max: default: 32768 minimum: 301
Dec  1 15:46:15 localhost kernel: [    0.001794] LSM: Security Framework initializing
Dec  1 15:46:15 localhost kernel: [    0.001838] Yama: becoming mindful.
Dec  1 15:46:15 localhost kernel: [    0.001983] AppArmor: AppArmor initialized
Dec  1 15:46:15 localhost kernel: [    0.002072] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    0.002102] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    0.005346] rcu: Hierarchical SRCU implementation.
Dec  1 15:46:15 localhost kernel: [    0.006463] Platform MSI: interrupt-controller@fee20000 domain created
Dec  1 15:46:15 localhost kernel: [    0.007025] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
Dec  1 15:46:15 localhost kernel: [    0.009629] EFI services will not be available.
Dec  1 15:46:15 localhost kernel: [    0.010290] smp: Bringing up secondary CPUs ...
Dec  1 15:46:15 localhost kernel: [    0.011314] Detected VIPT I-cache on CPU1
Dec  1 15:46:15 localhost kernel: [    0.011363] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
Dec  1 15:46:15 localhost kernel: [    0.011382] GICv3: CPU1: using allocated LPI pending table @0x00000000f6cd0000
Dec  1 15:46:15 localhost kernel: [    0.011443] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Dec  1 15:46:15 localhost kernel: [    0.012805] Detected VIPT I-cache on CPU2
Dec  1 15:46:15 localhost kernel: [    0.012851] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
Dec  1 15:46:15 localhost kernel: [    0.012870] GICv3: CPU2: using allocated LPI pending table @0x00000000f6ce0000
Dec  1 15:46:15 localhost kernel: [    0.012931] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Dec  1 15:46:15 localhost kernel: [    0.014362] Detected VIPT I-cache on CPU3
Dec  1 15:46:15 localhost kernel: [    0.014408] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
Dec  1 15:46:15 localhost kernel: [    0.014427] GICv3: CPU3: using allocated LPI pending table @0x00000000f6cf0000
Dec  1 15:46:15 localhost kernel: [    0.014487] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Dec  1 15:46:15 localhost kernel: [    0.015878] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
Dec  1 15:46:15 localhost kernel: [    0.015888] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
Dec  1 15:46:15 localhost kernel: [    0.015896] Detected PIPT I-cache on CPU4
Dec  1 15:46:15 localhost kernel: [    0.015929] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
Dec  1 15:46:15 localhost kernel: [    0.015943] GICv3: CPU4: using allocated LPI pending table @0x00000000f6d80000
Dec  1 15:46:15 localhost kernel: [    0.015981] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
Dec  1 15:46:15 localhost kernel: [    0.017170] Detected PIPT I-cache on CPU5
Dec  1 15:46:15 localhost kernel: [    0.017206] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
Dec  1 15:46:15 localhost kernel: [    0.017220] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d90000
Dec  1 15:46:15 localhost kernel: [    0.017259] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
Dec  1 15:46:15 localhost kernel: [    0.017427] smp: Brought up 1 node, 6 CPUs
Dec  1 15:46:15 localhost kernel: [    0.017438] SMP: Total of 6 processors activated.
Dec  1 15:46:15 localhost kernel: [    0.017448] CPU features: detected: 32-bit EL0 Support
Dec  1 15:46:15 localhost kernel: [    0.017456] CPU features: detected: CRC32 instructions
Dec  1 15:46:15 localhost kernel: [    0.017465] CPU features: detected: 32-bit EL1 Support
Dec  1 15:46:15 localhost kernel: [    0.045670] CPU: All CPU(s) started at EL2
Dec  1 15:46:15 localhost kernel: [    0.045735] alternatives: patching kernel code
Dec  1 15:46:15 localhost kernel: [    0.049447] devtmpfs: initialized
Dec  1 15:46:15 localhost kernel: [    0.066117] Registered cp15_barrier emulation handler
Dec  1 15:46:15 localhost kernel: [    0.066138] Registered setend emulation handler
Dec  1 15:46:15 localhost kernel: [    0.066911] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Dec  1 15:46:15 localhost kernel: [    0.066981] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    0.070117] xor: measuring software checksum speed
Dec  1 15:46:15 localhost kernel: [    0.109648]    8regs     :  2346.000 MB/sec
Dec  1 15:46:15 localhost kernel: [    0.149732]    32regs    :  2757.000 MB/sec
Dec  1 15:46:15 localhost kernel: [    0.189818]    arm64_neon:  2226.000 MB/sec
Dec  1 15:46:15 localhost systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Dec  1 15:46:15 localhost systemd[1]: Started Update UTMP about System Boot/Shutdown.
Dec  1 15:46:15 localhost systemd[1]: Reached target System Initialization.
Dec  1 15:46:15 localhost systemd[1]: Started Daily rotation of log files.
Dec  1 15:46:15 localhost systemd[1]: Starting Armbian hardware monitoring...
Dec  1 15:46:15 localhost systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec  1 15:46:15 localhost systemd[1]: Starting Armbian hardware optimization...
Dec  1 15:46:15 localhost systemd[1]: Listening on D-Bus System Message Bus Socket.
Dec  1 15:46:15 localhost systemd[1]: Reached target Sockets.
Dec  1 15:46:15 localhost systemd[1]: Started Daily apt download activities.
Dec  1 15:46:15 localhost systemd[1]: Started Daily apt upgrade and clean activities.
Dec  1 15:46:15 localhost systemd[1]: Started Daily man-db regeneration.
Dec  1 15:46:15 localhost systemd[1]: Reached target Timers.
Dec  1 15:46:15 localhost systemd[1]: Starting Armbian filesystem resize...
Dec  1 15:46:15 localhost systemd[1]: Started Armbian hardware monitoring.
Dec  1 15:46:15 localhost armbian-hardware-optimization[683]: aplay: device_list:272: no soundcards found...
Dec  1 15:46:15 localhost systemd[1]: Started Armbian hardware optimization.
Dec  1 15:46:15 localhost armbian-hardware-optimization[683]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1
Dec  1 15:46:15 localhost armbian-hardware-optimization[683]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1boot0
Dec  1 15:46:15 localhost armbian-hardware-optimization[683]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1boot1
Dec  1 15:46:15 localhost haveged[680]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 8.3.0 CTV); collect: 128K
Dec  1 15:46:15 localhost haveged[680]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 15528/64688
Dec  1 15:46:15 localhost haveged[680]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 7.99694
Dec  1 15:46:15 localhost haveged[680]: haveged: fills: 0, generated: 0
Dec  1 15:46:15 localhost armbian-resize-filesystem[685]: /usr/lib/armbian/armbian-resize-filesystem: line 145: [[: 10%: syntax error: operand expected (error token is "%")
Dec  1 15:46:15 localhost armbian-resize-filesystem[685]: Removed /etc/systemd/system/basic.target.wants/armbian-resize-filesystem.service.
Dec  1 15:46:15 localhost systemd[1]: Reloading.
Dec  1 15:46:15 localhost systemd[1]: /etc/systemd/system/serial-getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
Dec  1 15:46:15 localhost systemd[1]: /etc/systemd/system/getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
Dec  1 15:46:15 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 15:46:15 localhost systemd[1]: Started Armbian filesystem resize.
Dec  1 15:46:15 localhost systemd[1]: Reached target Basic System.
Dec  1 15:46:15 localhost systemd[1]: Starting fan speed regulator...
Dec  1 15:46:15 localhost systemd[1]: Starting rng-tools.service...
Dec  1 15:46:15 localhost systemd[1]: Started Armbian first run tasks.
Dec  1 15:46:15 localhost systemd[1]: Created slice system-getty.slice.
Dec  1 15:46:15 localhost systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Dec  1 15:46:15 localhost systemd[1]: Starting Resets System Activity Data Collector...
Dec  1 15:46:15 localhost systemd[1]: Starting Login Service...
Dec  1 15:46:15 localhost fancontrol[1311]: Loading configuration from /etc/fancontrol ...
Dec  1 15:46:15 localhost systemd[1]: Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Dec  1 15:46:15 localhost rng-tools[1312]: Starting Hardware RNG entropy gatherer daemon: rngd.
Dec  1 15:46:15 localhost rngd[1318]: rngd 2-unofficial-mt.14 starting up...
Dec  1 15:46:15 localhost rngd[1318]: entropy feed to the kernel ready
Dec  1 15:46:15 localhost systemd[1]: Starting System Logging Service...
Dec  1 15:46:15 localhost systemd[1]: Started D-Bus System Message Bus.
Dec  1 15:46:15 localhost systemd[1]: Starting WPA supplicant...
Dec  1 15:46:15 localhost systemd[1]: Starting Network Manager...
Dec  1 15:46:15 localhost systemd[1]: Started Regular background program processing daemon.
Dec  1 15:46:15 localhost kernel: [    0.189824] xor: using function: 32regs (2757.000 MB/sec)
Dec  1 15:46:15 localhost kernel: [    0.189882] pinctrl core: initialized pinctrl subsystem
Dec  1 15:46:15 localhost kernel: [    0.190555] DMI not present or invalid.
Dec  1 15:46:15 localhost kernel: [    0.191153] NET: Registered protocol family 16
Dec  1 15:46:15 localhost kernel: [    0.193918] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Dec  1 15:46:15 localhost kernel: [    0.195363] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Dec  1 15:46:15 localhost kernel: [    0.196135] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Dec  1 15:46:15 localhost kernel: [    0.196237] audit: initializing netlink subsys (disabled)
Dec  1 15:46:15 localhost kernel: [    0.196550] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
Dec  1 15:46:15 localhost kernel: [    0.197810] thermal_sys: Registered thermal governor 'fair_share'
Dec  1 15:46:15 localhost kernel: [    0.197813] thermal_sys: Registered thermal governor 'bang_bang'
Dec  1 15:46:15 localhost kernel: [    0.197820] thermal_sys: Registered thermal governor 'step_wise'
Dec  1 15:46:15 localhost kernel: [    0.197825] thermal_sys: Registered thermal governor 'user_space'
Dec  1 15:46:15 localhost kernel: [    0.198323] cpuidle: using governor menu
Dec  1 15:46:15 localhost kernel: [    0.198653] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Dec  1 15:46:15 localhost kernel: [    0.198886] ASID allocator initialised with 65536 entries
Dec  1 15:46:15 localhost kernel: [    0.200211] Serial: AMBA PL011 UART driver
Dec  1 15:46:15 localhost kernel: [    0.267811] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Dec  1 15:46:15 localhost kernel: [    0.267821] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Dec  1 15:46:15 localhost kernel: [    0.267828] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Dec  1 15:46:15 localhost kernel: [    0.267835] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Dec  1 15:46:15 localhost kernel: [    0.273384] cryptd: max_cpu_qlen set to 1000
Dec  1 15:46:15 localhost kernel: [    0.350264] raid6: neonx8   gen()  1667 MB/s
Dec  1 15:46:15 localhost kernel: [    0.418429] raid6: neonx8   xor()  1223 MB/s
Dec  1 15:46:15 localhost kernel: [    0.486591] raid6: neonx4   gen()  1684 MB/s
Dec  1 15:46:15 localhost kernel: [    0.554760] raid6: neonx4   xor()  1265 MB/s
Dec  1 15:46:15 localhost kernel: [    0.622925] raid6: neonx2   gen()  1504 MB/s
Dec  1 15:46:15 localhost kernel: [    0.691084] raid6: neonx2   xor()  1160 MB/s
Dec  1 15:46:15 localhost kernel: [    0.759256] raid6: neonx1   gen()  1183 MB/s
Dec  1 15:46:15 localhost kernel: [    0.827421] raid6: neonx1   xor()   942 MB/s
Dec  1 15:46:15 localhost kernel: [    0.895609] raid6: int64x8  gen()   993 MB/s
Dec  1 15:46:15 localhost kernel: [    0.963739] raid6: int64x8  xor()   578 MB/s
Dec  1 15:46:15 localhost kernel: [    1.031896] raid6: int64x4  gen()   990 MB/s
Dec  1 15:46:15 localhost kernel: [    1.100036] raid6: int64x4  xor()   589 MB/s
Dec  1 15:46:15 localhost kernel: [    1.168186] raid6: int64x2  gen()   927 MB/s
Dec  1 15:46:15 localhost kernel: [    1.236335] raid6: int64x2  xor()   522 MB/s
Dec  1 15:46:15 localhost kernel: [    1.304513] raid6: int64x1  gen()   722 MB/s
Dec  1 15:46:15 localhost kernel: [    1.372657] raid6: int64x1  xor()   389 MB/s
Dec  1 15:46:15 localhost kernel: [    1.372663] raid6: using algorithm neonx4 gen() 1684 MB/s
Dec  1 15:46:15 localhost kernel: [    1.372668] raid6: .... xor() 1265 MB/s, rmw enabled
Dec  1 15:46:15 localhost kernel: [    1.372673] raid6: using neon recovery algorithm
Dec  1 15:46:15 localhost kernel: [    1.374205] vcc12v_dcin_bkup: supplied by vcc12v_dcin
Dec  1 15:46:15 localhost kernel: [    1.374613] vcc12v_hdd: supplied by vcc12v_dcin_bkup
Dec  1 15:46:15 localhost kernel: [    1.388904] vcc5v0_perdev: supplied by vcc12v_dcin_bkup
Dec  1 15:46:15 localhost kernel: [    1.389417] pcie_power: supplied by vcc5v0_perdev
Dec  1 15:46:15 localhost kernel: [    1.389528] vcc5v0_usb: supplied by vcc5v0_perdev
Dec  1 15:46:15 localhost kernel: [    1.389595] vcc5v0_typec: supplied by vcc5v0_usb
Dec  1 15:46:15 localhost kernel: [    1.389652] vcc5v0_hdd: supplied by vcc12v_dcin_bkup
Dec  1 15:46:15 localhost kernel: [    1.390274] vcc5v0_sys: supplied by vcc12v_dcin_bkup
Dec  1 15:46:15 localhost kernel: [    1.390813] vcc3v3_sys_s3: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    1.390867] vcc0v9_s3: supplied by vcc3v3_sys_s3
Dec  1 15:46:15 localhost kernel: [    1.390956] avdd_1v8_s0: supplied by vcc3v3_sys_s3
Dec  1 15:46:15 localhost kernel: [    1.391023] vcc3v0_sd: supplied by vcc3v3_sys_s3
Dec  1 15:46:15 localhost kernel: [    1.392008] usblan_power: supplied by vcc5v0_usb
Dec  1 15:46:15 localhost kernel: [    1.392598] iommu: Default domain type: Translated
Dec  1 15:46:15 localhost kernel: [    1.396071] vgaarb: loaded
Dec  1 15:46:15 localhost kernel: [    1.396596] SCSI subsystem initialized
Dec  1 15:46:15 localhost kernel: [    1.396878] libata version 3.00 loaded.
Dec  1 15:46:15 localhost kernel: [    1.397138] usbcore: registered new interface driver usbfs
Dec  1 15:46:15 localhost kernel: [    1.397182] usbcore: registered new interface driver hub
Dec  1 15:46:15 localhost kernel: [    1.397281] usbcore: registered new device driver usb
Dec  1 15:46:15 localhost kernel: [    1.398016] pps_core: LinuxPPS API ver. 1 registered
Dec  1 15:46:15 localhost kernel: [    1.398022] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Dec  1 15:46:15 localhost kernel: [    1.398037] PTP clock support registered
Dec  1 15:46:15 localhost kernel: [    1.398353] EDAC MC: Ver: 3.0.0
Dec  1 15:46:15 localhost kernel: [    1.399528] NetLabel: Initializing
Dec  1 15:46:15 localhost kernel: [    1.399535] NetLabel:  domain hash size = 128
Dec  1 15:46:15 localhost kernel: [    1.399540] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Dec  1 15:46:15 localhost kernel: [    1.399604] NetLabel:  unlabeled traffic allowed by default
Dec  1 15:46:15 localhost kernel: [    1.400127] clocksource: Switched to clocksource arch_sys_counter
Dec  1 15:46:15 localhost kernel: [    1.524434] VFS: Disk quotas dquot_6.6.0
Dec  1 15:46:15 localhost kernel: [    1.524512] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec  1 15:46:15 localhost kernel: [    1.525344] AppArmor: AppArmor Filesystem Enabled
Dec  1 15:46:15 localhost kernel: [    1.534052] NET: Registered protocol family 2
Dec  1 15:46:15 localhost kernel: [    1.534921] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    1.535095] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    1.535634] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    1.536339] TCP: Hash tables configured (established 32768 bind 32768)
Dec  1 15:46:15 localhost kernel: [    1.536533] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    1.536703] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Dec  1 15:46:15 localhost kernel: [    1.537048] NET: Registered protocol family 1
Dec  1 15:46:15 localhost kernel: [    1.537078] NET: Registered protocol family 44
Dec  1 15:46:15 localhost kernel: [    1.537092] PCI: CLS 0 bytes, default 64
Dec  1 15:46:15 localhost kernel: [    1.537321] Trying to unpack rootfs image as initramfs...
Dec  1 15:46:15 localhost kernel: [    2.555802] Freeing initrd memory: 13908K
Dec  1 15:46:15 localhost kernel: [    2.557061] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
Dec  1 15:46:15 localhost kernel: [    2.557478] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Dec  1 15:46:15 localhost kernel: [    2.558252] kvm [1]: IPA Size Limit: 40bits
Dec  1 15:46:15 localhost kernel: [    2.559004] kvm [1]: vgic-v2@fff20000
Dec  1 15:46:15 localhost kernel: [    2.559039] kvm [1]: GIC system register CPU interface enabled
Dec  1 15:46:15 localhost kernel: [    2.559278] kvm [1]: vgic interrupt IRQ10
Dec  1 15:46:15 localhost kernel: [    2.559568] kvm [1]: Hyp mode initialized successfully
Dec  1 15:46:15 localhost kernel: [    2.570635] Initialise system trusted keyrings
Dec  1 15:46:15 localhost kernel: [    2.570687] Key type blacklist registered
Dec  1 15:46:15 localhost kernel: [    2.570897] workingset: timestamp_bits=44 max_order=20 bucket_order=0
Dec  1 15:46:15 localhost kernel: [    2.577143] zbud: loaded
Dec  1 15:46:15 localhost kernel: [    2.578735] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Dec  1 15:46:15 localhost kernel: [    2.579593] fuse: init (API version 7.31)
Dec  1 15:46:15 localhost kernel: [    2.580988] integrity: Platform Keyring initialized
Dec  1 15:46:15 localhost kernel: [    2.646193] Key type asymmetric registered
Dec  1 15:46:15 localhost kernel: [    2.646200] Asymmetric key parser 'x509' registered
Dec  1 15:46:15 localhost kernel: [    2.646252] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
Dec  1 15:46:15 localhost kernel: [    2.646522] io scheduler mq-deadline registered
Dec  1 15:46:15 localhost kernel: [    2.646529] io scheduler kyber registered
Dec  1 15:46:15 localhost kernel: [    2.646654] io scheduler bfq registered
Dec  1 15:46:15 localhost kernel: [    2.665439] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
Dec  1 15:46:15 localhost kernel: [    2.665465] OF: /pcie@f8000000: Missing device_type
Dec  1 15:46:15 localhost kernel: [    2.665497] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
Dec  1 15:46:15 localhost kernel: [    2.665518] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
Dec  1 15:46:15 localhost kernel: [    2.674512] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
Dec  1 15:46:15 localhost kernel: [    2.674525] dma-pl330 ff6d0000.dma-controller: 	DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
Dec  1 15:46:15 localhost kernel: [    2.676051] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
Dec  1 15:46:15 localhost kernel: [    2.676062] dma-pl330 ff6e0000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
Dec  1 15:46:15 localhost kernel: [    2.680802] vdd_log: supplied by regulator-dummy
Dec  1 15:46:15 localhost kernel: [    2.682238] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
Dec  1 15:46:15 localhost kernel: [    2.685423] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
Dec  1 15:46:15 localhost rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Dec  1 15:46:15 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="1324" x-info="https://www.rsyslog.com"] start
Dec  1 15:46:15 localhost kernel: [    2.686417] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
Dec  1 15:46:15 localhost kernel: [    2.686605] printk: console [ttyS2] enabled
Dec  1 15:46:15 localhost kernel: [    2.688010] Serial: AMBA driver
Dec  1 15:46:15 localhost kernel: [    2.689664] cacheinfo: Unable to detect cache hierarchy for CPU 0
Dec  1 15:46:15 localhost kernel: [    2.701470] loop: module loaded
Dec  1 15:46:15 localhost kernel: [    2.710395] libphy: Fixed MDIO Bus: probed
Dec  1 15:46:15 localhost kernel: [    2.710737] tun: Universal TUN/TAP device driver, 1.6
Dec  1 15:46:15 localhost kernel: [    2.711886] thunder_xcv, ver 1.0
Dec  1 15:46:15 localhost kernel: [    2.711929] thunder_bgx, ver 1.0
Dec  1 15:46:15 localhost kernel: [    2.711977] nicpf, ver 1.0
Dec  1 15:46:15 localhost kernel: [    2.713270] e1000e: Intel(R) PRO/1000 Network Driver
Dec  1 15:46:15 localhost kernel: [    2.713275] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Dec  1 15:46:15 localhost kernel: [    2.713324] igb: Intel(R) Gigabit Ethernet Network Driver
Dec  1 15:46:15 localhost kernel: [    2.713329] igb: Copyright (c) 2007-2014 Intel Corporation.
Dec  1 15:46:15 localhost kernel: [    2.713365] igbvf: Intel(R) Gigabit Virtual Function Network Driver
Dec  1 15:46:15 localhost kernel: [    2.713370] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Dec  1 15:46:15 localhost kernel: [    2.713674] sky2: driver version 1.30
Dec  1 15:46:15 localhost kernel: [    2.714395] VFIO - User Level meta-driver version: 0.3
Dec  1 15:46:15 localhost kernel: [    2.733327] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec  1 15:46:15 localhost kernel: [    2.733351] ehci-pci: EHCI PCI platform driver
Dec  1 15:46:15 localhost kernel: [    2.733390] ehci-platform: EHCI generic platform driver
Dec  1 15:46:15 localhost kernel: [    2.735802] ehci-platform fe380000.usb: EHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    2.735827] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
Dec  1 15:46:15 localhost kernel: [    2.735999] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
Dec  1 15:46:15 localhost kernel: [    2.748149] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
Dec  1 15:46:15 localhost kernel: [    2.748404] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 15:46:15 localhost kernel: [    2.748415] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 15:46:15 localhost kernel: [    2.748423] usb usb1: Product: EHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    2.748431] usb usb1: Manufacturer: Linux 5.9.11-rockchip64 ehci_hcd
Dec  1 15:46:15 localhost kernel: [    2.748438] usb usb1: SerialNumber: fe380000.usb
Dec  1 15:46:15 localhost kernel: [    2.748986] hub 1-0:1.0: USB hub found
Dec  1 15:46:15 localhost kernel: [    2.749026] hub 1-0:1.0: 1 port detected
Dec  1 15:46:15 localhost kernel: [    2.749832] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec  1 15:46:15 localhost kernel: [    2.749873] ohci-pci: OHCI PCI platform driver
Dec  1 15:46:15 localhost kernel: [    2.749927] ohci-platform: OHCI generic platform driver
Dec  1 15:46:15 localhost kernel: [    2.750264] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
Dec  1 15:46:15 localhost kernel: [    2.750286] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 2
Dec  1 15:46:15 localhost kernel: [    2.750408] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
Dec  1 15:46:15 localhost kernel: [    2.812364] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
Dec  1 15:46:15 localhost kernel: [    2.812374] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 15:46:15 localhost kernel: [    2.812382] usb usb2: Product: Generic Platform OHCI controller
Dec  1 15:46:15 localhost kernel: [    2.812390] usb usb2: Manufacturer: Linux 5.9.11-rockchip64 ohci_hcd
Dec  1 15:46:15 localhost kernel: [    2.812397] usb usb2: SerialNumber: fe3a0000.usb
Dec  1 15:46:15 localhost kernel: [    2.812937] hub 2-0:1.0: USB hub found
Dec  1 15:46:15 localhost kernel: [    2.812977] hub 2-0:1.0: 1 port detected
Dec  1 15:46:15 localhost kernel: [    2.814589] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    2.814611] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
Dec  1 15:46:15 localhost kernel: [    2.814792] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
Dec  1 15:46:15 localhost kernel: [    2.814856] xhci-hcd xhci-hcd.0.auto: irq 228, io mem 0xfe900000
Dec  1 15:46:15 localhost kernel: [    2.815267] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 15:46:15 localhost kernel: [    2.815276] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 15:46:15 localhost kernel: [    2.815285] usb usb3: Product: xHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    2.815292] usb usb3: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 15:46:15 localhost kernel: [    2.815299] usb usb3: SerialNumber: xhci-hcd.0.auto
Dec  1 15:46:15 localhost kernel: [    2.815822] hub 3-0:1.0: USB hub found
Dec  1 15:46:15 localhost kernel: [    2.815863] hub 3-0:1.0: 1 port detected
Dec  1 15:46:15 localhost kernel: [    2.816233] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    2.816249] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
Dec  1 15:46:15 localhost kernel: [    2.816284] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
Dec  1 15:46:15 localhost kernel: [    2.816362] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Dec  1 15:46:15 localhost kernel: [    2.816512] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
Dec  1 15:46:15 localhost kernel: [    2.816521] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 15:46:15 localhost kernel: [    2.816528] usb usb4: Product: xHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    2.816535] usb usb4: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 15:46:15 localhost kernel: [    2.816542] usb usb4: SerialNumber: xhci-hcd.0.auto
Dec  1 15:46:15 localhost kernel: [    2.817024] hub 4-0:1.0: USB hub found
Dec  1 15:46:15 localhost kernel: [    2.817061] hub 4-0:1.0: 1 port detected
Dec  1 15:46:15 localhost kernel: [    2.817546] usbcore: registered new interface driver usb-storage
Dec  1 15:46:15 localhost kernel: [    2.820292] mousedev: PS/2 mouse device common for all mice
Dec  1 15:46:15 localhost kernel: [    2.821739] i2c /dev entries driver
Dec  1 15:46:15 localhost kernel: [    2.825802] pca953x 2-0020: using no AI
Dec  1 15:46:15 localhost kernel: [    2.835540] rk808 0-001b: chip id: 0x0
Dec  1 15:46:15 localhost kernel: [    2.839820] rk808-regulator rk808-regulator: there is no dvs0 gpio
Dec  1 15:46:15 localhost kernel: [    2.839850] rk808-regulator rk808-regulator: there is no dvs1 gpio
Dec  1 15:46:15 localhost kernel: [    2.840936] vdd_center: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.841584] vdd_cpu_l: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.841919] vcc_ddr_s3: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.842578] vcc1v8_sys_s3: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.843085] vcc1v8_dvp: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.843563] vcc3v0_touch: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.845043] vcc1v8_s3: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.845344] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
Dec  1 15:46:15 localhost kernel: [    2.846483] vcc_sdio_s0: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.846972] vcca3v0_codec: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.848163] vcc1v5_s3: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.848687] vcca1v8_codec: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.849913] vcc3v0_s3: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.850045] vcc3v3_sys_s0: failed to get the current voltage(-517)
Dec  1 15:46:15 localhost kernel: [    2.850065] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
Dec  1 15:46:15 localhost kernel: [    2.850627] vcc3v3_s0: supplied by vcc3v3_sys_s3
Dec  1 15:46:15 localhost kernel: [    2.854339] rk808-rtc rk808-rtc: registered as rtc0
Dec  1 15:46:15 localhost kernel: [    2.854896] rk808-rtc rk808-rtc: setting system clock to 2020-12-01T15:45:58 UTC (1606837558)
Dec  1 15:46:15 localhost kernel: [    2.858083] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
Dec  1 15:46:15 localhost kernel: [    2.859325] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
Dec  1 15:46:15 localhost kernel: [    2.859420] avdd_0v9_s0: supplied by vcc1v8_sys_s3
Dec  1 15:46:15 localhost kernel: [    2.859524] vdd_cpu_b: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.862612] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
Dec  1 15:46:15 localhost kernel: [    2.863186] random: fast init done
Dec  1 15:46:15 localhost kernel: [    2.863974] vdd_gpu: supplied by vcc5v0_sys
Dec  1 15:46:15 localhost kernel: [    2.873566] dw_wdt ff848000.watchdog: No valid TOPs array specified
Dec  1 15:46:15 localhost kernel: [    2.875413] sdhci: Secure Digital Host Controller Interface driver
Dec  1 15:46:15 localhost kernel: [    2.875419] sdhci: Copyright(c) Pierre Ossman
Dec  1 15:46:15 localhost kernel: [    2.875444] Synopsys Designware Multimedia Card Interface Driver
Dec  1 15:46:15 localhost kernel: [    2.877216] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
Dec  1 15:46:15 localhost kernel: [    2.877246] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
Dec  1 15:46:15 localhost kernel: [    2.877262] dwmmc_rockchip fe320000.mmc: Version ID is 270a
Dec  1 15:46:15 localhost kernel: [    2.877331] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
Dec  1 15:46:15 localhost kernel: [    2.877806] dwmmc_rockchip fe320000.mmc: Got CD GPIO
Dec  1 15:46:15 localhost kernel: [    2.890704] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Dec  1 15:46:15 localhost kernel: [    2.904372] sdhci-pltfm: SDHCI platform and OF driver helper
Dec  1 15:46:15 localhost kernel: [    2.906164] mmc1: CQHCI version 5.10
Dec  1 15:46:15 localhost kernel: [    2.932039] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
Dec  1 15:46:15 localhost kernel: [    2.936321] ledtrig-cpu: registered to indicate activity on CPUs
Dec  1 15:46:15 localhost kernel: [    2.937526] hid: raw HID events driver (C) Jiri Kosina
Dec  1 15:46:15 localhost kernel: [    2.937674] usbcore: registered new interface driver usbhid
Dec  1 15:46:15 localhost kernel: [    2.937680] usbhid: USB HID core driver
Dec  1 15:46:15 localhost kernel: [    2.943666] drop_monitor: Initializing network drop monitor service
Dec  1 15:46:15 localhost kernel: [    2.944597] NET: Registered protocol family 10
Dec  1 15:46:15 localhost kernel: [    3.000524] Segment Routing with IPv6
Dec  1 15:46:15 localhost kernel: [    3.000638] NET: Registered protocol family 17
Dec  1 15:46:15 localhost kernel: [    3.000816] 8021q: 802.1Q VLAN Support v1.8
Dec  1 15:46:15 localhost kernel: [    3.000872] Key type dns_resolver registered
Dec  1 15:46:15 localhost kernel: [    3.001686] registered taskstats version 1
Dec  1 15:46:15 localhost kernel: [    3.001757] Loading compiled-in X.509 certificates
Dec  1 15:46:15 localhost kernel: [    3.005342] mmc1: Command Queue Engine enabled
Dec  1 15:46:15 localhost kernel: [    3.005363] mmc1: new HS200 MMC card at address 0001
Dec  1 15:46:15 localhost kernel: [    3.005930] Loaded X.509 cert 'Build time autogenerated kernel key: cf582b85d37ac5e7e16062bd2222df75b99b261f'
Dec  1 15:46:15 localhost kernel: [    3.006168] zswap: loaded using pool lzo/zbud
Dec  1 15:46:15 localhost kernel: [    3.006195] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
Dec  1 15:46:15 localhost kernel: [    3.006483] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
Dec  1 15:46:15 localhost kernel: [    3.006723] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
Dec  1 15:46:15 localhost kernel: [    3.006772] Key type ._fscrypt registered
Dec  1 15:46:15 localhost kernel: [    3.006782] Key type .fscrypt registered
Dec  1 15:46:15 localhost kernel: [    3.006788] Key type fscrypt-provisioning registered
Dec  1 15:46:15 localhost kernel: [    3.006909] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB, chardev (243:0)
Dec  1 15:46:15 localhost kernel: [    3.008164]  mmcblk1: p1
Dec  1 15:46:15 localhost kernel: [    3.010309] Btrfs loaded, crc32c=crc32c-generic
Dec  1 15:46:15 localhost kernel: [    3.036868] Key type encrypted registered
Dec  1 15:46:15 localhost kernel: [    3.036894] AppArmor: AppArmor sha1 policy hashing enabled
Dec  1 15:46:15 localhost kernel: [    3.086061] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
Dec  1 15:46:15 localhost kernel: [    3.086110] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
Dec  1 15:46:15 localhost kernel: [    3.086131] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
Dec  1 15:46:15 localhost kernel: [    3.141404] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
Dec  1 15:46:15 localhost kernel: [    3.141418] pci_bus 0000:00: root bus resource [bus 00-1f]
Dec  1 15:46:15 localhost kernel: [    3.141427] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
Dec  1 15:46:15 localhost kernel: [    3.141440] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
Dec  1 15:46:15 localhost kernel: [    3.141495] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
Dec  1 15:46:15 localhost kernel: [    3.141642] pci 0000:00:00.0: supports D1
Dec  1 15:46:15 localhost kernel: [    3.141650] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Dec  1 15:46:15 localhost kernel: [    3.147416] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Dec  1 15:46:15 localhost kernel: [    3.147673] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
Dec  1 15:46:15 localhost kernel: [    3.147742] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
Dec  1 15:46:15 localhost kernel: [    3.147751] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.147786] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
Dec  1 15:46:15 localhost kernel: [    3.147794] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.147829] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
Dec  1 15:46:15 localhost kernel: [    3.147837] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.147871] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
Dec  1 15:46:15 localhost kernel: [    3.147878] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.147912] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
Dec  1 15:46:15 localhost kernel: [    3.147919] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.147954] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
Dec  1 15:46:15 localhost kernel: [    3.147989] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Dec  1 15:46:15 localhost kernel: [    3.148027] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
Dec  1 15:46:15 localhost kernel: [    3.148371] pci 0000:01:00.0: PME# supported from D3hot
Dec  1 15:46:15 localhost kernel: [    3.148619] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
Dec  1 15:46:15 localhost kernel: [    3.152162] usb 3-1: new high-speed USB device number 2 using xhci-hcd
Dec  1 15:46:15 localhost kernel: [    3.154235] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
Dec  1 15:46:15 localhost kernel: [    3.154265] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
Dec  1 15:46:15 localhost kernel: [    3.154281] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
Dec  1 15:46:15 localhost kernel: [    3.154291] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
Dec  1 15:46:15 localhost kernel: [    3.154311] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154319] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154327] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154334] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154341] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154348] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154356] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154363] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154370] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154377] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
Dec  1 15:46:15 localhost kernel: [    3.154387] pci 0000:00:00.0: PCI bridge to [bus 01]
Dec  1 15:46:15 localhost kernel: [    3.154399] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
Dec  1 15:46:15 localhost kernel: [    3.154649] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
Dec  1 15:46:15 localhost kernel: [    3.154953] pcieport 0000:00:00.0: PME: Signaling with IRQ 239
Dec  1 15:46:15 localhost kernel: [    3.155307] pcieport 0000:00:00.0: AER: enabled with IRQ 239
Dec  1 15:46:15 localhost kernel: [    3.155634] ahci 0000:01:00.0: version 3.0
Dec  1 15:46:15 localhost kernel: [    3.155659] ahci 0000:01:00.0: enabling device (0000 -> 0002)
Dec  1 15:46:15 localhost kernel: [    3.156264] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
Dec  1 15:46:15 localhost kernel: [    3.156364] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
Dec  1 15:46:15 localhost kernel: [    3.156377] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
Dec  1 15:46:15 localhost kernel: [    3.159891] scsi host0: ahci
Dec  1 15:46:15 localhost kernel: [    3.160636] scsi host1: ahci
Dec  1 15:46:15 localhost kernel: [    3.161219] scsi host2: ahci
Dec  1 15:46:15 localhost kernel: [    3.161851] scsi host3: ahci
Dec  1 15:46:15 localhost kernel: [    3.162443] scsi host4: ahci
Dec  1 15:46:15 localhost kernel: [    3.162665] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 240
Dec  1 15:46:15 localhost kernel: [    3.162675] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 241
Dec  1 15:46:15 localhost kernel: [    3.162684] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 242
Dec  1 15:46:15 localhost kernel: [    3.162691] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 243
Dec  1 15:46:15 localhost kernel: [    3.162699] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 244
Dec  1 15:46:15 localhost kernel: [    3.169079] input: gpio-keys as /devices/platform/gpio-keys/input/input0
Dec  1 15:46:15 localhost kernel: [    3.169643] of_cfs_init
Dec  1 15:46:15 localhost kernel: [    3.169681] of_cfs_init: OK
Dec  1 15:46:15 localhost kernel: [    3.302148] usb 3-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
Dec  1 15:46:15 localhost kernel: [    3.302160] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec  1 15:46:15 localhost kernel: [    3.302169] usb 3-1: Product: USB2.0 Hub
Dec  1 15:46:15 localhost kernel: [    3.302177] usb 3-1: Manufacturer: VIA Labs, Inc.
Dec  1 15:46:15 localhost kernel: [    3.360720] hub 3-1:1.0: USB hub found
Dec  1 15:46:15 localhost kernel: [    3.360854] hub 3-1:1.0: 4 ports detected
Dec  1 15:46:15 localhost kernel: [    3.455393] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Dec  1 15:46:15 localhost kernel: [    3.474762] ata1: SATA link down (SStatus 0 SControl 300)
Dec  1 15:46:15 localhost kernel: [    3.573618] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
Dec  1 15:46:15 localhost kernel: [    3.573629] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec  1 15:46:15 localhost kernel: [    3.573637] usb 4-1: Product: USB3.0 Hub
Dec  1 15:46:15 localhost kernel: [    3.573645] usb 4-1: Manufacturer: VIA Labs, Inc.
Dec  1 15:46:15 localhost kernel: [    3.600728] hub 4-1:1.0: USB hub found
Dec  1 15:46:15 localhost kernel: [    3.600904] hub 4-1:1.0: 4 ports detected
Dec  1 15:46:15 localhost kernel: [    3.786743] ata2: SATA link down (SStatus 0 SControl 300)
Dec  1 15:46:15 localhost kernel: [    4.098815] ata3: SATA link down (SStatus 0 SControl 300)
Dec  1 15:46:15 localhost kernel: [    4.176153] usb 3-1.4: new high-speed USB device number 3 using xhci-hcd
Dec  1 15:46:15 localhost kernel: [    4.410763] ata4: SATA link down (SStatus 0 SControl 300)
Dec  1 15:46:15 localhost kernel: [    4.722756] ata5: SATA link down (SStatus 0 SControl 300)
Dec  1 15:46:15 localhost kernel: [    4.725571] Freeing unused kernel memory: 4224K
Dec  1 15:46:15 localhost kernel: [    4.725735] Run /init as init process
Dec  1 15:46:15 localhost kernel: [    4.725742]   with arguments:
Dec  1 15:46:15 localhost kernel: [    4.725748]     /init
Dec  1 15:46:15 localhost kernel: [    4.725753]   with environment:
Dec  1 15:46:15 localhost cron[1343]: (CRON) INFO (pidfile fd = 3)
Dec  1 15:46:15 localhost systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Dec  1 15:46:15 localhost kernel: [    4.725758]     HOME=/
Dec  1 15:46:15 localhost kernel: [    4.725762]     TERM=linux
Dec  1 15:46:15 localhost kernel: [    4.725767]     ubootpart=92c32d3c-01
Dec  1 15:46:15 localhost kernel: [    4.725772]     cgroup_enable=memory
Dec  1 15:46:15 localhost kernel: [    4.725777]     cgroup_memory=1
Dec  1 15:46:15 localhost kernel: [    4.992340] usb 4-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
Dec  1 15:46:15 localhost kernel: [    5.013491] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
Dec  1 15:46:15 localhost kernel: [    5.013509] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Dec  1 15:46:15 localhost kernel: [    5.013520] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN
Dec  1 15:46:15 localhost kernel: [    5.013530] usb 4-1.4: Manufacturer: Realtek
Dec  1 15:46:15 localhost kernel: [    5.013539] usb 4-1.4: SerialNumber: 000000001
Dec  1 15:46:15 localhost kernel: [    5.285576] input: adc-keys as /devices/platform/adc-keys/input/input1
Dec  1 15:46:15 localhost kernel: [    5.380236] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
Dec  1 15:46:15 localhost kernel: [    5.380253] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
Dec  1 15:46:15 localhost kernel: [    5.380490] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
Dec  1 15:46:15 localhost kernel: [    5.380845] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
Dec  1 15:46:15 localhost kernel: [    5.380860] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
Dec  1 15:46:15 localhost kernel: [    5.380873] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
Dec  1 15:46:15 localhost kernel: [    5.380893] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
Dec  1 15:46:15 localhost kernel: [    5.380996] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
Dec  1 15:46:15 localhost kernel: [    5.381005] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
Dec  1 15:46:15 localhost kernel: [    5.386038] rk_gmac-dwmac fe300000.ethernet: init for RGMII
Dec  1 15:46:15 localhost kernel: [    5.386537] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
Dec  1 15:46:15 localhost kernel: [    5.386553] rk_gmac-dwmac fe300000.ethernet: 	DWMAC1000
Dec  1 15:46:15 localhost kernel: [    5.386563] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
Dec  1 15:46:15 localhost kernel: [    5.386570] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
Dec  1 15:46:15 localhost kernel: [    5.386577] rk_gmac-dwmac fe300000.ethernet: COE Type 2
Dec  1 15:46:15 localhost kernel: [    5.386584] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
Dec  1 15:46:15 localhost kernel: [    5.386591] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
Dec  1 15:46:15 localhost kernel: [    5.386717] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
Dec  1 15:46:15 localhost kernel: [    5.386726] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
Dec  1 15:46:15 localhost kernel: [    5.386733] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
Dec  1 15:46:15 localhost kernel: [    5.509939] libphy: stmmac: probed
Dec  1 15:46:15 localhost kernel: [    5.509972] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
Dec  1 15:46:15 localhost kernel: [    5.509988] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Dec  1 15:46:15 localhost kernel: [    5.736373] async_tx: api initialized (async)
Dec  1 15:46:15 localhost kernel: [    6.020614] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
Dec  1 15:46:15 localhost kernel: [    6.599767] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
Dec  1 15:46:15 localhost kernel: [    6.851849] random: systemd: uninitialized urandom read (16 bytes read)
Dec  1 15:46:15 localhost kernel: [    6.859461] random: systemd: uninitialized urandom read (16 bytes read)
Dec  1 15:46:15 localhost kernel: [    6.863200] random: systemd: uninitialized urandom read (16 bytes read)
Dec  1 15:46:15 localhost kernel: [    6.969771] lm75 2-004c: hwmon2: sensor 'lm75'
Dec  1 15:46:15 localhost kernel: [    6.990357] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
Dec  1 15:46:15 localhost kernel: [    7.605873] zram: Added device: zram0
Dec  1 15:46:15 localhost kernel: [    7.606592] zram: Added device: zram1
Dec  1 15:46:15 localhost kernel: [    7.607355] zram: Added device: zram2
Dec  1 15:46:15 localhost kernel: [    7.666915] zram1: detected capacity change from 0 to 1992228864
Dec  1 15:46:15 localhost kernel: [    7.668678] input: beeper as /devices/platform/beeper/input/input2
Dec  1 15:46:15 localhost kernel: [    7.782536] rockchip-vop ff8f0000.vop: Adding to iommu group 2
Dec  1 15:46:15 localhost kernel: [    7.786113] rockchip-vop ff900000.vop: Adding to iommu group 3
Dec  1 15:46:15 localhost kernel: [    7.802933] mc: Linux media interface: v0.10
Dec  1 15:46:15 localhost kernel: [    7.822792] videodev: Linux video capture interface: v2.00
Dec  1 15:46:15 localhost kernel: [    7.854451] panfrost ff9a0000.gpu: clock rate = 500000000
Dec  1 15:46:15 localhost kernel: [    7.855524] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
Dec  1 15:46:15 localhost kernel: [    7.855534] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
Dec  1 15:46:15 localhost kernel: [    7.855539] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
Dec  1 15:46:15 localhost kernel: [    7.855542] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
Dec  1 15:46:15 localhost kernel: [    7.856523] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
Dec  1 15:46:15 localhost kernel: [    7.871619] rockchip-rga ff680000.rga: HW Version: 0x03.02
Dec  1 15:46:15 localhost kernel: [    7.871925] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
Dec  1 15:46:15 localhost kernel: [    7.879674] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
Dec  1 15:46:15 localhost kernel: [    7.881514] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
Dec  1 15:46:15 localhost kernel: [    7.881831] rkvdec ff660000.video-codec: Adding to iommu group 1
Dec  1 15:46:15 localhost kernel: [    7.883904] hantro-vpu ff650000.video-codec: Adding to iommu group 0
Dec  1 15:46:15 localhost kernel: [    7.887323] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
Dec  1 15:46:15 localhost kernel: [    7.887464] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
Dec  1 15:46:15 localhost kernel: [    7.908327] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
Dec  1 15:46:15 localhost kernel: [    7.916238] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
Dec  1 15:46:15 localhost kernel: [    7.916314] [drm] unsupported AFBC format[3231564e]
Dec  1 15:46:15 localhost kernel: [    7.917828] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
Dec  1 15:46:15 localhost kernel: [    7.917992] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
Dec  1 15:46:15 localhost kernel: [    7.919117] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
Dec  1 15:46:15 localhost kernel: [    7.919469] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
Dec  1 15:46:15 localhost kernel: [    7.919912] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 15:46:15 localhost kernel: [    7.925071] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
Dec  1 15:46:15 localhost kernel: [    7.925802] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    7.925818] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 5
Dec  1 15:46:15 localhost kernel: [    7.925937] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
Dec  1 15:46:15 localhost kernel: [    7.925949] xhci-hcd xhci-hcd.3.auto: irq 227, io mem 0xfe800000
Dec  1 15:46:15 localhost kernel: [    7.926164] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 15:46:15 localhost kernel: [    7.926168] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 15:46:15 localhost kernel: [    7.926172] usb usb5: Product: xHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    7.926175] usb usb5: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 15:46:15 localhost kernel: [    7.926178] usb usb5: SerialNumber: xhci-hcd.3.auto
Dec  1 15:46:15 localhost kernel: [    7.926461] hub 5-0:1.0: USB hub found
Dec  1 15:46:15 localhost kernel: [    7.926480] hub 5-0:1.0: 1 port detected
Dec  1 15:46:15 localhost kernel: [    7.926654] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    7.926661] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 6
Dec  1 15:46:15 localhost kernel: [    7.926670] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
Dec  1 15:46:15 localhost kernel: [    7.926712] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
Dec  1 15:46:15 localhost kernel: [    7.926779] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
Dec  1 15:46:15 localhost kernel: [    7.926783] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 15:46:15 localhost kernel: [    7.926785] usb usb6: Product: xHCI Host Controller
Dec  1 15:46:15 localhost kernel: [    7.926788] usb usb6: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 15:46:15 localhost kernel: [    7.926791] usb usb6: SerialNumber: xhci-hcd.3.auto
Dec  1 15:46:15 localhost kernel: [    7.927047] hub 6-0:1.0: USB hub found
Dec  1 15:46:15 localhost kernel: [    7.927065] hub 6-0:1.0: 1 port detected
Dec  1 15:46:15 localhost kernel: [    8.225241] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
Dec  1 15:46:15 localhost kernel: [    8.229458] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 15:46:15 localhost kernel: [    8.360543] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
Dec  1 15:46:15 localhost kernel: [    8.376356] r8152 4-1.4:1.0 eth1: v2.13.0 (2020/04/20)
Dec  1 15:46:15 localhost kernel: [    8.376376] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents:
Dec  1 15:46:15 localhost kernel: [    8.376376] 		US6,570,884, US6,115,776, and US6,327,625.
Dec  1 15:46:15 localhost kernel: [    8.376704] usbcore: registered new interface driver r8152
Dec  1 15:46:15 localhost kernel: [    8.477353] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 15:46:15 localhost kernel: [    8.728185] Adding 1945532k swap on /dev/zram1.  Priority:5 extents:1 across:1945532k SSFS
Dec  1 15:46:15 localhost kernel: [    8.857653] zram0: detected capacity change from 0 to 52428800
Dec  1 15:46:15 localhost kernel: [    8.936340] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
Dec  1 15:46:15 localhost kernel: [    9.408731] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 15:46:15 localhost kernel: [   10.908812] zram2: detected capacity change from 0 to 1992228864
Dec  1 15:46:15 localhost kernel: [   13.014595] EXT4-fs (zram2): mounted filesystem without journal. Opts: discard
Dec  1 15:46:15 localhost kernel: [   13.101966] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
Dec  1 15:46:15 localhost kernel: [   13.102006] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
Dec  1 15:46:15 localhost kernel: [   15.867015] random: crng init done
Dec  1 15:46:15 localhost kernel: [   15.867022] random: 7 urandom warning(s) missed due to ratelimiting
Dec  1 15:46:15 localhost kernel: [   15.932556] EXT4-fs (mmcblk1p1): resizing filesystem from 436224 to 3774692 blocks
Dec  1 15:46:15 localhost kernel: [   19.714435] EXT4-fs (mmcblk1p1): resized filesystem to 3774692
Dec  1 15:46:15 localhost systemd[1]: Started System Logging Service.
Dec  1 15:46:15 localhost systemd[1]: Started rng-tools.service.
Dec  1 15:46:15 localhost cron[1343]: (CRON) INFO (Running @reboot jobs)
Dec  1 15:46:15 localhost systemd[1]: Started Resets System Activity Data Collector.
Dec  1 15:46:15 localhost dbus-daemon[1327]: [system] Successfully activated service 'org.freedesktop.systemd1'
Dec  1 15:46:15 localhost wpa_supplicant[1335]: Successfully initialized wpa_supplicant
Dec  1 15:46:15 localhost systemd[1]: Started Login Service.
Dec  1 15:46:15 localhost systemd[1]: Started WPA supplicant.
Dec  1 15:46:15 localhost CRON[1380]: (root) CMD (/usr/lib/armbian/armbian-apt-updates)
Dec  1 15:46:15 localhost fancontrol[1311]: Common settings:
Dec  1 15:46:15 localhost fancontrol[1311]:   INTERVAL=10
Dec  1 15:46:15 localhost loadcpufreq[1317]: Loading cpufreq kernel modules...done (none).
Dec  1 15:46:15 localhost systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling.
Dec  1 15:46:15 localhost systemd[1]: Starting LSB: set CPUFreq kernel parameters...
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.0232] NetworkManager (version 1.14.6) is starting... (for the first time)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.0234] Read config: /etc/NetworkManager/NetworkManager.conf (lib: no-mac-addr-change.conf) (etc: 10-override-wifi-random-mac-disable.conf, 20-override-wifi-powersave-disable.conf)
Dec  1 15:46:16 localhost cpufrequtils[1444]: CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...CPU2...CPU3...CPU4...CPU5...done.
Dec  1 15:46:16 localhost fancontrol[1311]: Settings for /dev/fan-p6/pwm1:
Dec  1 15:46:16 localhost fancontrol[1311]:   Depends on /dev/thermal-cpu/temp1_input
Dec  1 15:46:16 localhost fancontrol[1311]:   Controls
Dec  1 15:46:16 localhost fancontrol[1311]:   MINTEMP=40
Dec  1 15:46:16 localhost fancontrol[1311]:   MAXTEMP=110
Dec  1 15:46:16 localhost fancontrol[1311]:   MINSTART=60
Dec  1 15:46:16 localhost fancontrol[1311]:   MINSTOP=40
Dec  1 15:46:16 localhost fancontrol[1311]:   MINPWM=0
Dec  1 15:46:16 localhost fancontrol[1311]:   MAXPWM=255
Dec  1 15:46:16 localhost systemd[1]: Started LSB: set CPUFreq kernel parameters.
Dec  1 15:46:16 localhost systemd[1]: Starting LSB: Set sysfs variables from /etc/sysfs.conf...
Dec  1 15:46:16 localhost systemd[1]: Started Network Manager.
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.0590] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Dec  1 15:46:16 localhost systemd[1]: Reached target Network.
Dec  1 15:46:16 localhost systemd[1]: Reached target Network is Online.
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.0649] manager[0xaaaab8dde030]: monitoring kernel firmware directory '/lib/firmware'.
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.0664] monitoring ifupdown state file '/run/network/ifstate'.
Dec  1 15:46:16 localhost systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon...
Dec  1 15:46:16 localhost systemd[1]: Condition check resulted in Armbian first run optional user configuration being skipped.
Dec  1 15:46:16 localhost dbus-daemon[1327]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=1336 comm="/usr/sbin/NetworkManager --no-daemon ")
Dec  1 15:46:16 localhost systemd[1]: Started Unattended Upgrades Shutdown.
Dec  1 15:46:16 localhost systemd[1]: Starting /etc/rc.local Compatibility...
Dec  1 15:46:16 localhost systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Dec  1 15:46:16 localhost systemd[1]: Starting OpenBSD Secure Shell server...
Dec  1 15:46:16 localhost systemd[1]: Starting Permit User Sessions...
Dec  1 15:46:16 localhost systemd[1]: Starting chrony, an NTP client/server...
Dec  1 15:46:16 localhost systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon.
Dec  1 15:46:16 localhost systemd[1]: Started /etc/rc.local Compatibility.
Dec  1 15:46:16 localhost systemd[1]: Started Permit User Sessions.
Dec  1 15:46:16 localhost chronyd[1533]: chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +SECHASH +IPV6 -DEBUG)
Dec  1 15:46:16 localhost chronyd[1533]: Loaded seccomp filter
Dec  1 15:46:16 localhost fancontrol[1311]: Settings for /dev/fan-p7/pwm1:
Dec  1 15:46:16 localhost systemd[1]: Started fan speed regulator.
Dec  1 15:46:16 localhost fancontrol[1542]: Loading configuration from /etc/fancontrol ...
Dec  1 15:46:16 localhost systemd[1]: Started OpenBSD Secure Shell server.
Dec  1 15:46:16 localhost systemd[1]: Starting Hostname Service...
Dec  1 15:46:16 localhost systemd[1]: Started Getty on tty1.
Dec  1 15:46:16 localhost systemd[1]: Started Serial Getty on ttyS2.
Dec  1 15:46:16 localhost systemd[1]: Reached target Login Prompts.
Dec  1 15:46:16 localhost sysfsutils[1490]: Setting sysfs variables....
Dec  1 15:46:16 localhost systemd[1]: Starting Enable heartbeat & network activity led on Helios64...
Dec  1 15:46:16 localhost bash[1568]: heartbeat
Dec  1 15:46:16 localhost systemd[1]: Started LSB: Set sysfs variables from /etc/sysfs.conf.
Dec  1 15:46:16 localhost systemd[1]: Started chrony, an NTP client/server.
Dec  1 15:46:16 localhost bash[1574]: netdev
Dec  1 15:46:16 localhost bash[1583]: eth0
Dec  1 15:46:16 localhost bash[1589]: 1
Dec  1 15:46:16 localhost fancontrol[1542]: Common settings:
Dec  1 15:46:16 localhost fancontrol[1542]:   INTERVAL=10
Dec  1 15:46:16 localhost bash[1598]: 1
Dec  1 15:46:16 localhost bash[1606]: 1
Dec  1 15:46:16 localhost systemd[1]: helios64-heartbeat-led.service: Succeeded.
Dec  1 15:46:16 localhost systemd[1]: Started Enable heartbeat & network activity led on Helios64.
Dec  1 15:46:16 localhost dbus-daemon[1327]: [system] Successfully activated service 'org.freedesktop.hostname1'
Dec  1 15:46:16 localhost systemd[1]: Started Hostname Service.
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.4234] hostname: hostname: using hostnamed
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.4236] hostname: hostname changed from (none) to "helios64"
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.4247] dns-mgr[0xaaaab8de9910]: init: dns=default, rc-manager=file
Dec  1 15:46:16 localhost armbian-hardware-optimization[683]: /usr/lib/armbian/armbian-hardware-optimization: line 234: /proc/irq/$(awk -F":" "/eth0/ {print \$1}" </proc/interrupts | sed 's/\ //g')/smp_affinity: No such file or directory
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.4484] manager[0xaaaab8dde030]: rfkill: WiFi hardware radio set enabled
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.4486] manager[0xaaaab8dde030]: rfkill: WWAN hardware radio set enabled
Dec  1 15:46:16 localhost systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec  1 15:46:16 localhost dbus-daemon[1327]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=1336 comm="/usr/sbin/NetworkManager --no-daemon ")
Dec  1 15:46:16 localhost systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec  1 15:46:16 localhost fancontrol[1542]: Settings for /dev/fan-p6/pwm1:
Dec  1 15:46:16 localhost fancontrol[1542]:   Depends on /dev/thermal-cpu/temp1_input
Dec  1 15:46:16 localhost fancontrol[1542]:   Controls
Dec  1 15:46:16 localhost fancontrol[1542]:   MINTEMP=40
Dec  1 15:46:16 localhost fancontrol[1542]:   MAXTEMP=110
Dec  1 15:46:16 localhost fancontrol[1542]:   MINSTART=60
Dec  1 15:46:16 localhost fancontrol[1542]:   MINSTOP=40
Dec  1 15:46:16 localhost fancontrol[1542]:   MINPWM=0
Dec  1 15:46:16 localhost fancontrol[1542]:   MAXPWM=255
Dec  1 15:46:16 localhost networkd-dispatcher[1349]: WARNING: systemd-networkd is not running, output will be incomplete.
Dec  1 15:46:16 localhost systemd[1]: Started Dispatcher daemon for systemd-networkd.
Dec  1 15:46:16 localhost systemd[1]: Reached target Multi-User System.
Dec  1 15:46:16 localhost systemd[1]: Reached target Graphical Interface.
Dec  1 15:46:16 localhost systemd[1]: Condition check resulted in Hide bootsplash after starting the system being skipped.
Dec  1 15:46:16 localhost systemd[1]: Starting Update UTMP about System Runlevel Changes...
Dec  1 15:46:16 localhost dbus-daemon[1327]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec  1 15:46:16 localhost systemd[1]: Started Network Manager Script Dispatcher Service.
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5375] ifupdown:       interface-parser: parsing file /etc/network/interfaces
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5376] ifupdown:       interface-parser: source line includes interfaces file(s) /etc/network/interfaces.d/*
Dec  1 15:46:16 localhost NetworkManager[1336]: <warn>  [1606837576.5378] ifupdown: interfaces file /etc/network/interfaces.d/* doesn't exist
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5378] ifupdown:       interface-parser: finished parsing file /etc/network/interfaces
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5378] ifupdown: management mode: managed
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5379] settings: Loaded settings plugin: SettingsPluginIfupdown ("/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-settings-plugin-ifupdown.so")
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5380] settings: Loaded settings plugin: NMSKeyfilePlugin (internal)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5390] manager: rfkill: WiFi enabled by radio killswitch; enabled by state file
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5393] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5394] manager: Networking is enabled by state file
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5398] dhcp-init: Using DHCP client 'dhclient'
Dec  1 15:46:16 localhost nm-dispatcher: req:1 'hostname': new request (3 scripts)
Dec  1 15:46:16 localhost nm-dispatcher: req:1 'hostname': start running ordered scripts...
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5581] Loaded device plugin: NMWwanFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-wwan.so)
Dec  1 15:46:16 localhost systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Dec  1 15:46:16 localhost systemd[1]: Started Update UTMP about System Runlevel Changes.
Dec  1 15:46:16 localhost systemd[1]: Startup finished in 6.354s (kernel) + 14.553s (userspace) = 20.907s.
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5650] Loaded device plugin: NMTeamFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-team.so)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5667] Loaded device plugin: NMAtmManager (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-adsl.so)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5705] Loaded device plugin: NMWifiFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-wifi.so)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5770] Loaded device plugin: NMBluezManager (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-bluetooth.so)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5798] device (lo): carrier: link connected
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5806] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5821] device (eth0): driver '(null)' does not support carrier detection.
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5858] device (eth0): driver 'rk_gmac-dwmac' does not support carrier detection.
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5868] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5960] keyfile: add connection /run/NetworkManager/system-connections/Wired connection 1.nmconnection (fd1c02fb-cedd-36e5-9d48-fc7bbf910907,"Wired connection 1")
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.5986] settings: (eth0): created default wired connection 'Wired connection 1'
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.6003] device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Dec  1 15:46:16 localhost kernel: [   20.958339] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
Dec  1 15:46:16 localhost fancontrol[1542]: Settings for /dev/fan-p7/pwm1:
Dec  1 15:46:16 localhost kernel: [   20.963907] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
Dec  1 15:46:16 localhost kernel: [   20.963922] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
Dec  1 15:46:16 localhost kernel: [   20.964337] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.6152] manager: (eth1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/3)
Dec  1 15:46:16 localhost nm-dispatcher: req:2 'connectivity-change': new request (3 scripts)
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.6201] keyfile: add connection /run/NetworkManager/system-connections/Wired connection 2.nmconnection (93e5396a-8208-3148-a49c-4e3c7f742570,"Wired connection 2")
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.6210] settings: (eth1): created default wired connection 'Wired connection 2'
Dec  1 15:46:16 localhost NetworkManager[1336]: <info>  [1606837576.6221] device (eth1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Dec  1 15:46:16 localhost nmcli[1710]: ../../../gio/gdbusobjectmanagerclient.c:1589: Processing InterfaceRemoved signal for path /org/freedesktop/NetworkManager/IP4Config/2 but no object proxy exists
Dec  1 15:46:16 localhost nmcli[1710]: ../../../gio/gdbusobjectmanagerclient.c:1589: Processing InterfaceRemoved signal for path /org/freedesktop/NetworkManager/IP6Config/2 but no object proxy exists
Dec  1 15:46:16 localhost dbus-daemon[1327]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.3' (uid=0 pid=1336 comm="/usr/sbin/NetworkManager --no-daemon ")
Dec  1 15:46:16 localhost fancontrol[1542]: Enabling PWM on fans...
Dec  1 15:46:16 localhost fancontrol[1542]: Starting automatic fan control...
Dec  1 15:46:16 localhost systemd[1]: Starting Authorization Manager...
Dec  1 15:46:16 localhost polkitd[1734]: started daemon version 0.105 using authority implementation `local' version `0.105'
Dec  1 15:46:16 localhost dbus-daemon[1327]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Dec  1 15:46:16 localhost systemd[1]: Started Authorization Manager.
Dec  1 15:46:16 localhost nm-dispatcher[1661]:
Dec  1 15:46:16 localhost nm-dispatcher: req:2 'connectivity-change': start running ordered scripts...
Dec  1 15:46:20 localhost systemd[1]: Reloading.
Dec  1 15:46:20 localhost systemd[1]: /etc/systemd/system/serial-getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
Dec  1 15:46:20 localhost systemd[1]: /etc/systemd/system/getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
Dec  1 15:46:20 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7118] device (eth0): carrier: link connected
Dec  1 15:46:20 localhost kernel: [   25.064930] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Dec  1 15:46:20 localhost kernel: [   25.064963] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7129] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7160] policy: auto-activating connection 'Wired connection 1' (fd1c02fb-cedd-36e5-9d48-fc7bbf910907)
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7189] device (eth0): Activation: starting connection 'Wired connection 1' (fd1c02fb-cedd-36e5-9d48-fc7bbf910907)
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7194] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7209] manager: NetworkManager state is now CONNECTING
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7220] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7240] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7264] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Dec  1 15:46:20 localhost systemd[1]: getty@tty1.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.7349] dhcp4 (eth0): dhclient started with pid 2152
Dec  1 15:46:20 localhost systemd[1]: serial-getty@ttyS2.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Dec  1 15:46:20 localhost dhclient[2152]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
Dec  1 15:46:20 localhost dhclient[2152]: DHCPOFFER of 192.168.0.190 from 192.168.0.1
Dec  1 15:46:20 localhost dhclient[2152]: DHCPREQUEST for 192.168.0.190 on eth0 to 255.255.255.255 port 67
Dec  1 15:46:20 localhost dhclient[2152]: DHCPACK of 192.168.0.190 from 192.168.0.1
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8575] dhcp4 (eth0):   address 192.168.0.190
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8576] dhcp4 (eth0):   plen 24 (255.255.255.0)
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8577] dhcp4 (eth0):   gateway 192.168.0.1
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8578] dhcp4 (eth0):   lease time 604800
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8578] dhcp4 (eth0):   hostname 'helios64'
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8579] dhcp4 (eth0):   nameserver '192.168.0.1'
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8579] dhcp4 (eth0):   domain name 'tendawifi.com'
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8580] dhcp4 (eth0): state changed unknown -> bound
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8627] device (eth0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8662] device (eth0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8675] device (eth0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8697] manager: NetworkManager state is now CONNECTED_LOCAL
Dec  1 15:46:20 localhost dhclient[2152]: bound to 192.168.0.190 -- renewal in 252942 seconds.
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8728] manager: NetworkManager state is now CONNECTED_SITE
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8736] policy: set 'Wired connection 1' (eth0) as default for IPv4 routing and DNS
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8783] device (eth0): Activation: successful, device activated.
Dec  1 15:46:20 localhost NetworkManager[1336]: <info>  [1606837580.8814] manager: NetworkManager state is now CONNECTED_GLOBAL
Dec  1 15:46:20 localhost nm-dispatcher: req:3 'up' [eth0]: new request (3 scripts)
Dec  1 15:46:20 localhost nm-dispatcher: req:3 'up' [eth0]: start running ordered scripts...
Dec  1 15:46:20 localhost nm-dispatcher: req:4 'connectivity-change': new request (3 scripts)
Dec  1 15:46:21 localhost systemd[1]: /etc/systemd/system/serial-getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
Dec  1 15:46:21 localhost systemd[1]: /etc/systemd/system/getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
Dec  1 15:46:21 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 15:46:21 localhost systemd[1]: Reloading.
Dec  1 15:46:21 localhost nm-dispatcher[1661]: Eth0 Eth0stat 2 2
Dec  1 15:46:21 localhost nm-dispatcher: req:4 'connectivity-change': start running ordered scripts...
Dec  1 15:46:21 localhost systemd[1]: Stopping OpenBSD Secure Shell server...
Dec  1 15:46:21 localhost systemd[1]: ssh.service: Succeeded.
Dec  1 15:46:21 localhost systemd[1]: Stopped OpenBSD Secure Shell server.
Dec  1 15:46:21 localhost systemd[1]: Starting OpenBSD Secure Shell server...
Dec  1 15:46:21 localhost systemd[1]: Started OpenBSD Secure Shell server.
Dec  1 15:46:21 localhost armbian-firstrun[1313]: Removed /etc/systemd/system/multi-user.target.wants/armbian-firstrun.service.
Dec  1 15:46:22 localhost systemd[1]: /etc/systemd/system/serial-getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
Dec  1 15:46:22 localhost systemd[1]: /etc/systemd/system/getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
Dec  1 15:46:22 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 15:46:22 localhost NetworkManager[1336]: <info>  [1606837582.6388] manager: startup complete
Dec  1 15:46:23 localhost chronyd[1533]: Selected source 149.20.176.27
Dec  1 15:46:23 localhost chronyd[1533]: System clock wrong by -2.731395 seconds, adjustment started
Dec  1 15:46:23 localhost chronyd[1533]: System clock was stepped by -2.731395 seconds
Dec  1 15:46:24 localhost systemd[1]: Created slice User Slice of UID 0.
Dec  1 15:46:24 localhost systemd[1]: Starting User Runtime Directory /run/user/0...
Dec  1 15:46:24 localhost systemd[1]: Started User Runtime Directory /run/user/0.
Dec  1 15:46:24 localhost systemd[1]: Starting User Manager for UID 0...
Dec  1 15:46:24 localhost systemd[2569]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec  1 15:46:24 localhost systemd[2569]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec  1 15:46:24 localhost systemd[2569]: Listening on GnuPG network certificate management daemon.
Dec  1 15:46:24 localhost systemd[2569]: Reached target Timers.
Dec  1 15:46:24 localhost systemd[2569]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec  1 15:46:24 localhost systemd[2569]: Reached target Paths.
Dec  1 15:46:24 localhost systemd[2569]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec  1 15:46:24 localhost systemd[2569]: Reached target Sockets.
Dec  1 15:46:24 localhost systemd[2569]: Reached target Basic System.
Dec  1 15:46:24 localhost systemd[2569]: Reached target Default.
Dec  1 15:46:24 localhost systemd[2569]: Startup finished in 94ms.
Dec  1 15:46:24 localhost systemd[1]: Started User Manager for UID 0.
Dec  1 15:46:24 localhost systemd[1]: Started Session 2 of user root.
Dec  1 15:46:24 localhost systemd[1]: Started Session 3 of user root.
Dec  1 15:46:24 localhost systemd[1]: Reloading.
Dec  1 15:46:24 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 15:46:24 localhost systemd[1]: getty@tty1.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Dec  1 15:46:24 localhost systemd[1]: serial-getty@ttyS2.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Dec  1 15:46:26 localhost kernel: [   33.768316] vcc3v0_sd: disabling
Dec  1 15:46:26 localhost kernel: [   33.768333] vcc5v0_typec: disabling
Dec  1 15:46:28 localhost systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Dec  1 15:46:43 localhost systemd[1]: systemd-hostnamed.service: Succeeded.
Dec  1 15:46:50 localhost systemd[1]: getty@tty1.service: Succeeded.
Dec  1 15:46:50 localhost systemd[1]: session-3.scope: Succeeded.
Dec  1 15:46:50 localhost systemd[1]: getty@tty1.service: Service has no hold-off time (RestartSec=0), scheduling restart.
Dec  1 15:46:50 localhost systemd[1]: getty@tty1.service: Scheduled restart job, restart counter is at 1.
Dec  1 15:46:50 localhost systemd[1]: Stopped Getty on tty1.
Dec  1 15:46:51 localhost systemd[1]: Started Getty on tty1.
Dec  1 15:47:03 localhost dbus-daemon[1327]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.22' (uid=0 pid=2699 comm="timedatectl set-timezone America/Chicago ")
Dec  1 15:47:03 localhost systemd[1]: Starting Time & Date Service...
Dec  1 15:47:03 localhost dbus-daemon[1327]: [system] Successfully activated service 'org.freedesktop.timedate1'
Dec  1 15:47:03 localhost systemd[1]: Started Time & Date Service.
Dec  1 15:47:03 localhost systemd-timedated[2700]: Changed time zone to 'America/Chicago' (CDT).
Dec  1 15:47:34 localhost systemd[1]: systemd-timedated.service: Succeeded.
Dec  1 15:55:01 localhost CRON[2935]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec  1 15:55:50 localhost systemd[1]: Stopping Authorization Manager...
Dec  1 15:55:50 localhost systemd[1]: Stopped target Timers.
Dec  1 15:55:50 localhost systemd[1]: logrotate.timer: Succeeded.
Dec  1 15:55:50 localhost systemd[1]: Stopped Daily rotation of log files.
Dec  1 15:55:50 localhost systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Dec  1 15:55:50 localhost systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Dec  1 15:55:50 localhost systemd[1]: Stopped target Graphical Interface.
Dec  1 15:55:50 localhost systemd[1]: Stopped target Multi-User System.
Dec  1 15:55:50 localhost systemd[1]: sysstat.service: Succeeded.
Dec  1 09:56:27 localhost systemd-modules-load[388]: Inserted module 'lm75'
Dec  1 09:56:27 localhost systemd-modules-load[388]: Inserted module 'ledtrig_netdev'
Dec  1 09:56:27 localhost systemd-udevd[437]: Using default interface naming scheme 'v240'.
Dec  1 09:56:27 localhost systemd-udevd[437]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Dec  1 09:56:27 localhost systemd-udevd[437]: link_config: could not get ethtool features for eth0
Dec  1 09:56:27 localhost systemd-udevd[437]: Could not set offload features of eth0: Device or resource busy
Dec  1 09:56:27 localhost systemd-udevd[433]: Process '/bin/ln -sf /sys/devices/platform/ff120000.i2c/i2c-2/2-004c/hwmon/hwmon2 /dev/thermal-board' failed with exit code 1.
Dec  1 09:56:27 localhost systemd-udevd[441]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Dec  1 09:56:27 localhost systemd-udevd[466]: Process '/bin/ln -sf /sys/devices/virtual/thermal/thermal_zone0/hwmon0 /dev/thermal-cpu' failed with exit code 1.
Dec  1 09:56:27 localhost systemd-udevd[432]: Using default interface naming scheme 'v240'.
Dec  1 09:56:27 localhost systemd-udevd[432]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Dec  1 09:56:27 localhost resolvconf[405]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
Dec  1 09:56:27 localhost armbian-zram-config[454]: Setting up swapspace version 1, size = 1.9 GiB (1992224768 bytes)
Dec  1 09:56:27 localhost armbian-zram-config[454]: no label, UUID=26ec8d62-b011-4f6f-a850-f865c4ed63e4
Dec  1 09:56:27 localhost armbian-zram-config[454]: mke2fs 1.44.5 (15-Dec-2018)
Dec  1 09:56:27 localhost armbian-zram-config[454]: Discarding device blocks:  4096/12800#010#010#010#010#010#010#010#010#010#010#010           #010#010#010#010#010#010#010#010#010#010#010done
Dec  1 09:56:27 localhost armbian-zram-config[454]: Creating filesystem with 12800 4k blocks and 12800 inodes
Dec  1 09:56:27 localhost armbian-zram-config[454]: Allocating group tables: 0/1#010#010#010   #010#010#010done
Dec  1 09:56:27 localhost armbian-zram-config[454]: Writing inode tables: 0/1#010#010#010   #010#010#010done
Dec  1 09:56:27 localhost armbian-zram-config[454]: Writing superblocks and filesystem accounting information: 0/1#010#010#010   #010#010#010done
Dec  1 09:56:27 localhost armbian-ramlog[804]: Mounting /dev/zram0 as /var/log/
Dec  1 09:56:27 localhost armbian-ramlog[804]: Tue 01 Dec 2020 09:56:24 AM CST: Loading logs from storage
Dec  1 09:56:27 localhost armbian-ramlog[804]: sending incremental file list
Dec  1 09:56:27 localhost armbian-ramlog[804]: ./
Dec  1 09:56:27 localhost armbian-ramlog[804]: alternatives.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: armbian-hardware-monitor.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: auth.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: bootstrap.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: btmp
Dec  1 09:56:27 localhost armbian-ramlog[804]: daemon.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: debug
Dec  1 09:56:27 localhost armbian-ramlog[804]: dpkg.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: faillog
Dec  1 09:56:27 localhost armbian-ramlog[804]: kern.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: lastlog
Dec  1 09:56:27 localhost armbian-ramlog[804]: messages
Dec  1 09:56:27 localhost armbian-ramlog[804]: syslog
Dec  1 09:56:27 localhost armbian-ramlog[804]: user.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: wtmp
Dec  1 09:56:27 localhost armbian-ramlog[804]: apt/
Dec  1 09:56:27 localhost armbian-ramlog[804]: apt/history.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: apt/term.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: chrony/
Dec  1 09:56:27 localhost armbian-ramlog[804]: private/
Dec  1 09:56:27 localhost armbian-ramlog[804]: sysstat/
Dec  1 09:56:27 localhost armbian-ramlog[804]: unattended-upgrades/
Dec  1 09:56:27 localhost armbian-ramlog[804]: unattended-upgrades/unattended-upgrades-shutdown.log
Dec  1 09:56:27 localhost armbian-ramlog[804]: sent 1,112,202 bytes  received 389 bytes  741,727.33 bytes/sec
Dec  1 09:56:27 localhost armbian-ramlog[804]: total size is 1,110,443  speedup is 1.00
Dec  1 09:56:27 localhost systemd[1]: Starting Flush Journal to Persistent Storage...
Dec  1 09:56:27 localhost systemd[1]: Started Flush Journal to Persistent Storage.
Dec  1 09:56:27 localhost systemd[1]: Starting Create Volatile Files and Directories...
Dec  1 09:56:27 localhost systemd[1]: Started Create Volatile Files and Directories.
Dec  1 09:56:27 localhost systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
Dec  1 09:56:27 localhost systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Dec  1 09:56:27 localhost systemd[1]: Started Update UTMP about System Boot/Shutdown.
Dec  1 09:56:27 localhost systemd[1]: Reached target System Initialization.
Dec  1 09:56:27 localhost systemd[1]: Started Daily apt download activities.
Dec  1 09:56:27 localhost systemd[1]: Started Daily man-db regeneration.
Dec  1 09:56:27 localhost systemd[1]: Listening on D-Bus System Message Bus Socket.
Dec  1 09:56:27 localhost systemd[1]: Reached target Sockets.
Dec  1 09:56:27 localhost systemd[1]: Starting Armbian hardware optimization...
Dec  1 09:56:27 localhost systemd[1]: Started Daily apt upgrade and clean activities.
Dec  1 09:56:27 localhost systemd[1]: Started Daily rotation of log files.
Dec  1 09:56:27 localhost systemd[1]: Starting Armbian hardware monitoring...
Dec  1 09:56:27 localhost systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec  1 09:56:27 localhost systemd[1]: Reached target Timers.
Dec  1 09:56:27 localhost systemd[1]: Started Armbian hardware monitoring.
Dec  1 09:56:27 localhost armbian-hardware-optimization[853]: aplay: device_list:272: no soundcards found...
Dec  1 09:56:27 localhost systemd[1]: Started Armbian hardware optimization.
Dec  1 09:56:27 localhost systemd[1]: Reached target Basic System.
Dec  1 09:56:27 localhost systemd[1]: Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Dec  1 09:56:27 localhost systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Dec  1 09:56:27 localhost systemd[1]: Starting System Logging Service...
Dec  1 09:56:27 localhost systemd[1]: Starting Resets System Activity Data Collector...
Dec  1 09:56:27 localhost systemd[1]: Starting rng-tools.service...
Dec  1 09:56:27 localhost systemd[1]: Started D-Bus System Message Bus.
Dec  1 09:56:27 localhost rngd[898]: rngd 2-unofficial-mt.14 starting up...
Dec  1 09:56:27 localhost rng-tools[891]: Starting Hardware RNG entropy gatherer daemon: rngd.
Dec  1 09:56:27 localhost rngd[898]: entropy feed to the kernel ready
Dec  1 09:56:27 localhost systemd[1]: Starting Network Manager...
Dec  1 09:56:27 localhost systemd[1]: Starting WPA supplicant...
Dec  1 09:56:27 localhost armbian-hardware-optimization[853]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1
Dec  1 09:56:27 localhost systemd[1]: Started Regular background program processing daemon.
Dec  1 09:56:27 localhost systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Dec  1 09:56:27 localhost systemd[1]: Starting fan speed regulator...
Dec  1 09:56:27 localhost rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Dec  1 09:56:27 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="888" x-info="https://www.rsyslog.com"] start
Dec  1 09:56:27 localhost systemd[1]: Starting Login Service...
Dec  1 09:56:27 localhost kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Dec  1 09:56:27 localhost kernel: [    0.000000] Linux version 5.9.11-rockchip64 (root@beast) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.11.1 SMP PREEMPT Fri Nov 27 21:59:08 CET 2020
Dec  1 09:56:27 localhost kernel: [    0.000000] Machine model: Helios64
Dec  1 09:56:27 localhost kernel: [    0.000000] efi: UEFI not found.
Dec  1 09:56:27 localhost kernel: [    0.000000] cma: Reserved 128 MiB at 0x00000000ed000000
Dec  1 09:56:27 localhost kernel: [    0.000000] NUMA: No NUMA configuration found
Dec  1 09:56:27 localhost kernel: [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 09:56:27 localhost kernel: [    0.000000] NUMA: NODE_DATA [mem 0xf77d9100-0xf77dafff]
Dec  1 09:56:27 localhost kernel: [    0.000000] Zone ranges:
Dec  1 09:56:27 localhost kernel: [    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
Dec  1 09:56:27 localhost kernel: [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
Dec  1 09:56:27 localhost kernel: [    0.000000]   Normal   empty
Dec  1 09:56:27 localhost kernel: [    0.000000] Movable zone start for each node
Dec  1 09:56:27 localhost kernel: [    0.000000] Early memory node ranges
Dec  1 09:56:27 localhost kernel: [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 09:56:27 localhost kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 09:56:27 localhost kernel: [    0.000000] On node 0 totalpages: 1015296
Dec  1 09:56:27 localhost kernel: [    0.000000]   DMA zone: 4088 pages used for memmap
Dec  1 09:56:27 localhost kernel: [    0.000000]   DMA zone: 0 pages reserved
Dec  1 09:56:27 localhost kernel: [    0.000000]   DMA zone: 261632 pages, LIFO batch:63
Dec  1 09:56:27 localhost kernel: [    0.000000]   DMA32 zone: 11776 pages used for memmap
Dec  1 09:56:27 localhost kernel: [    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
Dec  1 09:56:27 localhost kernel: [    0.000000] psci: probing for conduit method from DT.
Dec  1 09:56:27 localhost kernel: [    0.000000] psci: PSCIv1.0 detected in firmware.
Dec  1 09:56:27 localhost kernel: [    0.000000] psci: Using standard PSCI v0.2 function IDs
Dec  1 09:56:27 localhost kernel: [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
Dec  1 09:56:27 localhost kernel: [    0.000000] psci: SMC Calling Convention v1.0
Dec  1 09:56:27 localhost kernel: [    0.000000] percpu: Embedded 32 pages/cpu s93784 r8192 d29096 u131072
Dec  1 09:56:27 localhost kernel: [    0.000000] pcpu-alloc: s93784 r8192 d29096 u131072 alloc=32*4096
Dec  1 09:56:27 localhost kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
Dec  1 09:56:27 localhost kernel: [    0.000000] Detected VIPT I-cache on CPU0
Dec  1 09:56:27 localhost kernel: [    0.000000] CPU features: detected: ARM erratum 845719
Dec  1 09:56:27 localhost kernel: [    0.000000] CPU features: detected: GIC system register CPU interface
Dec  1 09:56:27 localhost kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
Dec  1 09:56:27 localhost kernel: [    0.000000] Policy zone: DMA32
Dec  1 09:56:27 localhost kernel: [    0.000000] Kernel command line: root=UUID=a60f3956-17d4-4744-bc2b-021293160020 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=92c32d3c-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
Dec  1 09:56:27 localhost kernel: [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
Dec  1 09:56:27 localhost kernel: [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
Dec  1 09:56:27 localhost kernel: [    0.000000] Memory: 3741864K/4061184K available (14528K kernel code, 2096K rwdata, 5992K rodata, 4224K init, 575K bss, 188248K reserved, 131072K cma-reserved)
Dec  1 09:56:27 localhost kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Dec  1 09:56:27 localhost kernel: [    0.000000] rcu: Preemptible hierarchical RCU implementation.
Dec  1 09:56:27 localhost kernel: [    0.000000] rcu: 	RCU event tracing is enabled.
Dec  1 09:56:27 localhost kernel: [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
Dec  1 09:56:27 localhost kernel: [    0.000000] 	Trampoline variant of Tasks RCU enabled.
Dec  1 09:56:27 localhost kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
Dec  1 09:56:27 localhost kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
Dec  1 09:56:27 localhost kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Dec  1 09:56:27 localhost kernel: [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
Dec  1 09:56:27 localhost kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: 256 SPIs implemented
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: 0 Extended SPIs implemented
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: Distributor has no Range Selector support
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: 16 PPIs implemented
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
Dec  1 09:56:27 localhost kernel: [    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
Dec  1 09:56:27 localhost kernel: [    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @f6d00000 (flat, esz 8, psz 64K, shr 0)
Dec  1 09:56:27 localhost kernel: [    0.000000] ITS: using cache flushing for cmd queue
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: using LPI property table @0x00000000f6cb0000
Dec  1 09:56:27 localhost kernel: [    0.000000] GIC: using cache flushing for LPI property table
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f6cc0000
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
Dec  1 09:56:27 localhost kernel: [    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
Dec  1 09:56:27 localhost kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x690/0x848 with crng_init=0
Dec  1 09:56:27 localhost kernel: [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
Dec  1 09:56:27 localhost kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Dec  1 09:56:27 localhost kernel: [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Dec  1 09:56:27 localhost kernel: [    0.001413] Console: colour dummy device 80x25
Dec  1 09:56:27 localhost kernel: [    0.001429] printk: console [tty1] enabled
Dec  1 09:56:27 localhost kernel: [    0.001559] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
Dec  1 09:56:27 localhost kernel: [    0.001573] pid_max: default: 32768 minimum: 301
Dec  1 09:56:27 localhost kernel: [    0.001724] LSM: Security Framework initializing
Dec  1 09:56:27 localhost kernel: [    0.001769] Yama: becoming mindful.
Dec  1 09:56:27 localhost kernel: [    0.001917] AppArmor: AppArmor initialized
Dec  1 09:56:27 localhost kernel: [    0.002006] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    0.002035] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    0.005276] rcu: Hierarchical SRCU implementation.
Dec  1 09:56:27 localhost kernel: [    0.006388] Platform MSI: interrupt-controller@fee20000 domain created
Dec  1 09:56:27 localhost kernel: [    0.006907] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
Dec  1 09:56:27 localhost kernel: [    0.009348] EFI services will not be available.
Dec  1 09:56:27 localhost kernel: [    0.010014] smp: Bringing up secondary CPUs ...
Dec  1 09:56:27 localhost kernel: [    0.011039] Detected VIPT I-cache on CPU1
Dec  1 09:56:27 localhost kernel: [    0.011087] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
Dec  1 09:56:27 localhost kernel: [    0.011106] GICv3: CPU1: using allocated LPI pending table @0x00000000f6cd0000
Dec  1 09:56:27 localhost kernel: [    0.011167] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Dec  1 09:56:27 localhost kernel: [    0.012530] Detected VIPT I-cache on CPU2
Dec  1 09:56:27 localhost kernel: [    0.012577] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
Dec  1 09:56:27 localhost kernel: [    0.012596] GICv3: CPU2: using allocated LPI pending table @0x00000000f6ce0000
Dec  1 09:56:27 localhost kernel: [    0.012656] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Dec  1 09:56:27 localhost kernel: [    0.014082] Detected VIPT I-cache on CPU3
Dec  1 09:56:27 localhost kernel: [    0.014127] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
Dec  1 09:56:27 localhost kernel: [    0.014146] GICv3: CPU3: using allocated LPI pending table @0x00000000f6cf0000
Dec  1 09:56:27 localhost kernel: [    0.014206] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Dec  1 09:56:27 localhost kernel: [    0.015591] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
Dec  1 09:56:27 localhost kernel: [    0.015601] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
Dec  1 09:56:27 localhost kernel: [    0.015608] Detected PIPT I-cache on CPU4
Dec  1 09:56:27 localhost kernel: [    0.015642] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
Dec  1 09:56:27 localhost kernel: [    0.015656] GICv3: CPU4: using allocated LPI pending table @0x00000000f6d80000
Dec  1 09:56:27 localhost kernel: [    0.015693] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
Dec  1 09:56:27 localhost kernel: [    0.016886] Detected PIPT I-cache on CPU5
Dec  1 09:56:27 localhost kernel: [    0.016922] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
Dec  1 09:56:27 localhost kernel: [    0.016936] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d90000
Dec  1 09:56:27 localhost kernel: [    0.016976] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
Dec  1 09:56:27 localhost kernel: [    0.017145] smp: Brought up 1 node, 6 CPUs
Dec  1 09:56:27 localhost kernel: [    0.017155] SMP: Total of 6 processors activated.
Dec  1 09:56:27 localhost kernel: [    0.017164] CPU features: detected: 32-bit EL0 Support
Dec  1 09:56:27 localhost kernel: [    0.017173] CPU features: detected: CRC32 instructions
Dec  1 09:56:27 localhost kernel: [    0.017182] CPU features: detected: 32-bit EL1 Support
Dec  1 09:56:27 localhost kernel: [    0.045385] CPU: All CPU(s) started at EL2
Dec  1 09:56:27 localhost kernel: [    0.045450] alternatives: patching kernel code
Dec  1 09:56:27 localhost kernel: [    0.049159] devtmpfs: initialized
Dec  1 09:56:27 localhost kernel: [    0.065826] Registered cp15_barrier emulation handler
Dec  1 09:56:27 localhost kernel: [    0.065846] Registered setend emulation handler
Dec  1 09:56:27 localhost kernel: [    0.066620] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Dec  1 09:56:27 localhost kernel: [    0.066690] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    0.069814] xor: measuring software checksum speed
Dec  1 09:56:27 localhost kernel: [    0.109377]    8regs     :  2346.000 MB/sec
Dec  1 09:56:27 localhost kernel: [    0.149462]    32regs    :  2757.000 MB/sec
Dec  1 09:56:27 localhost kernel: [    0.189550]    arm64_neon:  2226.000 MB/sec
Dec  1 09:56:27 localhost kernel: [    0.189557] xor: using function: 32regs (2757.000 MB/sec)
Dec  1 09:56:27 localhost kernel: [    0.189612] pinctrl core: initialized pinctrl subsystem
Dec  1 09:56:27 localhost kernel: [    0.190277] DMI not present or invalid.
Dec  1 09:56:27 localhost kernel: [    0.190877] NET: Registered protocol family 16
Dec  1 09:56:27 localhost kernel: [    0.193645] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Dec  1 09:56:27 localhost kernel: [    0.195090] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Dec  1 09:56:27 localhost kernel: [    0.195863] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Dec  1 09:56:27 localhost kernel: [    0.195964] audit: initializing netlink subsys (disabled)
Dec  1 09:56:27 localhost kernel: [    0.196278] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
Dec  1 09:56:27 localhost kernel: [    0.197497] thermal_sys: Registered thermal governor 'fair_share'
Dec  1 09:56:27 localhost kernel: [    0.197501] thermal_sys: Registered thermal governor 'bang_bang'
Dec  1 09:56:27 localhost kernel: [    0.197508] thermal_sys: Registered thermal governor 'step_wise'
Dec  1 09:56:27 localhost kernel: [    0.197514] thermal_sys: Registered thermal governor 'user_space'
Dec  1 09:56:27 localhost kernel: [    0.198009] cpuidle: using governor menu
Dec  1 09:56:27 localhost kernel: [    0.198337] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Dec  1 09:56:27 localhost kernel: [    0.198557] ASID allocator initialised with 65536 entries
Dec  1 09:56:27 localhost kernel: [    0.199811] Serial: AMBA PL011 UART driver
Dec  1 09:56:27 localhost kernel: [    0.266946] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Dec  1 09:56:27 localhost kernel: [    0.266956] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Dec  1 09:56:27 localhost kernel: [    0.266964] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Dec  1 09:56:27 localhost kernel: [    0.266971] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Dec  1 09:56:27 localhost kernel: [    0.272533] cryptd: max_cpu_qlen set to 1000
Dec  1 09:56:27 localhost kernel: [    0.349955] raid6: neonx8   gen()  1667 MB/s
Dec  1 09:56:27 localhost kernel: [    0.418097] raid6: neonx8   xor()  1223 MB/s
Dec  1 09:56:27 localhost kernel: [    0.486256] raid6: neonx4   gen()  1684 MB/s
Dec  1 09:56:27 localhost kernel: [    0.554417] raid6: neonx4   xor()  1265 MB/s
Dec  1 09:56:27 localhost kernel: [    0.622579] raid6: neonx2   gen()  1500 MB/s
Dec  1 09:56:27 localhost kernel: [    0.690721] raid6: neonx2   xor()  1159 MB/s
Dec  1 09:56:27 localhost kernel: [    0.758872] raid6: neonx1   gen()  1183 MB/s
Dec  1 09:56:27 localhost kernel: [    0.827025] raid6: neonx1   xor()   942 MB/s
Dec  1 09:56:27 localhost kernel: [    0.895233] raid6: int64x8  gen()   993 MB/s
Dec  1 09:56:27 localhost kernel: [    0.963426] raid6: int64x8  xor()   391 MB/s
Dec  1 09:56:27 localhost kernel: [    1.031538] raid6: int64x4  gen()   986 MB/s
Dec  1 09:56:27 localhost kernel: [    1.099687] raid6: int64x4  xor()   589 MB/s
Dec  1 09:56:27 localhost kernel: [    1.167837] raid6: int64x2  gen()   927 MB/s
Dec  1 09:56:27 localhost kernel: [    1.235987] raid6: int64x2  xor()   522 MB/s
Dec  1 09:56:27 localhost kernel: [    1.304161] raid6: int64x1  gen()   722 MB/s
Dec  1 09:56:27 localhost kernel: [    1.372310] raid6: int64x1  xor()   389 MB/s
Dec  1 09:56:27 localhost kernel: [    1.372316] raid6: using algorithm neonx4 gen() 1684 MB/s
Dec  1 09:56:27 localhost kernel: [    1.372322] raid6: .... xor() 1265 MB/s, rmw enabled
Dec  1 09:56:27 localhost kernel: [    1.372328] raid6: using neon recovery algorithm
Dec  1 09:56:27 localhost kernel: [    1.373843] vcc12v_dcin_bkup: supplied by vcc12v_dcin
Dec  1 09:56:27 localhost kernel: [    1.374298] vcc12v_hdd: supplied by vcc12v_dcin_bkup
Dec  1 09:56:27 localhost kernel: [    1.389142] vcc5v0_perdev: supplied by vcc12v_dcin_bkup
Dec  1 09:56:27 localhost kernel: [    1.389660] pcie_power: supplied by vcc5v0_perdev
Dec  1 09:56:27 localhost kernel: [    1.389771] vcc5v0_usb: supplied by vcc5v0_perdev
Dec  1 09:56:27 localhost kernel: [    1.389837] vcc5v0_typec: supplied by vcc5v0_usb
Dec  1 09:56:27 localhost kernel: [    1.389895] vcc5v0_hdd: supplied by vcc12v_dcin_bkup
Dec  1 09:56:27 localhost kernel: [    1.390522] vcc5v0_sys: supplied by vcc12v_dcin_bkup
Dec  1 09:56:27 localhost kernel: [    1.391032] vcc3v3_sys_s3: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    1.391086] vcc0v9_s3: supplied by vcc3v3_sys_s3
Dec  1 09:56:27 localhost kernel: [    1.391177] avdd_1v8_s0: supplied by vcc3v3_sys_s3
Dec  1 09:56:27 localhost kernel: [    1.391249] vcc3v0_sd: supplied by vcc3v3_sys_s3
Dec  1 09:56:27 localhost kernel: [    1.392239] usblan_power: supplied by vcc5v0_usb
Dec  1 09:56:27 localhost kernel: [    1.392813] iommu: Default domain type: Translated
Dec  1 09:56:27 localhost kernel: [    1.396291] vgaarb: loaded
Dec  1 09:56:27 localhost kernel: [    1.396799] SCSI subsystem initialized
Dec  1 09:56:27 localhost kernel: [    1.397075] libata version 3.00 loaded.
Dec  1 09:56:27 localhost kernel: [    1.397348] usbcore: registered new interface driver usbfs
Dec  1 09:56:27 localhost kernel: [    1.397393] usbcore: registered new interface driver hub
Dec  1 09:56:27 localhost kernel: [    1.397491] usbcore: registered new device driver usb
Dec  1 09:56:27 localhost kernel: [    1.398197] pps_core: LinuxPPS API ver. 1 registered
Dec  1 09:56:27 localhost kernel: [    1.398204] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Dec  1 09:56:27 localhost kernel: [    1.398219] PTP clock support registered
Dec  1 09:56:27 localhost kernel: [    1.398532] EDAC MC: Ver: 3.0.0
Dec  1 09:56:27 localhost kernel: [    1.399735] NetLabel: Initializing
Dec  1 09:56:27 localhost kernel: [    1.399742] NetLabel:  domain hash size = 128
Dec  1 09:56:27 localhost kernel: [    1.399746] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Dec  1 09:56:27 localhost kernel: [    1.399827] NetLabel:  unlabeled traffic allowed by default
Dec  1 09:56:27 localhost kernel: [    1.400340] clocksource: Switched to clocksource arch_sys_counter
Dec  1 09:56:27 localhost kernel: [    1.524598] VFS: Disk quotas dquot_6.6.0
Dec  1 09:56:27 localhost kernel: [    1.524675] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec  1 09:56:27 localhost kernel: [    1.525510] AppArmor: AppArmor Filesystem Enabled
Dec  1 09:56:27 localhost kernel: [    1.534241] NET: Registered protocol family 2
Dec  1 09:56:27 localhost kernel: [    1.535111] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    1.535286] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    1.535821] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    1.536525] TCP: Hash tables configured (established 32768 bind 32768)
Dec  1 09:56:27 localhost kernel: [    1.536727] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    1.536888] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Dec  1 09:56:27 localhost kernel: [    1.537221] NET: Registered protocol family 1
Dec  1 09:56:27 localhost kernel: [    1.537252] NET: Registered protocol family 44
Dec  1 09:56:27 localhost kernel: [    1.537267] PCI: CLS 0 bytes, default 64
Dec  1 09:56:27 localhost kernel: [    1.537492] Trying to unpack rootfs image as initramfs...
Dec  1 09:56:27 localhost kernel: [    2.556286] Freeing initrd memory: 13908K
Dec  1 09:56:27 localhost kernel: [    2.557583] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
Dec  1 09:56:27 localhost kernel: [    2.558014] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Dec  1 09:56:27 localhost kernel: [    2.558703] kvm [1]: IPA Size Limit: 40bits
Dec  1 09:56:27 localhost kernel: [    2.559458] kvm [1]: vgic-v2@fff20000
Dec  1 09:56:27 localhost kernel: [    2.559493] kvm [1]: GIC system register CPU interface enabled
Dec  1 09:56:27 localhost kernel: [    2.559734] kvm [1]: vgic interrupt IRQ10
Dec  1 09:56:27 localhost kernel: [    2.560021] kvm [1]: Hyp mode initialized successfully
Dec  1 09:56:27 localhost kernel: [    2.571099] Initialise system trusted keyrings
Dec  1 09:56:27 localhost kernel: [    2.571142] Key type blacklist registered
Dec  1 09:56:27 localhost kernel: [    2.571375] workingset: timestamp_bits=44 max_order=20 bucket_order=0
Dec  1 09:56:27 localhost kernel: [    2.577606] zbud: loaded
Dec  1 09:56:27 localhost kernel: [    2.579227] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Dec  1 09:56:27 localhost kernel: [    2.580080] fuse: init (API version 7.31)
Dec  1 09:56:27 localhost kernel: [    2.581436] integrity: Platform Keyring initialized
Dec  1 09:56:27 localhost kernel: [    2.646636] Key type asymmetric registered
Dec  1 09:56:27 localhost kernel: [    2.646643] Asymmetric key parser 'x509' registered
Dec  1 09:56:27 localhost kernel: [    2.646693] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
Dec  1 09:56:27 localhost kernel: [    2.646958] io scheduler mq-deadline registered
Dec  1 09:56:27 localhost kernel: [    2.646965] io scheduler kyber registered
Dec  1 09:56:27 localhost kernel: [    2.647097] io scheduler bfq registered
Dec  1 09:56:27 localhost kernel: [    2.665511] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
Dec  1 09:56:27 localhost kernel: [    2.665538] OF: /pcie@f8000000: Missing device_type
Dec  1 09:56:27 localhost kernel: [    2.665570] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
Dec  1 09:56:27 localhost kernel: [    2.665597] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
Dec  1 09:56:27 localhost kernel: [    2.674569] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
Dec  1 09:56:27 localhost kernel: [    2.674581] dma-pl330 ff6d0000.dma-controller: 	DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
Dec  1 09:56:27 localhost kernel: [    2.676103] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
Dec  1 09:56:27 localhost kernel: [    2.676114] dma-pl330 ff6e0000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
Dec  1 09:56:27 localhost kernel: [    2.680645] vdd_log: supplied by regulator-dummy
Dec  1 09:56:27 localhost kernel: [    2.682035] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
Dec  1 09:56:27 localhost kernel: [    2.685227] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
Dec  1 09:56:27 localhost kernel: [    2.686219] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
Dec  1 09:56:27 localhost kernel: [    2.686406] printk: console [ttyS2] enabled
Dec  1 09:56:27 localhost kernel: [    2.687729] Serial: AMBA driver
Dec  1 09:56:27 localhost kernel: [    2.689339] cacheinfo: Unable to detect cache hierarchy for CPU 0
Dec  1 09:56:27 localhost kernel: [    2.701117] loop: module loaded
Dec  1 09:56:27 localhost kernel: [    2.709860] libphy: Fixed MDIO Bus: probed
Dec  1 09:56:27 localhost kernel: [    2.710201] tun: Universal TUN/TAP device driver, 1.6
Dec  1 09:56:27 localhost kernel: [    2.711274] thunder_xcv, ver 1.0
Dec  1 09:56:27 localhost kernel: [    2.711316] thunder_bgx, ver 1.0
Dec  1 09:56:27 localhost kernel: [    2.711358] nicpf, ver 1.0
Dec  1 09:56:27 localhost kernel: [    2.712586] e1000e: Intel(R) PRO/1000 Network Driver
Dec  1 09:56:27 localhost kernel: [    2.712591] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Dec  1 09:56:27 localhost kernel: [    2.712645] igb: Intel(R) Gigabit Ethernet Network Driver
Dec  1 09:56:27 localhost kernel: [    2.712650] igb: Copyright (c) 2007-2014 Intel Corporation.
Dec  1 09:56:27 localhost kernel: [    2.712695] igbvf: Intel(R) Gigabit Virtual Function Network Driver
Dec  1 09:56:27 localhost kernel: [    2.712700] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Dec  1 09:56:27 localhost kernel: [    2.713001] sky2: driver version 1.30
Dec  1 09:56:27 localhost kernel: [    2.713717] VFIO - User Level meta-driver version: 0.3
Dec  1 09:56:27 localhost kernel: [    2.732282] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec  1 09:56:27 localhost kernel: [    2.732309] ehci-pci: EHCI PCI platform driver
Dec  1 09:56:27 localhost kernel: [    2.732413] ehci-platform: EHCI generic platform driver
Dec  1 09:56:27 localhost kernel: [    2.734811] ehci-platform fe380000.usb: EHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    2.734837] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
Dec  1 09:56:27 localhost kernel: [    2.735010] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
Dec  1 09:56:27 localhost kernel: [    2.748361] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
Dec  1 09:56:27 localhost kernel: [    2.748631] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 09:56:27 localhost kernel: [    2.748641] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 09:56:27 localhost kernel: [    2.748650] usb usb1: Product: EHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    2.748657] usb usb1: Manufacturer: Linux 5.9.11-rockchip64 ehci_hcd
Dec  1 09:56:27 localhost kernel: [    2.748664] usb usb1: SerialNumber: fe380000.usb
Dec  1 09:56:27 localhost kernel: [    2.749217] hub 1-0:1.0: USB hub found
Dec  1 09:56:27 localhost kernel: [    2.749257] hub 1-0:1.0: 1 port detected
Dec  1 09:56:27 localhost kernel: [    2.750070] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec  1 09:56:27 localhost kernel: [    2.750091] ohci-pci: OHCI PCI platform driver
Dec  1 09:56:27 localhost kernel: [    2.750147] ohci-platform: OHCI generic platform driver
Dec  1 09:56:27 localhost kernel: [    2.750475] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
Dec  1 09:56:27 localhost kernel: [    2.750495] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 2
Dec  1 09:56:27 localhost kernel: [    2.750621] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
Dec  1 09:56:27 localhost kernel: [    2.812618] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
Dec  1 09:56:27 localhost kernel: [    2.812629] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 09:56:27 localhost kernel: [    2.812637] usb usb2: Product: Generic Platform OHCI controller
Dec  1 09:56:27 localhost kernel: [    2.812644] usb usb2: Manufacturer: Linux 5.9.11-rockchip64 ohci_hcd
Dec  1 09:56:27 localhost kernel: [    2.812651] usb usb2: SerialNumber: fe3a0000.usb
Dec  1 09:56:27 localhost kernel: [    2.813183] hub 2-0:1.0: USB hub found
Dec  1 09:56:27 localhost kernel: [    2.813223] hub 2-0:1.0: 1 port detected
Dec  1 09:56:27 localhost kernel: [    2.814766] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    2.814789] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
Dec  1 09:56:27 localhost kernel: [    2.814987] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
Dec  1 09:56:27 localhost kernel: [    2.815053] xhci-hcd xhci-hcd.0.auto: irq 228, io mem 0xfe900000
Dec  1 09:56:27 localhost kernel: [    2.815468] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 09:56:27 localhost kernel: [    2.815478] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 09:56:27 localhost kernel: [    2.815486] usb usb3: Product: xHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    2.815493] usb usb3: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 09:56:27 localhost kernel: [    2.815500] usb usb3: SerialNumber: xhci-hcd.0.auto
Dec  1 09:56:27 localhost kernel: [    2.816017] hub 3-0:1.0: USB hub found
Dec  1 09:56:27 localhost kernel: [    2.816057] hub 3-0:1.0: 1 port detected
Dec  1 09:56:27 localhost kernel: [    2.816438] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    2.816453] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
Dec  1 09:56:27 localhost kernel: [    2.816468] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
Dec  1 09:56:27 localhost kernel: [    2.816552] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Dec  1 09:56:27 localhost kernel: [    2.816702] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
Dec  1 09:56:27 localhost kernel: [    2.816710] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 09:56:27 localhost kernel: [    2.816718] usb usb4: Product: xHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    2.816725] usb usb4: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 09:56:27 localhost kernel: [    2.816731] usb usb4: SerialNumber: xhci-hcd.0.auto
Dec  1 09:56:27 localhost kernel: [    2.817217] hub 4-0:1.0: USB hub found
Dec  1 09:56:27 localhost kernel: [    2.817255] hub 4-0:1.0: 1 port detected
Dec  1 09:56:27 localhost kernel: [    2.817734] usbcore: registered new interface driver usb-storage
Dec  1 09:56:27 localhost kernel: [    2.820287] mousedev: PS/2 mouse device common for all mice
Dec  1 09:56:27 localhost kernel: [    2.821765] i2c /dev entries driver
Dec  1 09:56:27 localhost kernel: [    2.825781] pca953x 2-0020: using no AI
Dec  1 09:56:27 localhost kernel: [    2.835456] rk808 0-001b: chip id: 0x0
Dec  1 09:56:27 localhost kernel: [    2.839305] rk808-regulator rk808-regulator: there is no dvs0 gpio
Dec  1 09:56:27 localhost kernel: [    2.839334] rk808-regulator rk808-regulator: there is no dvs1 gpio
Dec  1 09:56:27 localhost kernel: [    2.840481] vdd_center: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.841139] vdd_cpu_l: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.841470] vcc_ddr_s3: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.842134] vcc1v8_sys_s3: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.842641] vcc1v8_dvp: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.843130] vcc3v0_touch: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.844597] vcc1v8_s3: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.844895] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
Dec  1 09:56:27 localhost kernel: [    2.846049] vcc_sdio_s0: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.846543] vcca3v0_codec: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.847731] vcc1v5_s3: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.848253] vcca1v8_codec: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.849499] vcc3v0_s3: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.849638] vcc3v3_sys_s0: failed to get the current voltage(-517)
Dec  1 09:56:27 localhost kernel: [    2.849658] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
Dec  1 09:56:27 localhost kernel: [    2.850217] vcc3v3_s0: supplied by vcc3v3_sys_s3
Dec  1 09:56:27 localhost kernel: [    2.853868] rk808-rtc rk808-rtc: registered as rtc0
Dec  1 09:56:27 localhost kernel: [    2.854435] rk808-rtc rk808-rtc: setting system clock to 2020-12-01T15:56:16 UTC (1606838176)
Dec  1 09:56:27 localhost kernel: [    2.857568] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
Dec  1 09:56:27 localhost kernel: [    2.858668] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
Dec  1 09:56:27 localhost kernel: [    2.858788] avdd_0v9_s0: supplied by vcc1v8_sys_s3
Dec  1 09:56:27 localhost kernel: [    2.858892] vdd_cpu_b: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.861977] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
Dec  1 09:56:27 localhost kernel: [    2.863104] vdd_gpu: supplied by vcc5v0_sys
Dec  1 09:56:27 localhost kernel: [    2.872484] dw_wdt ff848000.watchdog: No valid TOPs array specified
Dec  1 09:56:27 localhost kernel: [    2.874440] sdhci: Secure Digital Host Controller Interface driver
Dec  1 09:56:27 localhost kernel: [    2.874447] sdhci: Copyright(c) Pierre Ossman
Dec  1 09:56:27 localhost kernel: [    2.874472] Synopsys Designware Multimedia Card Interface Driver
Dec  1 09:56:27 localhost kernel: [    2.876183] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
Dec  1 09:56:27 localhost kernel: [    2.876214] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
Dec  1 09:56:27 localhost kernel: [    2.876230] dwmmc_rockchip fe320000.mmc: Version ID is 270a
Dec  1 09:56:27 localhost kernel: [    2.876291] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
Dec  1 09:56:27 localhost kernel: [    2.876878] dwmmc_rockchip fe320000.mmc: Got CD GPIO
Dec  1 09:56:27 localhost kernel: [    2.888489] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Dec  1 09:56:27 localhost kernel: [    2.902099] sdhci-pltfm: SDHCI platform and OF driver helper
Dec  1 09:56:27 localhost kernel: [    2.903888] mmc1: CQHCI version 5.10
Dec  1 09:56:27 localhost kernel: [    2.929154] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
Dec  1 09:56:27 localhost kernel: [    2.933385] ledtrig-cpu: registered to indicate activity on CPUs
Dec  1 09:56:27 localhost kernel: [    2.934622] hid: raw HID events driver (C) Jiri Kosina
Dec  1 09:56:27 localhost kernel: [    2.934767] usbcore: registered new interface driver usbhid
Dec  1 09:56:27 localhost kernel: [    2.934772] usbhid: USB HID core driver
Dec  1 09:56:27 localhost kernel: [    2.939563] random: fast init done
Dec  1 09:56:27 localhost kernel: [    2.940905] drop_monitor: Initializing network drop monitor service
Dec  1 09:56:27 localhost kernel: [    2.941839] NET: Registered protocol family 10
Dec  1 09:56:27 localhost kernel: [    2.997301] Segment Routing with IPv6
Dec  1 09:56:27 localhost kernel: [    2.997402] NET: Registered protocol family 17
Dec  1 09:56:27 localhost kernel: [    2.997650] 8021q: 802.1Q VLAN Support v1.8
Dec  1 09:56:27 localhost kernel: [    2.997716] Key type dns_resolver registered
Dec  1 09:56:27 localhost kernel: [    2.998478] registered taskstats version 1
Dec  1 09:56:27 localhost kernel: [    2.998520] Loading compiled-in X.509 certificates
Dec  1 09:56:27 localhost cron[911]: (CRON) INFO (pidfile fd = 3)
Dec  1 09:56:27 localhost systemd[1]: Started System Logging Service.
Dec  1 09:56:27 localhost kernel: [    3.004515] Loaded X.509 cert 'Build time autogenerated kernel key: cf582b85d37ac5e7e16062bd2222df75b99b261f'
Dec  1 09:56:27 localhost kernel: [    3.004798] zswap: loaded using pool lzo/zbud
Dec  1 09:56:27 localhost kernel: [    3.005383] Key type ._fscrypt registered
Dec  1 09:56:27 localhost kernel: [    3.005390] Key type .fscrypt registered
Dec  1 09:56:27 localhost kernel: [    3.005396] Key type fscrypt-provisioning registered
Dec  1 09:56:27 localhost kernel: [    3.006598] mmc1: Command Queue Engine enabled
Dec  1 09:56:27 localhost kernel: [    3.006620] mmc1: new HS200 MMC card at address 0001
Dec  1 09:56:27 localhost kernel: [    3.007438] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
Dec  1 09:56:27 localhost kernel: [    3.007717] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
Dec  1 09:56:27 localhost kernel: [    3.007948] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
Dec  1 09:56:27 localhost kernel: [    3.008117] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB, chardev (243:0)
Dec  1 09:56:27 localhost kernel: [    3.008752] Btrfs loaded, crc32c=crc32c-generic
Dec  1 09:56:27 localhost kernel: [    3.009380]  mmcblk1: p1
Dec  1 09:56:27 localhost kernel: [    3.035272] Key type encrypted registered
Dec  1 09:56:27 localhost kernel: [    3.035300] AppArmor: AppArmor sha1 policy hashing enabled
Dec  1 09:56:27 localhost kernel: [    3.097824] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
Dec  1 09:56:27 localhost kernel: [    3.097875] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
Dec  1 09:56:27 localhost kernel: [    3.097898] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
Dec  1 09:56:27 localhost kernel: [    3.148368] usb 3-1: new high-speed USB device number 2 using xhci-hcd
Dec  1 09:56:27 localhost kernel: [    3.153613] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
Dec  1 09:56:27 localhost kernel: [    3.153625] pci_bus 0000:00: root bus resource [bus 00-1f]
Dec  1 09:56:27 localhost kernel: [    3.153635] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
Dec  1 09:56:27 localhost kernel: [    3.153646] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
Dec  1 09:56:27 localhost kernel: [    3.153701] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
Dec  1 09:56:27 localhost kernel: [    3.153849] pci 0000:00:00.0: supports D1
Dec  1 09:56:27 localhost kernel: [    3.153857] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Dec  1 09:56:27 localhost kernel: [    3.159338] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Dec  1 09:56:27 localhost kernel: [    3.159585] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
Dec  1 09:56:27 localhost kernel: [    3.159654] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
Dec  1 09:56:27 localhost kernel: [    3.159663] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.159698] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
Dec  1 09:56:27 localhost kernel: [    3.159706] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.159740] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
Dec  1 09:56:27 localhost kernel: [    3.159747] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.159781] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
Dec  1 09:56:27 localhost kernel: [    3.159788] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.159821] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
Dec  1 09:56:27 localhost kernel: [    3.159828] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.159863] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
Dec  1 09:56:27 localhost kernel: [    3.159899] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Dec  1 09:56:27 localhost kernel: [    3.159937] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
Dec  1 09:56:27 localhost kernel: [    3.160263] pci 0000:01:00.0: PME# supported from D3hot
Dec  1 09:56:27 localhost kernel: [    3.160528] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
Dec  1 09:56:27 localhost kernel: [    3.165861] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
Dec  1 09:56:27 localhost kernel: [    3.165892] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
Dec  1 09:56:27 localhost kernel: [    3.165908] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
Dec  1 09:56:27 localhost kernel: [    3.165917] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
Dec  1 09:56:27 localhost kernel: [    3.165937] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.165945] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.165952] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.165959] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.165966] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.165973] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.165980] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.165987] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.165995] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.166002] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
Dec  1 09:56:27 localhost kernel: [    3.166011] pci 0000:00:00.0: PCI bridge to [bus 01]
Dec  1 09:56:27 localhost kernel: [    3.166024] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
Dec  1 09:56:27 localhost kernel: [    3.166265] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
Dec  1 09:56:27 localhost kernel: [    3.166578] pcieport 0000:00:00.0: PME: Signaling with IRQ 239
Dec  1 09:56:27 localhost kernel: [    3.166902] pcieport 0000:00:00.0: AER: enabled with IRQ 239
Dec  1 09:56:27 localhost kernel: [    3.167237] ahci 0000:01:00.0: version 3.0
Dec  1 09:56:27 localhost kernel: [    3.167261] ahci 0000:01:00.0: enabling device (0000 -> 0002)
Dec  1 09:56:27 localhost kernel: [    3.167845] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
Dec  1 09:56:27 localhost kernel: [    3.167946] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
Dec  1 09:56:27 localhost kernel: [    3.167958] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
Dec  1 09:56:27 localhost kernel: [    3.171731] scsi host0: ahci
Dec  1 09:56:27 localhost kernel: [    3.172443] scsi host1: ahci
Dec  1 09:56:27 localhost kernel: [    3.173057] scsi host2: ahci
Dec  1 09:56:27 localhost kernel: [    3.173641] scsi host3: ahci
Dec  1 09:56:27 localhost kernel: [    3.174244] scsi host4: ahci
Dec  1 09:56:27 localhost kernel: [    3.174461] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 240
Dec  1 09:56:27 localhost kernel: [    3.174471] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 241
Dec  1 09:56:27 localhost kernel: [    3.174480] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 242
Dec  1 09:56:27 localhost kernel: [    3.174488] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 243
Dec  1 09:56:27 localhost kernel: [    3.174495] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 244
Dec  1 09:56:27 localhost kernel: [    3.180802] input: gpio-keys as /devices/platform/gpio-keys/input/input0
Dec  1 09:56:27 localhost kernel: [    3.181555] of_cfs_init
Dec  1 09:56:27 localhost kernel: [    3.181613] of_cfs_init: OK
Dec  1 09:56:27 localhost kernel: [    3.298328] usb 3-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
Dec  1 09:56:27 localhost kernel: [    3.298340] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec  1 09:56:27 localhost kernel: [    3.298348] usb 3-1: Product: USB2.0 Hub
Dec  1 09:56:27 localhost kernel: [    3.298355] usb 3-1: Manufacturer: VIA Labs, Inc.
Dec  1 09:56:27 localhost kernel: [    3.360932] hub 3-1:1.0: USB hub found
Dec  1 09:56:27 localhost kernel: [    3.361083] hub 3-1:1.0: 4 ports detected
Dec  1 09:56:27 localhost kernel: [    3.424604] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Dec  1 09:56:27 localhost kernel: [    3.486987] ata1: SATA link down (SStatus 0 SControl 300)
Dec  1 09:56:27 localhost kernel: [    3.575533] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
Dec  1 09:56:27 localhost kernel: [    3.575545] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec  1 09:56:27 localhost kernel: [    3.575553] usb 4-1: Product: USB3.0 Hub
Dec  1 09:56:27 localhost kernel: [    3.575560] usb 4-1: Manufacturer: VIA Labs, Inc.
Dec  1 09:56:27 localhost kernel: [    3.600807] hub 4-1:1.0: USB hub found
Dec  1 09:56:27 localhost kernel: [    3.600996] hub 4-1:1.0: 4 ports detected
Dec  1 09:56:27 localhost kernel: [    3.798814] ata2: SATA link down (SStatus 0 SControl 300)
Dec  1 09:56:27 localhost kernel: [    4.110832] ata3: SATA link down (SStatus 0 SControl 300)
Dec  1 09:56:27 localhost kernel: [    4.176365] usb 3-1.4: new high-speed USB device number 3 using xhci-hcd
Dec  1 09:56:27 localhost kernel: [    4.422814] ata4: SATA link down (SStatus 0 SControl 300)
Dec  1 09:56:27 localhost kernel: [    4.734803] ata5: SATA link down (SStatus 0 SControl 300)
Dec  1 09:56:27 localhost kernel: [    4.737616] Freeing unused kernel memory: 4224K
Dec  1 09:56:27 localhost kernel: [    4.737780] Run /init as init process
Dec  1 09:56:27 localhost kernel: [    4.737787]   with arguments:
Dec  1 09:56:27 localhost kernel: [    4.737793]     /init
Dec  1 09:56:27 localhost kernel: [    4.737798]   with environment:
Dec  1 09:56:27 localhost kernel: [    4.737803]     HOME=/
Dec  1 09:56:27 localhost kernel: [    4.737808]     TERM=linux
Dec  1 09:56:27 localhost kernel: [    4.737813]     ubootpart=92c32d3c-01
Dec  1 09:56:27 localhost kernel: [    4.737818]     cgroup_enable=memory
Dec  1 09:56:27 localhost kernel: [    4.737823]     cgroup_memory=1
Dec  1 09:56:27 localhost kernel: [    4.988617] usb 4-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
Dec  1 09:56:27 localhost kernel: [    5.009731] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
Dec  1 09:56:27 localhost kernel: [    5.009749] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Dec  1 09:56:27 localhost kernel: [    5.009760] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN
Dec  1 09:56:27 localhost kernel: [    5.009770] usb 4-1.4: Manufacturer: Realtek
Dec  1 09:56:27 localhost kernel: [    5.009780] usb 4-1.4: SerialNumber: 000000001
Dec  1 09:56:27 localhost kernel: [    5.297493] input: adc-keys as /devices/platform/adc-keys/input/input1
Dec  1 09:56:27 localhost kernel: [    5.381623] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
Dec  1 09:56:27 localhost kernel: [    5.381636] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
Dec  1 09:56:27 localhost kernel: [    5.381790] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
Dec  1 09:56:27 localhost kernel: [    5.382049] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
Dec  1 09:56:27 localhost kernel: [    5.382060] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
Dec  1 09:56:27 localhost kernel: [    5.382071] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
Dec  1 09:56:27 localhost kernel: [    5.382086] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
Dec  1 09:56:27 localhost kernel: [    5.382167] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
Dec  1 09:56:27 localhost kernel: [    5.382174] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
Dec  1 09:56:27 localhost kernel: [    5.387195] rk_gmac-dwmac fe300000.ethernet: init for RGMII
Dec  1 09:56:27 localhost kernel: [    5.390518] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
Dec  1 09:56:27 localhost kernel: [    5.390532] rk_gmac-dwmac fe300000.ethernet: 	DWMAC1000
Dec  1 09:56:27 localhost kernel: [    5.390541] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
Dec  1 09:56:27 localhost kernel: [    5.390548] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
Dec  1 09:56:27 localhost kernel: [    5.390555] rk_gmac-dwmac fe300000.ethernet: COE Type 2
Dec  1 09:56:27 localhost kernel: [    5.390562] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
Dec  1 09:56:27 localhost kernel: [    5.390569] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
Dec  1 09:56:27 localhost kernel: [    5.390671] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
Dec  1 09:56:27 localhost kernel: [    5.390678] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
Dec  1 09:56:27 localhost kernel: [    5.390686] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
Dec  1 09:56:27 localhost kernel: [    5.530506] libphy: stmmac: probed
Dec  1 09:56:27 localhost kernel: [    5.530536] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
Dec  1 09:56:27 localhost kernel: [    5.530554] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Dec  1 09:56:27 localhost kernel: [    5.715512] async_tx: api initialized (async)
Dec  1 09:56:27 localhost kernel: [    6.003990] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
Dec  1 09:56:27 localhost kernel: [    6.532579] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
Dec  1 09:56:27 localhost kernel: [    6.851463] random: systemd: uninitialized urandom read (16 bytes read)
Dec  1 09:56:27 localhost kernel: [    6.859544] random: systemd: uninitialized urandom read (16 bytes read)
Dec  1 09:56:27 localhost kernel: [    6.860759] random: systemd: uninitialized urandom read (16 bytes read)
Dec  1 09:56:27 localhost kernel: [    6.943038] lm75 2-004c: hwmon2: sensor 'lm75'
Dec  1 09:56:27 localhost kernel: [    6.971901] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
Dec  1 09:56:27 localhost kernel: [    7.637944] zram: Added device: zram0
Dec  1 09:56:27 localhost kernel: [    7.638721] zram: Added device: zram1
Dec  1 09:56:27 localhost kernel: [    7.639363] zram: Added device: zram2
Dec  1 09:56:27 localhost kernel: [    7.706553] zram1: detected capacity change from 0 to 1992228864
Dec  1 09:56:27 localhost kernel: [    7.725086] input: beeper as /devices/platform/beeper/input/input2
Dec  1 09:56:27 localhost kernel: [    7.850084] rockchip-vop ff8f0000.vop: Adding to iommu group 2
Dec  1 09:56:27 localhost kernel: [    7.866807] mc: Linux media interface: v0.10
Dec  1 09:56:27 localhost kernel: [    7.884655] rockchip-vop ff900000.vop: Adding to iommu group 3
Dec  1 09:56:27 localhost kernel: [    7.901229] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
Dec  1 09:56:27 localhost kernel: [    7.911418] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
Dec  1 09:56:27 localhost kernel: [    7.911506] [drm] unsupported AFBC format[3231564e]
Dec  1 09:56:27 localhost kernel: [    7.913064] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
Dec  1 09:56:27 localhost kernel: [    7.913269] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
Dec  1 09:56:27 localhost kernel: [    7.915207] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 09:56:27 localhost kernel: [    7.920623] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
Dec  1 09:56:27 localhost kernel: [    7.920991] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
Dec  1 09:56:27 localhost kernel: [    7.926354] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
Dec  1 09:56:27 localhost kernel: [    7.929895] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    7.929916] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 5
Dec  1 09:56:27 localhost kernel: [    7.930048] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
Dec  1 09:56:27 localhost kernel: [    7.930063] xhci-hcd xhci-hcd.3.auto: irq 227, io mem 0xfe800000
Dec  1 09:56:27 localhost kernel: [    7.930294] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 09:56:27 localhost kernel: [    7.930298] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 09:56:27 localhost kernel: [    7.930301] usb usb5: Product: xHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    7.930303] usb usb5: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 09:56:27 localhost kernel: [    7.930306] usb usb5: SerialNumber: xhci-hcd.3.auto
Dec  1 09:56:27 localhost kernel: [    7.930695] hub 5-0:1.0: USB hub found
Dec  1 09:56:27 localhost kernel: [    7.930714] hub 5-0:1.0: 1 port detected
Dec  1 09:56:27 localhost kernel: [    7.930890] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    7.930899] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 6
Dec  1 09:56:27 localhost kernel: [    7.930908] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
Dec  1 09:56:27 localhost kernel: [    7.930949] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
Dec  1 09:56:27 localhost kernel: [    7.931009] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
Dec  1 09:56:27 localhost kernel: [    7.931012] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 09:56:27 localhost kernel: [    7.931015] usb usb6: Product: xHCI Host Controller
Dec  1 09:56:27 localhost kernel: [    7.931017] usb usb6: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 09:56:27 localhost kernel: [    7.931020] usb usb6: SerialNumber: xhci-hcd.3.auto
Dec  1 09:56:27 localhost kernel: [    7.931296] hub 6-0:1.0: USB hub found
Dec  1 09:56:27 localhost kernel: [    7.931312] hub 6-0:1.0: 1 port detected
Dec  1 09:56:27 localhost kernel: [    7.940180] videodev: Linux video capture interface: v2.00
Dec  1 09:56:27 localhost kernel: [    8.022525] panfrost ff9a0000.gpu: clock rate = 500000000
Dec  1 09:56:27 localhost kernel: [    8.041576] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
Dec  1 09:56:27 localhost kernel: [    8.041586] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
Dec  1 09:56:27 localhost kernel: [    8.041592] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
Dec  1 09:56:27 localhost kernel: [    8.041597] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
Dec  1 09:56:27 localhost kernel: [    8.045475] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
Dec  1 09:56:27 localhost kernel: [    8.055070] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
Dec  1 09:56:27 localhost kernel: [    8.057387] hantro-vpu ff650000.video-codec: Adding to iommu group 0
Dec  1 09:56:27 localhost kernel: [    8.058358] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video0
Dec  1 09:56:27 localhost kernel: [    8.058619] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video1
Dec  1 09:56:27 localhost kernel: [    8.076971] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
Dec  1 09:56:27 localhost kernel: [    8.079849] rockchip-rga ff680000.rga: HW Version: 0x03.02
Dec  1 09:56:27 localhost kernel: [    8.080084] rkvdec ff660000.video-codec: Adding to iommu group 1
Dec  1 09:56:27 localhost kernel: [    8.080485] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video2
Dec  1 09:56:27 localhost kernel: [    8.224972] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 09:56:27 localhost kernel: [    8.321362] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
Dec  1 09:56:27 localhost kernel: [    8.464918] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
Dec  1 09:56:27 localhost kernel: [    8.473369] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 09:56:27 localhost kernel: [    8.480617] r8152 4-1.4:1.0 eth1: v2.13.0 (2020/04/20)
Dec  1 09:56:27 localhost kernel: [    8.480633] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents:
Dec  1 09:56:27 localhost kernel: [    8.480633] 		US6,570,884, US6,115,776, and US6,327,625.
Dec  1 09:56:27 localhost kernel: [    8.480895] usbcore: registered new interface driver r8152
Dec  1 09:56:27 localhost kernel: [    8.760394] Adding 1945532k swap on /dev/zram1.  Priority:5 extents:1 across:1945532k SSFS
Dec  1 09:56:27 localhost kernel: [    8.886931] zram0: detected capacity change from 0 to 52428800
Dec  1 09:56:27 localhost kernel: [    9.376874] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 09:56:27 localhost kernel: [   11.007291] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
Dec  1 09:56:27 localhost kernel: [   11.007327] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
Dec  1 09:56:27 localhost kernel: [   13.446211] random: crng init done
Dec  1 09:56:27 localhost kernel: [   13.446221] random: 7 urandom warning(s) missed due to ratelimiting
Dec  1 09:56:27 localhost systemd[1]: Started Resets System Activity Data Collector.
Dec  1 09:56:27 localhost systemd[1]: Started rng-tools.service.
Dec  1 09:56:27 localhost fancontrol[912]: Loading configuration from /etc/fancontrol ...
Dec  1 09:56:27 localhost cron[911]: (CRON) INFO (Running @reboot jobs)
Dec  1 09:56:27 localhost armbian-hardware-optimization[853]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1boot0
Dec  1 09:56:27 localhost armbian-hardware-optimization[853]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1boot1
Dec  1 09:56:27 localhost systemd[1]: Started WPA supplicant.
Dec  1 09:56:27 localhost wpa_supplicant[905]: Successfully initialized wpa_supplicant
Dec  1 09:56:27 localhost CRON[954]: (root) CMD (/usr/lib/armbian/armbian-apt-updates)
Dec  1 09:56:27 localhost systemd[1]: Started Login Service.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.3820] NetworkManager (version 1.14.6) is starting... (for the first time)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.3822] Read config: /etc/NetworkManager/NetworkManager.conf (lib: no-mac-addr-change.conf) (etc: 10-override-wifi-random-mac-disable.conf, 20-override-wifi-powersave-disable.conf)
Dec  1 09:56:27 localhost fancontrol[912]: Common settings:
Dec  1 09:56:27 localhost fancontrol[912]:   INTERVAL=10
Dec  1 09:56:27 localhost loadcpufreq[880]: Loading cpufreq kernel modules...done (none).
Dec  1 09:56:27 localhost systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling.
Dec  1 09:56:27 localhost systemd[1]: Starting LSB: set CPUFreq kernel parameters...
Dec  1 09:56:27 localhost systemd[1]: Started Network Manager.
Dec  1 09:56:27 localhost systemd[1]: Reached target Network.
Dec  1 09:56:27 localhost systemd[1]: Starting Permit User Sessions...
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.4305] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Dec  1 09:56:27 localhost systemd[1]: Starting chrony, an NTP client/server...
Dec  1 09:56:27 localhost systemd[1]: Reached target Network is Online.
Dec  1 09:56:27 localhost systemd[1]: Starting /etc/rc.local Compatibility...
Dec  1 09:56:27 localhost systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon...
Dec  1 09:56:27 localhost systemd[1]: Condition check resulted in Armbian first run optional user configuration being skipped.
Dec  1 09:56:27 localhost systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Dec  1 09:56:27 localhost chronyd[1081]: chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +SECHASH +IPV6 -DEBUG)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.4582] manager[0xaaaaf5e5f030]: monitoring kernel firmware directory '/lib/firmware'.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.4584] monitoring ifupdown state file '/run/network/ifstate'.
Dec  1 09:56:27 localhost dbus-daemon[896]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=904 comm="/usr/sbin/NetworkManager --no-daemon ")
Dec  1 09:56:27 localhost chronyd[1081]: Frequency -31.576 +/- 7.310 ppm read from /var/lib/chrony/chrony.drift
Dec  1 09:56:27 localhost systemd[1]: Starting OpenBSD Secure Shell server...
Dec  1 09:56:27 localhost chronyd[1081]: Loaded seccomp filter
Dec  1 09:56:27 localhost systemd[1]: Started Unattended Upgrades Shutdown.
Dec  1 09:56:27 localhost systemd[1]: Started Permit User Sessions.
Dec  1 09:56:27 localhost systemd[1]: Started /etc/rc.local Compatibility.
Dec  1 09:56:27 localhost systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon.
Dec  1 09:56:27 localhost systemd[1]: Starting Hostname Service...
Dec  1 09:56:27 localhost systemd[1]: Started Getty on tty1.
Dec  1 09:56:27 localhost systemd[1]: Started Serial Getty on ttyS2.
Dec  1 09:56:27 localhost systemd[1]: Reached target Login Prompts.
Dec  1 09:56:27 localhost systemd[1]: Starting Enable heartbeat & network activity led on Helios64...
Dec  1 09:56:27 localhost systemd[1]: Started chrony, an NTP client/server.
Dec  1 09:56:27 localhost bash[1128]: heartbeat
Dec  1 09:56:27 localhost haveged[851]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 8.3.0 CTV); collect: 128K
Dec  1 09:56:27 localhost haveged[851]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 15528/64688
Dec  1 09:56:27 localhost haveged[851]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.00272
Dec  1 09:56:27 localhost haveged[851]: haveged: fills: 0, generated: 0
Dec  1 09:56:27 localhost bash[1145]: netdev
Dec  1 09:56:27 localhost systemd[1]: Started OpenBSD Secure Shell server.
Dec  1 09:56:27 localhost cpufrequtils[1056]: CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...CPU2...CPU3...CPU4...CPU5...done.
Dec  1 09:56:27 localhost systemd[1]: Started LSB: set CPUFreq kernel parameters.
Dec  1 09:56:27 localhost systemd[1]: Starting LSB: Set sysfs variables from /etc/sysfs.conf...
Dec  1 09:56:27 localhost bash[1168]: eth0
Dec  1 09:56:27 localhost fancontrol[912]: Settings for /dev/fan-p6/pwm1:
Dec  1 09:56:27 localhost fancontrol[912]:   Depends on /dev/thermal-cpu/temp1_input
Dec  1 09:56:27 localhost fancontrol[912]:   Controls
Dec  1 09:56:27 localhost fancontrol[912]:   MINTEMP=40
Dec  1 09:56:27 localhost fancontrol[912]:   MAXTEMP=110
Dec  1 09:56:27 localhost fancontrol[912]:   MINSTART=60
Dec  1 09:56:27 localhost fancontrol[912]:   MINSTOP=40
Dec  1 09:56:27 localhost fancontrol[912]:   MINPWM=0
Dec  1 09:56:27 localhost fancontrol[912]:   MAXPWM=255
Dec  1 09:56:27 localhost bash[1178]: 1
Dec  1 09:56:27 localhost bash[1193]: 1
Dec  1 09:56:27 localhost dbus-daemon[896]: [system] Successfully activated service 'org.freedesktop.hostname1'
Dec  1 09:56:27 localhost systemd[1]: Started Hostname Service.
Dec  1 09:56:27 localhost bash[1210]: 1
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.7009] hostname: hostname: using hostnamed
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.7011] hostname: hostname changed from (none) to "helios64"
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.7024] dns-mgr[0xaaaaf5e6d130]: init: dns=default, rc-manager=file
Dec  1 09:56:27 localhost systemd[1]: helios64-heartbeat-led.service: Succeeded.
Dec  1 09:56:27 localhost systemd[1]: Started Enable heartbeat & network activity led on Helios64.
Dec  1 09:56:27 localhost sysfsutils[1169]: Setting sysfs variables....
Dec  1 09:56:27 localhost systemd[1]: Started LSB: Set sysfs variables from /etc/sysfs.conf.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.7260] manager[0xaaaaf5e5f030]: rfkill: WiFi hardware radio set enabled
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.7262] manager[0xaaaaf5e5f030]: rfkill: WWAN hardware radio set enabled
Dec  1 09:56:27 localhost dbus-daemon[896]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=904 comm="/usr/sbin/NetworkManager --no-daemon ")
Dec  1 09:56:27 localhost systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec  1 09:56:27 localhost systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec  1 09:56:27 localhost fancontrol[912]: Settings for /dev/fan-p7/pwm1:
Dec  1 09:56:27 localhost systemd[1]: Started fan speed regulator.
Dec  1 09:56:27 localhost fancontrol[1265]: Loading configuration from /etc/fancontrol ...
Dec  1 09:56:27 localhost dbus-daemon[896]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec  1 09:56:27 localhost systemd[1]: Started Network Manager Script Dispatcher Service.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8217] ifupdown:       interface-parser: parsing file /etc/network/interfaces
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8218] ifupdown:       interface-parser: source line includes interfaces file(s) /etc/network/interfaces.d/*
Dec  1 09:56:27 localhost NetworkManager[904]: <warn>  [1606838187.8221] ifupdown: interfaces file /etc/network/interfaces.d/* doesn't exist
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8221] ifupdown:       interface-parser: finished parsing file /etc/network/interfaces
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8222] ifupdown: management mode: managed
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8222] settings: Loaded settings plugin: SettingsPluginIfupdown ("/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-settings-plugin-ifupdown.so")
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8223] settings: Loaded settings plugin: NMSKeyfilePlugin (internal)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8239] manager: rfkill: WiFi enabled by radio killswitch; enabled by state file
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8244] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8248] manager: Networking is enabled by state file
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8255] dhcp-init: Using DHCP client 'dhclient'
Dec  1 09:56:27 localhost nm-dispatcher: req:1 'hostname': new request (3 scripts)
Dec  1 09:56:27 localhost nm-dispatcher: req:1 'hostname': start running ordered scripts...
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8437] Loaded device plugin: NMWwanFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-wwan.so)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8544] Loaded device plugin: NMTeamFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-team.so)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8580] Loaded device plugin: NMAtmManager (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-adsl.so)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8631] Loaded device plugin: NMWifiFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-wifi.so)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8702] Loaded device plugin: NMBluezManager (/usr/lib/aarch64-linux-gnu/NetworkManager/1.14.6/libnm-device-plugin-bluetooth.so)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8757] device (lo): carrier: link connected
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8783] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8810] device (eth0): driver '(null)' does not support carrier detection.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8827] device (eth0): driver 'rk_gmac-dwmac' does not support carrier detection.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.8849] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Dec  1 09:56:27 localhost networkd-dispatcher[884]: WARNING: systemd-networkd is not running, output will be incomplete.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.9029] keyfile: add connection /run/NetworkManager/system-connections/Wired connection 1.nmconnection (fd1c02fb-cedd-36e5-9d48-fc7bbf910907,"Wired connection 1")
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.9058] settings: (eth0): created default wired connection 'Wired connection 1'
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.9098] device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Dec  1 09:56:27 localhost systemd[1]: Started Dispatcher daemon for systemd-networkd.
Dec  1 09:56:27 localhost systemd[1]: Reached target Multi-User System.
Dec  1 09:56:27 localhost systemd[1]: Reached target Graphical Interface.
Dec  1 09:56:27 localhost systemd[1]: Condition check resulted in Hide bootsplash after starting the system being skipped.
Dec  1 09:56:27 localhost systemd[1]: Starting Update UTMP about System Runlevel Changes...
Dec  1 09:56:27 localhost kernel: [   14.284447] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
Dec  1 09:56:27 localhost fancontrol[1265]: Common settings:
Dec  1 09:56:27 localhost fancontrol[1265]:   INTERVAL=10
Dec  1 09:56:27 localhost kernel: [   14.308295] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
Dec  1 09:56:27 localhost kernel: [   14.308369] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
Dec  1 09:56:27 localhost kernel: [   14.308676] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
Dec  1 09:56:27 localhost nmcli[1306]: ../../../gio/gdbusobjectmanagerclient.c:1589: Processing InterfaceRemoved signal for path /org/freedesktop/NetworkManager/IP4Config/1 but no object proxy exists
Dec  1 09:56:27 localhost nmcli[1306]: ../../../gio/gdbusobjectmanagerclient.c:1589: Processing InterfaceRemoved signal for path /org/freedesktop/NetworkManager/IP6Config/1 but no object proxy exists
Dec  1 09:56:27 localhost nm-dispatcher: req:2 'connectivity-change': new request (3 scripts)
Dec  1 09:56:27 localhost systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.9637] manager: (eth1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/3)
Dec  1 09:56:27 localhost systemd[1]: Started Update UTMP about System Runlevel Changes.
Dec  1 09:56:27 localhost systemd[1]: Startup finished in 6.330s (kernel) + 7.984s (userspace) = 14.315s.
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.9734] keyfile: add connection /run/NetworkManager/system-connections/Wired connection 2.nmconnection (93e5396a-8208-3148-a49c-4e3c7f742570,"Wired connection 2")
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.9773] settings: (eth1): created default wired connection 'Wired connection 2'
Dec  1 09:56:27 localhost NetworkManager[904]: <info>  [1606838187.9784] device (eth1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Dec  1 09:56:27 localhost dbus-daemon[896]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.3' (uid=0 pid=904 comm="/usr/sbin/NetworkManager --no-daemon ")
Dec  1 09:56:28 localhost systemd[1]: Starting Authorization Manager...
Dec  1 09:56:28 localhost polkitd[1381]: started daemon version 0.105 using authority implementation `local' version `0.105'
Dec  1 09:56:28 localhost dbus-daemon[896]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Dec  1 09:56:28 localhost systemd[1]: Started Authorization Manager.
Dec  1 09:56:28 localhost fancontrol[1265]: Settings for /dev/fan-p6/pwm1:
Dec  1 09:56:28 localhost fancontrol[1265]:   Depends on /dev/thermal-cpu/temp1_input
Dec  1 09:56:28 localhost fancontrol[1265]:   Controls
Dec  1 09:56:28 localhost fancontrol[1265]:   MINTEMP=40
Dec  1 09:56:28 localhost fancontrol[1265]:   MAXTEMP=110
Dec  1 09:56:28 localhost fancontrol[1265]:   MINSTART=60
Dec  1 09:56:28 localhost fancontrol[1265]:   MINSTOP=40
Dec  1 09:56:28 localhost fancontrol[1265]:   MINPWM=0
Dec  1 09:56:28 localhost fancontrol[1265]:   MAXPWM=255
Dec  1 09:56:28 localhost nm-dispatcher[1246]:
Dec  1 09:56:28 localhost fancontrol[1265]: Settings for /dev/fan-p7/pwm1:
Dec  1 09:56:28 localhost fancontrol[1265]: Enabling PWM on fans...
Dec  1 09:56:28 localhost fancontrol[1265]: Starting automatic fan control...
Dec  1 09:56:28 localhost nm-dispatcher: req:2 'connectivity-change': start running ordered scripts...
Dec  1 09:56:32 localhost kernel: [   18.409170] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Dec  1 09:56:32 localhost kernel: [   18.409229] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0596] device (eth0): carrier: link connected
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0626] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0705] policy: auto-activating connection 'Wired connection 1' (fd1c02fb-cedd-36e5-9d48-fc7bbf910907)
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0781] device (eth0): Activation: starting connection 'Wired connection 1' (fd1c02fb-cedd-36e5-9d48-fc7bbf910907)
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0794] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0841] manager: NetworkManager state is now CONNECTING
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0871] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0923] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.0987] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.1176] dhcp4 (eth0): dhclient started with pid 1915
Dec  1 09:56:32 localhost dhclient[1915]: DHCPREQUEST for 192.168.0.190 on eth0 to 255.255.255.255 port 67
Dec  1 09:56:32 localhost dhclient[1915]: DHCPACK of 192.168.0.190 from 192.168.0.1
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7309] dhcp4 (eth0):   address 192.168.0.190
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7311] dhcp4 (eth0):   plen 24 (255.255.255.0)
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7312] dhcp4 (eth0):   gateway 192.168.0.1
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7314] dhcp4 (eth0):   lease time 604800
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7315] dhcp4 (eth0):   hostname 'helios64'
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7316] dhcp4 (eth0):   nameserver '192.168.0.1'
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7317] dhcp4 (eth0):   domain name 'tendawifi.com'
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7318] dhcp4 (eth0): state changed unknown -> bound
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7391] device (eth0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Dec  1 09:56:32 localhost dhclient[1915]: bound to 192.168.0.190 -- renewal in 255882 seconds.
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7446] device (eth0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7466] device (eth0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7502] manager: NetworkManager state is now CONNECTED_LOCAL
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7602] manager: NetworkManager state is now CONNECTED_SITE
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7609] policy: set 'Wired connection 1' (eth0) as default for IPv4 routing and DNS
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7673] device (eth0): Activation: successful, device activated.
Dec  1 09:56:32 localhost NetworkManager[904]: <info>  [1606838192.7708] manager: NetworkManager state is now CONNECTED_GLOBAL
Dec  1 09:56:32 localhost nm-dispatcher: req:3 'up' [eth0]: new request (3 scripts)
Dec  1 09:56:32 localhost nm-dispatcher: req:3 'up' [eth0]: start running ordered scripts...
Dec  1 09:56:32 localhost nm-dispatcher: req:4 'connectivity-change': new request (3 scripts)
Dec  1 09:56:33 localhost nm-dispatcher[1246]: Eth0 Eth0stat 2 2
Dec  1 09:56:33 localhost nm-dispatcher: req:4 'connectivity-change': start running ordered scripts...
Dec  1 09:56:33 localhost NetworkManager[904]: <info>  [1606838193.9879] manager: startup complete
Dec  1 09:56:37 localhost chronyd[1081]: Selected source 149.20.176.27
Dec  1 09:56:43 localhost systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Dec  1 09:56:47 localhost kernel: [   34.586694] vcc3v0_sd: disabling
Dec  1 09:56:47 localhost kernel: [   34.586711] vcc5v0_typec: disabling
Dec  1 09:56:57 localhost systemd[1]: systemd-hostnamed.service: Succeeded.
Dec  1 09:57:59 localhost systemd[1]: Created slice User Slice of UID 0.
Dec  1 09:57:59 localhost systemd[1]: Starting User Runtime Directory /run/user/0...
Dec  1 09:57:59 localhost systemd[1]: Started User Runtime Directory /run/user/0.
Dec  1 09:57:59 localhost systemd[1]: Starting User Manager for UID 0...
Dec  1 09:57:59 localhost systemd[2149]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec  1 09:57:59 localhost systemd[2149]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec  1 09:57:59 localhost systemd[2149]: Reached target Paths.
Dec  1 09:57:59 localhost systemd[2149]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec  1 09:57:59 localhost systemd[2149]: Reached target Timers.
Dec  1 09:57:59 localhost systemd[2149]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec  1 09:57:59 localhost systemd[2149]: Listening on GnuPG network certificate management daemon.
Dec  1 09:57:59 localhost systemd[2149]: Reached target Sockets.
Dec  1 09:57:59 localhost systemd[2149]: Reached target Basic System.
Dec  1 09:57:59 localhost systemd[2149]: Reached target Default.
Dec  1 09:57:59 localhost systemd[2149]: Startup finished in 108ms.
Dec  1 09:57:59 localhost systemd[1]: Started User Manager for UID 0.
Dec  1 09:57:59 localhost systemd[1]: Started Session 2 of user root.
Dec  1 10:00:01 localhost CRON[2964]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Dec  1 10:01:27 localhost systemd[1]: Reloading.
Dec  1 10:01:27 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:01:27 localhost systemd[1]: getty@tty1.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Dec  1 10:01:27 localhost systemd[1]: serial-getty@ttyS2.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Dec  1 10:01:28 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:01:28 localhost systemd[1]: Created slice system-postfix.slice.
Dec  1 10:01:28 localhost systemd[1]: Starting Postfix Mail Transport Agent (instance -)...
Dec  1 10:01:29 localhost postfix/postfix-script[3633]: starting the Postfix mail system
Dec  1 10:01:29 localhost postfix/master[3635]: daemon started -- version 3.4.14, configuration /etc/postfix
Dec  1 10:01:29 localhost systemd[1]: Started Postfix Mail Transport Agent (instance -).
Dec  1 10:01:29 localhost systemd[1]: Starting Postfix Mail Transport Agent...
Dec  1 10:01:29 localhost systemd[1]: Started Postfix Mail Transport Agent.
Dec  1 10:01:29 localhost systemd[1]: Reloading.
Dec  1 10:01:29 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:01:31 localhost systemd[1]: Reloading.
Dec  1 10:01:31 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:01:31 localhost systemd[1]: Stopping System Logging Service...
Dec  1 10:01:31 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="888" x-info="https://www.rsyslog.com"] exiting on signal 15.
Dec  1 10:01:31 localhost systemd[1]: rsyslog.service: Succeeded.
Dec  1 10:01:31 localhost systemd[1]: Stopped System Logging Service.
Dec  1 10:01:31 localhost systemd[1]: Starting System Logging Service...
Dec  1 10:01:31 localhost rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Dec  1 10:01:31 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="4044" x-info="https://www.rsyslog.com"] start
Dec  1 10:01:31 localhost systemd[1]: Started System Logging Service.
Dec  1 10:01:52 localhost systemd[1]: Reloading.
Dec  1 10:01:52 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:01:53 localhost systemd[1]: Starting LSB: service and resource monitoring daemon...
Dec  1 10:01:53 localhost monit[5063]: Starting daemon monitor: monit.
Dec  1 10:01:53 localhost systemd[1]: Started LSB: service and resource monitoring daemon.
Dec  1 10:01:53 localhost systemd[1]: Reloading.
Dec  1 10:01:53 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:02:23 localhost dbus-daemon[896]: [system] Reloaded configuration
Dec  1 10:02:59 localhost systemd[1]: Reloading.
Dec  1 10:02:59 localhost systemd[7167]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:02:59 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:02:59 localhost systemd[7191]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:02:59 localhost systemd[1]: Started Self Monitoring and Reporting Technology (SMART) Daemon.
Dec  1 10:02:59 localhost smartd[7218]: smartd 6.6 2017-11-05 r4594 [aarch64-linux-5.9.11-rockchip64] (local build)
Dec  1 10:02:59 localhost smartd[7218]: Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Dec  1 10:02:59 localhost smartd[7218]: Opened configuration file /etc/smartd.conf
Dec  1 10:02:59 localhost smartd[7218]: Drive: DEVICESCAN, implied '-a' Directive on line 21 of file /etc/smartd.conf
Dec  1 10:02:59 localhost smartd[7218]: Configuration file /etc/smartd.conf was parsed, found DEVICESCAN, scanning devices
Dec  1 10:02:59 localhost smartd[7218]: DEVICESCAN failed: glob(3) aborted matching pattern /dev/discs/disc*
Dec  1 10:02:59 localhost smartd[7218]: In the system's table of devices NO devices found to scan
Dec  1 10:02:59 localhost smartd[7218]: Unable to monitor any SMART enabled devices. Try debug (-d) option. Exiting...
Dec  1 10:02:59 localhost systemd[1]: smartd.service: Main process exited, code=exited, status=17/n/a
Dec  1 10:02:59 localhost systemd[1]: smartd.service: Failed with result 'exit-code'.
Dec  1 10:03:00 localhost systemd[7221]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:00 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:00 localhost systemd[1]: Reloading.
Dec  1 10:03:00 localhost systemd[7247]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:00 localhost systemd[1]: Started Self Monitoring and Reporting Technology (SMART) Daemon.
Dec  1 10:03:00 localhost smartd[7273]: smartd 6.6 2017-11-05 r4594 [aarch64-linux-5.9.11-rockchip64] (local build)
Dec  1 10:03:00 localhost smartd[7273]: Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Dec  1 10:03:00 localhost smartd[7273]: Opened configuration file /etc/smartd.conf
Dec  1 10:03:00 localhost smartd[7273]: Drive: DEVICESCAN, implied '-a' Directive on line 21 of file /etc/smartd.conf
Dec  1 10:03:00 localhost smartd[7273]: Configuration file /etc/smartd.conf was parsed, found DEVICESCAN, scanning devices
Dec  1 10:03:00 localhost smartd[7273]: DEVICESCAN failed: glob(3) aborted matching pattern /dev/discs/disc*
Dec  1 10:03:00 localhost smartd[7273]: In the system's table of devices NO devices found to scan
Dec  1 10:03:00 localhost systemd[1]: smartd.service: Main process exited, code=exited, status=17/n/a
Dec  1 10:03:00 localhost smartd[7273]: Unable to monitor any SMART enabled devices. Try debug (-d) option. Exiting...
Dec  1 10:03:00 localhost systemd[1]: smartd.service: Failed with result 'exit-code'.
Dec  1 10:03:02 localhost systemd[1]: Reloading.
Dec  1 10:03:02 localhost systemd[7304]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:02 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:02 localhost systemd[7327]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:02 localhost systemd[1]: Started Clean PHP session files every 30 mins.
Dec  1 10:03:04 localhost systemd[1]: Reloading.
Dec  1 10:03:04 localhost systemd[7380]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:04 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:04 localhost systemd[7404]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:05 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:05 localhost systemd[1]: Reloading.
Dec  1 10:03:05 localhost systemd[7430]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:05 localhost systemd[1]: Condition check resulted in Statistics collection and monitoring daemon being skipped.
Dec  1 10:03:06 localhost systemd[1]: Reloading.
Dec  1 10:03:06 localhost systemd[7476]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:06 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:07 localhost systemd[7502]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:07 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:07 localhost systemd[1]: Reloading.
Dec  1 10:03:07 localhost systemd[7528]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:08 localhost systemd[7551]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:08 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:08 localhost systemd[1]: Started Trigger anacron every hour.
Dec  1 10:03:10 localhost systemd[1]: Reloading.
Dec  1 10:03:10 localhost systemd[7627]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:10 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:11 localhost systemd[7651]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:11 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:17 localhost php7.3-common: php_invoke calendar: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:17 localhost php7.3-common: php_invoke calendar: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:17 localhost php7.3-common: php_invoke calendar: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:18 localhost php7.3-common: php_invoke ctype: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:18 localhost php7.3-common: php_invoke ctype: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:18 localhost php7.3-common: php_invoke ctype: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:20 localhost php7.3-common: php_invoke exif: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:20 localhost php7.3-common: php_invoke exif: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:20 localhost php7.3-common: php_invoke exif: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:21 localhost php7.3-common: php_invoke fileinfo: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:21 localhost php7.3-common: php_invoke fileinfo: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:21 localhost php7.3-common: php_invoke fileinfo: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:22 localhost php7.3-common: php_invoke ftp: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:22 localhost php7.3-common: php_invoke ftp: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:22 localhost php7.3-common: php_invoke ftp: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:23 localhost php7.3-common: php_invoke gettext: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:23 localhost php7.3-common: php_invoke gettext: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:23 localhost php7.3-common: php_invoke gettext: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:25 localhost php7.3-common: php_invoke iconv: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:25 localhost php7.3-common: php_invoke iconv: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:25 localhost php7.3-common: php_invoke iconv: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:26 localhost php7.3-common: php_invoke pdo: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:26 localhost php7.3-common: php_invoke pdo: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:26 localhost php7.3-common: php_invoke pdo: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:27 localhost php7.3-common: php_invoke phar: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:27 localhost php7.3-common: php_invoke phar: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:27 localhost php7.3-common: php_invoke phar: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:28 localhost php7.3-common: php_invoke posix: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:28 localhost php7.3-common: php_invoke posix: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:28 localhost php7.3-common: php_invoke posix: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:29 localhost php7.3-common: php_invoke shmop: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:29 localhost php7.3-common: php_invoke shmop: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:30 localhost php7.3-common: php_invoke shmop: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:31 localhost php7.3-common: php_invoke sockets: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:31 localhost php7.3-common: php_invoke sockets: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:31 localhost php7.3-common: php_invoke sockets: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:32 localhost php7.3-common: php_invoke sysvmsg: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:32 localhost php7.3-common: php_invoke sysvmsg: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:32 localhost php7.3-common: php_invoke sysvmsg: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:33 localhost php7.3-common: php_invoke sysvsem: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:33 localhost php7.3-common: php_invoke sysvsem: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:33 localhost php7.3-common: php_invoke sysvsem: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:34 localhost php7.3-common: php_invoke sysvshm: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:34 localhost php7.3-common: php_invoke sysvshm: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:34 localhost php7.3-common: php_invoke sysvshm: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:35 localhost php7.3-common: php_invoke tokenizer: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:35 localhost php7.3-common: php_invoke tokenizer: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:35 localhost php7.3-common: php_invoke tokenizer: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:38 localhost systemd[1]: Reloading.
Dec  1 10:03:38 localhost systemd[12387]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:38 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:38 localhost systemd[12411]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:39 localhost systemd[1]: Reloading.
Dec  1 10:03:39 localhost systemd[12437]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:39 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:40 localhost systemd[1]: Reloading.
Dec  1 10:03:40 localhost systemd[12463]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:40 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:42 localhost php7.3-opcache: php_invoke opcache: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:42 localhost php7.3-opcache: php_invoke opcache: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:42 localhost php7.3-opcache: php_invoke opcache: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:45 localhost php7.3-bcmath: php_invoke bcmath: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:45 localhost php7.3-bcmath: php_invoke bcmath: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:45 localhost php7.3-bcmath: php_invoke bcmath: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:47 localhost php7.3-mbstring: php_invoke mbstring: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:47 localhost php7.3-mbstring: php_invoke mbstring: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:47 localhost php7.3-mbstring: php_invoke mbstring: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:50 localhost php7.3-json: php_invoke json: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:50 localhost php7.3-json: php_invoke json: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:50 localhost php7.3-json: php_invoke json: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:52 localhost php7.3-readline: php_invoke readline: already enabled for PHP 7.3 fpm sapi
Dec  1 10:03:52 localhost php7.3-readline: php_invoke readline: already enabled for PHP 7.3 cgi sapi
Dec  1 10:03:52 localhost php7.3-readline: php_invoke readline: already enabled for PHP 7.3 cli sapi
Dec  1 10:03:53 localhost systemd[1]: Reloading.
Dec  1 10:03:53 localhost systemd[14124]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:53 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:54 localhost systemd[14174]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:54 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:54 localhost systemd[1]: Reloading.
Dec  1 10:03:54 localhost systemd[14201]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:54 localhost systemd[1]: Listening on RPCbind Server Activation Socket.
Dec  1 10:03:54 localhost systemd[1]: Starting RPC bind portmap service...
Dec  1 10:03:54 localhost systemd[1]: Started RPC bind portmap service.
Dec  1 10:03:54 localhost systemd[1]: Reached target RPC Port Mapper.
Dec  1 10:03:54 localhost systemd[1]: Reached target Remote File Systems (Pre).
Dec  1 10:03:55 localhost systemd[1]: Reloading.
Dec  1 10:03:55 localhost systemd[14237]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:55 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:55 localhost systemd[14263]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:58 localhost systemd[1]: Reloading.
Dec  1 10:03:58 localhost systemd[14473]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:58 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:03:58 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:58 localhost systemd[14496]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:59 localhost systemd[14524]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:03:59 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:03:59 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:03:59 localhost systemd[1]: Reloading.
Dec  1 10:03:59 localhost systemd[14551]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:01 localhost systemd[1]: Reloading.
Dec  1 10:04:02 localhost systemd[14674]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:02 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:02 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:02 localhost systemd[1]: Reloading.
Dec  1 10:04:02 localhost systemd[14704]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:02 localhost systemd[1]: Starting LSB: Starts ProFTPD daemon...
Dec  1 10:04:02 localhost proftpd[14729]: Starting ftp server: proftpd2020-12-01 10:04:02,853 helios64 proftpd[14737]: processing configuration directory '/etc/proftpd/conf.d/'
Dec  1 10:04:02 localhost proftpd[14729]: .
Dec  1 10:04:02 localhost systemd[1]: Started LSB: Starts ProFTPD daemon.
Dec  1 10:04:04 localhost php7.3-xml: php_invoke dom: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:04 localhost php7.3-xml: php_invoke dom: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:04 localhost php7.3-xml: php_invoke dom: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:05 localhost php7.3-xml: php_invoke simplexml: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:05 localhost php7.3-xml: php_invoke simplexml: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:05 localhost php7.3-xml: php_invoke simplexml: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:06 localhost php7.3-xml: php_invoke wddx: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:07 localhost php7.3-xml: php_invoke wddx: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:07 localhost php7.3-xml: php_invoke wddx: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:08 localhost php7.3-xml: php_invoke xml: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:08 localhost php7.3-xml: php_invoke xml: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:08 localhost php7.3-xml: php_invoke xml: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:09 localhost php7.3-xml: php_invoke xmlreader: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:09 localhost php7.3-xml: php_invoke xmlreader: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:09 localhost php7.3-xml: php_invoke xmlreader: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:10 localhost php7.3-xml: php_invoke xmlwriter: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:10 localhost php7.3-xml: php_invoke xmlwriter: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:10 localhost php7.3-xml: php_invoke xmlwriter: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:11 localhost php7.3-xml: php_invoke xsl: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:11 localhost php7.3-xml: php_invoke xsl: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:11 localhost php7.3-xml: php_invoke xsl: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke xml: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke mbstring: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke fileinfo: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke phar: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke xmlwriter: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke simplexml: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke dom: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke sysvmsg: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke posix: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:13 localhost php7.3-cli: php_invoke ftp: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke sysvshm: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke wddx: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke sockets: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke opcache: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke pdo: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke ctype: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke gettext: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke xmlreader: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke exif: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke bcmath: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke iconv: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke xsl: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke calendar: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke sysvsem: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke readline: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:14 localhost php7.3-cli: php_invoke shmop: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:15 localhost php7.3-cli: php_invoke json: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:15 localhost php7.3-cli: php_invoke tokenizer: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke xml: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke mbstring: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke fileinfo: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke phar: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke xmlwriter: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke simplexml: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke dom: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke sysvmsg: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke posix: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke ftp: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke sysvshm: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke wddx: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke sockets: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:16 localhost php7.3-cgi: php_invoke opcache: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke pdo: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke ctype: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke gettext: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke xmlreader: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke exif: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke bcmath: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke iconv: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke xsl: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke calendar: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke sysvsem: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke readline: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke shmop: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke json: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:17 localhost php7.3-cgi: php_invoke tokenizer: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:18 localhost systemd[1]: Reloading.
Dec  1 10:04:18 localhost systemd[18686]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:19 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:19 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:19 localhost systemd[1]: Reloading.
Dec  1 10:04:19 localhost systemd[18709]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:19 localhost systemd[1]: Mounting NFSD configuration filesystem...
Dec  1 10:04:19 localhost systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
Dec  1 10:04:19 localhost systemd[1]: Starting Preprocess NFS configuration...
Dec  1 10:04:19 localhost systemd[1]: Mounting RPC Pipe File System...
Dec  1 10:04:19 localhost systemd[1]: nfs-config.service: Succeeded.
Dec  1 10:04:19 localhost systemd[1]: Started Preprocess NFS configuration.
Dec  1 10:04:19 localhost kernel: [  486.738678] RPC: Registered named UNIX socket transport module.
Dec  1 10:04:19 localhost kernel: [  486.738683] RPC: Registered udp transport module.
Dec  1 10:04:19 localhost kernel: [  486.738685] RPC: Registered tcp transport module.
Dec  1 10:04:19 localhost kernel: [  486.738687] RPC: Registered tcp NFSv4.1 backchannel transport module.
Dec  1 10:04:19 localhost systemd[1]: Mounted RPC Pipe File System.
Dec  1 10:04:19 localhost systemd[1]: Starting NFSv4 ID-name mapping service...
Dec  1 10:04:19 localhost systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Dec  1 10:04:19 localhost systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Dec  1 10:04:19 localhost systemd[1]: Started NFSv4 ID-name mapping service.
Dec  1 10:04:19 localhost kernel: [  486.777023] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Dec  1 10:04:19 localhost systemd[1]: Mounted NFSD configuration filesystem.
Dec  1 10:04:19 localhost systemd[1]: Starting NFS Mount Daemon...
Dec  1 10:04:19 localhost rpc.mountd[18751]: Version 1.3.3 starting
Dec  1 10:04:19 localhost systemd[1]: Started NFS Mount Daemon.
Dec  1 10:04:19 localhost systemd[1]: Starting NFS server and services...
Dec  1 10:04:19 localhost exportfs[18752]: exportfs: can't open /etc/exports for reading
Dec  1 10:04:19 localhost systemd[1]: nfs-server.service: Control process exited, code=exited, status=1/FAILURE
Dec  1 10:04:19 localhost systemd[1]: nfs-server.service: Failed with result 'exit-code'.
Dec  1 10:04:19 localhost systemd[1]: Stopped NFS server and services.
Dec  1 10:04:19 localhost systemd[1]: Stopping NFSv4 ID-name mapping service...
Dec  1 10:04:19 localhost systemd[1]: Stopping NFS Mount Daemon...
Dec  1 10:04:19 localhost systemd[1]: nfs-idmapd.service: Main process exited, code=killed, status=15/TERM
Dec  1 10:04:19 localhost systemd[1]: nfs-idmapd.service: Succeeded.
Dec  1 10:04:19 localhost rpc.mountd[18751]: Caught signal 15, un-registering and exiting.
Dec  1 10:04:19 localhost systemd[1]: Stopped NFSv4 ID-name mapping service.
Dec  1 10:04:19 localhost systemd[1]: nfs-mountd.service: Succeeded.
Dec  1 10:04:19 localhost systemd[1]: Stopped NFS Mount Daemon.
Dec  1 10:04:21 localhost systemd[1]: Reloading.
Dec  1 10:04:21 localhost systemd[18913]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:21 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:21 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:21 localhost systemd[18940]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:21 localhost systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
Dec  1 10:04:21 localhost systemd[1]: Starting Preprocess NFS configuration...
Dec  1 10:04:21 localhost systemd[1]: nfs-config.service: Succeeded.
Dec  1 10:04:21 localhost systemd[1]: Started Preprocess NFS configuration.
Dec  1 10:04:21 localhost systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Dec  1 10:04:21 localhost systemd[1]: Starting NFSv4 ID-name mapping service...
Dec  1 10:04:21 localhost systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Dec  1 10:04:21 localhost systemd[1]: Starting NFS Mount Daemon...
Dec  1 10:04:21 localhost systemd[1]: Started NFSv4 ID-name mapping service.
Dec  1 10:04:21 localhost rpc.mountd[18971]: Version 1.3.3 starting
Dec  1 10:04:21 localhost systemd[1]: Started NFS Mount Daemon.
Dec  1 10:04:21 localhost systemd[1]: Starting NFS server and services...
Dec  1 10:04:22 localhost kernel: [  490.138275] NFSD: Using UMH upcall client tracking operations.
Dec  1 10:04:22 localhost kernel: [  490.138289] NFSD: starting 90-second grace period (net f00000a1)
Dec  1 10:04:22 localhost systemd[1]: Started NFS server and services.
Dec  1 10:04:26 localhost php7.3-fpm: php_invoke xml: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:26 localhost php7.3-fpm: php_invoke mbstring: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:26 localhost php7.3-fpm: php_invoke fileinfo: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:26 localhost php7.3-fpm: php_invoke phar: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:26 localhost php7.3-fpm: php_invoke xmlwriter: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:26 localhost php7.3-fpm: php_invoke simplexml: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:26 localhost php7.3-fpm: php_invoke dom: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:26 localhost php7.3-fpm: php_invoke sysvmsg: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke posix: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke ftp: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke sysvshm: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke wddx: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke sockets: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke opcache: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke pdo: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke ctype: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke gettext: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke xmlreader: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke exif: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke bcmath: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke iconv: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke xsl: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:27 localhost php7.3-fpm: php_invoke calendar: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:28 localhost php7.3-fpm: php_invoke sysvsem: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:28 localhost php7.3-fpm: php_invoke readline: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:28 localhost php7.3-fpm: php_invoke shmop: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:28 localhost php7.3-fpm: php_invoke json: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:28 localhost php7.3-fpm: php_invoke tokenizer: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:28 localhost systemd[1]: Reloading.
Dec  1 10:04:28 localhost systemd[19975]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:28 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:28 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:29 localhost systemd[1]: Reloading.
Dec  1 10:04:29 localhost systemd[20000]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:29 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:29 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:29 localhost systemd[20026]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:29 localhost systemd[1]: Starting The PHP 7.3 FastCGI Process Manager...
Dec  1 10:04:29 localhost systemd[1]: Started The PHP 7.3 FastCGI Process Manager.
Dec  1 10:04:30 localhost php-yaml: php_invoke yaml: already enabled for PHP 7.3 fpm sapi
Dec  1 10:04:30 localhost php-yaml: php_invoke yaml: already enabled for PHP 7.3 cgi sapi
Dec  1 10:04:30 localhost php-yaml: php_invoke yaml: already enabled for PHP 7.3 cli sapi
Dec  1 10:04:41 localhost dbus-daemon[896]: Unknown username "avahi" in message bus configuration file
Dec  1 10:04:41 localhost dbus-daemon[896]: [system] Reloaded configuration
Dec  1 10:04:42 localhost systemd[1]: Reloading.
Dec  1 10:04:42 localhost systemd[20380]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:42 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:42 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:42 localhost systemd[1]: Reloading D-Bus System Message Bus.
Dec  1 10:04:42 localhost dbus-daemon[896]: [system] Reloaded configuration
Dec  1 10:04:42 localhost dbus-send[20407]: method return time=1606838682.513106 sender=org.freedesktop.DBus -> destination=:1.33 serial=3 reply_serial=2
Dec  1 10:04:42 localhost systemd[1]: Reloaded D-Bus System Message Bus.
Dec  1 10:04:42 localhost systemd[20413]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:43 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:43 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:43 localhost systemd[1]: Reloading.
Dec  1 10:04:43 localhost systemd[20439]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:44 localhost systemd[20463]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:44 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:44 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:44 localhost systemd[1]: Reloading.
Dec  1 10:04:44 localhost systemd[20489]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:44 localhost systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Dec  1 10:04:44 localhost systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Dec  1 10:04:44 localhost avahi-daemon[20515]: Found user 'avahi' (UID 113) and group 'avahi' (GID 119).
Dec  1 10:04:44 localhost avahi-daemon[20515]: Successfully dropped root privileges.
Dec  1 10:04:44 localhost avahi-daemon[20515]: avahi-daemon 0.7 starting up.
Dec  1 10:04:44 localhost systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Dec  1 10:04:44 localhost avahi-daemon[20515]: Successfully called chroot().
Dec  1 10:04:44 localhost avahi-daemon[20515]: Successfully dropped remaining capabilities.
Dec  1 10:04:44 localhost avahi-daemon[20515]: No service file found in /etc/avahi/services.
Dec  1 10:04:44 localhost avahi-daemon[20515]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::a738:86aa:ee73:de3e.
Dec  1 10:04:44 localhost avahi-daemon[20515]: New relevant interface eth0.IPv6 for mDNS.
Dec  1 10:04:44 localhost avahi-daemon[20515]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.190.
Dec  1 10:04:44 localhost avahi-daemon[20515]: New relevant interface eth0.IPv4 for mDNS.
Dec  1 10:04:44 localhost avahi-daemon[20515]: Network interface enumeration completed.
Dec  1 10:04:44 localhost avahi-daemon[20515]: Registering new address record for fe80::a738:86aa:ee73:de3e on eth0.*.
Dec  1 10:04:44 localhost avahi-daemon[20515]: Registering new address record for 192.168.0.190 on eth0.IPv4.
Dec  1 10:04:45 localhost systemd[1]: Reloading.
Dec  1 10:04:45 localhost avahi-daemon[20515]: Server startup complete. Host name is helios64.local. Local service cookie is 922089970.
Dec  1 10:04:45 localhost systemd[20539]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:45 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:45 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:45 localhost systemd[1]: Starting Statistics collection and monitoring daemon...
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "syslog" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "battery" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "cpu" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "df" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "disk" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "entropy" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "interface" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "irq" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "load" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "memory" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "processes" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "rrdtool" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "swap" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: plugin_load: plugin "users" successfully loaded.
Dec  1 10:04:45 localhost collectd[20566]: Systemd detected, trying to signal readyness.
Dec  1 10:04:45 localhost systemd[1]: Started Statistics collection and monitoring daemon.
Dec  1 10:04:45 localhost collectd[20566]: Initialization complete, entering read-loop.
Dec  1 10:04:45 localhost systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 20575 (reader#2)
Dec  1 10:04:45 localhost systemd[1]: Mounting Arbitrary Executable File Formats File System...
Dec  1 10:04:45 localhost systemd[1]: Mounted Arbitrary Executable File Formats File System.
Dec  1 10:04:46 localhost systemd[20583]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:46 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:46 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:46 localhost systemd[1]: Reloading.
Dec  1 10:04:46 localhost systemd[20612]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:46 localhost systemd[1]: Starting LSB: start or stop rrdcached...
Dec  1 10:04:46 localhost rrdcached[20638]: rrdcached started.
Dec  1 10:04:46 localhost systemd[1]: Started LSB: start or stop rrdcached.
Dec  1 10:04:46 localhost systemd[20667]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:47 localhost systemd[1]: Starting A high performance web server and a reverse proxy server...
Dec  1 10:04:47 localhost systemd[1]: Started A high performance web server and a reverse proxy server.
Dec  1 10:04:47 localhost systemd[1]: Reloading.
Dec  1 10:04:47 localhost systemd[20707]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:47 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:47 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:48 localhost systemd[1]: Reloading.
Dec  1 10:04:48 localhost systemd[20731]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:48 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:48 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:48 localhost systemd[20757]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:48 localhost systemd[1]: Starting The Salt Minion...
Dec  1 10:04:49 localhost systemd[1]: Started The Salt Minion.
Dec  1 10:04:52 localhost systemd[1]: Reloading.
Dec  1 10:04:52 localhost systemd[20906]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:52 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:52 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:53 localhost systemd[20946]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:53 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:53 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:53 localhost systemd[1]: Reloading.
Dec  1 10:04:53 localhost systemd[20973]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:53 localhost salt-minion[20783]: [ERROR   ] DNS lookup or connection check of 'salt' failed.
Dec  1 10:04:53 localhost salt-minion[20783]: [ERROR   ] Master hostname: 'salt' not found or not responsive. Retrying in 30 seconds
Dec  1 10:04:53 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:04:53 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:04:53 localhost systemd[1]: Starting Samba SMB Daemon...
Dec  1 10:04:53 localhost update-apparmor-samba-profile[20999]: grep: /etc/apparmor.d/samba/smbd-shares: No such file or directory
Dec  1 10:04:53 localhost update-apparmor-samba-profile[20999]: diff: /etc/apparmor.d/samba/smbd-shares: No such file or directory
Dec  1 10:04:54 localhost systemd[1]: Started Samba SMB Daemon.
Dec  1 10:04:54 localhost systemd[1]: Reloading.
Dec  1 10:04:54 localhost systemd[21016]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:54 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:54 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:54 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:04:54 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:04:54 localhost systemd[21043]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:54 localhost systemd[1]: Starting Samba NMB Daemon...
Dec  1 10:04:55 localhost systemd[1]: Started Samba NMB Daemon.
Dec  1 10:04:55 localhost systemd[1]: Reloading.
Dec  1 10:04:55 localhost systemd[21072]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:55 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:55 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:55 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:04:55 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:04:55 localhost systemd[21099]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:56 localhost systemd[1]: Reloading.
Dec  1 10:04:56 localhost systemd[21127]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:56 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:04:56 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:56 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:56 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:04:57 localhost systemd[1]: Reloading.
Dec  1 10:04:57 localhost systemd[21157]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:57 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:04:57 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:04:57 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:57 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:57 localhost systemd[21181]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:58 localhost systemd[1]: Reloading.
Dec  1 10:04:58 localhost systemd[21212]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:58 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:04:58 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:04:58 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:04:58 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:04:58 localhost systemd[21235]: /usr/lib/systemd/system-generators/lvm2-activation-generator failed with exit status 1.
Dec  1 10:04:59 localhost systemd[1]: Listening on Device-mapper event daemon FIFOs.
Dec  1 10:05:00 localhost systemd[1]: Reloading.
Dec  1 10:05:00 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:05:00 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:00 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:00 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:01 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:05:01 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:01 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:01 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:01 localhost systemd[1]: Reloading.
Dec  1 10:05:01 localhost CRON[21385]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec  1 10:05:01 localhost systemd[1]: Listening on LVM2 poll daemon socket.
Dec  1 10:05:01 localhost systemd[1]: Started LVM2 poll daemon.
Dec  1 10:05:02 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:05:02 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:02 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:02 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:02 localhost systemd[1]: Reloading.
Dec  1 10:05:03 localhost systemd[1]: Reloading.
Dec  1 10:05:03 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:05:03 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:03 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:03 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:03 localhost systemd[1]: Starting Availability of block devices...
Dec  1 10:05:03 localhost systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Dec  1 10:05:03 localhost systemd[1]: Started Availability of block devices.
Dec  1 10:05:03 localhost systemd[1]: Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Dec  1 10:05:04 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:05:04 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:04 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:04 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:05 localhost systemd[1]: Reloading.
Dec  1 10:05:05 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:05:05 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:05 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:05 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:05 localhost chronyd[1081]: chronyd exiting
Dec  1 10:05:05 localhost systemd[1]: Stopping chrony, an NTP client/server...
Dec  1 10:05:05 localhost systemd[1]: chrony.service: Succeeded.
Dec  1 10:05:05 localhost systemd[1]: Stopped chrony, an NTP client/server.
Dec  1 10:05:06 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:05:06 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:06 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:06 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:06 localhost systemd[1]: Stopping LSB: Starts ProFTPD daemon...
Dec  1 10:05:06 localhost proftpd[21596]: Stopping ftp server: proftpd.
Dec  1 10:05:06 localhost systemd[1]: proftpd.service: Succeeded.
Dec  1 10:05:06 localhost systemd[1]: Stopped LSB: Starts ProFTPD daemon.
Dec  1 10:05:06 localhost systemd[1]: Stopping NFS server and services...
Dec  1 10:05:06 localhost kernel: [  534.066081] nfsd: last server has exited, flushing export cache
Dec  1 10:05:06 localhost systemd[1]: nfs-server.service: Succeeded.
Dec  1 10:05:06 localhost systemd[1]: Stopped NFS server and services.
Dec  1 10:05:06 localhost systemd[1]: Stopping NFSv4 ID-name mapping service...
Dec  1 10:05:06 localhost systemd[1]: Stopping NFS Mount Daemon...
Dec  1 10:05:06 localhost rpc.mountd[18971]: Caught signal 15, un-registering and exiting.
Dec  1 10:05:06 localhost systemd[1]: nfs-idmapd.service: Main process exited, code=killed, status=15/TERM
Dec  1 10:05:06 localhost systemd[1]: nfs-idmapd.service: Succeeded.
Dec  1 10:05:06 localhost systemd[1]: Stopped NFSv4 ID-name mapping service.
Dec  1 10:05:06 localhost systemd[1]: nfs-mountd.service: Succeeded.
Dec  1 10:05:06 localhost systemd[1]: Stopped NFS Mount Daemon.
Dec  1 10:05:07 localhost systemd[1]: Reloading.
Dec  1 10:05:07 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:07 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:07 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:07 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:05:07 localhost systemd[1]: Stopping Samba SMB Daemon...
Dec  1 10:05:07 localhost systemd[1]: smbd.service: Main process exited, code=killed, status=15/TERM
Dec  1 10:05:07 localhost systemd[1]: smbd.service: Succeeded.
Dec  1 10:05:07 localhost systemd[1]: Stopped Samba SMB Daemon.
Dec  1 10:05:08 localhost systemd[1]: Stopping Samba NMB Daemon...
Dec  1 10:05:08 localhost systemd[1]: nmbd.service: Succeeded.
Dec  1 10:05:08 localhost systemd[1]: Stopped Samba NMB Daemon.
Dec  1 10:05:08 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:05:08 localhost systemd[1]: Reloading.
Dec  1 10:05:08 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:08 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:08 localhost systemd[1]: postfix.service: Succeeded.
Dec  1 10:05:08 localhost systemd[1]: Stopped Postfix Mail Transport Agent.
Dec  1 10:05:08 localhost systemd[1]: Stopping Postfix Mail Transport Agent (instance -)...
Dec  1 10:05:08 localhost postfix/postfix-script[21694]: stopping the Postfix mail system
Dec  1 10:05:08 localhost postfix/master[3635]: terminating on signal 15
Dec  1 10:05:08 localhost systemd[1]: postfix@-.service: Succeeded.
Dec  1 10:05:08 localhost systemd[1]: Stopped Postfix Mail Transport Agent (instance -).
Dec  1 10:05:09 localhost systemd[1]: Stopping The Salt Minion...
Dec  1 10:05:09 localhost salt-minion[20783]: [WARNING ] Minion received a SIGTERM. Exiting.
Dec  1 10:05:09 localhost salt-minion[20783]: The Salt Minion is shutdown. Minion received a SIGTERM. Exited.
Dec  1 10:05:09 localhost systemd[1]: salt-minion.service: Succeeded.
Dec  1 10:05:09 localhost systemd[1]: Stopped The Salt Minion.
Dec  1 10:05:09 localhost systemd[1]: Reloading.
Dec  1 10:05:10 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:10 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:10 localhost systemd[1]: Starting Network Service...
Dec  1 10:05:10 localhost systemd-networkd[21749]: eth0: Gained IPv6LL
Dec  1 10:05:10 localhost systemd-networkd[21749]: Enumeration completed
Dec  1 10:05:10 localhost systemd[1]: Started Network Service.
Dec  1 10:05:10 localhost systemd[1]: Reloading.
Dec  1 10:05:10 localhost systemd[1]: Starting Network Name Resolution...
Dec  1 10:05:11 localhost systemd-resolved[21781]: Positive Trust Anchors:
Dec  1 10:05:11 localhost systemd-resolved[21781]: . IN DS 19036 8 2 49aac11d7b6f6446702e54a1607371607a1a41855200fd2ce1cdde32f24e8fb5
Dec  1 10:05:11 localhost systemd-resolved[21781]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
Dec  1 10:05:11 localhost systemd-resolved[21781]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa 28.172.in-addr.arpa 29.172.in-addr.arpa 30.172.in-addr.arpa 31.172.in-addr.arpa 168.192.in-addr.arpa d.f.ip6.arpa corp home internal intranet lan local private test
Dec  1 10:05:11 localhost systemd-resolved[21781]: Using system hostname 'helios64'.
Dec  1 10:05:11 localhost sh[21782]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
Dec  1 10:05:11 localhost systemd[1]: Started Network Name Resolution.
Dec  1 10:05:11 localhost systemd[1]: Reached target Host and Network Name Lookups.
Dec  1 10:05:11 localhost systemd[1]: Reloading.
Dec  1 10:05:11 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:11 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:12 localhost systemd[1]: Reloading.
Dec  1 10:05:12 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:12 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:13 localhost systemd[1]: Reloading.
Dec  1 10:05:13 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:13 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:14 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:14 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:14 localhost systemd[1]: Reloading.
Dec  1 10:05:50 localhost systemd-udevd[22335]: Using default interface naming scheme 'v240'.
Dec  1 10:05:50 localhost systemd-udevd[22345]: Process '/bin/ln -sf /sys/devices/platform/ff120000.i2c/i2c-2/2-004c/hwmon/hwmon2 /dev/thermal-board' failed with exit code 1.
Dec  1 10:05:51 localhost systemd-udevd[22330]: Process '/bin/ln -sf /sys/devices/platform/p6-fan/hwmon/hwmon6 /dev/fan-p6' failed with exit code 1.
Dec  1 10:05:51 localhost systemd-udevd[22345]: Process '/bin/ln -sf /sys/devices/platform/p7-fan/hwmon/hwmon5 /dev/fan-p7' failed with exit code 1.
Dec  1 10:05:51 localhost systemd[1]: Started /usr/bin/systemctl start fstrim.timer.
Dec  1 10:05:51 localhost systemd[1]: Started Discard unused blocks once a week.
Dec  1 10:05:51 localhost systemd[1]: run-r510d753fd5974a238626d26155324aac.scope: Succeeded.
Dec  1 10:05:51 localhost systemd-udevd[22336]: Process '/bin/ln -sf /sys/devices/virtual/thermal/thermal_zone0/hwmon0 /dev/thermal-cpu' failed with exit code 1.
Dec  1 10:05:51 localhost systemd-udevd[22351]: Using default interface naming scheme 'v240'.
Dec  1 10:05:51 localhost systemd[1]: Started /usr/bin/systemctl enable fstrim.timer.
Dec  1 10:05:51 localhost systemd[1]: Reloading.
Dec  1 10:05:51 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:05:51 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:05:51 localhost systemd[1]: run-r926a0940eb6a4c9ab9dc5a1ef55a7bdc.scope: Succeeded.
Dec  1 10:06:01 localhost systemd[1]: lvm2-lvmpolld.service: Succeeded.
Dec  1 10:06:09 localhost systemd[1]: Started /usr/bin/systemctl restart cpufrequtils.service.
Dec  1 10:06:09 localhost systemd[1]: Stopping LSB: set CPUFreq kernel parameters...
Dec  1 10:06:09 localhost systemd[1]: cpufrequtils.service: Succeeded.
Dec  1 10:06:09 localhost systemd[1]: Stopped LSB: set CPUFreq kernel parameters.
Dec  1 10:06:09 localhost systemd[1]: Starting LSB: set CPUFreq kernel parameters...
Dec  1 10:06:09 localhost cpufrequtils[22552]: CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...CPU2...CPU3...CPU4...CPU5...done.
Dec  1 10:06:10 localhost systemd[1]: Started LSB: set CPUFreq kernel parameters.
Dec  1 10:06:10 localhost systemd[1]: run-r4e302e3290b947009cc1295076047193.scope: Succeeded.
Dec  1 10:06:10 localhost systemd[1]: Started /usr/bin/systemctl restart loadcpufreq.service.
Dec  1 10:06:10 localhost systemd[1]: Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
Dec  1 10:06:10 localhost systemd[1]: loadcpufreq.service: Succeeded.
Dec  1 10:06:10 localhost systemd[1]: Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
Dec  1 10:06:10 localhost systemd[1]: Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Dec  1 10:06:10 localhost loadcpufreq[22576]: Loading cpufreq kernel modules...done (none).
Dec  1 10:06:10 localhost systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling.
Dec  1 10:06:10 localhost systemd[1]: run-rdd617b9cddf04528b527cb011ac1e048.scope: Succeeded.
Dec  1 10:06:11 localhost systemd[1]: Started /usr/bin/systemctl reload monit.service.
Dec  1 10:06:11 localhost systemd[1]: Reloading LSB: service and resource monitoring daemon.
Dec  1 10:06:11 localhost monit[22616]: Reloading daemon monitor configuration: monit.
Dec  1 10:06:11 localhost systemd[1]: Reloaded LSB: service and resource monitoring daemon.
Dec  1 10:06:11 localhost systemd[1]: run-r842030ff359645b78feb5a5381febae9.scope: Succeeded.
Dec  1 10:06:11 localhost monit[5068]: '\helios64' Monit reloaded
Dec  1 10:06:11 localhost monit[5068]: 'omv-engined' process is not running
Dec  1 10:06:11 localhost monit[5068]: 'omv-engined' trying to restart
Dec  1 10:06:11 localhost monit[5068]: 'omv-engined' start: '/bin/systemctl start openmediavault-engined'
Dec  1 10:06:11 localhost systemd[1]: Starting The OpenMediaVault engine daemon that processes the RPC request...
Dec  1 10:06:11 localhost systemd[1]: openmediavault-engined.service: Supervising process 22624 which is not our child. We'll most likely not notice when it exits.
Dec  1 10:06:11 localhost systemd[1]: Started The OpenMediaVault engine daemon that processes the RPC request.
Dec  1 10:06:13 localhost systemd[1]: Started /usr/bin/systemctl restart rrdcached.service.
Dec  1 10:06:13 localhost systemd[1]: Stopping LSB: start or stop rrdcached...
Dec  1 10:06:13 localhost rrdcached[22642]: rrdcached has been stopped.
Dec  1 10:06:13 localhost systemd[1]: rrdcached.service: Succeeded.
Dec  1 10:06:13 localhost systemd[1]: Stopped LSB: start or stop rrdcached.
Dec  1 10:06:13 localhost systemd[1]: Starting LSB: start or stop rrdcached...
Dec  1 10:06:13 localhost rrdcached[22653]: rrdcached started.
Dec  1 10:06:13 localhost systemd[1]: Started LSB: start or stop rrdcached.
Dec  1 10:06:13 localhost systemd[1]: run-r7f96b3bc2cdb4f93bb852aa3906b5e2e.scope: Succeeded.
Dec  1 10:06:13 localhost systemd[1]: Started /usr/bin/systemctl mask avahi-daemon.service.
Dec  1 10:06:13 localhost systemd[1]: Reloading.
Dec  1 10:06:14 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:06:14 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:06:14 localhost systemd[1]: avahi-daemon.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Dec  1 10:06:14 localhost systemd[1]: run-r2cb0f0e8d37a4095b6a870f7c23a1f9f.scope: Succeeded.
Dec  1 10:06:14 localhost systemd[1]: Started /usr/bin/systemctl stop avahi-daemon.socket.
Dec  1 10:06:14 localhost systemd[1]: avahi-daemon.socket: Succeeded.
Dec  1 10:06:14 localhost systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Dec  1 10:06:14 localhost systemd[1]: run-rfed813fba190434f8d0404ed3dd0196a.scope: Succeeded.
Dec  1 10:06:14 localhost systemd[1]: Started /usr/bin/systemctl disable avahi-daemon.socket.
Dec  1 10:06:14 localhost systemd[1]: Reloading.
Dec  1 10:06:15 localhost systemd[1]: run-r63d9efa82c414321931d91c34eb8f533.scope: Succeeded.
Dec  1 10:06:15 localhost systemd[1]: Started /usr/bin/systemctl stop avahi-daemon.service.
Dec  1 10:06:15 localhost avahi-daemon[20515]: Got SIGTERM, quitting.
Dec  1 10:06:15 localhost avahi-daemon[20515]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::a738:86aa:ee73:de3e.
Dec  1 10:06:15 localhost systemd[1]: Stopping avahi-daemon.service...
Dec  1 10:06:15 localhost avahi-daemon[20515]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.0.190.
Dec  1 10:06:15 localhost avahi-daemon[20515]: avahi-daemon 0.7 exiting.
Dec  1 10:06:15 localhost systemd[1]: avahi-daemon.service: Succeeded.
Dec  1 10:06:15 localhost systemd[1]: Stopped avahi-daemon.service.
Dec  1 10:06:15 localhost systemd[1]: run-rc94df65b180042e2ab5677fa900960a4.scope: Succeeded.
Dec  1 10:06:15 localhost systemd[1]: Started /usr/bin/systemctl unmask avahi-daemon.service.
Dec  1 10:06:15 localhost systemd[1]: Reloading.
Dec  1 10:06:15 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:06:15 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:06:16 localhost systemd[1]: run-r73dba4ad5fe348baa3aaeeca6cc0bfef.scope: Succeeded.
Dec  1 10:06:16 localhost systemd[1]: Started /usr/bin/systemctl start avahi-daemon.socket.
Dec  1 10:06:16 localhost systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Dec  1 10:06:16 localhost systemd[1]: run-rc28277d64b584aad8ca5457ece82bacf.scope: Succeeded.
Dec  1 10:06:16 localhost systemd[1]: Started /usr/bin/systemctl enable avahi-daemon.socket.
Dec  1 10:06:16 localhost systemd[1]: Reloading.
Dec  1 10:06:16 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:06:16 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:06:16 localhost systemd[1]: run-rc39414b490bf47d08cc8765252bfc15a.scope: Succeeded.
Dec  1 10:06:16 localhost systemd[1]: Started /usr/bin/systemctl start avahi-daemon.service.
Dec  1 10:06:16 localhost systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Dec  1 10:06:16 localhost avahi-daemon[22783]: Process 20515 died: No such process; trying to remove PID file. (/run/avahi-daemon//pid)
Dec  1 10:06:16 localhost avahi-daemon[22783]: Found user 'avahi' (UID 113) and group 'avahi' (GID 119).
Dec  1 10:06:16 localhost avahi-daemon[22783]: Successfully dropped root privileges.
Dec  1 10:06:16 localhost avahi-daemon[22783]: avahi-daemon 0.7 starting up.
Dec  1 10:06:16 localhost systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Dec  1 10:06:16 localhost avahi-daemon[22783]: Successfully called chroot().
Dec  1 10:06:16 localhost avahi-daemon[22783]: Successfully dropped remaining capabilities.
Dec  1 10:06:16 localhost avahi-daemon[22783]: Loading service file /services/ssh.service.
Dec  1 10:06:16 localhost avahi-daemon[22783]: Loading service file /services/website.service.
Dec  1 10:06:16 localhost avahi-daemon[22783]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::a738:86aa:ee73:de3e.
Dec  1 10:06:16 localhost avahi-daemon[22783]: New relevant interface eth0.IPv6 for mDNS.
Dec  1 10:06:16 localhost avahi-daemon[22783]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.190.
Dec  1 10:06:16 localhost systemd[1]: run-rb3982bf334f24b06a950135bc2c5123c.scope: Succeeded.
Dec  1 10:06:16 localhost avahi-daemon[22783]: New relevant interface eth0.IPv4 for mDNS.
Dec  1 10:06:16 localhost avahi-daemon[22783]: Network interface enumeration completed.
Dec  1 10:06:16 localhost avahi-daemon[22783]: Registering new address record for fe80::a738:86aa:ee73:de3e on eth0.*.
Dec  1 10:06:16 localhost avahi-daemon[22783]: Registering new address record for 192.168.0.190 on eth0.IPv4.
Dec  1 10:06:17 localhost systemd[1]: Started /usr/bin/systemctl restart ssh.service.
Dec  1 10:06:17 localhost systemd[1]: Stopping OpenBSD Secure Shell server...
Dec  1 10:06:17 localhost systemd[1]: ssh.service: Succeeded.
Dec  1 10:06:17 localhost systemd[1]: Stopped OpenBSD Secure Shell server.
Dec  1 10:06:17 localhost systemd[1]: Starting OpenBSD Secure Shell server...
Dec  1 10:06:17 localhost sshd[22793]: Could not load host key: /etc/ssh/ssh_host_dsa_key
Dec  1 10:06:17 localhost sshd[22794]: Could not load host key: /etc/ssh/ssh_host_dsa_key
Dec  1 10:06:17 localhost systemd[1]: Started OpenBSD Secure Shell server.
Dec  1 10:06:17 localhost systemd[1]: run-r775c1158534e4b808ae95e5d20f59df5.scope: Succeeded.
Dec  1 10:06:17 localhost avahi-daemon[22783]: Server startup complete. Host name is helios64.local. Local service cookie is 1080910810.
Dec  1 10:06:18 localhost avahi-daemon[22783]: Service "helios64 - Web control panel" (/services/website.service) successfully established.
Dec  1 10:06:18 localhost avahi-daemon[22783]: Service "helios64 - SSH" (/services/ssh.service) successfully established.
Dec  1 10:06:23 localhost systemd[1]: Started /usr/bin/systemctl restart nginx.service.
Dec  1 10:06:23 localhost systemd[1]: Stopping A high performance web server and a reverse proxy server...
Dec  1 10:06:23 localhost systemd[1]: nginx.service: Succeeded.
Dec  1 10:06:23 localhost systemd[1]: Stopped A high performance web server and a reverse proxy server.
Dec  1 10:06:23 localhost systemd[1]: Starting A high performance web server and a reverse proxy server...
Dec  1 10:06:23 localhost systemd[1]: Started A high performance web server and a reverse proxy server.
Dec  1 10:06:23 localhost systemd[1]: run-r676e3a3523b94709b5059fb4a4f45d36.scope: Succeeded.
Dec  1 10:06:26 localhost systemd[1]: Started /usr/bin/systemctl restart collectd.service.
Dec  1 10:06:26 localhost collectd[20566]: Exiting normally.
Dec  1 10:06:26 localhost collectd[20566]: collectd: Stopping 5 read threads.
Dec  1 10:06:26 localhost collectd[20566]: collectd: Stopping 5 write threads.
Dec  1 10:06:26 localhost systemd[1]: Stopping Statistics collection and monitoring daemon...
Dec  1 10:06:26 localhost collectd[20566]: rrdtool plugin: Shutting down the queue thread.
Dec  1 10:06:26 localhost systemd[1]: collectd.service: Succeeded.
Dec  1 10:06:26 localhost systemd[1]: Stopped Statistics collection and monitoring daemon.
Dec  1 10:06:26 localhost systemd[1]: Starting Statistics collection and monitoring daemon...
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "cpu" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "df" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "interface" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "load" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "memory" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "rrdcached" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "syslog" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "unixsock" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: plugin_load: plugin "uptime" successfully loaded.
Dec  1 10:06:26 localhost collectd[24139]: Systemd detected, trying to signal readyness.
Dec  1 10:06:26 localhost systemd[1]: Started Statistics collection and monitoring daemon.
Dec  1 10:06:26 localhost collectd[24139]: Initialization complete, entering read-loop.
Dec  1 10:06:26 localhost systemd[1]: run-rb9b7401ce32d4414b9f6ca39d079a785.scope: Succeeded.
Dec  1 10:06:31 localhost systemd[1]: Started /usr/bin/systemctl restart php7.3-fpm.service.
Dec  1 10:06:31 localhost systemd[1]: Stopping The PHP 7.3 FastCGI Process Manager...
Dec  1 10:06:31 localhost systemd[1]: php7.3-fpm.service: Succeeded.
Dec  1 10:06:31 localhost systemd[1]: Stopped The PHP 7.3 FastCGI Process Manager.
Dec  1 10:06:31 localhost systemd[1]: Starting The PHP 7.3 FastCGI Process Manager...
Dec  1 10:06:31 localhost systemd[1]: Started The PHP 7.3 FastCGI Process Manager.
Dec  1 10:06:31 localhost systemd[1]: run-r4922039eb7264b99ba863c6cb49ae639.scope: Succeeded.
Dec  1 10:06:33 localhost systemd[1]: Started /usr/bin/systemctl restart systemd-logind.service.
Dec  1 10:06:33 localhost systemd[1]: Stopping Login Service...
Dec  1 10:06:33 localhost systemd[1]: systemd-logind.service: Succeeded.
Dec  1 10:06:33 localhost systemd[1]: Stopped Login Service.
Dec  1 10:06:33 localhost systemd[1]: Starting Login Service...
Dec  1 10:06:33 localhost systemd[1]: Started Login Service.
Dec  1 10:06:33 localhost systemd[1]: run-r3d2930036e654b83a3a84142198f2fae.scope: Succeeded.
Dec  1 10:06:34 localhost systemd[1]: Reloading.
Dec  1 10:06:34 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:06:34 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:06:34 localhost systemd[1]: Stopping System Logging Service...
Dec  1 10:06:34 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="4044" x-info="https://www.rsyslog.com"] exiting on signal 15.
Dec  1 10:06:34 localhost systemd[1]: rsyslog.service: Succeeded.
Dec  1 10:06:34 localhost systemd[1]: Stopped System Logging Service.
Dec  1 10:06:34 localhost systemd[1]: Starting System Logging Service...
Dec  1 10:06:34 localhost rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Dec  1 10:06:34 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="24299" x-info="https://www.rsyslog.com"] start
Dec  1 10:06:34 localhost systemd[1]: Started System Logging Service.
Dec  1 10:06:39 localhost dbus-daemon[896]: [system] Reloaded configuration
Dec  1 10:06:41 localhost monit[5068]: 'omv-engined' process is running with pid 22624
Dec  1 10:07:04 localhost monit[5068]: 'omv-engined' restart on user request
Dec  1 10:07:04 localhost monit[5068]: Monit daemon with PID 5068 awakened
Dec  1 10:07:04 localhost monit[5068]: Awakened by User defined signal 1
Dec  1 10:07:04 localhost monit[5068]: 'omv-engined' trying to restart
Dec  1 10:07:04 localhost monit[5068]: 'omv-engined' stop: '/bin/systemctl stop openmediavault-engined'
Dec  1 10:07:04 localhost systemd[1]: Stopping The OpenMediaVault engine daemon that processes the RPC request...
Dec  1 10:07:04 localhost systemd[1]: openmediavault-engined.service: Succeeded.
Dec  1 10:07:04 localhost systemd[1]: Stopped The OpenMediaVault engine daemon that processes the RPC request.
Dec  1 10:07:04 localhost monit[5068]: 'omv-engined' start: '/bin/systemctl start openmediavault-engined'
Dec  1 10:07:04 localhost systemd[1]: Starting The OpenMediaVault engine daemon that processes the RPC request...
Dec  1 10:07:04 localhost systemd[1]: openmediavault-engined.service: Supervising process 29196 which is not our child. We'll most likely not notice when it exits.
Dec  1 10:07:04 localhost systemd[1]: Started The OpenMediaVault engine daemon that processes the RPC request.
Dec  1 10:07:04 localhost monit[5068]: 'omv-engined' restart action done
Dec  1 10:07:18 localhost dbus-daemon[896]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.43' (uid=0 pid=29575 comm="timedatectl ")
Dec  1 10:07:18 localhost systemd[1]: Starting Time & Date Service...
Dec  1 10:07:19 localhost dbus-daemon[896]: [system] Successfully activated service 'org.freedesktop.timedate1'
Dec  1 10:07:19 localhost systemd[1]: Started Time & Date Service.
Dec  1 10:07:36 localhost monit[5068]: 'omv-engined' restart on user request
Dec  1 10:07:36 localhost monit[5068]: Monit daemon with PID 5068 awakened
Dec  1 10:07:36 localhost monit[5068]: Awakened by User defined signal 1
Dec  1 10:07:36 localhost monit[5068]: 'omv-engined' trying to restart
Dec  1 10:07:36 localhost monit[5068]: 'omv-engined' stop: '/bin/systemctl stop openmediavault-engined'
Dec  1 10:07:36 localhost systemd[1]: openmediavault-engined.service: Killing process 29196 (omv-engined) with signal SIGKILL.
Dec  1 10:07:36 localhost systemd[1]: openmediavault-engined.service: Succeeded.
Dec  1 10:07:36 localhost systemd[1]: Stopped The OpenMediaVault engine daemon that processes the RPC request.
Dec  1 10:07:36 localhost monit[5068]: 'omv-engined' start: '/bin/systemctl start openmediavault-engined'
Dec  1 10:07:36 localhost systemd[1]: Starting The OpenMediaVault engine daemon that processes the RPC request...
Dec  1 10:07:36 localhost systemd[1]: openmediavault-engined.service: Supervising process 30192 which is not our child. We'll most likely not notice when it exits.
Dec  1 10:07:36 localhost systemd[1]: Started The OpenMediaVault engine daemon that processes the RPC request.
Dec  1 10:07:36 localhost monit[5068]: 'omv-engined' restart action done
Dec  1 10:07:49 localhost systemd[1]: systemd-timedated.service: Succeeded.
Dec  1 10:08:44 localhost systemd[1]: Stopping Armbian memory supported logging...
Dec  1 10:08:44 localhost armbian-ramlog[31074]: Tue Dec  1 10:08:44 CST 2020: Syncing logs to storage
Dec  1 10:08:44 localhost armbian-ramlog[31074]: sending incremental file list
Dec  1 10:08:44 localhost armbian-ramlog[31074]: ./
Dec  1 10:08:44 localhost armbian-ramlog[31074]: alternatives.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: armbian-hardware-monitor.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: auth.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: daemon.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: debug
Dec  1 10:08:44 localhost armbian-ramlog[31074]: dpkg.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: faillog
Dec  1 10:08:44 localhost armbian-ramlog[31074]: fontconfig.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: kern.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: lastlog
Dec  1 10:08:44 localhost armbian-ramlog[31074]: mail.info
Dec  1 10:08:44 localhost armbian-ramlog[31074]: mail.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: messages
Dec  1 10:08:44 localhost armbian-ramlog[31074]: monit.log
Dec  1 10:08:44 localhost armbian-ramlog[31074]: omv_install.log
Dec  1 10:12:02 localhost systemd[1]: Stopping System Logging Service...
Dec  1 10:12:02 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="24299" x-info="https://www.rsyslog.com"] exiting on signal 15.
Dec  1 10:12:02 localhost systemd[1]: rsyslog.service: Succeeded.
Dec  1 10:12:02 localhost systemd[1]: Stopped System Logging Service.
Dec  1 10:12:02 localhost systemd[1]: Starting System Logging Service...
Dec  1 10:12:02 localhost systemd[1]: Started System Logging Service.
Dec  1 10:12:02 localhost rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Dec  1 10:12:02 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="3915" x-info="https://www.rsyslog.com"] start
Dec  1 10:12:11 localhost NetworkManager[904]: <info>  [1606839131.9101] caught SIGTERM, shutting down normally.
Dec  1 10:12:11 localhost systemd[1]: Stopping Network Manager...
Dec  1 10:12:11 localhost NetworkManager[904]: <info>  [1606839131.9314] dhcp4 (eth0): canceled DHCP transaction, DHCP client pid 1915
Dec  1 10:12:11 localhost NetworkManager[904]: <info>  [1606839131.9315] dhcp4 (eth0): state changed bound -> done
Dec  1 10:12:11 localhost NetworkManager[904]: <info>  [1606839131.9316] device (eth0): DHCPv4: 480 seconds grace period started
Dec  1 10:12:11 localhost NetworkManager[904]: <info>  [1606839131.9396] exiting (success)
Dec  1 10:12:11 localhost systemd[1]: NetworkManager.service: Succeeded.
Dec  1 10:12:11 localhost systemd[1]: Stopped Network Manager.
Dec  1 10:12:12 localhost systemd[1]: Reloading.
Dec  1 10:12:12 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:12:12 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:12:12 localhost dbus-daemon[896]: [system] Reloaded configuration
Dec  1 10:12:13 localhost systemd[1]: Reloading.
Dec  1 10:12:13 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:12:13 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:12:14 localhost systemd[1]: Reloading.
Dec  1 10:12:14 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:12:14 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:12:15 localhost dbus-daemon[896]: [system] Reloaded configuration
Dec  1 10:12:15 localhost systemd[1]: Reloading.
Dec  1 10:12:15 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:12:15 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:12:16 localhost systemd[1]: Reloading.
Dec  1 10:12:16 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:12:16 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:12:17 localhost systemd[1]: Reloading.
Dec  1 10:12:17 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:12:17 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:12:18 localhost systemd[1]: Reloading.
Dec  1 10:12:18 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:12:18 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:12:28 localhost systemd[1]: Reloading.
Dec  1 10:12:29 localhost systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Dec  1 10:12:29 localhost systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly.
Dec  1 10:12:29 localhost rfkill: unblock set for all
Dec  1 10:12:41 localhost systemd[1]: Stopping Network Service...
Dec  1 10:12:41 localhost systemd[1]: systemd-networkd.service: Succeeded.
Dec  1 10:12:41 localhost systemd[1]: Stopped Network Service.
Dec  1 10:12:41 localhost systemd[1]: Starting Network Service...
Dec  1 10:12:41 localhost systemd-networkd[4564]: eth0: Gained IPv6LL
Dec  1 10:12:41 localhost systemd-networkd[4564]: Enumeration completed
Dec  1 10:12:41 localhost systemd[1]: Started Network Service.
Dec  1 10:12:41 localhost networkd-dispatcher[884]: ERROR:Unable to execute script, check file mode: /usr/lib/networkd-dispatcher/routable.d/10-disable-offloading
Dec  1 10:12:41 localhost avahi-daemon[22783]: Withdrawing address record for 192.168.0.190 on eth0.
Dec  1 10:12:41 localhost avahi-daemon[22783]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.0.190.
Dec  1 10:12:41 localhost avahi-daemon[22783]: Interface eth0.IPv4 no longer relevant for mDNS.
Dec  1 10:12:41 localhost chronyd[2930]: Source 45.55.58.103 offline
Dec  1 10:12:41 localhost chronyd[2930]: Can't synchronise: no selectable sources
Dec  1 10:12:41 localhost systemd-networkd[4564]: eth0: DHCPv4 address 192.168.0.190/24 via 192.168.0.1
Dec  1 10:12:41 localhost avahi-daemon[22783]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.190.
Dec  1 10:12:41 localhost avahi-daemon[22783]: New relevant interface eth0.IPv4 for mDNS.
Dec  1 10:12:41 localhost dbus-daemon[896]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.52' (uid=102 pid=4564 comm="/lib/systemd/systemd-networkd ")
Dec  1 10:12:41 localhost avahi-daemon[22783]: Registering new address record for 192.168.0.190 on eth0.IPv4.
Dec  1 10:12:41 localhost systemd[1]: Starting Hostname Service...
Dec  1 10:12:41 localhost chronyd[2930]: Source 45.55.58.103 online
Dec  1 10:12:41 localhost dbus-daemon[896]: [system] Successfully activated service 'org.freedesktop.hostname1'
Dec  1 10:12:41 localhost systemd[1]: Started Hostname Service.
Dec  1 10:12:42 localhost systemd[1]: lvm2-lvmpolld.socket: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Closed LVM2 poll daemon socket.
Dec  1 10:12:42 localhost systemd[1]: Stopping Session 2 of user root.
Dec  1 10:12:42 localhost systemd[1]: Condition check resulted in Show bootsplash on system halt, power off, reboot, or kexec being skipped.
Dec  1 10:12:42 localhost systemd[1]: Starting Beep before system shutdown...
Dec  1 10:12:42 localhost systemd[1]: Starting folder2ram systemd service...
Dec  1 10:12:42 localhost systemd[1]: Unmounting RPC Pipe File System...
Dec  1 10:12:42 localhost systemd[1]: Stopped target Timers.
Dec  1 10:12:42 localhost systemd[1]: man-db.timer: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopped Daily man-db regeneration.
Dec  1 10:12:42 localhost systemd[1]: logrotate.timer: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopped Daily rotation of log files.
Dec  1 10:12:42 localhost systemd[1]: fstrim.timer: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopped Discard unused blocks once a week.
Dec  1 10:12:42 localhost systemd[1]: apt-daily-upgrade.timer: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopped Daily apt upgrade and clean activities.
Dec  1 10:12:42 localhost systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Dec  1 10:12:42 localhost systemd[1]: systemd-rfkill.socket: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec  1 10:12:42 localhost systemd[1]: Removed slice system-postfix.slice.
Dec  1 10:12:42 localhost systemd[1]: apt-daily.timer: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopped Daily apt download activities.
Dec  1 10:12:42 localhost systemd[1]: Stopping Authorization Manager...
Dec  1 10:12:42 localhost systemd[1]: anacron.timer: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopped Trigger anacron every hour.
Dec  1 10:12:42 localhost systemd[1]: Stopping Availability of block devices...
Dec  1 10:12:42 localhost systemd[1]: phpsessionclean.timer: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopped Clean PHP session files every 30 mins.
Dec  1 10:12:42 localhost folder2ram[4579]: will now stop all mountpoints
Dec  1 10:12:42 localhost systemd[1]: Stopped target System Time Synchronized.
Dec  1 10:12:42 localhost systemd[1]: Stopping Hostname Service...
Dec  1 10:12:42 localhost systemd[1]: Stopped target RPC Port Mapper.
Dec  1 10:12:42 localhost systemd[1]: Stopped target Graphical Interface.
Dec  1 10:12:42 localhost systemd[1]: Stopped target Multi-User System.
Dec  1 10:12:42 localhost systemd[2149]: run-rpc_pipefs.mount: Succeeded.
Dec  1 10:12:42 localhost systemd[1]: Stopping A high performance web server and a reverse proxy server...
Dec  1 10:12:42 localhost systemd[1]: Stopping Regular background program processing daemon...
Dec  1 10:12:42 localhost systemd[1]: Stopping The PHP 7.3 FastCGI Process Manager...
Dec  1 10:12:42 localhost blkdeactivate[4583]: Deactivating block devices:
Dec  1 10:12:42 localhost systemd[1]: Stopping Unattended Upgrades Shutdown...
Dec  1 10:12:42 localhost systemd[1]: Stopping Dispatcher daemon for systemd-networkd...
Dec  1 10:13:15 localhost systemd-modules-load[400]: Inserted module 'lm75'
Dec  1 10:13:15 localhost kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Dec  1 10:13:15 localhost blkmapd[437]: open pipe file /run/rpc_pipefs/nfs/blocklayout failed: No such file or directory
Dec  1 10:13:15 localhost systemd-modules-load[400]: Inserted module 'ledtrig_netdev'
Dec  1 10:13:15 localhost systemd[1]: Starting Flush Journal to Persistent Storage...
Dec  1 10:13:15 localhost kernel: [    0.000000] Linux version 5.9.11-rockchip64 (root@beast) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.11.1 SMP PREEMPT Fri Nov 27 21:59:08 CET 2020
Dec  1 10:13:15 localhost kernel: [    0.000000] Machine model: Helios64
Dec  1 10:13:15 localhost resolvconf[443]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
Dec  1 10:13:15 localhost kernel: [    0.000000] efi: UEFI not found.
Dec  1 10:13:15 localhost kernel: [    0.000000] cma: Reserved 128 MiB at 0x00000000ecc00000
Dec  1 10:13:15 localhost kernel: [    0.000000] NUMA: No NUMA configuration found
Dec  1 10:13:15 localhost systemd[1]: Started Set the console keyboard layout.
Dec  1 10:13:15 localhost kernel: [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 10:13:15 localhost systemd[1]: Reached target Local File Systems (Pre).
Dec  1 10:13:15 localhost kernel: [    0.000000] NUMA: NODE_DATA [mem 0xf77d9100-0xf77dafff]
Dec  1 10:13:15 localhost kernel: [    0.000000] Zone ranges:
Dec  1 10:13:15 localhost kernel: [    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
Dec  1 10:13:15 localhost kernel: [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
Dec  1 10:13:15 localhost kernel: [    0.000000]   Normal   empty
Dec  1 10:13:15 localhost kernel: [    0.000000] Movable zone start for each node
Dec  1 10:13:15 localhost kernel: [    0.000000] Early memory node ranges
Dec  1 10:13:15 localhost systemd[1]: Mounting Mount /tmp as tmpfs to reduce write access to the root device...
Dec  1 10:13:15 localhost kernel: [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 10:13:15 localhost kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
Dec  1 10:13:15 localhost systemd[1]: Mounted Mount /tmp as tmpfs to reduce write access to the root device.
Dec  1 10:13:15 localhost kernel: [    0.000000] On node 0 totalpages: 1015296
Dec  1 10:13:15 localhost kernel: [    0.000000]   DMA zone: 4088 pages used for memmap
Dec  1 10:13:15 localhost kernel: [    0.000000]   DMA zone: 0 pages reserved
Dec  1 10:13:15 localhost systemd[1]: Started udev Kernel Device Manager.
Dec  1 10:13:15 localhost kernel: [    0.000000]   DMA zone: 261632 pages, LIFO batch:63
Dec  1 10:13:15 localhost kernel: [    0.000000]   DMA32 zone: 11776 pages used for memmap
Dec  1 10:13:15 localhost systemd[1]: Starting Network Service...
Dec  1 10:13:15 localhost kernel: [    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
Dec  1 10:13:15 localhost kernel: [    0.000000] psci: probing for conduit method from DT.
Dec  1 10:13:15 localhost systemd[1]: Reached target Local File Systems.
Dec  1 10:13:15 localhost kernel: [    0.000000] psci: PSCIv1.0 detected in firmware.
Dec  1 10:13:15 localhost kernel: [    0.000000] psci: Using standard PSCI v0.2 function IDs
Dec  1 10:13:15 localhost kernel: [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
Dec  1 10:13:15 localhost kernel: [    0.000000] psci: SMC Calling Convention v1.0
Dec  1 10:13:15 localhost kernel: [    0.000000] percpu: Embedded 32 pages/cpu s93784 r8192 d29096 u131072
Dec  1 10:13:15 localhost kernel: [    0.000000] pcpu-alloc: s93784 r8192 d29096 u131072 alloc=32*4096
Dec  1 10:13:15 localhost kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
Dec  1 10:13:15 localhost kernel: [    0.000000] Detected VIPT I-cache on CPU0
Dec  1 10:13:15 localhost kernel: [    0.000000] CPU features: detected: ARM erratum 845719
Dec  1 10:13:15 localhost kernel: [    0.000000] CPU features: detected: GIC system register CPU interface
Dec  1 10:13:15 localhost kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
Dec  1 10:13:15 localhost kernel: [    0.000000] Policy zone: DMA32
Dec  1 10:13:15 localhost kernel: [    0.000000] Kernel command line: root=UUID=a60f3956-17d4-4744-bc2b-021293160020 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=92c32d3c-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
Dec  1 10:13:15 localhost kernel: [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Dec  1 10:13:15 localhost kernel: [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Dec  1 10:13:15 localhost kernel: [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
Dec  1 10:13:15 localhost kernel: [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
Dec  1 10:13:15 localhost kernel: [    0.000000] Memory: 3739996K/4061184K available (14528K kernel code, 2096K rwdata, 5992K rodata, 4224K init, 575K bss, 190116K reserved, 131072K cma-reserved)
Dec  1 10:13:15 localhost kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Dec  1 10:13:15 localhost kernel: [    0.000000] rcu: Preemptible hierarchical RCU implementation.
Dec  1 10:13:15 localhost kernel: [    0.000000] rcu: 	RCU event tracing is enabled.
Dec  1 10:13:15 localhost kernel: [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
Dec  1 10:13:15 localhost kernel: [    0.000000] 	Trampoline variant of Tasks RCU enabled.
Dec  1 10:13:15 localhost kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
Dec  1 10:13:15 localhost kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
Dec  1 10:13:15 localhost kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Dec  1 10:13:15 localhost kernel: [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
Dec  1 10:13:15 localhost kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: 256 SPIs implemented
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: 0 Extended SPIs implemented
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: Distributor has no Range Selector support
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: 16 PPIs implemented
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
Dec  1 10:13:15 localhost kernel: [    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
Dec  1 10:13:15 localhost kernel: [    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @f6d00000 (flat, esz 8, psz 64K, shr 0)
Dec  1 10:13:15 localhost kernel: [    0.000000] ITS: using cache flushing for cmd queue
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: using LPI property table @0x00000000f6cb0000
Dec  1 10:13:15 localhost kernel: [    0.000000] GIC: using cache flushing for LPI property table
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f6cc0000
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
Dec  1 10:13:15 localhost kernel: [    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
Dec  1 10:13:15 localhost kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x690/0x848 with crng_init=0
Dec  1 10:13:15 localhost kernel: [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
Dec  1 10:13:15 localhost kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Dec  1 10:13:15 localhost kernel: [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Dec  1 10:13:15 localhost kernel: [    0.001399] Console: colour dummy device 80x25
Dec  1 10:13:15 localhost kernel: [    0.001416] printk: console [tty1] enabled
Dec  1 10:13:15 localhost kernel: [    0.001543] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
Dec  1 10:13:15 localhost kernel: [    0.001558] pid_max: default: 32768 minimum: 301
Dec  1 10:13:15 localhost systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
Dec  1 10:13:15 localhost kernel: [    0.001709] LSM: Security Framework initializing
Dec  1 10:13:15 localhost kernel: [    0.001754] Yama: becoming mindful.
Dec  1 10:13:15 localhost kernel: [    0.001900] AppArmor: AppArmor initialized
Dec  1 10:13:15 localhost kernel: [    0.001989] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Dec  1 10:13:15 localhost kernel: [    0.002018] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Dec  1 10:13:15 localhost systemd[1]: Starting Cleanup monit state file...
Dec  1 10:13:15 localhost kernel: [    0.005259] rcu: Hierarchical SRCU implementation.
Dec  1 10:13:15 localhost kernel: [    0.006370] Platform MSI: interrupt-controller@fee20000 domain created
Dec  1 10:13:15 localhost kernel: [    0.006929] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
Dec  1 10:13:15 localhost systemd[1]: Starting folder2ram systemd service...
Dec  1 10:13:15 localhost kernel: [    0.009373] EFI services will not be available.
Dec  1 10:13:15 localhost kernel: [    0.010039] smp: Bringing up secondary CPUs ...
Dec  1 10:13:15 localhost kernel: [    0.011066] Detected VIPT I-cache on CPU1
Dec  1 10:13:15 localhost systemd[1]: Starting Set console font and keymap...
Dec  1 10:13:15 localhost kernel: [    0.011115] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
Dec  1 10:13:15 localhost kernel: [    0.011134] GICv3: CPU1: using allocated LPI pending table @0x00000000f6cd0000
Dec  1 10:13:15 localhost systemd[1]: Starting Cleanup PHP session files...
Dec  1 10:13:15 localhost kernel: [    0.011195] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Dec  1 10:13:15 localhost kernel: [    0.012557] Detected VIPT I-cache on CPU2
Dec  1 10:13:15 localhost kernel: [    0.012604] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
Dec  1 10:13:15 localhost kernel: [    0.012623] GICv3: CPU2: using allocated LPI pending table @0x00000000f6ce0000
Dec  1 10:13:15 localhost systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Dec  1 10:13:15 localhost kernel: [    0.012683] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Dec  1 10:13:15 localhost folder2ram[473]: will now start all mountpoints
Dec  1 10:13:15 localhost kernel: [    0.014109] Detected VIPT I-cache on CPU3
Dec  1 10:13:15 localhost kernel: [    0.014153] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
Dec  1 10:13:15 localhost kernel: [    0.014172] GICv3: CPU3: using allocated LPI pending table @0x00000000f6cf0000
Dec  1 10:13:15 localhost kernel: [    0.014233] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Dec  1 10:13:15 localhost kernel: [    0.015611] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
Dec  1 10:13:15 localhost kernel: [    0.015621] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
Dec  1 10:13:15 localhost systemd[1]: Starting Preprocess NFS configuration...
Dec  1 10:13:15 localhost kernel: [    0.015629] Detected PIPT I-cache on CPU4
Dec  1 10:13:15 localhost kernel: [    0.015662] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
Dec  1 10:13:15 localhost systemd[1]: openmediavault-cleanup-monit.service: Succeeded.
Dec  1 10:13:15 localhost kernel: [    0.015676] GICv3: CPU4: using allocated LPI pending table @0x00000000f6d80000
Dec  1 10:13:15 localhost kernel: [    0.015714] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
Dec  1 10:13:15 localhost kernel: [    0.016903] Detected PIPT I-cache on CPU5
Dec  1 10:13:15 localhost kernel: [    0.016939] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
Dec  1 10:13:15 localhost systemd[1]: Started Cleanup monit state file.
Dec  1 10:13:15 localhost kernel: [    0.016954] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d90000
Dec  1 10:13:15 localhost kernel: [    0.016993] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
Dec  1 10:13:15 localhost systemd[1]: openmediavault-cleanup-php.service: Succeeded.
Dec  1 10:13:15 localhost kernel: [    0.017173] smp: Brought up 1 node, 6 CPUs
Dec  1 10:13:15 localhost kernel: [    0.017182] SMP: Total of 6 processors activated.
Dec  1 10:13:15 localhost kernel: [    0.017191] CPU features: detected: 32-bit EL0 Support
Dec  1 10:13:15 localhost systemd[1]: Started Cleanup PHP session files.
Dec  1 10:13:15 localhost kernel: [    0.017200] CPU features: detected: CRC32 instructions
Dec  1 10:13:15 localhost kernel: [    0.017209] CPU features: detected: 32-bit EL1 Support
Dec  1 10:13:15 localhost systemd[1]: Started Set console font and keymap.
Dec  1 10:13:15 localhost systemd[1]: Started Flush Journal to Persistent Storage.
Dec  1 10:13:15 localhost systemd[1]: nfs-config.service: Succeeded.
Dec  1 10:13:15 localhost systemd[1]: Started Preprocess NFS configuration.
Dec  1 10:13:15 localhost systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Dec  1 10:13:15 localhost systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Dec  1 10:13:15 localhost systemd[1]: Reached target NFS client services.
Dec  1 10:13:15 localhost systemd[1]: Starting NFSv4 ID-name mapping service...
Dec  1 10:13:15 localhost systemd[1]: Starting Create Volatile Files and Directories...
Dec  1 10:13:15 localhost systemd[1]: Started NFSv4 ID-name mapping service.
Dec  1 10:13:15 localhost systemd-networkd[466]: Enumeration completed
Dec  1 10:13:15 localhost systemd[1]: Started Network Service.
Dec  1 10:13:15 localhost systemd[1]: Starting Wait for Network to be Configured...
Dec  1 10:13:15 localhost systemd[1]: Started Create Volatile Files and Directories.
Dec  1 10:13:15 localhost systemd[1]: Starting Network Name Resolution...
Dec  1 10:13:15 localhost systemd-networkd-wait-online[510]: ignoring: lo
Dec  1 10:13:15 localhost systemd[1]: Starting RPC bind portmap service...
Dec  1 10:13:15 localhost folder2ram[473]: start /var/log
Dec  1 10:13:15 localhost systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
Dec  1 10:13:15 localhost systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Dec  1 10:13:15 localhost systemd[1]: Started RPC bind portmap service.
Dec  1 10:13:15 localhost systemd[1]: Reached target RPC Port Mapper.
Dec  1 10:13:15 localhost systemd[1]: Started Update UTMP about System Boot/Shutdown.
Dec  1 10:13:15 localhost kernel: [    0.045412] CPU: All CPU(s) started at EL2
Dec  1 10:13:15 localhost systemd[1]: Started udev Coldplug all Devices.
Dec  1 10:13:15 localhost kernel: [    0.045476] alternatives: patching kernel code
Dec  1 10:13:15 localhost systemd[1]: Reached target System Initialization.
Dec  1 10:13:15 localhost kernel: [    0.049186] devtmpfs: initialized
Dec  1 10:13:15 localhost kernel: [    0.065891] Registered cp15_barrier emulation handler
Dec  1 10:13:15 localhost kernel: [    0.065912] Registered setend emulation handler
Dec  1 10:13:15 localhost systemd[1]: Started Daily apt download activities.
Dec  1 10:13:15 localhost kernel: [    0.066690] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Dec  1 10:13:15 localhost kernel: [    0.066760] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Dec  1 10:13:15 localhost systemd[1]: Started Clean PHP session files every 30 mins.
Dec  1 10:13:15 localhost kernel: [    0.069872] xor: measuring software checksum speed
Dec  1 10:13:15 localhost kernel: [    0.109405]    8regs     :  2345.000 MB/sec
Dec  1 10:13:15 localhost kernel: [    0.149489]    32regs    :  2757.000 MB/sec
Dec  1 10:13:15 localhost systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec  1 10:13:15 localhost kernel: [    0.189576]    arm64_neon:  2226.000 MB/sec
Dec  1 10:13:15 localhost kernel: [    0.189582] xor: using function: 32regs (2757.000 MB/sec)
Dec  1 10:13:15 localhost kernel: [    0.189638] pinctrl core: initialized pinctrl subsystem
Dec  1 10:13:15 localhost systemd[1]: Starting Armbian hardware monitoring...
Dec  1 10:13:15 localhost kernel: [    0.190301] DMI not present or invalid.
Dec  1 10:13:15 localhost systemd[1]: Started Daily apt upgrade and clean activities.
Dec  1 10:13:15 localhost systemd[1]: Listening on D-Bus System Message Bus Socket.
Dec  1 10:13:15 localhost kernel: [    0.190902] NET: Registered protocol family 16
Dec  1 10:13:15 localhost kernel: [    0.193675] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Dec  1 10:13:15 localhost kernel: [    0.195123] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Dec  1 10:13:15 localhost systemd[1]: Starting Armbian hardware optimization...
Dec  1 10:13:15 localhost kernel: [    0.195894] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Dec  1 10:13:15 localhost kernel: [    0.195999] audit: initializing netlink subsys (disabled)
Dec  1 10:13:15 localhost kernel: [    0.196315] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
Dec  1 10:13:15 localhost systemd[1]: Started Daily rotation of log files.
Dec  1 10:13:15 localhost kernel: [    0.197535] thermal_sys: Registered thermal governor 'fair_share'
Dec  1 10:13:15 localhost kernel: [    0.197539] thermal_sys: Registered thermal governor 'bang_bang'
Dec  1 10:13:15 localhost kernel: [    0.197546] thermal_sys: Registered thermal governor 'step_wise'
Dec  1 10:13:15 localhost systemd[1]: Started Daily man-db regeneration.
Dec  1 10:13:15 localhost kernel: [    0.197552] thermal_sys: Registered thermal governor 'user_space'
Dec  1 10:13:15 localhost kernel: [    0.198045] cpuidle: using governor menu
Dec  1 10:13:15 localhost kernel: [    0.198376] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Dec  1 10:13:15 localhost kernel: [    0.198595] ASID allocator initialised with 65536 entries
Dec  1 10:13:15 localhost systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Dec  1 10:13:15 localhost kernel: [    0.199848] Serial: AMBA PL011 UART driver
Dec  1 10:13:15 localhost systemd[1]: Reached target Sockets.
Dec  1 10:13:15 localhost kernel: [    0.266993] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Dec  1 10:13:15 localhost kernel: [    0.267004] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Dec  1 10:13:15 localhost kernel: [    0.267011] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Dec  1 10:13:15 localhost systemd[1]: Started Trigger anacron every hour.
Dec  1 10:13:15 localhost kernel: [    0.267018] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Dec  1 10:13:15 localhost kernel: [    0.272530] cryptd: max_cpu_qlen set to 1000
Dec  1 10:13:15 localhost systemd[1]: Started Discard unused blocks once a week.
Dec  1 10:13:15 localhost kernel: [    0.350009] raid6: neonx8   gen()  1667 MB/s
Dec  1 10:13:15 localhost kernel: [    0.418156] raid6: neonx8   xor()  1223 MB/s
Dec  1 10:13:15 localhost systemd[1]: Reached target Timers.
Dec  1 10:13:15 localhost systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Dec  1 10:13:15 localhost systemd[1]: Started Armbian hardware monitoring.
Dec  1 10:13:15 localhost systemd[1]: Started Helper to synchronize boot up for ifupdown.
Dec  1 10:13:15 localhost systemd-resolved[514]: Positive Trust Anchors:
Dec  1 10:13:15 localhost systemd-resolved[514]: . IN DS 19036 8 2 49aac11d7b6f6446702e54a1607371607a1a41855200fd2ce1cdde32f24e8fb5
Dec  1 10:13:15 localhost systemd-resolved[514]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
Dec  1 10:13:15 localhost systemd-resolved[514]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa 28.172.in-addr.arpa 29.172.in-addr.arpa 30.172.in-addr.arpa 31.172.in-addr.arpa 168.192.in-addr.arpa d.f.ip6.arpa corp home internal intranet lan local private test
Dec  1 10:13:15 localhost systemd-resolved[514]: Using system hostname 'helios64'.
Dec  1 10:13:15 localhost folder2ram[473]: start /var/tmp
Dec  1 10:13:15 localhost systemd[1]: Starting Raise network interfaces...
Dec  1 10:13:15 localhost armbian-hardware-optimization[569]: aplay: device_list:272: no soundcards found...
Dec  1 10:13:15 localhost systemd[1]: Started Armbian hardware optimization.
Dec  1 10:13:15 localhost sh[590]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
Dec  1 10:13:15 localhost systemd-udevd[531]: Using default interface naming scheme 'v240'.
Dec  1 10:13:15 localhost systemd-udevd[531]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Dec  1 10:13:15 localhost systemd[1]: Found device /dev/ttyS2.
Dec  1 10:13:15 localhost systemd[1]: Started Network Name Resolution.
Dec  1 10:13:15 localhost systemd[1]: Reached target Host and Network Name Lookups.
Dec  1 10:13:15 localhost armbian-hardware-optimization[569]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1
Dec  1 10:13:15 localhost armbian-hardware-optimization[569]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1boot0
Dec  1 10:13:15 localhost folder2ram[473]: start /var/lib/openmediavault/rrd
Dec  1 10:13:15 localhost armbian-hardware-optimization[569]: [#033[0;32m ok #033[0m] Setting none I/O scheduler for mmcblk1boot1
Dec  1 10:13:15 localhost systemd[1]: Started Raise network interfaces.
Dec  1 10:13:15 localhost folder2ram[473]: start /var/spool
Dec  1 10:13:15 localhost haveged[526]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 8.3.0 CTV); collect: 128K
Dec  1 10:13:15 localhost haveged[526]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 15528/64688
Dec  1 10:13:15 localhost haveged[526]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.00199
Dec  1 10:13:15 localhost haveged[526]: haveged: fills: 0, generated: 0
Dec  1 10:13:15 localhost folder2ram[473]: start /var/lib/rrdcached
Dec  1 10:13:15 localhost systemd-udevd[537]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Dec  1 10:13:15 localhost systemd-udevd[475]: Process '/bin/ln -sf /sys/devices/virtual/thermal/thermal_zone0/hwmon0 /dev/thermal-cpu' failed with exit code 1.
Dec  1 10:13:15 localhost folder2ram[473]: start /var/lib/monit
Dec  1 10:13:15 localhost folder2ram[473]: start /var/cache/samba
Dec  1 10:13:15 localhost systemd-udevd[501]: Using default interface naming scheme 'v240'.
Dec  1 10:13:15 localhost systemd-udevd[501]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Dec  1 10:13:15 localhost systemd[1]: Started folder2ram systemd service.
Dec  1 10:13:15 localhost systemd[1]: Reached target Basic System.
Dec  1 10:13:15 localhost systemd[1]: Starting System Logging Service...
Dec  1 10:13:15 localhost systemd[1]: Started D-Bus System Message Bus.
Dec  1 10:13:15 localhost systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Dec  1 10:13:15 localhost systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Dec  1 10:13:15 localhost systemd[1]: Starting Login Service...
Dec  1 10:13:15 localhost systemd[1]: Started Run anacron jobs.
Dec  1 10:13:15 localhost systemd[1]: Starting WPA supplicant...
Dec  1 10:13:15 localhost systemd[1]: Starting fan speed regulator...
Dec  1 10:13:15 localhost anacron[1214]: Anacron 2.3 started on 2020-12-01
Dec  1 10:13:15 localhost systemd[1]: Starting Resets System Activity Data Collector...
Dec  1 10:13:15 localhost anacron[1214]: Will run job `cron.daily' in 5 min.
Dec  1 10:13:15 localhost anacron[1214]: Will run job `cron.weekly' in 10 min.
Dec  1 10:13:15 localhost anacron[1214]: Will run job `cron.monthly' in 15 min.
Dec  1 10:13:15 localhost anacron[1214]: Jobs will be executed sequentially
Dec  1 10:13:15 localhost systemd[1]: Started Self Monitoring and Reporting Technology (SMART) Daemon.
Dec  1 10:13:15 localhost systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Dec  1 10:13:15 localhost avahi-daemon[1210]: Found user 'avahi' (UID 113) and group 'avahi' (GID 119).
Dec  1 10:13:15 localhost avahi-daemon[1210]: Successfully dropped root privileges.
Dec  1 10:13:15 localhost avahi-daemon[1210]: avahi-daemon 0.7 starting up.
Dec  1 10:13:15 localhost fancontrol[1216]: Loading configuration from /etc/fancontrol ...
Dec  1 10:13:15 localhost systemd[1]: Started Resets System Activity Data Collector.
Dec  1 10:13:15 localhost rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Dec  1 10:13:15 localhost rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="1206" x-info="https://www.rsyslog.com"] start
Dec  1 10:13:15 localhost kernel: [    0.486311] raid6: neonx4   gen()  1684 MB/s
Dec  1 10:13:15 localhost kernel: [    0.554474] raid6: neonx4   xor()  1265 MB/s
Dec  1 10:13:15 localhost kernel: [    0.622620] raid6: neonx2   gen()  1501 MB/s
Dec  1 10:13:15 localhost kernel: [    0.690776] raid6: neonx2   xor()  1160 MB/s
Dec  1 10:13:15 localhost kernel: [    0.758940] raid6: neonx1   gen()  1183 MB/s
Dec  1 10:13:15 localhost kernel: [    0.827084] raid6: neonx1   xor()   942 MB/s
Dec  1 10:13:15 localhost kernel: [    0.895284] raid6: int64x8  gen()   993 MB/s
Dec  1 10:13:15 localhost kernel: [    0.963484] raid6: int64x8  xor()   391 MB/s
Dec  1 10:13:15 localhost kernel: [    1.031588] raid6: int64x4  gen()   987 MB/s
Dec  1 10:13:15 localhost kernel: [    1.099737] raid6: int64x4  xor()   589 MB/s
Dec  1 10:13:15 localhost kernel: [    1.167892] raid6: int64x2  gen()   927 MB/s
Dec  1 10:13:15 localhost kernel: [    1.236038] raid6: int64x2  xor()   522 MB/s
Dec  1 10:13:15 localhost kernel: [    1.304207] raid6: int64x1  gen()   724 MB/s
Dec  1 10:13:15 localhost kernel: [    1.372358] raid6: int64x1  xor()   389 MB/s
Dec  1 10:13:15 localhost kernel: [    1.372364] raid6: using algorithm neonx4 gen() 1684 MB/s
Dec  1 10:13:15 localhost kernel: [    1.372369] raid6: .... xor() 1265 MB/s, rmw enabled
Dec  1 10:13:15 localhost kernel: [    1.372375] raid6: using neon recovery algorithm
Dec  1 10:13:15 localhost kernel: [    1.373885] vcc12v_dcin_bkup: supplied by vcc12v_dcin
Dec  1 10:13:15 localhost kernel: [    1.374344] vcc12v_hdd: supplied by vcc12v_dcin_bkup
Dec  1 10:13:15 localhost kernel: [    1.389166] vcc5v0_perdev: supplied by vcc12v_dcin_bkup
Dec  1 10:13:15 localhost kernel: [    1.389679] pcie_power: supplied by vcc5v0_perdev
Dec  1 10:13:15 localhost kernel: [    1.389789] vcc5v0_usb: supplied by vcc5v0_perdev
Dec  1 10:13:15 localhost kernel: [    1.389857] vcc5v0_typec: supplied by vcc5v0_usb
Dec  1 10:13:15 localhost kernel: [    1.389914] vcc5v0_hdd: supplied by vcc12v_dcin_bkup
Dec  1 10:13:15 localhost kernel: [    1.390548] vcc5v0_sys: supplied by vcc12v_dcin_bkup
Dec  1 10:13:15 localhost kernel: [    1.391060] vcc3v3_sys_s3: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    1.391116] vcc0v9_s3: supplied by vcc3v3_sys_s3
Dec  1 10:13:15 localhost kernel: [    1.391212] avdd_1v8_s0: supplied by vcc3v3_sys_s3
Dec  1 10:13:15 localhost kernel: [    1.391277] vcc3v0_sd: supplied by vcc3v3_sys_s3
Dec  1 10:13:15 localhost kernel: [    1.392261] usblan_power: supplied by vcc5v0_usb
Dec  1 10:13:15 localhost kernel: [    1.392837] iommu: Default domain type: Translated
Dec  1 10:13:15 localhost kernel: [    1.396327] vgaarb: loaded
Dec  1 10:13:15 localhost kernel: [    1.396837] SCSI subsystem initialized
Dec  1 10:13:15 localhost kernel: [    1.397103] libata version 3.00 loaded.
Dec  1 10:13:15 localhost kernel: [    1.397374] usbcore: registered new interface driver usbfs
Dec  1 10:13:15 localhost kernel: [    1.397419] usbcore: registered new interface driver hub
Dec  1 10:13:15 localhost kernel: [    1.397519] usbcore: registered new device driver usb
Dec  1 10:13:15 localhost kernel: [    1.398233] pps_core: LinuxPPS API ver. 1 registered
Dec  1 10:13:15 localhost kernel: [    1.398239] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Dec  1 10:13:15 localhost kernel: [    1.398254] PTP clock support registered
Dec  1 10:13:15 localhost kernel: [    1.398573] EDAC MC: Ver: 3.0.0
Dec  1 10:13:15 localhost kernel: [    1.399762] NetLabel: Initializing
Dec  1 10:13:15 localhost kernel: [    1.399769] NetLabel:  domain hash size = 128
Dec  1 10:13:15 localhost kernel: [    1.399774] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Dec  1 10:13:15 localhost kernel: [    1.399855] NetLabel:  unlabeled traffic allowed by default
Dec  1 10:13:15 localhost kernel: [    1.400355] clocksource: Switched to clocksource arch_sys_counter
Dec  1 10:13:15 localhost kernel: [    1.524669] VFS: Disk quotas dquot_6.6.0
Dec  1 10:13:15 localhost kernel: [    1.524747] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec  1 10:13:15 localhost kernel: [    1.525583] AppArmor: AppArmor Filesystem Enabled
Dec  1 10:13:15 localhost kernel: [    1.534256] NET: Registered protocol family 2
Dec  1 10:13:15 localhost kernel: [    1.535136] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Dec  1 10:13:15 localhost kernel: [    1.535312] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec  1 10:13:15 localhost kernel: [    1.535850] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Dec  1 10:13:15 localhost kernel: [    1.536553] TCP: Hash tables configured (established 32768 bind 32768)
Dec  1 10:13:15 localhost kernel: [    1.536748] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Dec  1 10:13:15 localhost kernel: [    1.536911] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Dec  1 10:13:15 localhost kernel: [    1.537246] NET: Registered protocol family 1
Dec  1 10:13:15 localhost kernel: [    1.537277] NET: Registered protocol family 44
Dec  1 10:13:15 localhost kernel: [    1.537291] PCI: CLS 0 bytes, default 64
Dec  1 10:13:15 localhost kernel: [    1.537526] Trying to unpack rootfs image as initramfs...
Dec  1 10:13:15 localhost kernel: [    2.691006] Freeing initrd memory: 15776K
Dec  1 10:13:15 localhost kernel: [    2.692314] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
Dec  1 10:13:15 localhost kernel: [    2.692774] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Dec  1 10:13:15 localhost kernel: [    2.693470] kvm [1]: IPA Size Limit: 40bits
Dec  1 10:13:15 localhost kernel: [    2.694229] kvm [1]: vgic-v2@fff20000
Dec  1 10:13:15 localhost kernel: [    2.694264] kvm [1]: GIC system register CPU interface enabled
Dec  1 10:13:15 localhost kernel: [    2.694507] kvm [1]: vgic interrupt IRQ10
Dec  1 10:13:15 localhost kernel: [    2.694795] kvm [1]: Hyp mode initialized successfully
Dec  1 10:13:15 localhost kernel: [    2.705908] Initialise system trusted keyrings
Dec  1 10:13:15 localhost kernel: [    2.705954] Key type blacklist registered
Dec  1 10:13:15 localhost kernel: [    2.706150] workingset: timestamp_bits=44 max_order=20 bucket_order=0
Dec  1 10:13:15 localhost kernel: [    2.712719] zbud: loaded
Dec  1 10:13:15 localhost kernel: [    2.714329] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Dec  1 10:13:15 localhost kernel: [    2.715207] fuse: init (API version 7.31)
Dec  1 10:13:15 localhost kernel: [    2.716575] integrity: Platform Keyring initialized
Dec  1 10:13:15 localhost kernel: [    2.779656] Key type asymmetric registered
Dec  1 10:13:15 localhost kernel: [    2.779663] Asymmetric key parser 'x509' registered
Dec  1 10:13:15 localhost kernel: [    2.779715] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
Dec  1 10:13:15 localhost kernel: [    2.779955] io scheduler mq-deadline registered
Dec  1 10:13:15 localhost kernel: [    2.779961] io scheduler kyber registered
Dec  1 10:13:15 localhost kernel: [    2.780095] io scheduler bfq registered
Dec  1 10:13:15 localhost kernel: [    2.798661] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
Dec  1 10:13:15 localhost kernel: [    2.798688] OF: /pcie@f8000000: Missing device_type
Dec  1 10:13:15 localhost kernel: [    2.798720] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
Dec  1 10:13:15 localhost kernel: [    2.798764] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
Dec  1 10:13:15 localhost kernel: [    2.807761] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
Dec  1 10:13:15 localhost kernel: [    2.807774] dma-pl330 ff6d0000.dma-controller: 	DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
Dec  1 10:13:15 localhost kernel: [    2.809287] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
Dec  1 10:13:15 localhost kernel: [    2.809299] dma-pl330 ff6e0000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
Dec  1 10:13:15 localhost kernel: [    2.813824] vdd_log: supplied by regulator-dummy
Dec  1 10:13:15 localhost kernel: [    2.815199] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
Dec  1 10:13:15 localhost kernel: [    2.818358] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
Dec  1 10:13:15 localhost kernel: [    2.819363] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
Dec  1 10:13:15 localhost kernel: [    2.819550] printk: console [ttyS2] enabled
Dec  1 10:13:15 localhost kernel: [    2.820989] Serial: AMBA driver
Dec  1 10:13:15 localhost kernel: [    2.822519] cacheinfo: Unable to detect cache hierarchy for CPU 0
Dec  1 10:13:15 localhost kernel: [    2.834298] loop: module loaded
Dec  1 10:13:15 localhost kernel: [    2.843014] libphy: Fixed MDIO Bus: probed
Dec  1 10:13:15 localhost kernel: [    2.843357] tun: Universal TUN/TAP device driver, 1.6
Dec  1 10:13:15 localhost kernel: [    2.844540] thunder_xcv, ver 1.0
Dec  1 10:13:15 localhost kernel: [    2.844584] thunder_bgx, ver 1.0
Dec  1 10:13:15 localhost kernel: [    2.844628] nicpf, ver 1.0
Dec  1 10:13:15 localhost kernel: [    2.845803] e1000e: Intel(R) PRO/1000 Network Driver
Dec  1 10:13:15 localhost kernel: [    2.845808] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Dec  1 10:13:15 localhost kernel: [    2.845858] igb: Intel(R) Gigabit Ethernet Network Driver
Dec  1 10:13:15 localhost kernel: [    2.845863] igb: Copyright (c) 2007-2014 Intel Corporation.
Dec  1 10:13:15 localhost kernel: [    2.845905] igbvf: Intel(R) Gigabit Virtual Function Network Driver
Dec  1 10:13:15 localhost kernel: [    2.845910] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Dec  1 10:13:15 localhost kernel: [    2.846208] sky2: driver version 1.30
Dec  1 10:13:15 localhost kernel: [    2.846942] VFIO - User Level meta-driver version: 0.3
Dec  1 10:13:15 localhost kernel: [    2.865546] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec  1 10:13:15 localhost kernel: [    2.865569] ehci-pci: EHCI PCI platform driver
Dec  1 10:13:15 localhost kernel: [    2.865609] ehci-platform: EHCI generic platform driver
Dec  1 10:13:15 localhost kernel: [    2.868009] ehci-platform fe380000.usb: EHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    2.868035] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
Dec  1 10:13:15 localhost kernel: [    2.868192] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
Dec  1 10:13:15 localhost kernel: [    2.880377] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
Dec  1 10:13:15 localhost kernel: [    2.880626] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 10:13:15 localhost kernel: [    2.880636] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 10:13:15 localhost kernel: [    2.880644] usb usb1: Product: EHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    2.880651] usb usb1: Manufacturer: Linux 5.9.11-rockchip64 ehci_hcd
Dec  1 10:13:15 localhost kernel: [    2.880658] usb usb1: SerialNumber: fe380000.usb
Dec  1 10:13:15 localhost kernel: [    2.881213] hub 1-0:1.0: USB hub found
Dec  1 10:13:15 localhost kernel: [    2.881260] hub 1-0:1.0: 1 port detected
Dec  1 10:13:15 localhost kernel: [    2.882051] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec  1 10:13:15 localhost kernel: [    2.882072] ohci-pci: OHCI PCI platform driver
Dec  1 10:13:15 localhost kernel: [    2.882127] ohci-platform: OHCI generic platform driver
Dec  1 10:13:15 localhost kernel: [    2.882456] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
Dec  1 10:13:15 localhost kernel: [    2.882476] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 2
Dec  1 10:13:15 localhost kernel: [    2.882604] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
Dec  1 10:13:15 localhost kernel: [    2.944610] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
Dec  1 10:13:15 localhost kernel: [    2.944620] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 10:13:15 localhost kernel: [    2.944628] usb usb2: Product: Generic Platform OHCI controller
Dec  1 10:13:15 localhost kernel: [    2.944635] usb usb2: Manufacturer: Linux 5.9.11-rockchip64 ohci_hcd
Dec  1 10:13:15 localhost kernel: [    2.944642] usb usb2: SerialNumber: fe3a0000.usb
Dec  1 10:13:15 localhost kernel: [    2.945154] hub 2-0:1.0: USB hub found
Dec  1 10:13:15 localhost kernel: [    2.945193] hub 2-0:1.0: 1 port detected
Dec  1 10:13:15 localhost kernel: [    2.946761] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    2.946784] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
Dec  1 10:13:15 localhost kernel: [    2.946983] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
Dec  1 10:13:15 localhost kernel: [    2.947051] xhci-hcd xhci-hcd.0.auto: irq 228, io mem 0xfe900000
Dec  1 10:13:15 localhost kernel: [    2.947449] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 10:13:15 localhost kernel: [    2.947459] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 10:13:15 localhost kernel: [    2.947467] usb usb3: Product: xHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    2.947474] usb usb3: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 10:13:15 localhost kernel: [    2.947481] usb usb3: SerialNumber: xhci-hcd.0.auto
Dec  1 10:13:15 localhost kernel: [    2.947981] hub 3-0:1.0: USB hub found
Dec  1 10:13:15 localhost kernel: [    2.948020] hub 3-0:1.0: 1 port detected
Dec  1 10:13:15 localhost kernel: [    2.948400] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    2.948417] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
Dec  1 10:13:15 localhost kernel: [    2.948433] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
Dec  1 10:13:15 localhost kernel: [    2.948520] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Dec  1 10:13:15 localhost kernel: [    2.948660] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
Dec  1 10:13:15 localhost kernel: [    2.948668] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 10:13:15 localhost kernel: [    2.948676] usb usb4: Product: xHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    2.948683] usb usb4: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 10:13:15 localhost kernel: [    2.948690] usb usb4: SerialNumber: xhci-hcd.0.auto
Dec  1 10:13:15 localhost kernel: [    2.949174] hub 4-0:1.0: USB hub found
Dec  1 10:13:15 localhost kernel: [    2.949212] hub 4-0:1.0: 1 port detected
Dec  1 10:13:15 localhost kernel: [    2.949694] usbcore: registered new interface driver usb-storage
Dec  1 10:13:15 localhost kernel: [    2.952264] mousedev: PS/2 mouse device common for all mice
Dec  1 10:13:15 localhost kernel: [    2.953727] i2c /dev entries driver
Dec  1 10:13:15 localhost kernel: [    2.957760] pca953x 2-0020: using no AI
Dec  1 10:13:15 localhost kernel: [    2.967392] rk808 0-001b: chip id: 0x0
Dec  1 10:13:15 localhost kernel: [    2.971211] rk808-regulator rk808-regulator: there is no dvs0 gpio
Dec  1 10:13:15 localhost kernel: [    2.971240] rk808-regulator rk808-regulator: there is no dvs1 gpio
Dec  1 10:13:15 localhost kernel: [    2.972316] vdd_center: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.973019] vdd_cpu_l: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.973366] vcc_ddr_s3: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.974037] vcc1v8_sys_s3: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.974540] vcc1v8_dvp: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.975033] vcc3v0_touch: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.976524] vcc1v8_s3: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.976802] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
Dec  1 10:13:15 localhost kernel: [    2.977978] vcc_sdio_s0: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.978478] vcca3v0_codec: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.979657] vcc1v5_s3: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.980181] vcca1v8_codec: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.981381] vcc3v0_s3: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.981514] vcc3v3_sys_s0: failed to get the current voltage(-517)
Dec  1 10:13:15 localhost kernel: [    2.981535] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
Dec  1 10:13:15 localhost kernel: [    2.982132] vcc3v3_s0: supplied by vcc3v3_sys_s3
Dec  1 10:13:15 localhost kernel: [    2.986610] rk808-rtc rk808-rtc: registered as rtc0
Dec  1 10:13:15 localhost kernel: [    2.987175] rk808-rtc rk808-rtc: setting system clock to 2020-12-01T16:13:08 UTC (1606839188)
Dec  1 10:13:15 localhost kernel: [    2.990285] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
Dec  1 10:13:15 localhost kernel: [    2.991381] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
Dec  1 10:13:15 localhost kernel: [    2.991479] avdd_0v9_s0: supplied by vcc1v8_sys_s3
Dec  1 10:13:15 localhost kernel: [    2.991605] vdd_cpu_b: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    2.994681] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
Dec  1 10:13:15 localhost kernel: [    2.995813] vdd_gpu: supplied by vcc5v0_sys
Dec  1 10:13:15 localhost kernel: [    3.005156] dw_wdt ff848000.watchdog: No valid TOPs array specified
Dec  1 10:13:15 localhost kernel: [    3.007040] sdhci: Secure Digital Host Controller Interface driver
Dec  1 10:13:15 localhost kernel: [    3.007046] sdhci: Copyright(c) Pierre Ossman
Dec  1 10:13:15 localhost kernel: [    3.007072] Synopsys Designware Multimedia Card Interface Driver
Dec  1 10:13:15 localhost kernel: [    3.008850] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
Dec  1 10:13:15 localhost kernel: [    3.008878] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
Dec  1 10:13:15 localhost kernel: [    3.008894] dwmmc_rockchip fe320000.mmc: Version ID is 270a
Dec  1 10:13:15 localhost kernel: [    3.008954] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
Dec  1 10:13:15 localhost kernel: [    3.009465] dwmmc_rockchip fe320000.mmc: Got CD GPIO
Dec  1 10:13:15 localhost kernel: [    3.020496] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Dec  1 10:13:15 localhost kernel: [    3.034107] sdhci-pltfm: SDHCI platform and OF driver helper
Dec  1 10:13:15 localhost kernel: [    3.035869] mmc1: CQHCI version 5.10
Dec  1 10:13:15 localhost kernel: [    3.061174] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
Dec  1 10:13:15 localhost kernel: [    3.065427] ledtrig-cpu: registered to indicate activity on CPUs
Dec  1 10:13:15 localhost kernel: [    3.066669] hid: raw HID events driver (C) Jiri Kosina
Dec  1 10:13:15 localhost kernel: [    3.066814] usbcore: registered new interface driver usbhid
Dec  1 10:13:15 localhost kernel: [    3.066819] usbhid: USB HID core driver
Dec  1 10:13:15 localhost kernel: [    3.071577] random: fast init done
Dec  1 10:13:15 localhost kernel: [    3.072945] drop_monitor: Initializing network drop monitor service
Dec  1 10:13:15 localhost kernel: [    3.073876] NET: Registered protocol family 10
Dec  1 10:13:15 localhost kernel: [    3.129501] Segment Routing with IPv6
Dec  1 10:13:15 localhost kernel: [    3.129604] NET: Registered protocol family 17
Dec  1 10:13:15 localhost kernel: [    3.129915] 8021q: 802.1Q VLAN Support v1.8
Dec  1 10:13:15 localhost kernel: [    3.130043] Key type dns_resolver registered
Dec  1 10:13:15 localhost kernel: [    3.130964] registered taskstats version 1
Dec  1 10:13:15 localhost kernel: [    3.130981] Loading compiled-in X.509 certificates
Dec  1 10:13:15 localhost kernel: [    3.133437] mmc1: Command Queue Engine enabled
Dec  1 10:13:15 localhost kernel: [    3.133456] mmc1: new HS200 MMC card at address 0001
Dec  1 10:13:15 localhost kernel: [    3.134162] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
Dec  1 10:13:15 localhost kernel: [    3.134440] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
Dec  1 10:13:15 localhost kernel: [    3.134671] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
Dec  1 10:13:15 localhost kernel: [    3.134840] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB, chardev (243:0)
Dec  1 10:13:15 localhost kernel: [    3.136020]  mmcblk1: p1
Dec  1 10:13:15 localhost kernel: [    3.137484] Loaded X.509 cert 'Build time autogenerated kernel key: cf582b85d37ac5e7e16062bd2222df75b99b261f'
Dec  1 10:13:15 localhost kernel: [    3.137726] zswap: loaded using pool lzo/zbud
Dec  1 10:13:15 localhost kernel: [    3.138323] Key type ._fscrypt registered
Dec  1 10:13:15 localhost kernel: [    3.138330] Key type .fscrypt registered
Dec  1 10:13:15 localhost kernel: [    3.138337] Key type fscrypt-provisioning registered
Dec  1 10:13:15 localhost kernel: [    3.141594] Btrfs loaded, crc32c=crc32c-generic
Dec  1 10:13:15 localhost kernel: [    3.168132] Key type encrypted registered
Dec  1 10:13:15 localhost kernel: [    3.168161] AppArmor: AppArmor sha1 policy hashing enabled
Dec  1 10:13:15 localhost kernel: [    3.230254] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
Dec  1 10:13:15 localhost kernel: [    3.230303] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
Dec  1 10:13:15 localhost kernel: [    3.230325] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
Dec  1 10:13:15 localhost kernel: [    3.280382] usb 3-1: new high-speed USB device number 2 using xhci-hcd
Dec  1 10:13:15 localhost kernel: [    3.285633] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
Dec  1 10:13:15 localhost kernel: [    3.285645] pci_bus 0000:00: root bus resource [bus 00-1f]
Dec  1 10:13:15 localhost kernel: [    3.285655] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
Dec  1 10:13:15 localhost kernel: [    3.285666] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
Dec  1 10:13:15 localhost kernel: [    3.285722] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
Dec  1 10:13:15 localhost kernel: [    3.285869] pci 0000:00:00.0: supports D1
Dec  1 10:13:15 localhost kernel: [    3.285878] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Dec  1 10:13:15 localhost kernel: [    3.291364] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Dec  1 10:13:15 localhost kernel: [    3.291624] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
Dec  1 10:13:15 localhost kernel: [    3.291694] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
Dec  1 10:13:15 localhost kernel: [    3.291703] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.291738] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
Dec  1 10:13:15 localhost kernel: [    3.291746] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.291780] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
Dec  1 10:13:15 localhost kernel: [    3.291787] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.291821] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
Dec  1 10:13:15 localhost kernel: [    3.291828] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.291862] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
Dec  1 10:13:15 localhost kernel: [    3.291870] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.291905] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
Dec  1 10:13:15 localhost kernel: [    3.291940] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Dec  1 10:13:15 localhost kernel: [    3.291978] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
Dec  1 10:13:15 localhost kernel: [    3.292297] pci 0000:01:00.0: PME# supported from D3hot
Dec  1 10:13:15 localhost kernel: [    3.292563] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
Dec  1 10:13:15 localhost kernel: [    3.297899] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
Dec  1 10:13:15 localhost kernel: [    3.297929] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
Dec  1 10:13:15 localhost kernel: [    3.297945] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
Dec  1 10:13:15 localhost kernel: [    3.297955] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
Dec  1 10:13:15 localhost kernel: [    3.297975] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.297983] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.297991] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.297998] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.298005] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.298013] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.298020] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.298027] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.298035] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.298042] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
Dec  1 10:13:15 localhost kernel: [    3.298051] pci 0000:00:00.0: PCI bridge to [bus 01]
Dec  1 10:13:15 localhost kernel: [    3.298064] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
Dec  1 10:13:15 localhost kernel: [    3.298312] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
Dec  1 10:13:15 localhost kernel: [    3.298618] pcieport 0000:00:00.0: PME: Signaling with IRQ 239
Dec  1 10:13:15 localhost kernel: [    3.298966] pcieport 0000:00:00.0: AER: enabled with IRQ 239
Dec  1 10:13:15 localhost kernel: [    3.299300] ahci 0000:01:00.0: version 3.0
Dec  1 10:13:15 localhost kernel: [    3.299323] ahci 0000:01:00.0: enabling device (0000 -> 0002)
Dec  1 10:13:15 localhost kernel: [    3.299890] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
Dec  1 10:13:15 localhost kernel: [    3.299990] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
Dec  1 10:13:15 localhost kernel: [    3.300002] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
Dec  1 10:13:15 localhost kernel: [    3.303577] scsi host0: ahci
Dec  1 10:13:15 localhost kernel: [    3.304336] scsi host1: ahci
Dec  1 10:13:15 localhost kernel: [    3.305013] scsi host2: ahci
Dec  1 10:13:15 localhost kernel: [    3.305612] scsi host3: ahci
Dec  1 10:13:15 localhost kernel: [    3.306186] scsi host4: ahci
Dec  1 10:13:15 localhost kernel: [    3.306426] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 240
Dec  1 10:13:15 localhost kernel: [    3.306435] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 241
Dec  1 10:13:15 localhost kernel: [    3.306444] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 242
Dec  1 10:13:15 localhost kernel: [    3.306452] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 243
Dec  1 10:13:15 localhost kernel: [    3.306460] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 244
Dec  1 10:13:15 localhost kernel: [    3.312757] input: gpio-keys as /devices/platform/gpio-keys/input/input0
Dec  1 10:13:15 localhost kernel: [    3.313505] of_cfs_init
Dec  1 10:13:15 localhost kernel: [    3.313563] of_cfs_init: OK
Dec  1 10:13:15 localhost kernel: [    3.430394] usb 3-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
Dec  1 10:13:15 localhost kernel: [    3.430405] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec  1 10:13:15 localhost kernel: [    3.430413] usb 3-1: Product: USB2.0 Hub
Dec  1 10:13:15 localhost kernel: [    3.430421] usb 3-1: Manufacturer: VIA Labs, Inc.
Dec  1 10:13:15 localhost kernel: [    3.492847] hub 3-1:1.0: USB hub found
Dec  1 10:13:15 localhost kernel: [    3.492996] hub 3-1:1.0: 4 ports detected
Dec  1 10:13:15 localhost kernel: [    3.556578] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Dec  1 10:13:15 localhost kernel: [    3.618999] ata1: SATA link down (SStatus 0 SControl 300)
Dec  1 10:13:15 localhost kernel: [    3.707464] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
Dec  1 10:13:15 localhost kernel: [    3.707475] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec  1 10:13:15 localhost kernel: [    3.707483] usb 4-1: Product: USB3.0 Hub
Dec  1 10:13:15 localhost kernel: [    3.707491] usb 4-1: Manufacturer: VIA Labs, Inc.
Dec  1 10:13:15 localhost kernel: [    3.732730] hub 4-1:1.0: USB hub found
Dec  1 10:13:15 localhost kernel: [    3.732925] hub 4-1:1.0: 4 ports detected
Dec  1 10:13:15 localhost kernel: [    3.930861] ata2: SATA link down (SStatus 0 SControl 300)
Dec  1 10:13:15 localhost kernel: [    4.242819] ata3: SATA link down (SStatus 0 SControl 300)
Dec  1 10:13:15 localhost kernel: [    4.304383] usb 3-1.4: new high-speed USB device number 3 using xhci-hcd
Dec  1 10:13:15 localhost kernel: [    4.554830] ata4: SATA link down (SStatus 0 SControl 300)
Dec  1 10:13:15 localhost kernel: [    4.866821] ata5: SATA link down (SStatus 0 SControl 300)
Dec  1 10:13:15 localhost kernel: [    4.869642] Freeing unused kernel memory: 4224K
Dec  1 10:13:15 localhost kernel: [    4.869806] Run /init as init process
Dec  1 10:13:15 localhost kernel: [    4.869814]   with arguments:
Dec  1 10:13:15 localhost kernel: [    4.869820]     /init
Dec  1 10:13:15 localhost kernel: [    4.869825]   with environment:
Dec  1 10:13:15 localhost kernel: [    4.869830]     HOME=/
Dec  1 10:13:15 localhost kernel: [    4.869834]     TERM=linux
Dec  1 10:13:15 localhost kernel: [    4.869839]     ubootpart=92c32d3c-01
Dec  1 10:13:15 localhost kernel: [    4.869845]     cgroup_enable=memory
Dec  1 10:13:15 localhost kernel: [    4.869849]     cgroup_memory=1
Dec  1 10:13:15 localhost kernel: [    5.116721] usb 4-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
Dec  1 10:13:15 localhost kernel: [    5.137937] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
Dec  1 10:13:15 localhost kernel: [    5.137954] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Dec  1 10:13:15 localhost kernel: [    5.137965] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN
Dec  1 10:13:15 localhost kernel: [    5.137975] usb 4-1.4: Manufacturer: Realtek
Dec  1 10:13:15 localhost kernel: [    5.137985] usb 4-1.4: SerialNumber: 000000001
Dec  1 10:13:15 localhost kernel: [    5.445465] input: adc-keys as /devices/platform/adc-keys/input/input1
Dec  1 10:13:15 localhost kernel: [    5.530849] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
Dec  1 10:13:15 localhost kernel: [    5.530865] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
Dec  1 10:13:15 localhost systemd[1]: Started System Logging Service.
Dec  1 10:13:15 localhost kernel: [    5.531068] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
Dec  1 10:13:15 localhost kernel: [    5.531397] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
Dec  1 10:13:15 localhost kernel: [    5.531411] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
Dec  1 10:13:15 localhost kernel: [    5.531424] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
Dec  1 10:13:15 localhost kernel: [    5.531443] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
Dec  1 10:13:15 localhost kernel: [    5.531550] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
Dec  1 10:13:15 localhost kernel: [    5.531559] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
Dec  1 10:13:15 localhost kernel: [    5.536596] rk_gmac-dwmac fe300000.ethernet: init for RGMII
Dec  1 10:13:15 localhost kernel: [    5.537045] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
Dec  1 10:13:15 localhost kernel: [    5.537064] rk_gmac-dwmac fe300000.ethernet: 	DWMAC1000
Dec  1 10:13:15 localhost kernel: [    5.537075] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
Dec  1 10:13:15 localhost kernel: [    5.537085] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
Dec  1 10:13:15 localhost kernel: [    5.537095] rk_gmac-dwmac fe300000.ethernet: COE Type 2
Dec  1 10:13:15 localhost kernel: [    5.537104] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
Dec  1 10:13:15 localhost kernel: [    5.537114] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
Dec  1 10:13:15 localhost kernel: [    5.537283] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
Dec  1 10:13:15 localhost kernel: [    5.537295] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
Dec  1 10:13:15 localhost kernel: [    5.537305] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
Dec  1 10:13:15 localhost kernel: [    5.670353] libphy: stmmac: probed
Dec  1 10:13:15 localhost kernel: [    5.670384] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
Dec  1 10:13:15 localhost kernel: [    5.670402] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Dec  1 10:13:15 localhost kernel: [    5.876710] async_tx: api initialized (async)
Dec  1 10:13:15 localhost kernel: [    6.172496] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
Dec  1 10:13:15 localhost kernel: [    6.797746] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
Dec  1 10:13:15 localhost kernel: [    6.830839] random: lvmconfig: uninitialized urandom read (4 bytes read)
Dec  1 10:13:15 localhost kernel: [    7.166860] random: systemd: uninitialized urandom read (16 bytes read)
Dec  1 10:13:15 localhost kernel: [    7.177481] random: systemd: uninitialized urandom read (16 bytes read)
Dec  1 10:13:15 localhost kernel: [    7.248295] lm75 2-004c: hwmon2: sensor 'lm75'
Dec  1 10:13:15 localhost kernel: [    7.337158] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
Dec  1 10:13:15 localhost kernel: [    7.340466] RPC: Registered named UNIX socket transport module.
Dec  1 10:13:15 localhost kernel: [    7.340477] RPC: Registered udp transport module.
Dec  1 10:13:15 localhost kernel: [    7.340482] RPC: Registered tcp transport module.
Dec  1 10:13:15 localhost kernel: [    7.340488] RPC: Registered tcp NFSv4.1 backchannel transport module.
Dec  1 10:13:15 localhost kernel: [    7.460729] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Dec  1 10:13:15 localhost kernel: [    7.960541] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
Dec  1 10:13:15 localhost kernel: [    7.976561] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
Dec  1 10:13:15 localhost kernel: [    7.976593] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
Dec  1 10:13:15 localhost kernel: [    7.978646] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
Dec  1 10:13:15 localhost kernel: [    8.374854] input: beeper as /devices/platform/beeper/input/input2
Dec  1 10:13:15 localhost kernel: [    8.581642] mc: Linux media interface: v0.10
Dec  1 10:13:15 localhost kernel: [    8.587780] rockchip-vop ff8f0000.vop: Adding to iommu group 2
Dec  1 10:13:15 localhost kernel: [    8.591595] rockchip-vop ff900000.vop: Adding to iommu group 3
Dec  1 10:13:15 localhost kernel: [    8.606817] videodev: Linux video capture interface: v2.00
Dec  1 10:13:15 localhost kernel: [    8.718153] rockchip-rga ff680000.rga: HW Version: 0x03.02
Dec  1 10:13:15 localhost kernel: [    8.719124] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
Dec  1 10:13:15 localhost kernel: [    8.737084] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
Dec  1 10:13:15 localhost kernel: [    8.766868] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
Dec  1 10:13:15 localhost kernel: [    8.777596] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
Dec  1 10:13:15 localhost kernel: [    8.778608] rkvdec ff660000.video-codec: Adding to iommu group 1
Dec  1 10:13:15 localhost kernel: [    8.785278] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
Dec  1 10:13:15 localhost kernel: [    8.785326] [drm] unsupported AFBC format[3231564e]
Dec  1 10:13:15 localhost kernel: [    8.787459] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
Dec  1 10:13:15 localhost kernel: [    8.787654] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
Dec  1 10:13:15 localhost kernel: [    8.788220] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
Dec  1 10:13:15 localhost kernel: [    8.791319] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
Dec  1 10:13:15 localhost kernel: [    8.798928] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
Dec  1 10:13:15 localhost kernel: [    8.800102] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 10:13:15 localhost kernel: [    8.805205] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    8.805224] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 5
Dec  1 10:13:15 localhost kernel: [    8.805375] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
Dec  1 10:13:15 localhost kernel: [    8.805389] xhci-hcd xhci-hcd.3.auto: irq 227, io mem 0xfe800000
Dec  1 10:13:15 localhost kernel: [    8.810254] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
Dec  1 10:13:15 localhost kernel: [    8.810262] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 10:13:15 localhost kernel: [    8.810265] usb usb5: Product: xHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    8.810267] usb usb5: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 10:13:15 localhost kernel: [    8.810270] usb usb5: SerialNumber: xhci-hcd.3.auto
Dec  1 10:13:15 localhost kernel: [    8.810603] hub 5-0:1.0: USB hub found
Dec  1 10:13:15 localhost kernel: [    8.810622] hub 5-0:1.0: 1 port detected
Dec  1 10:13:15 localhost kernel: [    8.810824] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    8.810838] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 6
Dec  1 10:13:15 localhost kernel: [    8.810848] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
Dec  1 10:13:15 localhost kernel: [    8.810888] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
Dec  1 10:13:15 localhost kernel: [    8.810953] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
Dec  1 10:13:15 localhost kernel: [    8.810956] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec  1 10:13:15 localhost kernel: [    8.810959] usb usb6: Product: xHCI Host Controller
Dec  1 10:13:15 localhost kernel: [    8.810962] usb usb6: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
Dec  1 10:13:15 localhost kernel: [    8.810964] usb usb6: SerialNumber: xhci-hcd.3.auto
Dec  1 10:13:15 localhost kernel: [    8.811179] hub 6-0:1.0: USB hub found
Dec  1 10:13:15 localhost kernel: [    8.811203] hub 6-0:1.0: 1 port detected
Dec  1 10:13:15 localhost kernel: [    8.817342] hantro-vpu ff650000.video-codec: Adding to iommu group 0
Dec  1 10:13:15 localhost kernel: [    8.822102] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
Dec  1 10:13:15 localhost kernel: [    8.825785] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
Dec  1 10:13:15 localhost kernel: [    8.912575] panfrost ff9a0000.gpu: clock rate = 500000000
Dec  1 10:13:15 localhost kernel: [    8.914782] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
Dec  1 10:13:15 localhost kernel: [    8.914795] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
Dec  1 10:13:15 localhost kernel: [    8.914802] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
Dec  1 10:13:15 localhost kernel: [    8.914807] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
Dec  1 10:13:15 localhost kernel: [    8.917555] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
Dec  1 10:13:15 localhost kernel: [    9.082512] random: crng init done
Dec  1 10:13:15 localhost kernel: [    9.082519] random: 7 urandom warning(s) missed due to ratelimiting
Dec  1 10:13:15 localhost kernel: [    9.380922] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
Dec  1 10:13:15 localhost kernel: [    9.508762] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
Dec  1 10:13:15 localhost kernel: [    9.524553] r8152 4-1.4:1.0 eth1: v2.13.0 (2020/04/20)
Dec  1 10:13:15 localhost kernel: [    9.524560] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents:
Dec  1 10:13:15 localhost kernel: [    9.524560] 		US6,570,884, US6,115,776, and US6,327,625.
Dec  1 10:13:15 localhost kernel: [    9.524650] usbcore: registered new interface driver r8152
Dec  1 10:13:15 localhost systemd[1]: Started Login Service.
Dec  1 10:13:15 localhost smartd[1219]: smartd 6.6 2017-11-05 r4594 [aarch64-linux-5.9.11-rockchip64] (local build)
Dec  1 10:13:15 localhost systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Dec  1 10:13:15 localhost smartd[1219]: Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Dec  1 10:13:15 localhost systemd[1]: Started WPA supplicant.
Dec  1 10:13:15 localhost smartd[1219]: Opened configuration file /etc/smartd.conf
Dec  1 10:13:15 localhost systemd[1]: Reached target Network.
Dec  1 10:13:15 localhost avahi-daemon[1210]: Successfully called chroot().
Dec  1 10:13:15 localhost avahi-daemon[1210]: Successfully dropped remaining capabilities.
Dec  1 10:13:15 localhost smartd[1219]: Drive: DEVICESCAN, implied '-a' Directive on line 21 of file /etc/smartd.conf
Dec  1 10:13:15 localhost smartd[1219]: Configuration file /etc/smartd.conf was parsed, found DEVICESCAN, scanning devices
Dec  1 10:13:15 localhost wpa_supplicant[1215]: Successfully initialized wpa_supplicant
Dec  1 10:13:15 localhost smartd[1219]: DEVICESCAN failed: glob(3) aborted matching pattern /dev/discs/disc*
Dec  1 10:13:15 localhost systemd[1]: Starting The PHP 7.3 FastCGI Process Manager...
Dec  1 10:13:15 localhost smartd[1219]: In the system's table of devices NO devices found to scan
Dec  1 10:13:15 localhost smartd[1219]: Unable to monitor any SMART enabled devices. Try debug (-d) option. Exiting...
Dec  1 10:13:15 localhost avahi-daemon[1210]: Loading service file /services/ssh.service.
Dec  1 10:13:15 localhost avahi-daemon[1210]: Loading service file /services/website.service.
Dec  1 10:13:15 localhost avahi-daemon[1210]: Network interface enumeration completed.
Dec  1 10:13:15 localhost avahi-daemon[1210]: Server startup complete. Host name is helios64.local. Local service cookie is 1428826376.
Dec  1 10:13:15 localhost avahi-daemon[1210]: Service "helios64 - Web control panel" (/services/website.service) successfully established.
Dec  1 10:13:15 localhost avahi-daemon[1210]: Service "helios64 - SSH" (/services/ssh.service) successfully established.
Dec  1 10:13:15 localhost systemd[1]: Started Unattended Upgrades Shutdown.
Dec  1 10:13:15 localhost systemd[1]: Starting The OpenMediaVault engine daemon that processes the RPC request...
Dec  1 10:13:15 localhost systemd[1]: Starting A high performance web server and a reverse proxy server...
Dec  1 10:13:15 localhost systemd[1]: Starting chrony, an NTP client/server...
Dec  1 10:13:15 localhost systemd[1]: Starting OpenBSD Secure Shell server...
Dec  1 10:13:15 localhost systemd[1]: Starting NFS Mount Daemon...
Dec  1 10:13:15 localhost systemd[1]: smartd.service: Main process exited, code=exited, status=17/n/a
Dec  1 10:13:15 localhost systemd[1]: smartd.service: Failed with result 'exit-code'.
Dec  1 10:13:15 localhost chronyd[1283]: chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +SECHASH +IPV6 -DEBUG)
Dec  1 10:13:15 localhost chronyd[1283]: Frequency -29.169 +/- 3.923 ppm read from /var/lib/chrony/chrony.drift
Dec  1 10:13:15 localhost chronyd[1283]: Loaded seccomp filter
Dec  1 10:13:15 localhost kernel: [    9.801334] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
Dec  1 10:13:15 localhost fancontrol[1216]: Common settings:
Dec  1 10:13:15 localhost fancontrol[1216]:   INTERVAL=10
Dec  1 10:13:15 localhost rpc.mountd[1303]: Version 1.3.3 starting
Dec  1 10:13:15 localhost sshd[1271]: Could not load host key: /etc/ssh/ssh_host_dsa_key
Dec  1 10:13:15 localhost systemd[1]: Started chrony, an NTP client/server.
Dec  1 10:13:15 localhost systemd[1]: Started NFS Mount Daemon.
Dec  1 10:13:15 localhost systemd[1]: Starting NFS server and services...
Dec  1 10:13:15 localhost sshd[1305]: Could not load host key: /etc/ssh/ssh_host_dsa_key
Dec  1 10:13:15 localhost systemd[1]: Started OpenBSD Secure Shell server.
Dec  1 10:13:15 localhost fancontrol[1216]: Settings for /dev/fan-p6/pwm1:
Dec  1 10:13:15 localhost fancontrol[1216]:   Depends on /dev/thermal-cpu/temp1_input
Dec  1 10:13:15 localhost fancontrol[1216]:   Controls
Dec  1 10:13:15 localhost fancontrol[1216]:   MINTEMP=40
Dec  1 10:13:15 localhost fancontrol[1216]:   MAXTEMP=110
Dec  1 10:13:15 localhost fancontrol[1216]:   MINSTART=60
Dec  1 10:13:15 localhost fancontrol[1216]:   MINSTOP=40
Dec  1 10:13:15 localhost fancontrol[1216]:   MINPWM=0
Dec  1 10:13:15 localhost fancontrol[1216]:   MAXPWM=255
Dec  1 10:13:15 localhost systemd[1]: openmediavault-engined.service: Supervising process 1349 which is not our child. We'll most likely not notice when it exits.
Dec  1 10:13:15 localhost systemd[1]: Started The OpenMediaVault engine daemon that processes the RPC request.
Dec  1 10:13:15 localhost systemd[1]: Started A high performance web server and a reverse proxy server.
Dec  1 10:13:15 localhost systemd[1]: Started The PHP 7.3 FastCGI Process Manager.
Dec  1 10:13:15 localhost kernel: [   10.077823] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 10:13:15 localhost fancontrol[1216]: Settings for /dev/fan-p7/pwm1:
Dec  1 10:13:15 localhost systemd[1]: Started fan speed regulator.
Dec  1 10:13:15 localhost fancontrol[1411]: Loading configuration from /etc/fancontrol ...
Dec  1 10:13:15 localhost systemd[1]: Started Dispatcher daemon for systemd-networkd.
Dec  1 10:13:15 localhost kernel: [   10.340243] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 10:13:15 localhost fancontrol[1411]: Common settings:
Dec  1 10:13:15 localhost fancontrol[1411]:   INTERVAL=10
Dec  1 10:13:15 localhost fancontrol[1411]: Settings for /dev/fan-p6/pwm1:
Dec  1 10:13:15 localhost fancontrol[1411]:   Depends on /dev/thermal-cpu/temp1_input
Dec  1 10:13:15 localhost fancontrol[1411]:   Controls
Dec  1 10:13:15 localhost fancontrol[1411]:   MINTEMP=40
Dec  1 10:13:15 localhost fancontrol[1411]:   MAXTEMP=110
Dec  1 10:13:15 localhost fancontrol[1411]:   MINSTART=60
Dec  1 10:13:15 localhost fancontrol[1411]:   MINSTOP=40
Dec  1 10:13:15 localhost fancontrol[1411]:   MINPWM=0
Dec  1 10:13:15 localhost fancontrol[1411]:   MAXPWM=255
Dec  1 10:13:16 localhost fancontrol[1411]: Settings for /dev/fan-p7/pwm1:
Dec  1 10:13:16 localhost fancontrol[1411]:   Depends on /dev/thermal-cpu/temp1_input
Dec  1 10:13:16 localhost fancontrol[1411]:   Controls
Dec  1 10:13:16 localhost fancontrol[1411]:   MINTEMP=40
Dec  1 10:13:16 localhost fancontrol[1411]:   MAXTEMP=110
Dec  1 10:13:16 localhost fancontrol[1411]:   MINSTART=60
Dec  1 10:13:16 localhost fancontrol[1411]:   MINSTOP=40
Dec  1 10:13:16 localhost fancontrol[1411]:   MINPWM=0
Dec  1 10:13:16 localhost fancontrol[1411]:   MAXPWM=255
Dec  1 10:13:16 localhost fancontrol[1411]: Enabling PWM on fans...
Dec  1 10:13:16 localhost fancontrol[1411]: Starting automatic fan control...
Dec  1 10:13:16 localhost kernel: [   11.007306] NFSD: Using UMH upcall client tracking operations.
Dec  1 10:13:16 localhost kernel: [   11.007331] NFSD: starting 90-second grace period (net f00000a1)
Dec  1 10:13:16 localhost systemd[1]: Started NFS server and services.
Dec  1 10:13:16 localhost systemd[1]: Reached target Remote File Systems (Pre).
Dec  1 10:13:16 localhost systemd[1]: Reached target Remote File Systems.
Dec  1 10:13:16 localhost systemd[1]: Started Regular background program processing daemon.
Dec  1 10:13:16 localhost cron[1693]: (CRON) INFO (pidfile fd = 3)
Dec  1 10:13:16 localhost systemd[1]: Starting Permit User Sessions...
Dec  1 10:13:16 localhost cron[1693]: (CRON) INFO (Running @reboot jobs)
Dec  1 10:13:16 localhost systemd[1]: Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Dec  1 10:13:16 localhost systemd[1]: Starting rng-tools.service...
Dec  1 10:13:16 localhost systemd[1]: Starting LSB: service and resource monitoring daemon...
Dec  1 10:13:16 localhost rngd[1712]: rngd 2-unofficial-mt.14 starting up...
Dec  1 10:13:16 localhost rngd[1712]: entropy feed to the kernel ready
Dec  1 10:13:16 localhost CRON[1713]: (root) CMD (/usr/lib/armbian/armbian-apt-updates)
Dec  1 10:13:16 localhost rng-tools[1700]: Starting Hardware RNG entropy gatherer daemon: rngd.
Dec  1 10:13:16 localhost systemd[1]: Started Permit User Sessions.
Dec  1 10:13:16 localhost systemd[1]: Started rng-tools.service.
Dec  1 10:13:16 localhost monit[1733]: Starting Monit 5.26.0 daemon with http interface at /run/monit.sock
Dec  1 10:13:16 localhost monit[1703]: Starting daemon monitor: monit.
Dec  1 10:13:16 localhost monit[1741]: Monit will delay for 5s on first start after reboot ...
Dec  1 10:13:16 localhost systemd[1]: Started LSB: service and resource monitoring daemon.
Dec  1 10:13:16 localhost loadcpufreq[1697]: Loading cpufreq kernel modules...done (none).
Dec  1 10:13:16 localhost systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling.
Dec  1 10:13:16 localhost systemd[1]: Starting LSB: set CPUFreq kernel parameters...
Dec  1 10:13:16 localhost kernel: [   11.263407] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Dec  1 10:13:16 localhost cpufrequtils[1763]: CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...CPU2...CPU3...CPU4...CPU5...done.
Dec  1 10:13:16 localhost systemd[1]: Started LSB: set CPUFreq kernel parameters.
Dec  1 10:13:16 localhost systemd[1]: Starting LSB: Set sysfs variables from /etc/sysfs.conf...
Dec  1 10:13:16 localhost sysfsutils[1776]: Setting sysfs variables....
Dec  1 10:13:16 localhost systemd[1]: Started LSB: Set sysfs variables from /etc/sysfs.conf.
Dec  1 10:13:17 localhost systemd-networkd[466]: eth0: Gained carrier
Dec  1 10:13:17 localhost systemd-networkd-wait-online[510]: ignoring: lo
Dec  1 10:13:17 localhost kernel: [   12.073140] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Dec  1 10:13:17 localhost kernel: [   12.073178] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Dec  1 10:13:17 localhost systemd-networkd[466]: eth0: DHCPv4 address 192.168.0.190/24 via 192.168.0.1
Dec  1 10:13:17 localhost avahi-daemon[1210]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.190.
Dec  1 10:13:17 localhost avahi-daemon[1210]: New relevant interface eth0.IPv4 for mDNS.
Dec  1 10:13:17 localhost avahi-daemon[1210]: Registering new address record for 192.168.0.190 on eth0.IPv4.
Dec  1 10:13:17 localhost dbus-daemon[1208]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.0' (uid=102 pid=466 comm="/lib/systemd/systemd-networkd ")
Dec  1 10:13:17 localhost networkd-dispatcher[1220]: ERROR:Unable to execute script, check file mode: /usr/lib/networkd-dispatcher/routable.d/10-disable-offloading
Dec  1 10:13:17 localhost systemd[1]: Starting Hostname Service...
Dec  1 10:13:17 localhost dbus-daemon[1208]: [system] Successfully activated service 'org.freedesktop.hostname1'
Dec  1 10:13:17 localhost systemd[1]: Started Hostname Service.
Dec  1 10:13:18 localhost avahi-daemon[1210]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::6662:66ff:fed0:180.
Dec  1 10:13:18 localhost avahi-daemon[1210]: New relevant interface eth0.IPv6 for mDNS.
Dec  1 10:13:18 localhost systemd-networkd[466]: eth0: Gained IPv6LL
Dec  1 10:13:18 localhost avahi-daemon[1210]: Registering new address record for fe80::6662:66ff:fed0:180 on eth0.*.
Dec  1 10:13:21 localhost monit[1741]: '\helios64' Monit 5.26.0 started
Dec  1 10:13:20 localhost chronyd[1283]: Selected source 45.55.58.103
Dec  1 10:13:20 localhost chronyd[1283]: System clock wrong by -1.110489 seconds, adjustment started
Dec  1 10:13:20 localhost chronyd[1283]: System clock was stepped by -1.110489 seconds
Dec  1 10:13:29 localhost systemd-networkd[466]: eth0: Configured
Dec  1 10:13:29 localhost systemd-networkd-wait-online[510]: ignoring: lo
Dec  1 10:13:38 localhost kernel: [   33.768936] vcc3v0_sd: disabling
Dec  1 10:13:38 localhost kernel: [   33.768952] vcc5v0_typec: disabling
Dec  1 10:13:46 localhost systemd[1]: systemd-hostnamed.service: Succeeded.
Dec  1 10:14:28 localhost systemd[1]: Created slice User Slice of UID 0.
Dec  1 10:14:28 localhost systemd[1]: Starting User Runtime Directory /run/user/0...
Dec  1 10:14:28 localhost systemd[1]: Started User Runtime Directory /run/user/0.
Dec  1 10:14:28 localhost systemd[1]: Starting User Manager for UID 0...
Dec  1 10:14:28 localhost systemd[1887]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec  1 10:14:28 localhost systemd[1887]: Reached target Timers.
Dec  1 10:14:28 localhost systemd[1887]: Listening on GnuPG network certificate management daemon.
Dec  1 10:14:28 localhost systemd[1887]: Reached target Paths.
Dec  1 10:14:28 localhost systemd[1887]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec  1 10:14:28 localhost systemd[1887]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec  1 10:14:28 localhost systemd[1887]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec  1 10:14:28 localhost systemd[1887]: Reached target Sockets.
Dec  1 10:14:28 localhost systemd[1887]: Reached target Basic System.
Dec  1 10:14:28 localhost systemd[1887]: Reached target Default.
Dec  1 10:14:28 localhost systemd[1887]: Startup finished in 116ms.
Dec  1 10:14:28 localhost systemd[1]: Started User Manager for UID 0.
Dec  1 10:14:28 localhost systemd[1]: Started Session 3 of user root.
Dec  1 10:14:53 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:14:53 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:15:01 localhost CRON[2038]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Dec  1 10:15:01 localhost CRON[2039]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec  1 10:15:03 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:15:03 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:15:12 localhost systemd-networkd-wait-online[510]: Event loop failed: Connection timed out
Dec  1 10:15:12 localhost systemd[1]: systemd-networkd-wait-online.service: Main process exited, code=exited, status=1/FAILURE
Dec  1 10:15:12 localhost systemd[1]: systemd-networkd-wait-online.service: Failed with result 'exit-code'.
Dec  1 10:15:12 localhost systemd[1]: Failed to start Wait for Network to be Configured.
Dec  1 10:15:12 localhost systemd[1]: Reached target Network is Online.
Dec  1 10:15:12 localhost systemd[1]: Condition check resulted in Armbian first run optional user configuration being skipped.
Dec  1 10:15:12 localhost systemd[1]: Starting /etc/rc.local Compatibility...
Dec  1 10:15:12 localhost systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon...
Dec  1 10:15:12 localhost systemd[1]: Starting Generate the prelogin message...
Dec  1 10:15:12 localhost systemd[1]: Started /etc/rc.local Compatibility.
Dec  1 10:15:12 localhost systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon.
Dec  1 10:15:12 localhost systemd[1]: Started Getty on tty1.
Dec  1 10:15:12 localhost systemd[1]: Started Serial Getty on ttyS2.
Dec  1 10:15:13 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:15:13 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:15:24 localhost omv-salt[2075]: helios64:
Dec  1 10:15:24 localhost omv-salt[2075]: ----------
Dec  1 10:15:24 localhost omv-salt[2075]:           ID: configure_issue
Dec  1 10:15:24 localhost omv-salt[2075]:     Function: file.managed
Dec  1 10:15:24 localhost omv-salt[2075]:         Name: /etc/issue
Dec  1 10:15:24 localhost omv-salt[2075]:       Result: True
Dec  1 10:15:24 localhost omv-salt[2075]:      Comment: File /etc/issue updated
Dec  1 10:15:24 localhost omv-salt[2075]:      Started: 10:15:18.771681
Dec  1 10:15:24 localhost omv-salt[2075]:     Duration: 5751.876 ms
Dec  1 10:15:24 localhost omv-salt[2075]:      Changes:
Dec  1 10:15:24 localhost omv-salt[2075]:               diff:
Dec  1 10:15:24 localhost omv-salt[2075]:                   +++
Dec  1 10:15:24 localhost omv-salt[2075]:                   @@ -4,7 +4,7 @@
Dec  1 10:15:24 localhost omv-salt[2075]:                    To manage the system visit the openmediavault web control panel:
Dec  1 10:15:24 localhost omv-salt[2075]:                    eth0: 192.168.0.190
Dec  1 10:15:24 localhost omv-salt[2075]:                   -eth0: fe80::a738:86aa:ee73:de3e
Dec  1 10:15:24 localhost omv-salt[2075]:                   +eth0: fe80::6662:66ff:fed0:180
Dec  1 10:15:24 localhost omv-salt[2075]:                    By default the web control panel administrator account has the
Dec  1 10:15:24 localhost omv-salt[2075]:                    username 'admin' and password 'openmediavault'.
Dec  1 10:15:24 localhost omv-salt[2075]: Summary for helios64
Dec  1 10:15:24 localhost omv-salt[2075]: ------------
Dec  1 10:15:24 localhost omv-salt[2075]: Succeeded: 1 (changed=1)
Dec  1 10:15:24 localhost omv-salt[2075]: Failed:    0
Dec  1 10:15:24 localhost omv-salt[2075]: Total states run:     1
Dec  1 10:15:24 localhost omv-salt[2075]: Total run time:   5.752 s
Dec  1 10:15:25 localhost systemd[1]: Started Generate the prelogin message.
Dec  1 10:15:25 localhost systemd[1]: Reached target Login Prompts.
Dec  1 10:15:25 localhost systemd[1]: Starting Enable heartbeat & network activity led on Helios64...
Dec  1 10:15:25 localhost bash[2250]: heartbeat
Dec  1 10:15:25 localhost bash[2254]: netdev
Dec  1 10:15:25 localhost bash[2257]: eth0
Dec  1 10:15:25 localhost bash[2260]: 1
Dec  1 10:15:25 localhost bash[2263]: 1
Dec  1 10:15:25 localhost bash[2266]: 1
Dec  1 10:15:25 localhost systemd[1]: helios64-heartbeat-led.service: Succeeded.
Dec  1 10:15:25 localhost systemd[1]: Started Enable heartbeat & network activity led on Helios64.
Dec  1 10:15:25 localhost systemd[1]: Reached target Multi-User System.
Dec  1 10:15:25 localhost systemd[1]: Starting watchdog daemon...
Dec  1 10:15:25 localhost systemd[1]: Starting Beep after system start...
Dec  1 10:15:25 localhost kernel: [  140.779204] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
Dec  1 10:15:25 localhost kernel: [  140.779212] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
Dec  1 10:15:25 localhost watchdog[2275]: starting daemon (5.15):
Dec  1 10:15:25 localhost watchdog[2275]: int=1s realtime=yes sync=no load=0,0,0 soft=no
Dec  1 10:15:25 localhost watchdog[2275]: memory not checked
Dec  1 10:15:25 localhost watchdog[2275]: ping: no machine to check
Dec  1 10:15:25 localhost watchdog[2275]: file: no file to check
Dec  1 10:15:25 localhost watchdog[2275]: pidfile: no server process to check
Dec  1 10:15:25 localhost watchdog[2275]: interface: no interface to check
Dec  1 10:15:25 localhost watchdog[2275]: temperature: no sensors to check
Dec  1 10:15:25 localhost watchdog[2275]: no test binary files
Dec  1 10:15:25 localhost watchdog[2275]: no repair binary files
Dec  1 10:15:25 localhost watchdog[2275]: error retry time-out = 60 seconds
Dec  1 10:15:25 localhost watchdog[2275]: repair attempts = 1
Dec  1 10:15:25 localhost watchdog[2275]: alive=/dev/watchdog heartbeat=[none] to=root no_act=no force=no
Dec  1 10:15:25 localhost watchdog[2275]: watchdog now set to 60 seconds
Dec  1 10:15:25 localhost watchdog[2275]: hardware watchdog identity: Synopsys DesignWare Watchdog
Dec  1 10:15:25 localhost systemd[1]: Started watchdog daemon.
Dec  1 10:15:25 localhost systemd[1]: Reached target Graphical Interface.
Dec  1 10:15:25 localhost systemd[1]: Starting Update UTMP about System Runlevel Changes...
Dec  1 10:15:25 localhost systemd[1]: Condition check resulted in Hide bootsplash after starting the system being skipped.
Dec  1 10:15:25 localhost systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Dec  1 10:15:25 localhost systemd[1]: Started Update UTMP about System Runlevel Changes.
Dec  1 10:15:25 localhost systemd[1]: openmediavault-beep-up.service: Succeeded.
Dec  1 10:15:25 localhost systemd[1]: Started Beep after system start.
Dec  1 10:15:25 localhost systemd[1]: Startup finished in 6.519s (kernel) + 2min 14.648s (userspace) = 2min 21.168s.
Dec  1 10:17:01 localhost CRON[3721]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Dec  1 10:18:14 localhost anacron[1214]: Job `cron.daily' started
Dec  1 10:18:14 localhost anacron[3915]: Updated timestamp for job `cron.daily' to 2020-12-01
Dec  1 10:18:14 localhost cracklib: no dictionary update necessary.
Dec  1 10:25:01 localhost CRON[8060]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec  1 10:26:23 localhost cron-apt: CRON-APT RUN [/etc/cron-apt/config]: Tue Dec  1 10:18:14 CST 2020
Dec  1 10:26:23 localhost cron-apt: CRON-APT SLEEP: 458, Tue Dec  1 10:25:52 CST 2020
Dec  1 10:26:23 localhost cron-apt: CRON-APT ACTION: 0-update
Dec  1 10:26:23 localhost cron-apt: CRON-APT LINE: /usr/bin/apt-get  update -o quiet=2
Dec  1 10:26:23 localhost anacron[1214]: Job `cron.daily' terminated
Dec  1 10:26:23 localhost anacron[1214]: Job `cron.weekly' started
Dec  1 10:26:23 localhost anacron[9574]: Updated timestamp for job `cron.weekly' to 2020-12-01
Dec  1 10:26:23 localhost openmediavault-update-smart-drivedb: Updating smartmontools drive database ...
Dec  1 10:26:23 localhost anacron[1214]: Job `cron.weekly' terminated
Dec  1 10:28:04 localhost systemd[1]: Starting Cleanup of Temporary Directories...
Dec  1 10:28:04 localhost systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Dec  1 10:28:04 localhost systemd[1]: Started Cleanup of Temporary Directories.
Dec  1 10:28:15 localhost anacron[1214]: Job `cron.monthly' started
Dec  1 10:28:15 localhost anacron[1214]: Job `cron.monthly' terminated
Dec  1 10:28:15 localhost anacron[1214]: Normal exit (3 jobs run)
Dec  1 10:28:15 localhost systemd[1]: anacron.service: Killing process 9697 (anacron) with signal SIGKILL.
Dec  1 10:28:15 localhost systemd[1]: anacron.service: Succeeded.
Dec  1 10:30:01 localhost CRON[9732]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
Dec  1 10:30:01 localhost CRON[9734]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Dec  1 10:31:42 localhost systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Dec  1 10:31:42 localhost systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Dec  1 10:33:01 localhost systemd[1]: Started Run anacron jobs.
Dec  1 10:33:01 localhost anacron[9917]: Anacron 2.3 started on 2020-12-01
Dec  1 10:33:01 localhost anacron[9917]: Normal exit (0 jobs run)
Dec  1 10:33:01 localhost systemd[1]: anacron.service: Succeeded.
Dec  1 10:35:01 localhost CRON[10104]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
15 minutes ago, BacchusIX said:
why can I only post once a day??
Sadly needed measure to fight spam. You received a like. Your limit should lift within 24h.
@BacchusIX I'm not sure I see anything wrong (beside some issue with fan control).
Are you using fixed IP or DHCP ?
Take note that fixed IP setup through armbian-config will be wiped out by OMV installation because OMV use netplan/networkd instead of NetworkManager. So if you use fixed IP, you need to configure it again inside OMV directly.
@gprovostI use DHCP, but the IP is bound to the device so it is more or less static through the router. I guess it's just how Tenda firmware does it.
Downloading plugins and other network related tasks seem to work fine so I don't THINK it's an IP issue. I've had issues with OMV every time I've used it; digging into a little more research, I'm not sure it's an issue with the Helios but rather an issue with OMV 5 as others on other systems are having the same issues.  Either way I think I've found other ways of accomplishing my end goals but I like a single GUI to organize and visualize everything. I get most fanboys love there CLI, but I don't use Linux enough to remember everything which means I have to look everything up and reteach myself every time I go in to change something. As I work a LOT and don't have very much free time, it greatly annoys me to spend 3 days doing something that should take a 1/3d of that time.  I'm not mad at or your team, I think what you guys built here is great, hence why I bought one over a pre packaged server. You want to go next level and grow your business, though, build a great  custom GUI for it that people other than computer experts can utilize.
Don't feel frustrated and inadequate. Computer things may look too scary and overwhelming but often that's the only problem. If you do not have time to invest or the funds for proper hardware (I mean Tenda.) there is always the option for hiring one of the "fan boys" to setup your system.
@BacchusIX,
I guess I could be (sort of?) considered a "CLI fan boy."
But I became this way after having enough of being frustrated by limited "off the shelf" and/or GUI options.  Which you seem to be also, although apparently not enough to quite push you over the hump of learning something new.
You correctly point out that it is an investment of time, perhaps one you are unable to make currently.  Fair enough.  I used to be on the hamster wheel, too.  But that's the tradeoff.  What do you value more, your freedom/independence, or your time?  It's quite personal and subjective and there is no "right/wrong" answer.  Right now it seems you value your time and you are certainly not in the minority in that calculation in the broader population (technical forums like ours perhaps more being the opposite).
As far as forgetting things, even as a "CLI fanboy" I take extensive notes[0] on many of the things I do, especially those which are new to me or that I also seem to never be able to remember.  Which I think is just good practice in general, but especially in technical disciplines.
[0] I really like Orgmode in Emacs for taking notes, but if you are throwing terms around like "CLI fanboy" then Emacs might not be for you.
