Trying to install php smbclient - pecl can't find /usr/bin/sed
Good morning community,
I need to install the php extension smbclient but the pecl command fails.
My odroid xu4 development board works under arbiam 20.11 Stable. with Apache 2.4.? (latest) / Msql 10.3.25-MariaDB / Php 7.4.13 (packages.sury.org)
konki@cloud:/etc/php/7.4/fpm# pecl channel-update pecl.php.net
Updating channel "pecl.php.net" Update of Channel "pecl.php.net" succeeded
konki@cloud:/etc/php/7.4/fpm# pecl install smbclient
downloading smbclient-1.0.0.tgz ...
Starting to download smbclient-1.0.0.tgz (32,017 bytes)
.........done: 32,017 bytes
4 source files, building
running: phpize
/usr/bin/phpize: 1: /usr/bin/phpize: /usr/bin/sed: not found
grep: write error: Broken pipe
Configuring for:
PHP Api Version:
Zend Module Api No:
Zend Extension Api No:
/usr/bin/phpize: 164: /usr/bin/phpize: /usr/bin/sed: not found
autoheader: error: AC_CONFIG_HEADERS not found in configure.ac
ERROR: `phpize' failed
Can't find a fix with google! Could you help me?
Thank's
Konki
I could be wrong, but this does not seem like anything Armbian specific.
Userspace (apt, packages, etc.) on top of Armbian is just vanilla Debian (or Ubuntu, depending on what you installed).
apt install sed
sed is a part of every image since its extensively used in lots of scripts. This is probably some other problem like - broken image, broken filesystem, ...
That's what I was thinking, too.  Not only that, but I am not even sure this is actually Armbian?  Or if it is, something very basic is just very wrong (things that Igor said already).
I was of the same opinion but the absence of GNU Sed from the /usr/bin directory is very strange under debian.
sed is installed under armbian 20, but the binary is in the /bin directory. it seems to me that this choice is absolutely not judicious even if a simple symlink allows to solve the problem. I have a workstation under MXLinux (debian stable) and the binary is in its usual place.
I see the same curiosity under linux raspberrypi 5.4.72, sed is installed but the /bin directory!
Damned, I thank you for your opinions, but you are wrong:
pecl is a simple script bash which ensures the local compilation of the package.
so either you modify the link /usr/bin/sed in pecl, or you just have to create a link for sed in its historical directory!!!
# sed --v
sed (GNU sed) 4.7
Packaged by Debian
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <https://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
# type -a sed
sed is /bin/sed
# cd /bin
# ln -s /bin/sed /user/bin/sed (create a symlink for sed)
# cd /usr/bin
# ln -l sed
lrwxewxrwx l root ....... sed -> /bin/sed
/usr/bin# pecl install smbclient
Build process completed successfully
Installing '/usr/lib/php/20190902/smbclient.so'
install ok: channel://pecl.php.net/smbclient-1.0.0
configuration option "php_ini" is not set to php.ini location
You should add "extension=smbclient.so" to php.ini
that's all folks
konki
1 hour ago, konki said:
it seems to me that this choice is absolutely not judicious ...
Well, it is your opinion. Mine is not better ...
But maybe you should complain with the script providers ...
As Igor said, "sed" is a mandatory component for the system and historically /usr was a user filesystem mounted only after initial system initialization. Unix (and Linux) is not WIndows : you have to get some control over the system and not reinstall in case of problem. So the system needs to be layered in some way.
┌─[ 2020-12-05 03:01 trs-80@host:~ ]
└─▶ $ which sed
/bin/sed
┌─[ 2020-12-05 13:01 trs-80@host:~ ]
└─▶ $ dpkg --print-architecture
amd64
└─▶ $ lsb_release -d
Description:	Debian GNU/Linux bullseye/sid
┌─[ 2020-12-05 13:06 trs-80@host:~ ]
└─▶ $ ls -al /bin | grep sed
-rwxr-xr-x  1 root root  122224 Dec 22  2018 sed
Edited by TRS-80
add last part to show it's not symlink
