michabbs 4 Posted January 11 Share Posted January 11 My Helios64 is "far away" and I am afraid to change network configuration, because if I miss something I could lose connectivity to the box. I would like to attach COM-to-IP adapter so that I always had serial console available, but... what actually do I need? "Normal" com-to-ip adapter provides COM port. Helios64 has COM-in-USB. So...? How to convert Helios'es serial console to anything accessible via LAN? Link to post Share on other sites
FloBaoti 2 Posted January 11 Share Posted January 11 (edited) I don't know if such "box" exists, but a simple Raspberry PI is enough to do this. It has IP connectivity, SSH server and can connect to your Helios64 via USB serial cable. Edited January 11 by FloBaoti Link to post Share on other sites
Igor 2164 Posted January 11 Share Posted January 11 44 minutes ago, FloBaoti said: but a simple Raspberry PI No need for video player type of board to preserve serial connection Orangepi Zero is already an overkill. Link to post Share on other sites
devman 13 Posted January 12 Share Posted January 12 Well, if you wanted to go minimalist, you could probably solder pin headers to J13 and then hang an esp8266 off it using something like the esp-link firmware Edit: sorry, was thinking of the Helios4. The Helios64 would use P14 and it's already populated, so no soldering required. Then you'd just need to pick up vcc/gnd from the gpio connector to power the device. *note: I haven't actually tried this Link to post Share on other sites
allen--smithee 10 Posted January 15 Share Posted January 15 @devmana "midi dsi" is missing ARM32 TFT35 I don't have the level yet but I'm obsessed with a tactile facade on the Helios64. with rail A in SSD I have a lot of space to do. Link to post Share on other sites
