legardner93 Posted July 2, 2021 Posted July 2, 2021 Hey everyone...I've tried searching the problem I'm having and have tried different things...all so far to no avail. I'm relatively new to learning about pihole and decided to go out and buy the kit from ameriDroid (maybe should have built my own but decided to go this route to try and save myself some time). I received the kit today and started following the install instructions (I am attempting to install via SSH thru Putty). Once I reached the install command, I get an error stating: "Error: Unable to update package cache. Please try "apt-get update". I've tried the apt update/upgrade and I'm still getting the same error. The output from the apt-get update command is the following: root@rock64:/home/pihole# sudo apt update Hit:2 http://ports.ubuntu.com focal InRelease Hit:3 http://ports.ubuntu.com focal-security InRelease Ign:1 https://armbian.tnahosting.net/apt focal InRelease Hit:4 http://ports.ubuntu.com focal-updates InRelease Hit:6 http://ports.ubuntu.com focal-backports InRelease Err:5 https://armbian.tnahosting.net/apt focal Release Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 130.185.239.75 443] Reading package lists... Done W: http://apt.armbian.com/dists/focal/InRelease: No system certificates available. Try installing ca-certificates. W: http://apt.armbian.com/dists/focal/Release: No system certificates available. Try installing ca-certificates. E: The repository 'http://apt.armbian.com focal Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. I've tried running sudo apt-get install ca-certificates but they already appear to be installed. Any help will be greatly appreciated.
Werner Posted July 2, 2021 Posted July 2, 2021 Retry with a fresh image from https://www.armbian.com/download/ ?
Igor Posted July 2, 2021 Posted July 2, 2021 2 hours ago, legardner93 said: Any help will be greatly appreciated. Just retry - from here everything looks ok: Spoiler bananapim2ultra:~:# apt update Hit:1 http://ports.ubuntu.com hirsute InRelease Hit:2 http://ports.ubuntu.com hirsute-security InRelease Hit:4 http://ports.ubuntu.com hirsute-updates InRelease Hit:5 http://ports.ubuntu.com hirsute-backports InRelease Get:3 https://imola.armbian.com/apt hirsute InRelease [18.5 kB] Get:6 https://imola.armbian.com/apt hirsute/main armhf Packages [207 kB] Get:7 https://imola.armbian.com/apt hirsute/hirsute-utils armhf Packages [265 kB] Get:8 https://imola.armbian.com/apt hirsute/hirsute-desktop armhf Packages [12.4 kB] Fetched 503 kB in 4s (134 kB/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. bananapim2ultra:~:# apt update Hit:1 http://ports.ubuntu.com hirsute InRelease Hit:2 http://ports.ubuntu.com hirsute-security InRelease Hit:4 http://ports.ubuntu.com hirsute-updates InRelease Hit:5 http://ports.ubuntu.com hirsute-backports InRelease Get:3 https://mirrors.dotsrc.org/armbian-apt hirsute InRelease [18.5 kB] Fetched 18.5 kB in 3s (5,465 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. bananapim2ultra:~:# apt update Hit:1 http://ports.ubuntu.com hirsute InRelease Hit:2 http://ports.ubuntu.com hirsute-security InRelease Hit:4 http://ports.ubuntu.com hirsute-updates InRelease Hit:5 http://ports.ubuntu.com hirsute-backports InRelease Get:3 https://armbian.hosthatch.com/apt hirsute InRelease [18.5 kB] Fetched 18.5 kB in 3s (5,480 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. bananapim2ultra:~:# apt update Hit:1 http://ports.ubuntu.com hirsute InRelease Hit:2 http://ports.ubuntu.com hirsute-security InRelease Hit:4 http://ports.ubuntu.com hirsute-updates InRelease Hit:5 http://ports.ubuntu.com hirsute-backports InRelease Hit:3 https://mirrors.netix.net/armbian/apt hirsute InRelease Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. bananapim2ultra:~:# apt update Hit:1 http://ports.ubuntu.com hirsute InRelease Hit:2 http://ports.ubuntu.com hirsute-security InRelease Hit:4 http://ports.ubuntu.com hirsute-updates InRelease Hit:5 http://ports.ubuntu.com hirsute-backports InRelease Get:3 https://mirrors.dotsrc.org/armbian-apt hirsute InRelease [18.5 kB] Fetched 18.5 kB in 3s (5,442 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. bananapim2ultra:~:# Another possible source of problem is that your system date and time is not set / set wrong.
lanefu Posted July 10, 2021 Posted July 10, 2021 3 hours ago, sarangpaul9 said: Damm even I am having a similar kind of issue, I have searched all over the internet and even have posted on number of threads on different forum, no solution seems to work. I am really frustrated, can anyone of you here help me resolve this issue, I am very much tired now. Can you share error messages please.
guidol Posted July 10, 2021 Posted July 10, 2021 On 7/2/2021 at 6:24 AM, legardner93 said: Err:5 https://armbian.tnahosting.net/apt focal Release Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 130.185.239.75 443] Reading package lists... Done W: http://apt.armbian.com/dists/focal/InRelease: No system certificates available. Try installing ca-certificates. W: http://apt.armbian.com/dists/focal/Release: No system certificates available. Try installing ca-certificates. in my browser the https-certificate or "https://armbian.tnahosting.net/apt" is OK Did you check time/date on your system and did you try (as suggested) "apt install ca-certificates" ? If you got "armbian-config -> personal settigs -> mirrors" in your armbian-like distro then try to change the source/apt servers to EU and not automatic and try to reload the apt cache.
lanefu Posted July 11, 2021 Posted July 11, 2021 the July 1st error was legit, but the certificate was fixed soon afterwards.
