kentAVR Posted July 4, 2021 Posted July 4, 2021 Hello! I follow instruction "Add names of overlays you want to activate to overlays= line in /boot/armbianEnv.txt" I try to find /boot/armbianEnv.txt but nothing. I see Build tools overview from https://github.com/armbian/build/blob/fcb8b6f195bbb76c83c612c425fdf08cfd48c68b/README.md And nothing about /boot/armbianEnv.txt May be documentation talking about build/config/bootenvrockchip.txt and build/config/zynq.txt and others txt files in build/config/ ? It looks like /boot/armbianEnv.txt is file on microSD after I burn armbian image on it. But reading docs I don't understand nothing about build/config/bootenv/rockchip.txt
Werner Posted July 5, 2021 Posted July 5, 2021 Are you using a supported Armbian image? If so which one?
kentAVR Posted July 5, 2021 Author Posted July 5, 2021 15 minutes ago, Werner said: Are you using a supported Armbian image? If so which one? Orange Pi 4
Igor Posted July 5, 2021 Posted July 5, 2021 6 hours ago, kentAVR said: May be documentation talking about build/config/bootenvrockchip.txt and build/config/zynq.txt and others txt files in build/config/ ? Xunlong / Orangepi forked our build system and adjusted upon their needs & ideas. Documentations for their fork is different in several areas - that's all I know about. 6 hours ago, kentAVR said: But reading docs I don't understand nothing about build/config/bootenv/rockchip.txt Those are converted to /boot/armbianEnv.txt in the build process and some parameters are added there if needed. Also in firstrun runtime if defined that way.
kentAVR Posted July 5, 2021 Author Posted July 5, 2021 19 hours ago, Igor said: Xunlong / Orangepi forked our build system and adjusted upon their needs & ideas. Documentations for their fork is different in several areas - that's all I know about. Those are converted to /boot/armbianEnv.txt in the build process and some parameters are added there if needed. Also in firstrun runtime if defined that way. So in armbian docs need add something like "If you want change /boot/armbianEnv.txt you should use build/config/bootenv/LINUXFAMILY.txt. For example if you use Orange Pi 4 you need use build/config/bootenv/rockchip.txt" __________________________________________________ I try to understand why U-Boot ignore my /boot/armbianEnv.txt I try to set bootdelay=-2 1) I use google and people talking about another filename: uEnv.txt not armbianEnv.txt So how U-Boot knows about /boot/armbianEnv.txt ? There is no "/boot/armbianEnv.txt" in U-Boot source code... I try to make uEnv.txt by myself... 2) Is /boot/armbianEnv.txt need to be placed in FAT volume? I build .img for my Orange Pi 4 /boot/armbianEnv.txt and another are in some volume... Orange Pi 4_U-Boot.log
martinayotte Posted July 5, 2021 Posted July 5, 2021 32 minutes ago, kentAVR said: So how U-Boot knows about /boot/armbianEnv.txt ? There is no "/boot/armbianEnv.txt" in U-Boot source code... If you look at /boot/boot.cmd (which then compiled into /boot/boot.scr), there is a line where /boot/armbianEnv.txt is loaded in memory and then "env import" is executed ...
Igor Posted July 5, 2021 Posted July 5, 2021 1 hour ago, kentAVR said: "If you want change /boot/armbianEnv.txt you should use build/config/bootenv/LINUXFAMILY.txt. For example if you use Orange Pi 4 you need use build/config/bootenv/rockchip.txt" No. "rockchip.txt" defaults are automatically used if you build Orangepi 4. Defaults were not meant to be user changeable, but you can change them this generic way while building image or manually on the board. 1 hour ago, kentAVR said: I use google and people talking about another filename: uEnv.txt not armbianEnv.txt This is the same. Just u-boot, which is not Armbian - we only use it for our needs, you will not learn just in one year ... you will find many different approaches and implementations, many versions and hacks to the u-boot in the wild. Which leads to - not simple to answer. 1 hour ago, kentAVR said: need to be placed in FAT volume? Isn't FAT something related to Windows?!?! No, there is no need for a FAT filesystem.
kentAVR Posted July 6, 2021 Author Posted July 6, 2021 On 7/5/2021 at 7:13 PM, Igor said: No. "rockchip.txt" defaults are automatically used if you build Orangepi 4. Defaults were not meant to be user changeable, but you can change them this generic way while building image or manually on the board. This is the same. Just u-boot, which is not Armbian - we only use it for our needs, you will not learn just in one year ... you will find many different approaches and implementations, many versions and hacks to the u-boot in the wild. Which leads to - not simple to answer. Isn't FAT something related to Windows?!?! No, there is no need for a FAT filesystem. I want verify that U-Boot use rockchip.txt in my case. Since I run ./compile.sh BOARD=orangepi4 BRANCH=current RELEASE=hirsute BUILD_MINIMAL=no BUILD_DESKTOP=yes KERNEL_ONLY=no KERNEL_CONFIGURE=yes COMPRESS_OUTPUTIMAGE=sha,gpg,img BSPFREEZE=yes REPOSITORY_INSTALL="" EXTERNAL=no EXTRAWIFI=no AUFS=no WIREGUARD=no INSTALL_KSRC=yes OFFLINE_WORK=no BSPFREEZE=yes CREATE_PATCHES=yes DESKTOP_ENVIRONMENT=xfce armbian build U-Boot and I can see in log: 3.2.1. HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o YACC scripts/kconfig/zconf.tab.c LEX scripts/kconfig/zconf.lex.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf # # configuration written to .config # scripts/kconfig/conf --syncconfig Kconfig CFG u-boot.cfg GEN include/autoconf.mk.dep 1) Where I can find this U-Boot's .config ? I try search it but nothing is found... 2) "No. "rockchip.txt" defaults are automatically used if you build Orangepi 4. Defaults were not meant to be user changeable, but you can change them this generic way while building image or manually on the board." I still don't see problem with my suggestion to add to armbian docs something like "If you want change /boot/armbianEnv.txt you should use build/config/bootenv/$LINUXFAMILY.txt. For example if you use Orange Pi 4 you need change build/config/bootenv/rockchip.txt"
Igor Posted July 7, 2021 Posted July 7, 2021 7 hours ago, kentAVR said: For example if you use Orange Pi 4 you need change build/config/bootenv/rockchip.txt Negative. Users don't need and should not change build script internals. When you do, also your script will not update anymore. Try to find reasoning for current situation, not adjusting documentation to the use case that will not be supported. At least not this way. 7 hours ago, kentAVR said: Where I can find this U-Boot's .config ? I try search it but nothing is found. u-boot sources perhaps? 1
kentAVR Posted July 7, 2021 Author Posted July 7, 2021 27 minutes ago, Igor said: Negative. Users don't need and should not change build script internals. When you do, also your script will not update anymore. Try to find reasoning for current situation, not adjusting documentation to the use case that will not be supported. At least not this way. u-boot sources perhaps? I can't see .config file at /home/a/Documents/myArmbians/8armbian/build/cache/sources/u-boot/v2020.10. Ubuntu too... "Negative. Users don't need and should not change build script internals. When you do, also your script will not update anymore. Try to find reasoning for current situation, not adjusting documentation to the use case that will not be supported. At least not this way." Switch off U-Boot input-output capabilities is not supported by armbian build script via editing rockchip.txt in my case?
lanefu Posted July 8, 2021 Posted July 8, 2021 In uboot there's a folder containing files that end in defconfig Those files are whats used based on what's configured here https://github.com/armbian/build/blob/master/config/boards/pinebook-pro.csc If you run make menuconfig you can load one of those defconfig files and then save accordingly
