SSH connection refused from windoze (11 enterprise) ethernet
virgosystems
Donate your old hardware to community. Start a giveaway Raffle!
Addresses need to be unique but within the defined subnet mask.
From your previous postings and questions you seem either lacking fundamental networking knowledge and/or your home setup has some weirdness into. Both is out of scope of Armbian since its competence ends at the PHY plug.
I suggest you try getting yourself more comfortable with that topic and start learning about it on places like https://www.geeksforgeeks.org/computer-network-tutorials/ or https://www.google.com/search?q=networking+for+beginners
Best of luck.
Link to comment
Share on other sites
It will probably be easiest to just set your Pi to use 192.168.137.x where x is a number between 1 and 254 that is not in use by any other device on your network. If you have more than one ethernet interface in use you may also need to set a route in your PC to use the right interface for the Pi.
Edited by CryBaby
Link to comment
