November 6, 20224 yr Hi folks, I have a Firefly AIO-3399C which boots Armbian fine, but no USB devices besides the root devices are detected. This happens with both the kernel 5.19.170 and 6.0.7 based images, made by @balbes150, which I've downloaded from https://users.armbian.com/balbes150/firefly-rk3399/ Any advice would be appreciated. U-Boot 2022.04-armbian (Nov 03 2022 - 17:26:20 +0300) Linux firefly-rk3399 5.19.17-media #trunk SMP PREEMPT Thu Nov 3 17:40:36 MSK 2022 aarch64 aarch64 aarch64 GNU/Linux In dmesg output, I see the following, which may be relevant: [ 4.616394] hub 7-0:1.0: USB hub found [ 14.296598] fusb30x: module is from the staging directory, the quality is unknown, you have been warned. [ 14.298983] fusb30x: module is from the staging directory, the quality is unknown, you have been warned. [ 14.346438] fusb302 7-0022: Can't get property of role, set role to default DRP [ 14.402787] fusb302 7-0022: Unable to request IRQ for INT_N GPIO! 0 [ 14.555053] fusb302: probe of 7-0022 failed with error -22 [ 14.568604] fusb302 4-0022: Can't get property of role, set role to default DRP [ 14.574971] fusb302 4-0022: Unable to request IRQ for INT_N GPIO! 0 [ 14.576841] fusb302: probe of 4-0022 failed with error -22 [ 14.692030] usbcore: registered new interface driver brcmfmac
November 7, 20224 yr Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
November 7, 20224 yr 7 часов назад, MrBIOS сказал: Firefly AIO-3399C This device is not included in the list of supported devices. Perhaps other DTBS are needed for it (I do not know which ones)
August 30, 20242 yr @MrBIOS How did you boot Armbian with you board? I have the same board, but when I put Armbian in tf card, it doesn't boot.
