Posted (edited)
A new variation of Orange Pi 5 is now available.  I think it's available on AliExpress, but I've seen the item on Amazon.com as well...reasonable price:
https://www.amazon.com/Orange-Pi-Rockchip-Frequency-Development/dp/B0C5BZLPZN
It comes now with the RK3588 instead of the RK3588s of the 5 and 5B.  It's similar in capabilities of the Rock 5B but I believe has a few more bells and whistles.  It has two  2.5GB ethernet ports.  Separate connectors than GPIO for RTC and fan.  Full size HDMI input as well as 2 full size HDMI outputs.  Can have m.2 for 2230 WiFi/BT on top side as well as m.2 2280 on bottom of board.  I think it can only go up to 16GB memory.
Not sure if Armbian will make all of these work...yet.
But this makes perfect sense...I just bouth my Orange Pi 5 about a month ago :(
PS:  A new tag is required for this new variation...I guess.
PPS:  Other thing to note is that Amazon link is for a 16GB version and includes a power supply.  However, this particular listing ships from China.  For Orange Pi 5 and 5B there were listings that were fulfilled by Amazon.  I would think that Orange Pi will/may have those in the near future, that ship from the US...hopefully, but likely a little more expensive.
PPPS:  If you go to that Amazon link, there is also a version with 4GB and no power supply for $99.99 at the time this was posted.
Edited by ArmBoy1988
I wasn't too upset with the wifi version.
However those two 2.5gbps ethernet ports have me regretting the 5.
You sure do need that good powersupply with this model. I have to run my external data SSD drive off of an externally powered USB hub too, as it draws too much power.
I was thinking that if the Orange Pi 5 I purchased didn't live up to what I was looking for, I'd buy the Rock 5B or something like that.  In any case, I got the 16GB memory, m.2 for an SSD and I wasn't going to need WiFi or I could just get a WiFi dongle, if needed.  A big difference, for me, is the PCIe throughput, I think that the throughput for the m.2 on the 5 will probably be sufficient.
Yup packaging looks good indeed, ordered one too so I could use the "old" one for LinuxCNC (great machine for it).
Would've been better if it had a 12v dc input, atm I'm using a 5v 4a usb c adapter, it seems like this is giving me sporadic issues. Hopefully this isn't the case with the OPi5+. Otherwise power direct on the pins worked fine.
I hesitated to buy the NanoPC-T6 which has a nice case (20,-) and 12v input, but it doesn't have MTD and no choice to buy without emmc.
@Avatar Ng Did you buy a case/heatsink with it?
@royk yeah man, NanoPC-T6 seems like a better deal, I NEED A CASE XD ...
end up I add on NVME, Wi-Fi6+BT5, casing (design my own), ... etc the cost goes up a lot 😂
Quick update, tried Armbian image "Armbian_22.11.4_Orangepi5_jammy_legacy_5.10.110_gnome_desktop.img" no luck; probably other image is like Radxa 5b image is a closer sibling??
and no debug message due to not found my tty debug cable yet 😅.
Hmm, got my Orange Pi 5 now running as home server and runs great. But this plus version does look great to have also. Like the 2.5Gbps ethernet ports... Perfect platform to build your own router. :)
Posted (edited)
@Efe Çetin Seems like the OPI5 image ("Armbian_23.02.2_Orangepi5_jammy_legacy_5.10.110.img") works better (at least it boots and got into console display) than the one you provide me, I tried both "Armbian_23.08.0-trunk_Orangepi5-plus_jammy_legacy_5.10.160_gnome_desktop.img" and the one from Radxa Rock 5b ("Armbian_23.02.2_Rock-5b_jammy_legacy_5.10.110.img"), these don't even boot with display.
Seems the official branch added support for this new board.
https://github.com/orangepi-xunlong/orangepi-build/tree/next
Let me supplement all those debug logs in the following days, apologize for the TTY debug cable, I have to get a new one.
Following were stack trace from TTY, using image  "Armbian_23.08.0-trunk_Orangepi5-plus_jammy_legacy_5.10.160_gnome_desktop.img".
Quote
Note: I've flash my SPI Flash by the way, for PCIE NVMe boot using OrangePi official Ubuntu image.
[  430.778765] rk806-pinctrl rk806-pinctrl.7.auto: not freeing pin 1 (gpio_pwrctrl2) as part of deactivating group gpio_pwrctrl2 - it is already used for some other setting
[  431.082338] reboot: Power down
\0\0\0DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
Manufacturer ID:0x6
CH0 RX Vref:32.7%, TX Vref:22.8%,21.8%
CH1 RX Vref:31.7%, TX Vref:22.8%,22.8%
CH2 RX Vref:31.7%, TX Vref:22.8%,22.8%
CH3 RX Vref:30.7%, TX Vref:22.8%,22.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-orangepi (May 25 2023 - 10:42:30)
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(806278dba1...) + OK
## Checking uboot 0x00200000 ... sha256(6e73bf447d...) + OK
## Checking fdt 0x00311dd0 ... sha256(d2dda3ef7c...) + OK
## Checking atf-2 0x000f0000 ... sha256(c00c7fd75b...) + OK
## Checking atf-3 0xff100000 ... sha256(71c3a5841b...) + OK
## Checking atf-4 0xff001000 ... sha256(2301cf73be...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 727.55 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-405-gb52c2eadd:derrick.huang
NOTICE:  BL31: Built : 11:23:47, Aug 15 2022
INFO:    spec: 0x1
INFO:    ext 32k is valid
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    system boots from cpu-hwid-0
INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO:    dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO:    dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO:    dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO:    dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-armbian (May 28 2023 - 19:44:43 +0000)
Model: RK3588 Orange Pi 5 Plus
PreSerial: 2, raw, 0xfeb50000
DRAM:  15.7 GiB
Sysmem: init
Relocation Offset: eda65000
Relocation fdt: eb9f9a98 - eb9fecc8
CR: M/C/I
Using default environment
mmc@fe2c0000: 0, mmc@fe2e0000: 1
Bootdev(atags): mmc 0
MMC0: Legacy, 52Mhz
PartType: EFI
DM: v2
boot mode: None
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
  b0pll 24000 KHz
  b1pll 24000 KHz
  lpll 24000 KHz
  v0pll 24000 KHz
  aupll 24000 KHz
  cpll 1500000 KHz
  gpll 1188000 KHz
  npll 24000 KHz
  ppll 1100000 KHz
  aclk_center_root 702000 KHz
  pclk_center_root 100000 KHz
  hclk_center_root 396000 KHz
  aclk_center_low_root 500000 KHz
  aclk_top_root 750000 KHz
  pclk_top_root 100000 KHz
  aclk_low_top_root 396000 KHz
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
switch to partitions #0, OK
mmc0 is current device
mmc@fe2c0000: 0 (SD)
mmc@fe2e0000: 1
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
3476 bytes read in 10 ms (338.9 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
reading /armbianEnv.txt
168 bytes read in 2 ms (82 KiB/s)
reading /uInitrd
15256327 bytes read in 1225 ms (11.9 MiB/s)
reading /Image
34638336 bytes read in 2775 ms (11.9 MiB/s)
** Unable to read file /dtb/rockchip/rk3588s-orangepi-5-plus.dtb **
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Default at 0xeb9f9a98
** Unable to read file /dtb/rockchip/overlay/rockchip-rk3588-fixup.scr **
Unknown command 'kaslrseed' - try 'help'
Fdt Ramdisk skip relocation
## Loading init Ramdisk from Legacy Image at 0a200000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    15256263 Bytes = 14.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
Device 0: unknown device
Device 2: Could not get clock for spi@fe2b0000: -2
unknown device
Device 1: Could not get clock for spi@fe2b0000: -2
unknown device
starting USB...
Bus usb@fc800000: "Synchronous Abort" handler, esr 0x96000004
* Reason:        Exception from a Data abort, from current exception level
* PC         =   00000000002809c0
* LR         =   00000000002809c0
* SP         =   00000000eb9f8b50
* ESR_EL2    =   0000000096000004
* Reloc Off  =   00000000eda65000
x0 : ffffffffffffffff x1 : 00000000edd3a9f1
x2 : 00000000fffffffc x3 : 0000000000000000
x4 : 00000000edd432ed x5 : 000000000000006e
x6 : 00000000edd2e12e x7 : 0000000000000000
x8 : 0000000000000044 x9 : 0000000000000008
x10: 00000000ffffffd0 x11: 00000000ebc6d288
x12: 0000000000000000 x13: 0000000000000004
x14: 000000000000000c x15: 0000000000000002
x16: 00000000edca9f74 x17: 0000000000000005
x18: 00000000eb9ffce0 x19: 0000000000000000
x20: 00000000ebc88f80 x21: 00000000ebc64140
x22: 00000000ebc89110 x23: 00000000edd4cfec
x24: 00000000edd77d40 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 00000000ebc88930 x29: 00000000eb9f8d30
Call trace:
  PC:	[< 002809c0 >]
  LR:	[< 002809c0 >]
Stack:
	[< 002809c0 >]
	[< 00233494 >]
	[< 0027cb00 >]
	[< 00212d3c >]
	[< 00212ddc >]
	[< 0022ad20 >]
	[< 00218124 >]
	[< 002182d8 >]
	[< 002179ec >]
	[< 0022a2d0 >]
	[< 0022ad20 >]
	[< 00218124 >]
	[< 002182d8 >]
	[< 002179ec >]
	[< 0022a2d0 >]
	[< 0022ad20 >]
	[< 00218124 >]
	[< 002182d8 >]
	[< 00217a28 >]
	[< 00217fdc >]
	[< 00217db8 >]
	[< 002182d8 >]
	[< 002179ec >]
	[< 0022a2d0 >]
	[< 0022ad20 >]
	[< 00218124 >]
	[< 002182d8 >]
	[< 002179ec >]
	[< 0022a240 >]
	[< 00218978 >]
	[< 00216818 >]
	[< 00219018 >]
	[< 0028cc68 >]
	[< 00219254 >]
	[< 00201e18 >]
Copy info from "Call trace..." to a file(eg. dump.txt), and run
command in your U-Boot project: ./scripts/stacktrace.sh dump.txt
Resetting CPU ...
### ERROR ### Please RESET the board ###
Edited by Avatar Ng
Posted (edited)
Here's another, tried an older image "Armbian_22.11.4_Orangepi5_jammy_legacy_5.10.110_gnome_desktop.img", at least there's a display, and then after the Armbian logo loading screen, gets into the following infinite loop (please find full log at attachment)
[  217.042512] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3
[  217.145850] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3
[  217.249275] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3
[  217.352617] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3
[  217.455849] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3
[  217.559164] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3
Image "Armbian_23.02.2_Orangepi5_jammy_legacy_5.10.110.img" is more silent, it stops at "Starting kernel ...", let me know if you need that log too, I forgot to capture it, it also has a display on my HDMI monitor.
Hope that helps.
ReceivedTofile-COM7-6_1_2023_1-21-02_AM.DAT
Edited by Avatar Ng
Posted (edited)
The Opi5 + is nice.
But what is the point of buying it if there is no support for rk3588.
I am just a novice when it comes to Linux
 There is no Linux that can do anything but running a basic gnome desktop on the the Opi5, maybe in 2024.
I guess flooding the market with rk3588 might move it along in time.
There is no reason to use cli, when a Opi zero 2 or an rpi3 can do a better job.
Example ; Opi zero 2 running OMV.
Edited by vandyman
@Efe Çetin I've downloaded the ' Armbian_23.08.0-trunk_Orangepi5-plus_jammy_legacy_5.10.160_gnome_desktop'. It can boot successfully but it stucks while loading the linux filesystem at initramfs:
ALERT! PARTUUID=614e0000-0000 does not exist. Dropping to a shell!
None of the /dev/mmcblk1p1 or /dev/mmcblk1p2 of my sdcard has that PARTUUID. The rootdev in armbianEnv.txt refers to the UUID of /dev/mmcblk1p2. I can boot Orange Pi's Debian successfully by using the same sdcard so I don't think that's the problem.
Any idea?
Regards.
The debug console output of the failed loading of Armbian_23.08.0-trunk_Orangepi5-plus_jammy_legacy_5.10.160_gnome_desktop is as below:
U-Boot 2017.09-armbian (May 31 2023 - 17:58:42 +0000)
DRAM:  15.7 GiB
Sysmem: init
CR: M/C/I
MMC0: Legacy, 52Mhz
PartType: EFI
DM: v2
boot mode: None
  b0pll 24000 KHz
  b1pll 24000 KHz
  lpll 24000 KHz
  v0pll 24000 KHz
  aupll 24000 KHz
  cpll 1500000 KHz
  gpll 1188000 KHz
  npll 24000 KHz
  ppll 1100000 KHz
mmc@fe2e0000: 1
Scanning mmc 0:1...
reading /boot.scr
3476 bytes read in 2 ms (1.7 MiB/s)
172 bytes read in 1 ms (168 KiB/s)
reading /uInitrd
15256294 bytes read in 1224 ms (11.9 MiB/s)
reading /Image
reading /dtb/rockchip/rk3588-orangepi-5-plus.dtb
265256 bytes read in 31 ms (8.2 MiB/s)
   Image Name:   uInitrd
   Data Size:    15256230 Bytes = 14.5 MiB
## Flattened Device Tree blob at 0x0a100000
   Booting using the fdt blob at 0x0a100000
   reserving fdt memory region: addr=a100000 size=a7000
  'reserved-memory' cma: addr=10000000 size=10000000
  'reserved-memory' ramoops@110000: addr=110000 size=f0000
   Using Device Tree in place at 000000000a100000, end 000000000a1a9fff
Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000)
Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000)
Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000)
Total: 4644.846 ms
Starting kernel ...
[2J[3J[-1;-1fdone.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
Just successfully built Armbian_23.08.0-trunk_Orangepi5-plus_jammy_legacy_5.10.160.img with server profile, booted from SD, copied to eMMC and it works fine.
Next step would be fixing pcie errors as I want to use LSI controller instead of NVME disk.
Looks like we'll have to stick with 5.10 for a while as mainline support is still quite partial - https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md
Here are my boot errors just for reference:
Jun 11 16:48:11 orangepi5-plus kernel: fiq_debugger fiq_debugger.0: IRQ fiq not found
Jun 11 16:48:11 orangepi5-plus kernel: fiq_debugger fiq_debugger.0: IRQ wakeup not found
Jun 11 16:48:11 orangepi5-plus kernel: fiq_debugger_probe: could not install nmi irq handler
Jun 11 16:48:11 orangepi5-plus kernel: debugfs: Directory 'vcc_mipicsi1' with parent 'regulator' already present!
Jun 11 16:48:11 orangepi5-plus kernel: debugfs: Directory 'vcc_mipicsi1' with parent 'vcc_mipicsi1' already present!
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe190000.pcie: IRQ msi not found
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe190000.pcie: Missing *config* reg space
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe180000.pcie: IRQ msi not found
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe180000.pcie: Missing *config* reg space
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe190000.pcie: invalid resource
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe180000.pcie: invalid resource
Jun 11 16:48:11 orangepi5-plus kernel: mpp-iep2 fdbb0000.iep: allocate roi buffer failed
Jun 11 16:48:11 orangepi5-plus kernel: mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
Jun 11 16:48:11 orangepi5-plus kernel: rkvdec2_init:1022: No niu aclk reset resource define
Jun 11 16:48:11 orangepi5-plus kernel: mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
Jun 11 16:48:11 orangepi5-plus kernel: rkvdec2_init:1025: No niu hclk reset resource define
Jun 11 16:48:11 orangepi5-plus kernel: mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
Jun 11 16:48:11 orangepi5-plus kernel: mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
Jun 11 16:48:11 orangepi5-plus kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19
Jun 11 16:48:11 orangepi5-plus kernel: rkvenc_init:1814: failed to add venc devfreq
Jun 11 16:48:11 orangepi5-plus kernel: mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe150000.pcie: IRQ msi not found
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe150000.pcie: Missing *config* reg space
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe150000.pcie: invalid resource
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe170000.pcie: IRQ msi not found
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe170000.pcie: Missing *config* reg space
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe170000.pcie: invalid resource
Jun 11 16:48:11 orangepi5-plus kernel: rk806 spi2.0: no sleep-setting state
Jun 11 16:48:11 orangepi5-plus kernel: rk806 spi2.0: no reset-setting pinctrl state
Jun 11 16:48:11 orangepi5-plus kernel: rk806 spi2.0: no dvs-setting pinctrl state
Jun 11 16:48:11 orangepi5-plus kernel: Error: Driver 'Goodix-TS' is already registered, aborting...
Jun 11 16:48:11 orangepi5-plus kernel: .. rk pwm remotectl v2.0 init
Jun 11 16:48:11 orangepi5-plus kernel: Goodix-TS 7-0014: i2c test failed attempt 1: -6
Jun 11 16:48:11 orangepi5-plus kernel: Goodix-TS 7-0014: i2c test failed attempt 2: -6
Jun 11 16:48:11 orangepi5-plus kernel: Goodix-TS 7-0014: I2C communication failure: -6
Jun 11 16:48:11 orangepi5-plus kernel: arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
Jun 11 16:48:11 orangepi5-plus kernel: debugfs: File 'Capture' in directory 'dapm' already present!
Jun 11 16:48:11 orangepi5-plus kernel: ES8323 7-0011: ASoC: error at soc_component_write_no_lock on ES8323.7-0011: -5
Jun 11 16:48:11 orangepi5-plus kernel: debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
Jun 11 16:48:11 orangepi5-plus kernel: rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
Jun 11 16:48:11 orangepi5-plus kernel: rockchip-dmc dmc: failed to get vop pn to msch rl
Jun 11 16:48:11 orangepi5-plus kernel: rockchip-dmc dmc: could not find power_model node
Jun 11 16:48:11 orangepi5-plus kernel: RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
Jun 11 16:48:11 orangepi5-plus kernel: RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
Jun 11 16:48:11 orangepi5-plus kernel: RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
Jun 11 16:48:11 orangepi5-plus kernel: debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
Jun 11 16:48:11 orangepi5-plus kernel: RKNPU fdab0000.npu: failed to find power_model node
Jun 11 16:48:11 orangepi5-plus kernel: RKNPU fdab0000.npu: RKNPU: failed to initialize power model
Jun 11 16:48:11 orangepi5-plus kernel: RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe150000.pcie: PCIe Link Fail
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe150000.pcie: failed to initialize host
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe170000.pcie: PCIe Link Fail
Jun 11 16:48:11 orangepi5-plus kernel: rk-pcie fe170000.pcie: failed to initialize host
Jun 11 16:48:11 orangepi5-plus systemd-tmpfiles[721]: Setting file flags is only supported on regular files and directories, cannot set on '/var/log/journal'.
I build a bullseye version from the trunk. Before that I used the Ubuntu jammy version by using Joshua Reik's dtb on an armbian image.
Two issues that I run into:
  1. The problematic Intel Ax201 wifi can't seem to be detected. Spend the whole day trying to make it work but fail.
  2. armbian-config feature 'Install to/update boot loader' can't be used to move image to NVMe and bootloader to MTD flash. NVMe drive is not given as a destination option even though it can detected by the system.
Have you tried to create a single partition on the nvme beforehand?
Yep. Totally missed that. Didn't come to my mind it's new and needs to be partition first. It works now, as intended.
@royk Hi :D
Yeah, my bad, i guess when you open an ssh connection it goes up a little bit as you can see on my second screenshot (when you log in), thats why I posted the htop screenshot too, because it didnt match.
Running mpstat showed me the truth:
# mpstat
Linux 5.10.160-rockchip-rk3588 (orangepi5-plus) 	06/14/2023 	_aarch64_	(8 CPU)
09:00:44 AM  CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest  %gnice   %idle
09:00:44 AM  all    0.25    0.00    0.66    0.07    0.00    0.01    0.00    0.00    0.00   99.01
About 99.01% of idle, or 0.99% of usage :D. Pretty nice.
Hi all,
I also got my opi5+ and after fiddling around with the "official" ubuntu, I flashed Armbian_23.5.4_Orangepi5-plus_jammy_legacy_5.10.160_xfce_desktop.img.xz and things look promising..
I wanted to ask if any of you have unfrozen the kernel...?
Also has anyone managed to get the cpu to go down to its lowest state (408Mhz) ?
Thanks!
@Tony3 The little I played with the desktop after installing, it seemed to work (you need to do the additional steps mentioned in the download page though). At least glxgears reached the 60FPS limit of my screen.. Now it's headless, so I cannot confirm.
