Posted (edited)
On 4/13/2025 at 10:41 AM, dr_toggleswitch said:
Was anybody able to install to emmc on this unit?  I can't do it with nand-sata-install. It only shows my SD card.
I don't think the Orange Pi Zero 3 has emmc..
Edited by jimg
I've not used a board which use EMMC (yet). They are more convenient, sometimes faster. While I'm not always against EMMC, some of the EMMC support is occasionally not very well documented / implemented, in particular by the vendors (e.g. how their boot rom selects booting from EMMC or SD). And that occasionally led to gotchas such as a boot fail in EMMC but it seem there isn't a way to recover from that etc.
EMMC add a bit more complexity to the boot process, in particular by the boot rom (on PCs used to be called BIOS) and it is necessary to see that all the different boot permutations are well supported, boot from SD, boot from EMMC, override from SD (e.g. if EMMC install fails) etc, reflash EMMC from SD etc.
I swapped OpenSSH server for Dropbear. Soooo much faster on this unit. Very noticeable. Easy to do on a headless install, just setup Dropbear on a different port than the default, reboot, sign in with that different port, disable & uninstall OpenSSH.
I updated my ArmBian and the kernel 6.12.23 appeared but u-boot is still v24.01 and there is still a problem with incorrect detection of the memory size instead of 1 Gb it shows 2 Gb only after a few reboots it shows correctly 1 Gb RAM. I don't know if u-boot v25.x versions solve this problem
Linux localhost 6.12.23-current-sunxi64 #1 SMP Thu Apr 10 12:39:41 UTC 2025 aarch64 GNU/Linux
There are actually just a few situations where updating the boot loader makes sense. So when a new u-boot package is shipped it just provides the binaries but does not write them to the boot sector.
I think you can use armbian-install to rewrite the boot loader with the latest binaries.
Thank you for info.
I did "armbian-install" and saved u-boot on microSD
but in the directory /usr/lib/linux-u-boot-current-orangepizero3
declare -i UBOOT_NUM_TARGETS=1
declare UBOOT_BIN_DIR="/usr/lib/linux-u-boot-current-orangepizero3"
declare UBOOT_VERSION="2024.01"
declare UBOOT_ARTIFACT_VERSION="2024.01-S866c-P4a40-H8869-V380a-Bb703-R448a"
declare UBOOT_GIT_REVISION="866ca972d6c3cabeaf6dbac431e8e08bb30b3c8e"
declare UBOOT_GIT_SOURCE="https://github.com/u-boot/u-boot"
declare UBOOT_GIT_BRANCH="tag:v2024.01"
indicates that nothing has changed and there is information that u-boot is 2024.01
during apt upgrade is:
Preparing to unpack .../base-files_25.5.0-trunk.426-12.4+deb12u10-bookworm_arm64.deb ...
Unpacking base-files (25.5.0-trunk.426-12.4+deb12u10-bookworm) over (25.5.0-trunk.422-12.4+deb12u10-bookworm) ...
Setting up base-files (25.5.0-trunk.426-12.4+deb12u10-bookworm) ...
(Reading database ... 46891 files and directories currently installed.)
Preparing to unpack .../armbian-bsp-cli-orangepizero3-current_25.5.0-trunk.426_arm64.deb ...
Armbian 'armbian-bsp-cli-orangepizero3-current' for '1-PC8904-V801b-Hc65c-B1e5d-Rf36a': 'preinst' starting.
Armbian 'armbian-bsp-cli-orangepizero3-current' for '1-PC8904-V801b-Hc65c-B1e5d-Rf36a': 'preinst' finishing.
Unpacking armbian-bsp-cli-orangepizero3-current (25.5.0-trunk.426) over (25.5.0-trunk.422) ...
Armbian 'armbian-bsp-cli-orangepizero3-current' for '1-PC8904-V801b-Hc65c-B1e5d-Rf36a': 'postrm' starting.
Armbian 'armbian-bsp-cli-orangepizero3-current' for '1-PC8904-V801b-Hc65c-B1e5d-Rf36a': 'postrm' finishing.
Preparing to unpack .../armbian-firmware_25.5.0-trunk.426_all.deb ...
Unpacking armbian-firmware (25.5.0-trunk.426) over (25.5.0-trunk.422) ...
Preparing to unpack .../linux-dtb-current-sunxi64_25.5.0-trunk.426_arm64.deb ...
Armbian 'linux-dtb-current-sunxi64' for '6.12.23-current-sunxi64': 'preinst' starting.
Armbian 'linux-dtb-current-sunxi64' for '6.12.23-current-sunxi64': 'preinst' finishing.
Unpacking linux-dtb-current-sunxi64 (25.5.0-trunk.426) over (25.5.0-trunk.422) ...
Preparing to unpack .../linux-image-current-sunxi64_25.5.0-trunk.426_arm64.deb ...
Armbian 'linux-image-current-sunxi64' for '6.12.23-current-sunxi64': 'prerm' starting.
Armbian 'linux-image-current-sunxi64' for '6.12.23-current-sunxi64': 'prerm' finishing.
Armbian 'linux-image-current-sunxi64' for '6.12.23-current-sunxi64': 'preinst' starting.
Armbian 'linux-image-current-sunxi64' for '6.12.23-current-sunxi64': 'preinst' finishing.
Unpacking linux-image-current-sunxi64 (25.5.0-trunk.426) over (25.5.0-trunk.422) ...
Armbian 'linux-image-current-sunxi64' for '6.12.23-current-sunxi64': 'postrm' starting.
Armbian 'linux-image-current-sunxi64' for '6.12.23-current-sunxi64': 'postrm' finishing.
Preparing to unpack .../linux-u-boot-orangepizero3-current_25.5.0-trunk.426_arm64.deb ...
Unpacking linux-u-boot-orangepizero3-current (25.5.0-trunk.426) over (25.5.0-trunk.422) ...
Setting up linux-u-boot-orangepizero3-current (25.5.0-trunk.426) ...
Armbian 'uboot-orangepizero3-current' for '2024.01-S866c-P4a40-H8869-V380a-Bb703-R448a': 'postinst' starting.
Armbian 'uboot-orangepizero3-current' for '2024.01-S866c-P4a40-H8869-V380a-Bb703-R448a': 'postinst' finishing.
Setting up linux-image-current-sunxi64 (25.5.0-trunk.426) ...
Armbian 'linux-image-current-sunxi64' for '6.12.23-current-sunxi64': 'postinst' starting.
update-initramfs: Generating /boot/initrd.img-6.12.23-current-sunxi64
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.12.23-current-sunxi64
Image Name:   uInitrd
Created:      Mon Apr 21 09:18:24 2025
Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
Data Size:    12492766 Bytes = 12199.97 KiB = 11.91 MiB
Load Address: 00000000
Entry Point:  00000000
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.12.23-current-sunxi64 to /boot/uInitrd
'/boot/uInitrd' -> 'uInitrd-6.12.23-current-sunxi64'
update-initramfs: Armbian: done.
Armbian: update last-installed kernel symlink to 'Image'...
'/boot/Image' -> 'vmlinuz-6.12.23-current-sunxi64'
Armbian: Debian compat: linux-update-symlinks install 6.12.23-current-sunxi64 boot/vmlinuz-6.12.23-current-sunxi64
Armbian 'linux-image-current-sunxi64' for '6.12.23-current-sunxi64': 'postinst' finishing.
Setting up armbian-bsp-cli-orangepizero3-current (25.5.0-trunk.426) ...
Armbian 'armbian-bsp-cli-orangepizero3-current' for '1-PC8904-V801b-Hc65c-B1e5d-Rf36a': 'postinst' starting.
'/boot/boot.cmd' -> '/usr/share/armbian/boot.cmd-1745219906'
NOTE: You can find previous bootscript versions in /usr/share/armbian !
Recreating boot script
'/usr/share/armbian/boot.cmd' -> '/boot/boot.cmd'
Armbian 'armbian-bsp-cli-orangepizero3-current' for '1-PC8904-V801b-Hc65c-B1e5d-Rf36a': 'postinst' finishing.
Setting up linux-dtb-current-sunxi64 (25.5.0-trunk.426) ...
Armbian 'linux-dtb-current-sunxi64' for '6.12.23-current-sunxi64': 'postinst' starting.
Armbian: DTB: symlinking /boot/dtb to /boot/dtb-6.12.23-current-sunxi64...
'dtb' -> 'dtb-6.12.23-current-sunxi64'
Armbian 'linux-dtb-current-sunxi64' for '6.12.23-current-sunxi64': 'postinst' finishing.
Setting up armbian-firmware (25.5.0-trunk.426) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for initramfs-tools (0.142+deb12u1) ...
Image Name:   uInitrd
Created:      Mon Apr 21 09:18:56 2025
Data Size:    12493052 Bytes = 12200.25 KiB = 11.91 MiB
I noticed that after updating the kernel to version 6.12.23 there is a problem with armbin-config
I can't set overllay tree devices choosing from
armbian-config --cmd SY210
The current Armbian 25.5.0-trunk.426 nightly (bookworm) is supported.
Check distro
Loaded Dialog...
Loaded Docs...
Loaded System helpers...
Loaded Network helpers...
Loaded Software helpers...
Loaded Runtime conditions...
Invalid overlay_prefix sun50i-h616
I changed it to sun50i-h618
but Invalid overlay_prefix sun50i-h618
I made an empty overlay_prefix=
but still Invalid overlay_prefix
What should be now in overlay_prefix= in ArmBianEnv.txt for Organa Pi Zero 3 for kernel 6.12.23???
Posted (edited)
I notice that with now new kernel 6.12.23 and armbian-config where I set in device tree overlay uart5 for Orange Pi Zero 3
(OZPI v3 UART5 described in the original documentation) now change number from /dev/ttyS1 (it was up to 6.6.67 kernel version) now is /dev/ttyS0
[    0.000621] printk: legacy console [tty1] enabled
[    1.550621] printk: legacy console [ttyS0] disabled
[    1.551031] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 300, base_baud = 1500000) is a 16550A
[    1.551091] printk: legacy console [ttyS0] enabled
but I am not sure why is now change name in device tree from uart5-ph to uart5
Edited by TRay
update info about UART5
Posted (edited)
I check on my old microSD card image with kernel 6.6.75
Linux armbian 6.6.75-current-sunxi64 #1 SMP Sat Feb  1 17:37:57 UTC 2025 aarch64 GNU/Linux
[    0.000505] printk: console [tty1] enabled
[    1.371166] printk: console [ttyS0] disabled
[    1.371473] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 297, base_baud = 1500000) is a 16550A
[    1.371524] printk: console [ttyS0] enabled
[    1.372761] 5001400.serial: ttyS1 at MMIO 0x5001400 (irq = 298, base_baud = 1500000) is a 16550A
and now I see that /dev/ttyS0 is for console connect but /dev/ttyS1 was UART5 on 26 PIN header so at current with new kernel 6.12.23 and we set in armbianEnv.txt
sun50i-h616-uart5
via armbian-config
we are not have access to UART5 /dev/ttyS1
Edited by TRay
I see that current image Orange Pi Zero 3 for download base on kernel 6.12
so the question is, does anyone have a problem with access to UART5 which is on the 26-pin connector?
Posted (edited)
Hi I know that I can use UART5 as /dev/ttyS1 but it worked on kernel 6.6.67 when in overlays was used uart5-ph but after
update to kernel 6.12.23 and new armbian-config now when you use armbian-config to setup device tree the UART5 has changed name to sun50i-h616-uart5 and this name is put in overlays in armbianEnv.txt.
overlays=sun50i-h616-uart5
After reboot we lose UART5 as /dev/ttyS1
But I found old problem that armbian-config add overlay_prefix to device name (https://github.com/armbian/configng/issues/344#issuecomment-2613947809 ) and this make problem. When I removed sun50i-616 from name sun50i-616-uart5 and overlays line looks:
overlays=uart5     (don't use uart5-ph)
now I see again UART5 /dev/ttyS1 in my system
[    0.000624] printk: legacy console [tty1] enabled
[    1.552801] printk: legacy console [ttyS0] disabled
[    1.553231] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 301, base_baud = 1500000) is a 16550A
[    1.553288] printk: legacy console [ttyS0] enabled
[    1.554781] 5001400.serial: ttyS1 at MMIO 0x5001400 (irq = 303, base_baud = 1500000) is a 16550A
Edited by TRay
The question is why (what was the reason) the name for h616 uart5-ph which was used so far to the name uart5 was changed (without -ph)? This will now cause many people to look for a solution to the problem with access to UART5. In the new kernel 6.12.23 I see that UART2 which is also available is still in the device tree called uart2-ph-...
Posted (edited)
Nice find :)
I don't know why those changes happen... but we as bleeding edge linux users, must be aware of those things (by searching in the armbian forum... or sometimes in the raspberry forum)
Edited by robertoj
On 4/21/2025 at 9:29 AM, Werner said:
Seems like the default for sunxi64 family is v2024.01. You can try manually bumping it by overwriting at board level and see what happens.
I see that u-boot 2025.04 has applied some fixes to DRAM detection a month ago
https://github.com/u-boot/u-boot/commits/master/arch/arm/mach-sunxi/dram_sun50i_h616.c
so if the new u-boot 2025.04 via apt upgrade will be available in armbian for Orange Pi Zero 3, there is hope that the problem of incorrect detection of RAM size will be solved
From the information of DietPi users, it appears that they have used UBoot v2025.04 for Orange Pi Zero 3 and it seems that the problem of incorrect detection of RAM size has been solved, especially in the version with 1 MB. It would be valuable if ArmBian was also transferred for Orange Pi Zero 3 to Uboot v2025.04, we could avoid complications during system updates and other processes that need a lot of RAM causing the system to hang up because they try to use memory addresses that are not physically there when the RAM size was incorrectly identified during booting.
More info about UBoot v2025.04 with Orange Pi Zero 3:
https://github.com/MichaIng/DietPi/issues/7242#issuecomment-2912290816
12 часов назад, TRay сказал:
Ok!
Are you ready to test it?
   /_\  _ _ _ __ | |__(_)__ _ _ _
  / _ \| '_| '  \| '_ \ / _` | ' \
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|
 v25.5.1 for Orange Pi Zero3 running Armbian Linux 6.12.23-current-sunxi64
 Packages:     Ubuntu stable (noble)
 Support:      DIY (community maintained)
 IPv4:         (LAN) 192.168.***.*** (WAN) ***.***.***.***
 IPv6:         ***
 Performance:
 Load:         4%               Up time:       16 min    Local users:   3
 Memory usage: 45% of 971M       Zram usage:    47% of 485M
 CPU temp:     46°C                Usage of /:   11% of 58G
 RX today:     98 MiB
 Commands:
 Configuration : armbian-config
 Monitoring    : htop
*** System restart required ***
 Some packages require a reboot (gnome-shell)
orangepi@orangepizero3:~$
I am also available for testing new images on Orange Pi Zero 3, while I am new to this SBC I am happy to learn.
Today I have installed "Armbian_community_25.8.0-trunk.38_Orangepizero3_bookworm_current_6.12.23_minimal.img" to use for NTP server purposes.
I have successfully enabled uart5 by using "overlays=uart5" and seeing GPS data with "gpsmon /dev/ttyS1".
However, I also want to use PPS signal coming from my Waveshare L76K module, and the pps device does not seem to be created.
I have used the following dts, from this forum:
/dts-v1/;
/plugin/;
        compatible = "allwinner,sun50i-h616";
        fragment@0 {
                target = <&pio>;
                __overlay__ {
                        pps_pins: pps_pins {
                                pins = "PC7";
                                function = "gpio_in";
        fragment@1 {
                target-path = "/";
                __overlay__ {
                        pps@0 {
                                compatible = "pps-gpio";
                                pinctrl-names = "default";
                                /* pinctrl-0 = <&pps_pins>; */
                                gpios = <&pio 2 7 0>; /* PC7 */
                                status = "okay";
Then I did "armbian-add-overlay sun50i-h616-pps-gpio.dts" followed by a reboot. Then I do not see any PPS device.
Am I missing something else?
I use the ArmBian version which is updated very often (see below) so if U-Boot v2025.04 for OZPI v3 appears in the current updates it will be possible to check and other users who have OZPI v3 with 1,1.5, 2, or 4 Gb RAM check it
@Igor
Armbian_25.5.1_Orangepizero3_bookworm_current_6.12.23_mi
nimal.img.xz
below is transcript from the 'debug uart (serial)' console, via a usb-uart dongle, it is the only way to boot up with a console , if network etc is not available.
U-Boot 2024.01-armbian-2024.01-S866c-P4a40-H8869-V3d5b-Bb703-R448a (May 28 2025 - 02:53:19 +0000) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: OrangePi Zero3
DRAM:  1.5 GiB
Core:  57 devices, 25 uclasses, devicetree: separate
WDT:   Not starting watchdog@30090a0
MMC:   mmc@4020000: 0
Loading Environment from FAT... Unable to use mmc 0:1...
_             _    _
 Packages:     Debian stable (bookworm)
 Updates:      Kernel upgrade enabled and 23 packages available for upgrade
 IPv4:         (LAN) 192.168.xxx.xxx (WAN) xxx.xxx.xxx.xxx
 IPv6:         fd00:xxxx:xxxxx, xxxxx (WAN) xxxx
 Performance:
 Load:         18%              Up time:       2 min
 Memory usage: 9% of 1.44G
 CPU temp:     50°C              Usage of /:   9% of 15G
 Commands:
 Upgrade       : armbian-upgrade
 Monitoring    : htop
root@orangepizero3:~# ping google.com
PING google.com (142.250.4.138) 56(84) bytes of data.
64 bytes from sm-in-f138.1e100.net (142.250.4.138): icmp_seq=1 ttl=100 time=2.77 ms
64 bytes from sm-in-f138.1e100.net (142.250.4.138): icmp_seq=2 ttl=100 time=2.79 ms
^ ethernet works
root@orangepizero3:~# ip link set wlan0 up
root@orangepizero3:~# iw dev wlan0 scan
BSS xxxxx
    freq: 24xx
    signal: -77 dBm
^ wifi works, at least for scanning for stations, connect and AP not yet tested
^ the above is booted up on a 'rare' 1.5GB board.
repeat using the same uSD card on a 4 GB board, initially the debug usb-uart console is garbled, it seemed to be a baud rate mismatch, I'm not sure why, but after a few retry it works. Perhaps it is due to bad wires.
DRAM:  4 GiB
MMC:   mmc@4020000: 0
_             _    _
 IPv6:         fd00:xxxx:xxxxx, xxxxxxxx (WAN) xxxxxxxx
 Performance:
 Load:         12%              Up time:       1 min
 Memory usage: 3% of 3.83G
 CPU temp:     46°C              Usage of /:   9% of 15G
 Commands:
 Monitoring    : htop
PING google.com (142.251.12.139) 56(84) bytes of data.
64 bytes from se-in-f139.1e100.net (142.251.12.139): icmp_seq=1 ttl=103 time=2.69 ms
64 bytes from se-in-f139.1e100.net (142.251.12.139): icmp_seq=2 ttl=103 time=2.99 ms
^ ethernet works
BSS xxxxxx(on wlan0)
        freq: 24xx
        signal: -78.00 dBm
^ wifi works for scan, connect and AP not tested
I'm not too sure what is the difference between v25.5.1 vs that on the boards page?
https://www.armbian.com/orange-pi-zero-3/
from those links 'current' seemed to be linked to: as of current 28 May 2025
Armbian_community_25.8.0-trunk.8_Orangepizero3_bookworm_current_6.12.23_minimal.img.xz
btw thanks much (to all contributors) for updating Armbian to 25.x for OrangePi Zero 3 (and likely means works for Zero 2W) as well.
oh frequency scaling works as well, this is on the 4GB board
root@orangepizero3:~# armbianmonitor -m
Stop monitoring using [ctrl]-[c]
Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
01:43:36  1416 MHz  0.00   1%   0%   0%   0%   0%   0%  47.2 °C  0/7
01:43:41   480 MHz  0.00   0%   0%   0%   0%   0%   0%  47.2 °C  0/7
01:43:46   480 MHz  0.00   0%   0%   0%   0%   0%   0%  47.4 °C  0/7
01:43:51   480 MHz  0.00   0%   0%   0%   0%   0%   0%  47.0 °C  0/7
'everyone' should just get the 4GB board, make it a 'standard' lol ;)
@TRay
It is a good idea to try  U-Boot v2025.04
I've got a python script which can patch u-boot  binary into an Armbian .img or practically any other image file (though i've only tested this in *unofficial* armbian builds)
https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/tree/main/tools
i created it back then while researching solutions for the '1.5GB' problem back then.
Do you have the 'bin' file for u-boot that you could share say in a zip file attached here?
you can extract that 'bin' file using the 'backup' procedure documented here:
https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3?tab=readme-ov-file#how-to-use
sudo dd if=/dev/sdX of=u-boot-backup.bin bs=1024 skip=8 count=1024
But that the appropriate way would be to build the full armbian image from source including u-boot etc.
Nevertheless, having the 'patched' u-boot binary would enable most here to test that by patching a distributed image file e.g. from the boards page, or from the 'test images' link as Igor has provided.
Posted (edited)
sun50i-h616-spidev1_1.dtso
/dts-v1/;
/plugin/;
    fragment@0 {
        target-path = "/aliases";
        __overlay__ {
            spi1 = "/soc/spi@5011000";
    fragment@1 {
        target = <&spi1>;
        __overlay__ {
                    status = "okay";
            #address-cells = <1>;
            #size-cells = <0>;
                        pinctrl-0 = <&spi1_pins>,<&spi1_cs1_pin>;
            spidev1_1: spidev@1 {
                compatible = "armbian,spi-dev";
                status = "okay";
                reg = <1>;
                spi-max-frequency = <1000000>;
Edited by mantouboji
fix code
I moved them to production already as I got another report they are working - so they are the same, but also community build images are mixed with those links ... this needs to be fixed eventually.
Thank you for comprehensive testings.
Here is image for 2w if anyone have it laying around:
https://fi.mirror.armbian.de/incoming/igorpecovnik/orangepizero2w/archive/
 v25.5.1 for Orange Pi Zero2W running Armbian Linux 6.12.23-current-sunxi64
 Updates:      Kernel upgrade enabled and 17 packages available for upgrade
 IPv4:         (LAN) 192.168.***.***, 192.168.***.*** (WAN) ***.***.***.***
 IPv6:         ***
 Performance:
 Load:         11%               Up time:       4 min    Local users:   3
 Memory usage: 24% of 1.93G
 CPU temp:     45°C                Usage of /:   10% of 58G
 Commands:
 Monitoring    : htop
orangepi@orangepizero2w:~$
It boots into xfce wifi works, eth works and hdmi work.
2gb board with keyboard plugged into expansion board.
