mexmet Posted July 12, 2021 Posted July 12, 2021 Thanx RaptorSDS Now I can boot... yeesssss... But I have now another problem. I install OMV, and afteer that i can not fix eth mac adress.. Afteer every boot change mac adress, and ip adress. I set mac adreess in /etc/network/interfaces, but not solved the problem. How can I fix that.?
RaptorSDS Posted July 13, 2021 Posted July 13, 2021 On 7/12/2021 at 5:08 PM, mexmet said: Thanx RaptorSDS Now I can boot... yeesssss... But I have now another problem. I install OMV, and afteer that i can not fix eth mac adress.. Afteer every boot change mac adress, and ip adress. I set mac adreess in /etc/network/interfaces, but not solved the problem. How can I fix that.? Expand short goog le and i found OMV has its own network-manager , all settings in interfaces will be ignore you have to set all network things inside OMV https://forum.openmediavault.org/index.php?thread/23034-network-manager/&postID=176055
AzuriAdore Posted July 31, 2021 Posted July 31, 2021 Hey everyone, I updated my guide on making Docker work here https://github.com/SLAzurin/armbian-aml-s8xx-kernel-build-steps (For Ubuntu/Debian on linux version 5.10) @balbes150 The previous comment for Docker requirements is wrong. These here are the only config you need to enable to make Docker work when you build the linux kernel. CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y I hope you can add it successfully for the next release, thank you for your work. 1
RaptorSDS Posted August 1, 2021 Posted August 1, 2021 On 7/31/2021 at 9:51 PM, AzuriAdore said: Hey everyone, I updated my guide on making Docker work here https://github.com/SLAzurin/armbian-aml-s8xx-kernel-build-steps (For Ubuntu/Debian on linux version 5.10) @balbes150 The previous comment for Docker requirements is wrong. These here are the only config you need to enable to make Docker work when you build the linux kernel. CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y I hope you can add it successfully for the next release, thank you for your work. Expand i do not know if there will be a new build because balbes150 has stop working on this box , but on kernel GIT and linx GIT there still some person who fix things maybe you have to ask there.
AzuriAdore Posted August 5, 2021 Posted August 5, 2021 On 8/1/2021 at 6:51 AM, RaptorSDS said: i do not know if there will be a new build because balbes150 has stop working on this box , but on kernel GIT and linx GIT there still some person who fix things maybe you have to ask there. Expand Ok thanks for the heads up, I'll try to contact xdarklight to see if those can be enabled by default.
Alex83 Posted August 8, 2021 Posted August 8, 2021 On 1/15/2020 at 11:00 PM, Red2 said: I have an old tv box with S802 MXIII 4k 1g8g netxeon m82 Just wondering what the latest Linux image I can get it to run and where would I find an image file. Most I find seem to only be for 2g boxes or I'm misinterpreting the info, which isn't that unlikely. Everything I have tried has failed so it would be nice to know if someone else got Linux install on one and which version Thank in advance Expand Hey, Can anyone help me? My device is Netxeon M82G V2.0 S812/2G/8G/AP6330 (Tronsmart MXIII Plus clone?). It's not booting proper. What shall I do first? Sometimes it boots until Android Logo on the screen and mostly you can just see Android TV Googleatv logo at the start. I recognized that ricoh rn5t618m chipset gets very fast hot. Any ideas or suggestions? Does someone still have an original image for debricking tries?
RaptorSDS Posted August 8, 2021 Posted August 8, 2021 ricoh rn5t618m is the power managment IC , if this is your main error than also a image can not help you its look like you found the startup problem if the power IC get wrong settings from image maybe a linux can help When you get multiboot activate you can boot from SD or USB , you have not to fear to brick because orginal android is not touched ( get a orginal image is hard to find because of the varity of the box ) maybe someone else can jump in and have more ideas about the thermal problems
Alex83 Posted August 12, 2021 Posted August 12, 2021 Hey @RaptorSDS, Thanks for your comment. I think so to and I don't know if it's a software or hardware related problem. I just noticed that the chip gets very fast hot.... Hmm... I would love and really appreciate if someone could offer an image or link to a possible download. I would think it's best to start a debricking try from windows with amligic-tool or something similar. I just did this with rk3229 boxes... But this S812 is opened and I can do some shortcut or whatever is needed to bring it to mask rom mode.
RaptorSDS Posted August 12, 2021 Posted August 12, 2021 @Alex83 be aware S812 is no rk3229 you can deep brik this device , Amlogic has no fallback to sd card when internal memory fail or boot loader missing only real way is to get into boot loader and install aml_autoscript.zip than you get multiboot and can use sdcard as linux boot drive
AzuriAdore Posted September 10, 2021 Posted September 10, 2021 Hey guys, I'm releasing my personal Armbian build for AML s8xx compatible with Docker. Armbian: 21.11.0 Ubuntu: 20.04 focal Linux: 5.14-rc2 by xdarklight Original build files by balbes150 I only tweaked the board settings. Files used here: https://github.com/SLAzurin/build-armbian-custom/tree/s8xx Build steps on system with Ubuntu 20.04 and docker: Copy files from `userpatches.s8xx` to `userpatches` ./compile_s812.sh Mount the output image file to your filesystem (Check `postbuild.sh` for more details) Change the label for the ext4 partition to be `ROOTFS` Unmount image file and flash to SD Card. (Optional) Generate new .sha file with `sha256sum $IMAGE > $IMAGE.sha` Downloads here: https://github.com/SLAzurin/build-armbian-custom/releases/tag/v2021.11-s8xx I will not be taking any requests, it is already hard enough to get an image released as it is. You get what you get. Thank you for understanding =) Edit: When you try to install Docker, If you run into an issue that says cannot find package docker-ce, or something similar, do this: sudo sed -i "s/focal/bionic/g" /etc/apt/sources.list.d/docker.list sudo apt-get update sudo apt-get install -y docker-ce docker-ce-cli containerd.io 1
Nabiloo Posted September 12, 2021 Posted September 12, 2021 On 4/5/2021 at 5:09 PM, Ruf73 said: @balbes150, good day! I ran Armbian_5.77_Aml-s812_Debian_stretch_default_3.10.108_20190326.img from the SD card, then copied it to nand. However, there was a problem. When I boot from the SD card, the system did not start without an hdmi cable until I removed the parameter "logo=osd1,loaded,0x15100000,1080p,full" from the uEnv.ini. It was in this configuration that I copied the system to nand. But when the system starts from nand, in the Kernel command line I again see the logo parameter! And the system does not start without a hdmi cable. How do I edit the Kernel command line? upd: solved the problem myself, thanks for the silence Expand Hi, Can you please help me, i have a M8S BCM4335 2GB Which dtb did you used to boot with Armbian_5.77_Aml-s812_Debian_stretch_default_3.10.108_20190326.img ? did you resolved 'HDMI must be pluged to boot' issue ? Thank you in advance FYI, i am actually booting with Armbian_5.44_S812_Debian_stretch_3.10.108_server_20180521.img without specifiying the db (strang ...) but hdmi need to be pluged if unplaged the linux crash BR, Nab
RaptorSDS Posted September 12, 2021 Posted September 12, 2021 @Nabiloo on 5.77 and 5.44 there should be only two m8s dtb files , your choice is only small. normally a there is a standard dtb ( i thing a mxii one) already on boot folder as dtb.img, on 3.10.108 Kernel image you have to copy and rename your dtb to dtb.img on boot folder some box still with right dtb have the HDMI plug problem , there was a patch with a HDMI plug dongle without cable 1
truonggiang152 Posted September 14, 2021 Posted September 14, 2021 Thank Azuri. It's works with Armbian_21.02.0-trunk_Aml-s812_bullseye_current_5.10.0. But how it's works with Armbian_5.67_Aml-s805_Debian_stretch_default_3.10.108_20181207. Please help!!
RaptorSDS Posted September 15, 2021 Posted September 15, 2021 @truonggiang152 i think its not possible to have docker in Armbian 5.67 because this has only a 3.10.108 Kernel . This Kernel was not and is not compatible to docker
dual3zw Posted September 16, 2021 Posted September 16, 2021 On 1/26/2021 at 3:45 PM, menelike said: @SteeMan Thanks for your response. I am not sure what you mean with "clean copy", but Kernel 3.x runs perfectly fine on the device. I just wanted to upgrade debian from stretch to bullseye because of missing/outdated debian packages. But I think that you're correct, there is no upgrade path. 😪 Luckily I had a H96 Pro H3 with a S905x which I managed to run the bullseye on. Expand Hi. Have you been able to get the wifi to work with 2.4 and 5 GHz on your H96 Pro in Bullseye?
erduk Posted September 29, 2021 Posted September 29, 2021 On 9/10/2021 at 4:27 PM, AzuriAdore said: Hey guys, I'm releasing my personal Armbian build for AML s8xx compatible with Docker. Armbian: 21.11.0 Ubuntu: 20.04 focal Linux: 5.14-rc2 by xdarklight Original build files by balbes150 I only tweaked the board settings. Files used here: https://github.com/SLAzurin/build-armbian-custom/tree/s8xx Build steps on system with Ubuntu 20.04 and docker: Copy files from `userpatches.s8xx` to `userpatches` ./compile_s812.sh Mount the output image file to your filesystem (Check `postbuild.sh` for more details) Change the label for the ext4 partition to be `ROOTFS` Unmount image file and flash to SD Card. (Optional) Generate new .sha file with `sha256sum $IMAGE > $IMAGE.sha` Downloads here: https://github.com/SLAzurin/build-armbian-custom/releases/tag/v2021.11-s8xx I will not be taking any requests, it is already hard enough to get an image released as it is. You get what you get. Thank you for understanding =) Edit: When you try to install Docker, If you run into an issue that says cannot find package docker-ce, or something similar, do this: sudo sed -i "s/focal/bionic/g" /etc/apt/sources.list.d/docker.list sudo apt-get update sudo apt-get install -y docker-ce docker-ce-cli containerd.io Expand Hi there, Many thanks for your efforts. I was able to boot your image with my MK808b plus device. I am planning to use it on my 3D printer for Octoprint/Klipper service. However, I'm facing the same issue that I couldn't fix it on previous balbes150 images: onboard wifi device (AP6210) doesn't work. I tried modprobe b43 and b43legacy didn't work out. I used meson8b-ec100.dtb as dtb.img For more information, I can use wifi on a prehistoric (ubuntu-mate-15-04-s805-standard-0_95_Beta.img.xz) image made by anonymous. but that built is way to old and I was not able to upgrade it to bionic to install uptodate python3. Anyway, I hope someone could help me on that. BR erduk
RaptorSDS Posted September 29, 2021 Posted September 29, 2021 On 9/29/2021 at 9:21 AM, erduk said: Hi there, Many thanks for your efforts. I was able to boot your image with my MK808b plus device. I am planning to use it on my 3D printer for Octoprint/Klipper service. However, I'm facing the same issue that I couldn't fix it on previous balbes150 images: onboard wifi device (AP6210) doesn't work. I tried modprobe b43 and b43legacy didn't work out. I used meson8b-ec100.dtb as dtb.img For more information, I can use wifi on a prehistoric (ubuntu-mate-15-04-s805-standard-0_95_Beta.img.xz) image made by anonymous. but that built is way to old and I was not able to upgrade it to bionic to install uptodate python3. Anyway, I hope someone could help me on that. BR erduk Expand If you use the newer Image 20.xx ( Kernel 5.xx) you have to edit uEnv , your rename of dtb.img is wrong ! also bionic i thing need kernel 4.xx and newer 1
erduk Posted September 30, 2021 Posted September 30, 2021 On 9/29/2021 at 12:16 PM, RaptorSDS said: If you use the newer Image 20.xx ( Kernel 5.xx) you have to edit uEnv , your rename of dtb.img is wrong ! also bionic i thing need kernel 4.xx and newer Expand I've already did that too. Now it seems that dtb.img was unnecessary, editing uEnv did the trick. I got it now. I found my device's correct dtd while searching on the web. I uploaded to my github if anyone would need it. https://github.com/erkutoyus/mk808bplus/blob/main/meson8b_mk808bplus.dtd I wanted to build an armbian image for myself but I couldn't figure it out how to do that. I looked at github in every folder of armbian source code and there is no folder containing dtd's. I couldn't find how to add new board there. If anyone can help me on that, I would highly appreciate it. BR erduk
SteeMan Posted September 30, 2021 Posted September 30, 2021 On 9/30/2021 at 7:54 PM, erduk said: I wanted to build an armbian image for myself but I couldn't figure it out how to do that. I looked at github in every folder of armbian source code and there is no folder containing dtd's. I couldn't find how to add new board there. If anyone can help me on that, I would highly appreciate it. Expand .dts are part of the kernel (.dtb's are binary and built from the .dts source files as part of a kernel build). The s805 dts's can be found in the linux kernel tree under arch/arm/boot/dts. To add a dtb to the build process you would need to add a kernel patch to the armbian build that puts the .dts in the proper location.
erduk Posted October 1, 2021 Posted October 1, 2021 On 9/30/2021 at 11:21 PM, SteeMan said: .dts are part of the kernel (.dtb's are binary and built from the .dts source files as part of a kernel build). The s805 dts's can be found in the linux kernel tree under arch/arm/boot/dts. To add a dtb to the build process you would need to add a kernel patch to the armbian build that puts the .dts in the proper location. Expand Ok, here is what I did: from AzuriAdore's repo I cloned armbian custom build exact branch (s8xx) git clone -b s8xx https://github.com/SLAzurin/build-armbian-custom sudo ./compile.sh I selected aml-s812 from the list to obtain his customizations. and waited couple of hours for the script to download necessary files. I found dts files under /cache/sources/linux-aml-current/meson-mx-integration-5.14-20210718/arch/arm/boot/dts folder as mentioned however, looking in configuration files I couldn't find any link to these dts files so I wasn't sure which file to alter. I was lost again, here I am
SteeMan Posted October 1, 2021 Posted October 1, 2021 @erduk Have you read the armbian documentation: https://docs.armbian.com/Developer-Guide_User-Configurations/
erduk Posted October 3, 2021 Posted October 3, 2021 @SteeMan ok what I've done so far; I found mk808bplus userpatch someone made for lakka https://github.com/eloirotava/lakka/blob/Lakka-2.3.2/projects/S805/patches/linux/meson8b_mk808bplus_dtd.patch and put it into userpatch directory compiled as usual but nothing seems to changed what I'm missing?
armbian-mxq Posted October 17, 2021 Posted October 17, 2021 i am using bullseye image for mxq-box s805/1Gb from this https://users.armbian.com/balbes150/s8xx/ previously i used armbian 5.67 with kernel 3 and meson8b-mxq dtb. everything just worked ok with that both with sdcard and usb. now with the 21 bulleseye meson8b-mxq.dtb doesn't give a proper hdmi signal. i get hdmi signal on my samsung monitor with meson8b-ec100.dtb and odroidc1.dtb but no signal on my 720p TV. If i run apt upgrade it remounts filesystem readonly giving i node errors. while working hdmi is currently low on my priority but this sdcard root ro remount on error is giving me a headache. on checking e2fsck everthing just seems fine. it happens if it writes very fast to sd card. what could be the problem? i want to run openvpn client on it..
RaptorSDS Posted October 18, 2021 Posted October 18, 2021 @armbian-mxq do you use the menson8b-mxq.dtb from 3.xx kernel on the 5.xx kernel ? -> thats didn`t work because kernel5 use some diffirent pin descriptions. also many dtb was rewriten for kernel 5.xx thats why maybe hdmi did not work. there could be some sd-card error because the SD-card driver was rewriten on kernel5 because of non-free code in the old sd-card driver. But than its shoulde be only high speed or low speed sd-card or non detect BUT that a filesystem was fine than readonly than fine -> this looks more like programm error not a driver issue do you use apt-upgrade as normal user or root user ? or Is there another apt-upgrade thread at the same time?
armbian-mxq Posted October 19, 2021 Posted October 19, 2021 On 10/18/2021 at 5:08 AM, RaptorSDS said: @armbian-mxq do you use the menson8b-mxq.dtb from 3.xx kernel on the 5.xx kernel ? -> thats didn`t work because kernel5 use some diffirent pin descriptions. also many dtb was rewriten for kernel 5.xx thats why maybe hdmi did not work. there could be some sd-card error because the SD-card driver was rewriten on kernel5 because of non-free code in the old sd-card driver. But than its shoulde be only high speed or low speed sd-card or non detect BUT that a filesystem was fine than readonly than fine -> this looks more like programm error not a driver issue do you use apt-upgrade as normal user or root user ? or Is there another apt-upgrade thread at the same time? Expand This dtb is from bullseye image /boot/dtb which i downloaded. I did not make any changes. For large files, i did dd if=/dev/zero of=./test bs=1024 count=500000 but no errors in this case. if I cp this or wget a large file then also i get no errors. for a large file proceeds without any errors. I also get cpu big soft lockup 22s message of i use external usb to boot. In case of sd card, it simply remounts filesystem in ro even if i put ro=continue in fstab for rootfs. Strange but on e2fs -f on a different box with this sdcard there is no corruption. May be some buffer overflows? I use apt upgrade as a root ooras a sudo. I also tried mounting external flash and symlink on /var/cache/apt still i get errors. Errors of inode start generally when download speed is high, say 15mbps or more. apt doesn't work in another thread because there is dpkg lock I guess sd card cant cope up with that though not sure.
RaptorSDS Posted October 19, 2021 Posted October 19, 2021 On 10/19/2021 at 3:42 AM, armbian-mxq said: This dtb is from bullseye image /boot/dtb which i downloaded. I did not make any changes. For large files, i did dd if=/dev/zero of=./test bs=1024 count=500000 but no errors in this case. if I cp this or wget a large file then also i get no errors. for a large file proceeds without any errors. I also get cpu big soft lockup 22s message of i use external usb to boot. In case of sd card, it simply remounts filesystem in ro even if i put ro=continue in fstab for rootfs. Strange but on e2fs -f on a different box with this sdcard there is no corruption. May be some buffer overflows? I use apt upgrade as a root ooras a sudo. I also tried mounting external flash and symlink on /var/cache/apt still i get errors. Errors of inode start generally when download speed is high, say 15mbps or more. apt doesn't work in another thread because there is dpkg lock I guess sd card cant cope up with that though not sure. Expand but weird that both usb and sdcard produce errors maybe also its some pin definition error from hdmi wich also produce error on memory or IO ports Problem at the moment we havent a lead system programmer for this box , balbes the maintainer of s805/S812 switch to rockchip system if you tell witch dtb you use i can maybe change some setting to disable HDMI complete but i can only change a small amount of dtb not all
armbian-mxq Posted October 21, 2021 Posted October 21, 2021 On 10/19/2021 at 7:16 PM, RaptorSDS said: but weird that both usb and sdcard produce errors maybe also its some pin definition error from hdmi wich also produce error on memory or IO ports Problem at the moment we havent a lead system programmer for this box , balbes the maintainer of s805/S812 switch to rockchip system if you tell witch dtb you use i can maybe change some setting to disable HDMI complete but i can only change a small amount of dtb not all Expand Working dtb is meson8b-odroidc1 and meson8b-ec100 others simply don't work
george_1312 Posted October 21, 2021 Posted October 21, 2021 hi guys! congrats for the excellent work and time you put into this. i have an old MX-III 2/8 with PCB: M82_V3.0_20140826 and would like to flash linux on it... I am soldering-wise-capable and have already removed the emmc and eeprom chips to program them directly on an external progammer (i.e. TL866-II)... is that possible? are there images ready for this king of work??? for me this way is the least complicated (instead of trying to use aml files and other scripts from the SD) thank you so much.
RaptorSDS Posted October 21, 2021 Posted October 21, 2021 On 10/21/2021 at 10:03 AM, george_1312 said: is that possible? are there images ready for this king of work??? Expand not this one's , mostly all are for Usb and SD-Card. you can try but than you have to with manually edit some files and uboot and .... (my box run now 4-5years with sd-card without problem) be aware this box are get deep brick with wrong uboot on emmc/nand there is no maskrom mode or any restore function in uboot 1
