Joel Posted February 24 Share Posted February 24 Are there any plans to make a version with the new Rockchip 6.1 kernel available for Orange Pi 5/5+? Joshua Riek seems to have had some success, he even got the Panfork drivers running. I run a headless server though so even without graphics it would be interesting but I use Debian. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted February 24 Share Posted February 24 Hi, no official plans as I am aware of. However anyone can step up and try to adopt the newer rk bsp into the build framework. 0 Quote Link to comment Share on other sites More sharing options...
Spooky Posted February 25 Share Posted February 25 I've been doing some work on the 6.1 kernel and would be happy to help adapt it to the build framework. I do think the Edge 2 will need some work as I had to drop some patches related to the board during my rebase. But I'd like to sort out mpp, ffmpeg, and chrome first as they all need changes to work properly. These packages should be patched in Amazingfate's PPA before upgrading the kernel to prevent breaking HW accel on jammy systems currently using the 5.10 kernel. So far, I have patched packages for everything except chromium. For some reason when using chrome to play 4k 60fps videos on YouTube, the video will stutter. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted February 26 Share Posted February 26 Just pinging @amazingfate and @Efe Çetin Maybe they want to join the 6.1 journey. If not, apologies 0 Quote Link to comment Share on other sites More sharing options...
Spooky Posted February 29 Share Posted February 29 Quote So far, I have patched packages for everything except chromium. For some reason when using chrome to play 4k 60fps videos on YouTube, the video will stutter. I was missing a patch for libv4l-rkmpp, now chrome is working with 4k 60fps playback on youtube again. 0 Quote Link to comment Share on other sites More sharing options...
Spooky Posted February 29 Share Posted February 29 Hi @amazingfate! Can you take a look at some of the changes I made to ffmpeg, librga, librist, libv4l-rkmpp, mpp, mpv, and v4l-utils? I would love to update these packages in your PPA for compatibility with the 6.1 kernel. I have my changes available here on launchpad: https://launchpad.net/~jjriek/+archive/ubuntu/rockchip-multimedia?field.series_filter=jammy 0 Quote Link to comment Share on other sites More sharing options...
amazingfate Posted February 29 Share Posted February 29 @Spooky Many thanks to your work. My company is pushing me hard these days and I don't have time to test 6.1 kernel. If these packages is working for you I can just copy it to my ppa. I can see ffmpeg, librga, libv4l-rkmpp, mpp is updated to latest upstream version. What are the changes you make to librist, mpv and v4l-util? 0 Quote Link to comment Share on other sites More sharing options...
Spooky Posted February 29 Share Posted February 29 @amazingfate No worries, I'm happy to work on this! There are no changes to librist, v4l-util, and mpv, I have them in my PPA for testing/development. The only packages that need to be copied are ffmpeg, librga, libv4l-rkmpp, and mpp. 0 Quote Link to comment Share on other sites More sharing options...
Spooky Posted February 29 Share Posted February 29 The `av1_rkmpp` decoder is broken in my PPA and I need to update ffmpeg again. Let me do some more debugging and I will let you know when this is fixed. https://github.com/Joshua-Riek/ubuntu-rockchip/issues/613#issuecomment-1971250537 0 Quote Link to comment Share on other sites More sharing options...
Spooky Posted March 1 Share Posted March 1 (edited) Hey @amazingfate, the above-mentioned av1 decoder issue was fixed, turned out that the Rock 5A and a few other boards did not have the av1d node enabled in the device tree. I did update ffmpeg and added some patches to mpv last night, after testing everything it looks good to go. The packages ffmpeg, librga, libv4l-rkmpp, mpp, and mpv are ready to be copied to your PPA. https://launchpad.net/~jjriek/+archive/ubuntu/rockchip-multimedia/+packages?field.name_filter=&field.status_filter=published&field.series_filter=jammy Edited March 1 by Spooky 1 Quote Link to comment Share on other sites More sharing options...
amazingfate Posted March 2 Share Posted March 2 @SpookyWill these packages work with old 5.10 legacy kernel? Some people may still using 5.10 kernel. I will test them later. 0 Quote Link to comment Share on other sites More sharing options...
amazingfate Posted March 2 Share Posted March 2 @Spooky kodi is not working with this version of ffmpeg, videos are displayed black. Mpv also not work, how did you get mpv work with hardware decoding? 0 Quote Link to comment Share on other sites More sharing options...
nyanmisaka Posted March 2 Share Posted March 2 @amazingfate The old hbiyik/FFmpeg is deprecated in favor of ffmpeg-rockchip. The latter one have different default behavior to enable the best performance and 10-bit/P010 support. Also the hbiyik/FFmpeg doesn't support the 6.1 bsp because the 6.1 kernel lacks of rk-dma-heap allocator. You can only use the drm gem allocator. Not only that, the decoder, filter and encoder components are bundled together in hbiyik/FFmpeg/libavcodec, makeing the code difficult to read and maintain. So we decided to move. - https://github.com/7Ji-PKGBUILDs/.report/issues/15#issuecomment-1909770887 - https://github.com/7Ji-PKGBUILDs/.report/issues/17#issuecomment-1913746159 To adapt MPV to ffmpeg-rockchip, except for the included nv16/p010/p210 format patches, there are two additional MPV configs need to be set in `/etc/mpv/mpv.conf`. To adapt Kodi to ffmpeg-rockchip, see this Wiki page. You will get 8k 60fps HEVC 10-bit playback this time. 0 Quote Link to comment Share on other sites More sharing options...
amazingfate Posted March 2 Share Posted March 2 @nyanmisakathanks, mpv with hwdec rkmpp works. And kodi in my ppa need patches to work. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted March 6 Share Posted March 6 Images for testing are coming up: https://k-space.ee.armbian.com/incoming/orangepi5/archive/ https://k-space.ee.armbian.com/incoming/orangepi5-plus/archive/ or https://fi.mirror.armbian.de/incoming/ or https://stpete-mirror.armbian.com/incoming/ 0 Quote Link to comment Share on other sites More sharing options...
Dbosco Posted March 6 Share Posted March 6 Hi! i've tested Kodi in the Armbian_24.2.2_Orangepi5_jammy_vendor_6.1.43_minimal, and i've a black screen under GBM Pressing the key "o" i can see that is HW decoded, and the audio come out then, following the guide https://github.com/hbiyik/ffmpeg-rockchip/wiki/Rendering, i've stopped the desktop environment with sudo service gdm stop and started kodi with FFMPEG_RKMPP_DEC_OPT="afbc=on" kodi --windowing=gbm --audio-backend=alsa, but nothing changed I've tried with direct to plane and EGL thanks 0 Quote Link to comment Share on other sites More sharing options...
nyanmisaka Posted March 7 Share Posted March 7 https://github.com/amazingfate/linux-rockchip/commits/rk-6.1-rkr1/ lacks of a VOP2 patch, which resulted the black screen in kodi. Quote 0002-vop2_rbga2101010_capability_fix.patch : When using Kodi in GBM Mode, you will get a black screen if this patch is not applied. This is a bug in rockchip kernel. https://github.com/hbiyik/ffmpeg-rockchip/wiki/Rendering#required-patches-and-fixes-in-the-toolchain 1 Quote Link to comment Share on other sites More sharing options...
jordanius Posted March 7 Share Posted March 7 I have been running the Armbian_24.2.3_Orangepi5_jammy_vendor_6.1.43_kde-plasma_desktop.img.xz image on my OPi5 16g alongside amazing fated's panfork drivers for a couple of hours and it is working great so far. 6.x kernel a huge step forward - Many thanks to all involved ! 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted March 9 Author Share Posted March 9 I've been running with the new kernel for two days now and almost everything works great. I built my own version with the build tool since I use a headless server and could only find the minimal version of Debian Bookworm available for download. So I made a standard server version, everything else set to defaults. Open Media Vault 7 works great, and Jellyfin with Rockchip support mostly works. The only problem is that I can't get transcoding of HDR movies working with Jellyfin, transcoding of SDR and direct streaming works perfectly. That's basically what I've tested so far since that's what I use my server for, if I can only get transcoding working I'll switch permanently. Thank you all so much for making the new kernel available! 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted March 9 Author Share Posted March 9 I just remembered, one thing that doesn't work is rebooting. It seems to get stuck somewhere so I have to pull the power. It did that sometimes with the old 5.10 kernel too but now it seems to happen every time. 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted March 9 Author Share Posted March 9 (edited) I got transcoding working with HDR movies too, after some help on Github. The latest libmali driver doesn't work with kernel 6.1 so I needed an older version. Apparently the most up to date driver uses the latest DDK and that's broken with 6.1. The libmali driver v1.9-1-2d267b0 from November seems to work with 6.1 though. I've only done a few quick tests so I don't know how stable it is but if I don't notice any trouble in a day or so I'll probably move this installation from the SD card to the NVME and use it for real. Edited March 9 by Joel 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted March 9 Author Share Posted March 9 I went ahead and tried to install to NVME by using armbian-config but it doesn't boot. When I try to boot without a SD card the red light just stays on, nothing happens. I have also connected the Orange Pi to a screen with HDMI but when the SD card is out there's no output at all. Unfortunately I don't have a USB to serial adapter so I can't see if there's any output there. I updated the MTD at the same time so I thought that might be the problem, but I got the rkspi_loader.img from Armbian 24.02.1 and wrote it to MTD but that didn't change anything. Have you gotten it working from NVME, @jordanius? To end on a positive note, rebooting started working again. I really don't know if I did anything to make it work again but I've rebooted several times now during testing and it starts up again every time. 0 Quote Link to comment Share on other sites More sharing options...
Thewonderer Posted March 11 Share Posted March 11 Might need to clear the SPI flash first them re-image that before copying to NVME. I had an issue with my OPi5 + not booting of EMMC, wiping SPI and imaging that first, sorted it. With all the newer kernel versions coming out and Spooky getting close to 6.1 too, I'm not clear if I will need to do the wiping for SPi first as the uboot is different...? Any advice appreciated. 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted March 11 Author Share Posted March 11 (edited) Good idea but I tried it now and it didn't help. I erased the flash with "flash_erase /dev/mtd0 0 0" and wrote the bootloader to MTD again using armbian-config but it still doesn't boot without the SD card inserted. I even tried to erase the flash a second time and write rkspi_loader.img from Armbian 24.2 but it made no difference. Edited March 11 by Joel 0 Quote Link to comment Share on other sites More sharing options...
jordanius Posted March 12 Share Posted March 12 @Joel- Yes am running from NVME...Just did a DD of the live system and fscked the partition. The only thing I noticed is that my board was somewhat fussy about which NVME drive it would work with and would do the same thing with the red light. Does it show up in fdisk/lsblk? Maybe try another NVME if you've got one lying around. 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted March 13 Author Share Posted March 13 I've been running with the same NVME for months with Armbian installed so it can't be the board. I can also mount and access the NVME from the new install with kernel 6.1 on the SD card, its only booting from the NVME that doesn't work. 0 Quote Link to comment Share on other sites More sharing options...
Solution royk Posted March 18 Solution Share Posted March 18 @Joel @amazingfate Just tried the 6.1 image (Armbian_24.2.4_Orangepi5-plus_jammy_vendor_6.1.43_kde-neon-amazingfated_desktop.img.xz) and installed to the NVME (with only 1 ext4 partition) with armbian-install. Initially it didn't boot, there are no files in /boot. After copying the files from the boot partition of the SD-card to the /boot folder of the NVME and changing the UUID in armbianEnv.txt to the UUID of the NVME it boots. 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted March 18 Author Share Posted March 18 That did it, @royk. Now I can boot from NVME. Thank you! 0 Quote Link to comment Share on other sites More sharing options...
OttawaHacker Posted March 18 Share Posted March 18 On 3/2/2024 at 11:47 AM, nyanmisaka said: To adapt MPV to ffmpeg-rockchip, except for the included nv16/p010/p210 format patches, there are two additional MPV configs need to be set in `/etc/mpv/mpv.conf`. To adapt Kodi to ffmpeg-rockchip, see this Wiki page. You will get 8k 60fps HEVC 10-bit playback this time. This is amazing!!!! Is Wayland supported yet? I'll give this a shot once all these updates make it to the official pre-release images. 0 Quote Link to comment Share on other sites More sharing options...
jollySleeper Posted April 6 Share Posted April 6 Hi, sorry for sounding like a total noob here(which I am). I wanted to try out Jellyfin Hardware Acceleration tried out with Jellyfin Unstable (10.9) and also with Nyan-Mikasa's latest 'jellyfin-rockchip' docker image. Nothing seems to work for me. Is is because I'm using the Debian Image from Orange Pi's official site with kernel 6.1?? Will I able to make Jellyfin work in it with some patches or will have to install new OS all together? Also, @Joel can you share all the steps you took to make Hardware Acceleration work in Jellyfin like the OS you are using and all the steps that you took to make it work. Thanks to all of you <3 0 Quote Link to comment Share on other sites More sharing options...
